X-Sense Adapter
@thomas-braun Hoffe, das ist alles:
========== Start marking the full check here =========== ```bash Script v.2025-03-08 *** BASE SYSTEM *** Static hostname: iobrokervm Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-37-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org OS is similar to: model name : Common KVM processor Docker : false Virtualization : kvm Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 17:47:35 up 43 min, 1 user, load average: 1.95, 2.02, 1.88 CPU threads: 8 *** LIFE CYCLE STATUS *** Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained. *** TIME AND TIMEZONES *** Local time: Tue 2025-07-29 17:47:35 CEST Universal time: Tue 2025-07-29 15:47:35 UTC RTC time: Tue 2025-07-29 15:47:35 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': oliver HOME=/home/oliver GROUPS=oliver cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 12G 5.4G 4.8G 536K 2.3G 6.8G Swap: 5.1G 0B 5.1G Total: 17G 5.4G 9.9G Active iob-Instances: 78 11676 M total memory 5184 M used memory 911 M active memory 5306 M inactive memory 4599 M free memory 438 M buffer memory 1767 M swap cache 4881 M total swap 0 M used swap 4881 M free swap *** top - Table Of Processes *** top - 17:47:35 up 43 min, 1 user, load average: 1.95, 2.02, 1.88 Tasks: 178 total, 4 running, 174 sleeping, 0 stopped, 0 zombie %Cpu(s): 33.3 us, 33.3 sy, 0.0 ni, 33.3 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 11676.7 total, 4598.2 free, 5185.9 used, 2206.0 buff/cache MiB Swap: 4881.2 total, 4881.2 free, 0.0 used. 6490.8 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 5.7G 0 5.7G 0% /dev tmpfs tmpfs 1.2G 528K 1.2G 1% /run /dev/sda1 ext4 141G 33G 103G 25% / tmpfs tmpfs 5.8G 0 5.8G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.2G 0 1.2G 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Jul 29 17:03:57 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none. [Tue Jul 29 17:03:57 2025] EXT4-fs (sda1): re-mounted. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 2.7G /var/ 1.5G /var/log 1.1G /var/cache/apt/archives 1.1G /var/cache/apt 1.1G /var/cache Archived and active journals take up 495.7M in the file system. /opt/iobroker/backups: 228M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.4G /opt/iobroker/iobroker-data/ 1.1G /opt/iobroker/iobroker-data/files 513M /opt/iobroker/iobroker-data/files/vis 505M /opt/iobroker/iobroker-data/files/vis/widgets 160M /opt/iobroker/iobroker-data/files/vis-2 The five largest files in iobroker-data are: 68M /opt/iobroker/iobroker-data/states.jsonl 57M /opt/iobroker/iobroker-data/objects.jsonl 41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map 37M /opt/iobroker/iobroker-data/files/radar-trap.admin/build/index.js.map 33M /opt/iobroker/iobroker-data/files/vis/widgets/vis-2-widgets-jaeger-design/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.0424abce.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_08a893a38329ec11ba4c6f7840c9ce8d-if00-port0 *** ZigBee Settings *** HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/ttyUSB0 Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v20.19.4 /usr/bin/node v20.19.4 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.32.0 nodejs: Installed: 20.19.4-1nodesource1 Candidate: 20.19.4-1nodesource1 Version table: *** 20.19.4-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 20.19.3-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.19.2-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.19.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.19.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.3-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.2-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.17.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.2-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobrokervm iobrokervm (version: 7.0.7, hostname: iobrokervm , alive, uptime: 1518) Core adapters versions js-controller: 7.0.7 admin: 7.7.2 javascript: 9.0.10 nodejs modules from github: 5 +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#2cbc14b6c33d01fcc29003e3648fcb0c4d917f75) +-- iobroker.life360@0.2.22 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1) | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0) +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83) +-- iobroker.xsense@0.0.6 (git+ssh://git@github.com/arteck/ioBroker.xsense.git#531318d145d8c6ebfa1772abdf4b11b51b7869ac) Adapter State + system.adapter.admin.1 : admin : iobrokervm - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa-timer-vis.0 : alexa-timer-vis : iobrokervm - enabled + system.adapter.alexa2.0 : alexa2 : iobrokervm - enabled system.adapter.alias-manager.0 : alias-manager : iobrokervm - disabled + system.adapter.alpha-ess.0 : alpha-ess : iobrokervm - enabled + system.adapter.awtrix-light.0 : awtrix-light : iobrokervm - enabled + system.adapter.backitup.0 : backitup : iobrokervm - enabled + system.adapter.chromecast.0 : chromecast : iobrokervm - enabled + system.adapter.cloud.0 : cloud : iobrokervm - enabled system.adapter.daswetter.0 : daswetter : iobrokervm - disabled + system.adapter.device-reminder.0 : device-reminder : iobrokervm - enabled + system.adapter.device-watcher.0 : device-watcher : iobrokervm - enabled system.adapter.devices.0 : devices : iobrokervm - disabled + system.adapter.discovery.0 : discovery : iobrokervm - enabled + system.adapter.doorbird.0 : doorbird : iobrokervm - enabled system.adapter.drops-weather.0 : drops-weather : iobrokervm - disabled system.adapter.dwd.0 : dwd : iobrokervm - enabled + system.adapter.echarts.0 : echarts : iobrokervm - enabled + system.adapter.email.0 : email : iobrokervm - enabled + system.adapter.ems-esp.0 : ems-esp : iobrokervm - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobrokervm - enabled + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobrokervm - enabled + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: iobrokervm - enabled + system.adapter.evcc.0 : evcc : iobrokervm - enabled, port: 7070 system.adapter.flexcharts.0 : flexcharts : iobrokervm - enabled system.adapter.flot.0 : flot : iobrokervm - disabled + system.adapter.followthesun.0 : followthesun : iobrokervm - enabled + system.adapter.fritzbox.0 : fritzbox : iobrokervm - enabled + system.adapter.fritzdect.0 : fritzdect : iobrokervm - enabled + system.adapter.fullybrowser.0 : fullybrowser : iobrokervm - enabled + system.adapter.go-e.0 : go-e : iobrokervm - enabled + system.adapter.harmony.0 : harmony : iobrokervm - enabled + system.adapter.homeconnect.0 : homeconnect : iobrokervm - enabled + system.adapter.hue.0 : hue : iobrokervm - enabled, port: 80 system.adapter.ical.0 : ical : iobrokervm - enabled + system.adapter.influxdb.0 : influxdb : iobrokervm - enabled, port: 8086 + system.adapter.iot.0 : iot : iobrokervm - enabled + system.adapter.javascript.0 : javascript : iobrokervm - enabled system.adapter.klipper-moonraker.0 : klipper-moonraker : iobrokervm - disabled + system.adapter.klipper-moonraker.1 : klipper-moonraker : iobrokervm - enabled system.adapter.knx.0 : knx : iobrokervm - disabled, bind: 192.168.0.251 system.adapter.labcom.0 : labcom : iobrokervm - enabled + system.adapter.lg-thinq.0 : lg-thinq : iobrokervm - enabled system.adapter.life360.0 : life360 : iobrokervm - disabled + system.adapter.linux-control.0 : linux-control : iobrokervm - enabled + system.adapter.logparser.0 : logparser : iobrokervm - enabled system.adapter.material.0 : material : iobrokervm - disabled system.adapter.mobile.0 : mobile : iobrokervm - disabled + system.adapter.modbus.0 : modbus : iobrokervm - enabled + system.adapter.modbus.1 : modbus : iobrokervm - enabled + system.adapter.mqtt.0 : mqtt : iobrokervm - enabled, port: 1884, bind: 0.0.0.0 system.adapter.netatmo-crawler.0 : netatmo-crawler : iobrokervm - disabled + system.adapter.nina.0 : nina : iobrokervm - enabled system.adapter.node-red.0 : node-red : iobrokervm - disabled, port: 1880, bind: 0.0.0.0 system.adapter.nuki-extended.0 : nuki-extended : iobrokervm - disabled + system.adapter.nuki.0 : nuki : iobrokervm - enabled + system.adapter.nut.0 : nut : iobrokervm - enabled system.adapter.octoprint.0 : octoprint : iobrokervm - disabled + system.adapter.onvif.0 : onvif : iobrokervm - enabled, port: 80, 7575, 8000, 8080, 8081, 8899 system.adapter.openweathermap.0 : openweathermap : iobrokervm - enabled + system.adapter.ping.0 : ping : iobrokervm - enabled + system.adapter.plex.0 : plex : iobrokervm - enabled + system.adapter.proxmox.0 : proxmox : iobrokervm - enabled, port: 8006 + system.adapter.proxmox.1 : proxmox : iobrokervm - enabled, port: 8006 + system.adapter.pvforecast.0 : pvforecast : iobrokervm - enabled + system.adapter.radar-trap.0 : radar-trap : iobrokervm - enabled system.adapter.reolink.0 : reolink : iobrokervm - disabled + system.adapter.reolink.1 : reolink : iobrokervm - enabled + system.adapter.reolink.2 : reolink : iobrokervm - enabled + system.adapter.reolink.3 : reolink : iobrokervm - enabled + system.adapter.rest-api.0 : rest-api : iobrokervm - enabled, port: 8093, bind: 0.0.0.0, run as: admin + system.adapter.sainlogic.0 : sainlogic : iobrokervm - enabled, port: 45000, bind: 0.0.0.0 + system.adapter.scenes.0 : scenes : iobrokervm - enabled + system.adapter.scheduler.0 : scheduler : iobrokervm - enabled + system.adapter.shelly.0 : shelly : iobrokervm - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : iobrokervm - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : iobrokervm - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.slideshow.0 : slideshow : iobrokervm - enabled + system.adapter.slideshow.1 : slideshow : iobrokervm - enabled + system.adapter.sonoff.0 : sonoff : iobrokervm - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sonos.0 : sonos : iobrokervm - enabled + system.adapter.sourceanalytix.0 : sourceanalytix : iobrokervm - enabled + system.adapter.synology.0 : synology : iobrokervm - enabled, port: 5000 + system.adapter.telegram.0 : telegram : iobrokervm - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : iobrokervm - enabled + system.adapter.tibberlink.0 : tibberlink : iobrokervm - enabled + system.adapter.tr-064.0 : tr-064 : iobrokervm - enabled + system.adapter.trashschedule.0 : trashschedule : iobrokervm - enabled + system.adapter.tuya.0 : tuya : iobrokervm - enabled system.adapter.uv-protect.0 : uv-protect : iobrokervm - enabled system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobrokervm - enabled system.adapter.vis-2-widgets-energy.0 : vis-2-widgets-energy : iobrokervm - enabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : iobrokervm - enabled system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobrokervm - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobrokervm - enabled system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: iobrokervm - enabled + system.adapter.vis-2.0 : vis-2 : iobrokervm - enabled system.adapter.vis-bars.0 : vis-bars : iobrokervm - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobrokervm - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobrokervm - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobrokervm - disabled system.adapter.vis-history.0 : vis-history : iobrokervm - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobrokervm - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobrokervm - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobrokervm - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobrokervm - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobrokervm - enabled system.adapter.vis-metro.0 : vis-metro : iobrokervm - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobrokervm - disabled system.adapter.vis.0 : vis : iobrokervm - enabled + system.adapter.vw-connect.0 : vw-connect : iobrokervm - enabled system.adapter.weatherunderground.0 : weatherunderground : iobrokervm - enabled + system.adapter.web.0 : web : iobrokervm - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobrokervm - enabled system.adapter.worx.0 : worx : iobrokervm - disabled + system.adapter.ws.0 : ws : iobrokervm - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.xsense.0 : xsense : iobrokervm - enabled + system.adapter.zigbee.0 : zigbee : iobrokervm - enabled, port: /dev/ttyUSB0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : iobrokervm - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.evcc.0 : evcc : iobrokervm - enabled, port: 7070 + system.adapter.hue.0 : hue : iobrokervm - enabled, port: 80 + system.adapter.influxdb.0 : influxdb : iobrokervm - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : iobrokervm - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.onvif.0 : onvif : iobrokervm - enabled, port: 80, 7575, 8000, 8080, 8081, 8899 + system.adapter.proxmox.0 : proxmox : iobrokervm - enabled, port: 8006 + system.adapter.proxmox.1 : proxmox : iobrokervm - enabled, port: 8006 + system.adapter.rest-api.0 : rest-api : iobrokervm - enabled, port: 8093, bind: 0.0.0.0, run as: admin + system.adapter.sainlogic.0 : sainlogic : iobrokervm - enabled, port: 45000, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobrokervm - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : iobrokervm - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : iobrokervm - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobrokervm - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.synology.0 : synology : iobrokervm - enabled, port: 5000 + system.adapter.telegram.0 : telegram : iobrokervm - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobrokervm - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : iobrokervm - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobrokervm - enabled, port: /dev/ttyUSB0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): beta Upgrade policy: none Installed ioBroker-Adapters Used repository: beta Adapter "acme" : 1.0.6 , installed 1.0.6 Adapter "admin" : 7.7.2 , installed 7.7.2 Adapter "alexa-timer-vis": 2.1.1 , installed 2.1.1 Adapter "alexa2" : 3.27.3 , installed 3.27.3 Adapter "alias-manager": 2.0.0 , installed 2.0.0 Adapter "alpha-ess" : 3.0.1 , installed 3.0.1 Adapter "awtrix-light" : 2.0.0 , installed 2.0.0 Adapter "backitup" : 3.3.5 , installed 3.3.5 Adapter "chromecast" : 4.0.0 , installed 4.0.0 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "daswetter" : 3.2.3 , installed 3.2.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.12.1 , installed 2.12.1 Adapter "devices" : 1.2.8 , installed 1.2.8 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "doorbird" : 3.0.0 , installed 3.0.0 Adapter "drops-weather": 1.2.7 , installed 1.2.7 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 2.0.6 , installed 2.0.6 Adapter "email" : 2.0.4 , installed 2.0.4 Adapter "ems-esp" : 6.0.0 , installed 6.0.0 Adapter "energiefluss-erweitert": 0.7.8, installed 0.7.8 Adapter "evcc" : 0.2.3 , installed 0.2.3 Adapter "fahrplan" : 1.4.1 , installed 1.4.1 Adapter "flexcharts" : 0.4.1 , installed 0.4.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.5.2 , installed 0.5.2 Adapter "fritzbox" : 0.6.0 , installed 0.6.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "go-e" : 1.0.42 , installed 1.0.42 Adapter "harmony" : 1.5.0 , installed 1.5.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homeconnect" : 1.4.3 , installed 1.4.3 Adapter "hue" : 3.16.2 , installed 3.16.2 Adapter "ical" : 1.16.2 , installed 1.16.2 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 3.6.0 , installed 3.6.0 Adapter "javascript" : 9.0.10 , installed 9.0.10 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "knx" : 2.0.33 , installed 2.0.33 Adapter "lg-thinq" : 1.1.0 , installed 1.1.0 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "logparser" : 2.4.0 , installed 2.4.0 Adapter "material" : 1.3.1 , installed 1.3.1 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "modbus" : 6.4.0 , installed 6.4.0 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "mytime" : 1.4.7 , installed 1.4.7 Adapter "netatmo-crawler": 1.0.0 , installed 1.0.0 Adapter "nina" : 0.0.26 , installed 0.0.26 Adapter "node-red" : 6.0.7 , installed 6.0.7 Adapter "nuki" : 2.0.0 , installed 2.0.0 Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "octoprint" : 6.0.0 , installed 6.0.0 Adapter "onvif" : 1.1.4 , installed 1.1.4 Adapter "openknx" : 0.9.0 , installed 0.9.0 Adapter "openweathermap": 1.3.0 , installed 1.3.0 Adapter "ping" : 1.7.9 , installed 1.7.9 Adapter "plex" : 1.1.5 , installed 1.1.5 Adapter "proxmox" : 2.4.0 , installed 2.4.0 Adapter "pvforecast" : 5.0.0 , installed 5.0.0 Adapter "radar-trap" : 2.2.2 , installed 2.2.2 Adapter "reolink" : 1.2.3 , installed 1.2.3 Adapter "rest-api" : 3.0.1 , installed 3.0.1 Adapter "sainlogic" : 0.12.1 , installed 0.12.1 Adapter "scenes" : 4.0.3 , installed 4.0.3 Adapter "scheduler" : 1.5.0 , installed 1.5.0 Adapter "shelly" : 10.1.0 , installed 10.1.0 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "slideshow" : 0.2.1 , installed 0.2.1 Adapter "socketio" : 7.0.8 , installed 7.0.8 Adapter "sonoff" : 3.2.1 , installed 3.2.1 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "sourceanalytix": 0.4.14 , installed 0.4.14 Adapter "synology" : 3.1.0 , installed 3.1.0 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tibberlink" : 5.0.0 , installed 5.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "traccar" : 1.1.6 , installed 1.1.6 Adapter "trashschedule": 4.0.1 , installed 4.0.1 Adapter "tronity" : 1.2.1 , installed 1.2.1 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "uv-protect" : 0.6.7 , installed 0.6.7 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.12.12 , installed 2.12.12 Adapter "vis-2-widgets-collection": 1.8.1, installed 1.8.1 Adapter "vis-2-widgets-energy": 1.0.2, installed 1.0.2 Adapter "vis-2-widgets-gauges": 2.0.1, installed 2.0.1 Adapter "vis-2-widgets-inventwo": 0.3.3, installed 0.3.3 Adapter "vis-2-widgets-material": 1.4.10, installed 1.4.10 Adapter "vis-2-widgets-radar-trap": 2.3.3, installed 2.3.3 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.14.0 , installed 1.14.0 Adapter "vis-inventwo" : 3.3.5 , installed 3.3.5 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vw-connect" : 0.7.12 , installed 0.7.12 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 7.0.9 , installed 7.0.9 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "worx" : 3.2.6 , installed 3.2.6 Adapter "ws" : 3.0.19 , installed 3.0.19 Adapter "zigbee" : 3.0.3 , installed 3.0.3 Objects and States Please stand by - This may take a while Objects: 38762 States: 33697 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://security.debian.org/debian-security bookworm-security InRelease Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:45000 0.0.0.0:* LISTEN 1001 66959 8291/io.sainlogic.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 1851 429/sshd: /usr/sbin tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 55419 7157/io.sonoff.0 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 57359 7318/io.shelly.1 tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 59625 7488/io.mqtt.0 tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 59624 7488/io.mqtt.0 tcp 0 0 192.168.0.251:8100 0.0.0.0:* LISTEN 1001 61840 7715/io.doorbird.0 tcp 0 0 192.168.0.251:9092 0.0.0.0:* LISTEN 1001 54905 7057/io.nuki.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 51715 6716/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 51148 6716/iobroker.js-co tcp6 0 0 :::3000 :::* LISTEN 1001 52802 6967/io.fullybrowse tcp6 0 0 :::3040 :::* LISTEN 1001 72489 8659/io.radar-trap. tcp6 0 0 :::3500 :::* LISTEN 1001 55450 7182/io.sonos.0 tcp6 0 0 :::41891 :::* LISTEN 1001 138560 11597/io.plex.0 tcp6 0 0 :::22 :::* LISTEN 0 1853 429/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 67734 8233/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 54288 6737/io.admin.1 tcp6 0 0 :::8087 :::* LISTEN 1001 73269 8744/io.simple-api. tcp6 0 0 :::8084 :::* LISTEN 1001 69252 8439/io.ws.0 tcp6 0 0 :::8093 :::* LISTEN 1001 69912 8392/io.rest-api.0 tcp6 0 0 :::61991 :::* LISTEN 1001 52813 6982/io.harmony.0 udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 59195 7586/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 59196 7586/io.tuya.0 udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 52814 6982/io.harmony.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 59099 7559/io.chromecast. udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 53897 7139/io.shelly.0 *** Log File - Last 25 Lines *** 2025-07-29 17:47:54.616 - debug: lg-thinq.0 (7267) resultConverted: {"Operation":"0","OpMode":"0","WindStrength":"2","TempUnit":"NS","TempCur":"24.5","TempCfg":"25","GroupType":"1","SleepTime":"0","OnTime":"0","OffTime":"0","RacAddFunc":"NS","ExtraOp":"0","DiagCode":"00","TimeBsOn":"0","TimeBsOff":"0","AirClean":"0","AutoDry":"0","PowerSave":"0","WDirVStep":"100","WDirHStep":"3","TempLimitMax":"0","TempLimitMin":"0","DuctZoneType":"0","ZoneControl":"0","DRED":"0","SensorPM1":"0","SensorPM2":"0","SensorPM10":"0","AirPolution":"0","HumidityCfg":"0","WaterTempCoolMin":"NS","WaterTempCoolMax":"NS","WaterTempHeatMin":"NS","WaterTempHeatMax":"NS","HotWaterTempMin":"NS","HotWaterTempMax":"NS","SensorHumidity":"0","TotalAirPolution":"0","SensorMon":"0","CleanDry":"0","ProductStatus":"0","AirMonitoring":"0","Humidification":"0","AirFast":"0","AirRemoval":"0","AirUVDisinfection":"0","WatertankLight":"0","SignalLighting":"0","WDirUpDown":"0","WDirLeftRight":"0","WSwirl":"0","Jet":"0","LowHeating":"0","CirculateStrength":"0","CirculateDir":"0","AntiBugs":"0","IceValley":"0","Humsave":"0","WaterTempCur":"0","HotWaterTempCur":"0","HotWaterTempCfg":"0","HotWaterMode":"0","HotWater":"0","AWHPTempCfgSwitch":"0","AirTempCoolMin":"NS","AirTempCoolMax":"NS","AirTempHeatMin":"NS","AirTempHeatMax":"NS","WaterInTempCur":"0","AWHPWATempControlSta":"0","DisplayControl":"0","SmartCare":"0","TwoSetCoolTemp":"0","TwoSetHeatTemp":"0","TwoSetCoolUSL":"0","TwoSetCoolLSL":"0","TwoSetHeatUSL":"0","TwoSetHeatLSL":"0","TwoSetACOState":"0","TwoSetModeDeadband":"0","TwoSetState":"0"} 2025-07-29 17:47:54.617 - debug: lg-thinq.0 (7267) device: {"deviceId":"d27c0210-7149-11d3-80b1-2c2bf9842822","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27c0210-7149-11d3-80b1-2c2bf9842822"} 2025-07-29 17:47:54.617 - debug: lg-thinq.0 (7267) resultConverted: {"Operation":"0","OpMode":"0","WindStrength":"2","TempUnit":"NS","TempCur":"24","TempCfg":"25","GroupType":"1","SleepTime":"0","OnTime":"0","OffTime":"0","RacAddFunc":"NS","ExtraOp":"0","DiagCode":"00","TimeBsOn":"0","TimeBsOff":"0","AirClean":"0","AutoDry":"0","PowerSave":"0","WDirVStep":"0","WDirHStep":"3","TempLimitMax":"0","TempLimitMin":"0","DuctZoneType":"0","ZoneControl":"0","DRED":"0","SensorPM1":"0","SensorPM2":"0","SensorPM10":"0","AirPolution":"0","HumidityCfg":"0","WaterTempCoolMin":"NS","WaterTempCoolMax":"NS","WaterTempHeatMin":"NS","WaterTempHeatMax":"NS","HotWaterTempMin":"NS","HotWaterTempMax":"NS","SensorHumidity":"0","TotalAirPolution":"0","SensorMon":"0","CleanDry":"0","ProductStatus":"0","AirMonitoring":"0","Humidification":"0","AirFast":"0","AirRemoval":"0","AirUVDisinfection":"0","WatertankLight":"0","SignalLighting":"0","WDirUpDown":"0","WDirLeftRight":"0","WSwirl":"0","Jet":"0","LowHeating":"0","CirculateStrength":"0","CirculateDir":"0","AntiBugs":"0","IceValley":"0","Humsave":"0","WaterTempCur":"0","HotWaterTempCur":"0","HotWaterTempCfg":"0","HotWaterMode":"0","HotWater":"0","AWHPTempCfgSwitch":"0","AirTempCoolMin":"NS","AirTempCoolMax":"NS","AirTempHeatMin":"NS","AirTempHeatMax":"NS","WaterInTempCur":"0","AWHPWATempControlSta":"0","DisplayControl":"0","SmartCare":"0","TwoSetCoolTemp":"0","TwoSetHeatTemp":"0","TwoSetCoolUSL":"0","TwoSetCoolLSL":"0","TwoSetHeatUSL":"0","TwoSetHeatLSL":"0","TwoSetACOState":"0","TwoSetModeDeadband":"0","TwoSetState":"0"} 2025-07-29 17:47:54.621 - debug: lg-thinq.0 (7267) active: 4 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) Status ongoing: false 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) START MONITORING 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) WORKID: 4 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) MODEL: 4 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) Counter: 4 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) DEV: d27b17b0-7149-11d3-80ab-2c2bf9735b14 workid: n-d27b17b0-7149-11d3-80ab-2c2bf9735b14 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) DEV: d27b3ec0-7149-11d3-80ac-2c2bf9a278bb workid: n-d27b3ec0-7149-11d3-80ac-2c2bf9a278bb 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) DEV: d27b8ce0-7149-11d3-80ae-2c2bf960395e workid: n-d27b8ce0-7149-11d3-80ae-2c2bf960395e 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) DEV: d27c0210-7149-11d3-80b1-2c2bf9842822 workid: n-d27c0210-7149-11d3-80b1-2c2bf9842822 2025-07-29 17:48:04.473 - debug: lg-thinq.0 (7267) HEADER: {"User-Agent":"LG ThinQ/5.0.11861 (iPhone; iOS 16.7.2; Scale/3.00)","x-model-name":"iPhone 9 Plus","x-thinq-app-ver":"5.0.1000","x-thinq-app-type":"NUTS","x-language-code":"en-DE","x-thinq-app-logintype":"LGE","x-os-version":"16.7.2","x-client-id":"52d000221eb8734a9223048600802e1de70a0964040331ec40ede99e0b198c5e","x-thinq-app-level":"PRD","x-app-version":"5.0.11861","x-user-no":"DE2201265334391","Connection":"keep-alive","x-service-code":"SVC202","Accept-Language":"en-DE;q=1","x-message-id":"05879ff1-3c5d-4f9c-809d-091ba6beb7f4","x-emp-token":"96cd0a4b3ea175e8bf48303ec9a6d5f95a6b3cbbac5751b356c90a60f8482f6d2ee891c9577bce04a03729126533a0cc","x-origin":"app-native","Accept":"application/json","Content-Type":"application/json;charset=UTF-8","x-api-key":"VGhpblEyLjAgU0VSVklDRQ==","x-thinq-app-os":"IOS","x-country-code":"DE","x-service-phase":"OP","x-thinq-jsessionId":"2CB638654991DC44ECBE52950FEC72BF.nodes_sadap_08"} 2025-07-29 17:48:04.608 - debug: lg-thinq.0 (7267) RESULTS: {"returnCd":"0000","returnMsg":"OK","workList":[{"deviceId":"d27b17b0-7149-11d3-80ab-2c2bf9735b14","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27b17b0-7149-11d3-80ab-2c2bf9735b14"},{"deviceId":"d27b3ec0-7149-11d3-80ac-2c2bf9a278bb","deviceState":"E","format":"B64","returnCode":"0000","returnData":"eyJPcGVyYXRpb24iOiIwIiwiT3BNb2RlIjoiMCIsIldpbmRTdHJlbmd0aCI6IjQiLCJUZW1wVW5pdCI6Ik5TIiwiVGVtcEN1ciI6IjI1IiwiVGVtcENmZyI6IjI0IiwiR3JvdXBUeXBlIjoiMSIsIlNsZWVwVGltZSI6IjAiLCJPblRpbWUiOiIwIiwiT2ZmVGltZSI6IjAiLCJSYWNBZGRGdW5jIjoiTlMiLCJFeHRyYU9wIjoiMCIsIkRpYWdDb2RlIjoiMDAiLCJUaW1lQnNPbiI6IjAiLCJUaW1lQnNPZmYiOiIwIiwiQWlyQ2xlYW4iOiIwIiwiQXV0b0RyeSI6IjAiLCJQb3dlclNhdmUiOiIwIiwiV0RpclZTdGVwIjoiMSIsIldEaXJIU3RlcCI6IjAiLCJUZW1wTGltaXRNYXgiOiIwIiwiVGVtcExpbWl0TWluIjoiMCIsIkR1Y3Rab25lVHlwZSI6IjAiLCJab25lQ29udHJvbCI6IjAiLCJEUkVEIjoiMCIsIlNlbnNvclBNMSI6IjAiLCJTZW5zb3JQTTIiOiIwIiwiU2Vuc29yUE0xMCI6IjAiLCJBaXJQb2x1dGlvbiI6IjAiLCJIdW1pZGl0eUNmZyI6IjAiLCJXYXRlclRlbXBDb29sTWluIjoiTlMiLCJXYXRlclRlbXBDb29sTWF4IjoiTlMiLCJXYXRlclRlbXBIZWF0TWluIjoiTlMiLCJXYXRlclRlbXBIZWF0TWF4IjoiTlMiLCJIb3RXYXRlclRlbXBNaW4iOiJOUyIsIkhvdFdhdGVyVGVtcE1heCI6Ik5TIiwiU2Vuc29ySHVtaWRpdHkiOiIwIiwiVG90YWxBaXJQb2x1dGlvbiI6IjAiLCJTZW5zb3JNb24iOiIwIiwiQ2xlYW5EcnkiOiIwIiwiUHJvZHVjdFN0YXR1cyI6IjAiLCJBaXJNb25pdG9yaW5nIjoiMCIsIkh1bWlkaWZpY2F0aW9uIjoiMCIsIkFpckZhc3QiOiIwIiwiQWlyUmVtb3ZhbCI6IjAiLCJBaXJVVkRpc2luZmVjdGlvbiI6IjAiLCJXYXRlcnRhbmtMaWdodCI6IjAiLCJTaWduYWxMaWdodGluZyI6IjAiLCJXRGlyVXBEb3duIjoiMCIsIldEaXJMZWZ0UmlnaHQiOiIwIiwiV1N3aXJsIjoiMCIsIkpldCI6IjAiLCJMb3dIZWF0aW5nIjoiMCIsIkNpcmN1bGF0ZVN0cmVuZ3RoIjoiMCIsIkNpcmN1bGF0ZURpciI6IjAiLCJBbnRpQnVncyI6IjAiLCJJY2VWYWxsZXkiOiIwIiwiSHVtc2F2ZSI6IjAiLCJXYXRlclRlbXBDdXIiOiIwIiwiSG90V2F0ZXJUZW1wQ3VyIjoiMCIsIkhvdFdhdGVyVGVtcENmZyI6IjAiLCJIb3RXYXRlck1vZGUiOiIwIiwiSG90V2F0ZXIiOiIwIiwiQVdIUFRlbXBDZmdTd2l0Y2giOiIwIiwiQWlyVGVtcENvb2xNaW4iOiJOUyIsIkFpclRlbXBDb29sTWF4IjoiTlMiLCJBaXJUZW1wSGVhdE1pbiI6Ik5TIiwiQWlyVGVtcEhlYXRNYXgiOiJOUyIsIldhdGVySW5UZW1wQ3VyIjoiMCIsIkFXSFBXQVRlbXBDb250cm9sU3RhIjoiMCIsIkRpc3BsYXlDb250cm9sIjoiMCIsIlNtYXJ0Q2FyZSI6IjAiLCJUd29TZXRDb29sVGVtcCI6IjAiLCJUd29TZXRIZWF0VGVtcCI6IjAiLCJUd29TZXRDb29sVVNMIjoiMCIsIlR3b1NldENvb2xMU0wiOiIwIiwiVHdvU2V0SGVhdFVTTCI6IjAiLCJUd29TZXRIZWF0TFNMIjoiMCIsIlR3b1NldEFDT1N0YXRlIjoiMCIsIlR3b1NldE1vZGVEZWFkYmFuZCI6IjAiLCJUd29TZXRTdGF0ZSI6IjAifQ==","stateCode":"S","workId":"n-d27b3ec0-7149-11d3-80ac-2c2bf9a278bb"},{"deviceId":"d27b8ce0-7149-11d3-80ae-2c2bf960395e","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27b8ce0-7149-11d3-80ae-2c2bf960395e"},{"deviceId":"d27c0210-7149-11d3-80b1-2c2bf9842822","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27c0210-7149-11d3-80b1-2c2bf9842822"}]} 2025-07-29 17:48:04.608 - debug: lg-thinq.0 (7267) device_array: [{"deviceId":"d27b17b0-7149-11d3-80ab-2c2bf9735b14","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27b17b0-7149-11d3-80ab-2c2bf9735b14"},{"deviceId":"d27b3ec0-7149-11d3-80ac-2c2bf9a278bb","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27b3ec0-7149-11d3-80ac-2c2bf9a278bb"},{"deviceId":"d27b8ce0-7149-11d3-80ae-2c2bf960395e","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27b8ce0-7149-11d3-80ae-2c2bf960395e"},{"deviceId":"d27c0210-7149-11d3-80b1-2c2bf9842822","deviceState":"E","format":"B64","returnCode":"0000","returnData":"eyJPcGVyYXRpb24iOiIwIiwiT3BNb2RlIjoiMCIsIldpbmRTdHJlbmd0aCI6IjIiLCJUZW1wVW5pdCI6Ik5TIiwiVGVtcEN1ciI6IjI0IiwiVGVtcENmZyI6IjI1IiwiR3JvdXBUeXBlIjoiMSIsIlNsZWVwVGltZSI6IjAiLCJPblRpbWUiOiIwIiwiT2ZmVGltZSI6IjAiLCJSYWNBZGRGdW5jIjoiTlMiLCJFeHRyYU9wIjoiMCIsIkRpYWdDb2RlIjoiMDAiLCJUaW1lQnNPbiI6IjAiLCJUaW1lQnNPZmYiOiIwIiwiQWlyQ2xlYW4iOiIwIiwiQXV0b0RyeSI6IjAiLCJQb3dlclNhdmUiOiIwIiwiV0RpclZTdGVwIjoiMCIsIldEaXJIU3RlcCI6IjMiLCJUZW1wTGltaXRNYXgiOiIwIiwiVGVtcExpbWl0TWluIjoiMCIsIkR1Y3Rab25lVHlwZSI6IjAiLCJab25lQ29udHJvbCI6IjAiLCJEUkVEIjoiMCIsIlNlbnNvclBNMSI6IjAiLCJTZW5zb3JQTTIiOiIwIiwiU2Vuc29yUE0xMCI6IjAiLCJBaXJQb2x1dGlvbiI6IjAiLCJIdW1pZGl0eUNmZyI6IjAiLCJXYXRlclRlbXBDb29sTWluIjoiTlMiLCJXYXRlclRlbXBDb29sTWF4IjoiTlMiLCJXYXRlclRlbXBIZWF0TWluIjoiTlMiLCJXYXRlclRlbXBIZWF0TWF4IjoiTlMiLCJIb3RXYXRlclRlbXBNaW4iOiJOUyIsIkhvdFdhdGVyVGVtcE1heCI6Ik5TIiwiU2Vuc29ySHVtaWRpdHkiOiIwIiwiVG90YWxBaXJQb2x1dGlvbiI6IjAiLCJTZW5zb3JNb24iOiIwIiwiQ2xlYW5EcnkiOiIwIiwiUHJvZHVjdFN0YXR1cyI6IjAiLCJBaXJNb25pdG9yaW5nIjoiMCIsIkh1bWlkaWZpY2F0aW9uIjoiMCIsIkFpckZhc3QiOiIwIiwiQWlyUmVtb3ZhbCI6IjAiLCJBaXJVVkRpc2luZmVjdGlvbiI6IjAiLCJXYXRlcnRhbmtMaWdodCI6IjAiLCJTaWduYWxMaWdodGluZyI6IjAiLCJXRGlyVXBEb3duIjoiMCIsIldEaXJMZWZ0UmlnaHQiOiIwIiwiV1N3aXJsIjoiMCIsIkpldCI6IjAiLCJMb3dIZWF0aW5nIjoiMCIsIkNpcmN1bGF0ZVN0cmVuZ3RoIjoiMCIsIkNpcmN1bGF0ZURpciI6IjAiLCJBbnRpQnVncyI6IjAiLCJJY2VWYWxsZXkiOiIwIiwiSHVtc2F2ZSI6IjAiLCJXYXRlclRlbXBDdXIiOiIwIiwiSG90V2F0ZXJUZW1wQ3VyIjoiMCIsIkhvdFdhdGVyVGVtcENmZyI6IjAiLCJIb3RXYXRlck1vZGUiOiIwIiwiSG90V2F0ZXIiOiIwIiwiQVdIUFRlbXBDZmdTd2l0Y2giOiIwIiwiQWlyVGVtcENvb2xNaW4iOiJOUyIsIkFpclRlbXBDb29sTWF4IjoiTlMiLCJBaXJUZW1wSGVhdE1pbiI6Ik5TIiwiQWlyVGVtcEhlYXRNYXgiOiJOUyIsIldhdGVySW5UZW1wQ3VyIjoiMCIsIkFXSFBXQVRlbXBDb250cm9sU3RhIjoiMCIsIkRpc3BsYXlDb250cm9sIjoiMCIsIlNtYXJ0Q2FyZSI6IjAiLCJUd29TZXRDb29sVGVtcCI6IjAiLCJUd29TZXRIZWF0VGVtcCI6IjAiLCJUd29TZXRDb29sVVNMIjoiMCIsIlR3b1NldENvb2xMU0wiOiIwIiwiVHdvU2V0SGVhdFVTTCI6IjAiLCJUd29TZXRIZWF0TFNMIjoiMCIsIlR3b1NldEFDT1N0YXRlIjoiMCIsIlR3b1NldE1vZGVEZWFkYmFuZCI6IjAiLCJUd29TZXRTdGF0ZSI6IjAifQ==","stateCode":"S","workId":"n-d27c0210-7149-11d3-80b1-2c2bf9842822"}] 2025-07-29 17:48:04.608 - debug: lg-thinq.0 (7267) device: {"deviceId":"d27b17b0-7149-11d3-80ab-2c2bf9735b14","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27b17b0-7149-11d3-80ab-2c2bf9735b14"} 2025-07-29 17:48:04.609 - debug: lg-thinq.0 (7267) resultConverted: {"Operation":"0","OpMode":"0","WindStrength":"2","TempUnit":"NS","TempCur":"24","TempCfg":"25","GroupType":"1","SleepTime":"0","OnTime":"0","OffTime":"0","RacAddFunc":"NS","ExtraOp":"0","DiagCode":"00","TimeBsOn":"0","TimeBsOff":"0","AirClean":"0","AutoDry":"0","PowerSave":"0","WDirVStep":"1","WDirHStep":"100","TempLimitMax":"0","TempLimitMin":"0","DuctZoneType":"0","ZoneControl":"0","DRED":"0","SensorPM1":"0","SensorPM2":"0","SensorPM10":"0","AirPolution":"0","HumidityCfg":"0","WaterTempCoolMin":"NS","WaterTempCoolMax":"NS","WaterTempHeatMin":"NS","WaterTempHeatMax":"NS","HotWaterTempMin":"NS","HotWaterTempMax":"NS","SensorHumidity":"0","TotalAirPolution":"0","SensorMon":"0","CleanDry":"0","ProductStatus":"0","AirMonitoring":"0","Humidification":"0","AirFast":"0","AirRemoval":"0","AirUVDisinfection":"0","WatertankLight":"0","SignalLighting":"0","WDirUpDown":"0","WDirLeftRight":"0","WSwirl":"0","Jet":"0","LowHeating":"0","CirculateStrength":"0","CirculateDir":"0","AntiBugs":"0","IceValley":"0","Humsave":"0","WaterTempCur":"0","HotWaterTempCur":"0","HotWaterTempCfg":"0","HotWaterMode":"0","HotWater":"0","AWHPTempCfgSwitch":"0","AirTempCoolMin":"NS","AirTempCoolMax":"NS","AirTempHeatMin":"NS","AirTempHeatMax":"NS","WaterInTempCur":"0","AWHPWATempControlSta":"0","DisplayControl":"0","SmartCare":"0","TwoSetCoolTemp":"0","TwoSetHeatTemp":"0","TwoSetCoolUSL":"0","TwoSetCoolLSL":"0","TwoSetHeatUSL":"0","TwoSetHeatLSL":"0","TwoSetACOState":"0","TwoSetModeDeadband":"0","TwoSetState":"0"} 2025-07-29 17:48:04.610 - debug: lg-thinq.0 (7267) device: {"deviceId":"d27b3ec0-7149-11d3-80ac-2c2bf9a278bb","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27b3ec0-7149-11d3-80ac-2c2bf9a278bb"} 2025-07-29 17:48:04.610 - debug: lg-thinq.0 (7267) resultConverted: {"Operation":"0","OpMode":"0","WindStrength":"4","TempUnit":"NS","TempCur":"25","TempCfg":"24","GroupType":"1","SleepTime":"0","OnTime":"0","OffTime":"0","RacAddFunc":"NS","ExtraOp":"0","DiagCode":"00","TimeBsOn":"0","TimeBsOff":"0","AirClean":"0","AutoDry":"0","PowerSave":"0","WDirVStep":"1","WDirHStep":"0","TempLimitMax":"0","TempLimitMin":"0","DuctZoneType":"0","ZoneControl":"0","DRED":"0","SensorPM1":"0","SensorPM2":"0","SensorPM10":"0","AirPolution":"0","HumidityCfg":"0","WaterTempCoolMin":"NS","WaterTempCoolMax":"NS","WaterTempHeatMin":"NS","WaterTempHeatMax":"NS","HotWaterTempMin":"NS","HotWaterTempMax":"NS","SensorHumidity":"0","TotalAirPolution":"0","SensorMon":"0","CleanDry":"0","ProductStatus":"0","AirMonitoring":"0","Humidification":"0","AirFast":"0","AirRemoval":"0","AirUVDisinfection":"0","WatertankLight":"0","SignalLighting":"0","WDirUpDown":"0","WDirLeftRight":"0","WSwirl":"0","Jet":"0","LowHeating":"0","CirculateStrength":"0","CirculateDir":"0","AntiBugs":"0","IceValley":"0","Humsave":"0","WaterTempCur":"0","HotWaterTempCur":"0","HotWaterTempCfg":"0","HotWaterMode":"0","HotWater":"0","AWHPTempCfgSwitch":"0","AirTempCoolMin":"NS","AirTempCoolMax":"NS","AirTempHeatMin":"NS","AirTempHeatMax":"NS","WaterInTempCur":"0","AWHPWATempControlSta":"0","DisplayControl":"0","SmartCare":"0","TwoSetCoolTemp":"0","TwoSetHeatTemp":"0","TwoSetCoolUSL":"0","TwoSetCoolLSL":"0","TwoSetHeatUSL":"0","TwoSetHeatLSL":"0","TwoSetACOState":"0","TwoSetModeDeadband":"0","TwoSetState":"0"} 2025-07-29 17:48:04.612 - debug: lg-thinq.0 (7267) device: {"deviceId":"d27b8ce0-7149-11d3-80ae-2c2bf960395e","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27b8ce0-7149-11d3-80ae-2c2bf960395e"} 2025-07-29 17:48:04.612 - debug: lg-thinq.0 (7267) resultConverted: {"Operation":"0","OpMode":"0","WindStrength":"2","TempUnit":"NS","TempCur":"24.5","TempCfg":"25","GroupType":"1","SleepTime":"0","OnTime":"0","OffTime":"0","RacAddFunc":"NS","ExtraOp":"0","DiagCode":"00","TimeBsOn":"0","TimeBsOff":"0","AirClean":"0","AutoDry":"0","PowerSave":"0","WDirVStep":"100","WDirHStep":"3","TempLimitMax":"0","TempLimitMin":"0","DuctZoneType":"0","ZoneControl":"0","DRED":"0","SensorPM1":"0","SensorPM2":"0","SensorPM10":"0","AirPolution":"0","HumidityCfg":"0","WaterTempCoolMin":"NS","WaterTempCoolMax":"NS","WaterTempHeatMin":"NS","WaterTempHeatMax":"NS","HotWaterTempMin":"NS","HotWaterTempMax":"NS","SensorHumidity":"0","TotalAirPolution":"0","SensorMon":"0","CleanDry":"0","ProductStatus":"0","AirMonitoring":"0","Humidification":"0","AirFast":"0","AirRemoval":"0","AirUVDisinfection":"0","WatertankLight":"0","SignalLighting":"0","WDirUpDown":"0","WDirLeftRight":"0","WSwirl":"0","Jet":"0","LowHeating":"0","CirculateStrength":"0","CirculateDir":"0","AntiBugs":"0","IceValley":"0","Humsave":"0","WaterTempCur":"0","HotWaterTempCur":"0","HotWaterTempCfg":"0","HotWaterMode":"0","HotWater":"0","AWHPTempCfgSwitch":"0","AirTempCoolMin":"NS","AirTempCoolMax":"NS","AirTempHeatMin":"NS","AirTempHeatMax":"NS","WaterInTempCur":"0","AWHPWATempControlSta":"0","DisplayControl":"0","SmartCare":"0","TwoSetCoolTemp":"0","TwoSetHeatTemp":"0","TwoSetCoolUSL":"0","TwoSetCoolLSL":"0","TwoSetHeatUSL":"0","TwoSetHeatLSL":"0","TwoSetACOState":"0","TwoSetModeDeadband":"0","TwoSetState":"0"} 2025-07-29 17:48:04.613 - debug: lg-thinq.0 (7267) device: {"deviceId":"d27c0210-7149-11d3-80b1-2c2bf9842822","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27c0210-7149-11d3-80b1-2c2bf9842822"} 2025-07-29 17:48:04.613 - debug: lg-thinq.0 (7267) resultConverted: {"Operation":"0","OpMode":"0","WindStrength":"2","TempUnit":"NS","TempCur":"24","TempCfg":"25","GroupType":"1","SleepTime":"0","OnTime":"0","OffTime":"0","RacAddFunc":"NS","ExtraOp":"0","DiagCode":"00","TimeBsOn":"0","TimeBsOff":"0","AirClean":"0","AutoDry":"0","PowerSave":"0","WDirVStep":"0","WDirHStep":"3","TempLimitMax":"0","TempLimitMin":"0","DuctZoneType":"0","ZoneControl":"0","DRED":"0","SensorPM1":"0","SensorPM2":"0","SensorPM10":"0","AirPolution":"0","HumidityCfg":"0","WaterTempCoolMin":"NS","WaterTempCoolMax":"NS","WaterTempHeatMin":"NS","WaterTempHeatMax":"NS","HotWaterTempMin":"NS","HotWaterTempMax":"NS","SensorHumidity":"0","TotalAirPolution":"0","SensorMon":"0","CleanDry":"0","ProductStatus":"0","AirMonitoring":"0","Humidification":"0","AirFast":"0","AirRemoval":"0","AirUVDisinfection":"0","WatertankLight":"0","SignalLighting":"0","WDirUpDown":"0","WDirLeftRight":"0","WSwirl":"0","Jet":"0","LowHeating":"0","CirculateStrength":"0","CirculateDir":"0","AntiBugs":"0","IceValley":"0","Humsave":"0","WaterTempCur":"0","HotWaterTempCur":"0","HotWaterTempCfg":"0","HotWaterMode":"0","HotWater":"0","AWHPTempCfgSwitch":"0","AirTempCoolMin":"NS","AirTempCoolMax":"NS","AirTempHeatMin":"NS","AirTempHeatMax":"NS","WaterInTempCur":"0","AWHPWATempControlSta":"0","DisplayControl":"0","SmartCare":"0","TwoSetCoolTemp":"0","TwoSetHeatTemp":"0","TwoSetCoolUSL":"0","TwoSetCoolLSL":"0","TwoSetHeatUSL":"0","TwoSetHeatLSL":"0","TwoSetACOState":"0","TwoSetModeDeadband":"0","TwoSetState":"0"} 2025-07-29 17:48:04.614 - debug: lg-thinq.0 (7267) active: 4
iob diag has finished.
@merlin123 machmal
whereis python3
oliver@iobrokervm:~$ whereis python3 python3: /usr/bin/python3 /usr/lib/python3 /etc/python3 /usr/share/python3 /usr/share/man/man1/python3.1.gz
@thomas-braun Hab es oben nochmal reinkopiert. Da hat er nen Teil nicht genommen. Sorry...
@merlin123 das ist das problem
rm /usr/share/man/man1/python3.1.gz
und und schauen ob dann läuft wenn nicht
sudo whereis python3
nicht das da noch was dümpelt
und
für
whereis python
oliver@iobrokervm:~$ rm /usr/share/man/man1/python3.1.gz rm: das Entfernen von '/usr/share/man/man1/python3.1.gz' ist nicht möglich: Keine Berechtigung oliver@iobrokervm:~$ sudo rm /usr/share/man/man1/python3.1.gz oliver@iobrokervm:~$ sudo whereis python3 python3: /usr/bin/python3 /usr/lib/python3 /etc/python3 /usr/share/python3 oliver@iobrokervm:~$ whereis python python: oliver@iobrokervm:~$
Adapter meldet immer noch Error on create No checksum URL for Python 3.11.13 found.
@merlin123 sagte in X-Sense Adapter:
3.11.13
ja die ist ja auch nicht freigegeben
https://peps.python.org/pep-0664/#source-only-security-fix-releases
es war nur ein security fix im source deployment
3.11.1: Tuesday, 2022-12-06
3.11.2: Wednesday, 2023-02-08
3.11.3: Wednesday, 2023-04-05
3.11.4: Tuesday, 2023-06-06
3.11.5: Thursday, 2023-08-24
3.11.6: Monday, 2023-10-02
3.11.7: Monday, 2023-12-04
3.11.8: Tuesday, 2024-02-06
3.11.9: Tuesday, 2024-04-02hier such dir was aus und installier es .. davor musst du aber die jetzige weg bekommen
also
ja python ist schon kacke.. ich weiss.. es gibt aber zur zeit keine andere möglichkeit.
@arteck Die ist ja auch nicht installiert:
oliver@iobrokervm:~$ python3 --version Python 3.11.2
Ich räum aber nochmal auf.....
zum test kannst du
python3 /opt/iobroker/node_modules/iobroker.xsense/python/run_xsense.py 'meine@email.de' 'hier_kommt_mein_password123'
aufrufen
der sollte dir auf der konsole daten schmeisse
bevor das das nicht sauber funktioniert läuft der adapter nicht -
Wie die 2er Version mal auf das System gekommen ist weiß ich nicht. Läuft ja schon ne zeitlang.
Ansonsten hab ich wie von Arteck auf Github geschrieben so installiert:sudo apt install python3 python3-pip -y
oliver@iobrokervm:~$ update-alternatives --config python update-alternatives: Fehler: keine Alternativen für python
das ist schon mal gut
@arteck da kommt
[1] 21050 -bash: p5a55: Kommando nicht gefunden. oliver@iobrokervm:~$ XSense-Modul nicht gefunden. Installiere lokal mit pip... /usr/bin/python3: No module named pip {"error": "Installation fehlgeschlagen: Command '['/usr/bin/python3', '-m', 'pip', 'install', '-e', '/opt/iobroker/node_modules/iobroker.xsense/python/python-xsense']' returned non-zero exit status 1."}
Hab jetzt nochmal ein
sudo apt install --reinstall python3-pip
gemacht.
Jetzt kommt
oliver@iobrokervm:~$ python3 /opt/iobroker/node_modules/iobroker.xsense/python/run_xsense.py xxx@gmail.com password [1] 22823 -bash: p5a55: Kommando nicht gefunden. oliver@iobrokervm:~$ XSense-Modul nicht gefunden. Installiere lokal mit pip... error: externally-managed-environment × This environment is externally managed ╰─> To install Python packages system-wide, try apt install python3-xyz, where xyz is the package you are trying to install. If you wish to install a non-Debian-packaged Python package, create a virtual environment using python3 -m venv path/to/venv. Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make sure you have python3-full installed. If you wish to install a non-Debian packaged Python application, it may be easiest to use pipx install xyz, which will manage a virtual environment for you. Make sure you have pipx installed. See /usr/share/doc/python3.11/README.venv for more information. note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages. hint: See PEP 668 for the detailed specification. {"error": "Installation fehlgeschlagen: Command '['/usr/bin/python3', '-m', 'pip', 'install', '-e', '/opt/iobroker/node_modules/iobroker.xsense/python/python-xsense']' returned non-zero exit status 1."} ^C [1]+ Exit 1 python3 /opt/iobroker/node_modules/iobroker.xsense/python/run_xsense.py xxx@gmail.com password
Der Adapter meldet immer noch die blöde 3.11.13 Version
NACHTRAG:
Etwas besser jetzt:
root@iobrokervm:/usr/lib/python3.11# ls -l E* -rw-r--r-- 1 root root 645 28. Apr 16:11 EXTERNALLY-MANAGED root@iobrokervm:/usr/lib/python3.11# mv EXTERNALLY-MANAGED EXTERNALLY-MANAGED.old root@iobrokervm:/usr/lib/python3.11# exit Abgemeldet oliver@iobrokervm:~$ python3 /opt/iobroker/node_modules/iobroker.xsense/python/run_xsense.py horgul123@gmail.com a6LSATYa8H8uY^&p5a55 [1] 27666 -bash: p5a55: Kommando nicht gefunden. oliver@iobrokervm:~$ XSense-Modul nicht gefunden. Installiere lokal mit pip... Defaulting to user installation because normal site-packages is not writeable Obtaining file:///opt/iobroker/node_modules/iobroker.xsense/python/python-xsense Installing build dependencies ... done Checking if build backend supports build_editable ... done Getting requirements to build editable ... done Preparing editable metadata (pyproject.toml) ... done Collecting requests Downloading requests-2.32.4-py3-none-any.whl (64 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 64.8/64.8 kB 3.7 MB/s eta 0:00:00 Collecting boto3 Downloading boto3-1.39.15-py3-none-any.whl (139 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 139.9/139.9 kB 10.0 MB/s eta 0:00:00 Collecting botocore Downloading botocore-1.39.15-py3-none-any.whl (13.9 MB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 13.9/13.9 MB 34.0 MB/s eta 0:00:00 Collecting pycognito Downloading pycognito-2024.5.1-py3-none-any.whl (26 kB) Collecting paho-mqtt Downloading paho_mqtt-2.1.0-py3-none-any.whl (67 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 67.2/67.2 kB 8.9 MB/s eta 0:00:00 Collecting jmespath<2.0.0,>=0.7.1 Downloading jmespath-1.0.1-py3-none-any.whl (20 kB) Collecting s3transfer<0.14.0,>=0.13.0 Downloading s3transfer-0.13.1-py3-none-any.whl (85 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 85.3/85.3 kB 11.6 MB/s eta 0:00:00 Collecting python-dateutil<3.0.0,>=2.1 Downloading python_dateutil-2.9.0.post0-py2.py3-none-any.whl (229 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 229.9/229.9 kB 21.2 MB/s eta 0:00:00 Collecting urllib3!=2.2.0,<3,>=1.25.4 Downloading urllib3-2.5.0-py3-none-any.whl (129 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 129.8/129.8 kB 17.6 MB/s eta 0:00:00 Collecting envs>=1.3 Downloading envs-1.4-py3-none-any.whl (10 kB) Collecting pyjwt[crypto]>=2.8.0 Downloading PyJWT-2.10.1-py3-none-any.whl (22 kB) Collecting charset_normalizer<4,>=2 Downloading charset_normalizer-3.4.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (147 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 147.3/147.3 kB 13.3 MB/s eta 0:00:00 Collecting idna<4,>=2.5 Downloading idna-3.10-py3-none-any.whl (70 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 70.4/70.4 kB 11.3 MB/s eta 0:00:00 Collecting certifi>=2017.4.17 Downloading certifi-2025.7.14-py3-none-any.whl (162 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 162.7/162.7 kB 18.7 MB/s eta 0:00:00 Collecting cryptography>=3.4.0 Downloading cryptography-45.0.5-cp311-abi3-manylinux_2_34_x86_64.whl (4.5 MB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.5/4.5 MB 36.3 MB/s eta 0:00:00 Collecting six>=1.5 Downloading six-1.17.0-py2.py3-none-any.whl (11 kB) Collecting cffi>=1.14 Downloading cffi-1.17.1-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (467 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 467.2/467.2 kB 32.1 MB/s eta 0:00:00 Collecting pycparser Downloading pycparser-2.22-py3-none-any.whl (117 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 117.6/117.6 kB 16.5 MB/s eta 0:00:00 Building wheels for collected packages: python-xsense Building editable for python-xsense (pyproject.toml) ... done Created wheel for python-xsense: filename=python_xsense-0.0.13-0.editable-py3-none-any.whl size=3490 sha256=295c28423e230379d2b6002418a68c9cda7b6145c2eb0c9c29cc1a524ec6e8b8 Stored in directory: /tmp/pip-ephem-wheel-cache-nivw94lb/wheels/bc/55/e1/e55c713f1c3d89b9fcc3d33bf9fdb7a0c98736f263516d3c63 Successfully built python-xsense Installing collected packages: urllib3, six, pyjwt, pycparser, paho-mqtt, jmespath, idna, envs, charset_normalizer, certifi, requests, python-dateutil, cffi, cryptography, botocore, s3transfer, boto3, pycognito, python-xsense WARNING: The script envs is installed in '/home/oliver/.local/bin' which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. WARNING: The script normalizer is installed in '/home/oliver/.local/bin' which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. Successfully installed boto3-1.39.15 botocore-1.39.15 certifi-2025.7.14 cffi-1.17.1 charset_normalizer-3.4.2 cryptography-45.0.5 envs-1.4 idna-3.10 jmespath-1.0.1 paho-mqtt-2.1.0 pycognito-2024.5.1 pycparser-2.22 pyjwt-2.10.1 python-dateutil-2.9.0.post0 python-xsense-0.0.13 requests-2.32.4 s3transfer-0.13.1 six-1.17.0 urllib3-2.5.0 {"error": "Installation fehlgeschlagen: No module named 'xsense'"}
Der Adapter denkt aber immer noch, es sei eine 3.11.13 installiert.... Wie liest der die Version aus?
rm -Rf /home/iobroker/.cache/autopy/venv/xsense-env
da der sich was gezogen hat was nicht sein sollte
danach sollte der Adapter starten
ansonsten wenn nicht schau in die
nano /home/iobroker/.cache/autopy/venv/xsense-env/pyvenv.cfg
da ist die virituelle umgebung drin definiert..da kannst du die versionen Kontrollieren.. lauf der Datei wird die python Version gezogen
hab jetzt nochmal versucht, alles von vorne zu machen:
Python3 komplett deinstalliert
alle Verzeichnisse, die irgendwie python3 hießen gelöscht
alles sonstigen Überreste von python3 gelöscht (zumindest ChatGPT war der Meinung, dass danach nix mehr da ist).
Dann Python3 und pip3 neu installiert.
debian meldet auch Versionoliver@iobrokervm:~$ which python3 /usr/bin/python3 oliver@iobrokervm:~$ python3 --version Python 3.11.2 oliver@iobrokervm:~$ pip3 --version pip 23.0.1 from /usr/lib/python3/dist-packages/pip (python 3.11)
Die pyvenc.cfg gibt es aber nicht (gab es auch vorher nicht)
oliver@iobrokervm:~$ sudo more /home/iobroker/.cache/autopy/venv/xsense-env/pyvenv.cfg more: cannot open /home/iobroker/.cache/autopy/venv/xsense-env/pyvenv.cfg: Datei oder Verzeichnis nicht gefunden
Der Adapter meint noch immer, 3.11.13 sei installiert
vielleicht auch wichtig:
oliver@iobrokervm:~$ sudo ls -l /home/iobroker/.cache/autopy/venv insgesamt 4 drwxr-xr-x 2 iobroker iobroker 4096 30. Jul 08:27 xsense-env oliver@iobrokervm:~$ cd /home/iobroker/.cache/autopy/venv/ oliver@iobrokervm:/home/iobroker/.cache/autopy/venv$ ls -l insgesamt 4 drwxr-xr-x 2 iobroker iobroker 4096 30. Jul 08:27 xsense-env oliver@iobrokervm:/home/iobroker/.cache/autopy/venv$ cd xsense-env/ oliver@iobrokervm:/home/iobroker/.cache/autopy/venv/xsense-env$ ls -l insgesamt 0
wurde also alles neu angelegt, hatte das xsense-env vor der Neuinstallation des Adapters gelöscht
Gewöhn dir ab vor jeden Befehrl sudo zu klatschen. Du verfummelst dir da komplett die Rechte.
Das kannste alles nicht mehr nachvollziehen. Deswegen hatte ich mich eigentlich auch aus dem Thread auch schon verabschiedet. -
@thomas-braun ich wollte nur sicher gehen, dass ich das auf jeden Fall sehe, auch wenn mein User keine Rechte dafür hätte. Ich habe sudo nur bei 2 Befehlen benutzt....
Alles unnötig und daraus kannst du auch keine verwertbaren Aussagen zu deinem verwurschtelten System ableiten:
sudo python --version sudo python3 --version root@iobrokervm sudo more /home/iobroker/.cache/autopy/venv/xsense-env/pyvenv.cfg sudo ls -l /home/iobroker/.cache/autopy/venv
Wer weiß was da in der Vergangenheit schon mit falschen Rechten verfummelt wurde.
