    4. Betatest NSPanel-lovelace-ui v0.6.x
      patricknitsch @ticaki last edited by patricknitsch
      @ticaki Sorry das wichtigste hatte ich nicht erwähnt. Erst das Script, dann den Adapter neu gestartet. Anbei die Logs erst vom Script, dann vom Adapter Neustart
      nspanel-lovelace-ui.0
      2025-08-12 22:04:29.361	info	[config-manager] Start converting configuration for NSPanel/NSPanel_Editor
      2025-08-12 22:04:24.678	info	[config-manager] Start converting configuration for NSPanel/NSPanel_Buero
      2025-08-12 22:05:08.198	error	No compatible config found, paused!
      2025-08-12 22:05:08.197	warn	No script config found for tasmota/NSPanel_Editor
      2025-08-12 22:05:08.196	warn	No script config found for tasmota/NSPanel_Buero
        ticaki @patricknitsch last edited by
        @patricknitsch
        Zeig mir mal das log nach dem du das Skript gesendet hast, und bevor du den Adapter neustartest - das sieht z.B. so aus:
        2025-08-12 22:08:59.059 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: Compiling TypeScript source
        2025-08-12 22:08:59.127 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: source code did not change, using cached compilation result...
        2025-08-12 22:08:59.138 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2025-08-12 22:08:59.141 - info: nspanel-lovelace-ui.0 (174592) [config-manager] Start converting configuration for nspanel/ns_panel1
        2025-08-12 22:08:59.461 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: Stopping script
        2025-08-12 22:09:00.351 - warn: nspanel-lovelace-ui.0 (174592) [config-manager] Page: WindowGrid dont have any navigation! Node 'main' provisionally added as home!
        2025-08-12 22:09:00.383 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: [
        'Panel for Topic: nspanel/ns_panel1 Script version 0.8.8 is correct!',
        "Page: WindowGrid dont have any navigation! Node 'main' provisionally added as home!",
        'done'
        Ich bin zu faul windowGrid zu reparieren 😄
          @ticaki Sorry mein Log ist auf dem Kopf..
          javascript.0
          2025-08-12 22:10:52.215	info	script.js.nspanel-lovelace-ui_0.NSPanel_Buero: [ 'Panel for Topic: NSPanel/NSPanel_Buero Script version 0.9.0 is correct!', 'done']
          javascript.0
          2025-08-12 22:10:50.960	info	script.js.nspanel-lovelace-ui_0.NSPanel_Buero: Stopping script
          2025-08-12 22:10:49.932	info	[config-manager] Start converting configuration for NSPanel/NSPanel_Buero
          javascript.0
          2025-08-12 22:10:49.929	info	script.js.nspanel-lovelace-ui_0.NSPanel_Buero: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2025-08-12 22:10:49.924	info	script.js.nspanel-lovelace-ui_0.NSPanel_Buero: source code did not change, using cached compilation result...
          javascript.0
          2025-08-12 22:10:49.887	info	script.js.nspanel-lovelace-ui_0.NSPanel_Buero: Compiling TypeScript source
          T Thomas Braun 3 Replies Last reply Reply Quote 0
            ticaki @patricknitsch last edited by ticaki
            @patricknitsch
            Topics sind unterschiedlich
              @patricknitsch sagte in Betatest NSPanel-lovelace-ui v0.2.x:
              Ich gehe immer auf log herunterladen und kopiere dann, ist viel leichter auszuwählen - bin halt faul 😄
                @ticaki Das darfst keinem erzählen... Ändere die Struktur und vergesse, die Topics im Script anzupassen. Im Adapter hab ichs noch geschafft. Jetzt gehts natürlich.
                Danke für die Hilfe.
                PS: Warum soll es gleich faul sein, wenn man mit weniger Aufwand zum selben Ziel kommt?
                  @patricknitsch
                  War scherzhaft gemeint - aber 👍 das es jetzt läuft
                    @ticaki Alles gut, habs schon verstanden. 🙂
                      Thomas Braun Most Active @patricknitsch last edited by
                      Das kann (und sollte) man umstellen. Geht mit dem blauen Pfeil (Ausgaberichtung umkehren).
                      Besser ist es allerdings noch direkt auf das Log zuzugreifen.
                      Mit
                      iob logs
                      z. B.
                      • teletapi
                        teletapi @ticaki last edited by
                        @ticaki said in Betatest NSPanel-lovelace-ui v0.2.x:
                        TT-Tom hat den Bug behoben - als ich das geschrieben habe gab es noch keinen Datenpunkt windDirectionText
                        Ist das dann in der kommenden Version mit drin oder wie kommt man da ran..?
                        T T 3 Replies Last reply Reply Quote 0
                          TT-Tom @teletapi last edited by
                          @teletapi
                          Wenn es eine neue Version gibt, melden wir uns.
                            ticaki @teletapi last edited by
                            @teletapi
                            Da der Adapter noch in keinem repo ist, kann man zwar auf Versionen warten - oder man läd die aktuelle Version von github per benutzerdefinierte Installation.
                            Die Versionsnummer ist dann halt noch die alte, der code ist jedoch aktuell.
                              TT-Tom @ticaki last edited by
                              @ticaki
                              Ja aber erst wenn wir das okay geben. Da können auch Testvarianten liegen, die ggf. Fehler verursachen können.
                                ticaki @TT-Tom last edited by ticaki
                                @tt-tom
                                IMHO habe die nix in der mainbranch verloren.
                                EDIT: Bissle ausführlicher - wenn wir leute darum bitten einen Adapter über github zu installieren und die personen das tun, können wir nicht kontrollieren, wann sie das tun. Heißt die mainbranch muß immer funktionieren. Ja klar die funktioniert manchmal nicht, aber ob du ich oder ein user das als erster rausfindet ist unerheblich, die sollen ja mittesten 😄
                                  @teletapi
                                  So der fix ist jetzt online. bitte testen.
                                    hm_krause @TT-Tom last edited by
                                    bitte um Starthilfe.
                                    Das Script ist installiert und läuft.
                                    Desired TFT Firmware: 58 / v4.9.4
                                    javascript.0	18:52:37.817	info
                                    Installed TFT Firmware: 58 / v4.9.4
                                    javascript.0	18:57:09.535	info
                                    Stopping script script.js.nspanel-lovelace-ui_0.NSPanel_1
                                    javascript.0	18:58:54.092	info
                                    Compiling TypeScript source script.js.nspanel-lovelace-ui_0.NSPanel_1
                                    javascript.0	18:58:54.554	info
                                    javascript.0	18:58:54.659	info
                                    --- start of NsPanelTs: 0_userdata.0.NSPanel. ---
                                    javascript.0	18:58:54.680	info
                                    setObjects enabled - create Alias Channels possible
                                    javascript.0	18:58:54.685	info
                                    weather alias for openweathermap.0. already exists
                                    javascript.0	18:58:54.696	info
                                    registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    javascript.0	18:58:54.701	info
                                    No Updates for NSPanel available
                                    javascript.0	18:58:54.861	info
                                    javascript.0	18:58:54.977	info
                                    Debug mode disabled
                                    javascript.0	18:58:56.163	info
                                    hidden Cards disabled
                                    javascript.0	18:58:56.253	info
                                    javascript.0	18:58:57.539	info
                                    Start MQTT-Port-Check -------------------------------------
                                    -- admin.0                   - 8081
                                    -- hm-rpc.0                  - 0
                                    -- hm-rpc.1                  - 8701
                                    -- influxdb.0                - 8086
                                    -- influxdb.1                - 8086
                                    -- mqtt.0                    - 1883
                                    -- mqtt.3                    - 1883
                                    -- mqtt.4                    - 1886
                                    -- proxmox.0                 - 8006
                                    -- shelly.0                  - 1883
                                    -- shelly.1                  - 1882
                                    javascript.0	18:58:57.540	info
                                    -- simple-api.0              - 8087
                                    -- sonoff.0                  - 1885
                                    -- sun2000.0                 - 502
                                    -- telegram.0                - 8443
                                    -- web.0                     - 8082
                                    -- zigbee.1                  - /dev
                                    - MQTT-Port-Check OK: Instance of Adapter: mqtt.4 is running on Port:1886
                                    End MQTT-Port-Check ----------
                                    Der Apapter startet nicht, Fehler: No compatible config found, paused!
                                    Hier die Einstellungen:3.jpg 2.jpg 1.jpg
                                    Log:
                                    	2025-08-13 19:15:32.584	debug	{"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.4"},"id":236,"ack":false,"time":1755105332581},"_id":22998830}
                                    	2025-08-13 19:14:56.356	debug	{"command":"getTimeZones","message":{"ip":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.4"},"id":235,"ack":false,"time":1755105296355},"_id":22998829}
                                    	2025-08-13 19:14:56.284	debug	{"command":"getTasmotaDevices","message":{"ip":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.4"},"id":234,"ack":false,"time":1755105296281},"_id":22998828}
                                    	2025-08-13 19:00:28.147	error	No compatible config found, paused!
                                    	2025-08-13 19:00:28.106	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
                                    	2025-08-13 19:00:27.873	debug	States connected to redis: 0.0.0.0:9000
                                    	2025-08-13 19:00:27.771	debug	States create User PubSub Client
                                    	2025-08-13 19:00:27.771	debug	States create System PubSub Client
                                    	2025-08-13 19:00:27.741	debug	Redis States: Use Redis connection: 0.0.0.0:9000
                                    	2025-08-13 19:00:27.683	debug	Objects connected to redis: 0.0.0.0:9001
                                    	2025-08-13 19:00:27.678	debug	Objects client initialize lua scripts
                                    	2025-08-13 19:00:27.578	debug	Objects create User PubSub Client
                                    	2025-08-13 19:00:27.578	debug	Objects create System PubSub Client
                                    	2025-08-13 19:00:27.577	debug	Objects client ready ... initialize now
                                    	2025-08-13 19:00:27.534	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
                                    	2025-08-13 19:00:23.080	info	terminating
                                    	2025-08-13 19:00:22.579	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    	2025-08-13 19:00:22.579	info	terminating
                                    	2025-08-13 19:00:22.578	info	Got terminate signal TERMINATE_YOURSELF
                                    	2025-08-13 18:59:52.362	debug	{"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.4"},"id":232,"ack":false,"time":1755104392359},"_id":22998826}
                                    Bitte um Hilfe
                                      TT-Tom @hm_krause last edited by TT-Tom
                                      @hm_krause
                                      Hast du dir die Hilfe zur Adapter Installation durchgelesen. Und diese schrittweise abgearbeitet.
                                      Dann solltest du selber auf den Fehler kommen.
                                      Du hast ein Schritt vergessen. Bitte lesen, damit du den Ablauf verstehst.
                                      Wenn es dann immer noch nicht klappt, melde dich einfach noch mal.
                                      Edit: sehe grade das du auch ein falsches Script genommen hast. Also bitte lesen, der Link ins auf der General Seite oben.
                                        @tt-tom
                                        --Hm...??
                                        Script habe ich dieses von hier: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/DEV/NSPanelTs.ts
                                        Hilfe zur Adapterinstallation mehrfach gelesen, ich finde den Fehler nicht.
                                          @hm_krause
                                          Um ehrlich zu sein hast du so nicht richtig gelesen.
                                          Das Script ist vom Parallel Projekt und hat mit dem Adapter nichts zu tun.
                                          Wiki
                                          Hier wird genau gesagt welches Script du nutzen sollst.
                                          Es wird vom Adapter angelegt.
                                          teletapi H 2 Replies Last reply Reply Quote 1
                                          • teletapi
                                            teletapi @TT-Tom last edited by
                                            Nabend, ich hab heute nach der Aufforderung zum testen des neuen Scriptes den Adapter aktualisiert danach stand dann unter Maintain das das neue script zur verfügung steht. Hab dann den Butten gedrückt und ein "OK" bekommen.
                                            Leider ist der Fehler nach Neustart des scriptes und des Adapters immernoch vorhanden .
                                            Die neue script Version wird aber geladen
                                            avascript.0	01:00:10.698	info
                                            javascript.0	01:00:10.758	info
                                            javascript.0	01:00:10.762	info
                                            javascript.0	01:00:11.123	info
                                            Stopping script
                                            javascript.0	01:00:11.529	info
                                              'Panel for Topic: SmartHome/NSPanel_Weiss Script version 0.9.1 is correct!',
                                              'done'
                                            	2025-08-14 00:57:49.999	warn	[StatesDB] Found more as 1 state for role in /^openweathermap\.0./ with .dp: openweathermap.0.forecast.current.windDirection and .regexp: /^openweathermap\.[0-9]+\.forecast\.current\.windDirection/
                                            	2025-08-14 00:57:49.944	warn	[StatesDB] Found more as 1 state for role in /^openweathermap\.0./ with .dp: openweathermap.0.forecast.current.windDirection and .regexp: /^openweathermap\.[0-9]+\.forecast\.current\.windDirection/
                                            T T 2 Replies Last reply Reply Quote 0
                                            533
                                            71773
