    4. Neuer Adapter für Roborock-Staubsauger
      fritzkalle @Skyx3 last edited by
      ich habe den Adapter jetzt eine Weile mit dem Saros 10R laufen und er funktioniert zwar, stürzt aber häufig ab und ist dann bis zum Neustart nicht ansprechbar 😞
      Das hier sind die Fehlermeldungen:
      setTimeout called, but adapter is shutting down
      Failed to process "get_clean_summary" on robot vArM2m3ap0E3f7dsbZWNX (roborock.vacuum.a144): Error: Could not check object existence of roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10.dust_collection_status: Cannot check object existence of "roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10.dust_collection_status": Connection is closed. at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/maybeCallback.ts:129:17) at Roborock._setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5017:26) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2336:17
      Could not check object existence of roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10: Cannot check object existence of "roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10": Connection is closed.
      Could not check object existence of roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10: Cannot check object existence of "roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10": Connection is closed. at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/maybeCallback.ts:129:17) at Roborock._setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5017:26) at runNextTicks (node:internal/process/task_queues:60:5) at processImmediate (node:internal/timers:454:9) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2336:17
      unhandled promise rejection: Could not check object existence of roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10: Cannot check object existence of "roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10": Connection is closed.
      Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      get state error: Connection is closed.
      redis get roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10.clean_type, error - Connection is closed.
      Ich weiß nicht, ob ich das mit dem Einfügen der Fehlermeldungen richtig gemacht habe. Ich bitte um Nachsicht. Auch weiß ich leider nicht ob und wie ich ein Issue auf Github aufmachen sollte.
      Viele Grüße!
      • copystring
        copystring last edited by
        Immer erstmal auf GitHub nach schauen, ob jemand das gleiche Problem hat. Falls nicht, einfach ein GitHub Issue aufmachen. Ich schaue es mir dann an.
          TimoWald @copystring last edited by
          Hallo ich habe aktuell diesen Fehler. Kann mir einer verraten woran es liegt?
          2025-07-26 17:58:52.423 - info: host.iobroker instance system.adapter.roborock.0 in version "0.6.19" (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) started with pid 2115372
          2025-07-26 17:58:56.781 - info: roborock.0 (2115372) starting. Version 0.6.19 (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 7.0.6
          2025-07-26 17:58:56.799 - info: roborock.0 (2115372) Starting adapter. This might take a few minutes depending on your setup. Please wait.
          2025-07-26 17:58:56.821 - info: roborock.0 (2115372) Loaded existing clientID: ee6783f4-5d0a-4d48-b00e-7cafd23b31d9
          2025-07-26 17:58:57.104 - error: roborock.0 (2115372) Failed to process undefined on robot undefined (unknown device model): TypeError: Cannot read properties of null (reading 'rrHomeId')
          at http_api.getHomeID (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:111:31)
          at processTicksAndRejections (node:internal/process/task_queues:95:5)
          at http_api.updateHomeData (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:123:19)
          at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:33:3)
          at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
          2025-07-26 17:58:57.328 - info: roborock.0 (2115372) MQTT initialized
          2025-07-26 17:58:57.329 - error: roborock.0 (2115372) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2025-07-26 17:58:57.330 - error: roborock.0 (2115372) unhandled promise rejection: this.homeData is not initialized. Initialize via getHomeData() first
          2025-07-26 17:58:57.330 - error: roborock.0 (2115372) Error: this.homeData is not initialized. Initialize via getHomeData() first
          at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
          at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
          2025-07-26 17:58:57.330 - error: roborock.0 (2115372) this.homeData is not initialized. Initialize via getHomeData() first
          2025-07-26 17:58:57.343 - info: roborock.0 (2115372) terminating
          2025-07-26 17:58:57.344 - warn: roborock.0 (2115372) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2025-07-26 17:58:57.402 - info: roborock.0 (2115372) MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
          2025-07-26 17:58:57.845 - info: roborock.0 (2115372) terminating
          2025-07-26 17:58:57.994 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2025-07-26 17:58:57.994 - error: host.iobroker Caught by controller[1]: Error: this.homeData is not initialized. Initialize via getHomeData() first
          2025-07-26 17:58:57.994 - error: host.iobroker Caught by controller[1]: at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
          2025-07-26 17:58:57.994 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
          2025-07-26 17:58:57.994 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2025-07-26 17:58:57.994 - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
          2025-07-26 17:58:59.558 - warn: openknx.0 (1699916) Ignoring GroupValue_Write of unknown GA 9/0/4
          2025-07-26 17:59:00.842 - info: host.iobroker "system.adapter.roborock.0" disabled
            Creekhail last edited by
            Ich möchte mich für die Arbeit an diesem Adapter bedanken.
            Seit einigen Tagen sind wir auf den Saros 10R umgestiegen, vorher war der S7 MaxV im Einsatz. Dort hatte ich noch den Xiaomi-Adapter verwendet.
            Mit dem Umstieg auf das neue Modell habe ich auch bei der App den Wechsel zur Roborock-Original-App vollzogen. Somit musste auch im iobroker auf den neuen Adapter gewechselt werden.
            Nach leichten Anfangsschwierigkeiten (keine lokale Verbindung), läuft die Geschichte jetzt mit der Version 0.6.19
            Daher konnte ich heute auch im VIS die Anpassungen vornehmen, da die Steuerung doch in einigen Punkten vom bisherigen Xiaomi-Adapter abweicht.
            Die wesentlichen Dinge lassen sich jetzt wieder steuern bzw. ablesen, so dass auch ohne Handy der Roboter seinen Dienst verrichten kann.
            Anbei noch ein Screenshot von der VIS dazu.
            T W 2 Replies Last reply Reply Quote 0
              TimoWald @Creekhail last edited by
              @creekhail hallo könnte ich einen Export deiner Seite haben?
                Creekhail @TimoWald last edited by
                @timowald Was genau hast du denn vor bzw. was meinst du mit "Export deiner Seite"?
                  @creekhail Export deiner Seite vom Robby. Finde diese super und würde es bei mir genauso machen wollen.
                    Würfel last edited by Würfel
                    ich hab die neuste Adapter Version installiert.
                    Nun bleibt der Adapter dauerhaft grün.
                    Wenn ich auf den Instanzlink klicke und dann 8083 nehme zeigt er mit eine schwarze Seite mit einem Reckeck oben links an und mehreren Buttons.
                    In der Zeit geht der Adapter auf Rot und in Logs kommen zig Fehlermeldungen...
                    Hab ich etwas falsch eingestellt im Adapter?
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.537	warn	Do not restart adapter system.adapter.roborock.0 because restart loop detected
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.537	info	Restart adapter system.adapter.roborock.0 because enabled
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	Caught by controller[3]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:601:18)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	Caught by controller[3]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	Caught by controller[3]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	Caught by controller[3]: TypeError: Cannot read properties of undefined (reading 'productId')
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	Caught by controller[2]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:562:26)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	Caught by controller[2]: at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.536	error	Caught by controller[2]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.535	error	Caught by controller[2]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.535	error	Caught by controller[2]: TypeError: Cannot read properties of undefined (reading 'productId')
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.535	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.535	error	Caught by controller[0]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:559:17)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.535	error	Caught by controller[0]: at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.535	error	Caught by controller[0]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.535	error	Caught by controller[0]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.534	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'productId')
                    host.PI250GBUSBC
                    2025-07-31 23:54:32.534	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    roborock.0
                    2025-07-31 23:54:32.330	info	terminating
                    roborock.0
                    2025-07-31 23:54:31.856	error	Cannot read properties of undefined (reading 'productId')
                    roborock.0
                    2025-07-31 23:54:31.856	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:601:18)
                    roborock.0
                    2025-07-31 23:54:31.854	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
                    roborock.0
                    2025-07-31 23:54:31.854	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    roborock.0
                    2025-07-31 23:54:31.850	error	Cannot read properties of undefined (reading 'productId')
                    roborock.0
                    2025-07-31 23:54:31.849	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:562:26)
                    roborock.0
                    2025-07-31 23:54:31.848	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
                    roborock.0
                    2025-07-31 23:54:31.848	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    roborock.0
                    2025-07-31 23:54:31.828	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    roborock.0
                    2025-07-31 23:54:31.826	info	terminating
                    roborock.0
                    2025-07-31 23:54:31.815	error	Cannot read properties of undefined (reading 'productId')
                    roborock.0
                    2025-07-31 23:54:31.815	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:559:17)
                    roborock.0
                    2025-07-31 23:54:31.813	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
                    roborock.0
                    2025-07-31 23:54:31.812	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    roborock.0
                    2025-07-31 23:54:31.500	error	Failed to process mainUpdateInterval on robot bMnYxoB2iqR9CnAlTK9fy (roborock.vacuum.a144): Error: this.get_status is not initialized. Request get_status first. at requests_handler.isCleaning (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:611:10) at /opt/iobroker/node_modules/iobroker.roborock/main.js:117:48 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2751:38) at listOnTimeout (node:internal/timers:581:17) at processTimers (node:internal/timers:519:7)
                    roborock.0
                    2025-07-31 23:54:30.411	error	Failed to process mainUpdateInterval on robot bMnYxoB2iqR9CnAlTK9fy (roborock.vacuum.a144): Error: this.get_status is not initialized. Request get_status first. at requests_handler.isCleaning (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:611:10) at /opt/iobroker/node_modules/iobroker.roborock/main.js:117:48
                    roborock.0
                    2025-07-31 23:54:29.403	info	Starting adapter finished. Let's go!!!!!!!
                    roborock.0
                    2025-07-31 23:54:22.571	error	Failed to process undefined on robot undefined (unknown device model): This robot is not fully supported just yet. Contact the dev to get this robot fully supported!
                    roborock.0
                    2025-07-31 23:54:21.279	error	Failed to process undefined on robot undefined (unknown device model): Failed to process message: Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at local_api.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:248:25) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:199:34) at Socket.emit (node:events:524:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:951:8)
                    roborock.0
                    2025-07-31 23:54:17.464	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                    roborock.0
                    2025-07-31 23:54:17.341	info	MQTT initialized
                    roborock.0
                    2025-07-31 23:54:16.632	info	Loaded existing clientID: 61f945a6-3735-4f3e-bcaa-dabc268a04bc
                    roborock.0
                    2025-07-31 23:54:16.569	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                    roborock.0
                    2025-08-01 00:00:14.402	error	Failed to process mainUpdateInterval on robot bMnYxoB2iqR9CnAlTxxxxx (roborock.vacuum.a144): Error: this.get_status is not initialized. Request get_status first. at requests_handler.isCleaning (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:611:10) at /opt/iobroker/node_modules/iobroker.roborock/main.js:117:48 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2751:38) at listOnTimeout (node:internal/timers:581:17) at processTimers (node:internal/timers:519:7)
                      fritzkalle @fritzkalle last edited by
                      Github Issue geschlossen, da Problem nach Neuinstallation des Adapters nicht mehr reproduzierbar.
                        Würfel @Creekhail last edited by
                        @creekhail
                        Was musstest Du denn anpassen das es bei Dir funktioniert?
                        bei mir wird der Adapter zwar grün, ruft man die Seite von dem Adapter auf springt der Adapter auf Rot und wirft zig Fehler im Log.
                        Tobias
                          ticaki last edited by ticaki
                          Hallo, weil ich meinen neuen Roborock Qrevo Curv S5X, nicht bei miHome gefunden habe, bin auf diesen Adapter (dev-branch) umgestiegen.
                          Der Saugroboter wird noch nicht "unterstützt", aber ich sehe die Daten und kann Programme starten, daher meine Frage:
                          Nach einer gewissen Zeit (ein paar Stunden) wird das Gerät als offline angezeigt und bleibt auch dabei. Ich kann dann zwar noch immer Programme über den Adapter starten, aber die Datenpunkte aktualisieren sich nicht mehr. Um das vollständig zu automatisieren müsste sich roborock.0.Devices.***.deviceStatus.state aktualisieren. Ist das ein Issuewert oder wird sich das ändern falls die Daten eingepflegt werden? Oder sollte ich per Skript den Adapter neustarten, wenn das Gerät länger als X Minuten offline ist.
                          Zusätzlich würde mich auch interessieren, ob es einen state gibt der "Programm läuft/Programm ist fertig" abbildet?
                          System 9 1 Reply Last reply Reply Quote 0
                          • System 9
                            System 9 @ticaki last edited by
                            guten morgen.
                            ich bekomme fehler, da einige Datenpunkte nicht angelegt werden.
                            State "roborock.0.Devices.6vZ1zawxmrZgMTxgOPtwJn.deviceStatus.carpet_clean_mode" has no existing object, this might lead to an error in future versions
                            State "roborock.0.Devices.6vZ1zawxmrZgMTxgOPtwJn.deviceStatus.carpet_mode" has no existing object, this might lead to an error in future versions
                            was kann ich hier machen ?
                              TimoWald @System 9 last edited by
                              Hallo, wieso bekomme ich meinen Adapter nicht mehr auf grün?
                              Dieser Feher kommt nach dem starten.
                              Was kann ich tun?
                              2025-08-20 06:57:36.146 - info: host.iobroker instance system.adapter.roborock.0 in version "0.6.19" (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) started with pid 2735931
                              2025-08-20 06:57:40.150 - info: roborock.0 (2735931) starting. Version 0.6.19 (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 7.0.7
                              2025-08-20 06:57:40.171 - info: roborock.0 (2735931) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                              2025-08-20 06:57:40.187 - info: roborock.0 (2735931) Loaded existing clientID: ee6783f4-5d0a-4d48-b00e-7cafd23b31d9
                              2025-08-20 06:57:40.472 - error: roborock.0 (2735931) Failed to process undefined on robot undefined (unknown device model): TypeError: Cannot read properties of null (reading 'rrHomeId')
                              2025-08-20 06:57:40.762 - info: roborock.0 (2735931) MQTT initialized
                              2025-08-20 06:57:40.763 - error: roborock.0 (2735931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2025-08-20 06:57:40.764 - error: roborock.0 (2735931) unhandled promise rejection: this.homeData is not initialized. Initialize via getHomeData() first
                              2025-08-20 06:57:40.764 - error: roborock.0 (2735931) Error: this.homeData is not initialized. Initialize via getHomeData() first
                              2025-08-20 06:57:40.765 - error: roborock.0 (2735931) this.homeData is not initialized. Initialize via getHomeData() first
                              2025-08-20 06:57:40.779 - info: roborock.0 (2735931) terminating
                              2025-08-20 06:57:40.781 - warn: roborock.0 (2735931) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2025-08-20 06:57:40.843 - info: roborock.0 (2735931) MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                              2025-08-20 06:57:41.282 - info: roborock.0 (2735931) terminating
                              2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                              2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[1]: Error: this.homeData is not initialized. Initialize via getHomeData() first
                              2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[1]: at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
                              2025-08-20 06:57:41.438 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
                              2025-08-20 06:57:41.438 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2025-08-20 06:57:41.438 - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
                              2025-08-20 06:57:52.160 - info: host.iobroker "system.adapter.roborock.0" disabled
                              2025-08-20 06:58:14.994 - error: roborock.0 (2735952) adapter disabled
                              2025-08-20 06:58:15.040 - warn: roborock.0 (2735952) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                              2025-08-20 06:58:15.723 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                              2025-08-20 06:58:15.723 - info: host.iobroker Do not restart adapter system.adapter.roborock.0 because disabled or deleted
                              • N
                                nu_81 @Anderl 0 last edited by nu_81
                                @anderl-0
                                hab nun auf einmal die selben Fehler.
                                Hast du das Problem schon gelöst?
                                  Thomas Braun Most Active @nu_81 last edited by
                                  @nu_81
                                  Versionsnummern der üblichen Verdächtigen? Alternativ die Ausgabe von
                                  iob diag
                                  posten.
                                  • N
                                    nu_81 @Thomas Braun last edited by
                                    @thomas-braun said in Fehler Roborock - Adapter:
                                    @nu_81
                                    Welche Verdächtigen meinst du? Kann dir leider nicht folgen.
                                      @nu_81
                                      Versionen von nodejs, js-controller usw.
                                      Poste einfach die Ausgabe von
                                      iob diag
                                      da steht erstmal alles drin.
                                      • N
                                        Hier der Log.
                                        Danke schonmal!
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                         Static hostname: raspberrypi
                                               Icon name: computer
                                                  Kernel: Linux 6.12.34+rpt-rpi-v8
                                            Architecture: arm64
                                        OS is similar to:
                                        Model           : Raspberry Pi 4 Model B Rev 1.1
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         18:42:51 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
                                        CPU threads: 4
                                        *** LIFE CYCLE STATUS ***
                                        Operating System is the current Debian stable version codenamed 'bookworm'!
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        ~ Under-voltage has occurred
                                        ~ Arm frequency capping has occurred
                                        ~ Throttling has occurred
                                        ~ Soft temperature limit has occurred
                                        *** TIME AND TIMEZONES ***
                                                       Local time: Sat 2025-08-23 18:42:51 CEST
                                                   Universal time: Sat 2025-08-23 16:42:51 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        pihome
                                        HOME=/home/pihome
                                        GROUPS=pihome adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker uosserver
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                        *** DISPLAY-SERVER SETUP ***
                                        Display-Server:         false
                                        Unit display-manager.service could not be found.
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:            4.0G        3.1G        281M         29M        696M        839M
                                        Swap:           209M        209M        704K
                                        Total:          4.2G        3.4G        282M
                                        Active iob-Instances:   29
                                                 3796 M total memory
                                                 2995 M used memory
                                                 2252 M active memory
                                                 1046 M inactive memory
                                                  268 M free memory
                                                   38 M buffer memory
                                                  625 M swap cache
                                                  199 M total swap
                                                  199 M used swap
                                                    0 M free swap
                                        top - 18:42:52 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
                                        Tasks: 252 total,   1 running, 251 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 44.4 us, 22.2 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   3796.9 total,    268.2 free,   2996.0 used,    664.5 buff/cache
                                        MiB Swap:    200.0 total,      0.7 free,    199.3 used.    800.9 avail Mem
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                        tmpfs          tmpfs     760M  1.2M  759M   1% /run
                                        /dev/mmcblk0p2 ext4       29G   17G   11G  63% /
                                        tmpfs          tmpfs     1.9G  9.2M  1.9G   1% /dev/shm
                                        /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                                        tmpfs          tmpfs     380M   84K  380M   1% /run/user/1002
                                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                        [Sat Aug 23 13:17:08 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Sat Aug 23 13:17:11 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                                        [Sat Aug 23 13:17:12 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                                        Show mounted filesystems:
                                        TARGET           SOURCE         FSTYPE OPTIONS
                                        /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        1.2G    /var/
                                        486M    /var/log
                                        380M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
                                        348M    /var/cache
                                        Archived and active journals take up 379.5M in the file system.
                                        /opt/iobroker/backups:
                                        54M     /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        358M    /opt/iobroker/iobroker-data/
                                        269M    /opt/iobroker/iobroker-data/files
                                        68M     /opt/iobroker/iobroker-data/backup-objects
                                        48M     /opt/iobroker/iobroker-data/files/iot.admin
                                        47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
                                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                        24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                        15M     /opt/iobroker/iobroker-data/objects.jsonl
                                        8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                                        8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                        *** ZigBee Settings ***
                                        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                        Zigbee Network Settings on your coordinator/in nvbackup are:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        To unmask the settings run 'iob diag --unmask'
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.19.4
                                        /usr/bin/node           v20.19.4
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.32.0
                                        nodejs:
                                          Installed: 20.19.4-1nodesource1
                                          Candidate: 20.19.4-1nodesource1
                                          Version table:
                                         *** 20.19.4-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                                100 /var/lib/dpkg/status
                                             20.19.3-1nodesource1 1001
                                             20.19.2-1nodesource1 1001
                                             20.19.1-1nodesource1 1001
                                             20.19.0-1nodesource1 1001
                                             20.18.3-1nodesource1 1001
                                             20.18.2-1nodesource1 1001
                                             20.18.1-1nodesource1 1001
                                             20.18.0-1nodesource1 1001
                                             20.17.0-1nodesource1 1001
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             18.19.0+dfsg-6~deb12u2 500
                                             18.19.0+dfsg-6~deb12u1 500
                                        No problems detected
                                        Errors in npm tree: 0
                                        Checking for nodejs vulnerability:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 3139)
                                        Core adapters versions
                                        admin:          7.6.17
                                        javascript:     8.9.2
                                        nodejs modules from github:     1
                                        +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                                        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                          system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                                        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                        + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                                        + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                                        + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
                                        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                                          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                          system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                                          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                        + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                                        + system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                        + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
                                        + system.adapter.ph803w.0                 : ph803w                : raspberrypi                              -  enabled
                                          system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
                                        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                                          system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
                                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                                        + system.adapter.tapo.0                   : tapo                  : raspberrypi                              -  enabled
                                        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                                        + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
                                        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Upgrade policy: none
                                        Installed ioBroker-Adapters
                                        Used repository: stable
                                        Adapter    "admin"        : 7.6.17   , installed 7.6.17
                                        Adapter    "alarm"        : 3.7.0    , installed 3.7.0
                                        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                                        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                                        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                                        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                                        Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                        Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
                                        Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
                                        Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                                        Adapter    "ical"         : 1.16.2   , installed 1.16.1 [Updatable]
                                        Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                                        Controller "js-controller": 7.0.7    , installed 7.0.7
                                        Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                                        Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                                        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                                        Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
                                        Adapter    "roborock"     : 0.6.18   , installed 0.6.18
                                        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                        Adapter    "schoolfree"   : 1.1.10   , installed 1.1.9  [Updatable]
                                        Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                                        Adapter    "shuttercontrol": 2.0.3   , installed 2.0.1  [Updatable]
                                        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                                        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                        Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                        Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                                        Objects and States
                                        Objects:        8590
                                        States:         6628
                                        Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       448519     33748/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       446004     33748/iobroker.js-c
                                        tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6488       914/slirp4netns
                                        tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6494       914/slirp4netns
                                        tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6496       914/slirp4netns
                                        tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6498       914/slirp4netns
                                        tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       6361       730/discovery
                                        tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6492       914/slirp4netns
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6107       732/sshd: /usr/sbin
                                        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8720       856/pihole-FTL
                                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        8055       856/pihole-FTL
                                        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        8056       856/pihole-FTL
                                        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6490       914/slirp4netns
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       453005     34618/io.shelly.1
                                        tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6500       914/slirp4netns
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       448417     34233/io.fullybrows
                                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       449536     34424/io.nuki-exten
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          6109       732/sshd: /usr/sbin
                                        tcp6       0      0 :::53                   :::*                    LISTEN      999        8722       856/pihole-FTL
                                        tcp6       0      0 :::80                   :::*                    LISTEN      999        8057       856/pihole-FTL
                                        tcp6       0      0 :::443                  :::*                    LISTEN      999        8058       856/pihole-FTL
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       446157     33776/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       452363     34755/io.web.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        484        553/avahi-daemon: r
                                        udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6504       914/slirp4netns
                                        udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6502       914/slirp4netns
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       452785     34516/io.shelly.0
                                        udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       555009     730/discovery
                                        udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6506       914/slirp4netns
                                        udp        0      0 0.0.0.0:36782           0.0.0.0:*                           1002       552483     914/slirp4netns
                                        udp        0      0 0.0.0.0:55259           0.0.0.0:*                           1001       451740     34458/io.ph803w.0
                                        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8719       856/pihole-FTL
                                        udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        9782       856/pihole-FTL
                                        udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       451251     34397/io.mihome-vac
                                        udp        0      0 0.0.0.0:33046           0.0.0.0:*                           104        486        553/avahi-daemon: r
                                        udp        0      0 192.168.2.109:33514     0.0.0.0:*                           1002       552649     730/discovery
                                        udp6       0      0 :::5353                 :::*                                104        485        553/avahi-daemon: r
                                        udp6       0      0 :::53                   :::*                                999        8721       856/pihole-FTL
                                        udp6       0      0 :::123                  :::*                                999        9783       856/pihole-FTL
                                        udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          7193       638/NetworkManager
                                        udp6       0      0 :::33351                :::*                                104        487        553/avahi-daemon: r
                                        2025-08-23 18:43:58.144  - error: roborock.0 (42090) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                                        2025-08-23 18:43:58.191  - info: roborock.0 (42090) terminating
                                        2025-08-23 18:43:58.193  - warn: roborock.0 (42090) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2025-08-23 18:43:58.851  - info: roborock.0 (42090) terminating
                                        2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                                        2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:193:29)
                                        2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                                        2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                                        2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:524:28)
                                        2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                                        2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:951:8) {
                                        2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
                                        2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
                                        2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                                        2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]: }
                                        2025-08-23 18:43:59.249  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        2025-08-23 18:43:59.249  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                                        2025-08-23 18:44:02.499  - info: tapo.0 (34846) Get camera Status failed
                                        2025-08-23 18:44:02.500  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                                        2025-08-23 18:44:06.991  - info: tr-064.0 (34564) forEachConfiguredDevice: in GetSpecificHostEntry 1(Gioia/B8:94:E7:E7:C5:98) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                        2025-08-23 18:44:12.515  - info: tapo.0 (34846) Get camera Status failed
                                        2025-08-23 18:44:12.516  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                                          Thomas Braun Most Active @nu_81 last edited by Thomas Braun
                                          @nu_81 sagte in Neuer Adapter für Roborock-Staubsauger:
                                          Ich habe den Verdacht, das könnte mit nodejs zusammenhängen.
                                          Bring die drei Adapter auf Stand und dann ein
                                          iob nodejs-update
                                          B N 2 Replies Last reply Reply Quote 0
                                            breaksrmine @Thomas Braun last edited by
                                            Beim Adapter 0.6.18 kommt beim Roborock QV 35A folgende Fehler.
                                            Steuern geht aber ohne Probleme
                                            roborock.0
                                            2025-08-23 19:17:02.540 warn Unsupported attribute: seq_type of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.539 warn Unsupported attribute: exit_dock of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.538 warn Unsupported attribute: cleaning_info of get_status with value [object Object]. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.458 warn Unsupported attribute: last_clean_t of get_status with value 1755969220. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.457 warn Unsupported attribute: switch_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.416 warn Unsupported attribute: kct of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.336 warn Unsupported attribute: common_status of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.335 warn Unsupported attribute: dss of get_status with value 169. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.335 warn Unsupported attribute: rss of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.334 warn Unsupported attribute: extra_time of get_status with value 1860. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.333 warn Unsupported attribute: clean_percent of get_status with value 45. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:02.172 warn Unsupported attribute: charge_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            roborock.0
                                            2025-08-23 19:17:01.851 warn Unsupported attribute: in_warmup of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:01.650 warn Unsupported attribute: water_shortage_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:01.530 warn Unsupported attribute: mop_forbidden_enable of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:01.529 warn Unsupported attribute: water_box_carriage_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:01.488 warn Unsupported attribute: water_box_mode of get_status with value 207. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            roborock.0
                                            2025-08-23 19:17:01.287 warn Unsupported attribute: water_box_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                            916
                                            306687
