    4. Test Adapter drops-weather 1.2.x
    • Chris76e
      Chris76e @mcm1957 last edited by Chris76e
      @mcm1957
      der link ist erreichbar. Wie entferne ich den Apater am besten für eine neuinstallation? Gibt es vieleicht nen befehl über die Commando Zeile damit wirklich alles entfernt wird?
      Das ist die main.js bei meinem System
      'use strict';
      const utils = require('@iobroker/adapter-core');
      const os = require('node:os');
      const puppeteer = require('puppeteer-extra');
      const StealthPlugin = require('puppeteer-extra-plugin-stealth');
      // add the stealth plugin
      puppeteer.use(StealthPlugin());
      let watchdog = null;
      let browser = null;
      class DropsWeather extends utils.Adapter {
           * @param options ioBroker optionen
          constructor(options) {
              super({
                  ...options,
              this.mainURLEN = 'https://www.meteox.com/';
              this.mainURLDE = 'https://www.niederschlagsradar.de/';
              this.pageTimeout = 60000;
              this.on('ready', this.onReady.bind(this));
              this.on('unload', this.onUnload.bind(this));
        sigi234 Forum Testing Most Active @mcm1957 last edited by
        @mcm1957
        neue Meldungen:
        drops-weather.0
        2025-06-06 03:33:16.154	error	Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed.
        drops-weather.0
        2025-06-06 03:33:16.154	error	ProtocolError: Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed. at <instance_members_initializer> (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\common\CallbackRegistry.js:102:14) at new Callback (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\common\CallbackRegistry.js:106:16) at CallbackRegistry.create (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\common\CallbackRegistry.js:24:26) at Connection._rawSend (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\Connection.js:99:26) at CdpCDPSession.send (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\CdpSession.js:73:33) at NetworkManager.addClient (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\NetworkManager.js:62:20) at FrameManager.initialize (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\FrameManager.js:174:38) at #initialize (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\Page.js:291:36) at CdpPage._create (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\Page.js:103:31) at C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\Target.js:205:42
        drops-weather.0
        2025-06-06 03:33:16.154	error	unhandled promise rejection: Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed.
        drops-weather.0
        2025-06-06 03:33:16.153	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        drops-weather.0
        2025-06-06 03:33:16.149	warn	ProtocolError: Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed.
        • icebear
          icebear last edited by icebear
          und bei mir war erst alles gut, aber jetzt kommt andauernd wieder:
          drops-weather.0
          2025-06-06 07:50:46.756	error	Error: DB closed
          drops-weather.0
          2025-06-06 07:50:46.755	error	Error: DB closed
          drops-weather.0
          2025-06-06 07:50:46.748	warn	get state error: Connection is closed.
          drops-weather.0
          2025-06-06 07:50:46.747	warn	Could not perform strict object check of state drops-weather.0.data_1h.chartRain: DB closed
          drops-weather.0
          2025-06-06 07:50:46.746	warn	get state error: Connection is closed.
          drops-weather.0
          2025-06-06 07:50:46.746	warn	Could not perform strict object check of state drops-weather.0.data_5min.chartRain: DB closed
          drops-weather.0
          2025-06-06 07:50:46.602	warn	get state error: Connection is closed.
          drops-weather.0
          2025-06-06 07:50:46.501	warn	get state error: Connection is closed.
          drops-weather.0
          2025-06-06 07:50:45.763	info	Terminated (NO_ERROR): Without reason
          deinstallieren und neu installieren hab ich schon gemacht, Language hab ich trotz neu Installation auch nochmal von 'de' auf 'en' und wieder zurück gestellt, ändert aber nix.
          EDIT:
          Hier noch die Ausgabe vom Debug-Mode:
          drops-weather.0
          2025-06-06 08:11:10.354	error	Error: DB closed
          drops-weather.0
          2025-06-06 08:11:10.353	error	Error: DB closed
          drops-weather.0
          2025-06-06 08:11:10.351	debug	redis get drops-weather.0.data_1h.chartRain, error - DB closed
          drops-weather.0
          2025-06-06 08:11:10.350	debug	redis get drops-weather.0.data_5min.chartRain, error - Connection is closed.
          drops-weather.0
          2025-06-06 08:11:10.342	debug	Rain (data_1h): [{"label":"10:00","value":"0"},{"label":"11:00","value":"0"},{"label":"12:00","value":"0"},{"label":"13:00","value":"0"},{"label":"14:00","value":"0"},{"label":"15:00","value":"0.1"},{"label":"16:00","value":"0"},{"label":"17:00","value":"0.3"},{"label":"18:00","value":"0.1"},{"label":"19:00","value":"0"},{"label":"20:00","value":"0.1"},{"label":"21:00","value":"0"},{"label":"22:00","value":"0.1"},{"label":"23:00","value":"0"},{"label":"00:00","value":"0"},{"label":"01:00","value":"0"},{"label":"02:00","value":"0"},{"label":"03:00","value":"0"},{"label":"04:00","value":"0"},{"label":"05:00","value":"0.2"},{"label":"06:00","value":"0.3"},{"label":"07:00","value":"0.1"},{"label":"08:00","value":"0.1"},{"label":"09:00","value":"0.2"}]
          drops-weather.0
          2025-06-06 08:11:10.319	warn	get state error: Connection is closed.
          drops-weather.0
          2025-06-06 08:11:10.314	debug	Rain (data_5min): [{"label":"08:10","value":"0"},{"label":"08:15","value":"0"},{"label":"08:20","value":"0"},{"label":"08:25","value":"0"},{"label":"08:30","value":"0"},{"label":"08:35","value":"0"},{"label":"08:40","value":"0"},{"label":"08:45","value":"0"},{"label":"08:50","value":"0"},{"label":"08:55","value":"0"},{"label":"09:00","value":"0"},{"label":"09:05","value":"0"},{"label":"09:10","value":"0"},{"label":"09:15","value":"0"},{"label":"09:20","value":"0"},{"label":"09:25","value":"0"},{"label":"09:30","value":"0"},{"label":"09:35","value":"0"},{"label":"09:40","value":"0"},{"label":"09:45","value":"0"},{"label":"09:50","value":"0"},{"label":"09:55","value":"0"},{"label":"10:00","value":"0"},{"label":"10:05","value":"0"},{"label":"10:10","value":"0"},{"label":"10:15","value":"0"},{"label":"10:20","value":"0"},{"label":"10:25","value":"0"},{"label":"10:30","value":"0"},{"label":"10:35","value":"0"},{"label":"10:40","value":"0"},{"label":"10:45","value":"0"},{"label":"10:50","value":"0"},{"label":"10:55","value":"0"},{"label":"11:00","value":"0"},{"label":"11:05","value":"0"},{"label":"11:10","value":"0"},{"label":"11:15","value":"0"}]
          host.iobroker
          2025-06-06 08:11:10.489	info	instance system.adapter.drops-weather.0 having pid 26365 terminated with code 0 (NO_ERROR)
          drops-weather.0
          2025-06-06 08:11:09.536	info	Terminated (NO_ERROR): Without reason
          drops-weather.0
          2025-06-06 08:11:09.173	debug	pages 2
          drops-weather.0
          2025-06-06 08:11:09.141	debug	destroy browser
          drops-weather.0
          2025-06-06 08:11:09.135	debug	creating 1 hour states
          drops-weather.0
          2025-06-06 08:11:09.134	debug	creating 5 min states
          drops-weather.0
          2025-06-06 08:11:09.134	debug	weatherData found
          drops-weather.0
          2025-06-06 08:11:09.131	debug	got labeltext "Es bleibt vorläufig trocken"
          drops-weather.0
          2025-06-06 08:11:09.127	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:10:00Z\",\"timestamp\":1749190200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:15:00Z\",\"timestamp\":1749190500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:20:00Z\",\"timestamp\":1749190800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:25:00Z\",\"timestamp\":1749191100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:30:00Z\",\"timestamp\":1749191400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:35:00Z\",\"timestamp\":1749191700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:40:00Z\",\"timestamp\":1749192000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:45:00Z\",\"timestamp\":1749192300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:50:00Z\",\"timestamp\":1749192600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:55:00Z\",\"timestamp\":1749192900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:00:00Z\",\"timestamp\":1749193200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:05:00Z\",\"timestamp\":1749193500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:10:00Z\",\"timestamp\":1749193800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:15:00Z\",\"timestamp\":1749194100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:20:00Z\",\"timestamp\":1749194400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:25:00Z\",\"timestamp\":1749194700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:30:00Z\",\"timestamp\":1749195000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:35:00Z\",\"timestamp\":1749195300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:40:00Z\",\"timestamp\":1749195600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:45:00Z\",\"timestamp\":1749195900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:50:00Z\",\"timestamp\":1749196200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:55:00Z\",\"timestamp\":1749196500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:00:00Z\",\"timestamp\":1749196800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:05:00Z\",\"timestamp\":1749197100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:10:00Z\",\"timestamp\":1749197400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:15:00Z\",\"timestamp\":1749197700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:20:00Z\",\"timestamp\":1749198000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:25:00Z\",\"timestamp\":1749198300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:30:00Z\",\"timestamp\":1749198600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:35:00Z\",\"timestamp\":1749198900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:40:00Z\",\"timestamp\":1749199200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:45:00Z\",\"timestamp\":1749199500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:50:00Z\",\"timestamp\":1749199800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:55:00Z\",\"timestamp\":1749200100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:00:00Z\",\"timestamp\":1749200400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:05:00Z\",\"timestamp\":1749200700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:10:00Z\",\"timestamp\":1749201000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:15:00Z\",\"timestamp\":1749201300}],\"daypart\":[{\"precipitationrate\":0.03,\"time\":\"2025-06-06T05:00:00Z\",\"timestamp\":1749186000,\"weathericon\":[1,0,-1,-1,0,-1,-1,-1,-1]},{\"precipitationrate\":0.04,\"time\":\"2025-06-06T06:00:00Z\",\"timestamp\":1749189600,\"weathericon\":[1,0,-1,-1,0,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-06-06T07:00:00Z\",\"timestamp\":1749193200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-06-06T08:00:00Z\",\"timestamp\":1749196800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-06-06T09:00:00Z\",\"timestamp\":1749200400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":50.5,\"longitude\":6.86,\"quadindex\":\"BCACADCABDBAAAC\",\"source\":\"radar-nl\",\"timestamp\":1749189600}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:00:00Z\",\"timestamp\":1749196800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:00:00Z\",\"timestamp\":1749200400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T10:00:00Z\",\"timestamp\":1749204000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T11:00:00Z\",\"timestamp\":1749207600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T12:00:00Z\",\"timestamp\":1749211200},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T13:00:00Z\",\"timestamp\":1749214800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T14:00:00Z\",\"timestamp\":1749218400},{\"lightningclass\":-1,\"precipitationrate\":0.3,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T15:00:00Z\",\"timestamp\":1749222000},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T16:00:00Z\",\"timestamp\":1749225600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T17:00:00Z\",\"timestamp\":1749229200},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T18:00:00Z\",\"timestamp\":1749232800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T19:00:00Z\",\"timestamp\":1749236400},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T20:00:00Z\",\"timestamp\":1749240000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T21:00:00Z\",\"timestamp\":1749243600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T22:00:00Z\",\"timestamp\":1749247200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T23:00:00Z\",\"timestamp\":1749250800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T00:00:00Z\",\"timestamp\":1749254400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T01:00:00Z\",\"timestamp\":1749258000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T02:00:00Z\",\"timestamp\":1749261600},{\"lightningclass\":-1,\"precipitationrate\":0.2,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T03:00:00Z\",\"timestamp\":1749265200},{\"lightningclass\":-1,\"precipitationrate\":0.3,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T04:00:00Z\",\"timestamp\":1749268800},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T05:00:00Z\",\"timestamp\":1749272400},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T06:00:00Z\",\"timestamp\":1749276000},{\"lightningclass\":-1,\"precipitationrate\":0.2,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T07:00:00Z\",\"timestamp\":1749279600}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":50.504,\"longitude\":6.855,\"quadindex\":\"BCACADCABDABB\",\"source\":\"weathercomputer\",\"timestamp\":1749190261}}},"," timezoneOffset: 120,"," locals: {\"labels\":[[0,\"trocken\"],[0.1,\"Nieselregen\"],[1,\"leichter Regen\"],[2,\"Starkregen\"]],\"language\":\"de\",\"strings\":{\"unavailable\":\"Etwas ist schief gelaufen\",\"mmph\":\"mm pro Std.\",\"now\":\"Jetzt\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
          drops-weather.0
          2025-06-06 08:11:09.121	debug	domcontent loaded, evaluate page
          drops-weather.0
          2025-06-06 08:11:00.788	debug	creating new page ...
          drops-weather.0
          2025-06-06 08:11:00.786	debug	Reading data from : https://www.niederschlagsradar.de/de-de/city/2821520
          drops-weather.0
          2025-06-06 08:10:59.356	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
          drops-weather.0
          2025-06-06 08:10:59.355	debug	browserPath set to puppeteer default
          drops-weather.0
          2025-06-06 08:10:59.354	debug	browserMode set to automatic, running on linux / x64
          drops-weather.0
          2025-06-06 08:10:59.323	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.16.0, js-controller: 7.0.6
            Marco 3 last edited by
            Mal eine Frage zum Datenumfang.
            Ist es eventuell geplant die Wind Richtung und Windstärke mit einzufangen?
            • mcm1957
              mcm1957 @Marco 3 last edited by
              @marco-3 said in Test Adapter drops-weather 1.2.x:
              Erstell für Erweiterungswünsche gener ein Issue.
              ABER - solange der Adapeter immer wieder merkbare Stabilitätsprobleme zeigt muss man überlegen wieviel Aufwand man da noch reinsteckt. Leider steht ja kein definiertes API zur Verfügung sondern es muss bzw. wird versucht die Webseite zu scrapen - was schon be geringen Änderungen der Webseite zu Stabilitätsproblemen und Anpassungsbedarf führt.
                emil70 last edited by
                Habe es mal unter Docker auf Synologie aufgespielt
                Fehlermeldung
                drops-weather.0
                	2025-08-04 18:54:08.665	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                drops-weather.0
                	2025-08-04 18:54:08.665	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                drops-weather.0
                	2025-08-04 18:54:08.664	warn	TypeError: Cannot read properties of null (reading 'newPage')
                drops-weather.0
                	2025-08-04 18:54:08.662	warn	setTimeout called, but adapter is shutting down
                drops-weather.0
                	2025-08-04 18:54:08.661	error	error launching browser undefined - Error: Failed to launch the browser process!/opt/iobroker/.cache/puppeteer/chrome/linux-138.0.7204.168/chrome-linux64/chrome: error while loading shared libraries: libnspr4.so: cannot open shared object file: No such file or directoryTROUBLESHOOTING: https://pptr.dev/troubleshooting
                drops-weather.0
                	2025-08-04 18:54:08.651	error	Cannot read properties of null (reading 'pages')
                PlatformBetriebssystem:linux
                Architektur:x64
                CPUs:4
                Geschwindigkeit:2197 MHz
                Modell:Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                RAM:11.5 GB
                System-Betriebszeit:2 T. 19:58:12
                Node.js:v20.18.2
                Zeit:1754276673997
                Zeitversatz:-120
                NPM:10.8.2
                Adapter-Anzahl:572
                Datenträgergröße:3572.6 GB
                Freier Festplattenspeicher:2158.0 GB
                Aktive Instanzen:29
                Pfad:/opt/iobroker/
                Betriebszeit:2 T. 19:08:42
                aktiv:true
                _nodeCurrent:20.18.2
                _nodeNewest:20.19.4
                _nodeNewestNext:20.19.4
                _npmCurrent:10.8.2
                _npmNewest:10.8.2
                _npmNewestNext:10.8.2
                Bekommt man das da gelöst??
                • David G.
                  @emil70
                  Selbe bei mir.
                  v7.6.17
                  99+
                  99+
                  Log-Größe: 1.4 KB
                  drops-weather.0
                  Zeit
                  debug
                  Nachricht
                  host.iobroker
                  2025-08-04 19:15:44.761	info	instance system.adapter.drops-weather.0 in version "1.2.7" (non-npm: iobroker-community-adapters/ioBroker.drops-weather) started with pid 108752
                  host.iobroker
                  2025-08-04 19:15:44.755	info	instance scheduled system.adapter.drops-weather.0 */5 * * * *
                  drops-weather.0
                  2025-08-04 19:15:45.981	error	Cannot read properties of null (reading 'pages')
                  drops-weather.0
                  2025-08-04 19:15:45.981	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:298:37) at DropsWeather.readDataFromServer (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:149:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                  drops-weather.0
                  2025-08-04 19:15:45.981	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                  drops-weather.0
                  2025-08-04 19:15:45.981	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  drops-weather.0
                  2025-08-04 19:15:45.981	warn	TypeError: Cannot read properties of null (reading 'newPage')
                  drops-weather.0
                  2025-08-04 19:15:45.981	warn	setTimeout called, but adapter is shutting down
                  drops-weather.0
                  2025-08-04 19:15:45.981	error	error launching browser undefined - Error: Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux-138.0.7204.168/chrome-linux64/chrome: error while loading shared libraries: libnspr4.so: cannot open shared object file: No such file or directory TROUBLESHOOTING: https://pptr.dev/troubleshooting
                  drops-weather.0
                  2025-08-04 19:15:45.977	error	Cannot read properties of null (reading 'pages')
                  drops-weather.0
                  2025-08-04 19:15:45.977	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:298:37) at DropsWeather.readDataFromServer (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:149:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                  drops-weather.0
                  2025-08-04 19:15:45.977	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                  drops-weather.0
                  2025-08-04 19:15:45.977	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  drops-weather.0
                  2025-08-04 19:15:45.977	warn	TypeError: Cannot read properties of null (reading 'newPage')
                  drops-weather.0
                  2025-08-04 19:15:45.977	warn	setTimeout called, but adapter is shutting down
                  drops-weather.0
                  2025-08-04 19:15:45.977	error	error launching browser undefined - Error: Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux-138.0.7204.168/chrome-linux64/chrome: error while loading shared libraries: libnspr4.so: cannot open shared object file: No such file or directory TROUBLESHOOTING: https://pptr.dev/troubleshooting
                  drops-weather.0
                  2025-08-04 19:15:45.973	error	Cannot read properties of null (reading 'pages')
                  drops-weather.0
                  2025-08-04 19:15:45.973	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:298:37) at DropsWeather.readDataFromServer (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:149:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                  bash        Script v.2025-03-08
                  *** BASE SYSTEM ***        Static hostname: iobroker
                         Icon name: computer-container
                           Chassis: container ☐
                    Virtualization: lxc
                            Kernel: Linux 6.8.12-11-pve
                      Architecture: x86-64
                  OS is similar to:
                  model name      : 12th Gen Intel(R) Core(TM) i3-12100
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   19:12:55 up 1 day,  5:47,  2 users,  load average: 0.87, 0.85, 0.87
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                  *** TIME AND TIMEZONES ***
                                 Local time: Mon 2025-08-04 19:12:55 CEST
                             Universal time: Mon 2025-08-04 17:12:55 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  david
                  HOME=/home/david
                  GROUPS=david adm dialout sudo audio video plugdev users iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server: false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            8.6G        4.5G        4.0G         81K        127M        4.1G
                  Swap:           536M        521M         15M
                  Total:          9.1G        5.0G        4.0G
                  Active iob-Instances:   55
                           8192 M total memory
                           4251 M used memory
                           2347 M active memory
                           1857 M inactive memory
                           3819 M free memory
                              0 M buffer memory
                            121 M swap cache
                            512 M total swap
                            496 M used swap
                             15 M free swap
                  top - 19:12:55 up 1 day,  5:47,  2 users,  load average: 0.87, 0.85, 0.87
                  Tasks:  85 total,   1 running,  84 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   8192.0 total,   3817.4 free,   4253.3 used,    121.3 buff/cache
                  MiB Swap:    512.0 total,     15.0 free,    497.0 used.   3938.7 avail Mem
                  *** FAILED SERVICES ***
                    UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                  * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                  LOAD   = Reflects whether the unit definition was properly loaded.
                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                  SUB    = The low-level unit activation state, values depend on unit type.
                  1 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  dmesg: read kernel buffer failed: Operation not permitted
                  No critical errors detected
                  *** FILESYSTEM ***
                  Filesystem             Type      Size  Used Avail Use% Mounted on
                  tank/subvol-118-disk-0 zfs        32G  8.7G   24G  27% /
                  none                   tmpfs     492K  4.0K  488K   1% /dev
                  none                   tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                  udev                   devtmpfs   16G     0   16G   0% /dev/tty
                  tmpfs                  tmpfs      16G     0   16G   0% /dev/shm
                  tmpfs                  tmpfs     6.3G  124K  6.3G   1% /run
                  tmpfs                  tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs                  tmpfs     3.2G     0  3.2G   0% /run/user/1000
                  Show mounted filesystems:
                  TARGET SOURCE                 FSTYPE OPTIONS
                  /      tank/subvol-118-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
                  /var:
                  1.4G    /var/
                  901M    /var/log
                  900M    /var/log/journal/409c783458ed4c4c8725e302ab3b413c
                  467M    /var/cache
                  Archived and active journals take up 899.7M in the file system.
                  /opt/iobroker/backups:
                  1.1G    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  1.1G    /opt/iobroker/iobroker-data/
                  531M    /opt/iobroker/iobroker-data/backup-objects
                  272M    /opt/iobroker/iobroker-data/files
                  93M     /opt/iobroker/iobroker-data/node-red
                  92M     /opt/iobroker/iobroker-data/node-red/node_modules
                  82M     /opt/iobroker/iobroker-data/states.jsonl
                  41M     /opt/iobroker/iobroker-data/mymedia/smoke.mp4
                  25M     /opt/iobroker/iobroker-data/mymedia/wasserhahn.mp4
                  21M     /opt/iobroker/iobroker-data/mymedia/clock_stopmotion.mov
                  16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  USB-Devices by-id:
                  *** ZigBee Settings ***
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  tcp
                  Zigbee Network Settings on your coordinator/in nvbackup are:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  To unmask the settings run 'iob diag --unmask'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.19.4
                  /usr/bin/node           v20.19.4
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.32.0
                  nodejs:
                    Installed: 20.19.4-1nodesource1
                    Candidate: 20.19.4-1nodesource1
                    Version table:
                   *** 20.19.4-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                          100 /var/lib/dpkg/status
                       20.19.3-1nodesource1 1001
                       20.19.2-1nodesource1 1001
                       20.19.1-1nodesource1 1001
                       20.19.0-1nodesource1 1001
                       20.18.3-1nodesource1 1001
                       20.18.2-1nodesource1 1001
                       20.18.1-1nodesource1 1001
                       20.18.0-1nodesource1 1001
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://security.debian.org bookworm-security/main amd64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 107241)
                  Core adapters versions
                  admin:          7.6.17
                  javascript:     8.9.2
                  nodejs modules from github:     7
                  +-- iobroker.ai-toolbox@0.1.3 (git+ssh://git@github.com/ToGe3688/ioBroker.ai-toolbox.git#f1fed33e3501a08d6052e01340e1ae1cda003746)
                  +-- iobroker.drops-weather@1.2.7 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.drops-weather.git#f0523e2380d3b95c612de4d4fc04c4bc6ee581e6)
                  +-- iobroker.google-sharedlocations@2.1.4 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#73e87eafd1922418a4829d93697b2268eacada2a)
                  +-- iobroker.playstation@0.0.3 (git+ssh://git@github.com/Lucky-ESA/ioBroker.playstation.git#5b43878f7d3f6b0a0cafff9a9882bd12c7f4dc20)
                  +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#97c61972c09ae9e53b157f4abc64e7e39efe617c)
                  +-- iobroker.smoothed@1.4.0 (git+ssh://git@github.com/BenAhrdt/ioBroker.smoothed.git#f864b035a8f8a432cb4aefb945158162d597b80b)
                  +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
                  Adapter State
                  + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                  + system.adapter.adb.0                    : adb                   : iobroker                                 -  enabled
                  + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.ai-assistant.0           : ai-assistant          : iobroker                                 -  enabled
                  + system.adapter.ai-toolbox.0             : ai-toolbox            : iobroker                                 -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                  + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                  + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                    system.adapter.daswetter.1              : daswetter             : iobroker                                 -  enabled
                    system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
                  + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                    system.adapter.devices.0                : devices               : iobroker                                 - disabled
                    system.adapter.drops-weather.0          : drops-weather         : iobroker                                 -  enabled
                  + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                  + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                  + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
                  + system.adapter.gsmsms.0                 : gsmsms                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                    system.adapter.iceroad.0                : iceroad               : iobroker                                 -  enabled
                  + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                  + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                    system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
                  + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                  + system.adapter.lovelace.1               : lovelace              : iobroker                                 -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
                    system.adapter.matter.0                 : matter                : iobroker                                 - disabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                    system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
                  + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                    system.adapter.notification-manager.0   : notification-manager  : iobroker                                 - disabled
                  + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                  + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                    system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                    system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                  + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                  + system.adapter.places.0                 : places                : iobroker                                 -  enabled
                    system.adapter.playstation.0            : playstation           : iobroker                                 - disabled
                  + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                    system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
                  + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                  + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                    system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                    system.adapter.rssfeed.0                : rssfeed               : iobroker                                 - disabled
                    system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1888, bind: 192.168.99.33
                  + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.smoothed.0               : smoothed              : iobroker                                 -  enabled
                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                  + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                  + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                  + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                  + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.99.4:6638
                  + instance is alive
                  ioBroker-Repositories
                  │ (index) │ name               │ url                                                     │ auto upgrade │
                  │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                  │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                  Active repo(s): Stable (default)
                  Upgrade policy: none
                  Installed ioBroker-Adapters
                  Used repository: Stable (default)
                  Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
                  Adapter    "adb"          : 0.0.7    , installed 0.0.7
                  Adapter    "adguard"      : 1.0.1    , installed 1.0.1
                  Adapter    "admin"        : 7.6.17   , installed 7.6.17
                  Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                  Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                  Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
                  Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
                  Adapter    "countdown"    : 3.0.0    , installed 3.0.0
                  Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                  Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                  Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                  Adapter    "drops-weather": 1.2.7    , installed 1.2.7
                  Adapter    "echarts"      : 1.9.2    , installed 2.0.6
                  Adapter    "email"        : 2.0.4    , installed 2.0.4
                  Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
                  Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                  Adapter    "gsmsms"       : 1.0.0    , installed 1.0.0
                  Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                  Adapter    "ical"         : 1.16.2   , installed 1.16.2
                  Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                  Adapter    "imap"         : 0.3.0    , installed 0.3.0
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                  Controller "js-controller": 7.0.6    , installed 7.0.6
                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                  Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                  Adapter    "lovelace"     : 4.1.15   , installed 5.0.0
                  Adapter    "matter"       : 0.5.1    , installed 0.5.1
                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                  Adapter    "nina"         : 0.0.25   , installed 0.0.25
                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                  Adapter    "notification-manager": 1.2.1, installed 1.3.0
                  Adapter    "nut"          : 1.6.0    , installed 1.6.0
                  Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                  Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                  Adapter    "parser"       : 2.2.4    , installed 2.2.4
                  Adapter    "ping"         : 1.6.2    , installed 1.7.9
                  Adapter    "places"       : 1.3.0    , installed 1.3.0
                  Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                  Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                  Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                  Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                  Adapter    "roborock"     : 0.6.18   , installed 0.6.19
                  Adapter    "rssfeed"      : 3.5.2    , installed 3.5.2
                  Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                  Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "smoothed"     : 1.4.0    , installed 1.4.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                  Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
                  Adapter    "sql"          : 3.0.1    , installed 3.0.1
                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                  Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                  Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                  Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                  Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Adapter    "zigbee"       : 2.0.5    , installed 3.0.1
                  Objects and States
                  Objects:        35683
                  States:         32075
                  Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:3 http://security.debian.org bookworm-security InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1001       39195      934/io.shelly.0
                  tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       39634      1079/adb
                  tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1001       29391      760/io.hm-rpc.1
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          25769      295/master
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26228      449/node-red
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       35596      968/io.sonoff.0
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       34994      835/io.mqtt.0
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21425      1/init
                  tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1001       26591      745/io.hm-rpc.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25810      122/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19308      122/iobroker.js-con
                  tcp6       0      0 :::8091                 :::*                    LISTEN      1001       71921      1634/io.lovelace.0
                  tcp6       0      0 :::8093                 :::*                    LISTEN      1001       72114      1741/io.rest-api.0
                  tcp6       0      0 :::8092                 :::*                    LISTEN      1001       71971      1685/io.lovelace.1
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24780      309/io.admin.0
                  tcp6       0      0 :::8083                 :::*                    LISTEN      1001       57312      1894/io.web.1
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57270      1877/io.web.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       72158      1758/io.simple-api.
                  tcp6       0      0 :::1980                 :::*                    LISTEN      1001       25097      449/node-red
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          21427      1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          23320      1/init
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          25770      295/master
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          21426      1/init
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       76158      1844/io.upnp.0
                  udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1001       41584      1007/io.tr-064.0
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37268      952/io.shelly.1
                  udp6       0      0 :::111                  :::*                                0          21428      1/init
                  2025-08-04 19:10:43.240  - error: drops-weather.0 (107328) Cannot read properties of null (reading 'pages')
                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) error launching browser undefined - Error: Failed to launch the browser process!
                  2025-08-04 19:10:43.244  - warn: drops-weather.0 (107328) setTimeout called, but adapter is shutting down
                  2025-08-04 19:10:43.244  - warn: drops-weather.0 (107328) TypeError: Cannot read properties of null (reading 'newPage')
                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) unhandled promise rejection: Cannot read properties of null (reading 'pages')
                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) TypeError: Cannot read properties of null (reading 'pages')
                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) Cannot read properties of null (reading 'pages')
                  2025-08-04 19:10:43.252  - info: host.iobroker instance system.adapter.drops-weather.0 having pid 107328 terminated with code 0 (NO_ERROR)
                  2025-08-04 19:10:58.584  - info: admin.0 (309) <== Disconnect system.user.admin from ::ffff:192.168.99.143 admin
                  2025-08-04 19:11:46.726  - info: mqtt.0 (835) Client [gaszaehler] reconnected. Old secret 1754307314012_4778. New secret 1754327506723_9892
                  2025-08-04 19:11:46.753  - info: mqtt.0 (835) Client [gaszaehler] subscribes on "mqtt.0.gaszaehler.ctrl.flow_start"
                  2025-08-04 19:11:46.763  - info: mqtt.0 (835) Client [gaszaehler] subscribes on "mqtt.0.gaszaehler.ctrl.set_prevalue"
                  2025-08-04 19:11:46.953  - info: mqtt.0 (835) Client [gaszaehler] publishOnSubscribe
                  2025-08-04 19:11:46.963  - info: mqtt.0 (835) Client [gaszaehler] publishOnSubscribe
                    emil70 @David G. last edited by
                    @david-g
                    HAbe etzt das nachinstalliert und nun geht es
                    sudo apt update
                    sudo apt install libnss3
                    sudo apt install libatk1.0-0
                    sudo apt install libxkbcommon-x11-0
                    sudo apt-get install libxcomposite-dev
                    sudo apt-get install libxdamage1
                    sudo apt-get install libxrandr2
                    sudo apt-get install libgbm-dev
                    sudo apt-get install libasound2
                    sudo apt-get install -y libatk-bridge2.0-0 libgtk-3.0
                    ilovegym David G. 2 Replies Last reply Reply Quote 0
                    • ilovegym
                      ilovegym @emil70 last edited by ilovegym
                      @emil70 setz die Pakete in die ENV im Docker, sonst muss du sieh ja jedesmal neu nach installieren..
                      dir hier meine ich:
                      - PACKAGES=nano redis-tools influxdb cifs-utils nfs-common
                      und da hintendran alle Pakete einfach mit Leerzeichen dazwischen
                      • David G.
                        David G. @emil70 last edited by
                        @emil70
                        Ja, so läuft es.
                        sudo apt update && sudo apt install -y libnss3 libatk1.0-0 libxkbcommon-x11-0 libxcomposite-dev libxdamage1 libxrandr2 libgbm-dev libasound2 libatk-bridge2.0-0 libgtk-3-0
                        Müssten die Abhängigkeiten nicht vom Adapter mit installiert werden?
                        E ilovegym 2 Replies Last reply Reply Quote 0
                          emil70 @ilovegym last edited by
                          @ilovegym
                          Kann ich dir nicht sagen. Wie sehe ich das unter docker?
                          ilovegym 1 Reply Last reply Reply Quote 0
                            @david-g
                            Weiß ich nicht
                            • ilovegym
                              @emil70
                              Doku
                              https://docs.buanet.de/de/iobroker-docker-image/#dokumentation
                              • ilovegym
                                ilovegym @David G. last edited by
                                @david-g sagte in Test Adapter drops-weather 1.2.x:
                                @emil70
                                Ja, so läuft es.
                                er hat n Docker laufen, da gibt man die Packages als ENV mit, wie in der Doku beschrieben. Sonst muss man ja jede Aenderung beim naechsten Image wieder von vorne installieren und dann laeuft erstmal nix, bis man alles hat.. (und da bestimmt einiges vergessen :))
                                • David G.
                                  David G. @ilovegym last edited by
                                  @ilovegym
                                  Ich hab aber kein Docker.
                                  So lasst es sich am schnellsten nachinstallieren.
                                  • ilovegym
                                    @david-g
                                    Sorry hab den @emil70 gemeint 😆
                                      masterkey @ilovegym last edited by
                                      Hallo zusammen:
                                      Ich bin gerade dabei den drops-weather adapter in meinen iobroker einzubinden. Ich hab einen raspberry pi 4. Ich habs allerdings bisher nicht zum laufen gebracht.
                                      Was ich bisher gemacht habe:
                                      drops-weather Adapter installiert und die Standort-id eingetragen
                                      puppeteer Adapter installiert
                                      mit:
                                      sudo apt install -y chromium-browser
                                      den Chromium Browser installiert.
                                      Muss ich da irgendwo noch etwas konfigurieren oder nachinstallieren? Hab leider in dem Thread den Überblick verloren und chatgpt ist es auch zu viel 😄
                                      • mcm1957
                                        mcm1957 @masterkey last edited by
                                        @masterkey
                                        Der puppeteer Adapter ist völlig unabhängig von drops-weather.
                                        Dann verrate doch mal welche Probleme du hast:
                                        • welche Version des Adapetrs ist installiert?
                                        • welche Fehlermeldungen hast du? Bitte poste den Log
                                          masterkey @mcm1957 last edited by
                                          @mcm1957
                                          ich hab die drops-weather version v1.2.7
                                          ich bekomme keine daten. es steht überall "Null"
                                          Als City Code habe ich mal den Standard Berlin 6573 drin gelassen. in der Browserconfig hab ich "automatic" und "chromium-browser" ausprobiert.
                                          Bei "Temp-Ordner für Browseraufruf" hab ich /tmp
                                          • mcm1957
                                            @masterkey
                                            Siehe oben:
                                            Wen da kein offensichtlicher Fehler drinnen steht, dann stell die Instanz auf LogLevel DEBUG und poste den debug log.
                                            drops-weather mcm1957
                                            21
                                            196
                                            25508
