    4. Shelly Adapter - genereller Support
      Mico last edited by Mico
      Hallo alle zusammen ich habe mehrere Windows Bues und auch Motion Blu im Einsatz die Scripte zum Empfang sind auf den Shellys 1pm plus in der Version 1 und der Adapter in der Vers. 10.1
      Nun bekomme ich bei dem Motion Blu diesesn Fehler gemeldet.
      und im Log des Iobrokers findet sich unter warn dieser eintrag
      025-08-06 17:49:52.380 - info: zigbee2mqtt.1 (154496) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Büro', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.66,"energy":43.31,"indicator_mode":"off/on","linkquality":156,"power":127,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"voltage":229}'
      2025-08-06 17:49:55.167 - warn: shelly.0 (51201) [Mqtt.statusNotifications] 192.168.178.118 (shellyplus1pm / shellyplus1pm-cc7b5c820c00 / shellyplus1pm#cc7b5c820c00#1): "General Status Notifications" are disabled (see adapter documentation for details)
      2025-08-06 17:49:56.121 - info: zigbee2mqtt.1 (154496) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SNZB-02 Bad', payload '{"battery":100,"humidity":79.44,"linkquality":87,"temperature":19.22,"voltage":3000}'
      2025-08-06 17:49:59.359 - info: zigbee2mqtt.1 (154496) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Büro', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.66,"energy":43.31,"indicator_mode":"off/on","linkquality":156,"power":115,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"voltage":229}'
      2025-08-06 17:49:59.856 - info: zigbee2mqtt.1 (154496) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Fernseherleiste', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.51,"energy":38.92,"indicator_mode":"off/on","linkquality":29,"power":97,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"voltage":231}'
      2025-08-06 17:50:03.166 - info: zigbee2mqtt.1 (154496) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Außendoppelsteckdose', payload '{"child_lock":"UNLOCK","current":0,"energy":8.48,"indicator_mode":"off/on","linkquality":109,"power":0,"power_outage_memory_l1":"restore","state_l1":"OFF","state_l2":"OFF","update":{"installed_version":69,"latest_version":69,"state":"idle"},"voltage":231}'
      2025-08-06 17:50:03.168 - info: zigbee2mqtt.1 (154496) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Garten', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.04,"energy":11.03,"indicator_mode":"off/on","linkquality":109,"power":5,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"voltage":232}'
      und bei dem Windows Blu bekomme ich zum Teil dieses angezeigt.
      wie schaffe ich es das das Script wieder Fehlerfrei funktioniert.
      Mico
      • mcm1957
        mcm1957 last edited by mcm1957
        @mico
        Installier das aktuelle script. Der Fehler mit 'unpackedData' stammt aus einer fehlerhaften Version.
        Kannst di Zeile 'console log ...' auch einfach löschen.
        https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/v10.0.0/docs/en/ble-devices.md#javascript-shelly-scripting
        Siehe auch:
        https://forum.iobroker.net/topic/80722/test-adapter-shelly-10-1-0-latest-beta/22
        @Homoran
        Bitte an den shelly support topic anhängen
        https://forum.iobroker.net/topic/81297/shelly-adapter-genereller-support
          Mico @mcm1957 last edited by
          @mcm1957
          Ich habe ja die Version 1.0 des Scriptes installiert, jetzt nochmals per Steuerung und C kopiert und eingefügt. leider immer noch dieser Fehler
          Also Shelkly Instanz ist 10.1 Bluetooth ist enable und Script zum Ausführen ist V 1.0
          • haus-automatisierung
            haus-automatisierung Developer Most Active @Mico last edited by
            @mico sagte in Shelly BLus zum Teil mit Fehler im Auto-Script:
            Ja, die Zeile wurde entfernt, ohne dass die Script-Version angepasst wurde. Daher existieren leider gerade 2 verschiedene 1.0 Versionen. Am besten die aus dem 10.1.0 Tag nehmen:
            https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/v10.1.0/docs/en/ble-devices.md
            • Andreios
              Andreios Forum Testing @Peter V. last edited by Andreios
              @peter-v sagte in Test Adapter shelly - ALPHA Versionen:
              Shelly 1PM Mini Gen3 : 1.6.2
              Genau davon habe ich den ersten verbaut und über MQTT angeschlossen, funktioniert aber leider nicht.
              mqtt Adapter Version ist 6.1.2
              shelly Adapter Version ist 10.1.0
              Der taucht unter mqtt.0.shellies.shelly1pm.... und unter mqtt.0.shelly1pm.... auf, jedoch mit fast keinen Datenpunkten.
              U.a. ist das der Datenpunkt ...status.switch:0 dabei, wenn ich diesen jedoch mit einem Schalter verbinde, funktioniert sowohl die Zustandsanzeige, als auch das Schalten nicht.
              mqtt-Daten habe ich geprüft, Port etc. auch andere Möglichkeiten, die ich hier im Thread gefunden habe.
              Andere, ältere, Shelly funktionieren, teilweise über CoAP, aber auch über mqtt.
              Hat veilleicht jemand noch eine Idee, wo ich suchen kann?
              Danke!
              crunchip mcm1957 2 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @Andreios last edited by
                @andreios sagte in Test Adapter shelly - ALPHA Versionen:
                Mqtt oder shelly Adapter, beides geht nicht
                Andreios 1 Reply Last reply Reply Quote 0
                • Andreios
                  Andreios Forum Testing @crunchip last edited by
                  @crunchip sagte in Test Adapter shelly - ALPHA Versionen:
                  Das würde ja bedeuten, dass der Teil der alten Shellys nicht mehr funktioniert, der über CoAP angebunden ist.
                  Eigentlich sollte es ja nur darauf ankommen, wohin der jeweilige Shelly sich verbindet, oder?
                  Ich habe die Shelly-Instanz einmal gestoppt, das hat aber keine Änderung gebracht.
                    crunchip Forum Testing Most Active @Andreios last edited by crunchip
                    Doku lesen
                    Solltest du beide Adapter in Verwendung haben, wäre üblicherweise
                    Mqtt Adapter port 1883
                    Shelly Adapter port 1882
                    Entsprechend In den shelly Geräten auch so hinterlegen.
                    Gen1 shelly Geräte entweder in einer separaten shelly Instanz laufen lassen oder ebenfalls auf mqtt umstellen.
                    Solltest du shelly Geräte mit dem mqtt Adapter nutzen, musst du die Steuerdatenpunkte manuell anlegen.
                      saugimanni last edited by saugimanni
                      ich habe nicht weiter gesucht, ob es zu diesem Problem schon ein Thema gibt, aber möchte einmal meine Lösung des Problems schildern, um eventuell einigen anderen Leuten, die das selbe Problem haben eine mögliche Lösung aufzuzeigen.
                      Hier mein Problem:
                      Shelly Adapter 8.4
                      Ich habe ca. 60 verschiedene Shellys im Einsatz aus allen Herstellungsjahren ( bin von Anfang an dabei ).
                      Bisher gab es wenig Probleme, aber seit meinem Umzug des IoBrokers auf einen neuen Mini PC und Proxmox 9 in einen LXC Container hatte ich das Problem, dass eine große Anzahl der Shellys in regelmaßigen Abständen ( ca. 1 Minute ) kurz die Verbindung zum Adapter verloren haben ( für ca. 2 Sekunden ) und sich die Schalter in den Shellys ausgeschalten haben .
                      Dies hatte ich ich in all den Jahren nicht und konnte es mir nicht erklären , vor allen Dingen das selbsttätige Ausschalten der Schalter . Ob dies mit dem Adapter etwas zu tun haben könnte, weiß ich nicht. Dazu bin ich zu "unwissend".
                      Nach Durchforschen der Logs ist mir aufgefallen, dass sich diese Shellys im Rhytmus von ca 1 Minute eine neue Timezone suchten . Sie haben auch nicht Berlin gefunden, sondern Helsinki oder Brüssel eingeloggt und es war ein anderer SNTP Server eingetragen.
                      Nach diversen Tests habe ich dieses Prozedere als Ursache der Abbrüche "diagnostiziert" .
                      Daraufhin habe ich alle Shellys der älteren Generationen auf Hand umgestellt, die Timezone auf Berlin umgestellt und den SNTP Server umbenannt: time.google.com sowie die Geozone angepasst .
                      Bei den neuen Geräten habe ich dies so gelassen :
                      Seit dieser Umstellung ( 2 Tage - ist noch nicht lange, ich weiß ) funktioniert alles wieder super, alle Shellys sind dauerhaft online und die Automation funktioniert wieder ohne Probleme .
                      Vielleicht kann ich damit einigen helfen.
                      Gruß Saugimann
                      haus-automatisierung da_Woody 2 Replies Last reply Reply Quote 0
                        haus-automatisierung Developer Most Active @saugimanni last edited by
                        @saugimanni sagte in Shelly Adapterproblem mit MQTT:
                        Shelly Adapter 8.4
                        Bitte auf die letzt stable gehen. 8.4 ist von Okt 2024
                        mcm1957 da_Woody 2 Replies Last reply Reply Quote 1
                        • mcm1957
                          mcm1957 @haus-automatisierung last edited by mcm1957
                          @Homoran
                          Bitte Shelly Adapter - genereller Support anhängen
                          • mcm1957
                            mcm1957 @crunchip last edited by mcm1957
                            @Homoran
                            Da die Frage absolut nichts mit alpha Versionen zu tun hat bitte Beiträge ab gestern an Shelly Adapter - henereller Support anhängen
                            Sollte ab da sein wenn ich mit hand richtog klicke
                            https://forum.iobroker.net/topic/80649/test-adapter-shelly-alpha-versionen/125
                              Homoran Global Moderator Administrators @mcm1957 last edited by
                              @mcm1957 done!
                                @mcm1957 dito
                                • da_Woody
                                  da_Woody @saugimanni last edited by
                                  @saugimanni abgesehn davon, daß du schwer veraltest bist, hat du deine shelly nicht richtig konfiguriert.
                                  desweiteren denke ich, daß du noch immer auf mcast unterwegs bist.
                                  ip deines ioB, save, der port wird automatisch angehängt.
                                  auch das liegt an der config des schelly!
                                  • da_Woody
                                    da_Woody @haus-automatisierung last edited by
                                    @haus-automatisierung sagte in Shelly Adapter - genereller Support:
                                    naja, bin auf 10.1.0 ohne probleme.
                                    wie in dem post an @saugimanni glaub ich eher an falsche config...
                                    • mcm1957
                                      mcm1957 @Andreios last edited by mcm1957
                                      @andreios said in Shelly Adapter - genereller Support:
                                      ist irrelevant wenn du den shelly Adapter verwenden willst.
                                      ok
                                      Wenn der nur beim mqtt Adapter auftaucht hast du im Shely den fslschen Port eingestellt.
                                      Die Shelly Instanz muss einen anderen mqtt Port haben als der mqtt AAdapter. 2 Adapterinstanzen am selben Port sind technisch nicht möglich. Je nachdem welchen Port du am Shelly eingetragen hast redet der Shelly mit dem mqtt Adapter oder dem Shelly Adapter.
                                      Setze zum Testen Werte direkt im Admin UI.
                                      Dann poste bitte mal
                                      • screenshot der Mqtt Einstellubgen des Shellies
                                      • screenshot der Mqtt Eindtellungen der Shelly Instant
                                      Coap benutz zwingend eine andere Shelly Instanz. Spielt hier also nicht mit.
                                      Hat veilleicht jemand noch eine Idee, wo ich suchen kann.
                                      • port einstellungen prüfen
                                      • screenshots der Einstellungen am Shelly u der Indtanzconfig posten
                                      • logfile posten
                                        saugimanni @da_Woody last edited by saugimanni
                                        @da_woody
                                        Sorry für die späte Antworten, war ein paar Tage unterwegs.
                                        • die Schalterconfig stand auf " letze Stellung "
                                        • Enable CoIoT hatte ich bei allen abgewählt und nur MQTT aktiviert
                                        Was hat es mit dieser Einstellung auf sich ? Ich dachte, dass dies nur aktiviert werden muss,
                                        wenn kein MQTT verwendet wird.
                                        Bis heute läuft alles super .
                                        Gruß Saugimanni
                                        • Horst Böttcher
                                          Horst Böttcher last edited by
                                          Ich habe Shellys über mqtt eingebunden es ging auch eine weile aber auf einmal sind sie angeblich offline obwol sie online sind
                                          Ich mutze den
                                          mcm1957 crunchip 2 Replies Last reply Reply Quote 0
                                          • mcm1957
                                            mcm1957 @Horst Böttcher last edited by mcm1957
                                            @horst-böttcher
                                            Der Online status wird durch anpingen der Shellies ermittelt. Check bitte ob die entsprechenden Shellies VOM IOBROKER System aus anpingbar sind bzw via http erreichbar sind.
                                            EDIT:
                                            Benutzt du irgendeine Art Firewall in deinem Netzwerk?
                                            Hast du verschiedene Netzwerksegmente?
                                            Hängen die Shellies alle im gleichen WLAN?
                                            @Homoran
                                            Bitte an den allgemeinen Shelly Topic anhängen.
                                            Horst Böttcher 1 Reply Last reply Reply Quote 1
                                            mcm1957 shelly
                                            35
                                            232
                                            15348
