    4. Wir empfehlen: Node.js 22.x
      Thomas Braun Most Active @lessthanmore last edited by Thomas Braun
      @lessthanmore sagte in Wir empfehlen: Node.js 22.x:
      resultiert in
      v22.18.0 has been installed! You are using the latest nodejs@20 release now!
      Dann stimmt da irgendwas wohl grundsätzlich mit deinem nodejs nicht.
      Ich hab gerade nochmal auf meinem Testsystem alles auf 20 gedrückt:
      SUCCESS!
      v20.19.4 has been installed! You are using the latest nodejs@20 release now!
      Die Meldung passt.
      Und zigbee2mqtt baut bei mir auch mit nodejs22:
      2025-08-13 08:26:00.332  - info: zigbee2mqtt.0 (105824) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v22.18.0, js-controller: 7.0.7
      2025-08-13 08:26:00.360  - info: zigbee2mqtt.0 (105824) ================================= Adapter Config =================================
      2025-08-13 08:26:00.361  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Frontend Scheme: http
      2025-08-13 08:26:00.362  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Frontend Server:
      2025-08-13 08:26:00.362  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Frontend Port: 8080
      2025-08-13 08:26:00.363  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Connection Type: ws
      2025-08-13 08:26:00.363  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Scheme: ws
      2025-08-13 08:26:00.363  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Server:
      2025-08-13 08:26:00.364  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Port: 8080
      2025-08-13 08:26:00.365  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Auth-Token: unused
      2025-08-13 08:26:00.365  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Websocket Dummy MQTT-Server: deactivated
      2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Zigbee2MQTT Debug Log: deactivated
      2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
      2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Use Kelvin: no
      2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Use ColorTemperature ColorSync: no
      2025-08-13 08:26:00.366  - info: zigbee2mqtt.0 (105824) || Use BrightnessMove OnOff: no
      2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use BrightnessStep OnOff: no
      2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use Event In Desc: yes
      2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use Device Icons: no
      2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use Simple Hold/Release State: yes
      2025-08-13 08:26:00.367  - info: zigbee2mqtt.0 (105824) || Use Simple Move/Stop State: no
      2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) || Use Simple Press/Release State: no
      2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) || Use Automatic Coordinator Check: no
      2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) || Coordinator Check Loglevel: info
      2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) || Coordinator Check Cron : 0 3 * * *
      2025-08-13 08:26:00.368  - info: zigbee2mqtt.0 (105824) ==================================================================================
      2025-08-13 08:26:00.434  - warn: zigbee2mqtt.0 (105824) Please configure the Websoket connection!
      Ist halt bei mir nicht konfiguriert, aber die Module werden gebaut.
        lessthanmore @Thomas Braun last edited by lessthanmore
        @thomas-braun Ja, bauen/ laufen ist kein Problem. Wirft aber dennoch die Meldungen.
        Hatte den Adapter gelöscht und neu installiert + reboot. Keine Änderung.
        Bin jetzt mit der "alten Anleitung" zurück auf 20.
        • skvarel
          skvarel Developer last edited by skvarel
          Danke!
          iob nodejs-update hat geklappt.
          (Raspberry4 mit Bookworm)
          • PlatformBetriebssystem:linux
          • Architektur:arm64
          • CPUs:4
          • Geschwindigkeit:1800 MHz
          • Modell:Cortex-A72
          • RAM:7.6 GB
          • System-Betriebszeit:00:04:40
          • Node.js:v22.18.0
          • Zeit:1755067963199
          • Zeitversatz:-120
          • NPM:10.9.3
          • Adapter-Anzahl:667
          • Datenträgergröße:234.3 GB
          • Freier Festplattenspeicher:227.6 GB
          • Aktive Instanzen:46
          • Pfad:/opt/iobroker/
          • Betriebszeit:00:04:40
          • aktiv:true
          • _nodeCurrent:22.18.0
          • _nodeNewest:22.18.0
          • _nodeNewestNext:22.18.0
          • _npmCurrent:10.9.3
          • _npmNewest:10.9.3
          • _npmNewestNext:10.9.3
            Ich bin immer noch der Meinung, das du dann da eine 'komische' Installation hast.
              Script v.2025-08-09
              *** BASE SYSTEM ***
              Operating System: Debian GNU/Linux 13 (trixie)
               Static hostname: iobroker
                     Icon name: computer-container
                       Chassis: container ☐
                Virtualization: lxc
                        Kernel: Linux 6.14.8-2-pve
                  Architecture: x86-64
              OS is similar to:
              model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
              Docker          : false
              Virtualization  : lxc
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               11:16:57 up  2:46,  1 user,  load average: 0.00, 0.00, 0.00
              CPU threads: 2
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'trixie'!
              *** TIME AND TIMEZONES ***
                             Local time: Wed 2025-08-13 11:16:57 CEST
                         Universal time: Wed 2025-08-13 09:16:57 UTC
                               RTC time: n/a
                            NTP service: inactive
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              michael
              HOME=/home/michael
              GROUPS=michael sudo users iobroker
              iobroker
              HOME=/home/iobroker
              SUDO_HOME=/home/michael
              GROUPS=iobroker tty dialout audio video plugdev redis
              *** DISPLAY-SERVER SETUP ***
              Display-Server: 	false
              Unit display-manager.service could not be found.
              Display-Manager:
              Desktop:
              Session: 		tty
              *** MEMORY ***
              Mem:            8.6G        1.2G        6.9G        1.2M        481M        7.4G
              Swap:           536M          0B        536M
              Total:          9.1G        1.2G        7.5G
              Active iob-Instances: 	13
                       8192 M total memory
                       1108 M used memory
                       1209 M active memory
                        285 M inactive memory
                       6625 M free memory
                          0 M buffer memory
                        459 M swap cache
                        512 M total swap
                          0 M used swap
                        512 M free swap
              top - 11:16:58 up  2:46,  1 user,  load average: 0.00, 0.00, 0.00
              Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  4.3 us,  4.3 sy,  0.0 ni, 87.0 id,  0.0 wa,  0.0 hi,  4.3 si,  0.0 st
              MiB Mem :   8192.0 total,   6624.1 free,   1109.5 used,    459.4 buff/cache
              MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7082.5 avail Mem
              *** FAILED SERVICES ***
                UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
              * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
              Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                      ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                      SUB    -> The low-level unit activation state, values depend on unit type.
              1 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              dmesg: read kernel buffer failed: Operation not permitted
              No critical errors detected
              *** FILESYSTEM ***
              Filesystem                       Type      Size  Used Avail Use% Mounted on
              /dev/mapper/pve-vm--100--disk--0 ext4       25G  4.9G   19G  21% /
              none                             tmpfs     492K  4.0K  488K   1% /dev
              /dev/mapper/pve-root             ext4       67G  3.9G   60G   7% /dev/ttyACM0
              udev                             devtmpfs   32G     0   32G   0% /dev/tty
              tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
              tmpfs                            tmpfs      13G  152K   13G   1% /run
              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs                            tmpfs      32G  976K   32G   1% /tmp
              tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
              Show mounted filesystems:
              TARGET         SOURCE                                                 FSTYPE OPTIONS
              /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
              `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
              /var:
              418M	/var/
              213M	/var/lib
              130M	/var/cache
              126M	/var/cache/apt
              89M	/var/lib/apt
              Archived and active journals take up 24M in the file system.
              /opt/iobroker/backups:
              1.8M	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              92M	/opt/iobroker/iobroker-data/
              56M	/opt/iobroker/iobroker-data/files
              38M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
              6.8M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
              5.3M	/opt/iobroker/iobroker-data/objects.jsonl
              3.9M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
              3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
              3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
              Zigbee Network Settings on your coordinator/in nvbackup are:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              To unmask the settings run 'iob diag --unmask'
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v20.19.4
              /usr/bin/node 		v20.19.4
              /usr/bin/npm 		10.8.2
              /usr/bin/npx 		10.8.2
              /usr/bin/corepack 	0.32.0
              nodejs:
                Installed: 20.19.4-1nodesource1
                Candidate: 22.18.0-1nodesource1
                Version table:
                   22.18.0-1nodesource1 600
                      500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                   22.17.1-1nodesource1 600
                   22.17.0-1nodesource1 600
                   22.16.0-1nodesource1 600
                   22.15.1-1nodesource1 600
                   22.15.0-1nodesource1 600
                   22.14.0-1nodesource1 600
                   22.13.1-1nodesource1 600
                   22.13.0-1nodesource1 600
                   22.12.0-1nodesource1 600
                   22.11.0-1nodesource1 600
                   22.10.0-1nodesource1 600
                   22.9.0-1nodesource1 600
                   22.8.0-1nodesource1 600
                   22.7.0-1nodesource1 600
                   22.6.0-1nodesource1 600
                   22.5.1-1nodesource1 600
                   22.5.0-1nodesource1 600
                   22.4.1-1nodesource1 600
                   22.4.0-1nodesource1 600
                   22.3.0-1nodesource1 600
                   22.2.0-1nodesource1 600
                   22.1.0-1nodesource1 600
                   22.0.0-1nodesource1 600
               *** 20.19.4-1nodesource1 100
                      100 /var/lib/dpkg/status
                   20.19.2+dfsg-1 500
                      500 http://deb.debian.org/debian trixie/main amd64 Packages
              No problems detected
              Errors in npm tree: 0
              Checking for nodejs vulnerability:
              *** ioBroker-Installation ***
              ioBroker Status
              At least one iobroker host is running.
              Objects type: redis
              States  type: redis
              Hosts:
              iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 9992)
              Core adapters versions
              js-controller: 	7.0.6
              admin: 		7.6.17
              javascript: 	8.9.2
              nodejs modules from github: 	1
              +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#e43328543d35c4555a4a3f3e595dd16417978d85)
              Adapter State
              + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
              + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
              + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
              + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Adapters
              Used repository: stable
              Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
              Adapter    "admin"        : 7.6.17   , installed 7.6.17
              Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
              Adapter    "ical"         : 1.16.2   , installed 1.16.2
              Adapter    "javascript"   : 8.9.2    , installed 8.9.2
              Controller "js-controller": 7.0.6    , installed 7.0.6
              Adapter    "lovelace"     : 4.1.15   , installed 4.1.15
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "openknx"      : 0.9.0    , installed 0.9.0
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "socketio"     : 6.7.1    , installed 7.0.8
              Adapter    "web"          : 7.0.8    , installed 7.0.8
              Adapter    "ws"           : 2.6.2    , installed 3.0.19
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
              Objects and States
              Objects: 	18993
              States: 	7104
              W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
              Hit:1 http://security.debian.org trixie-security InRelease
              Hit:2 http://deb.debian.org/debian trixie InRelease
              Hit:3 http://deb.debian.org/debian trixie-updates InRelease
              Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
              Reading package lists...
              Pending Updates: 1
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:42847         0.0.0.0:*               LISTEN      1000       2535409    539/io.yahka.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        2535936    323/mosquitto
              tcp        0      0 127.0.0.1:41907         0.0.0.0:*               LISTEN      1000       2535413    539/io.yahka.0
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2528715    1/init
              tcp        0      0 127.0.0.1:34161         0.0.0.0:*               LISTEN      1000       2535405    539/io.yahka.0
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2535667    288/master
              tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        2535506    138/redis-server 12
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2535668    288/master
              tcp6       0      0 ::1:6379                :::*                    LISTEN      105        2535507    138/redis-server 12
              tcp6       0      0 :::36289                :::*                    LISTEN      1000       2535327    539/io.yahka.0
              tcp6       0      0 :::33881                :::*                    LISTEN      1000       2535325    539/io.yahka.0
              tcp6       0      0 :::1883                 :::*                    LISTEN      107        2535937    323/mosquitto
              tcp6       0      0 :::32939                :::*                    LISTEN      1000       2535329    539/io.yahka.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          2532133    1/init
              tcp6       0      0 :::111                  :::*                    LISTEN      0          2528717    1/init
              tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2535284    524/io.lovelace.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2535370    569/io.web.0
              tcp6       0      0 :::8080                 :::*                    LISTEN      1001       2534659    141/node
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2534661    342/io.admin.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        2529247    132/avahi-daemon: r
              udp        0      0 0.0.0.0:47975           0.0.0.0:*                           106        2529249    132/avahi-daemon: r
              udp        0      0 0.0.0.0:51408           0.0.0.0:*                           1000       2535202    494/io.openknx.0
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2528716    1/init
              udp6       0      0 :::5353                 :::*                                106        2529248    132/avahi-daemon: r
              udp6       0      0 :::43720                :::*                                106        2529250    132/avahi-daemon: r
              udp6       0      0 :::111                  :::*                                0          2528718    1/init
              2025-08-13 09:21:13.403  - error: admin.0 (342) Automatic repository update is not allowed more than once an hour
              2025-08-13 09:36:25.746  - warn: javascript.0 (398) State "mqtt.0.nuki.35C7D56C.lockAction" not found
              2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
              2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.<anonymous> (script.js.common.Zentral.Anwesenheit:29:5)
              2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
              2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
              2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7336:48)
              2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at process.processImmediate (node:internal/timers:483:21)
                BigMike71 last edited by
                Moin,
                ich habe nen PI5 mit aktueller Installation laufen und alles soweit aktuell in Iobroker
                gehalten.
                Leider bekomme ich das Node.js nicht mit iob nodesjs-update hochgezogen.
                Es kommt keinerlei ausgabe in der ssh shell...
                komischerweise zeigt auch iob diag nichts an?!?
                Homoran Thomas Braun 2 Replies Last reply Reply Quote 1
                  Installed: 20.19.4-1nodesource1 Candidate: 22.18.0-1nodesource1
                  Da ist die 22er-Quelle aktiv, dafür hängt die 20 ohne Anbindung an ein Repo da herum. Apt wird dir also nun immer die aktuelle Version aus dem 22-Zweig vorschlagen.
                  Und die Version ist auch nicht auf Prio 1001 gepinnt.
                  Das macht aber eigentlich alles iob nodejs-update für dich, wenn du die gewünschte Ziel-Version als Option mit gibst.
                    Homoran Global Moderator Administrators @BigMike71 last edited by
                    @bigmike71 sagte in Wir empfehlen: Node.js 22.x:
                    zeigen 😉
                    Eingabe und (fehlende) Ausgabe bis zum nächsten Prompt
                      BigMike71 @Homoran last edited by Homoran
                      mike@Pi5:~ $ iob diag
                      mike@Pi5:~ $ iob status
                      Objects type: jsonl
                      States  type: jsonl
                      mike@Pi5:~ $
                      mike@Pi5:~ $ iob version
                      7.0.7
                      mike@Pi5:~ $
                      mike@Pi5:~ $
                        Thomas Braun Most Active @BigMike71 last edited by Thomas Braun
                        Deutet auf Netzwerkprobleme hin. Beide Skripte werden jeweils frisch vom Server gezogen. 'Leider' werden aber Fehlermeldungen ausgeblendet, weswegen auch im Terminal nichts zu sehen ist.
                        Versuch es mal mit dem Befehl aus meiner Signatur, alternativ mit
                        curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                          BigMike71 @Thomas Braun last edited by
                          meine Netzwerk läuft hier zu 100%, was sollte da nicht richtig sein?
                          Systemupdate über sudo apt-get update und upgrade geht auch fehlerfrei...
                            @bigmike71
                              BigMike71 @Thomas Braun last edited by BigMike71
                              ========== Start marking the full check here ===========
                              ```bash
                              Script v.2025-08-09
                              *** BASE SYSTEM ***
                               Static hostname: Pi5
                                     Icon name: computer
                                        Kernel: Linux 6.6.47+rpt-rpi-2712
                                  Architecture: arm64
                              OS is similar to:
                              Model           : Raspberry Pi 5 Model B Rev 1.0
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : 64 bit
                               11:33:50 up 51 min,  1 user,  load average: 0.49, 0.43, 0.42
                              CPU threads: 4
                              Operating System is the current Debian stable version codenamed 'bookworm'!
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                                             Local time: Wed 2025-08-13 11:33:50 CEST
                                         Universal time: Wed 2025-08-13 09:33:50 UTC
                                               RTC time: Wed 2025-08-13 09:33:50
                                            NTP service: active
                                        RTC in local TZ: no
                              mike
                              HOME=/home/mike
                              GROUPS=mike adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                              Display-Manager:
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Mem:            8.4G        2.7G        3.6G         11M        2.3G        5.8G
                              Swap:           209M          0B        209M
                              Total:          8.6G        2.7G        3.8G
                              Active iob-Instances:   21
                                       8048 M total memory
                                       2551 M used memory
                                       2817 M active memory
                                       1378 M inactive memory
                                       3424 M free memory
                                        163 M buffer memory
                                       2017 M swap cache
                                        199 M total swap
                                          0 M used swap
                                        199 M free swap
                              top - 11:33:51 up 51 min,  1 user,  load average: 0.49, 0.43, 0.42
                              Tasks: 201 total,   1 running, 200 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8048.3 total,   3423.9 free,   2551.9 used,   2181.0 buff/cache
                              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5496.5 avail Mem
                              * nvmf-autoconnect.service loaded failed failed Connect NVMe-oF subsystems automatically during boot
                              LOAD   = Reflects whether the unit definition was properly loaded.
                              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                              SUB    = The low-level unit activation state, values depend on unit type.
                              *** FILESYSTEM ***
                              udev           devtmpfs  3.8G     0  3.8G   0% /dev
                              tmpfs          tmpfs     1.6G  5.5M  1.6G   1% /run
                              /dev/nvme0n1p2 ext4      229G   19G  199G   9% /
                              tmpfs          tmpfs     4.0G  5.6M  4.0G   1% /dev/shm
                              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                              /dev/nvme0n1p1 vfat      510M   66M  445M  13% /boot/firmware
                              tmpfs          tmpfs     805M     0  805M   0% /run/user/1000
                              [Wed Aug 13 10:42:34 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:32:C2:78 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=6fe73f65-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Wed Aug 13 10:42:37 2025] EXT4-fs (nvme0n1p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                              [Wed Aug 13 10:42:38 2025] EXT4-fs (nvme0n1p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                              /                /dev/nvme0n1p2 ext4   rw,noatime
                              `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              8.1G    /var/
                              3.6G    /var/log
                              3.5G    /var/log/journal/e2767c797fed49779b649eddbed462f7
                              3.1G    /var/cache/apt
                              Archived and active journals take up 3.4G in the file system.
                              108M    /opt/iobroker/backups/
                              229M    /opt/iobroker/iobroker-data/
                              123M    /opt/iobroker/iobroker-data/files
                              84M     /opt/iobroker/iobroker-data/backup-objects
                              47M     /opt/iobroker/iobroker-data/files/admin.admin
                              46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                              20M     /opt/iobroker/iobroker-data/objects.jsonl
                              8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                              4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                              3.7M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/assets/index-DXg_kRe6.js
                              3.7M    /opt/iobroker/iobroker-data/files/hmip.admin/custom/assets/index-HTN9Fhdh.js
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b44d6fa857a4ed1180ce8a582981d5c7-if00-port0
                              *** ZigBee Settings ***
                              HINT:
                              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                              /dev/ttyUSB0
                              HINT:
                              Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                              tcp
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Candidate: 20.19.4-1nodesource1
                                Version table:
                               *** 20.19.4-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                   20.19.3-1nodesource1 1001
                                   20.19.2-1nodesource1 1001
                                   20.19.1-1nodesource1 1001
                                   20.19.0-1nodesource1 1001
                                   20.18.3-1nodesource1 1001
                                   20.18.2-1nodesource1 1001
                                   20.18.1-1nodesource1 1001
                                   20.18.0-1nodesource1 1001
                                   20.17.0-1nodesource1 1001
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                                   18.19.0+dfsg-6~deb12u2 500
                                   18.19.0+dfsg-6~deb12u1 500
                              Need to install the following packages:
                              is-my-node-vulnerable@1.6.1
                              Ok to proceed? (y) y
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              Pi5                 Pi5 (version: 7.0.7, hostname: Pi5           , alive, uptime: 2342)
                              admin:          7.7.2
                              javascript:     9.0.11
                              nodejs modules from github:     2
                              +-- iobroker.govee-app@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#f7848a9817a15db547dd5fc7f332822752d9bed6)
                              `-- iobroker.zigbee@3.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#ff370acc5c61473cc0a008ff15a1f244a9bb73ee)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : Pi5                                      -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                system.adapter.airquality.0             : airquality            : Pi5                                      - disabled
                              + system.adapter.ankersolix2.0            : ankersolix2           : Pi5                                      -  enabled
                              + system.adapter.backitup.0               : backitup              : Pi5                                      -  enabled
                              + system.adapter.denon.0                  : denon                 : Pi5                                      -  enabled
                              + system.adapter.enigma2.0                : enigma2               : Pi5                                      -  enabled
                              + system.adapter.govee-app.0              : govee-app             : Pi5                                      -  enabled
                                system.adapter.govee-local.0            : govee-local           : Pi5                                      - disabled
                              + system.adapter.hmip.0                   : hmip                  : Pi5                                      -  enabled
                                system.adapter.homeconnect.0            : homeconnect           : Pi5                                      - disabled
                              + system.adapter.hue.0                    : hue                   : Pi5                                      -  enabled, port: 443
                              + system.adapter.influxdb.0               : influxdb              : Pi5                                      -  enabled, port: 8086
                              + system.adapter.influxdb.1               : influxdb              : Pi5                                      -  enabled, port: 8086
                                system.adapter.influxdb.2               : influxdb              : Pi5                                      - disabled, port: 8086
                              + system.adapter.iot.0                    : iot                   : Pi5                                      -  enabled
                              + system.adapter.javascript.0             : javascript            : Pi5                                      -  enabled
                                system.adapter.lgtv.0                   : lgtv                  : Pi5                                      - disabled
                              + system.adapter.modbus.0                 : modbus                : Pi5                                      -  enabled
                                system.adapter.modbus.1                 : modbus                : Pi5                                      - disabled
                                system.adapter.myuplink.0               : myuplink              : Pi5                                      - disabled
                              + system.adapter.rpi2.0                   : rpi2                  : Pi5                                      -  enabled
                              + system.adapter.shelly.0                 : shelly                : Pi5                                      -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.shelly.1                 : shelly                : Pi5                                      -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.simple-api.0             : simple-api            : Pi5                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              + system.adapter.sonoff.0                 : sonoff                : Pi5                                      -  enabled, port: 1884, bind: 0.0.0.0
                                system.adapter.twinkly.0                : twinkly               : Pi5                                      - disabled
                                system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Pi5                                      - disabled
                              + system.adapter.zigbee.0                 : zigbee                : Pi5                                      -  enabled, port: /dev/ttyUSB0
                              + system.adapter.zigbee.1                 : zigbee                : Pi5                                      -  enabled, port: tcp://192.168.0.176:6638
                              + instance is alive
                              Active repo(s): beta
                              Used repository: beta
                              Adapter    "admin"        : 7.7.2    , installed 7.7.2
                              Adapter    "airquality"   : 0.1.5    , installed 0.1.5
                              Adapter    "ankersolix2"  : 2.2.0    , installed 2.2.0
                              Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                              Adapter    "denon"        : 1.15.12  , installed 1.15.12
                              Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
                              Adapter    "govee-local"  : 0.2.8    , installed 0.2.8
                              Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                              Adapter    "hue"          : 3.16.2   , installed 3.16.2
                              Adapter    "iot"          : 3.6.0    , installed 3.6.0
                              Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                              Controller "js-controller": 7.0.7    , installed 7.0.7
                              Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                              Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                              Adapter    "myuplink"     : 0.8.4    , installed 0.8.4
                              Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                              Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                              Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                              Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                              Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
                              Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                              Adapter    "zigbee"       : 3.0.3    , installed 3.0.3
                              Objects and States
                              Objects:        8338
                              States:         6601
                              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:5 https://repos.influxdata.com/debian stable InRelease
                              Hit:6 https://apt.grafana.com stable InRelease
                              Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Reading package lists... Done
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       66414      60339/io.sonoff.0
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       68265      61131/io.shelly.1
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       65007      59763/iobroker.js-c
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       65002      59763/iobroker.js-c
                              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        6656       961/pihole-FTL
                              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        6655       961/pihole-FTL
                              tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        1992       961/pihole-FTL
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6328       853/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:61209         0.0.0.0:*               LISTEN      0          7219       836/python3
                              tcp6       0      0 :::443                  :::*                    LISTEN      999        6658       961/pihole-FTL
                              tcp6       0      0 :::80                   :::*                    LISTEN      999        6657       961/pihole-FTL
                              tcp6       0      0 :::53                   :::*                    LISTEN      999        1994       961/pihole-FTL
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          6330       853/sshd: /usr/sbin
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       69944      61166/io.simple-api
                              tcp6       0      0 :::8086                 :::*                    LISTEN      995        6668       909/influxd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       63399      59781/io.admin.0
                              tcp6       0      0 :::3000                 :::*                    LISTEN      106        6712       1025/grafana
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1798       706/avahi-daemon: r
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       65490      60310/io.shelly.0
                              udp        0      0 0.0.0.0:43039           0.0.0.0:*                           1001       137700     60310/io.shelly.0
                              udp        0      0 0.0.0.0:60398           0.0.0.0:*                           104        1800       706/avahi-daemon: r
                              udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        1991       961/pihole-FTL
                              udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        9268       961/pihole-FTL
                              udp6       0      0 :::5353                 :::*                                104        1799       706/avahi-daemon: r
                              udp6       0      0 :::34332                :::*                                104        1801       706/avahi-daemon: r
                              udp6       0      0 :::53                   :::*                                999        1993       961/pihole-FTL
                              udp6       0      0 :::123                  :::*                                999        5936       961/pihole-FTL
                              2025-08-13 11:33:15.110  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                              2025-08-13 11:33:32.234  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
                              2025-08-13 11:33:32.290  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_absolut" has to be type "number" but received type "string"
                              2025-08-13 11:33:32.334  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                              2025-08-13 11:33:35.920  - info: influxdb.0 (59873) Store 23 buffered influxDB history points
                              2025-08-13 11:33:55.130  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Aussentemperatur" has to be type "number" but received type "string"
                              2025-08-13 11:33:55.176  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Gefuehlte_Temperatur" has to be type "number" but received type "string"
                              2025-08-13 11:33:55.232  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind" has to be type "number" but received type "string"
                              2025-08-13 11:33:55.274  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
                              2025-08-13 11:33:55.356  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_absolut" has to be type "number" but received type "string"
                              2025-08-13 11:33:55.403  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                              2025-08-13 11:34:05.921  - info: influxdb.0 (59873) Store 29 buffered influxDB history points
                              2025-08-13 11:34:11.383  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
                              2025-08-13 11:34:12.170  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Aussentemperatur" has to be type "number" but received type "string"
                              2025-08-13 11:34:12.221  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Gefuehlte_Temperatur" has to be type "number" but received type "string"
                              2025-08-13 11:34:12.272  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
                              2025-08-13 11:34:12.316  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_absolut" has to be type "number" but received type "string"
                              2025-08-13 11:34:12.358  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                              2025-08-13 11:34:29.105  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Aussentemperatur" has to be type "number" but received type "string"
                              2025-08-13 11:34:29.161  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Gefuehlte_Temperatur" has to be type "number" but received type "string"
                              2025-08-13 11:34:29.235  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind" has to be type "number" but received type "string"
                              2025-08-13 11:34:29.282  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
                              2025-08-13 11:34:29.329  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_absolut" has to be type "number" but received type "string"
                              2025-08-13 11:34:29.378  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                              2025-08-13 11:34:29.433  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Sonnenstrahlung" has to be type "number" but received type "string"
                              iob diag has finished.
                              mike@Pi5:~ $ ^C
                              mike@Pi5:~ $
                                @bigmike71
                                Da fehlt der Anfang.
                                  so nun alles einkopiert
                                    @bigmike71
                                    iob nodejs-update
                                    ist immer noch schweigsam?
                                    Dann versuch mal
                                    curl -L -o node-update.sh https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/master/node-update.sh && bash node-update.sh
                                      prima das script hat geholfen, jedoch gibt immer noch keine ausgaben bei iob diag und co... was das wohl ist
                                        Was spuckt denn der curl-Befehl aus, wenn das nicht direkt in die bash gekippt wird?
                                        Also nur
                                          mike@Pi5:~ $ curl -L -o node-update.sh https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/master/node-update.sh
                                            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                          100 13917  100 13917    0     0  65309      0 --:--:-- --:--:-- --:--:-- 65646
                                          mike@Pi5:~ $
                                            @bigmike71
                                            Nix zu sehen.
                                            Auf meinem System funktioniert aber auch der direkte Aufruf via
                                            iob diag
                                            oder
                                            iob nodesjs-update
                                            Keine Ahnung, was das dann bei dir ist.
                                            202
                                            23817
