    4. Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten
      Krys @Thomas Braun last edited by
      @thomas-braun Habs im Nachgang auch gemerkt und direkt geändert.
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-11-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       14:26:01 up 13 min,  2 users,  load average: 0.57, 0.74, 0.88
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-08-10 14:26:01 CEST
                 Universal time: Sun 2025-08-10 12:26:01 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      krystian
      HOME=/home/krystian
      GROUPS=krystian dialout sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             10G        2.7G        7.3G        110K        638M        7.9G
      Swap:           1.1G          0B        1.1G
      Total:           11G        2.7G        8.3G
      Active iob-Instances:   41
              10124 M total memory
               2583 M used memory
               2534 M active memory
                478 M inactive memory
               6931 M free memory
                  0 M buffer memory
                608 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      top - 14:26:01 up 13 min,  2 users,  load average: 0.57, 0.74, 0.88
      Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  10124.0 total,   6929.6 free,   2585.7 used,    608.8 buff/cache
      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7538.3 avail Mem
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  43% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
      tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
      tmpfs                            tmpfs     3.1G  100K  3.1G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
      /var:
      1.3G    /var/
      787M    /var/log
      782M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
      355M    /var/cache
      Archived and active journals take up 182.7M in the file system.
      /opt/iobroker/backups:
      237M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      849M    /opt/iobroker/iobroker-data/
      453M    /opt/iobroker/iobroker-data/files
      186M    /opt/iobroker/iobroker-data/files/vis-2
      167M    /opt/iobroker/iobroker-data/history-data
      149M    /opt/iobroker/iobroker-data/backup-objects
      43M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/states.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.4
      /usr/bin/node           v20.19.4
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.32.0
      nodejs:
        Installed: 20.19.4-1nodesource1
        Candidate: 20.19.4-1nodesource1
        Version table:
       *** 20.19.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.19.3-1nodesource1 1001
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 818)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     10
      +-- iobroker.ankersolix2@2.2.0 (git+ssh://git@github.com/ronny130286/ioBroker.ankersolix2.git#feb2ace0252fbd8cf30684f2f962d52d30b80d03)
      +-- iobroker.devices@1.1.5 (git+ssh://git@github.com/ioBroker/ioBroker.devices.git#9c60a66913c1aee57658cf845db655f13c144ebe)
      +-- iobroker.geofency@1.2.4 (git+ssh://git@github.com/ioBroker/ioBroker.geofency.git#cf9ccab32a4c8896a90f645e41c3a665ac0d6b0f)
      +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
      +-- iobroker.homeconnect@1.4.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.homeconnect.git#1c0ea50d8814e21bfa238db6bfcd5300846ffe9d)
      +-- iobroker.sayit@5.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.sayit.git#d15c2954b01673c5ac3697c3747bd904f99ad3e2)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
      +-- iobroker.yahka@1.1.5 (git+ssh://git@github.com/jensweigele/ioBroker.yahka.git#33608f7a2cc3ee5397a08980c5e03384be7dda27)
      +-- iobroker.zigbee@3.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#dc37fdcbd64b52258cf6b44a6b703954796a844b)
      `-- nodejieba@3.4.3 (git+ssh://git@github.com/yanyiwu/nodejieba.git#7b93462d7e8eff6f2939202a0abbfcbf64c9ec01)
      Adapter State
      + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
      + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
        system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      + system.adapter.geofency.0               : geofency              : ioBroker                                 -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.google-sharedlocations.0 : google-sharedlocations: ioBroker                                 -  enabled
      + system.adapter.google-sharedlocations.1 : google-sharedlocations: ioBroker                                 -  enabled
      + system.adapter.google-sharedlocations.2 : google-sharedlocations: ioBroker                                 -  enabled
      + system.adapter.google-sharedlocations.3 : google-sharedlocations: ioBroker                                 -  enabled
      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
      + system.adapter.hmip.1                   : hmip                  : ioBroker                                 -  enabled
      + system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
      + system.adapter.nuki.0                   : nuki                  : ioBroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
        system.adapter.openweathermap.1         : openweathermap        : ioBroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      │ 1       │ 'latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "adguard"      : 1.0.1    , installed 1.0.1
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "ankersolix2"  : 2.2.0    , installed 2.2.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "hmip"         : 1.27.0   , installed 1.27.0
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "hue"          : 3.16.1   , installed 3.16.1
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "notification-manager": 1.2.1, installed 1.2.1
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "yahka"        : 1.0.3    , installed 1.1.5
      Adapter    "zigbee"       : 2.0.5    , installed 3.0.3
      Objects and States
      Objects:        30300
      States:         27699
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       178002187  1032/io.nuki.0
      tcp        0      0 127.0.0.1:37867         0.0.0.0:*               LISTEN      1001       178004354  1803/io.yahka.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          177990009  1/init
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          178004999  1963/master
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       177989093  127/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       177988369  127/iobroker.js-con
      tcp        0      0 0.0.0.0:36969           0.0.0.0:*               LISTEN      1001       178002394  1803/io.yahka.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          177990917  1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          177990011  1/init
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       178006856  2166/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       177990413  155/io.admin.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          178005000  1963/master
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       178003747  1788/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       178003748  1788/io.tuya.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       177991515  353/io.broadlink2.0
      udp        0      0 0.0.0.0:56427           0.0.0.0:*                           1001       178006835  2159/io.upnp.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          177990010  1/init
      udp        0      0 0.0.0.0:42078           0.0.0.0:*                           1001       177993846  353/io.broadlink2.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       178007757  2159/io.upnp.0
      udp        0      0 0.0.0.0:53341           0.0.0.0:*                           1001       177993161  353/io.broadlink2.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       177997732  1021/io.mihome-vacu
      udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       178005438  1995/io.mihome-vacu
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178002391  1803/io.yahka.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       177991544  379/io.chromecast.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       178004066  1750/io.shelly.0
      udp6       0      0 :::111                  :::*                                0          177990012  1/init
      2025-08-10 14:22:06.854  - info: chromecast.0 (379) Chromecast - Connected player
      2025-08-10 14:22:06.855  - info: chromecast.0 (379) Chromecast - Player joint
      2025-08-10 14:22:06.867  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
      2025-08-10 14:24:06.467  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
          at TLSWrap.onStreamRead (node:internal/stream_base_commons:218:20)
      2025-08-10 14:24:06.467  - info: chromecast.0 (379) Chromecast - client disconnected
      2025-08-10 14:24:06.468  - info: chromecast.0 (379) Chromecast - Detached player
      2025-08-10 14:24:06.542  - info: chromecast.0 (379) Chromecast - Connected client
      2025-08-10 14:24:06.647  - info: chromecast.0 (379) Chromecast - Try to join player
      2025-08-10 14:24:06.648  - info: chromecast.0 (379) Chromecast - Connected player
      2025-08-10 14:24:06.648  - info: chromecast.0 (379) Chromecast - Player joint
      2025-08-10 14:24:06.661  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
      2025-08-10 14:24:07.138  - info: nuki.0 (1032) Bridge Info requested: http://192.168.178.43:8080/info?ts=2025-08-10T12:24:06Z&rnr=51748&hash=bd97abd6fc36232b0a8173c26cd18fdd2db40f1303dc72fba2a933ce7401abff
      2025-08-10 14:24:10.147  - info: nuki.0 (1032) Lock list requested: http://192.168.178.43:8080/list?ts=2025-08-10T12:24:09Z&rnr=57691&hash=a8b330db2e5ae9097aa7c08d37e4380d8110d1812ccf8ec2263eeddb8a91f7c4
      2025-08-10 14:26:09.565  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
      2025-08-10 14:26:09.566  - info: chromecast.0 (379) Chromecast - client disconnected
      2025-08-10 14:26:09.567  - info: chromecast.0 (379) Chromecast - Detached player
      2025-08-10 14:26:09.881  - info: chromecast.0 (379) Chromecast - Connected client
      2025-08-10 14:26:10.262  - info: chromecast.0 (379) Chromecast - Try to join player
      2025-08-10 14:26:10.264  - info: chromecast.0 (379) Chromecast - Connected player
      2025-08-10 14:26:10.264  - info: chromecast.0 (379) Chromecast - Player joint
      2025-08-10 14:26:10.665  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
        Homoran Global Moderator Administrators @Krys last edited by
        @krys sagte in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
        warum sind alle diese Instanzen über github installiert?
        da gibt's bestimmt einige in offiziellen Repos.
        sourceanalytix auf jeden Fall
          Krys last edited by
          Sollte nun i.O. sein.
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           19:35:34 up 43 min,  2 users,  load average: 1.13, 0.94, 0.97
          CPU threads: 4
                         Local time: Sun 2025-08-10 19:35:34 CEST
                     Universal time: Sun 2025-08-10 17:35:34 UTC
                           RTC time: n/a
                    RTC in local TZ: no
          krystian
          HOME=/home/krystian
          iobroker
          HOME=/home/iobroker
          Unit display-manager.service could not be found.
          Display-Manager:
          Desktop:
          Session:
          *** MEMORY ***
          Mem:             10G        2.8G        7.3G        106K        507M        7.8G
          Swap:           1.1G          0B        1.1G
          Total:           11G        2.8G        8.3G
                   2709 M used memory
                   2728 M active memory
                    319 M inactive memory
                   6931 M free memory
                      0 M buffer memory
                    483 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          top - 19:35:35 up 43 min,  2 users,  load average: 1.13, 0.94, 0.97
          %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  10124.0 total,   6928.9 free,   2711.3 used,    483.9 buff/cache
          MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7412.7 avail Mem
          *** FILESYSTEM ***
          /var:
          1.3G    /var/
          779M    /var/log
          774M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
          355M    /var/cache
          825M    /opt/iobroker/iobroker-data/
          455M    /opt/iobroker/iobroker-data/files
          35M     /opt/iobroker/iobroker-data/objects.jsonl
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          Checking for nodejs vulnerability:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 2631)
          admin:          7.6.17
          javascript:     8.9.2
          nodejs modules from github:     2
          Adapter State
          + instance is alive
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
          Objects and States
          Objects:        30300
          States:         27641
          Pending Updates: 0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       178894137  125/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       178894132  125/iobroker.js-con
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          178899939  816/master
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          178892112  1/init
          tcp        0      0 127.0.0.1:35471         0.0.0.0:*               LISTEN      1001       178906235  656/io.yahka.0
          tcp        0      0 0.0.0.0:35257           0.0.0.0:*               LISTEN      1001       178900327  656/io.yahka.0
          tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       178898901  551/io.nuki.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          178891524  1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          178892114  1/init
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          178899940  816/master
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       178905344  989/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178894361  155/io.admin.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       178902337  641/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       178902338  641/io.tuya.0
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       178894660  273/io.broadlink2.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          178892113  1/init
          udp        0      0 0.0.0.0:42485           0.0.0.0:*                           1001       178894667  273/io.broadlink2.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       178905612  970/io.upnp.0
          udp        0      0 0.0.0.0:35019           0.0.0.0:*                           1001       178905269  970/io.upnp.0
          udp        0      0 0.0.0.0:45068           0.0.0.0:*                           1001       178894782  273/io.broadlink2.0
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       178899133  536/io.mihome-vacuu
          udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       178901842  865/io.mihome-vacuu
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178900324  656/io.yahka.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178894696  296/io.chromecast.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       178899569  611/io.shelly.0
          udp6       0      0 :::111                  :::*                                0          178892115  1/init
          2025-08-10 19:34:00.886  - info: host.ioBroker iobroker upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/readmeDocu/stateStartValues.png readmeDocu/stateStartValues.png image/png
          2025-08-10 19:34:00.903  - info: host.ioBroker instance system.adapter.sourceanalytix.0 in version "0.4.14" started with pid 1411
          2025-08-10 19:34:01.061  - info: host.ioBroker iobroker upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
          2025-08-10 19:34:01.227  - info: host.ioBroker iobroker upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
          2025-08-10 19:34:01.236  - info: host.ioBroker iobroker upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
          2025-08-10 19:34:01.242  - info: host.ioBroker iobroker upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
          2025-08-10 19:34:01.248  - info: host.ioBroker iobroker upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
          2025-08-10 19:34:01.256  - info: host.ioBroker iobroker Updating objects from io-package.json for adapter "sourceanalytix" with version "0.4.14"
          2025-08-10 19:34:02.418  - info: host.ioBroker iobroker exit 0
          2025-08-10 19:35:22.864  - warn: chromecast.0 (296) Chromecast - Client error: Error: Device timeout
              at fn.ontimeout (/opt/iobroker/node_modules/castv2-client/lib/senders/platform.js:56:26)
              at Object.onceWrapper (node:events:638:28)
              at fn.emit (node:events:524:28)
              at fn.emit (node:domain:489:12)
              at Timeout.ontimeout [as _onTimeout] (/opt/iobroker/node_modules/castv2-client/lib/controllers/heartbeat.js:44:10)
              at listOnTimeout (node:internal/timers:581:17)
              at processTimers (node:internal/timers:519:7)
          2025-08-10 19:35:22.864  - info: chromecast.0 (296) Chromecast - client disconnected
          2025-08-10 19:35:22.865  - info: chromecast.0 (296) Chromecast - Detached player
          2025-08-10 19:35:22.929  - info: chromecast.0 (296) Chromecast - Connected client
          2025-08-10 19:35:22.968  - info: chromecast.0 (296) Chromecast - Try to join player
          2025-08-10 19:35:22.969  - info: chromecast.0 (296) Chromecast - Connected player
          2025-08-10 19:35:22.970  - info: chromecast.0 (296) Chromecast - Player joint
          2025-08-10 19:35:23.023  - info: chromecast.0 (296) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fd29bca0-aaaa-4b99-b18d-1df589d32b9a","statusText":"","transportId":"fd29bca0-aaaa-4b99-b18d-1df589d32b9a","universalAppId":"E8C28D3C"}
            Thomas Braun Most Active @Krys last edited by
            @krys
            Ich vermute da immer noch ein falsch eingestelltes Netzwerk.
            systemctl status systemd-networkd-wait-online.service
            sagt?
              @thomas-braun said in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
              krystian@ioBroker:~$ systemctl status systemd-networkd-wait-online.service
              x systemd-networkd-wait-online.service - Wait for Network to be Configured
                   Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; preset: disabled)
                   Active: failed (Result: exit-code) since Sun 2025-08-10 18:53:51 CEST; 1h 17min ago
                     Docs: man:systemd-networkd-wait-online.service(8)
                  Process: 105 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=1/FAILURE)
                 Main PID: 105 (code=exited, status=1/FAILURE)
                      CPU: 12ms
                @krys
                Auf meiner Kiste schaut der so aus:
                echad@chet:~ $ systemctl status systemd-networkd-wait-online.service
                ○ systemd-networkd-wait-online.service - Wait for Network to be Configured
                     Loaded: loaded (/usr/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: enabled)
                     Active: inactive (dead)
                echad@chet:~ $
                Aber zu LXCs und Netzwerk kann ich nichts sagen.
                  Ralf 2 @Thomas Braun last edited by
                  Das sieht bei einem previligiertem LXC genauso aus wie bei dir:
                  ralf@Home-Server:~$ systemctl status systemd-networkd-wait-online.service
                  * systemd-networkd-wait-online.service - Wait for Network to be Configured
                       Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: disabled)
                  ralf@Home-Server:~$
                    TT-Tom @Ralf 2 last edited by
                    @ralf-2
                    bei einem unpreviligierten auch so
                    tom@iobDev:~$ systemctl status systemd-networkd-wait-online.service
                      Krys last edited by
                      So Leute, nach langem rumgefummel folgendes Ergebnis.
                      was kurios war, mein iobroker hatte plötzlich zwei IP-Adressen, was offensichtlich auch zu zusätzlichen Problemen führte.
                      Könnt ihr nochmal mit eurem geschulten Auge drüber schauen, ob euch noch was auffällt?
                      ```bash
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                        Virtualization: lxc
                                Kernel: Linux 6.8.12-13-pve
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       10:32:36 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
                      CPU threads: 4
                                     Local time: Tue 2025-08-12 10:32:37 CEST
                                 Universal time: Tue 2025-08-12 08:32:37 UTC
                                       RTC time: n/a
                                RTC in local TZ: no
                      krystian
                      HOME=/home/krystian
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:
                      *** MEMORY ***
                      Mem:             10G        2.6G        7.4G        114K        570M        8.0G
                      Swap:           1.1G          0B        1.1G
                      Total:           11G        2.6G        8.5G
                               2478 M used memory
                               2438 M active memory
                                410 M inactive memory
                               7101 M free memory
                                  0 M buffer memory
                                544 M swap cache
                               1024 M total swap
                                  0 M used swap
                               1024 M free swap
                      top - 10:32:37 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
                      %Cpu(s): 25.0 us,  0.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  10124.0 total,   7100.1 free,   2479.8 used,    544.3 buff/cache
                      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7644.2 avail Mem
                      2 loaded units listed.
                      *** FILESYSTEM ***
                      /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  41% /
                      tmpfs                            tmpfs     3.1G  104K  3.1G   1% /run
                      /var:
                      1.3G    /var/
                      781M    /var/log
                      355M    /var/cache
                      251M    /opt/iobroker/backups/
                      660M    /opt/iobroker/iobroker-data/
                      268M    /opt/iobroker/iobroker-data/files
                      148M    /opt/iobroker/iobroker-data/backup-objects
                      48M     /opt/iobroker/iobroker-data/files/iot.admin
                      45M     /opt/iobroker/iobroker-data/states.jsonl
                      33M     /opt/iobroker/iobroker-data/objects.jsonl
                      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                      USB-Devices by-id:
                      HINT:
                      /dev/ttyUSB0
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 428)
                      admin:          7.6.17
                      javascript:     8.9.2
                      nodejs modules from github:     4
                      +-- iobroker.alexa2@3.27.3 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#1f026d3554d62693f1c785027d1e326cf6461998)
                      +-- iobroker.cloudless-homeconnect@1.6.2 (git+ssh://git@github.com/eifel-tech/ioBroker.cloudless-homeconnect.git#2e5ef03576947db4490f99fe5b032ef5d0e216fe)
                      Adapter State
                      + system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : ioBroker                                 -  enabled
                      + instance is alive
                      Objects and States
                      Objects:        29378
                      States:         27132
                      Hit:2 http://security.debian.org bookworm-security InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          343600     295/master
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          341984     1/init
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       344427     126/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       344422     126/iobroker.js-con
                      tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       349074     700/io.nuki.0
                      tcp        0      0 127.0.0.1:45729         0.0.0.0:*               LISTEN      1001       353213     813/io.yahka.0
                      tcp        0      0 0.0.0.0:37503           0.0.0.0:*               LISTEN      1001       352501     813/io.yahka.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          344254     1/init
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          341986     1/init
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          343601     295/master
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       346474     306/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       356415     992/io.web.0
                      udp        0      0 0.0.0.0:36423           0.0.0.0:*                           1001       345845     428/io.broadlink2.0
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       348828     681/io.mihome-vacuu
                      udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       353940     874/io.mihome-vacuu
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       352498     813/io.yahka.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       348185     443/io.chromecast.0
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       349155     760/io.shelly.0
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       353336     790/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       353337     790/io.tuya.0
                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       346813     428/io.broadlink2.0
                      udp        0      0 0.0.0.0:56183           0.0.0.0:*                           1001       355236     969/io.upnp.0
                      udp        0      0 192.168.178.100:68      0.0.0.0:*                           103        345195     73/systemd-networkd
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          341985     1/init
                      udp        0      0 0.0.0.0:41265           0.0.0.0:*                           1001       347378     428/io.broadlink2.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       357628     969/io.upnp.0
                      udp6       0      0 :::111                  :::*                                0          341987     1/init
                      udp6       0      0 fe80::be24:11ff:fe5:546 :::*                                103        345342     73/systemd-networkd
                           Active: active (exited) since Tue 2025-08-12 10:25:35 CEST; 8min ago
                          Process: 108 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=0/SUCCESS)
                         Main PID: 108 (code=exited, status=0/SUCCESS)
                              CPU: 13ms
                        Thomas Braun Most Active @Krys last edited by Thomas Braun
                        @krys
                        Ich sag ja, da klemmt beim Netzwerk was...
                        Die üblichen Nicklichkeiten würde ich noch angehen.
                        Bei Zigbee z. B. den Geräte Link 'by-id' verwenden usw.
                        Ich würde auch jetzt auf nodejs@22 gehen:
                        iob nodejs-update
                        Und im Herbst würde ich das ganze Ding auf Debian 13 'Trixie' haben.
                          Krys last edited by
                          nodejs 22 ist erledigt.
                          beim Zigbee-Adapter, wenn ich vom Anschlussnamen
                          eintrage, habe ich ne Bootschleife und der Adapter wird nicht grün.
                            @krys
                            Dann stell es wieder um. Liegt vermutlich am LXC. Die Dinger ticken tw. etwas anders als ein 'richtiges' System.
                              @thomas-braun Ja, da scheint irgendwas mit den Rechten nicht zu passen. Kriege es aber anders auch nicht durchgeschleift.
                                @krys
                                Welche Rechte brauchst du denn an dem Gerät?
                                ls -l /dev/ttyUSB0
                                  @thomas-braun so wie ich das jetzt verstanden habe, sind die Rechte beim Host. Wie und was für Rechte ich brauche, das weiß ich nicht :/. Ich meine, es läuft ja grundsätzlich so wie es aktuell ist.
                                    @krys
                                    Aber dann nicht wundern, wenn ggfls. genau das passiert:
                                    https://forum.iobroker.net/topic/81899/raspi-vermeidung-der-usb-port-wechsel?_=1755000455669
                                      Krys last edited by
                                      Das ist tatsächlich in den letzten 4 Jahren nicht passiert.
                                      631
