    4. MieleCloudService Adapter
    • Diginix
      Diginix @ChristophsMowL last edited by
      @christophsmowl Ist bei mir wie oben zu sehen aber seit Anfang April nie wieder aufgetreten. Heute habe ich allerdings die WaMa nicht an gehabt. Adapter ist aber grün.
        ChristophsMowL @Diginix last edited by
        @diginix
        Ist nach einigen Minuten auch wieder auf grün gegangen 🤷‍♂️
        • Meister Mopper
          Meister Mopper @Grizzelbee last edited by
          @grizzelbee
          Moin, ich habe heute die v6.5.10 in stable angeboten bekommen, das läuft aber in Fehler:
          mielecloudservice.0	2025-05-02 10:09:35.658	info	starting. Version 6.5.9 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v20.19.1, js-controller: 7.0.6
          mielecloudservice.0	2025-05-02 10:09:35.708	info	Login attempt #1 @Miele-API
          mielecloudservice.0	2025-05-02 10:09:36.177	info	Access token expires on: 1.6.2025, 10:09:00
          mielecloudservice.0	2025-05-02 10:09:36.179	info	Registering for all appliance events at Miele API.
          mielecloudservice.0	2025-05-02 10:09:36.204	info	Initializing SSE watchdog.
          mielecloudservice.0	2025-05-02 10:09:36.263	error	uncaught exception: request.headers.split is not a function
          mielecloudservice.0	2025-05-02 10:09:36.264	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
          mielecloudservice.0	2025-05-02 10:09:36.264	error	request.headers.split is not a function
          host.rpizigbee	2025-05-02 10:09:36.461	error	Caught by controller[0]: TypeError: request.headers.split is not a function
          host.rpizigbee	2025-05-02 10:09:36.462	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
          host.rpizigbee	2025-05-02 10:09:36.462	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
          host.rpizigbee	2025-05-02 10:09:36.462	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
          host.rpizigbee	2025-05-02 10:09:36.462	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
          host.rpizigbee	2025-05-02 10:09:36.463	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
          host.rpizigbee	2025-05-02 10:09:36.463	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
          host.rpizigbee	2025-05-02 10:09:36.463	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
          host.rpizigbee	2025-05-02 10:09:36.463	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
          host.rpizigbee	2025-05-02 10:09:36.463	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
          host.rpizigbee	2025-05-02 10:09:36.463	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
          host.rpizigbee	2025-05-02 10:09:36.463	error	instance system.adapter.mielecloudservice.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          Die v6.5.7 funktioniert nach wie vor.
          • Diginix
            Diginix @Meister Mopper last edited by
            @meister-mopper Dein Log zeigt den Start von v6.5.9 und ansonsten für mein leihenhaftes Auge nur Fehler mit Sentry (/opt/iobroker/node_modules/@sentry/...), nicht aber direkt mit dem Miele Adapter.
            Bei mir lief v6.5.9 und über latest bereits seit 3. April v6.5.10 problemlos.
            • Meister Mopper
              Meister Mopper @Diginix last edited by Meister Mopper
              @diginix
              Ja stimmt, es ist das log des 6.5.9 aber bei v6.5.10 sieht es genau so aus.
              Edit:
              Guter Hinweis
              @diginix sagte in MieleCloudService Adapter:
              Fehler mit Sentry
              Nachdem ich Sentry deaktiviert habe, funktioniert auch die 6.5.10 fehlerfrei.
              Danke!
                jupzup @Meister Mopper last edited by
                @meister-mopper
                Bei mir auch so ich musste Sentry deaktivieren da der Adapter nicht lief und mit Fehlern immer wieder abgestürzt war.
                  Mumpitz last edited by
                  keine Ahnung ob das hier die richtige Stelle ist meine Anfrage zu posten. Falls nicht, dann bitte kurze Info, wie ich es richtig machen würde. 😉
                  Wir haben heute unsere neue Waschmaschine WQ 1000 WPS Nova bekommen und ich habe sie in der Miele App eingerichtet, in der schon ein Miele Trockner eingerichtet war. Hat alles soweit funktioniert.
                  Dann habe ich den MieleCloudService-Adapter neu gestartet, in der Hoffnung, dass er das zusätzliche Gerät findet und in den Objekten die Datenpunkte anzeigt. Aber leider Fehlanzeige. Es sind weiterhin nur die Datenpunkte des Trockners zu sehen.
                  Die Maschine ist noch recht neu und gerade erst erschienen.
                  Kann es sein, dass der MieleCloudService-Adapter erst ein Update braucht? Ich verwende die Version 6.5.10
                  Danke für eure Tipps.
                  Uwe
                    Kiam @Mumpitz last edited by
                    @mumpitz
                    Die derzeit aktuelle Version ist tatsächlich die 6.5.10. Insofern liegt es wahrscheinlich nicht daran...
                    Es ist schon eine Weile her, als ich den WT ins "Netz" genommen habe. Als 1. habe ich die Maschinen ins WLAN eingebunden und in der App eingerichtet. Danach habe ich den Adapter installiert bzw. eine neue API-Client-ID erstellt. Beide Geräte sind unter einer Instanz eingerichtet. Wenn die WM in der Miele-App eingerichtet ist und funktioniert, würde ich den Adapter bzw. die API im iOBroker neu installieren bzw. einrichten. Evtl. muss ein neuer API generiert werden. Die Geräte werden über die Grundeinstellungen in den iOBroker-Adapter eingebunden. Wenn die WM in der App zu finden ist, sollte der Adapter keine Probleme bereiten...
                      Mumpitz @Kiam last edited by
                      @kiam
                      Hallo Kiam,
                      ich habe gerade den Adapter neu installiert. Hat nichts gebracht.
                      Warum sollte eine neue Client-ID helfen? Dann müsste ich mir ja einen neuen Miele-Account mit einer neuen Mailadresse einrichten.
                      Außerdem funktioniert ja der Trockner, auch nach der Neuinstallation des Adapters.
                      Sieht eher so aus, dass eventuell die Miele-API die Maschine noch nicht unterstützt. Ich weiß nicht, wie der Adapter programmiert ist, daher dachte ich, dass es auch am Adapter liegen könnte.
                      Aber danke für deine Antwort. Einen Versuch war's wert... 😉
                      Uwe
                        @mumpitz
                        Kannst Du denn über die App die Maschine steuern? Wenn das nicht geht, könnte es tatsächlich daran liegen , dass die Maaschine "zu neu" ist. Das glaube ich allerdings nicht, da auf der Websiote explizit auf die Steuerung mittels der App hingewiesen wird.
                        Für eine neue API musst Du keinen neuen Account anlegen. Du musst nur in den Grundeinstellungen der Instanz auf "Wenn Sie neue Miele API-Anmeldeinformationen benötigen, klicken Sie bitte hier!" anklicken...
                          @kiam
                          Und dort kann man dann nur auf "Register" klicken, was doch einen neuen Account bedeutet, oder nicht?
                          In der APP habe ich beide Maschinen und beide kann ich steuern.
                          Bist du sicher, dass die APP dieselbe API, wie der Adapter verwendet, ich denke eher nicht. Die App funktioniert meiner Meinung nach auf andere Weise oder mit einer Miele-internen API.
                          Ist aber nur Spekulation.
                            Kiam @Mumpitz last edited by Kiam
                            @mumpitz
                            Ich habe über den o.g. Weg bereits mehrmals eine neue API geholt. Dazu braucht man keinen neuen Account. Du bekommst nur eine neue Client-ID incl. PW.
                            Evtl. hilft es Dir, wenn Du Dir die Hilfe zum Adapter anschaust.
                              @kiam
                              Habe jetzt eine neue Client-ID und den Adapter nochmals neu eingerichtet. Hat aber leider auch keine Änderung gebracht.
                              Wer hat denn den Adapter geschrieben? War das Grizzelbee? Ich denke, er kann das aufklären. 🙂
                              Grizzelbee 1 Reply Last reply Reply Quote 0
                              • mcm1957
                                mcm1957 @jupzup last edited by
                                @jupzup said in MieleCloudService Adapter:
                                @meister-mopper
                                Ja das liegt an der zu alten Sentry version auf deinem System. Leider ist das hier untergegangen bzw. nicht als Problem des Sentry Plugins erfasst worden.
                                Hier gibts jetzt jedenfalls ein Issue dazu
                                https://github.com/ioBroker/plugin-sentry/issues/271
                                Und hoffentlich auch bald den Fix
                                mcm1957 created this issue in ioBroker/plugin-sentry
                                open URGENT: Update of sentry dependencies required #271
                                • Grizzelbee
                                  Grizzelbee Developer @Mumpitz last edited by
                                  @mumpitz sagte in MieleCloudService Adapter:
                                  Ja - der hat den Adapter geschrieben - und kann das vielleicht aufklären.
                                  Grundsätzlich erkennt der Adapter neue Geräte sobald sie in der App eingerichtet werden und bringt sie in den ioBroker - solange er die Device-ID (=Geräteklasse) des Gerätes kennt.
                                  Bei der Miele-API ist es so, dass alle Geräteklassen eine Device-ID haben: https://www.miele.com/developer/assets/API_V1.x.x_capabilities_by_device.pdf
                                  Und jede Geräteklasse hat bestimmte Fähigkeiten - das ist auch zu größten Teil implementiert.
                                  Allerdings hat Miele lt. deren API-News vor kurzem neue Geräteklassen für Trockner, Waschmaschinen und Staubsauger eingeführt:
                                  Und eben die sind, da sie noch nicht veröffentlicht sind, auch noch nicht implementiert.
                                  Ich vermute also mal ganz stark, dass es bei dir um ein sehr neues Modell handelt.
                                  Wenn Du ins Debug-Log schaust, wirst Du eine relativ große JSON finden, die der Adapter von der API bekommen hat. Da stehen die Infos alle drin - und vermutlich eben auch eine Device-ID, die nicht in dem oben verlinkten PDF zu finden ist. Meinetwegen können wir versuchen die neue DeviceID herauszufiltern und wie eine "alte" WaMa einzubinden - oder wir warten auf offizielle Infos von Miele.
                                  viele Grüße
                                  grizzelbee
                                    Mumpitz @Grizzelbee last edited by
                                    @grizzelbee
                                    Hallo Grizzelbee,
                                    danke für die schnelle Antwort.
                                    Ich denke es ist sinnvoller zu warten, bis die offiziellen Infos entsprechend veröffenlicht wurden. Kommt halt drauf an, wieviel Zeit sich Miele mit soetwas lässt. Aber auf ein paar Tage/Wochen hin oder her, kommt es mir nicht an.
                                    Ich wollte eigentlich nur ausschließen, dass ich etwas falsch mache und es eigentlich funktionieren müsste.
                                    Unser Lieferant hat zumindest gesagt, dass sie von dieser Maschine erst eine außer unserer ausgeliefert haben, was ja dann dafür spricht, dass diese Device-ID noch nicht offiziell ist.
                                    Vielen Dank für die Infos
                                    Uwe
                                    FernetMenta 1 Reply Last reply Reply Quote 0
                                    • FernetMenta
                                      FernetMenta @Mumpitz last edited by FernetMenta
                                      @mumpitz Ich würde die Erwartungen sehr weit nach unten schrauben. Ich habe seit Ende letzen Jahres eine neue WaMa und Geschirrspühler. Der Geschirrspüler war ein Drama bzgl IoT und ich habe immer noch einen Support-Case offen, weil die Programmbezeichnungen für einige Programme fehlen (in der API). Ich hatte oft mit denen telefoniert und immer den Eindruck, dass die nicht mal wissen wie man Software schreibt. Ich konnte nie mit einem sprechen, der nur ansatzweise wusste was eine API ist. Miele mag gute Hardware bauen aber von Software haben die leider keine Ahnung.
                                        Mumpitz @FernetMenta last edited by
                                        @fernetmenta
                                        Hallo fernetmenta,
                                        naja, in der Mitteilung steht, dass es im Herbst 2025 aktualisiert werden soll. Ich bin Optimist. 😉
                                        Außerdem funktioniert ja die APP schon mit dem neuen Gerät. Ist also nicht ganz so dramatisch, wenn es etwas dauert.
                                        Da hatte ich mit Bugs bei den Tapo-Plugs schon ganz andere Wartezeiten.
                                          RISSN last edited by
                                          ich habe einen Miele Waschtrockner, der Adapter lieferte mir jetzt bestimmt 2 Jahre immer alles, ich war zufrieden. Seit 2 Wochen kommt nichts mehr, keine Fehler, einfach nichts. Ich habe mal die API Daten (Client ID etc.) erneuert, aber auch ohne Erfolg, in der App sehe ich die WM. Woran kann das noch liegen?
                                          FernetMenta Grizzelbee 2 Replies Last reply Reply Quote 0
                                          • FernetMenta
                                            FernetMenta @RISSN last edited by
                                            @rissn Es liegt höchstwahrscheinlich an Miele. Um ein Problem im Adapter auszuschließen, kannst du die API direkt abfragen: https://www.miele.com/developer/openapi/index.html
                                            mit /short/devices bekommst du deine Device IDs, die du dann in den anderen Aufrufen wie /devices/{deviceId}/state verwenden kannst.
                                            miele mieleathome mielecloudservice
                                            90
                                            851
                                            204183
