    4. Simple + Vis Api startet nicht
      Majorkamy @Thomas Braun last edited by
      ja den js-controller@4.0.24 habe ich eingelesen, da dies beim erstmaligen einlesen des Bacups gefordert wurde.
      Ebenfalls tauchte vis@1.4.16 auf
      Zunächst hat auch die knx instanze nur eingelsen,konnte jdeoch nicht beschrieben werden. Dies geht allerdings mittlerweile.
      iob log:
      ========== Start marking the full check here ===========
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: NuC
             Icon name: computer-desktop
               Chassis: desktop 🖥️
      Operating System: Ubuntu 24.04.2 LTS
                Kernel: Linux 6.14.0-27-generic
          Architecture: x86-64
       Hardware Vendor: Intel_R_ Client Systems
        Hardware Model: NUC8i3BEK
      Firmware Version: BECFL357.86A.0089.2021.0621.1343
         Firmware Date: Mon 2021-06-21
          Firmware Age: 4y 1month 2w
      OS is similar to: debian
      model name	: Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       14:26:29 up 3 days, 16:14,  1 user,  load average: 0.48, 0.30, 0.17
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Ubuntu LTS release codenamed 'noble'!
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-08-04 14:26:29 CEST
                 Universal time: Mon 2025-08-04 12:26:29 UTC
                       RTC time: Mon 2025-08-04 12:26:29
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      majorkamy
      HOME=/home/majorkamy
      GROUPS=majorkamy adm cdrom sudo dip plugdev users lpadmin iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth redis
      *** DISPLAY-SERVER SETUP ***
      Display-Server: true
      Desktop: 	ubuntu
      Terminal: 	wayland
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.2G        5.4G        222M        913M        2.8G        2.8G
      Swap:           4.3G        663M        3.6G
      Total:           12G        6.1G        3.9G
      Active iob-Instances: 	21
               7812 M total memory
               5177 M used memory
               3722 M active memory
               2896 M inactive memory
                211 M free memory
                 94 M buffer memory
               2607 M swap cache
               4095 M total swap
                632 M used swap
               3463 M free swap
      top - 14:26:29 up 3 days, 16:14,  1 user,  load average: 0.48, 0.30, 0.17
      Tasks: 285 total,   1 running, 284 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.1 us,  4.3 sy,  0.0 ni, 91.5 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7812.0 total,    211.8 free,   5177.5 used,   2701.6 buff/cache
      MiB Swap:   4096.0 total,   3463.5 free,    632.5 used.   2634.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      tmpfs          tmpfs     782M  2.2M  780M   1% /run
      /dev/sda2      ext4      233G   16G  206G   8% /
      tmpfs          tmpfs     3.9G  4.0K  3.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
      efivarfs       efivarfs  192K   98K   90K  53% /sys/firmware/efi/efivars
      /dev/sda1      vfat      1.1G  6.2M  1.1G   1% /boot/efi
      tmpfs          tmpfs     782M  2.6M  779M   1% /run/user/1000
      [Thu Jul 31 22:11:35 2025] EXT4-fs (sda2): mounted filesystem de750efa-dbcb-4f60-8b7a-643d5ae5e7de ro with ordered data mode. Quota mode: none.
      [Thu Jul 31 22:11:35 2025] EXT4-fs (sda2): re-mounted de750efa-dbcb-4f60-8b7a-643d5ae5e7de r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                SOURCE      FSTYPE      OPTIONS
      /                                     /dev/sda2   ext4        rw,relatime
      |-/run/user/1000/doc                  portal      fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |-/snap/bare/5                        /dev/loop0  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/core22/2045                   /dev/loop1  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/firefox/5751                  /dev/loop2  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/firmware-updater/167          /dev/loop3  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/gnome-42-2204/202             /dev/loop5  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/core22/1748                   /dev/loop4  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/gtk-common-themes/1535        /dev/loop6  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/snap-store/1248               /dev/loop7  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/snapd/23545                   /dev/loop9  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/snapd-desktop-integration/253 /dev/loop10 squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/boot/efi                           /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
      |-/snap/snapd/24792                   /dev/loop8  squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/snap-store/1270               /dev/loop12 squashfs    ro,nodev,relatime,errors=continue,threads=single
      |-/snap/snapd-desktop-integration/315 /dev/loop11 squashfs    ro,nodev,relatime,errors=continue,threads=single
      `-/snap/firefox/6565                  /dev/loop13 squashfs    ro,nodev,relatime,errors=continue,threads=single
      /var:
      2.3G	/var/
      1.9G	/var/lib
      1.4G	/var/lib/snapd
      1007M	/var/lib/snapd/seed/snaps
      Archived and active journals take up 60.6M in the file system.
      /opt/iobroker/backups:
      146M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      155M	/opt/iobroker/iobroker-data/
      124M	/opt/iobroker/iobroker-data/files
      58M	/opt/iobroker/iobroker-data/files/vis.0
      47M	/opt/iobroker/iobroker-data/files/admin.admin
      46M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      26M	/opt/iobroker/iobroker-data/objects.jsonl
      15M	/opt/iobroker/iobroker-data/files/vis.0/HOME_FHD/vis-views.json
      9.7M	/opt/iobroker/iobroker-data/files/vis.0/HOME/vis-views.json
      8.6M	/opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
      5.3M	/opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.19.4
      /usr/bin/node 		v20.19.4
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.32.0
      nodejs:
        Installed: 20.19.4-1nodesource1
        Candidate: 20.19.4-1nodesource1
        Version table:
       *** 20.19.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.19.3-1nodesource1 1001
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.1+dfsg-6ubuntu5 500
              500 http://de.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      NuC                 NuC (version: 4.0.24, hostname: NuC           , alive, uptime: 10186)
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.7.2
      javascript: 	7.1.4
      nodejs modules from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : NuC                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : NuC                                      -  enabled
      + system.adapter.backitup.0               : backitup              : NuC                                      -  enabled
        system.adapter.consumption.0            : consumption           : NuC                                      -  enabled
        system.adapter.daswetter.0              : daswetter             : NuC                                      -  enabled
        system.adapter.devices.0                : devices               : NuC                                      - disabled
        system.adapter.echarts.0                : echarts               : NuC                                      - disabled
      + system.adapter.ekey.0                   : ekey                  : NuC                                      -  enabled, port: 56000, bind: 0.0.0.0
      + system.adapter.email.0                  : email                 : NuC                                      - disabled
        system.adapter.flot.0                   : flot                  : NuC                                      - disabled
      + system.adapter.history.0                : history               : NuC                                      - disabled
      + system.adapter.hm-rega.0                : hm-rega               : NuC                                      -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : NuC                                      -  enabled, port: 12001
      + system.adapter.hm-rpc.1                 : hm-rpc                : NuC                                      -  enabled, port: 12010
      + system.adapter.hue-extended.0           : hue                   : NuC                                      -  enabled, port: 443
      + system.adapter.hue.0                    : hue                   : NuC                                      -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : NuC                                      - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : NuC                                      - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NuC                                      - disabled
      + system.adapter.javascript.0             : javascript            : NuC                                      -  enabled
      + system.adapter.javascript.1             : javascript            : NuC                                      -  enabled
      + system.adapter.knx.0                    : knx                   : NuC                                      -  enabled, bind: 10.1.10.160
      + system.adapter.link.0                   : link                  : NuC                                      - disabled
        system.adapter.material.0               : material              : NuC                                      - disabled
      + system.adapter.mbus.0                   : mbus                  : NuC                                      -  enabled, port: 3493
      + system.adapter.owfs.0                   : owfs                  : NuC                                      -  enabled, port: 4304
      + system.adapter.parser.0                 : parser                : NuC                                      -  enabled
        system.adapter.proxy.0                  : proxy                 : NuC                                      - disabled
      + system.adapter.scenes.0                 : scenes                : NuC                                      -  enabled
        system.adapter.simple-api.0             : simple-api            : NuC                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : NuC                                      - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sql.0                    : sql                   : NuC                                      - disabled, port: 1
        system.adapter.vis-bars.0               : vis                   : NuC                                      - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : NuC                                      - disabled
        system.adapter.vis-fancyswitch.0        : vis                   : NuC                                      - disabled
        system.adapter.vis-google-fonts.0       : vis                   : NuC                                      -  enabled
        system.adapter.vis-history.0            : vis                   : NuC                                      - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NuC                                      - disabled
        system.adapter.vis-jqui-mfd.0           : vis                   : NuC                                      - disabled
        system.adapter.vis-justgage.0           : vis                   : NuC                                      - disabled
        system.adapter.vis-map.0                : vis                   : NuC                                      - disabled
        system.adapter.vis-material.0           : vis                   : NuC                                      - disabled
        system.adapter.vis-metro.0              : vis                   : NuC                                      - disabled
        system.adapter.vis-rgraph.0             : vis                   : NuC                                      - disabled
        system.adapter.vis-sip-asterisk.0       : vis                   : NuC                                      - disabled
        system.adapter.vis-sip.0                : vis                   : NuC                                      - disabled
        system.adapter.vis-special-charts.0     : vis                   : NuC                                      - disabled
        system.adapter.vis-timeandweather.0     : vis                   : NuC                                      - disabled
        system.adapter.vis.0                    : vis                   : NuC                                      -  enabled
      + system.adapter.web.0                    : web                   : NuC                                      - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yr.0                     : yr                    : NuC                                      - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Adapters
      Used repository: beta
      Adapter    "admin"        : 7.7.2    , installed 6.7.2  [Updatable]
      Adapter    "alarm"        : 3.7.2    , installed 3.3.13 [Updatable]
      Adapter    "backitup"     : 3.3.5    , installed 2.8.1  [Updatable]
      Adapter    "consumption"  : 1.0.2    , installed 1.0.2
      Adapter    "daswetter"    : 3.2.3    , installed 3.1.10 [Updatable]
      Adapter    "devices"      : 1.2.8    , installed 1.1.5  [Updatable]
      Adapter    "echarts"      : 2.0.6    , installed 1.5.4  [Updatable]
      Adapter    "ekey"         : 1.2.3    , installed 1.2.3
      Adapter    "email"        : 2.0.4    , installed 1.2.1  [Updatable]
      Adapter    "history"      : 3.0.1    , installed 3.0.0  [Updatable]
      Adapter    "hm-rega"      : 5.1.0    , installed 4.0.0  [Updatable]
      Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.19 [Updatable]
      Adapter    "hue"          : 3.16.2   , installed 3.10.0 [Updatable]
      Adapter    "ical"         : 1.16.2   , installed 1.13.3 [Updatable]
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
      Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
      Adapter    "javascript"   : 9.0.11   , installed 7.1.4  [Updatable]
      Controller "js-controller": 7.0.7    , installed 4.0.24 [Updatable]
      Adapter    "knx"          : 2.0.33   , installed 1.0.44 [Updatable]
      Adapter    "link"         : 0.5.12   , installed 0.5.12
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mbus"         : 2.7.0    , installed 2.5.0  [Updatable]
      Adapter    "owfs"         : 0.7.0    , installed 0.7.0
      Adapter    "parser"       : 2.3.1    , installed 2.0.5  [Updatable]
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "scenes"       : 4.0.3    , installed 2.3.9  [Updatable]
      Adapter    "simple-api"   : 3.0.7    , installed 2.7.2  [Updatable]
      Adapter    "socketio"     : 7.0.8    , installed 6.5.5  [Updatable]
      Adapter    "sql"          : 3.0.1    , installed 2.2.0  [Updatable]
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
      Adapter    "web"          : 7.0.9    , installed 6.1.2  [Updatable]
      Adapter    "ws"           : 3.0.19   , installed 2.5.5  [Updatable]
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects: 	15035
      States: 	13088
      Hit:1 https://linux.teamviewer.com/deb stable InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu noble InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
      Hit:6 http://security.ubuntu.com/ubuntu noble-security InRelease
      Reading package lists...
      Pending Updates: 124
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      991        7668       676/systemd-resolve
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4276       1/init
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      124        10052      1140/redis-server 1
      tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          14059      1646/teamviewerd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          353442     38811/cupsd
      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      991        7670       676/systemd-resolve
      tcp        0      0 10.1.10.160:12010       0.0.0.0:*               LISTEN      1001       425949     49280/io.hm-rpc.1
      tcp        0      0 10.1.10.160:12001       0.0.0.0:*               LISTEN      1001       427921     49412/io.hm-rpc.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          4278       1/init
      tcp6       0      0 ::1:6379                :::*                    LISTEN      124        10053      1140/redis-server 1
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       424951     48954/io.admin.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          353441     38811/cupsd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9714       875/avahi-daemon: r
      udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1001       428559     49747/io.ekey.0
      udp        0      0 10.1.10.160:56134       0.0.0.0:*                           1001       430100     49508/io.knx.0
      udp        0      0 0.0.0.0:52639           0.0.0.0:*                           108        9716       875/avahi-daemon: r
      udp        0      0 127.0.0.54:53           0.0.0.0:*                           991        7669       676/systemd-resolve
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           991        7667       676/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4277       1/init
      udp6       0      0 :::5353                 :::*                                108        9715       875/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          4279       1/init
      udp6       0      0 :::57507                :::*                                108        9717       875/avahi-daemon: r
      2025-08-04 14:26:22.925  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.8CB5AA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.8CB5AA030000/temperature'
      2025-08-04 14:26:22.925  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.ECEAAA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.ECEAAA030000/temperature'
      2025-08-04 14:26:31.958  - info: knx.0 (49508) State value to set for "knx.0.Sonstiges.Energie.Energiezähler_Allgemein_-_Wirkleistung_P__(W)" has to be type "number" but received type "string"
      2025-08-04 14:26:32.850  - warn: parser.0 (58114) Cannot read link "https://www.onvista.de/": AxiosError: Request failed with status code 403
      2025-08-04 14:26:37.539  - info: knx.0 (49508) State value to set for "knx.0.Sensorik.OG.Kind_Ost_PM_schalten" has to be type "boolean" but received type "number"
      2025-08-04 14:26:37.925  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.D35EC3030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.D35EC3030000/temperature'
      2025-08-04 14:26:37.925  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.8CB5AA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.8CB5AA030000/temperature'
      2025-08-04 14:26:37.925  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.ECEAAA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.ECEAAA030000/temperature'
      2025-08-04 14:26:42.843  - warn: parser.0 (58114) Cannot read link "https://www.onvista.de/": AxiosError: Request failed with status code 403
      2025-08-04 14:26:42.845  - warn: parser.0 (58114) Cannot read link "https://www.onvista.de/": AxiosError: Request failed with status code 403
      2025-08-04 14:26:45.561  - info: knx.0 (49508) State value to set for "knx.0.Sonstiges.Energie.Energiezähler_Waermepumpe_-_Blindleistung_(var)" has to be type "number" but received type "string"
      2025-08-04 14:26:51.359  - info: knx.0 (49508) State value to set for "knx.0.Sensorik.KG.Büro_PM_schalten" has to be type "boolean" but received type "number"
      2025-08-04 14:26:52.753  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.DF55C3030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.DF55C3030000/temperature'
      2025-08-04 14:26:52.753  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/10.F9FB0D030800/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/10.F9FB0D030800/temperature'
      2025-08-04 14:26:52.844  - warn: parser.0 (58114) Cannot read link "https://www.onvista.de/": AxiosError: Request failed with status code 403
      2025-08-04 14:26:52.927  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.D35EC3030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.D35EC3030000/temperature'
      2025-08-04 14:26:52.927  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.8CB5AA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.8CB5AA030000/temperature'
      2025-08-04 14:26:52.927  - info: owfs.0 (49461) Cannot read value of /mnt/1wire/28.ECEAAA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.ECEAAA030000/temperature'
      2025-08-04 14:26:53.361  - info: knx.0 (49508) State value to set for "knx.0.Sonstiges.Energie.Energiezähler_Allgemein_-_Blindleistung_(var)" has to be type "number" but received type "string"
      2025-08-04 14:26:54.397  - info: knx.0 (49508) State value to set for "knx.0.Sensorik.OG.Kind_Ost_PM_schalten" has to be type "boolean" but received type "number"
      iob diag has finished.
        Thomas Braun Most Active @Majorkamy last edited by Thomas Braun
        @majorkamy
        Dann musst du das Zeug jetzt unisono auf einen aktuellen Stand bringen.
        Beim OS angefangen, denn da stehen
        in der Pipeline.
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Dann würde ich empfehlen, die Kiste OHNE Desktop und Teamviewer und so einem Schmonzes zu betreiben. Server immer ohne den ganzen Overhead.
        Kann man u. a. mit dem
        iob fix
        umstellen.
        Wenn die Basis sauber ist:
        Zuvor aus dem Beta-Testing aussteigen und das stable-Repo scharf schalten.
        iob repo unset beta
        iob repo set stable
        Dann
        iob update
        iob stop
        iob upgrade self
        iob update
        iob upgrade all -y
        Und dann final nochmal per
        iob diag
        drüberschauen, ob das alles dann richtig eingestellt ist.
        [Edit: Zuvor aus dem Beta-Testing aussteigen und das stable-Repo scharf schalten. (s.o.)
          Vielen Dank soweit. Die Simple Api läuft soweit wieder durch das updaten der Instanzen.
          Vis leider gar nicht.
          Zusätzlich ist mir nun aufgefallen, dass auch noch 1-Wire Sensoren über einen LinkUSB angeschlossen sind. Diese Werte bekomme ich auch noch nicht wieder rein.
          Ich mache dazu ein neues Thema auf, da ich hierzu noch nichts vollständiges gefunden habe. OWFS habe ich installiert, allerdings fehlt noch der korrekte Link zum Linkusb.
          Bei der Vis, die komplex aufgebaut war fehlt mir noch das Verständnis.
          Die Umsetzung hat etwas nun gedauert, da ich mir einen zweiten Rechner besorgt habe. -> Sicherheit + zukünftig einen Backup.
          Der Status ist nun bei Beiden gleich. Jeweil ein NUCi3BEK.
          Script v.2025-03-08
          *** BASE SYSTEM ***
                   Chassis: desktop 🖥️
          Operating System: Ubuntu 24.04.3 LTS
              Firmware Age: 4y 1month 2w 5d
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           16:49:37 up  1:52,  1 user,  load average: 1.40, 1.36, 1.29
          CPU threads: 4
                         Local time: Sat 2025-08-09 16:49:37 CEST
                     Universal time: Sat 2025-08-09 14:49:37 UTC
                           RTC time: Sat 2025-08-09 14:49:37
                        NTP service: active
                    RTC in local TZ: no
          majorkamy
          iobroker
          HOME=/home/iobroker
          Desktop: 	ubuntu
          Terminal: 	wayland
          *** MEMORY ***
          Mem:            8.2G        6.1G        220M        1.2G        2.4G        2.1G
          Swap:           4.3G        2.6G        1.7G
          Total:           12G        8.7G        1.9G
          Active iob-Instances: 	25
                   7812 M total memory
                   5808 M used memory
                   4408 M active memory
                   2304 M inactive memory
                    209 M free memory
                     31 M buffer memory
                   2228 M swap cache
                   4095 M total swap
                   2474 M used swap
                   1621 M free swap
          top - 16:49:38 up  1:52,  1 user,  load average: 1.40, 1.36, 1.29
          Tasks: 310 total,   1 running, 309 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  4.1 us,  4.1 sy,  0.0 ni, 89.8 id,  2.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7812.0 total,    209.7 free,   5808.2 used,   2260.3 buff/cache
          MiB Swap:   4096.0 total,   1621.9 free,   2474.1 used.   2003.8 avail Mem
            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
          * owftpd.service  loaded failed failed Anonymous FTP server for 1-wire access
          * owserver.socket loaded failed failed Listening socket for owserver
          Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                  ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                  SUB    -> The low-level unit activation state, values depend on unit type.
          2 loaded units listed.
          *** FILESYSTEM ***
          /dev/sda2      ext4      233G   18G  204G   8% /
          [Sat Aug  9 14:57:03 2025] EXT4-fs (sda2): mounted filesystem de750efa-dbcb-4f60-8b7a-643d5ae5e7de ro with ordered data mode. Quota mode: none.
          [Sat Aug  9 14:57:04 2025] EXT4-fs (sda2): re-mounted de750efa-dbcb-4f60-8b7a-643d5ae5e7de r/w. Quota mode: none.
          |-/run/owfs                           OWFS        fuse.OWFS   rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/snap/core22/1748                   /dev/loop1  squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/core22/2045                   /dev/loop2  squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/firefox/5751                  /dev/loop3  squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/firmware-updater/167          /dev/loop4  squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/firefox/6565                  /dev/loop6  squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/gtk-common-themes/1535        /dev/loop7  squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/snap-store/1248               /dev/loop8  squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/snap-store/1270               /dev/loop9  squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/snapd/23545                   /dev/loop10 squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/snapd/24792                   /dev/loop11 squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/snapd-desktop-integration/253 /dev/loop13 squashfs    ro,nodev,relatime,errors=continue,threads=single
          |-/snap/snapd-desktop-integration/315 /dev/loop12 squashfs    ro,nodev,relatime,errors=continue,threads=single
          `-/mnt/1wire                          OWFS        fuse.OWFS   rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          2.5G	/var/
          1.9G	/var/lib
          1.4G	/var/lib/snapd
          Archived and active journals take up 137.5M in the file system.
          260M	/opt/iobroker/backups/
          USB-Devices by-id:
          /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A7009I1K-if00-port0
          /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03X1WM-if00-port0
          /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907T26T-if00-port0
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: redis
          States  type: redis
          Hosts:
          NuC                 NuC (version: 7.0.6, hostname: NuC           , alive, uptime: 6752)
          js-controller: 	7.0.6
          admin: 		7.6.17
          javascript: 	8.9.2
          Adapter State
          + system.adapter.consumption.0            : consumption           : NuC                                      -  enabled
            system.adapter.knx.1                    : knx                   : NuC                                      - disabled, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : NuC                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.socketio.0               : socketio              : NuC                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sql.0                    : sql                   : NuC                                      -  enabled, port: 1
          + instance is alive
          Active repo(s): stable
          Upgrade policy: none
          Used repository: stable
          Adapter    "admin"        : 7.6.17   , installed 7.6.17
          Adapter    "alarm"        : 3.7.0    , installed 3.7.0
          Adapter    "backitup"     : 3.3.5    , installed 3.3.5
          Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "email"        : 2.0.4    , installed 2.0.4
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "hue"          : 3.16.1   , installed 3.16.1
          Adapter    "ical"         : 1.16.2   , installed 1.16.2
          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "knx"          : 2.0.30   , installed 2.0.30
          Adapter    "mbus"         : 2.7.0    , installed 2.7.0
          Adapter    "parser"       : 2.2.4    , installed 2.2.4
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 7.0.8
          Adapter    "sql"          : 3.0.1    , installed 3.0.1
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects: 	15086
          States: 	13124
          Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
          Hit:3 https://linux.teamviewer.com/deb stable InRelease
          Hit:4 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          491        1/init
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      991        9180       705/systemd-resolve
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      124        13235      1230/redis-server 1
          tcp        0      0 0.0.0.0:33947           0.0.0.0:*               LISTEN      1001       22705      4595/owserver
          tcp        0      0 10.1.10.160:12001       0.0.0.0:*               LISTEN      1001       19764      2903/io.hm-rpc.0
          tcp        0      0 10.1.10.160:12010       0.0.0.0:*               LISTEN      1001       21160      3872/io.hm-rpc.1
          tcp        0      0 0.0.0.0:2121            0.0.0.0:*               LISTEN      125        136438     15330/owhttpd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          10222      1228/cupsd
          tcp        0      0 127.0.0.1:4304          0.0.0.0:*               LISTEN      0          136389     15286/owserver
          tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      991        9182       705/systemd-resolve
          tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          14852      1656/teamviewerd
          tcp6       0      0 :::111                  :::*                    LISTEN      0          493        1/init
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          10221      1228/cupsd
          tcp6       0      0 ::1:6379                :::*                    LISTEN      124        13236      1230/redis-server 1
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21761      4083/io.simple-api.
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21873      4271/io.socketio.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17019      1878/io.admin.0
          udp        0      0 10.1.10.160:48805       0.0.0.0:*                           1001       33561      3960/io.knx.0
          udp        0      0 127.0.0.54:53           0.0.0.0:*                           991        9181       705/systemd-resolve
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           991        9179       705/systemd-resolve
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          492        1/init
          udp        0      0 10.1.10.160:49856       0.0.0.0:*                           1001       21216      3960/io.knx.0
          udp        0      0 0.0.0.0:38064           0.0.0.0:*                           108        10634      762/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10632      762/avahi-daemon: r
          udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1001       22609      4426/io.ekey.0
          udp6       0      0 :::111                  :::*                                0          494        1/init
          udp6       0      0 :::41214                :::*                                108        10635      762/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        10633      762/avahi-daemon: r
          2025-08-09 16:49:45.621  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.9CE0AA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.9CE0AA030000/temperature'
          2025-08-09 16:49:45.622  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.DCD621060000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.DCD621060000/temperature'
          2025-08-09 16:49:45.622  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.92F7AA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.92F7AA030000/temperature'
          2025-08-09 16:49:45.623  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.25BF23060000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.25BF23060000/temperature'
          2025-08-09 16:49:45.623  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.95D0AA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.95D0AA030000/temperature'
          2025-08-09 16:49:45.624  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.EDA822060000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.EDA822060000/temperature'
          2025-08-09 16:49:45.624  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.D3CDAA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.D3CDAA030000/temperature'
          2025-08-09 16:49:45.625  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.A748C3030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.A748C3030000/temperature'
          2025-08-09 16:49:52.114  - error: sql.0 (2396) Error: connect ECONNREFUSED 127.0.0.1:1
          2025-08-09 16:49:55.683  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.DF55C3030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.DF55C3030000/temperature'
          2025-08-09 16:49:55.683  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/10.F9FB0D030800/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/10.F9FB0D030800/temperature'
          2025-08-09 16:49:59.707  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.D35EC3030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.D35EC3030000/temperature'
          2025-08-09 16:49:59.708  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.8CB5AA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.8CB5AA030000/temperature'
          2025-08-09 16:49:59.709  - info: owfs.0 (3639) Cannot read value of /mnt/1wire/28.ECEAAA030000/temperature: Error: ENOENT: no such file or directory, open '/mnt/1wire/28.ECEAAA030000/temperature'
          2025-08-09 16:50:00.003  - info: javascript.0 (2428) script.js.Startup.Check_ob_OneWire_Daten_liefert: OWFS = keine Daten
          2025-08-09 16:50:00.004  - info: javascript.1 (2493) script.js.Sonstiges.RSS_NTV_-_Überschrift: RSS-Feed https://www.n-tv.de/rss eingelesen
          2025-08-09 16:50:00.015  - info: javascript.1 (2493) script.js.Sonstiges.RSS_Google: RSS-Feed https://news.google.com/news/rss/?ned=de&gl=DE&hl=de eingelesen
          2025-08-09 16:50:00.018  - info: javascript.1 (2493) script.js.Sonstiges.RSS_Welt: RSS-Feed https://www.welt.de/feeds/latest.rss eingelesen
          2025-08-09 16:50:00.022  - info: javascript.1 (2493) script.js.Sonstiges.RSS_Google_Bruchsal: RSS-Feed https://news.google.com/news/rss/local?hl=de&gl=DE&ned=de eingelesen
          2025-08-09 16:50:00.025  - info: javascript.1 (2493) script.js.Sonstiges.RSS_NTV_neu: RSS-Feed https://www.n-tv.de/rss eingelesen
          2025-08-09 16:50:00.028  - info: javascript.1 (2493) script.js.Sonstiges.RSS_Bild: RSS-Feed http://www.bild.de/rssfeeds/vw-news/vw-news-16726644,sort=1,view=rss2.bild.xml eingelesen
          2025-08-09 16:50:00.029  - info: javascript.1 (2493) script.js.Sonstiges.RSS_TV-Spielfilm: RSS-Feed http://www.tvspielfilm.de/tv-programm/rss/tipps.xml eingelesen
          2025-08-09 16:50:00.029  - info: javascript.1 (2493) script.js.Sonstiges.RSS_NTVWirtschaft: RSS-Feed https://www.n-tv.de/wirtschaft/rss eingelesen
          2025-08-09 16:50:00.428  - error: javascript.1 (2493) script.js.Sonstiges.RSS_Bild: null
          2025-08-09 16:50:02.087  - info: knx.0 (3960) State value to set for "knx.0.Sensorik.OG.OG_Kind_West_-_Multisensor_-_Präsenzausgang" has to be type "boolean" but received type "number"
            @majorkamy sagte in Simple + Vis Api startet nicht:
            Schalt den Display-Mumpitz aus. Oder hängt ein Monitor für die vis direkt an dem Rechner?
            1Wire kann nicht laufen, der Dienst startet nicht:
            • owftpd.service loaded failed failed Anonymous FTP server for 1-wire access
            • owserver.socket loaded failed failed Listening socket for owserver
            vis läuft auch nicht.
            iob enable web
            iob start vis
            sagt?
              Majorkamy @Thomas Braun last edited by Homoran
              majorkamy@NuC:/$ iobroker enable web
              iobroker [command]
              Commands:
                iobroker setup                                               Setup ioBroker
                iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                iobroker info                                                Shows the host info
                iobroker logs [<adapter>]                                    Monitor log
                iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                iobroker rebuild [<module>]                                  Rebuild all native modules or path
                iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
                iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                iobroker update [<repositoryUrl>]                            Update repository and list adapters
                iobroker upgrade                                             Upgrade management
                iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                iobroker object                                              Object management  [aliases: o]
                iobroker state                                               State management  [aliases: s]
                iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                iobroker list <type> [<filter>]                              List all entries, like objects
                iobroker chmod <mode> <file>                                 Change file rights
                iobroker chown <user> <group> <file>                         Change file ownership
                iobroker touch <file>                                        Touch file
                iobroker rm <file>                                           Remove file
                iobroker file                                                File management
                iobroker user                                                User commands
                iobroker group                                               group management
                iobroker host <hostname>                                     Set host to given hostname
                iobroker set <adapter>.<instance>                            Change settings of adapter config
                iobroker license <license.file or license.text>              Update license by given file
                iobroker cert                                                Certificate management
                iobroker clean <yes>                                         Clears all objects and states
                iobroker backup                                              Create backup
                iobroker restore <backup name or path>                       Restore a specified backup
                iobroker validate <backup name or path>                      Validate a specified backup
                iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                iobroker repo                                                Show repo information
                iobroker uuid                                                Show uuid of the installation  [aliases: id]
                iobroker unsetup                                             Reset license, installation secret and language
                iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
                iobroker multihost                                           Multihost management
                iobroker compact                                             compact group management
                iobroker plugin                                              Plugin management
                iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
              Options:
                --help  Show help  [boolean]
              majorkamy@NuC:/$ iobroker start vis
              majorkamy@NuC:/$
              Es erscheint kein sichtbarer Fehler aber die Vis bleibt inaktiv.
              und nein ich habe keinen direkten Monitor dran.
              Die Visualisierung lief bzw soll auch wieder über einen RasperiPi über einen Kioskbrowser und Touchbildschirm laufen.
              Soll ich es über iob fix deaktivieren?
                Und wohin soll dann der Desktop leuchten?
                Reine sinnlose Verschwendung, die alles nur unnötig verkompliziert und die Verwaltung aufwändiger macht.
                Mach das Ding aus und bedien den Server über die Kommandozeile. Oder die WebFrontends der einzelnen Dienste.
                  Hallo ich habe es aktuell noch nicht abgeschaltet, da ich bis alles läuft noch einen Monitor angeschlossen habe.
                  Nun zur nicht funktionierenden VIS.
                  Weder die Runtime noch der Editor öffnen sich.
                  Adapter Übersicht:
                  Er verweist, ständig auf 1.4.16
                  Log Files
                  2025-08-11T12_00_01_241Z-debug-0.log 2025-08-11T12_00_09_838Z-debug-0.log 2025-08-11T12_00_14_511Z-debug-0.log 2025-08-11T12_00_19_475Z-debug-0.log 2025-08-11T12_00_24_390Z-debug-0.log 2025-08-11T12_00_29_111Z-debug-0.log 2025-08-11T12_00_33_982Z-debug-0.log 2025-08-11T12_00_40_074Z-debug-0.log 2025-08-11T12_00_49_556Z-debug-0.log 2025-08-11T12_01_02_108Z-debug-0.log 2025-08-11T12_01_11_370Z-debug-0.log
                  Log Auszug
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]: TypeError: _0x577a56[_0x28a911(...)] is not a constructor
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at _0x4f7dc4 (/opt/iobroker/node_modules/iobroker.link/main.js:1:50238)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.link/main.js:1:55604)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.link/main.js:1:55635)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at 9../lib/access-server-client (/opt/iobroker/node_modules/iobroker.link/main.js:1:55662)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at _0x2ec651 (/opt/iobroker/node_modules/iobroker.link/main.js:1:1746)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at _0x53eb29 (/opt/iobroker/node_modules/iobroker.link/main.js:1:2125)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.link/main.js:1:2195)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1529:14)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1275:32)
                  2025-08-11 13:55:22.581  - error: host.NUC Caught by controller[1]: Node.js v20.19.4
                  2025-08-11 13:55:22.581  - info: host.NUC instance system.adapter.link.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2025-08-11 13:55:22.603  - info: host.NUC instance system.adapter.parser.0 terminated with code 0 (NO_ERROR)
                  2025-08-11 13:55:22.618  - info: host.NUC instance system.adapter.consumption.0 terminated with code 0 (NO_ERROR)
                  2025-08-11 13:55:22.628  - info: host.NUC stopInstance timeout system.adapter.owfs.0 killing pid 2607
                  2025-08-11 13:55:22.630  - info: host.NUC stopInstance timeout system.adapter.web.0 killing pid 3393
                  2025-08-11 13:55:22.651  - warn: host.NUC instance system.adapter.web.0 terminated due to SIGKILL
                  2025-08-11 13:55:22.652  - info: host.NUC instance system.adapter.web.0 terminated with code null ()
                  2025-08-11 13:55:22.652  - info: host.NUC All instances are stopped.
                  2025-08-11 13:55:22.655  - info: host.NUC terminated
                  2025-08-11 13:55:36.122  - info: host.NUC iobroker.js-controller version 7.0.6 js-controller starting
                  2025-08-11 13:55:36.124  - info: host.NUC Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                  2025-08-11 13:55:36.125  - info: host.NUC hostname: NUC, node: v20.19.4
                  2025-08-11 13:55:36.125  - info: host.NUC ip addresses: 10.1.10.160 fdc5:a05b:6438:8f10:d985:3dbe:7c73:dd9b fdc5:a05b:6438:8f10:315b:e9f0:f6d9:7cb5 fe80::2c40:21b2:2e24:35d6 10.1.10.100 fdc5:a05b:6438:8f10:c558:5109:79f6:35cc fdc5:a05b:6438:8f10:7538:1c33:8bb6:1bfb fe80::4034:c8e7:18fa:e9ea
                  2025-08-11 13:55:36.217  - info: host.NUC connected to Objects and States
                  2025-08-11 13:55:36.224  - info: host.NUC added notifications configuration of host
                  2025-08-11 13:55:36.266  - warn: host.NUC No configuration found for scope "databaseErrors" and category "system"
                  2025-08-11 13:55:36.296  - info: host.NUC 51 instances found
                  2025-08-11 13:55:36.316  - info: host.NUC starting 28 instances
                  2025-08-11 13:55:36.318  - warn: host.NUC startInstance cannot find adapter "vis-bars@1.4.16". Try to install it... 1 attempt
                  2025-08-11 13:55:36.318  - info: host.NUC iobroker install vis-bars@1.4.16 using installedVersion
                  2025-08-11 13:55:36.695  - info: host.NUC instance system.adapter.admin.0 in version "7.6.17" started with pid 10962
                  2025-08-11 13:55:36.711  - info: host.NUC Delete state "system.host.NUC.versions.npmNewestNext"
                  2025-08-11 13:55:36.716  - info: host.NUC Delete state "system.host.NUC.versions.nodeNewest"
                  2025-08-11 13:55:36.717  - info: host.NUC Delete state "system.host.NUC.versions.npmNewest"
                  2025-08-11 13:55:36.719  - info: host.NUC Delete state "system.host.NUC.versions.nodeCurrent"
                  2025-08-11 13:55:36.720  - info: host.NUC Delete state "system.host.NUC.versions.npmCurrent"
                  2025-08-11 13:55:36.722  - info: host.NUC Delete state "system.host.NUC.versions.nodeNewestNext"
                  2025-08-11 13:55:36.723  - info: host.NUC Some obsolete host states deleted.
                  2025-08-11 13:55:37.413  - info: host.NUC iobroker npm-install: NPM version: 10.8.2
                  2025-08-11 13:55:37.414  - info: host.NUC iobroker npm-install: Installing iobroker.vis-bars@1.4.16... (System call)
                  2025-08-11 13:55:37.683  - info: admin.0 (10962) starting. Version 7.6.17 in /opt/iobroker/node_modules/iobroker.admin, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:55:37.702  - info: admin.0 (10962) requesting all objects
                  2025-08-11 13:55:38.775  - info: admin.0 (10962) received all objects
                  2025-08-11 13:55:38.838  - info: admin.0 (10962) socket.io server listening on port 8081
                  2025-08-11 13:55:38.839  - info: admin.0 (10962) http server listening on port 8081
                  2025-08-11 13:55:38.840  - info: admin.0 (10962) Use link "http://127.0.0.1:8081" to configure.
                  2025-08-11 13:55:40.571  - info: host.NUC instance system.adapter.sql.0 in version "3.0.1" started with pid 11030
                  2025-08-11 13:55:41.248  - info: sql.0 (11030) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.sql, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:55:41.304  - error: sql.0 (11030) Error: connect ECONNREFUSED 127.0.0.1:3306
                  2025-08-11 13:55:41.464  - error: host.NUC iobroker npm-install: npm error code ETARGETnpm error notarget No matching version found for iobroker.vis-bars@1.4.16.npm error notarget In most cases you or one of your dependencies are requestingnpm error notarget a package version that doesn't exist.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-11T11_55_37_504Z-debug-0.log
                  2025-08-11 13:55:41.465  - error: host.NUC iobroker npm-install: host.NUC Cannot install iobroker.vis-bars@1.4.16: 1
                  2025-08-11 13:55:42.261  - info: admin.0 (10962) ==> Connected system.user.admin from ::ffff:10.1.10.160
                  2025-08-11 13:55:42.489  - info: host.NUC iobroker npm-install: exit 25
                  2025-08-11 13:55:43.490  - warn: host.NUC startInstance cannot find adapter "vis-history@1.4.16". Try to install it... 1 attempt
                  2025-08-11 13:55:43.491  - info: host.NUC iobroker install vis-history@1.4.16 using installedVersion
                  2025-08-11 13:55:44.467  - info: host.NUC iobroker npm-install: NPM version: 10.8.2Installing iobroker.vis-history@1.4.16... (System call)
                  2025-08-11 13:55:44.497  - info: host.NUC instance system.adapter.scenes.0 in version "3.2.3" started with pid 11085
                  2025-08-11 13:55:45.044  - debug: scenes.0 (11085) Redis Objects: Use Redis connection: 127.0.0.1:6379
                  2025-08-11 13:55:45.059  - debug: scenes.0 (11085) Objects client ready ... initialize now
                  2025-08-11 13:55:45.060  - debug: scenes.0 (11085) Objects create System PubSub Client
                  2025-08-11 13:55:45.061  - debug: scenes.0 (11085) Objects create User PubSub Client
                  2025-08-11 13:55:45.114  - debug: scenes.0 (11085) Objects client initialize lua scripts
                  2025-08-11 13:55:45.116  - debug: scenes.0 (11085) Objects connected to redis: 127.0.0.1:6379
                  2025-08-11 13:55:45.122  - debug: scenes.0 (11085) Redis States: Use Redis connection: 127.0.0.1:6379
                  2025-08-11 13:55:45.125  - debug: scenes.0 (11085) States create System PubSub Client
                  2025-08-11 13:55:45.125  - debug: scenes.0 (11085) States create User PubSub Client
                  2025-08-11 13:55:45.132  - debug: scenes.0 (11085) States connected to redis: 127.0.0.1:6379
                  2025-08-11 13:55:45.145  - debug: scenes.0 (11085) Plugin sentry Do not initialize Plugin (enabled=false)
                  2025-08-11 13:55:45.166  - info: scenes.0 (11085) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.scenes, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:55:45.226  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Bad_Jalousie_Nord_groß_Position
                  2025-08-11 13:55:45.235  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Bad_Jalousie_Nord_groß_Lamelle_Position
                  2025-08-11 13:55:45.238  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Bad_Jalousie_Nord_klein_Lamelle_Position
                  2025-08-11 13:55:45.243  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Bad_Jalousie_Nord_klein_Position
                  2025-08-11 13:55:45.244  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Bad_Jalousie_West_Lamelle_Position
                  2025-08-11 13:55:45.245  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Bad_Jalousie_West_Position
                  2025-08-11 13:55:45.246  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Empore_Jalousie_Lamelle_Position
                  2025-08-11 13:55:45.247  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Empore_Jalousie_Position
                  2025-08-11 13:55:45.248  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Kind_Ost_Jalousie_Süd_Lamelle_Position
                  2025-08-11 13:55:45.249  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Kind_Ost_Jalousie_Süd_Position
                  2025-08-11 13:55:45.250  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Kind_Ost_Rolladen_Ost_Position
                  2025-08-11 13:55:45.251  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Kind_West_Jalousie_Süd_Lamelle_Position
                  2025-08-11 13:55:45.252  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Kind_West_Jalousie_Süd_Position
                  2025-08-11 13:55:45.253  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Kind_West_Jalousie_West_Lamelle_Position
                  2025-08-11 13:55:45.254  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Kind_West_Jalousie_West_Position
                  2025-08-11 13:55:45.254  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Schlafen_Jalousie_Nord_Position
                  2025-08-11 13:55:45.255  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Schlafen_Jalousie_Nord_Lamelle_Position
                  2025-08-11 13:55:45.255  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.OG.Schlafen_Rolladen_Ost_Position
                  2025-08-11 13:55:45.256  - debug: scenes.0 (11085) initScenes: subscribe on scene.0.Beschattung_EG_Tag
                  2025-08-11 13:55:45.257  - debug: scenes.0 (11085) initScenes: subscribe on scene.0.Beschattung_UG_Tag
                  2025-08-11 13:55:45.258  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Essen_Wandleuchten_Helligkeitswert
                  2025-08-11 13:55:45.259  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Flur_Bodenspots_Helligkeitswert
                  2025-08-11 13:55:45.260  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Flur_Hängelampe_Helligkeitswert
                  2025-08-11 13:55:45.260  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Flur_Spots_Helligkeitswert
                  2025-08-11 13:55:45.260  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Flur_Spots_einzeln_bei_Garage_Helligkeitswert
                  2025-08-11 13:55:45.261  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kücheninsel_Spots_Helligkeitswert
                  2025-08-11 13:55:45.262  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Wohnzimmer_3-fach_Spots_Helligkeitswert
                  2025-08-11 13:55:45.262  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Wohnzimmer_Hängelampe_Helligkeitswert
                  2025-08-11 13:55:45.263  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Wohnzimmer_Tisch_Spot_Helligkeitswert
                  2025-08-11 13:55:45.263  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Flur_Bodenspot_Helligkeitswert
                  2025-08-11 13:55:45.264  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Flur_Wandspot_Helligkeitswert
                  2025-08-11 13:55:45.264  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Spüle_Regal_oben_Schalten
                  2025-08-11 13:55:45.265  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Spüle_Regal_unten_Schalten
                  2025-08-11 13:55:45.265  - debug: scenes.0 (11085) initScenes: subscribe on hue-extended.0.groups.003-küche.action.level
                  2025-08-11 13:55:45.266  - debug: scenes.0 (11085) initScenes: subscribe on hue-extended.0.groups.002-esszimmer.action.level
                  2025-08-11 13:55:45.266  - debug: scenes.0 (11085) initScenes: subscribe on hue-extended.0.groups.003-küche.action.colorTemperature
                  2025-08-11 13:55:45.267  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Kind_West_Leselicht_Schalten
                  2025-08-11 13:55:45.268  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Kind_West_Licht_Schalten
                  2025-08-11 13:55:45.268  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Essen_Wandleuchten_Schalten
                  2025-08-11 13:55:45.269  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Flur_Bodenspots_Schalten
                  2025-08-11 13:55:45.270  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Flur_Hängelampe_Schalten
                  2025-08-11 13:55:45.271  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Flur_Spots_Schalten
                  2025-08-11 13:55:45.271  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Flur_Spots_einzeln_bei_Garage_Schalten
                  2025-08-11 13:55:45.272  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Garderobe_LED_KW_Schalten
                  2025-08-11 13:55:45.272  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Garderobe_LED_WW_Schalten
                  2025-08-11 13:55:45.273  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Garderobe_Spots_Schalten
                  2025-08-11 13:55:45.273  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Gäste-WC_Spots_Schalten
                  2025-08-11 13:55:45.274  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Hobbyraum_Indirekt_Schalten
                  2025-08-11 13:55:45.274  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kaminzimmer_Decke_Stripe_Schalten
                  2025-08-11 13:55:45.275  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kaminzimmer_Spots_Schalten
                  2025-08-11 13:55:45.275  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kücheninsel_Spots_Schalten
                  2025-08-11 13:55:45.276  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Nebenküche_Indirekt_Schalten
                  2025-08-11 13:55:45.277  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Putzschrank_Spots_Schalten
                  2025-08-11 13:55:45.277  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Treppenraum_ins_UG_Spots_Schalten
                  2025-08-11 13:55:45.278  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Wohnzimmer_3-fach_Spots_Schalten
                  2025-08-11 13:55:45.278  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Wohnzimmer_Hängelampe_Schalten
                  2025-08-11 13:55:45.279  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Wohnzimmer_Tisch_Spot_Schalten
                  2025-08-11 13:55:45.279  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Abstellkammer_Licht_Schalten
                  2025-08-11 13:55:45.280  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Bad_Spots_Schalten
                  2025-08-11 13:55:45.280  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Büro_Licht_Schalten
                  2025-08-11 13:55:45.281  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Elektroraum_Licht_Schalten
                  2025-08-11 13:55:45.284  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Flur_Spots_bei_Büro_Schalten
                  2025-08-11 13:55:45.285  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Flur_Spots_bei_Treppe_Schalten
                  2025-08-11 13:55:45.286  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Gäste_Licht_Schalten
                  2025-08-11 13:55:45.287  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Heizungsraum_Licht_Schalten
                  2025-08-11 13:55:45.287  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Waschraum_Licht_Schalten
                  2025-08-11 13:55:45.288  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Werkstatt_Licht_Schalten
                  2025-08-11 13:55:45.288  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Bad_Dusche_Spots_Schalten
                  2025-08-11 13:55:45.289  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Bad_Wanne_Spot_Schalten
                  2025-08-11 13:55:45.289  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Bad_Waschtisch_Spots_Schalten
                  2025-08-11 13:55:45.289  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Flur_Bodenspot_Schalten
                  2025-08-11 13:55:45.290  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Flur_Spots_Schalten
                  2025-08-11 13:55:45.290  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Flur_Wandspot_Schalten
                  2025-08-11 13:55:45.291  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Kind_Ost_Leselicht_Schalten
                  2025-08-11 13:55:45.291  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Kind_Ost_Licht_Schalten
                  2025-08-11 13:55:45.292  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Schlafzimmer_Spots_Schalten
                  2025-08-11 13:55:45.292  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Treppenraum_ins_EG_Spots_Schalten
                  2025-08-11 13:55:45.293  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kaminzimmer_Bank_blau_Helligkeitswert
                  2025-08-11 13:55:45.294  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kaminzimmer_Bank_grün_Helligkeitswert
                  2025-08-11 13:55:45.294  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kaminzimmer_Bank_rot_Helligkeitswert
                  2025-08-11 13:55:45.295  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Gartentreppe_zu_Nachbars_Schalten
                  2025-08-11 13:55:45.296  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Terrasse_Blumenbeet_Licht_Schalten
                  2025-08-11 13:55:45.296  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Terrasse_Wandleuchte_Schalten
                  2025-08-11 13:55:45.297  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Steckdose_-_Außen_Sitzbank_Ri_Haus_-_schalten
                  2025-08-11 13:55:45.297  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Garderobe_LED_KW_Helligkeitswert
                  2025-08-11 13:55:45.298  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Garderobe_LED_WW_Helligkeitswert
                  2025-08-11 13:55:45.298  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Garderobe_Spots_Helligkeitswert
                  2025-08-11 13:55:45.299  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kaminzimmer_Decke_Stripe_Helligkeitswert
                  2025-08-11 13:55:45.299  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Kaminzimmer_Spots_Helligkeitswert
                  2025-08-11 13:55:45.300  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.EG.Treppenraum_ins_UG_Spots_Helligkeitswert
                  2025-08-11 13:55:45.300  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Flur_Spots_Helligkeitswert
                  2025-08-11 13:55:45.301  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Treppenraum_ins_EG_Spots_Helligkeitswer_status
                  2025-08-11 13:55:45.301  - debug: scenes.0 (11085) initScenes: subscribe on Meine_Objekte.0.Licht.Kaminbank_warmweis_schalten
                  2025-08-11 13:55:45.303  - debug: scenes.0 (11085) initScenes: subscribe on hue.0.Hue_go_1.bri
                  2025-08-11 13:55:45.304  - debug: scenes.0 (11085) initScenes: subscribe on hue.0.Hue_go_1.ct
                  2025-08-11 13:55:45.304  - debug: scenes.0 (11085) initScenes: subscribe on hue.0.Esszimmer.on
                  2025-08-11 13:55:45.306  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Büro_Licht_Helligkeitswert
                  2025-08-11 13:55:45.307  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.KG.Flur_Spots_bei_Büro_Helligkeitswert
                  2025-08-11 13:55:45.309  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.KG.Büro_Rolladen_Position
                  2025-08-11 13:55:45.310  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Kind_Ost_Leselicht_Helligkeitswert
                  2025-08-11 13:55:45.310  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.OG.Bad_Wanne_Spots_Helligkeitswert
                  2025-08-11 13:55:45.311  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Arbeitszimmer_Jalousie_Lamelle_Position
                  2025-08-11 13:55:45.311  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Arbeitszimmer_Jalousie_Position
                  2025-08-11 13:55:45.315  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Esszimmer_Jalousie_Lamelle_Position
                  2025-08-11 13:55:45.315  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Esszimmer_Jalousie_Position
                  2025-08-11 13:55:45.316  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Flur_Arbeitszimmer_Jalousie_Lamelle_Position
                  2025-08-11 13:55:45.316  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Flur_Arbeitszimmer_Jalousie_Position
                  2025-08-11 13:55:45.317  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Gäste-WC_Jalousie_Lamelle_Position
                  2025-08-11 13:55:45.318  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Gäste-WC_Jalousie_Position
                  2025-08-11 13:55:45.319  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Küche_Jalousie_Süd_Lamelle_Position
                  2025-08-11 13:55:45.319  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Küche_Jalousie_Süd_Position
                  2025-08-11 13:55:45.319  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Küche_Jalousie_West_Lamelle_Position
                  2025-08-11 13:55:45.320  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Küche_Jalousie_West_Position
                  2025-08-11 13:55:45.323  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Wohnzimmer_Jalousie_Ost_Lamelle_Position
                  2025-08-11 13:55:45.323  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Wohnzimmer_Jalousie_Ost_Position
                  2025-08-11 13:55:45.324  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Wohnzimmer_Jalousie_Süd_Lamelle_Position
                  2025-08-11 13:55:45.324  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Wohnzimmer_Jalousie_Süd_Position
                  2025-08-11 13:55:45.325  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.KG.Abstellkammer_Rolladen_Position
                  2025-08-11 13:55:45.326  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.KG.Bad_Rolladen_Position
                  2025-08-11 13:55:45.326  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.KG.Gästezimmer_Rolladen_Position
                  2025-08-11 13:55:45.328  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Jalousie.EG.Nebenküche_Rolladen_Position
                  2025-08-11 13:55:45.329  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Hauswand_bei_Gäste-WC_Licht_Schalten
                  2025-08-11 13:55:45.331  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Kind_Ost_Balkon_Spot_Schalten
                  2025-08-11 13:55:45.332  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Kind_West_Balkon_Spot_Schalten
                  2025-08-11 13:55:45.335  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Holz_hinter_Haus_-_Y90_-_Flutlicht_Effektlicht_-_schalten
                  2025-08-11 13:55:45.336  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Beleuchtung.Außen.Holzunterstand_Garage_LED-Stripe_-_Y5-2_-_schalten
                  2025-08-11 13:55:45.336  - debug: scenes.0 (11085) initScenes: subscribe on scene.0.Beschattung_EG_Nacht
                  2025-08-11 13:55:45.338  - debug: scenes.0 (11085) initScenes: subscribe on scene.0.Beschattung_OG_Nacht
                  2025-08-11 13:55:45.338  - debug: scenes.0 (11085) initScenes: subscribe on scene.0.Beschattung_UG_Nacht
                  2025-08-11 13:55:45.339  - debug: scenes.0 (11085) initScenes: subscribe on scene.0.Alle_Lichter_Aus
                  2025-08-11 13:55:45.339  - debug: scenes.0 (11085) initScenes: subscribe on scene.0.Beschattung_Nacht
                  2025-08-11 13:55:45.340  - debug: scenes.0 (11085) initScenes: subscribe on Meine_Objekte.0.Energie.Warmwasser_Zirkulation_Intervall_aktiv
                  2025-08-11 13:55:45.341  - debug: scenes.0 (11085) initScenes: subscribe on sonos.0.root.192_168_0_180.stop
                  2025-08-11 13:55:45.342  - debug: scenes.0 (11085) initScenes: subscribe on knx.0.Heizung.Heizungsraum_Aktoren.Zirkulationspumpe_OG_Schalten
                  2025-08-11 13:55:45.342  - debug: scenes.0 (11085) initScenes: subscribe on Meine_Objekte.0.Heizung.Warmwasser.400l_Tank_Heizen
                  2025-08-11 13:55:45.343  - debug: scenes.0 (11085) initScenes: subscribe on javascript.0.Sonstiges.Spechtabwehr
                  2025-08-11 13:55:45.345  - debug: scenes.0 (11085) initScenes: subscribe on hue-extended.0.groups.000-all_lights.action.on
                  2025-08-11 13:55:45.346  - debug: scenes.0 (11085) initScenes: subscribe on javascript.0.Heizung.Zirkulation_Bad
                  2025-08-11 13:55:45.346  - debug: scenes.0 (11085) initScenes: subscribe on javascript.0.Heizung.Zirkulation_GaesteWC
                  2025-08-11 13:55:45.348  - debug: scenes.0 (11085) initScenes: subscribe on javascript.0.Heizung.Zirkulation_Kueche
                  2025-08-11 13:55:45.349  - debug: scenes.0 (11085) initScenes: subscribe on scene.0.Beschattung_OG_Tag
                  2025-08-11 13:55:47.651  - error: host.NUC iobroker npm-install: npm error code ETARGETnpm error notarget No matching version found for iobroker.vis-history@1.4.16.npm error notarget In most cases you or one of your dependencies are requestingnpm error notarget a package version that doesn't exist.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-11T11_55_44_488Z-debug-0.loghost.NUC Cannot install iobroker.vis-history@1.4.16: 1
                  2025-08-11 13:55:48.532  - info: host.NUC instance system.adapter.history.0 in version "3.0.1" started with pid 11104
                  2025-08-11 13:55:48.667  - info: host.NUC iobroker npm-install: exit 25
                  2025-08-11 13:55:49.119  - info: history.0 (11104) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:55:49.139  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.2N_Motion_Detected (Count=1), Alias=false
                  2025-08-11 13:55:49.140  - info: history.0 (11104) enabled logging of owfs.0.wires.Ablauf_UG_Bad_Waschbecken (Count=2), Alias=false
                  2025-08-11 13:55:49.140  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.Anwesend_Marc (Count=3), Alias=false
                  2025-08-11 13:55:49.140  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_Sole_Rücklauf (Count=4), Alias=false
                  2025-08-11 13:55:49.141  - info: history.0 (11104) enabled logging of owfs.0.wires.Zulauf_KW_UG_Bad_Waschbecken (Count=5), Alias=false
                  2025-08-11 13:55:49.141  - info: history.0 (11104) enabled logging of owfs.0.wires.Solar_Rücklauf (Count=6), Alias=false
                  2025-08-11 13:55:49.141  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.Anwesend_Putzfrau (Count=7), Alias=false
                  2025-08-11 13:55:49.141  - info: history.0 (11104) enabled logging of owfs.0.wires.KWL_Außenluft (Count=8), Alias=false
                  2025-08-11 13:55:49.141  - info: history.0 (11104) enabled logging of parser.0.2NCardEntered (Count=9), Alias=false
                  2025-08-11 13:55:49.142  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Heizung.Heizungswasser.Heizungswasser_Soll_plus_Pufferzuschlag (Count=10), Alias=false
                  2025-08-11 13:55:49.142  - info: history.0 (11104) enabled logging of owfs.0.wires.Solar_Umschichtung_400L_Vorlauf (Count=11), Alias=false
                  2025-08-11 13:55:49.142  - info: history.0 (11104) enabled logging of owfs.0.wires.KWL_Abluft (Count=12), Alias=false
                  2025-08-11 13:55:49.142  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.2N_KeyPressed (Count=13), Alias=false
                  2025-08-11 13:55:49.142  - info: history.0 (11104) enabled logging of owfs.0.wires.Zulauf_WW_UG_Bad_Waschbecken (Count=14), Alias=false
                  2025-08-11 13:55:49.142  - info: history.0 (11104) enabled logging of owfs.0.wires.Kühlung_WT_RL (Count=15), Alias=false
                  2025-08-11 13:55:49.143  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_WP_Vorlauf (Count=16), Alias=false
                  2025-08-11 13:55:49.143  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.Anwesend_Ersatz (Count=17), Alias=false
                  2025-08-11 13:55:49.143  - info: history.0 (11104) enabled logging of javascript.0.MyObjects.Gadgets.Maeher.Starten (Count=18), Alias=false
                  2025-08-11 13:55:49.143  - info: history.0 (11104) enabled logging of owfs.0.wires.Kühlung_Sole_RL (Count=19), Alias=false
                  2025-08-11 13:55:49.143  - info: history.0 (11104) enabled logging of owfs.0.wires.Solar_Umschichtung_400L_Rücklauf (Count=20), Alias=false
                  2025-08-11 13:55:49.143  - info: history.0 (11104) enabled logging of link.0.info.status (Count=21), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of parser.0.2NStatusSwitch (Count=22), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of owfs.0.wires.Aussentemp_Nord (Count=23), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.2N_CardEntered_UID (Count=24), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of owfs.0.wires.Kühlung_WT_VL (Count=25), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of owfs.0.wires.Kühlung_Sole_VL (Count=26), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of owfs.0.wires.KWL_Zuluft (Count=27), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.Anwesend_Robert (Count=28), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of javascript.0.HKL.absolute_Innenluftfeuchtigkeit (Count=29), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of javascript.0.HKL.absolute_Aussenluftfeuchtigkeit (Count=30), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_2000L_oben (Count=31), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.Anwesend_Julia (Count=32), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of owfs.0.wires.Solar_Vorlauf (Count=33), Alias=false
                  2025-08-11 13:55:49.144  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_400L_Mitte (Count=34), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.Anwesend_Elfriede (Count=35), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_Sole_Vorlauf (Count=36), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_400L_unten (Count=37), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of javascript.0.MyObjects.Gadgets.Maeher.Home (Count=38), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of parser.0.2NCallstatus (Count=39), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_400L_oben (Count=40), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_2000L_mitte_unten (Count=41), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.Anwesend_Sabine (Count=42), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of owfs.0.wires.KWL_Fortluft (Count=43), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of Meine_Objekte.0.Sicherheit.Anwesend_Jana (Count=44), Alias=false
                  2025-08-11 13:55:49.145  - info: history.0 (11104) enabled logging of owfs.0.wires.Heizung_WP_Rücklauf (Count=45), Alias=false
                  2025-08-11 13:55:49.668  - warn: host.NUC startInstance cannot find adapter "vis-timeandweather@1.4.16". Try to install it... 1 attempt
                  2025-08-11 13:55:49.668  - info: host.NUC iobroker install vis-timeandweather@1.4.16 using installedVersion
                  2025-08-11 13:55:50.568  - info: host.NUC iobroker npm-install: NPM version: 10.8.2
                  2025-08-11 13:55:50.569  - info: host.NUC iobroker npm-install: Installing iobroker.vis-timeandweather@1.4.16... (System call)
                  2025-08-11 13:55:52.557  - info: host.NUC instance system.adapter.javascript.0 in version "8.9.2" started with pid 11153
                  2025-08-11 13:55:53.660  - info: javascript.0 (11153) starting. Version 8.9.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:55:53.826  - error: host.NUC iobroker npm-install: npm error code ETARGETnpm error notarget No matching version found for iobroker.vis-timeandweather@1.4.16.npm error notarget In most cases you or one of your dependencies are requestingnpm error notarget a package version that doesn't exist.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-11T11_55_50_633Z-debug-0.log
                  2025-08-11 13:55:53.828  - error: host.NUC iobroker npm-install: host.NUC Cannot install iobroker.vis-timeandweather@1.4.16: 1
                  2025-08-11 13:55:54.848  - info: host.NUC iobroker npm-install: exit 25
                  2025-08-11 13:55:55.849  - warn: host.NUC startInstance cannot find adapter "vis-sip-asterisk@1.4.16". Try to install it... 1 attempt
                  2025-08-11 13:55:55.850  - info: host.NUC iobroker install vis-sip-asterisk@1.4.16 using installedVersion
                  2025-08-11 13:55:56.590  - info: host.NUC instance system.adapter.javascript.1 in version "8.9.2" started with pid 11190
                  2025-08-11 13:55:56.918  - error: host.NUC iobroker npm-install: host.NUC Unknown packet name vis-sip-asterisk. Please install packages from outside the repository using "iobroker url <url-or-package>"!
                  2025-08-11 13:55:56.926  - error: host.NUC iobroker npm-install: adapter "vis-sip-asterisk" cannot be installed: Unknown packet name vis-sip-asterisk. Please install packages from outside the repository using "iobroker url <url-or-package>"!
                  2025-08-11 13:55:57.741  - info: javascript.1 (11190) starting. Version 8.9.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:55:57.950  - info: host.NUC iobroker npm-install: exit 12
                  2025-08-11 13:55:58.951  - warn: host.NUC startInstance cannot find adapter "vis-material@1.4.16". Try to install it... 1 attempt
                  2025-08-11 13:55:58.951  - info: host.NUC iobroker install vis-material@1.4.16 using installedVersion
                  2025-08-11 13:56:00.242  - info: host.NUC iobroker npm-install: NPM version: 10.8.2
                  2025-08-11 13:56:00.243  - info: host.NUC iobroker npm-install: Installing iobroker.vis-material@1.4.16... (System call)
                  2025-08-11 13:56:00.804  - info: host.NUC instance scheduled system.adapter.ical.0 29,59 * * * *
                  2025-08-11 13:56:00.819  - info: host.NUC instance system.adapter.ical.0 in version "1.16.2" started with pid 11291
                  2025-08-11 13:56:02.056  - info: ical.0 (11291) starting. Version 1.16.2 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:56:03.280  - info: ical.0 (11291) processing URL: Homeserver Lueftung https://calendar.google.com/calendar/ical/l1oqjqcup45j82e55csi7ncv6k%40group.calendar.google.com/private-32e8cca4d4b943e151431115e03cf161/basic.ics
                  2025-08-11 13:56:04.908  - info: host.NUC instance system.adapter.owfs.0 in version "0.7.0" started with pid 11336
                  2025-08-11 13:56:06.284  - info: owfs.0 (11336) starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.owfs, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:56:07.604  - error: host.NUC iobroker npm-install: npm error code ETARGETnpm error notarget No matching version found for iobroker.vis-material@1.4.16.npm error notarget In most cases you or one of your dependencies are requestingnpm error notarget a package version that doesn't exist.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-11T11_56_00_341Z-debug-0.log
                  2025-08-11 13:56:07.607  - error: host.NUC iobroker npm-install: host.NUC Cannot install iobroker.vis-material@1.4.16: 1
                  2025-08-11 13:56:08.413  - info: javascript.1 (11190) requesting all states
                  2025-08-11 13:56:08.415  - info: javascript.1 (11190) requesting all objects
                  2025-08-11 13:56:08.634  - info: host.NUC iobroker npm-install: exit 25
                  2025-08-11 13:56:08.708  - info: host.NUC instance system.adapter.knx.0 in version "2.0.30" started with pid 11355
                  2025-08-11 13:56:09.281  - info: javascript.1 (11190) received all states
                  2025-08-11 13:56:09.635  - warn: host.NUC startInstance cannot find adapter "vis-rgraph@1.4.16". Try to install it... 1 attempt
                  2025-08-11 13:56:09.635  - info: host.NUC iobroker install vis-rgraph@1.4.16 using installedVersion
                  2025-08-11 13:56:10.232  - info: javascript.1 (11190) received all objects
                  2025-08-11 13:56:11.313  - error: sql.0 (11030) Error: connect ECONNREFUSED 127.0.0.1:3306
                  2025-08-11 13:56:11.412  - info: knx.0 (11355) starting. Version 2.0.30 in /opt/iobroker/node_modules/iobroker.knx, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:56:11.567  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.A301_Lehrsaal_EDV_-_Fehlerstatus is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.661  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Gäste-WC_Sichtschutz_Text_AN is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.669  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Spots_Flur_komplett_Schalten is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.716  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_Fasade_2_-_Lamellenposition is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.737  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Bertreibsmodus_R_-_EG_WC is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.759  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.BUS_gesteuerte_Zentralfunktionen.Putzlicht_Status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.785  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Basis-Sollwert_status_-_KG_Elektro is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.801  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Ein_Licht_im_Haus_an is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.812  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Meldung_Heizen_R_-_KG_Gaeste is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.833  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_IST-Temp_FF_Ausgang_unabgeglichen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.846  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Ventil_R_-_OG_Wind_West is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.863  - warn: knx.0 (11355) Object knx.0.Sensorik.OG.OG_Kind_West_-_Multisensor_-_Lichtausgang is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.917  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Bad_Sichtschutz_LERNEN is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.942  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Ventil_R_-_KG_Abstellkammer is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.964  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Textmeldung_Ladegerät_AN is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.978  - warn: knx.0 (11355) Object knx.0.Sensorik.OG.OG_Raumtemp_Schlafen_Schalter_Temp is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:11.987  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Anforderung_Heizen_R_-_KG_Waesche is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.039  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.BUS_gesteuerte_Zentralfunktionen.Alarmanlage_abwesend_Taster_Status_hörend is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.054  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Basis-Sollwert_status_-_EG_WC is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.060  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_ueberlagert_schalten is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.069  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Anforderung_Heizen_R_-_EG_Hobby is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.138  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Ventil_R_-_KG_Elektro is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.143  - warn: knx.0 (11355) Object knx.0.Jalousie.Gesamt.Beschattung_Fassade_1 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.183  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Tauchpumpe_manuell_ein is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.228  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Anforderung_Heizen_R_-_KG_Gaestebad is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.242  - warn: knx.0 (11355) Object knx.0.Sicherheit.EG.RWM_Alarm_-_EG_Kaminzimmer_ is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.276  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_Sollwertverschiebung_AUSG is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.290  - warn: knx.0 (11355) Object knx.0.Beleuchtung.EG.Garderobe_LED_KW_Helligkeitswert_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.318  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Haus_morgens_verlassen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.344  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_OG_Fitness_-_Stellgr__Heizen_AUSG_R is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.416  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_manuell_schalten is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.482  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.BUS_gesteuerte_Zentralfunktionen.Sonnenschutzautomatik_EIN_AUS is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.497  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Anforderung_Heizen_R_-_KG_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.520  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Kanal_B__Stop is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.542  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Testalarm_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.563  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Vorgabe_Sollwertversch_-_EG_WC is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.583  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_schalten_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.621  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Büro_EA is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.647  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Basalte_Taster_Kalibrieren is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.684  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.GaesteWC_PM_Licht_schalten is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.837  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Ventil_R_-_KG_Waesche is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.840  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Anforderung_Heizen_R_-_OG_Wind_West is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:12.868  - warn: knx.0 (11355) Object knx.0.Heizung.KG.RTR_KG_Büro is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.041  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Ventil_R_-_EG_Wohn_Essbereich is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.051  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Stellgr__Kühlen_R_-_EG_WC is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.103  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Ventil_R_-_OG_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.117  - info: host.NUC iobroker npm-install: NPM version: 10.8.2Installing iobroker.vis-rgraph@1.4.16... (System call)
                  2025-08-11 13:56:13.253  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Büro_Helligkeitswert is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.276  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_Fasade_3_-_Lamellenposition is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.282  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Jana_messen_Sabine_EA is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.302  - info: host.NUC instance system.adapter.alarm.0 in version "3.7.0" started with pid 11422
                  2025-08-11 13:56:13.315  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Lüfter_-_Status_manuelle_Lüftersteuerung_-_EG_Suite4_-_179_164 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.337  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_-_Niederschlag_2 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.362  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_Gemessener_Helligkeit is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.407  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Lüfter_-_Manuelle_Lüftersteuerung_Vorgabe_-_EG_Suite4_-_179_164 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.448  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Ventil_R_-_EG_Hobby is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.485  - warn: knx.0 (11355) Object knx.0.Sensorik.OG.OG_Kind_West_Helligkeit is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.545  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_Stellventil is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.563  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.EA_-_Fitness_DMX_-_GRUEN is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.571  - warn: knx.0 (11355) Object knx.0.Sonstiges.Wago.Sensor is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.576  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Gäste-WC_Sichtschutz_Text_AUS is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.586  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_Fasade_1_-_Beschattungssteuerung is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.594  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.EA_-_Fitness_DMX_-_BLAU is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.604  - warn: knx.0 (11355) Object knx.0.Beleuchtung.EG.Garderobe_LED_WW_Schalten_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.612  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Ventil_R_-_KG_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.626  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_Basis-Sollwert is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.634  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_Geräuschsensor_aktivieren is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.637  - warn: knx.0 (11355) Object knx.0.Sonstiges.Wago.Aktor is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.656  - warn: knx.0 (11355) Object knx.0.Jalousie.Gesamt.Beschattung_Fassade_2 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.664  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Bertreibsmodus_R_-_OG_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.692  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_ueberlagert_Wert is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.707  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Anforderung_Heizen_R_-_KG_Gaeste is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.734  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_dimmen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.760  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_IST-Temp is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.777  - warn: knx.0 (11355) Object knx.0.Sensorik.OG.Kind_West_PM_schalten is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.826  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Basis-Sollwert_-_KG_Gaeste is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.843  - warn: knx.0 (11355) Object knx.0.Beleuchtung.EG.Garderobe_LED_WW_Helligkeitswert_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.854  - warn: knx.0 (11355) Object knx.0.Heizung.KG.IST-Temp_R_-_KG_Abstellkammer is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.899  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Anforderung_Heizen_R_-_KG_Abstellkammer is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:13.930  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Anforderung_Heizen_R_-_OG_Schlafen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.037  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Ventil_R_-_OG_Wind_Ost is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.052  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Gäste-WC_Sichtschutz_AA is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.110  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Büro_Sperren is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.118  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_Fasade_4_-_Lamellenposition is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.195  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_Fehlerstatus is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.218  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_IST-Temp_FF_Ausgang is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.234  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.BUS_gesteuerte_Zentralfunktionen.Panikfunktion_Status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.245  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Lüfter_-_Status_aktive_Lüfterstufe_-_EG_Suite4_-_179_164 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.271  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Alle_Lichter_aus is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.283  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_Wert_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.301  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Ventil_R_-_OG_Schlafen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.320  - warn: knx.0 (11355) Object knx.0.Schaltfunktionen.KG.Steckdose_Buero_z-wave_schalten_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.337  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_-_Niederschlag_1 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.375  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_Fasade_2_-_Beschattungssteuerung is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.399  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Anforderung_Heizen_R_-_EG_Wohn_Essbereich is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.412  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Meldung_Heizen_R_-_KG_Abstellkammer is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.424  - warn: knx.0 (11355) Object knx.0.Sensorik.OG.OG_Raumtemperatur_Taster_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.439  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Anforderung_Heizen_R_-_KG_Buero is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.473  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Bertreibsmodusumsch__-_OG_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.497  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Musik_-_Gaeste-WC_-_Start_Stop_Anzeige is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.514  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Haus_betreten is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.539  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Basis-Sollwert_status_-_KG_Abstellkammer is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.546  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Meldung_Heizen_R_-_KG_Elektro is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.597  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Ventil_Störung_Stellgröße_-_EG_Suite4_-_179_164 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.614  - warn: knx.0 (11355) Object knx.0.Jalousie.Gesamt.Beschattung_Fassade_3 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.684  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Basis-Sollwert_status_-_KG_Gaestebad is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.787  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Anforderung_Heizen_R_-_OG_Wind_Ost is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.797  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_ext_Bewegung is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.809  - warn: knx.0 (11355) Object knx.0.Beleuchtung.EG.Garderobe_LED_KW_Schalten_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.824  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Meldung_Heizen_R_-_KG_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.853  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.EA_-_Fitness_DMX_-_FLASH is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.854  - warn: knx.0 (11355) Object knx.0.Heizung.Heizungsraum_Aktoren.Solarpumpe_schalten_status is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.867  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Lüfter_-_Auto=1_Man=0_-_EG_Suite4_-_179_164 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.878  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.KG_Buero_Test_-_ueberlagert_dimmen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.888  - warn: knx.0 (11355) Object knx.0.Heizung.KG.IST-Temp_R_-_KG_Gaeste is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.917  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Meldung_Heizen_R_-_KG_Buero is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.947  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Meldung_Heizen_R_-_EG_WC is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:14.998  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Ventil_R_-_KG_Gaeste is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.001  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Soll-Temp_R_-_KG_Gaeste is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.032  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Textmeldung_Ladegerät_AUS is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.043  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Ventil_R_-_EG_WC is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.165  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Anforderung_Heizen_R_-_OG_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.248  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_Fasade_4_-_Beschattungssteuerung is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.272  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Ventil_R_-_KG_Buero is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.317  - warn: knx.0 (11355) Object knx.0.Sensorik.OG.OG_Raumtemp_Taster_Bad is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.396  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Anforderung_Heizen_R_-_OG_Bad is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.506  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Haustür_öffnen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.608  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Klima_OG_Fitness_-_IST-Temp_gemessen_an_Klima is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.624  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Klima_OG_Fitness_-_Istwert_Raumtemperatur_ueber_KNX_lesen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.667  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_Fasade_3_-_Beschattungssteuerung is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.746  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.EA_-_Fitness_DMX_-_WEISS is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.774  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Klima_OG_Fitness_-_SOLLWert_Temp_lesen is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.778  - warn: knx.0 (11355) Object knx.0.Heizung.OG.Ventil_R_-_OG_Bad is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.847  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_Betriebsmodus is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.859  - warn: knx.0 (11355) Object knx.0.Sensorik.OG.OG_rel__Luftfeuchte_Flur is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:15.942  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Anforderung_Heizen_R_-_EG_WC is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.012  - warn: knx.0 (11355) Object knx.0.Zentralfunktionen.HomeServer.Szene_Jalousien_Nachtstellung is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.086  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Rückm__Sollwertversch_R_-_EG_WC is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.107  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Anforderung_Heizen_R_-_KG_Elektro is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.157  - warn: knx.0 (11355) Object knx.0.Heizung.EG.Bertreibsmodusumsch__-_EG_Wohn_Essbereich is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.165  - warn: knx.0 (11355) Object knx.0.Sensorik.Außen.Wetterstation_Fasade_1_-_Lamellenposition is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.177  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Basis-Sollwert_status_-_KG_Buero is invalid: obj.common.write has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.198  - warn: knx.0 (11355) Object knx.0.Sensorik.EG.EG_Raumtemp_Taster_Gäste-WC is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.211  - warn: knx.0 (11355) Object knx.0.Heizung.KG.IST-Temp_R_-_KG_Gaestebad is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.224  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Meldung_Heizen_R_-_KG_Gaestebad is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.237  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Büro_EA_Überlagert is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.247  - warn: knx.0 (11355) Object knx.0.Sensorik.KG.UG_Raumtemp_Taster_Elektroraum is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.289  - warn: knx.0 (11355) Object knx.0.Heizung.KG.Ventil_R_-_KG_Gaestebad is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.358  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.Ventil_Stellgröße_-_EG_Suite4_-_179_164 is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.388  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_SOLL-Temp_AUSG is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.399  - warn: knx.0 (11355) Object knx.0.Sonstiges.Test.RTR_KG_Büro_Sollwertverschiebung_EING is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.428  - warn: knx.0 (11355) Object knx.0.Sonstiges.Sonos.Musik_Bad_Künstler is invalid: obj.common.read has an invalid type! Expected "boolean", received "string" This will throw an error up from js-controller version 7.0.0!
                  2025-08-11 13:56:16.501  - info: alarm.0 (11422) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.alarm, node: v20.19.4, js-controller: 7.0.6
                  2025-08-11 13:56:16.588  - warn: knx.0 (11355) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
                  2025-08-11 13:56:16.591  - info: knx.0 (11355) Connecting to knx GW: 10.1.10.161:3671 with phy. Adr: 1.1.150
                  2025-08-11 13:56:16.600  - info: knx.0 (11355) Debuglevel: 0    1
                  2025-08-11 13:56:16.607  - info: knx.0 (11355) Connected  - local UDP Server listening on 10.1.10.160:58931
                  2025-08-11 13:56:16.663  - info: knx.0 (11355) Connected! :-)
                  2025-08-11 13:56:17.307  - info: knx.0 (11355) State value to set for "knx.0.Heizung.OG.Betriebsmodus_Frost-_Hitzeschutz_-_OG_Bad" has to be type "boolean" but received type "number"
                  2025-08-11 13:56:17.522  - info: knx.0 (11355) State value to set for "knx.0.Sensorik.KG.Elektroraum_PM_schalten" has to be type "boolean" but received type "number"
                  2025-08-11 13:56:17.630  - info: knx.0 (11355) State value to set for "knx.0.Sensorik.KG.KG_Türkontakt_Büro" has to be type "boolean" but received type "number"
                  2025-08-11 13:56:17.885  - info: knx.0 (11355) State value to set for "knx.0.Heizung.Heizungsraum_Aktoren.Umwälzpumpe_Deckenkühlung_Schalten_Status" has to be type "boolean" but received type "number"
                  2025-08-11 13:56:17.885  - info: knx.0 (11355) State value to set for "knx.0.Heizung.Heizungsraum_Aktoren.Umwälzpumpe_Deckenkühlung_Schalten" has to be type "boolean" but received type "number"
                  2025-08-11 13:56:17.975  - info: knx.0 (11355) State value to set for "knx.0.Schaltfunktionen.OG.Steckdose_Schlafzimmer_Wasserbett_schalten_status" has to be type "boolean" but received type "number"
                  2025-08-11 13:56:17.977  - info: knx.0 (11355) State value to set for "knx.0.Schaltfunktionen.OG.Steckdose_Schlafzimmer_Wasserbett_schalten" has to be type "boolean" but received type "number"
                  2025-08-11 13:56:18.446  - info: knx.0 (11355) State value to set for "knx.0.Heizung.Heizungsraum_Aktoren.Zirkulationspumpe_OG_Schalten_Status" has to be type "boolean" but received type "number"
                  2025-08-11 13:56:18.447  - info: knx.0 (11355) State value to set for "knx.0.Heizung.Heizungsraum_Aktoren.Zirkulationspumpe_OG_Schalten" has to be type "boolean" but received type "number"
                  Thomas Braun 3 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @Majorkamy last edited by
                    @majorkamy sagte in Simple + Vis Api startet nicht:
                    Cannot install iobroker.vis-bars@1.4.16
                    Richtig, die gibt es ja auch nicht.
                    vis-bars
                    github:	0.1.4
                    latest:	0.1.4 for 100 months
                    stable:	0.1.4 for 100 months
                    Versuch mal ein
                    iob upgrade vis-bars@0.1.4
                      vis-history@1.4.16
                      Da gilt das gleiche:
                      vis-history
                      github:	1.0.0
                      latest:	1.0.0 for 71 months
                      stable:	1.0.0 for 71 months
                        vis-timeandweather
                        github:	1.2.2
                        latest:	1.2.2 for 37 months
                        stable:	1.2.2 for 37 months
                        Ich weiß aber nicht, ob die alten Versionen für vis1 noch richtig laufen. Das wird ja alles nicht mehr aktiv gepflegt, wenn man sich anschaut wie lange die schon nicht mehr angepackt wurden.
                          Majorkamy @Thomas Braun last edited by
                          Die VIS bekomme ich nach wie vor nicht zum Laufen
                          Ich habe die Instanz nun .... versucht zu deinstallieren und neu zu installieren. Aber da läuft irgendwas grob schief.
                          Er zeigt sie als installiert an, aber die Instanz ist doch nicht sichtbar.
                          Über die Konsole sieht es wie unten aus...
                          Bildschirmfoto vom 2025-08-12 22-53-31.png Bildschirmfoto vom 2025-08-12 22-53-59.png Bildschirmfoto vom 2025-08-12 22-54-19.png
                          ajorkamy@NuC:~$ iobroker stop
                          majorkamy@NuC:~$ iobroker del vis
                          Delete adapter "vis"
                          host.NuC Counted 1 meta of vis
                          host.NuC Counted 1 adapter for vis
                          host.NuC Counted 1 states of vis
                          host.NuC Counted 1 states of system.adapter.vis
                          host.NuC Counted 1 states (vis.*) from states
                          host.NuC Counted 3 states (system.adapter.vis.*) from states
                          host.NuC file vis deleted
                          host.NuC file vis.admin deleted
                          host.NuC object vis deleted
                          host.NuC object vis.admin deleted
                          host.NuC Deleting 5 object(s).
                          host.NuC Deleting 4 state(s).
                          removed 1 package, and changed 1 package in 5s
                          349 packages are looking for funding
                            run `npm fund` for details
                          majorkamy@NuC:~$ iobroker install vis
                          NPM version: 10.8.2
                          Installing iobroker.vis@1.5.6... (System call)
                          added 1 package in 8s
                          host.NuC install adapter vis
                          upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                          upload [590] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                          upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                          upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/img/zip.png img/zip.png image/png
                          upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/24/mp3.png js/fm/icon/mine/24/mp3.png image/png
                          upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/img/shape_align_right.png lib/img/shape_align_right.png image/png
                          upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars/img/help/helpPicsVert.png widgets/bars/img/help/helpPicsVert.png image/png
                          upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueTimestamp.png widgets/basic/img/Prev_ValueTimestamp.png image/png
                          upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/consumption/img/spreadsheet.svg widgets/consumption/img/spreadsheet.svg image/svg+xml
                          upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.3db94a73.chunk.js.map widgets/echarts/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.3db94a73.chunk.js.map application/json
                          upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/static/media/Entrance.19ce7f39973660d9f988.svg widgets/echarts/static/media/Entrance.19ce7f39973660d9f988.svg image/svg+xml
                          upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/static/media/Second Floor.6d7739a57ae0abc218e6.svg widgets/echarts/static/media/Second Floor.6d7739a57ae0abc218e6.svg image/svg+xml
                          upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/static/media/Stairwell.35b4654398fb9ed90321.svg widgets/echarts/static/media/Stairwell.35b4654398fb9ed90321.svg image/svg+xml
                          upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/static/media/Upstairs.173a9bce7c2bf3e9ecda.svg widgets/echarts/static/media/Upstairs.173a9bce7c2bf3e9ecda.svg image/svg+xml
                          upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/static/media/Weather.b40e189f0bfc9f489bda.svg widgets/echarts/static/media/Weather.b40e189f0bfc9f489bda.svg image/svg+xml
                          upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/css/odometer-theme-car.css widgets/hqwidgets/css/odometer-theme-car.css text/css
                          upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/lockLocked.png widgets/hqwidgets/img/lockLocked.png image/png
                          upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/js/jquery.knob.js widgets/hqwidgets/js/jquery.knob.js application/javascript
                          upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialog.png widgets/jqui/img/Prev_ContainerDialog.png image/png
                          upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png
                          upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Swipe.png widgets/swipe/img/Prev_Swipe.png image/png
                          upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
                          upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
                          upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
                          upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                          upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
                          upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
                          upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
                          upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
                          upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                          upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
                          upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
                          upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
                          upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
                          upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                          upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                          upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
                          upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
                          upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                          upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
                          host.NuC object system.adapter.vis created/updated
                          Updating objects from io-package.json for adapter "vis" with version "1.5.6"
                          majorkamy@NuC:~$ iobroker start
                          majorkamy@NuC:~$ iob start vis
                          Cannot find any instances of "vis"!
                            Da ist keine Instanz angelegt.
                            iob add vis
                            Oder über die GUI.
                              Das geht leider auch nicht.
                              majorkamy@NuC:~$ iob add vis
                              host.NuC error: this adapter does not allow multiple instances
                              Die Instanz muss irgendwo noch als Infosatz oder ähnliches
                                Thomas Braun Most Active @Majorkamy last edited by Thomas Braun
                                @majorkamy
                                iob list instances
                                Du musst schauen, das du den web-Adapter/Instanz ans fliegen bekommst. Da klemmt es wohl noch.
                                  Okay, ich war an einer Stelle Blind. Die Web Instanz war nicht aktiv.
                                  Nun komme ich zwar in den Editor, jedoch mit Fehlern und bekomme die alten Daten auch nicht wieder rein.
                                  Bildschirmfoto vom 2025-08-13 09-15-09.png Bildschirmfoto vom 2025-08-13 09-15-23.png Bildschirmfoto vom 2025-08-13 09-15-31.png
                                  Folgender Fehler erscheint im log
                                  2025-08-13 10:09:51.484  - error: web.0 (4059) Cannot write file main/vis-views.json: vis.0 is not an object of type "meta"
                                  2025-08-13 10:09:51.648  - error: web.0 (4059) Cannot write file main/vis-user.css: vis.0 is not an object of type "meta"
                                  Zum einen habe ich die Vis.0 aus dem Backup des Iobroker über Winrar entpackt in den Ordner /opt/iobroker/iobroker-data kopiert -> ohne Erfolg
                                  Dann auch ein reines Vis Backup versucht einzulesen.. geht nicht
                                    @majorkamy
                                    Zu vis kann ich dir nix genaues sagen, verwende ich nicht.
                                    340
