    4. Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten
      TT-Tom @Ralf 2 last edited by
      @ralf-2
      bei einem unpreviligierten auch so
      tom@iobDev:~$ systemctl status systemd-networkd-wait-online.service
      ○ systemd-networkd-wait-online.service - Wait for Network to be Configured
           Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: disabled)
           Active: inactive (dead)
             Docs: man:systemd-networkd-wait-online.service(8)
        Krys last edited by
        So Leute, nach langem rumgefummel folgendes Ergebnis.
        was kurios war, mein iobroker hatte plötzlich zwei IP-Adressen, was offensichtlich auch zu zusätzlichen Problemen führte.
        Könnt ihr nochmal mit eurem geschulten Auge drüber schauen, ob euch noch was auffällt?
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.8.12-13-pve
            Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         10:32:36 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2025-08-12 10:32:37 CEST
                   Universal time: Tue 2025-08-12 08:32:37 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        krystian
        HOME=/home/krystian
        GROUPS=krystian dialout sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:
        *** MEMORY ***
        Mem:             10G        2.6G        7.4G        114K        570M        8.0G
        Swap:           1.1G          0B        1.1G
        Total:           11G        2.6G        8.5G
        Active iob-Instances:   41
                10124 M total memory
                 2478 M used memory
                 2438 M active memory
                  410 M inactive memory
                 7101 M free memory
                    0 M buffer memory
                  544 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        top - 10:32:37 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
        Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 25.0 us,  0.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  10124.0 total,   7100.1 free,   2479.8 used,    544.3 buff/cache
        MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7644.2 avail Mem
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  41% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
        tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
        tmpfs                            tmpfs     3.1G  104K  3.1G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
        /var:
        1.3G    /var/
        781M    /var/log
        774M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
        355M    /var/cache
        Archived and active journals take up 182.7M in the file system.
        /opt/iobroker/backups:
        251M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        660M    /opt/iobroker/iobroker-data/
        268M    /opt/iobroker/iobroker-data/files
        167M    /opt/iobroker/iobroker-data/history-data
        148M    /opt/iobroker/iobroker-data/backup-objects
        48M     /opt/iobroker/iobroker-data/files/iot.admin
        45M     /opt/iobroker/iobroker-data/states.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/objects.jsonl
        8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        *** ZigBee Settings ***
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyUSB0
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.19.4
        /usr/bin/node           v20.19.4
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.32.0
        nodejs:
          Installed: 20.19.4-1nodesource1
          Candidate: 20.19.4-1nodesource1
          Version table:
         *** 20.19.4-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.19.3-1nodesource1 1001
             20.19.2-1nodesource1 1001
             20.19.1-1nodesource1 1001
             20.19.0-1nodesource1 1001
             20.18.3-1nodesource1 1001
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        Checking for nodejs vulnerability:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 428)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.6.17
        javascript:     8.9.2
        nodejs modules from github:     4
        +-- iobroker.alexa2@3.27.3 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#1f026d3554d62693f1c785027d1e326cf6461998)
        +-- iobroker.cloudless-homeconnect@1.6.2 (git+ssh://git@github.com/eifel-tech/ioBroker.cloudless-homeconnect.git#2e5ef03576947db4490f99fe5b032ef5d0e216fe)
        +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
        `-- nodejieba@3.4.3 (git+ssh://git@github.com/yanyiwu/nodejieba.git#7b93462d7e8eff6f2939202a0abbfcbf64c9ec01)
        Adapter State
        + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
        + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
        + system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : ioBroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
          system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        + system.adapter.geofency.0               : geofency              : ioBroker                                 -  enabled, port: 7999, bind: 0.0.0.0
        + system.adapter.google-sharedlocations.0 : google-sharedlocations: ioBroker                                 -  enabled
        + system.adapter.google-sharedlocations.1 : google-sharedlocations: ioBroker                                 -  enabled
        + system.adapter.google-sharedlocations.2 : google-sharedlocations: ioBroker                                 -  enabled
        + system.adapter.google-sharedlocations.3 : google-sharedlocations: ioBroker                                 -  enabled
        + system.adapter.history.0                : history               : ioBroker                                 -  enabled
        + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
        + system.adapter.hmip.1                   : hmip                  : ioBroker                                 -  enabled
        + system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 -  enabled
        + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
        + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
        + system.adapter.nuki.0                   : nuki                  : ioBroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
          system.adapter.openweathermap.1         : openweathermap        : ioBroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
        + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        │ 1       │ 'latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "adguard"      : 1.0.1    , installed 1.0.1
        Adapter    "admin"        : 7.6.17   , installed 7.6.17
        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
        Adapter    "ankersolix2"  : 2.2.0    , installed 2.2.0
        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "geofency"     : 1.2.4    , installed 1.2.4
        Adapter    "hmip"         : 1.27.0   , installed 1.27.0
        Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
        Adapter    "hue"          : 3.16.1   , installed 3.16.1
        Adapter    "ical"         : 1.16.2   , installed 1.16.2
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
        Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
        Adapter    "notification-manager": 1.2.1, installed 1.2.1
        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
        Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
        Adapter    "shelly"       : 10.1.0   , installed 10.1.0
        Adapter    "socketio"     : 6.7.1    , installed 7.0.8
        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "ws"           : 2.6.2    , installed 3.0.19
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
        Objects and States
        Objects:        29378
        States:         27132
        Hit:2 http://security.debian.org bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          343600     295/master
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          341984     1/init
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       344427     126/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       344422     126/iobroker.js-con
        tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       349074     700/io.nuki.0
        tcp        0      0 127.0.0.1:45729         0.0.0.0:*               LISTEN      1001       353213     813/io.yahka.0
        tcp        0      0 0.0.0.0:37503           0.0.0.0:*               LISTEN      1001       352501     813/io.yahka.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          344254     1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          341986     1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          343601     295/master
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       346474     306/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       356415     992/io.web.0
        udp        0      0 0.0.0.0:36423           0.0.0.0:*                           1001       345845     428/io.broadlink2.0
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       348828     681/io.mihome-vacuu
        udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       353940     874/io.mihome-vacuu
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       352498     813/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       348185     443/io.chromecast.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       349155     760/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       353336     790/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       353337     790/io.tuya.0
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       346813     428/io.broadlink2.0
        udp        0      0 0.0.0.0:56183           0.0.0.0:*                           1001       355236     969/io.upnp.0
        udp        0      0 192.168.178.100:68      0.0.0.0:*                           103        345195     73/systemd-networkd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          341985     1/init
        udp        0      0 0.0.0.0:41265           0.0.0.0:*                           1001       347378     428/io.broadlink2.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       357628     969/io.upnp.0
        udp6       0      0 :::111                  :::*                                0          341987     1/init
        udp6       0      0 fe80::be24:11ff:fe5:546 :::*                                103        345342     73/systemd-networkd
        krystian@ioBroker:~$ systemctl status systemd-networkd-wait-online.service
        * systemd-networkd-wait-online.service - Wait for Network to be Configured
             Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; preset: disabled)
             Active: active (exited) since Tue 2025-08-12 10:25:35 CEST; 8min ago
            Process: 108 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=0/SUCCESS)
           Main PID: 108 (code=exited, status=0/SUCCESS)
                CPU: 13ms
          Thomas Braun Most Active @Krys last edited by Thomas Braun
          @krys
          Ich sag ja, da klemmt beim Netzwerk was...
          Die üblichen Nicklichkeiten würde ich noch angehen.
          Bei Zigbee z. B. den Geräte Link 'by-id' verwenden usw.
          Ich würde auch jetzt auf nodejs@22 gehen:
          iob nodejs-update
          Und im Herbst würde ich das ganze Ding auf Debian 13 'Trixie' haben.
            Krys last edited by
            nodejs 22 ist erledigt.
            beim Zigbee-Adapter, wenn ich vom Anschlussnamen
            eintrage, habe ich ne Bootschleife und der Adapter wird nicht grün.
              @krys
              Dann stell es wieder um. Liegt vermutlich am LXC. Die Dinger ticken tw. etwas anders als ein 'richtiges' System.
                Krys @Thomas Braun last edited by
                @thomas-braun Ja, da scheint irgendwas mit den Rechten nicht zu passen. Kriege es aber anders auch nicht durchgeschleift.
                  @krys
                  Welche Rechte brauchst du denn an dem Gerät?
                  ls -l /dev/ttyUSB0
                    @thomas-braun so wie ich das jetzt verstanden habe, sind die Rechte beim Host. Wie und was für Rechte ich brauche, das weiß ich nicht :/. Ich meine, es läuft ja grundsätzlich so wie es aktuell ist.
                      @krys
                      Aber dann nicht wundern, wenn ggfls. genau das passiert:
                      https://forum.iobroker.net/topic/81899/raspi-vermeidung-der-usb-port-wechsel?_=1755000455669
                        Krys last edited by
                        Das ist tatsächlich in den letzten 4 Jahren nicht passiert.
                        631
