    4. 1-Wire - LinkUSB - IoBroker
      Homoran Global Moderator Administrators @Majorkamy last edited by
      @majorkamy warum dafür 2 Threads?
        Majorkamy @Thomas Braun last edited by Homoran
        @thomas-braun said in 1-Wire - LinkUSB - IoBroker:
        systemctl status owserver.service
        Das kommt für den owserver
        majorkamy@NuC:/$ sudo service owserver restart
        [sudo] Passwort für majorkamy:
        Job for owserver.service failed because the control process exited with error code.
        See "systemctl status owserver.service" and "journalctl -xeu owserver.service" for details.
        majorkamy@NuC:/$ systemctl status owserver.service
        × owserver.service - Backend server for 1-wire control
             Loaded: loaded (/usr/lib/systemd/system/owserver.service; enabled; preset: enabled)
             Active: failed (Result: exit-code) since Sat 2025-08-09 18:43:57 CEST; 12s ago
           Duration: 2h 9min 55.516s
        TriggeredBy: × owserver.socket
               Docs: man:owserver(1)
            Process: 32323 ExecStart=/usr/bin/owserver --foreground -c /etc/owfs.conf (code=exited, status=1/FAILURE)
           Main PID: 32323 (code=exited, status=1/FAILURE)
                CPU: 18ms
        Aug 09 18:43:57 NuC systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5.
        Aug 09 18:43:57 NuC systemd[1]: owserver.service: Start request repeated too quickly.
        Aug 09 18:43:57 NuC systemd[1]: owserver.service: Failed with result 'exit-code'.
        Aug 09 18:43:57 NuC systemd[1]: Failed to start owserver.service - Backend server for 1-wire control.
        und folgendes für den owhttpd
        majorkamy@NuC:/$ sudo service owhttpd restart
        Job for owhttpd.service failed because the control process exited with error code.
        See "systemctl status owhttpd.service" and "journalctl -xeu owhttpd.service" for details.
        majorkamy@NuC:/$ systemctl status owhttpd.service
        × owhttpd.service - Tiny webserver for 1-wire control
             Loaded: loaded (/usr/lib/systemd/system/owhttpd.service; enabled; preset: enabled)
             Active: failed (Result: exit-code) since Sat 2025-08-09 18:46:13 CEST; 8s ago
           Duration: 2h 9min 56.356s
               Docs: man:owhttpd(1)
            Process: 32595 ExecStart=/usr/bin/owhttpd --foreground -c /etc/owfs.conf (code=exited, status=1/FAILURE)
           Main PID: 32595 (code=exited, status=1/FAILURE)
                CPU: 19ms
        Aug 09 18:46:08 NuC systemd[1]: Starting owhttpd.service - Tiny webserver for 1-wire control...
        Aug 09 18:46:13 NuC owhttpd[32595]: DEFAULT: owlib.c:(52) No valid 1-wire buses found
        Aug 09 18:46:13 NuC systemd[1]: owhttpd.service: Main process exited, code=exited, status=1/FAILURE
        Aug 09 18:46:13 NuC systemd[1]: owhttpd.service: Failed with result 'exit-code'.
        Aug 09 18:46:13 NuC systemd[1]: Failed to start owhttpd.service - Tiny webserver for 1-wire control.
        MOD-EDIT: Code in code-tags gesetzt und formatiert
        M Thomas Braun 2 Replies Last reply Reply Quote 0
          Majorkamy @Majorkamy last edited by
          @majorkamy
          Achso
          3 x usb aktuell:
          • Mouse+key board angeschlossen (Es ist keine virtuelle Maschine)
          • MBUS
          • USB Hub mit 2xLINKUSB für 1-Wire
          @ Homoran
          Ich wollte den 1 Wire Adapter thematisch trennen, damit später auch andere die Informationen finden können.
            Thomas Braun Most Active @Majorkamy last edited by Thomas Braun
            @majorkamy sagte in 1-Wire - LinkUSB - IoBroker:
            Ich denke da ist in der Einrichtungsdatei was nicht richtig definiert.
            cat /etc/owfs.conf
            sagt?
              Das ist auch meine Vermutung, oder bedarf es einer speziellen Zuuordnung bzgl LINKUSB?
              # Sample configuration file for the OWFS suite for Debian GNU/Linux.
              # This is the main OWFS configuration file. You should read the
              # owfs.conf(5) manual page in order to understand the options listed
              # here.
              ######################## SOURCES ########################
              # With this setup, any client (but owserver) uses owserver on the
              # local machine...
              ! server: server = localhost:4304
              # ...and owserver uses the real hardware, by default fake devices
              # This part must be changed on real installation
              #server: FAKE = DS18S20,DS2405
              # USB device: DS9490
              server: usb = all
              # Serial port: DS9097
              #server: device = /dev/ttyS1
              # owserver tcp address
              #server: server = 192.168.10.1:3131
              # random simulated device
              ######################### OWFS ##########################
              #mountpoint = /mnt/1wire
              #allow_other
              ####################### OWHTTPD #########################
              http: port = 2121
              ####################### OWFTPD ##########################
              ftp: port = 2120
              ####################### OWSERVER ########################
              server: port = localhost:4304
                @majorkamy
                Ich vermute (habe kein 1W am Start), die Zeile 22 sollte so aussehen:
                server: device = /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A7009I1K-if00-port0
                (Oder eine der beiden anderen Gerätedateien. Hängt davon ab, welches Gerät denn nun konkret was ist.
                  Danke Thomas
                  Das hat schonmal geholfen. Die ersten 11 Sensoren sind sichtbar
                  server: usb = all
                  ggfs muss ich noch mal an der Device Art usw. spielen
                  Laut Iobroker müssen es eigentlich 43 sein
                  Erkennen tut er jedoch nur die 11 im OWFS und auch nur deren Daten erscheinen im IoBroker
                  Wenn wer noch eine Idee hat, wäre ich dankbar.
                  Thomas Braun M 2 Replies Last reply Reply Quote 0
                    Mal versucht das so einzutragen:
                    server: device = /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03X1WM-if00-port0
                    server: device = /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907T26T-if00-port0
                    Keine Ahnung ob oder wie man da mehrere Server eintragen kann.
                      @majorkamy
                      Hallo, ich habe nun alle Signal wieder im System
                      Ich habe mich nochmal durch diverse Quellen gehangelt
                      Folgendes zusätzliche Device Zuordnung war nötig.
                      Verstanden habe ich es jedoch leider nicht.
                      #server: usb = all
                      server: device = /dev/ttyUSB0
                      Thema kann dann jedoch geschlossen werden.
                      Nun heißt es nur noch die VIS wiederherstellen....
                        @majorkamy
                        Statt /dev/ttyUSB0 würde ich da den entsprechenden Link 'by-id' setzen.
                        Findet man so heraus:
                        echad@chet:~ $ ls -l /dev/serial/by-id/
                        total 0
                        lrwxrwxrwx 1 root root 13 Aug  1 01:13 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                        echad@chet:~ $
                        Bei mir wäre da also statt besser
                        /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 einzutragen.
                        Hintergrund: /dev/tttyXYZ kann sich immer mal ändern, je nachdem welches Gerät gerade schneller gefunden wird oder gerade in welchem USB-Port steckt.
                          Verstanden, ist umgesetzt.
                          204
