    4. nodejs 22.18 update
    nodejs 22.18 update
      Thomas Braun Most Active @Mico last edited by
      @mico
      Gib mal die Ausgabe von
      iob diag
      zum Besten.
        Mico last edited by
        Ist das beim Protokoll oder wo finde ich das
          @mico
          In deinem Terminal...
          Da klickt nix, nur die Tastatur.
            Mico @Thomas Braun last edited by
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
             Static hostname: raspberrypi5
                   Icon name: computer
                      Kernel: Linux 6.12.34+rpt-rpi-2712
                Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 5 Model B Rev 1.0
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             07:30:50 up 41 min,  4 users,  load average: 0.50, 0.52, 0.58
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            ~ Under-voltage has occurred
            ~ Arm frequency capping has occurred
            ~ Throttling has occurred
            ~ Soft temperature limit has occurred
            *** TIME AND TIMEZONES ***
                           Local time: Tue 2025-08-12 07:30:50 CEST
                       Universal time: Tue 2025-08-12 05:30:50 UTC
                             RTC time: Tue 2025-08-12 05:30:50
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         true
            Display-Manager:        * lightdm.service - Light Display Manager
            Desktop:
            Session:                tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:            8.5G        3.6G        3.2G         28M        1.8G        4.9G
            Swap:           209M          0B        209M
            Total:          8.7G        3.6G        3.4G
            Active iob-Instances:   37
                     8063 M total memory
                     3405 M used memory
                     3673 M active memory
                      872 M inactive memory
                     3013 M free memory
                      140 M buffer memory
                     1618 M swap cache
                      199 M total swap
                        0 M used swap
                      199 M free swap
            top - 07:30:51 up 41 min,  4 users,  load average: 0.50, 0.52, 0.58
            Tasks: 265 total,   1 running, 264 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8063.2 total,   3013.8 free,   3405.7 used,   1758.9 buff/cache
            MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4657.5 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs  3.9G     0  3.9G   0% /dev
            tmpfs          tmpfs     1.6G  6.0M  1.6G   1% /run
            /dev/mmcblk0p2 ext4       58G   41G   15G  75% /
            tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
            tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
            /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
            tmpfs          tmpfs     807M  192K  807M   1% /run/user/1000
            [Tue Aug 12 06:49:30 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:68:16 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a84847a9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Tue Aug 12 06:49:32 2025] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
            [Tue Aug 12 06:49:33 2025] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w.
            Show mounted filesystems:
            TARGET               SOURCE         FSTYPE      OPTIONS
            /                    /dev/mmcblk0p2 ext4        rw,noatime
            |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            30G     /var/
            28G     /var/lib/influxdb/engine/data/2d344d64e0714233/autogen
            Archived and active journals take up 1.5G in the file system.
            /opt/iobroker/backups:
            84M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.1G    /opt/iobroker/iobroker-data/
            536M    /opt/iobroker/iobroker-data/files
            377M    /opt/iobroker/iobroker-data/history
            165M    /opt/iobroker/iobroker-data/files/vis-2
            122M    /opt/iobroker/iobroker-data/backup-objects
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            32M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03218114-if00-port0
            *** ZigBee Settings ***
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.19.4
            /usr/bin/node           v20.19.4
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.32.0
            nodejs:
              Installed: 20.19.4-1nodesource1
              Candidate: 20.19.4-1nodesource1
              Version table:
             *** 20.19.4-1nodesource1 600
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 20.19.3-1nodesource1 600
                 20.19.2-1nodesource1 600
                 20.19.1-1nodesource1 600
                 20.19.0-1nodesource1 600
                 20.18.3-1nodesource1 600
                 20.18.2-1nodesource1 600
                 20.18.1-1nodesource1 600
                 20.18.0-1nodesource1 600
                 20.17.0-1nodesource1 600
                 20.16.0-1nodesource1 600
                 20.15.1-1nodesource1 600
                 20.15.0-1nodesource1 600
                 20.14.0-1nodesource1 600
                 20.13.1-1nodesource1 600
                 20.13.0-1nodesource1 600
                 20.12.2-1nodesource1 600
                 20.12.1-1nodesource1 600
                 20.12.0-1nodesource1 600
                 20.11.1-1nodesource1 600
                 20.11.0-1nodesource1 600
                 20.10.0-1nodesource1 600
                 20.9.0-1nodesource1 600
                 20.8.1-1nodesource1 600
                 20.8.0-1nodesource1 600
                 20.7.0-1nodesource1 600
                 20.6.1-1nodesource1 600
                 20.6.0-1nodesource1 600
                 20.5.1-1nodesource1 600
                 20.5.0-1nodesource1 600
                 20.4.0-1nodesource1 600
                 20.3.1-1nodesource1 600
                 20.3.0-1nodesource1 600
                 20.2.0-1nodesource1 600
                 20.1.0-1nodesource1 600
                 20.0.0-1nodesource1 600
                 18.19.0+dfsg-6~deb12u2 500
                 18.19.0+dfsg-6~deb12u1 500
            No problems detected
            Errors in npm tree: 0
            Checking for nodejs vulnerability:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            raspberrypi2        raspberrypi2 (version: 7.0.6, hostname: raspberrypi2  , alive, uptime: 1499)
            raspberrypi5        raspberrypi5 (version: 7.0.6, hostname: raspberrypi5  , alive, uptime: 1337)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.6.17
            javascript:     8.9.2
            nodejs modules from github:     2
            | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
            +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
              system.adapter.alias-manager.0          : alias-manager         : raspberrypi5                             - disabled
            + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
            + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
            + system.adapter.device-reminder.0        : device-reminder       : raspberrypi5                             -  enabled
              system.adapter.devices.0                : devices               : raspberrypi5                             - disabled
            + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
            + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi5                             -  enabled
            + system.adapter.geofency.0               : geofency              : raspberrypi5                             -  enabled, port: 7999, bind: 0.0.0.0
            + system.adapter.growatt.0                : growatt               : raspberrypi5                             -  enabled
              system.adapter.habpanel.0               : habpanel              : raspberrypi5                             - disabled
            + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
              system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
              system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi5                             - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi5                             - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi5                             - disabled
            + system.adapter.influxdb.0               : influxdb              : raspberrypi5                             -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
            + system.adapter.meross.0                 : meross                : raspberrypi5                             -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : raspberrypi2                             -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.mqtt.1                   : mqtt                  : raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
            + system.adapter.node-red.0               : node-red              : raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
              system.adapter.openweathermap.0         : openweathermap        : raspberrypi5                             -  enabled
            + system.adapter.pushover.0               : pushover              : raspberrypi5                             -  enabled
            + system.adapter.reolink.0                : reolink               : raspberrypi5                             -  enabled
            + system.adapter.reolink.1                : reolink               : raspberrypi5                             -  enabled
            + system.adapter.samsung.0                : samsung               : raspberrypi5                             -  enabled
            + system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi5                             -  enabled, port: 8002
            + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
            + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.smartthings.0            : smartthings           : raspberrypi5                             -  enabled
            + system.adapter.sonoff.0                 : sonoff                : raspberrypi2                             -  enabled, port: 1889, bind: 0.0.0.0
            + system.adapter.statistics.0             : statistics            : raspberrypi5                             -  enabled
            + system.adapter.telegram.0               : telegram              : raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : raspberrypi5                             -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             -  enabled
            + system.adapter.tuya.0                   : tuya                  : raspberrypi5                             -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi5                             - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi5                             - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi5                             - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi5                             - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             - disabled
              system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
            + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.yahka.0                  : yahka                 : raspberrypi5                             -  enabled
              system.adapter.yr.0                     : yr                    : raspberrypi5                             -  enabled
            + system.adapter.zigbee2mqtt.1            : zigbee2mqtt           : raspberrypi5                             -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.6.17   , installed 7.6.17
            Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
            Adapter    "geofency"     : 1.2.4    , installed 1.2.4
            Adapter    "growatt"      : 3.3.1    , installed 3.3.1
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "ical"         : 1.16.2   , installed 1.16.2
            Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "node-red"     : 5.2.1    , installed 5.2.1
            Adapter    "openweathermap": 1.1.2   , installed 1.1.2
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "reolink"      : 1.2.3    , installed 1.2.3
            Adapter    "samsung"      : 0.6.1    , installed 0.6.1
            Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
            Adapter    "scenes"       : 3.2.3    , installed 3.2.3
            Adapter    "shelly"       : 10.1.0   , installed 10.1.0
            Adapter    "socketio"     : 6.7.1    , installed 7.0.8
            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
            Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
            Adapter    "web"          : 7.0.8    , installed 7.0.8
            Adapter    "ws"           : 2.6.2    , installed 3.0.19
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
            Objects and States
            Objects:        14179
            States:         11326
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:5 https://repos.influxdata.com/debian stable InRelease
            Hit:6 https://apt.grafana.com stable InRelease
            Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:8 https://repo.mosquitto.org/debian bookworm InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7316       833/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       31261      5766/iobroker.js-co
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       31266      5766/iobroker.js-co
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7356       816/cupsd
            tcp        0      0 127.0.0.1:34259         0.0.0.0:*               LISTEN      1001       48557      6489/io.yahka.0
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       33315      5935/node-red
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       34419      6192/io.shelly.0
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      113        6655       824/mosquitto
            tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       31683      6134/io.mqtt.1
            tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       31682      6134/io.mqtt.1
            tcp        0      0 0.0.0.0:35415           0.0.0.0:*               LISTEN      1001       35072      6489/io.yahka.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          7318       833/sshd: /usr/sbin
            tcp6       0      0 :::1884                 :::*                    LISTEN      113        6656       824/mosquitto
            tcp6       0      0 :::3000                 :::*                    LISTEN      112        10091      2066/grafana
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7355       816/cupsd
            tcp6       0      0 :::7999                 :::*                    LISTEN      1001       31620      6071/io.geofency.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31325      5791/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       35963      6474/io.web.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        12414      1205/influxd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        8808       651/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33525      6211/io.shelly.1
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32652      6226/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32653      6226/io.tuya.0
            udp        0      0 0.0.0.0:45274           0.0.0.0:*                           104        8810       651/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        8809       651/avahi-daemon: r
            udp6       0      0 :::56697                :::*                                104        8811       651/avahi-daemon: r
            udp6       0      0 fe80::201f:2fec:9bc:546 :::*                                0          10508      772/NetworkManager
            2025-08-12 07:31:03.771  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:04.774  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:05.775  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:06.775  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:07.776  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:08.777  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:09.779  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:10.781  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:11.784  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:12.786  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:13.788  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:14.319  - warn: shelly.0 (6192) [Mqtt.statusNotifications] 192.168.178.118 (shellyplus1pm / shellyplus1pm-cc7b5c820c00 / shellyplus1pm#cc7b5c820c00#1): "General Status Notifications" are disabled (see adapter documentation for details)
            2025-08-12 07:31:14.789  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:15.791  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:16.793  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:17.794  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:18.796  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:19.797  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:20.798  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:21.800  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:22.801  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:23.803  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:24.804  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:25.806  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            2025-08-12 07:31:26.807  - warn: zigbee2mqtt.1 (7970) Start try again in 1 seconds...
            iob diag has finished.
              Thomas Braun Most Active last edited by
              @mico
              nodejs ist richtig installiert.
              Da belügt dich mal wieder eine graphische Oberfläche.
              Starte die Kiste mal sauber durch (NIE einfach den Strom kappen!)
              iob stop
              sudo reboot
                Thomas Braun Most Active @Mico last edited by Thomas Braun
                @mico
                Und schalt den Desktop-Quark aus. Der belügt dich ja ohnehin nur.
                Server immer ohne solchen Overhead.
                  Was soll ich da genau abschalten die Übersicht?
                    @mico
                    Geht u.a. per
                    iob fix
                    Da wirste gefragt, ob die graphische Oberfläche ausgeschaltet werden soll.
                      OK das ist aber nicht dann der Browser über denn ich immer zum Iobroker gelange per PC
                      Thomas Braun M 2 Replies Last reply Reply Quote 0
                        @mico
                        Eine Weboberfläche hat nichts mit dem Desktop zu tun.
                        Den ioBroker-Admin erreichst du natürlich weiter über den Browser.
                          Mico @Mico last edited by Mico
                          aber er zeigt mir trotzdem bei Übersicht diesen Stand an.
                          Mico
                            @mico
                            Haste die Seite mal neugeladen?
                            Wie gesagt, GUIs sind notorische Lügner.
                              @thomas-braun sagte in nodejs 22.18 update:
                              @Mico
                              = Browsercache geleert/mit incognitoTab geöffnet
                              • wendy2702
                                wendy2702 @Homoran last edited by
                                @homoran @Thomas-Braun Vielleicht übersehe ich es am Habdy aber das was ihm der Browser anzeigt als installierte Version ist doch laut iob diag auch installiert und er würde gerne auf NodeJS 22.x
                                Ist der „runde Pfeil“ nicht nur ein refresh Button?
                                  Thomas Braun Most Active @wendy2702 last edited by
                                  @wendy2702
                                  Deswegen vermute ich, das nur die Seite mal neugeladen werden muss.
                                  • mcm1957
                                    mcm1957 @Thomas Braun last edited by
                                    Hmm - vielleicht verwechsel ich was.
                                    Aber der Update Button im UI aktualisisert doch nur innerhalb einer node Release.
                                    Zum Update 20 -> 22 muss man doch 'iob node-update' auf der Coammndline aufrufen.
                                    Oder?
                                      Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                                      @mcm1957 @wendy2702
                                      OMG, ihr habt natürlich beide Recht...
                                      Hab die 20 total überlesen...
                                      @Mico
                                      Ein Upgrade auf einen anderen Zweig macht man per
                                      iob nodejs-update
                                      • mcm1957
                                        Ich hab jetzt mal ein Issue erstellt (https://github.com/ioBroker/ioBroker.admin/issues/3152) damit admin da verbessert wird. Wenn du da Ideen zu einer Umsetzung oder sonstige Anmerkungen hast - nur rein damit.
                                        mcm1957 created this issue in ioBroker/ioBroker.admin
                                        open [bug / enhancement]: Confusing / Inoperable update button for node.js update #3152
                                        679
