    3. Einsteigerfragen
    4. [GELÖST]Node.js update will nicht wie es soll
      Gerhardptl @Thomas Braun last edited by
      iob stop
      iob fix
      iob start
      das hatte ich bereits erledigt. Trotzdem - iob diag macht folgende Meldung:
        Thomas Braun Most Active @Gerhardptl last edited by
        @gerhardptl
        Und bitte keine Bildchen von Text.
        G 2 Replies Last reply Reply Quote 0
          Alles zurück - jetzt hat es funktioniert
            so sieht es jetzt aus
            ========== Start marking the full check here ===========
            Script v.2025-03-08
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 12 (bookworm)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
            OS is similar to: debian
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 32 bit
            Systemuptime and Load:
             14:13:29 up 33 min,  2 users,  load average: 0.50, 1.19, 1.44
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Thu 2025-07-31 14:13:29 CEST
                       Universal time: Thu 2025-07-31 12:13:29 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            8.2G        1.1G        6.3G        1.2M        906M        7.1G
            Swap:           104M          0B        104M
            Total:          8.3G        1.1G        6.4G
            Active iob-Instances:   20
                     7812 M total memory
                     1059 M used memory
                     1007 M active memory
                      532 M inactive memory
                     6011 M free memory
                      194 M buffer memory
                      669 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 14:13:30 up 33 min,  2 users,  load average: 0.50, 1.19, 1.44
            Tasks: 176 total,   1 running, 175 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us, 28.6 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   7812.3 total,   6011.4 free,   1059.3 used,    864.7 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6753.1 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4       15G  9.3G  4.5G  68% /
            devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
            /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
            tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
            [Thu Jul 31 13:40:12 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:6E:CD:63 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=03469609-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Thu Jul 31 13:40:13 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Thu Jul 31 13:40:13 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Thu Jul 31 13:40:16 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            2.8G    /var/
            1.4G    /var/log/journal/6ac5520739004d4f99a6b7dc043c9949
            1.4G    /var/log
            1.2G    /var/cache/apt/archives
            Archived and active journals take up 1.3G in the file system.
            /opt/iobroker/backups:
            601M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            417M    /opt/iobroker/iobroker-data/
            325M    /opt/iobroker/iobroker-data/files
            76M     /opt/iobroker/iobroker-data/backup-objects
            48M     /opt/iobroker/iobroker-data/files/iot.admin
            47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            21M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.9f443724.js.map
            14M     /opt/iobroker/iobroker-data/objects.jsonl
            8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
            8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.19.1
            /usr/bin/node           v20.19.1
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.31.0
            nodejs:
              Installed: 20.19.1-1nodesource1
              Candidate: 20.19.1-1nodesource1
              Version table:
             *** 20.19.1-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                    100 /var/lib/dpkg/status
                 20.19.0-1nodesource1 1001
                 20.18.3-1nodesource1 1001
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2+rpi1 500
                    500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 288)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.6.17
            javascript:     8.9.2
            nodejs modules from github:     0
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
            + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
              system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
            + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
            + system.adapter.tahoma.0                 : tahoma                : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.6.17   , installed 7.6.17
            Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "ical"         : 1.16.2   , installed 1.16.2
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
            Adapter    "shelly"       : 10.1.0   , installed 10.1.0
            Adapter    "socketio"     : 6.7.1    , installed 7.0.8
            Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
            Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "web"          : 7.0.8    , installed 7.0.8
            Adapter    "ws"           : 2.6.2    , installed 3.0.19
            Objects and States
            Objects:        5085
            States:         4085
            W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
            Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48802      5383/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48797      5383/iobroker.js-co
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       49119      5689/io.shelly.1
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       49058      5624/io.mqtt.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12967      550/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          16391      519/cupsd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          12969      550/sshd: /usr/sbin
            tcp6       0      0 :::631                  :::*                    LISTEN      0          16392      519/cupsd
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       51972      6036/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       48896      5401/io.admin.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13120      801/dhcpcd
            udp        0      0 0.0.0.0:41986           0.0.0.0:*                           108        12828      393/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12826      393/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       50573      5678/io.shelly.0
            udp6       0      0 :::44892                :::*                                108        12829      393/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          13134      801/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        12827      393/avahi-daemon: r
            2025-07-31 14:13:28.264  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 19(WZ-Essplatz/C4:5B:BE:79:48:8B) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:40.366  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 7(gateway-2013-4959-9376/D4:8A:3B:CD:86:F3) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:40.476  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 8(Gerdas-iPhone/7A:43:5F:51:3B:00) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:40.587  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 9(Gerhards-iPhone/1E:11:09:80:C4:E4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:40.802  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 11(iPadProGuG/DE:19:03:1F:C8:4F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:41.142  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 14(Repeater-Buero/4E:91:AB:61:5B:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:41.622  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 19(WZ-Essplatz/C4:5B:BE:79:48:8B) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:53.558  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 7(gateway-2013-4959-9376/D4:8A:3B:CD:86:F3) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:53.664  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 8(Gerdas-iPhone/7A:43:5F:51:3B:00) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:53.769  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 9(Gerhards-iPhone/1E:11:09:80:C4:E4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:53.986  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 11(iPadProGuG/DE:19:03:1F:C8:4F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:54.314  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 14(Repeater-Buero/4E:91:AB:61:5B:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:13:54.753  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 19(WZ-Essplatz/C4:5B:BE:79:48:8B) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:06.716  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 7(gateway-2013-4959-9376/D4:8A:3B:CD:86:F3) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:06.827  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 8(Gerdas-iPhone/7A:43:5F:51:3B:00) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:06.944  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 9(Gerhards-iPhone/1E:11:09:80:C4:E4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:07.154  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 11(iPadProGuG/DE:19:03:1F:C8:4F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:07.507  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 14(Repeater-Buero/4E:91:AB:61:5B:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:07.967  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 19(WZ-Essplatz/C4:5B:BE:79:48:8B) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:20.153  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 7(gateway-2013-4959-9376/D4:8A:3B:CD:86:F3) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:20.378  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 8(Gerdas-iPhone/7A:43:5F:51:3B:00) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:20.585  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 9(Gerhards-iPhone/1E:11:09:80:C4:E4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:20.734  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 11(iPadProGuG/DE:19:03:1F:C8:4F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:21.019  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 14(Repeater-Buero/4E:91:AB:61:5B:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-07-31 14:14:21.472  - info: tr-064.0 (5738) forEachConfiguredDevice: in GetSpecificHostEntry 19(WZ-Essplatz/C4:5B:BE:79:48:8B) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            iob diag has finished.
            pi@iobroker:~ $
              Thomas Braun Most Active @Gerhardptl last edited by Thomas Braun
              @gerhardptl sagte in [GELÖST]Node.js update will nicht wie es soll:
              Userland : 32 bit
              Bedeutet schonmal KOMPLETTE NEUINSTALLATION des aktuellen Releases in der 64Bit-Lite-Version. Anders kommst du da nicht runter.
              Kannst auch gleich wie vorgesehen einen anderen username als 'pi' verwenden.
              nodejs ist aber in der vorgesehen Version installiert, was siehtste denn da für ein Problem?
                ich habe eben immer noch V20.19.1 und nicht die .4
                  PlatformBetriebssystem:linux
                  Architektur:arm
                  CPUs:4
                  Geschwindigkeit:1800 MHz
                  Modell:unknown
                  RAM:7.6 GB
                  System-Betriebszeit:00:13:22
                  Node.js:v20.19.1
                  Zeit:1753962814337
                  Zeitversatz:-120
                  NPM:10.8.2
                  Adapter-Anzahl:572
                  Datenträgergröße:14.3 GB
                  Freier Festplattenspeicher:5.1 GB
                  Aktive Instanzen:8
                  Pfad:/opt/iobroker/
                  Betriebszeit:00:00:33
                  aktiv:true
                  _nodeCurrent:20.19.1
                  _nodeNewest:20.19.4
                  _nodeNewestNext:20.19.4
                  _npmCurrent:10.8.2
                  _npmNewest:10.8.2
                  _npmNewestNext:10.8.2
                    @gerhardptl
                    nodesource hat es für die 32Bit-Version noch nicht gebaut. Da scheint's warum auch immer zu klemmen.
                    Könnte damit zusammenhängen, das halt 32Bit nicht mehr im Fokus steht. Zeit da auf 64 umzusatteln, arm32 stirbt halt aus und wird ganz offensichtlich nicht mehr gleichwertig gepflegt. Deswegen predige ich ja auch immer da die vollständige 64Bit-Version zu fahren.
                    Gilt offenbar auch für nodejs@22:
                    https://github.com/nodesource/distributions/issues/1881
                    passibe15 created this issue in nodesource/distributions
                    open [ERROR] Node.js v22 out of date for armhf #1881
                      Vielen Dank für deine Unterstützung - ich werde am besten neu anfangen.
                      Viele Grüße
                      Gerhard
                        Richtig...
                        Schnapp die ein frisches Speichermedium, knall da RaspberryOS 13 'Trixie' drauf, wenn das in wenigen Wochen veröffentlicht wurde und zieh dann mit einem Backup der Nutzdaten um.
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                        1.2k
                        2046
