    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. wie Z2M richtig konfigurieren?
      ManiacKill @Asgothian last edited by
      Moien Jungs,
      ich versuch zigbee2mqtt mit meinem Zigbee Coordinator zu verbinden, leider ohne Erfolg !
      ich weiß nicht was ich hier falsch mache, 192.168.2.249:6638 ist meine Adresse zum Coordinator.
      Thomas Braun arteck skvarel 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @ManiacKill last edited by
        @maniackill sagte in Smart-Home mit ioBroker – Zigbee, Z-Wave, DECT, Matter?:
        Das steht vielleicht im Log drin.
          ManiacKill @Thomas Braun last edited by
          zigbee2mqtt.0
          2025-07-31 20:25:41.125	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          zigbee2mqtt.0
          2025-07-31 20:25:41.124	warn	Start try again in 1 seconds...
          zigbee2mqtt.0
          2025-07-31 20:25:41.124	debug	Error: Parse Error: Expected HTTP/
          zigbee2mqtt.0
          2025-07-31 20:25:23.126	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          zigbee2mqtt.0
          2025-07-31 20:25:23.124	warn	Start try again in 1 seconds...
          zigbee2mqtt.0
          2025-07-31 20:25:23.124	debug	Error: Parse Error: Expected HTTP/
          zigbee2mqtt.0
          2025-07-31 20:25:08.833	info	Statring DummyMQTT-Server on IP 192.168.2.220 and Port 1881
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	==================================================================================
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Coordinator Check Cron : 0 3 * * *
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Coordinator Check Loglevel: info
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use Automatic Coordinator Check: no
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use Simple Press/Release State: no
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use Simple Move/Stop State: no
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use Simple Hold/Release State: yes
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use Device Icons: no
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use Event In Desc: yes
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use BrightnessStep OnOff: no
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use BrightnessMove OnOff: no
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use ColorTemperature ColorSync: no
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Use Kelvin: no
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Zigbee2MQTT Debug Log: deactivated
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Zigbee2MQTT Dummy MQTT Port: 1881
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Zigbee2MQTT Dummy MQTT IP-Bind: 192.168.2.220
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Zigbee2MQTT Websocket Dummy MQTT-Server: activated
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Zigbee2MQTT Websocket Auth-Token: unused
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Zigbee2MQTT Websocket Port: 6638
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Zigbee2MQTT Websocket Server: 192.168.2.249
          zigbee2mqtt.0
          2025-07-31 20:25:08.782	info	|| Zigbee2MQTT Websocket Scheme: ws
          Das kommt aber das sagt mir leider nix !
            arteck Developer Most Active @ManiacKill last edited by
            @maniackill das kann nicht sein
            die websocket IP kann nicht anders als die von der GUI sein
            • skvarel
              skvarel Developer @ManiacKill last edited by skvarel
              @maniackill .. du musst den Adapter nicht mit deinem Coordinator sondern mit deiner Zigbee2mqtt Installation verbinden.
              Die IP 192.168.130.120:8081 ist die Adresse von meinem Zigbee2mqtt Server
                ManiacKill @skvarel last edited by
                @skvarel
                Ja das Problem war das ich überhaupt nicht den Zigbee2MQTT installiert habe :(.
                Hab jetzt Zigbee2MQTT + MQTT in einem LXC installiert und siehe da es geht auch 🙂
                  Homoran Global Moderator Administrators @ManiacKill last edited by
                  @maniackill ich hab den Part mal abgetrennt
                  bitte ggf. den provisorischen Threadtitel anpassen
                  81.1k
