    4. Wir empfehlen: Node.js 22.x
      Mutanten @apollon77 last edited by Samson71
      @apollon77
      Habe iob nodejs-update ausgeführt und er hat auch von 20 auf 22 upgedatet, jedoch nur auf 22.15.0
      bei wiederholter Eingabe wird auch wird auch angezeigt das es die 22.18.0 gibt:
      Recommended nodejs-version is: 22.18.0
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v22.15.0
      /usr/bin/node           v22.15.0
      /usr/bin/npm            10.9.2
      /usr/bin/npx            10.9.2
      /usr/bin/corepack       0.32.0
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 22.15.0-1nodesource1
        Candidate: 22.15.0-1nodesource1
        Version table:
       *** 22.15.0-1nodesource1 600
              500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           22.14.0-1nodesource1 600
           22.13.1-1nodesource1 600
           22.13.0-1nodesource1 600
           22.12.0-1nodesource1 600
           22.11.0-1nodesource1 600
           22.10.0-1nodesource1 600
           22.9.0-1nodesource1 600
           22.8.0-1nodesource1 600
           22.7.0-1nodesource1 600
           22.6.0-1nodesource1 600
           22.5.1-1nodesource1 600
           22.5.0-1nodesource1 600
           22.4.1-1nodesource1 600
           22.4.0-1nodesource1 600
           22.3.0-1nodesource1 600
           22.2.0-1nodesource1 600
           22.1.0-1nodesource1 600
           22.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main armhf Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main armhf Packages
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v22.15.0. Do you want to install recommended version 22.18.0?
      Jedoch wird diese nicht installiert:
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
      Stopping ioBroker now
      ioBroker has been stopped
      Removing dfsg-nodejs
      *** These repos are active on your system:
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian buster InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_22.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
      Get:6 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages [6705 B]
      Fetched 18.8 kB in 2s (8795 B/s)
      Installing nodejs now!
      Installing latest nodejs v22 release
      SUCCESS!
      v22.15.0 has been installed! You are using the latest nodejs@22 release now!
      COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
      add fsevents 2.3.3
      added 1 package in 7s
      257 packages are looking for funding
        run `npm fund` for details
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      iob diag spukt folgendes aus
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: raspberrypi-dashboard
             Icon name: computer
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       13:21:06 up  2:14,  3 users,  load average: 2.40, 1.59, 1.49
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-08-12 13:21:06 CEST
                 Universal time: Tue 2025-08-12 11:21:06 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            4.0G        1.5G        1.5G        929K        1.2G        2.5G
      Swap:           2.1G          0B        2.1G
      Total:          6.2G        1.5G        3.7G
      Active iob-Instances:   19
               3838 M total memory
               1462 M used memory
                685 M active memory
               1478 M inactive memory
               1438 M free memory
                340 M buffer memory
                761 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      top - 13:21:07 up  2:14,  3 users,  load average: 2.40, 1.59, 1.49
      Tasks: 165 total,   3 running, 162 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3838.7 total,   1437.8 free,   1463.8 used,   1102.6 buff/cache
      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   2374.9 avail Mem
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
      * influxdb.service      loaded failed failed InfluxDB is an open-source, distributed, time series database
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       29G   14G   15G  50% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     768M  848K  767M   1% /run
      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
      tmpfs          tmpfs     384M   28K  384M   1% /run/user/1000
      [Tue Aug 12 11:06:13 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:EA:23:4A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=31dab8ea-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Tue Aug 12 11:06:14 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Tue Aug 12 11:06:14 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Aug 12 11:06:17 2025] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.3G    /var/
      826M    /var/log
      777M    /var/log/journal/d095af32df8b433fb0cbfdb5e85b78d0
      213M    /var/lib
      Archived and active journals take up 776.4M in the file system.
      /opt/iobroker/backups:
      380M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      519M    /opt/iobroker/iobroker-data/
      218M    /opt/iobroker/iobroker-data/files
      151M    /opt/iobroker/iobroker-data/backup-objects
      99M     /opt/iobroker/iobroker-data/History
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.9f443724.js.map
      14M     /opt/iobroker/iobroker-data/states.jsonl
      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/npm            10.9.2
      /usr/bin/npx            10.9.2
      nodejs:
        Version table:
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      The current Node.js version (v22.15.0) is vulnerable to the following CVEs:
      CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
      Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi-dashboard raspberrypi-dashboard (version: 7.0.6, hostname: raspberrypi-dashboard, alive, uptime: 155)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     3
      +-- iobroker.renault@0.0.22 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#93de058900073dc703b24502ff289003610aac5f)
      +-- iobroker.vw-connect@0.7.12 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#d59d3f600b8fc35deb9a82ca1da66a285d02ea42)
      `-- iobroker.zoe2@0.2.11 (git+ssh://git@github.com/fungus75/ioBroker.zoe2.git#b925f4abcb587c30c919de011271a670667ce915)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi-dashboard                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi-dashboard                    -  enabled
        system.adapter.discovergy.0             : discovergy            : raspberrypi-dashboard                    - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi-dashboard                    - disabled
      + system.adapter.e3dc-rscp.0              : e3dc-rscp             : raspberrypi-dashboard                    -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi-dashboard                    - disabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi-dashboard                    -  enabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspberrypi-dashboard                    -  enabled
      + system.adapter.fronius.0                : fronius               : raspberrypi-dashboard                    -  enabled
      + system.adapter.history.0                : history               : raspberrypi-dashboard                    -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi-dashboard                    - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi-dashboard                    - disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi-dashboard                    -  enabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi-dashboard                    -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : raspberrypi-dashboard                    -  enabled
      + system.adapter.parser.0                 : parser                : raspberrypi-dashboard                    -  enabled
      + system.adapter.renault.0                : renault               : raspberrypi-dashboard                    -  enabled
      + system.adapter.s7.0                     : s7                    : raspberrypi-dashboard                    -  enabled
      + system.adapter.solarlog.0               : solarlog              : raspberrypi-dashboard                    -  enabled, port: 80
      + system.adapter.tibberlink.0             : tibberlink            : raspberrypi-dashboard                    -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi-dashboard                    - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-dashboard                    - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-dashboard                    -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi-dashboard                    - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi-dashboard                    - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi-dashboard                    - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi-dashboard                    -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : raspberrypi-dashboard                    -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi-dashboard                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zoe2.0                   : zoe2                  : raspberrypi-dashboard                    -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): Stable (default)
      Upgrade policy: minor
      Installed ioBroker-Adapters
      Used repository: Stable (default)
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "discovergy"   : 0.5.13   , installed 0.5.13
      Adapter    "e3dc-rscp"    : 1.4.2    , installed 1.4.2
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "operating-hours": 1.3.0  , installed 1.3.0
      Adapter    "parser"       : 2.2.4    , installed 2.2.4
      Adapter    "s7"           : 1.4.3    , installed 1.4.3
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
      Adapter    "tibberlink"   : 5.0.0    , installed 5.0.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        9525
      States:         8156
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          14624      491/connmand
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13574      575/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13546      534/cupsd
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          12275      896/exim4
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       143484     27043/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       143479     27043/iobroker.js-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       141875     27065/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       143835     27381/io.web.0
      tcp6       0      0 ::1:53                  :::*                    LISTEN      0          14628      491/connmand
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13576      575/sshd: /usr/sbin
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          14522      541/xrdp-sesman
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13545      534/cupsd
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          12276      896/exim4
      tcp6       0      0 :::3389                 :::*                    LISTEN      116        13081      568/xrdp
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          14616      491/connmand
      udp        0      0 0.0.0.0:35394           0.0.0.0:*                           0          12130      491/connmand
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12285      440/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13407      376/avahi-daemon: r
      udp        0      0 0.0.0.0:53516           0.0.0.0:*                           108        13409      376/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15506      440/dhcpcd
      udp6       0      0 ::1:53                  :::*                                0          14620      491/connmand
      udp6       0      0 :::5353                 :::*                                108        13408      376/avahi-daemon: r
      udp6       0      0 :::47441                :::*                                108        13410      376/avahi-daemon: r
      2025-08-12 13:20:17.288  - info: fritzdect.0 (27278) ____________________________________________
      2025-08-12 13:20:17.289  - info: fritzdect.0 (27278) create Main object DECT_ 113240165432-1 Rauchmelder Garage switch
      2025-08-12 13:20:17.909  - info: fritzdect.0 (27278) ____________________________________________
      2025-08-12 13:20:17.909  - info: fritzdect.0 (27278) create Main object DECT_ 139790430399 Taster Tschinkel thermo
      2025-08-12 13:20:18.341  - info: fritzdect.0 (27278) ____________________________________________
      2025-08-12 13:20:18.342  - info: fritzdect.0 (27278) create Main object DECT_ 139790456408 Tschinkel Küche thermo.heat
      2025-08-12 13:20:18.990  - info: fritzdect.0 (27278) ____________________________________________
      2025-08-12 13:20:18.990  - info: fritzdect.0 (27278) create Main object DECT_ 139790456383 Tschinkel Wohnzimmer thermo.heat
      2025-08-12 13:20:19.492  - info: fritzdect.0 (27278) ____________________________________________
      2025-08-12 13:20:19.492  - info: fritzdect.0 (27278) create Main object DECT_ 116300448324 Spülmaschine switch
      2025-08-12 13:20:20.039  - info: fritzdect.0 (27278) ____________________________________________
      2025-08-12 13:20:20.039  - info: fritzdect.0 (27278) create Main object DECT_ 152820284349-1 MK Terrassentür switch
      2025-08-12 13:20:20.318  - info: fritzdect.0 (27278) ____________________________________________
      2025-08-12 13:20:20.319  - info: fritzdect.0 (27278) create Main object DECT_ 139790786726 Heizung Bad Handtuchhalter thermo.heat
      2025-08-12 13:20:21.003  - info: fritzdect.0 (27278) ____________________________________________
      2025-08-12 13:20:21.003  - info: fritzdect.0 (27278) create Main object DECT_ 116300480469 Heizstab Heizung Bad switch
      2025-08-12 13:20:21.532  - info: fritzdect.0 (27278) finished creating devices/groups (if any)
      2025-08-12 13:20:21.532  - info: fritzdect.0 (27278) templates are not used (true)
      2025-08-12 13:20:21.533  - info: fritzdect.0 (27278) routines are used(false)
      2025-08-12 13:20:21.533  - info: fritzdect.0 (27278) start creating routines
      2025-08-12 13:20:21.988  - info: fritzdect.0 (27278) finished creating routines (if any)
      2025-08-12 13:20:21.989  - info: fritzdect.0 (27278) start initial updating devices/groups
      2025-08-12 13:20:25.629  - info: fritzdect.0 (27278) finished initial updating devices/groups
      2025-08-12 13:20:25.629  - info: fritzdect.0 (27278) going over to cyclic polling, messages to poll activity only in debug-mode
      2025-08-12 13:20:26.720  - info: vw-connect.0 (27368) No last shorterm trips found. Please check if your car supports shortterm trips. Block fetching for:WVGZZZE29SP503026
      Die Danger Meldung habe ich gesehen, kann damit jedoch nichts anfangen, bin kein Linux Spezialist, kämpfe mich so durch.
      Ich hoffe du kannst mir helfen.
      Danke und Gruß, Michael
      Mod-Edit
      Code-Tags repariert
        Thomas Braun Most Active @Mutanten last edited by Thomas Braun
        @mutanten sagte in Wir empfehlen: Node.js 22.x:
        Nein, kann ich nicht.
        Das liegt an der von dir verwendeten 32Bit-Version.
        Installier das ganze Ding komplett neu als reines 64Bit-System.
        Dann würde auch der aktuelle Kernel geladen und nicht der von Raspberry 11 noch.
        In-line-Upgrades funktionieren von 11 auf 12 NICHT!
        • I
          iobroker2001 last edited by
          Das Update ist bei mir erfolgreich durchgelaufen, alles klappt, AUSSER der Adapter CUL/culfw
          Der Adapter bleibt auf rot stehen.
          cul.0
          	2025-08-12 18:02:14.577	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          cul.0
          	2025-08-12 18:02:14.576	info	terminating
          cul.0
          	2025-08-12 18:02:14.567	error	Exception-Code: ERR_DLOPEN_FAILED: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 115. This version of Node.js requiresNODE_MODULE_VERSION 127. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
          cul.0
          	2025-08-12 18:02:14.567	error	Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 115. This version of Node.js requiresNODE_MODULE_VERSION 127. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`). at Object..node (node:internal/modules/cjs/loader:1846:18) at Module.load (node:internal/modules/cjs/loader:1423:32) at Function._load (node:internal/modules/cjs/loader:1246:12) at TracingChannel.traceSync (node:diagnostics_channel:322:14) at wrapModuleLoad (node:internal/modules/cjs/loader:235:24) at Module.require (node:internal/modules/cjs/loader:1445:12) at require (node:internal/modules/helpers:135:16) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1688:14)
          cul.0
          	2025-08-12 18:02:14.566	error	uncaught exception: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 115. This version of Node.js requiresNODE_MODULE_VERSION 127. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
          cul.0
          	2025-08-12 18:02:14.481	info	starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.cul, node: v22.18.0, js-controller: 7.0.6
            Thomas Braun Most Active @iobroker2001 last edited by
            @iobroker2001
            Da müssen Komponenten neugebaut werden. Mal deinstallieren und wieder drauf, dann sollte das automatisch passieren.
            • I
              iobroker2001 @Thomas Braun last edited by
              @thomas-braun @thomas-braun Vielen Dank, das hat funktioniert!
              Möglicherweise lag es sogar nur daran, dass nach dem Update die vorgewählte serielle Schnittstelle in den Adaptereinstellung geleert wurde, sprich neu ausgewählt werden musste.
                @iobroker2001
                Nein, es lag daran:
                The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 115. This version of Node.js requires NODE_MODULE_VERSION 127.
                Das ist jetzt gegen NODE_MODULE_VERSION 127 gebaut worden und dann läuft das auch wieder.
                  lessthanmore last edited by
                  zigbee2mqtt ist wohl noch nicht soweit:
                  zigbee2mqtt.0
                  2025-08-12 19:37:59.781	error	z2m: Could not init sd_notify: The module '/opt/zigbee2mqtt/node_modules/.pnpm/unix-dgram@2.0.6/node_modules/unix-dgram/build/Release/unix_dgram.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 115. This version of Node.js requires NODE_MODULE_VERSION 127. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
                  zigbee2mqtt.0
                  2025-08-12 19:36:18.708	error	z2m: Could not init sd_notify: The module '/opt/zigbee2mqtt/node_modules/.pnpm/unix-dgram@2.0.6/node_modules/unix-dgram/build/Release/unix_dgram.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 115. This version of Node.js requiresNODE_MODULE_VERSION 127. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
                  Obwohl alles bislang offensichtlich funktioniert.
                    Thomas Braun Most Active @lessthanmore last edited by
                    @lessthanmore
                    Da gilt auch:
                    L apollon77 2 Replies Last reply Reply Quote 0
                      lessthanmore @Thomas Braun last edited by lessthanmore
                      @thomas-braun Leider nein, Fehler bleibt.
                      npm rebuild
                      endet ebenfalls mit dem Code 127.
                      Zurück auf 20 mittels
                      iob nodejs-update 20
                      resultiert in
                      Installing latest nodejs v20 release
                      W: https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                      SUCCESS!
                      v22.18.0 has been installed! You are using the latest nodejs@20 release now!
                      Thomas Braun 1 Reply Last reply Reply Quote -1
                        Thomas Braun Most Active @lessthanmore last edited by Thomas Braun
                        @lessthanmore sagte in Wir empfehlen: Node.js 22.x:
                        resultiert in
                        Dann stimmt da irgendwas wohl grundsätzlich mit deinem nodejs nicht.
                        Ich hab gerade nochmal auf meinem Testsystem alles auf 20 gedrückt:
                        SUCCESS!
                        v20.19.4 has been installed! You are using the latest nodejs@20 release now!
                        Die Meldung passt.
                        Und zigbee2mqtt baut bei mir auch mit nodejs22:
                        2025-08-13 08:26:00.332  - info: zigbee2mqtt.0 (105824) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v22.18.0, js-controller: 7.0.7
                        2025-08-13 08:26:00.360  - info: zigbee2mqtt.0 (105824) ================================= Adapter Config =================================
                        2025-08-13 08:26:00.361  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Frontend Scheme: http
                        2025-08-13 08:26:00.362  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Frontend Server:
                        2025-08-13 08:26:00.362  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Frontend Port: 8080
                        2025-08-13 08:26:00.363  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Connection Type: ws
                        2025-08-13 08:26:00.363  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Scheme: ws
                        2025-08-13 08:26:00.363  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Server:
                        2025-08-13 08:26:00.364  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Port: 8080
                        2025-08-13 08:26:00.365  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Auth-Token: unused
                        2025-08-13 08:26:00.365  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Dummy MQTT-Server: deactivated
                        2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Debug Log: deactivated
                        2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
                        2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Use Kelvin: no
                        2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Use ColorTemperature ColorSync: no
                        2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Use BrightnessMove OnOff: no
                        2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use BrightnessStep OnOff: no
                        2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use Event In Desc: yes
                        2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use Device Icons: no
                        2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use Simple Hold/Release State: yes
                        2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use Simple Move/Stop State: no
                        2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) || Use Simple Press/Release State: no
                        2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) || Use Automatic Coordinator Check: no
                        2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) || Coordinator Check Loglevel: info
                        2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) || Coordinator Check Cron : 0 3 * * *
                        2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) ==================================================================================
                        2025-08-13 08:26:00.434  - warn: zigbee2mqtt.0 (105824) Please configure the Websoket connection!
                        Ist halt bei mir nicht konfiguriert, aber die Module werden gebaut.
                          @thomas-braun Ja, bauen/ laufen ist kein Problem. Wirft aber dennoch die Meldungen.
                          Hatte den Adapter gelöscht und neu installiert + reboot. Keine Änderung.
                          Bin jetzt mit der "alten Anleitung" zurück auf 20.
                          • skvarel
                            skvarel Developer last edited by skvarel
                            Danke!
                            iob nodejs-update hat geklappt.
                            (Raspberry4 mit Bookworm)
                            • PlatformBetriebssystem:linux
                            • Architektur:arm64
                            • CPUs:4
                            • Geschwindigkeit:1800 MHz
                            • Modell:Cortex-A72
                            • RAM:7.6 GB
                            • System-Betriebszeit:00:04:40
                            • Node.js:v22.18.0
                            • Zeit:1755067963199
                            • Zeitversatz:-120
                            • NPM:10.9.3
                            • Adapter-Anzahl:667
                            • Datenträgergröße:234.3 GB
                            • Freier Festplattenspeicher:227.6 GB
                            • Aktive Instanzen:46
                            • Pfad:/opt/iobroker/
                            • Betriebszeit:00:04:40
                            • aktiv:true
                            • _nodeCurrent:22.18.0
                            • _nodeNewest:22.18.0
                            • _nodeNewestNext:22.18.0
                            • _npmCurrent:10.9.3
                            • _npmNewest:10.9.3
                            • _npmNewestNext:10.9.3
                              Ich bin immer noch der Meinung, das du dann da eine 'komische' Installation hast.
                                Script v.2025-08-09
                                *** BASE SYSTEM ***
                                Operating System: Debian GNU/Linux 13 (trixie)
                                 Static hostname: iobroker
                                       Icon name: computer-container
                                         Chassis: container ☐
                                  Virtualization: lxc
                                          Kernel: Linux 6.14.8-2-pve
                                    Architecture: x86-64
                                OS is similar to:
                                model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
                                Docker          : false
                                Virtualization  : lxc
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 11:16:57 up  2:46,  1 user,  load average: 0.00, 0.00, 0.00
                                CPU threads: 2
                                Operating System is the current Debian stable version codenamed 'trixie'!
                                               Local time: Wed 2025-08-13 11:16:57 CEST
                                           Universal time: Wed 2025-08-13 09:16:57 UTC
                                                 RTC time: n/a
                                              NTP service: inactive
                                          RTC in local TZ: no
                                michael
                                HOME=/home/michael
                                GROUPS=michael sudo users iobroker
                                iobroker
                                HOME=/home/iobroker
                                SUDO_HOME=/home/michael
                                GROUPS=iobroker tty dialout audio video plugdev redis
                                Unit display-manager.service could not be found.
                                Display-Manager:
                                Desktop:
                                Session: 		tty
                                *** MEMORY ***
                                Mem:            8.6G        1.2G        6.9G        1.2M        481M        7.4G
                                Swap:           536M          0B        536M
                                Total:          9.1G        1.2G        7.5G
                                Active iob-Instances: 	13
                                         8192 M total memory
                                         1108 M used memory
                                         1209 M active memory
                                          285 M inactive memory
                                         6625 M free memory
                                            0 M buffer memory
                                          459 M swap cache
                                          512 M total swap
                                            0 M used swap
                                          512 M free swap
                                top - 11:16:58 up  2:46,  1 user,  load average: 0.00, 0.00, 0.00
                                Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  4.3 us,  4.3 sy,  0.0 ni, 87.0 id,  0.0 wa,  0.0 hi,  4.3 si,  0.0 st
                                MiB Mem :   8192.0 total,   6624.1 free,   1109.5 used,    459.4 buff/cache
                                MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7082.5 avail Mem
                                * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                                Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                        ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                        SUB    -> The low-level unit activation state, values depend on unit type.
                                1 loaded units listed.
                                dmesg: read kernel buffer failed: Operation not permitted
                                *** FILESYSTEM ***
                                Filesystem                       Type      Size  Used Avail Use% Mounted on
                                /dev/mapper/pve-vm--100--disk--0 ext4       25G  4.9G   19G  21% /
                                none                             tmpfs     492K  4.0K  488K   1% /dev
                                /dev/mapper/pve-root             ext4       67G  3.9G   60G   7% /dev/ttyACM0
                                udev                             devtmpfs   32G     0   32G   0% /dev/tty
                                tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
                                tmpfs                            tmpfs      13G  152K   13G   1% /run
                                tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                tmpfs                            tmpfs      32G  976K   32G   1% /tmp
                                tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
                                /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
                                `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
                                /var:
                                418M	/var/
                                213M	/var/lib
                                130M	/var/cache
                                126M	/var/cache/apt
                                89M	/var/lib/apt
                                Archived and active journals take up 24M in the file system.
                                1.8M	/opt/iobroker/backups/
                                92M	/opt/iobroker/iobroker-data/
                                56M	/opt/iobroker/iobroker-data/files
                                38M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                                6.8M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
                                5.3M	/opt/iobroker/iobroker-data/objects.jsonl
                                3.9M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
                                3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                                3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/nodejs 	v20.19.4
                                /usr/bin/node 		v20.19.4
                                /usr/bin/npm 		10.8.2
                                /usr/bin/npx 		10.8.2
                                nodejs:
                                  Installed: 20.19.4-1nodesource1
                                  Candidate: 22.18.0-1nodesource1
                                  Version table:
                                     22.18.0-1nodesource1 600
                                        500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                                     22.17.1-1nodesource1 600
                                     22.17.0-1nodesource1 600
                                     22.16.0-1nodesource1 600
                                     22.15.1-1nodesource1 600
                                 *** 20.19.4-1nodesource1 100
                                     20.19.2+dfsg-1 500
                                        500 http://deb.debian.org/debian trixie/main amd64 Packages
                                ioBroker Status
                                At least one iobroker host is running.
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 9992)
                                admin: 		7.6.17
                                javascript: 	8.9.2
                                nodejs modules from github: 	1
                                +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#e43328543d35c4555a4a3f3e595dd16417978d85)
                                Adapter State
                                + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                                + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
                                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
                                + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                                + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
                                + instance is alive
                                Active repo(s): stable
                                Upgrade policy: none
                                Used repository: stable
                                Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
                                Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
                                Adapter    "ical"         : 1.16.2   , installed 1.16.2
                                Adapter    "lovelace"     : 4.1.15   , installed 4.1.15
                                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                Adapter    "openknx"      : 0.9.0    , installed 0.9.0
                                Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                                Adapter    "ws"           : 2.6.2    , installed 3.0.19
                                Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
                                Objects and States
                                Objects: 	18993
                                States: 	7104
                                W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                Hit:1 http://security.debian.org trixie-security InRelease
                                Hit:2 http://deb.debian.org/debian trixie InRelease
                                Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                                Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                Pending Updates: 1
                                tcp        0      0 127.0.0.1:42847         0.0.0.0:*               LISTEN      1000       2535409    539/io.yahka.0
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        2535936    323/mosquitto
                                tcp        0      0 127.0.0.1:41907         0.0.0.0:*               LISTEN      1000       2535413    539/io.yahka.0
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2528715    1/init
                                tcp        0      0 127.0.0.1:34161         0.0.0.0:*               LISTEN      1000       2535405    539/io.yahka.0
                                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2535667    288/master
                                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        2535506    138/redis-server 12
                                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2535668    288/master
                                tcp6       0      0 ::1:6379                :::*                    LISTEN      105        2535507    138/redis-server 12
                                tcp6       0      0 :::36289                :::*                    LISTEN      1000       2535327    539/io.yahka.0
                                tcp6       0      0 :::33881                :::*                    LISTEN      1000       2535325    539/io.yahka.0
                                tcp6       0      0 :::1883                 :::*                    LISTEN      107        2535937    323/mosquitto
                                tcp6       0      0 :::32939                :::*                    LISTEN      1000       2535329    539/io.yahka.0
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          2532133    1/init
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          2528717    1/init
                                tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2535284    524/io.lovelace.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2535370    569/io.web.0
                                tcp6       0      0 :::8080                 :::*                    LISTEN      1001       2534659    141/node
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2534661    342/io.admin.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        2529247    132/avahi-daemon: r
                                udp        0      0 0.0.0.0:47975           0.0.0.0:*                           106        2529249    132/avahi-daemon: r
                                udp        0      0 0.0.0.0:51408           0.0.0.0:*                           1000       2535202    494/io.openknx.0
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2528716    1/init
                                udp6       0      0 :::5353                 :::*                                106        2529248    132/avahi-daemon: r
                                udp6       0      0 :::43720                :::*                                106        2529250    132/avahi-daemon: r
                                udp6       0      0 :::111                  :::*                                0          2528718    1/init
                                2025-08-13 09:21:13.403  - error: admin.0 (342) Automatic repository update is not allowed more than once an hour
                                2025-08-13 09:36:25.746  - warn: javascript.0 (398) State "mqtt.0.nuki.35C7D56C.lockAction" not found
                                2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
                                2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.<anonymous> (script.js.common.Zentral.Anwesenheit:29:5)
                                2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
                                2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                                2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7336:48)
                                2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at process.processImmediate (node:internal/timers:483:21)
                                  BigMike71 last edited by
                                  Moin,
                                  ich habe nen PI5 mit aktueller Installation laufen und alles soweit aktuell in Iobroker
                                  gehalten.
                                  Leider bekomme ich das Node.js nicht mit iob nodesjs-update hochgezogen.
                                  Es kommt keinerlei ausgabe in der ssh shell...
                                  komischerweise zeigt auch iob diag nichts an?!?
                                  Homoran Thomas Braun 2 Replies Last reply Reply Quote 1
                                    Installed: 20.19.4-1nodesource1 Candidate: 22.18.0-1nodesource1
                                    Da ist die 22er-Quelle aktiv, dafür hängt die 20 ohne Anbindung an ein Repo da herum. Apt wird dir also nun immer die aktuelle Version aus dem 22-Zweig vorschlagen.
                                    Und die Version ist auch nicht auf Prio 1001 gepinnt.
                                    Das macht aber eigentlich alles iob nodejs-update für dich, wenn du die gewünschte Ziel-Version als Option mit gibst.
                                      Homoran Global Moderator Administrators @BigMike71 last edited by
                                      @bigmike71 sagte in Wir empfehlen: Node.js 22.x:
                                      zeigen 😉
                                      Eingabe und (fehlende) Ausgabe bis zum nächsten Prompt
                                        BigMike71 @Homoran last edited by Homoran
                                        mike@Pi5:~ $ iob diag
                                        mike@Pi5:~ $ iob status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        mike@Pi5:~ $
                                        mike@Pi5:~ $ iob version
                                        7.0.7
                                        mike@Pi5:~ $
                                        mike@Pi5:~ $
                                          Thomas Braun Most Active @BigMike71 last edited by Thomas Braun
                                          Deutet auf Netzwerkprobleme hin. Beide Skripte werden jeweils frisch vom Server gezogen. 'Leider' werden aber Fehlermeldungen ausgeblendet, weswegen auch im Terminal nichts zu sehen ist.
                                          Versuch es mal mit dem Befehl aus meiner Signatur, alternativ mit
                                          curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                                            BigMike71 @Thomas Braun last edited by
                                            meine Netzwerk läuft hier zu 100%, was sollte da nicht richtig sein?
                                            Systemupdate über sudo apt-get update und upgrade geht auch fehlerfrei...
                                            202
                                            23801
