    4. mihome vacuum - login failed
      Thomas Braun Most Active @dirkhe last edited by
      @dirkhe
      Da ist auch nicht mehr. get devices geklickt um 20:40:23.105
      2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e09ffffffffffffffffffffffffffffffff
      2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2025-07-24 20:40:18.926  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e13ffffffffffffffffffffffffffffffff
      2025-07-24 20:40:18.927  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2025-07-24 20:40:23.105  - debug: mihome-vacuum.0 (1462) discover__{}
      2025-07-24 20:40:28.930  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e1dffffffffffffffffffffffffffffffff
      2025-07-24 20:40:28.931  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2025-07-24 20:40:38.934  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e27ffffffffffffffffffffffffffffffff
      2025-07-24 20:40:38.935  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        @dirkhe
        Ah! Nochmal neugestartet, jetzt funktioniert es!
          @dirkhe
          Hi!
          Die Version aus 'latest' funktioniert nicht:
          2025-07-25 11:52:30.448  - info: mihome-vacuum.0 (59185) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v24.4.1, js-controller: 7.0.7
          2025-07-25 11:53:41.089  - debug: mihome-vacuum.0 (59185) CloudApi-Login gestartet…
          2025-07-25 11:53:41.090  - debug: mihome-vacuum.0 (59185) CloudApi-CloudApi-Step 1: Getting sign token
          2025-07-25 11:53:41.229  - debug: mihome-vacuum.0 (59185) CloudApi-Step 2: Authenticating user
          2025-07-25 11:53:41.327  - error: mihome-vacuum.0 (59185) CloudApi-Login failed, because no captcha resolving possible
          2025-07-25 11:53:41.328  - info: mihome-vacuum.0 (59185) discover Login failed, because no captcha resolving possible
            dirkhe Developer @Thomas Braun last edited by
            @thomas-braun tja, sieht so aus, als wenn jetzt ganz viele Anfragen über diesen Weg gekommen sind, so dass der Server da jetzt die captcha Frage stellt. Ich fürchte, da können wir jetzt nichts machen, zumindest habe ich keine Idee mehr
            • bahnuhr
              bahnuhr Forum Testing Most Active @dirkhe last edited by
              @dirkhe sagte in mihome vacuum - login failed:
              Danke für die Info.
              Vielleicht kann ja jemand helfen?
              @apollon77
              @mcm1957
              Ich meine hier schon mal gelesen zu haben, dass jemand captcha im Adapter schon umgesetzt hatte.
              Weiß aber nicht mehr wo und wer.
              mfg
              Dieter
              • bahnuhr
                zur Info:
                @apollon77 hat im issue geantwortet.
                Anbei:
                • bahnuhr
                  bahnuhr Forum Testing Most Active @bahnuhr last edited by bahnuhr
                  @bahnuhr sagte in mihome vacuum - login failed:
                  Jetzt weiß ich es wieder.
                  War beim bmw Adapter.
                  Vielleicht geht ja sowas hier auch.
                  • bahnuhr
                    im issue wurde vermerkt, dass wohl oauth2 angesagt ist.
                    Jetzt muss dies "nur" noch umgesetzt werden.
                    Anbei nochmal link zum issue (wer nachlesen möchte).
                    https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/1063
                    gmtjan created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                    closed ERROR: Login failed #1063
                    • bahnuhr
                      Rückinfo von mir:
                      Nach Neustart von iob und dann halt auch der Adapter kommt im log:
                      mihome-vacuum.0
                      2025-08-01 16:23:39.601	info	IOT disabled, delete state
                      mihome-vacuum.0
                      2025-08-01 16:23:39.521	info	starting. Version 5.2.0 (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.19.4, js-controller: 7.0.6
                      Folglich; der Adapter wird nicht mehr grün und funktioniert bei mir nun gar nicht mehr.
                      • Eduard77
                        Eduard77 @dirkhe last edited by
                        @dirkhe
                        nun hat jetzt auch micht erwischt.
                        Ich habe 2 Instanzen.
                        Die Instanz 1 mit Roborock S5 funktioniert noch.
                        Bei der 2. mit Roborock Q8 habe ich gerade festgestellt, dass die Karte seit letzter Woche nicht mehr aktualiesiert wird.
                        Nach dem ich die Roborock Q8 Instanz neu gestartet habe, bekomme ich folgendes im LOG.
                        mihome-vacuum.1 2025-08-06 14:12:04.767	info	Got terminate signal TERMINATE_YOURSELF
                        mihome-vacuum.1 2025-08-06 14:11:52.128	info	discover Login failed
                        mihome-vacuum.1 2025-08-06 14:11:38.127	info	discover Login failed
                        mihome-vacuum.1 2025-08-06 14:10:51.788	info	discover Login failed
                        mihome-vacuum.1 2025-08-06 14:10:17.767	info	discover Login failed
                        mihome-vacuum.1 2025-08-06 14:09:27.868	info	create state for carpet_mode
                        mihome-vacuum.1 2025-08-06 14:09:27.093	info	create states for dust collecting
                        mihome-vacuum.1 2025-08-06 14:09:27.091	info	create states for dock status
                        mihome-vacuum.1 2025-08-06 14:09:27.048	info	create states for mop mode
                        mihome-vacuum.1 2025-08-06 14:09:27.035	info	change states from State control.fan_power mihome-vacuum.1.rooms.161001076339.roomFanPower
                        mihome-vacuum.1 2025-08-06 14:09:27.035	info	change states from State control.fan_power mihome-vacuum.1.rooms.161001076338.roomFanPower
                        mihome-vacuum.1 2025-08-06 14:09:27.034	info	change states from State control.fan_power mihome-vacuum.1.rooms.161001022185.roomFanPower
                        mihome-vacuum.1 2025-08-06 14:09:27.034	info	change states from State control.fan_power mihome-vacuum.1.rooms.161001003117.roomFanPower
                        mihome-vacuum.1 2025-08-06 14:09:27.015	info	create states for water box mode
                        mihome-vacuum.1 2025-08-06 14:09:27.012	info	create states for water box
                        mihome-vacuum.1 2025-08-06 14:09:27.011	info	change states from State control.fan_power
                        mihome-vacuum.1 2025-08-06 14:09:27.010	info	create states for mop
                        mihome-vacuum.1 2025-08-06 14:09:26.818	warn	Login failed
                        mihome-vacuum.1 2025-08-06 14:09:24.934	info	settest next timer: not available
                        mihome-vacuum.1 2025-08-06 14:09:24.369	info	select standard vacuum protocol....
                        mihome-vacuum.1 2025-08-06 14:09:24.245	info	IOT disabled, delete state
                        mihome-vacuum.1 2025-08-06 14:09:24.180	info	starting. Version 5.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.19.4, js-controller: 7.0.6
                        mihome-vacuum.1 2025-08-06 14:09:19.302	info	terminating
                        mihome-vacuum.1 2025-08-06 14:09:18.801	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        mihome-vacuum.1 2025-08-06 14:09:18.801	info	terminating
                        mihome-vacuum.1 2025-08-06 14:09:18.801	error	Socket Close
                        Interessanter weise, obwohl die instanz Login Fehler anzeigt, kann ich den Q8 steuern/starten.
                        Eduard
                          dirkhe Developer last edited by
                          @eduard77 solange du den token hast, ist alles gut. Nur die karte geht halt nicht
                            schneidy76 @dirkhe last edited by
                            @dirkhe Von mir als Hinweis:
                            Man kann sich den Token mit dem Tool aus git holen.
                            Bei mir, Windows 11, gab es hier aber richtig Probleme mit dem Tool.
                            Es wird von Windows als "potentiell gefährlich" eingestuft. Dies bedeutet, einmal gestartet, dann -trotz Erlaubnis nicht ausgeführt und gelöscht. Danach kann man es nicht mehr so einfach downloaden.
                            Ich habe es vor! dem Ausführen dann hinbekommen, die Datei als "sicher" zu kennzeichnen.
                            In Folge lies es sich ausführen. Mit den Daten konnte ich nun auch den Roboter wieder über ioBroker steuern...
                            VG Torsten
                            • bahnuhr
                              @dirkhe
                              hat auf git
                              mitgeteilt, dass er den Umbau auf oauto2 nicht vornehmen wird.
                              Schade auch, damit ist der super Adapter nur mit dem Tool (token holen) lauffähig.
                              Die Karte wird zukünftig nicht mehr funktionieren.
                              Äußerst schade.
                              • mcm1957
                                mcm1957 last edited by
                                Dazu wäre allerdings zu ergänzen, dass auch @Apollon77 festgehalten hat dass hier eine Umstellung auf oauth2 nicht sinnvoll gehen wird, da kein bekanntes Verfahren existiert mit dem das Captcha handling implementiert werden kann. Es macht lt. Apollon77 derzeit keinen Sinn hier Aufwand für oath2 zu setzen. Und persönlich glaube ich, dass Apollon77 ein wenig Erfahrung angesammelt hat 🙂
                                Insofern führt dies zwar zum selben Ergebnis aber die zukünftigen Einschränkungen sind nach derzeitigem Wissensstan nicht auf Unwillen von @Dirkhe zurückzuführen wie es im Vorposting möglicherweise durchklingen könnte.
                                Abgesehen davon steht es jedermann/frau frei einen PR beizusteuern falls jemand eine Lösung hat.
                                login mihome vacuum
                                1225
