    4. IoBroker mit Warema WMS Web Control
    • Marc Berg
      Marc Berg Most Active last edited by
      @marco-santarelli sagte in IoBroker mit Warema WMS Web Control:
      Hello, is the maintaner of warema-wms-venetian-blinds on NPM reading this thread? While I know I can see it and reverse-engineer it from the node_modules folder, Is it possible for this person to put the code on GitHub, so that we can collaborate on it?
      I have Warema blinds and a weather station at home, as well as the WMS stick and a webcontrol pro, and I became fairly proficient with WMS Studio, so I can help test the integrations and provide bugfixes!
      Hi Marco, did you get any response? I am also interested in further development.
      Marco Santarelli 1 Reply Last reply Reply Quote 0
      • Marco Santarelli
        Marco Santarelli @Marc Berg last edited by
        @marc-berg No response, i reverse-engineered the code from the npm package and modified it myself. You can see how I use it at https://github.com/santam85/addon-warema-wms/tree/main
        • Marc Berg
          Marc Berg Most Active @Marco Santarelli last edited by
          @marco-santarelli
          Yes, that's how I did it too. A fork of your repo and some customisations for my devices. I'm happy with that now.
          https://github.com/Marc-Berg/wms2mqtt
            tweefo last edited by
            Had been using Tombox' adapter working with the Webcontrol pro for a while. However it suddenly stopped working some time ago. Does someone still have it running with pro?
              PatrickR @Marc Berg last edited by
              @marc-berg
              Entschuldige bitte mein Anfängerfrage
              Dein "wms2mqtt" auf Github, sollte dies auch auf HA laufen?
              Ich frage, weil ich die Fehlermeldung beim hinzufügen erhalte, dass es kein gültiges Repository wäre,
              was ggf. an der fehlenden "repository.json" liegt.
              Danke schon mal
              Patrick
              • Marc Berg
                Marc Berg Most Active @PatrickR last edited by
                @patrickr sagte in IoBroker mit Warema WMS Web Control:
                Mein Ziel war es, das Image um meine zusätzlichen Gerätetypen zu erweitern und unter einer Docker Umgebung laufen zu lassen. Deshalb habe ich alle HA-Funktionalitäten entfernt, um den Code schlank zu halten.
                Wenn dir die Geräte reichen, die @Marco-Santarelli drin hat, solltest du sein Image nehmen.
                  PatrickR @Marc Berg last edited by PatrickR
                  @marc-berg
                  Danke für Deine schnelle RM.
                  Ich hab auch 63, 2A, daher bin ich auf Dein Resp gestossen.
                  Hab gerade erst die Chat-Funktion gefunden (what a shame)
                  Ich chatte Dich mal an, vermutlich interessiert meine Frage die wenigsten da HA.
                  Patrick
                  • Marc Berg
                    Um ganz ehrlich zu sein: Mich interessiert HA auch nicht. Deshalb kann ich diesbezüglich auch keinen Support leisten.
                    Wenn du dir selbst was zusammenstricken möchtest, dann musst du neben der index.js auch die Module unter addon-warema-wms/warema-bridge/srv/warema-wms-venetian-blinds anpassen, denn diese übernehmen die eigentliche Kommunikation mit dem WMS Netzwerk. Wegen der von mir entfernen HA-Funktionalität kannst du die Dateien aber nicht 1:1 ersetzen.
                      @marc-berg Vielen Dank
                        PatrickR @PatrickR last edited by
                        @Marc-Berg
                        Hallo Marc,
                        ich mußte bzgl. Wetterstation Pro
                        bei mir im wms-util.js noch einen Wert ändern.
                        Das wäre bei Dir
                        wms2mqtt/warema-bridge/srv/warema-wms-venetian-blinds/wms-util.js
                        Zeile 272
                        params.temp = parseInt(payload.substr(18, 2), 16) / 2 - 35;
                        Ich muß 40 abziehen, um die korrekten Werte zu erhalten.
                        Vergleich mit WMS Stick und WMS studio pro.
                        Patrick
                        PS: Sieh bitte auch meinen Kommentar zum " Squash deduplication #6"
                        Und vielen Dank für das "Implement comprehensive weather data deduplication"
                        • Marc Berg
                          Das wäre bei Dir
                          Zeile 272
                          Da hast du Recht, das passt nicht. Habe ich aber auch nur aus der original Library übernommen. Ich verwende die Temperatur der Wetterstation nicht, da bei starker Sonneneinstrahlung gern mal Mondwerte ankommen. Auch in der Warema App wird die Temperatur nicht direkt angezeigt, dem Hersteller ist wohl auch klar, dass man darauf nichts geben kann. Passe ich aber trotzdem bei Gelegenheit mal an.
                          Ich dachte erst, es sei ein Fehler im Code, aber die Wetterstation sendet wirklich ständig doppelt und dreifach. Wahrscheinlich kann ich noch viel mehr Duplikate rausfiltern, auch das schaue ich mir nochmal an.
                            @marc-berg sagte in IoBroker mit Warema WMS Web Control:
                            Wo noch ein allgemeines Problem liegt, ist bei den Jalousien, der maximale Winkel welcher wie in meinem Fall auf 80° steht.
                            Und bei der Umrechnung in % muss ich genau diesen maximal Wert als 100% hernehmen, ansonsten verwende ich einen falschen Wert.
                            So ging es mir anfänglich.
                            Da dieser Maximalwert für jeden Actuator unterschiedlich sein kann,
                            gibt es für unterschiedliche Werte auch unterschiedliche Winkelwerte die 100% bedeuten.
                            Man müßte eigentlich für jeden Actuator den maxWert als Berechnungsbasis ablegen und diesen in der Konfiguration übergeben (alles machbar aber mit Aufwand).
                            Was anderes noch.
                            Es gibt bestimmt eine Botschaft um im WMS-Mesh-System die Geräte auf "Abwesend" zu setzen.
                            Ist Dir da etwas bekannt?
                            Danke.
                            Patrick
                            • Marc Berg
                              Da ich keine Jalousien von Warema besitze, kann ich das nicht nachstellen.
                              Nein, keine Ahnung.
                                @marc-berg
                                ich hab noch für mich eine Anpassung bzgl. Polling gemacht.
                                Wenn ein neues Weather broadcast empfangen wird, wird der
                                der Intervall-Zähler für "Weather polling function" retriggert.
                                ///////////// index.js : Info
                                //Neu: Info
                                let weatherInterval;
                                //Neu: Info
                                function retriggerWeatherPolling() {
                                if (weatherInterval) {
                                clearInterval(weatherInterval);
                                weatherInterval = setInterval(pollWeatherData, pollingInterval);
                                log.fkt_log_info('046:Restarted weather data polling every ' + pollingInterval + ' ms');
                                //Änderung : Info
                                // Start weather polling with configurable interval
                                log.fkt_log_info('045:Started weather data polling every ' + pollingInterval + ' ms');
                                //Neu: Info
                                //function callback(err, msg)
                                /////case 'wms-vb-rcv-weather-broadcast':
                                ///////if (!cachedWeather || cachedWeather.hash !== weatherHash || (currentTime - cachedWeather.timestamp) > minTimeDiff) {
                                /////////if (typeof client !== 'undefined' && client.connected) {
                                retriggerWeatherPolling();
                                Patrick
                                  PatrickR @PatrickR last edited by PatrickR
                                  @Marc-Berg
                                  Noch eine Änderung des "weatherBroadcast" für meinen batteriebetrieben Temperatursensor "65".
                                         case '7080':
                                              msgType = 'weatherBroadcast';
                                              params.unknown_1 = payload.substr(0, 2);
                                              params.wind = parseInt(payload.substr(2, 2), 16) / 2;                  // 2025-06-28 PatrickR68 added / 2
                                              params.lumen = payload.substr(4, 2) === '00' ? parseInt(payload.substr(12, 2), 16) * 2 : parseInt(payload.substr(4, 2), 16) * parseInt(payload.substr(12, 2), 16) * 2;
                                              params.unknown_2 = payload.substr(6, 6);
                                              params.batt = parseInt(payload.substr(14, 2), 16) / 2;                // 2025-08-24 PatrickR68 0.99.111 Battery in V
                                              params.rain = payload.substr(16, 2) === 'C8';
                                              params.temp = parseInt(payload.substr(18, 2), 16) / 2 - 40;           // 2025-07-02 PatrickR68 changed 35->40 (range -40..87,5)
                                              params.temp_in = parseInt(payload.substr(20, 2), 16) / 2 - 40;        // 2025-08-24 PatrickR68 0.99.111 indoor °C
                                              params.unknown_4 = payload.substr(22,4);
                                              params.humidity = parseInt(payload.substr(26, 2), 16) / 2;            // 2025-08-24 PatrickR68 0.99.111 Humidity in %
                                              params.unknown_5 = payload.substr(28,34);
                                              params.temp_target_in = parseInt(payload.substr(62, 2), 16) / 2 - 40; // 2025-08-24 PatrickR68 0.99.111 indoor target °C
                                              params.unknown_6 = payload.substr(64,2);                              // 2025-08-24 PatrickR68 0.99.111
                                              break;
                                  127
                                  34687
