    4. Probleme mit Mielecloudservice-Adapter [gelöst]
    • mcm1957
      mcm1957 @mkreu last edited by
      @mkreu
      System sieht für mich eigentlich gut aus.
      M mcm1957 2 Replies Last reply Reply Quote 0
        mkreu @mcm1957 last edited by
        @mcm1957 Danke für's Checken...
        JA, wie gesagt, mit der Version 6.5.7 des Adapter funktioniert alles problemlos. Mit den Versionen 6.5.9 und 6.5.10 kommen die besagten Fehler. Hier nochmal der Output als Text:
        2025-08-04 19:03:54.705 - info: host.ct-iobroker01 "system.adapter.mielecloudservice.1" enabled
        2025-08-04 19:03:55.002 - info: host.ct-iobroker01 instance system.adapter.mielecloudservice.1 in version "6.5.10" started with pid 313950
        2025-08-04 19:03:55.721 - info: mielecloudservice.1 (313950) starting. Version 6.5.10 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v20.19.4, js-controller: 7.0.6
        2025-08-04 19:03:55.740 - info: mielecloudservice.1 (313950) Login attempt #1 @Miele-API
        2025-08-04 19:03:56.370 - info: mielecloudservice.1 (313950) Access token expires on: 9/3/2025, 7:03:00 PM
        2025-08-04 19:03:56.370 - info: mielecloudservice.1 (313950) Registering for all appliance events at Miele API.
        2025-08-04 19:03:56.379 - info: mielecloudservice.1 (313950) Initializing SSE watchdog.
        2025-08-04 19:03:56.398 - error: mielecloudservice.1 (313950) uncaught exception: request.headers.split is not a function
        2025-08-04 19:03:56.398 - error: mielecloudservice.1 (313950) TypeError: request.headers.split is not a function
        at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
        at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
        at Channel.publish (node:diagnostics_channel:150:9)
        at new Request (node:internal/deps/undici/undici:2008:27)
        at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
        at Intercept (node:internal/deps/undici/undici:7535:20)
        at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
        at Client.dispatch (node:internal/deps/undici/undici:588:44)
        at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
        at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
        2025-08-04 19:03:56.398 - error: mielecloudservice.1 (313950) request.headers.split is not a function
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: TypeError: request.headers.split is not a function
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
        2025-08-04 19:03:56.455 - error: host.ct-iobroker01 instance system.adapter.mielecloudservice.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2025-08-04 19:03:56.455 - info: host.ct-iobroker01 Restart adapter system.adapter.mielecloudservice.1 because enabled
        2025-08-04 19:04:08.881 - info: host.ct-iobroker01 "system.adapter.mielecloudservice.1" disabled
        Gruß,
        Marko
        • mcm1957
          mcm1957 @mcm1957 last edited by mcm1957
          @apollon77
          @foxriver76
          Wenn einer von euch mal Zeit hat kann er ev. schaun ob da was bei unserem js-controller / sentry Plugin ev.nicht up to date ist?
          Im ERSTEN Posting gibts (leidr nur als Bildchen) einen Crash des Adapters mielcloudservice der im sentry Bereich bei 'undici' crashed.
          EDIT: Fehlermeldung siehe vorhergehenden Post
          Der Fehler wurde wie in einem späteren Posting beschrieben hier https://github.com/getsentry/sentry-javascript/pull/10938/files gefixed.
          Meilecloudservice verwendet das Sentry Plugin. Eine direkte dependency zu sentry ist nicht im Adapter package.json.
          Unklar ist mir warum ein downgrade des Adapters irgendeinen Einfluss haben sollte - das Plugin wird dadurch ja nicht anders / neu installiert.
          Zu klären wär m.E. zuerst mal ob der via Link referenzierte PR schon in der von uns verwendeten Sentry Version drinnen ist. Außerdem ist mir unklar wo undici eigentlich aufgerufen wird. Lt. Adapter package-lock ist es nicht in der dependency Liste des Adapters.
          jessezhang91 created this issue in getsentry/sentry-javascript
          closed fix(node): support undici headers as strings or arrays #10938
            Homoran Global Moderator Administrators @mcm1957 last edited by
            @mcm1957 sagte in Probleme mit Mielecloudservice-Adapter:
            das kommt mir bekannt vor!
            https://forum.iobroker.net/post/1267282
            FernetMenta 1 Reply Last reply Reply Quote 0
            • FernetMenta
              FernetMenta @Homoran last edited by
              @mcm1957 Vielleicht hilft das noch ein wenig. Bei mir läuft 6.5.10. Ich verwende iobroker im docker container. Bei mir fehlt das src directory in /opt/iobroker/node_modules/@sentry
              Andere scheinen den Fehler auch zu haben: https://github.com/Grizzelbee/ioBroker.mielecloudservice/issues/507
              Matt77CHE created this issue in Grizzelbee/ioBroker.mielecloudservice
              open request.headers.split is not a function #507
              • mcm1957
                mcm1957 @FernetMenta last edited by
                @fernetmenta
                Yept das Issue hab ich auch grad gefunden
                Ich glaub immer mehr dass da ein Problem mit dem Sebtry Plugin existiert. Ich hab nur absolut keine Idee warum da bei einer älteren Version des Miele Cloud Adapters nicht auftritt. Und offensichtlich zig andere Adapter auch kein Problem haben ...
                Das sollte ich m.E. @foxriver76 / @Apollon77 ansehen. Ev. kann einer von den beiden zumindest sagen ob ein Issue beim js-controller da was bringt bzw. gewunschen ist.
                • mcm1957
                  @fernetmenta
                  Das aktuelle Senry Plugin ist von Juni 2024. Da könnte der Fix aus dem März schon drinnen sein - oder auch nicht 🙂
                  Kannst du ev mal schaun in welcher Version von sentry-integrations der Fix drinnen ist? Das Plugin installiert ^7.55.2.
                  M FernetMenta 2 Replies Last reply Reply Quote 0
                    Danke schon mal für eure Mühe...
                    Ich verstehe aber gerade gar nix. 😉 Aber ich warte einfach mal...
                    Ist zwar doof mit der alten Version, funktioniert aber.
                    • FernetMenta
                      FernetMenta @mcm1957 last edited by
                      @mcm1957 Das fix ist ab 7.106.0 von 7.3.2024
                      https://github.com/getsentry/publish/issues/3524
                      getsentry-release created this issue in getsentry/publish
                      closed publish: getsentry/sentry-javascript@7.106.0 #3524
                      • mcm1957
                        @mkreu said in Probleme mit Mielecloudservice-Adapter:
                        Ich auch nur zum Teil 🙂
                        Du könntest ev die neuste Version testen aber SENTRY für den Adapter abschalten. Keine Ahnung ob das reicht - aber versuchen kannst es:
                        Sentry Icon anklciken und auf durchgeschrichen umstellen.
                        • mcm1957
                          mcm1957 @FernetMenta last edited by mcm1957
                          @fernetmenta
                          Ok, da fehlen ca 51 Versionen ....
                          @apollon77 @foxriver76
                          Issue bei sentry Plugin erwünscht oder überseh ich da was ?
                          • FernetMenta
                            @mcm1957 komisch, dass ich 7.120.0 in meiner installation habe:
                            rainer@pi-home:~/iobroker-data/node_modules/@sentry/core $ cat package.json
                              "name": "@sentry/core",
                              "version": "7.120.0",
                              "description": "Base implementation for all Sentry JavaScript SDKs",
                              "repository": "git://github.com/getsentry/sentry-javascript.git",
                              "homepage": "https://github.com/getsentry/sentry-javascript/tree/master/packages/core",
                              "author": "Sentry",
                            Wie gesagt, ich verwende iobroker im offiziellen docker container. Ich habe an sentry nie etwas gedreht.
                            • mcm1957
                              @fernetmenta said in Probleme mit Mielecloudservice-Adapter:
                                "author": "Sentry",
                              Das Plugin verlangt ^7.55.2, das heißt jede 7.x.x Version größer als 7.55.2.
                              Bei der Installation wird daher das aktuellste 7.x.x installiert. Ein späterer Update erfolgt nicht automatisch sondern dann wenn ein Adapter eine neuere und kompatible 7.x.x verlangt.
                              Ergo hängt die installierte Version davon ab waszum Zeitpunkt deiner Installation aktuell war.
                              Das ist zumindest mein Verständnisstand des semantic Versionings von node.
                              EDIT / KORREKTUR:
                              Das Plugin verlangt sentry-integrations 7.55.2. Welche core version dies bedingt hab ich noch nicht nachgesehen. Ich hab übersehen dass wir da von 2 unterschiedlichen Komponenten und ihrere Version reden !
                              EDIT2:
                              Lt. package-lock ist auch core 7.55.2 verlangt (= alle sentry componenten haben dieselbe release)
                              @mkreu
                              Kannst du mal schaun was bei dir installiert ist? Command dazu siehe vorposting
                                @mcm1957 Welches Kommando soll ich absetzen? Unter iobroker-data finde ich den Pfad nicht...
                                • FernetMenta
                                  FernetMenta @mkreu last edited by
                                  @mkreu
                                  cat /opt/iobroker/node_modules/@sentry/core/package.json
                                    mkreu @FernetMenta last edited by
                                    danke... 😉
                                    mkreu@ct-iobroker01:~$ cat /opt/iobroker/node_modules/@sentry/core/package.json
                                      "version": "7.91.0",
                                      "author": "Sentry",
                                      "license": "MIT",
                                      "engines": {
                                        "node": ">=8"
                                      "main": "cjs/index.js",
                                      "module": "esm/index.js",
                                      "types": "types/index.d.ts",
                                      "typesVersions": {
                                        "<4.9": {
                                          "types/index.d.ts": [
                                            "types-ts3.8/index.d.ts"
                                      "publishConfig": {
                                        "access": "public"
                                      "dependencies": {
                                        "@sentry/types": "7.91.0",
                                        "@sentry/utils": "7.91.0"
                                      "sideEffects": false
                                    }mkreu@ct-iobroker01:~$
                                    mcm1957 Meister Mopper 2 Replies Last reply Reply Quote 0
                                    • mcm1957
                                      mcm1957 @mkreu last edited by mcm1957
                                      @mkreu
                                      JEP du hast was älteres 🙂
                                      Ich würd sagen da ist ein zentraler Fix angebracht ...
                                      Für heute ists zu spät - werd moregn ein Issue schreiben beim Plugin
                                        @mcm1957 Okay, dann sag mir Bescheid, wenn ich was tun soll. Ich mach aber heute auch Feierabend...
                                        Gruß,
                                        mkreu
                                        • mcm1957
                                          Ich hab das Thema mal als Issue erfasst:
                                          https://github.com/ioBroker/plugin-sentry/issues/271
                                          mcm1957 created this issue in ioBroker/plugin-sentry
                                          open URGENT: Update of sentry dependencies required #271
                                          • Meister Mopper
                                            Meister Mopper @mkreu last edited by
                                            @mkreu
                                            Wenn du beim Adapter sentry deaktivierst, funzt auch die letzte stable Version des Adapters.
                                            (siehe hier)
                                            mcm1957 M 2 Replies Last reply Reply Quote 0
                                            551
