    4. Wir empfehlen: Node.js 22.x
      Thomas Braun Most Active @lessthanmore last edited by
      @lessthanmore sagte in Wir empfehlen: Node.js 22.x:
      Bin jetzt mit der "alten Anleitung" zurück auf 20.
      Ich bin immer noch der Meinung, das du dann da eine 'komische' Installation hast.
        lessthanmore @Thomas Braun last edited by
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 13 (trixie)
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.14.8-2-pve
            Architecture: x86-64
        OS is similar to:
        model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         11:16:57 up  2:46,  1 user,  load average: 0.00, 0.00, 0.00
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'trixie'!
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2025-08-13 11:16:57 CEST
                   Universal time: Wed 2025-08-13 09:16:57 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        michael
        HOME=/home/michael
        GROUPS=michael sudo users iobroker
        iobroker
        HOME=/home/iobroker
        SUDO_HOME=/home/michael
        GROUPS=iobroker tty dialout audio video plugdev redis
        *** DISPLAY-SERVER SETUP ***
        Display-Server: 	false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session: 		tty
        *** MEMORY ***
        Mem:            8.6G        1.2G        6.9G        1.2M        481M        7.4G
        Swap:           536M          0B        536M
        Total:          9.1G        1.2G        7.5G
        Active iob-Instances: 	13
                 8192 M total memory
                 1108 M used memory
                 1209 M active memory
                  285 M inactive memory
                 6625 M free memory
                    0 M buffer memory
                  459 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        top - 11:16:58 up  2:46,  1 user,  load average: 0.00, 0.00, 0.00
        Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  4.3 us,  4.3 sy,  0.0 ni, 87.0 id,  0.0 wa,  0.0 hi,  4.3 si,  0.0 st
        MiB Mem :   8192.0 total,   6624.1 free,   1109.5 used,    459.4 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7082.5 avail Mem
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                SUB    -> The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--100--disk--0 ext4       25G  4.9G   19G  21% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        /dev/mapper/pve-root             ext4       67G  3.9G   60G   7% /dev/ttyACM0
        udev                             devtmpfs   32G     0   32G   0% /dev/tty
        tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
        tmpfs                            tmpfs      13G  152K   13G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs      32G  976K   32G   1% /tmp
        tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
        Show mounted filesystems:
        TARGET         SOURCE                                                 FSTYPE OPTIONS
        /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
        `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
        /var:
        418M	/var/
        213M	/var/lib
        130M	/var/cache
        126M	/var/cache/apt
        89M	/var/lib/apt
        Archived and active journals take up 24M in the file system.
        /opt/iobroker/backups:
        1.8M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        92M	/opt/iobroker/iobroker-data/
        56M	/opt/iobroker/iobroker-data/files
        38M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
        6.8M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
        5.3M	/opt/iobroker/iobroker-data/objects.jsonl
        3.9M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
        3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
        3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v20.19.4
        /usr/bin/node 		v20.19.4
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.32.0
        nodejs:
          Installed: 20.19.4-1nodesource1
          Candidate: 22.18.0-1nodesource1
          Version table:
             22.18.0-1nodesource1 600
                500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
             22.17.1-1nodesource1 600
             22.17.0-1nodesource1 600
             22.16.0-1nodesource1 600
             22.15.1-1nodesource1 600
             22.15.0-1nodesource1 600
             22.14.0-1nodesource1 600
             22.13.1-1nodesource1 600
             22.13.0-1nodesource1 600
             22.12.0-1nodesource1 600
             22.11.0-1nodesource1 600
             22.10.0-1nodesource1 600
             22.9.0-1nodesource1 600
             22.8.0-1nodesource1 600
             22.7.0-1nodesource1 600
             22.6.0-1nodesource1 600
             22.5.1-1nodesource1 600
             22.5.0-1nodesource1 600
             22.4.1-1nodesource1 600
             22.4.0-1nodesource1 600
             22.3.0-1nodesource1 600
             22.2.0-1nodesource1 600
             22.1.0-1nodesource1 600
             22.0.0-1nodesource1 600
         *** 20.19.4-1nodesource1 100
                100 /var/lib/dpkg/status
             20.19.2+dfsg-1 500
                500 http://deb.debian.org/debian trixie/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        Checking for nodejs vulnerability:
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: redis
        States  type: redis
        Hosts:
        iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 9992)
        Core adapters versions
        js-controller: 	7.0.6
        admin: 		7.6.17
        javascript: 	8.9.2
        nodejs modules from github: 	1
        +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#e43328543d35c4555a4a3f3e595dd16417978d85)
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
        + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
        Adapter    "admin"        : 7.6.17   , installed 7.6.17
        Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
        Adapter    "ical"         : 1.16.2   , installed 1.16.2
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "lovelace"     : 4.1.15   , installed 4.1.15
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "openknx"      : 0.9.0    , installed 0.9.0
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "socketio"     : 6.7.1    , installed 7.0.8
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "ws"           : 2.6.2    , installed 3.0.19
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
        Objects and States
        Objects: 	18993
        States: 	7104
        W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
        Hit:1 http://security.debian.org trixie-security InRelease
        Hit:2 http://deb.debian.org/debian trixie InRelease
        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:42847         0.0.0.0:*               LISTEN      1000       2535409    539/io.yahka.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        2535936    323/mosquitto
        tcp        0      0 127.0.0.1:41907         0.0.0.0:*               LISTEN      1000       2535413    539/io.yahka.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2528715    1/init
        tcp        0      0 127.0.0.1:34161         0.0.0.0:*               LISTEN      1000       2535405    539/io.yahka.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2535667    288/master
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        2535506    138/redis-server 12
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2535668    288/master
        tcp6       0      0 ::1:6379                :::*                    LISTEN      105        2535507    138/redis-server 12
        tcp6       0      0 :::36289                :::*                    LISTEN      1000       2535327    539/io.yahka.0
        tcp6       0      0 :::33881                :::*                    LISTEN      1000       2535325    539/io.yahka.0
        tcp6       0      0 :::1883                 :::*                    LISTEN      107        2535937    323/mosquitto
        tcp6       0      0 :::32939                :::*                    LISTEN      1000       2535329    539/io.yahka.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          2532133    1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          2528717    1/init
        tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2535284    524/io.lovelace.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2535370    569/io.web.0
        tcp6       0      0 :::8080                 :::*                    LISTEN      1001       2534659    141/node
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2534661    342/io.admin.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        2529247    132/avahi-daemon: r
        udp        0      0 0.0.0.0:47975           0.0.0.0:*                           106        2529249    132/avahi-daemon: r
        udp        0      0 0.0.0.0:51408           0.0.0.0:*                           1000       2535202    494/io.openknx.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2528716    1/init
        udp6       0      0 :::5353                 :::*                                106        2529248    132/avahi-daemon: r
        udp6       0      0 :::43720                :::*                                106        2529250    132/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          2528718    1/init
        2025-08-13 09:21:13.403  - error: admin.0 (342) Automatic repository update is not allowed more than once an hour
        2025-08-13 09:36:25.746  - warn: javascript.0 (398) State "mqtt.0.nuki.35C7D56C.lockAction" not found
        2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
        2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.<anonymous> (script.js.common.Zentral.Anwesenheit:29:5)
        2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7336:48)
        2025-08-13 09:36:25.749  - warn: javascript.0 (398)     at process.processImmediate (node:internal/timers:483:21)
          BigMike71 last edited by
          Moin,
          ich habe nen PI5 mit aktueller Installation laufen und alles soweit aktuell in Iobroker
          gehalten.
          Leider bekomme ich das Node.js nicht mit iob nodesjs-update hochgezogen.
          Es kommt keinerlei ausgabe in der ssh shell...
          komischerweise zeigt auch iob diag nichts an?!?
          Homoran Thomas Braun 2 Replies Last reply Reply Quote 1
            Thomas Braun Most Active @lessthanmore last edited by Thomas Braun
            Installed: 20.19.4-1nodesource1 Candidate: 22.18.0-1nodesource1
            Da ist die 22er-Quelle aktiv, dafür hängt die 20 ohne Anbindung an ein Repo da herum. Apt wird dir also nun immer die aktuelle Version aus dem 22-Zweig vorschlagen.
            Und die Version ist auch nicht auf Prio 1001 gepinnt.
            Das macht aber eigentlich alles iob nodejs-update für dich, wenn du die gewünschte Ziel-Version als Option mit gibst.
              Homoran Global Moderator Administrators @BigMike71 last edited by
              @bigmike71 sagte in Wir empfehlen: Node.js 22.x:
              zeigen 😉
              Eingabe und (fehlende) Ausgabe bis zum nächsten Prompt
                BigMike71 @Homoran last edited by Homoran
                mike@Pi5:~ $ iob diag
                mike@Pi5:~ $ iob status
                Objects type: jsonl
                States  type: jsonl
                mike@Pi5:~ $
                mike@Pi5:~ $ iob version
                7.0.7
                mike@Pi5:~ $
                mike@Pi5:~ $
                  Thomas Braun Most Active @BigMike71 last edited by Thomas Braun
                  Deutet auf Netzwerkprobleme hin. Beide Skripte werden jeweils frisch vom Server gezogen. 'Leider' werden aber Fehlermeldungen ausgeblendet, weswegen auch im Terminal nichts zu sehen ist.
                  Versuch es mal mit dem Befehl aus meiner Signatur, alternativ mit
                  curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                    BigMike71 @Thomas Braun last edited by
                    meine Netzwerk läuft hier zu 100%, was sollte da nicht richtig sein?
                    Systemupdate über sudo apt-get update und upgrade geht auch fehlerfrei...
                      @bigmike71
                        BigMike71 @Thomas Braun last edited by BigMike71
                        ========== Start marking the full check here ===========
                        ```bash
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                         Static hostname: Pi5
                               Icon name: computer
                                  Kernel: Linux 6.6.47+rpt-rpi-2712
                            Architecture: arm64
                        OS is similar to:
                        Model           : Raspberry Pi 5 Model B Rev 1.0
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                         11:33:50 up 51 min,  1 user,  load average: 0.49, 0.43, 0.42
                        CPU threads: 4
                        Operating System is the current Debian stable version codenamed 'bookworm'!
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                                       Local time: Wed 2025-08-13 11:33:50 CEST
                                   Universal time: Wed 2025-08-13 09:33:50 UTC
                                         RTC time: Wed 2025-08-13 09:33:50
                                      NTP service: active
                                  RTC in local TZ: no
                        mike
                        HOME=/home/mike
                        GROUPS=mike adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:            8.4G        2.7G        3.6G         11M        2.3G        5.8G
                        Swap:           209M          0B        209M
                        Total:          8.6G        2.7G        3.8G
                        Active iob-Instances:   21
                                 8048 M total memory
                                 2551 M used memory
                                 2817 M active memory
                                 1378 M inactive memory
                                 3424 M free memory
                                  163 M buffer memory
                                 2017 M swap cache
                                  199 M total swap
                                    0 M used swap
                                  199 M free swap
                        top - 11:33:51 up 51 min,  1 user,  load average: 0.49, 0.43, 0.42
                        Tasks: 201 total,   1 running, 200 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   8048.3 total,   3423.9 free,   2551.9 used,   2181.0 buff/cache
                        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5496.5 avail Mem
                        * nvmf-autoconnect.service loaded failed failed Connect NVMe-oF subsystems automatically during boot
                        LOAD   = Reflects whether the unit definition was properly loaded.
                        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                        SUB    = The low-level unit activation state, values depend on unit type.
                        *** FILESYSTEM ***
                        udev           devtmpfs  3.8G     0  3.8G   0% /dev
                        tmpfs          tmpfs     1.6G  5.5M  1.6G   1% /run
                        /dev/nvme0n1p2 ext4      229G   19G  199G   9% /
                        tmpfs          tmpfs     4.0G  5.6M  4.0G   1% /dev/shm
                        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                        /dev/nvme0n1p1 vfat      510M   66M  445M  13% /boot/firmware
                        tmpfs          tmpfs     805M     0  805M   0% /run/user/1000
                        [Wed Aug 13 10:42:34 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:32:C2:78 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=6fe73f65-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Wed Aug 13 10:42:37 2025] EXT4-fs (nvme0n1p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                        [Wed Aug 13 10:42:38 2025] EXT4-fs (nvme0n1p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                        /                /dev/nvme0n1p2 ext4   rw,noatime
                        `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        8.1G    /var/
                        3.6G    /var/log
                        3.5G    /var/log/journal/e2767c797fed49779b649eddbed462f7
                        3.1G    /var/cache/apt
                        Archived and active journals take up 3.4G in the file system.
                        108M    /opt/iobroker/backups/
                        229M    /opt/iobroker/iobroker-data/
                        123M    /opt/iobroker/iobroker-data/files
                        84M     /opt/iobroker/iobroker-data/backup-objects
                        47M     /opt/iobroker/iobroker-data/files/admin.admin
                        46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                        20M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                        4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                        3.7M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/assets/index-DXg_kRe6.js
                        3.7M    /opt/iobroker/iobroker-data/files/hmip.admin/custom/assets/index-HTN9Fhdh.js
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b44d6fa857a4ed1180ce8a582981d5c7-if00-port0
                        *** ZigBee Settings ***
                        HINT:
                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                        /dev/ttyUSB0
                        HINT:
                        Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                        tcp
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Candidate: 20.19.4-1nodesource1
                          Version table:
                         *** 20.19.4-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                             20.19.3-1nodesource1 1001
                             20.19.2-1nodesource1 1001
                             20.19.1-1nodesource1 1001
                             20.19.0-1nodesource1 1001
                             20.18.3-1nodesource1 1001
                             20.18.2-1nodesource1 1001
                             20.18.1-1nodesource1 1001
                             20.18.0-1nodesource1 1001
                             20.17.0-1nodesource1 1001
                             20.16.0-1nodesource1 1001
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             18.19.0+dfsg-6~deb12u2 500
                             18.19.0+dfsg-6~deb12u1 500
                        Need to install the following packages:
                        is-my-node-vulnerable@1.6.1
                        Ok to proceed? (y) y
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        Pi5                 Pi5 (version: 7.0.7, hostname: Pi5           , alive, uptime: 2342)
                        js-controller:  7.0.7
                        admin:          7.7.2
                        javascript:     9.0.11
                        nodejs modules from github:     2
                        +-- iobroker.govee-app@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#f7848a9817a15db547dd5fc7f332822752d9bed6)
                        `-- iobroker.zigbee@3.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#ff370acc5c61473cc0a008ff15a1f244a9bb73ee)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : Pi5                                      -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          system.adapter.airquality.0             : airquality            : Pi5                                      - disabled
                        + system.adapter.ankersolix2.0            : ankersolix2           : Pi5                                      -  enabled
                        + system.adapter.backitup.0               : backitup              : Pi5                                      -  enabled
                        + system.adapter.denon.0                  : denon                 : Pi5                                      -  enabled
                        + system.adapter.enigma2.0                : enigma2               : Pi5                                      -  enabled
                        + system.adapter.govee-app.0              : govee-app             : Pi5                                      -  enabled
                          system.adapter.govee-local.0            : govee-local           : Pi5                                      - disabled
                        + system.adapter.hmip.0                   : hmip                  : Pi5                                      -  enabled
                          system.adapter.homeconnect.0            : homeconnect           : Pi5                                      - disabled
                        + system.adapter.hue.0                    : hue                   : Pi5                                      -  enabled, port: 443
                        + system.adapter.influxdb.0               : influxdb              : Pi5                                      -  enabled, port: 8086
                        + system.adapter.influxdb.1               : influxdb              : Pi5                                      -  enabled, port: 8086
                          system.adapter.influxdb.2               : influxdb              : Pi5                                      - disabled, port: 8086
                        + system.adapter.iot.0                    : iot                   : Pi5                                      -  enabled
                        + system.adapter.javascript.0             : javascript            : Pi5                                      -  enabled
                          system.adapter.lgtv.0                   : lgtv                  : Pi5                                      - disabled
                        + system.adapter.modbus.0                 : modbus                : Pi5                                      -  enabled
                          system.adapter.modbus.1                 : modbus                : Pi5                                      - disabled
                          system.adapter.myuplink.0               : myuplink              : Pi5                                      - disabled
                        + system.adapter.rpi2.0                   : rpi2                  : Pi5                                      -  enabled
                        + system.adapter.shelly.0                 : shelly                : Pi5                                      -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shelly.1                 : shelly                : Pi5                                      -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : Pi5                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.sonoff.0                 : sonoff                : Pi5                                      -  enabled, port: 1884, bind: 0.0.0.0
                          system.adapter.twinkly.0                : twinkly               : Pi5                                      - disabled
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Pi5                                      - disabled
                        + system.adapter.zigbee.0                 : zigbee                : Pi5                                      -  enabled, port: /dev/ttyUSB0
                        + system.adapter.zigbee.1                 : zigbee                : Pi5                                      -  enabled, port: tcp://192.168.0.176:6638
                        + instance is alive
                        Active repo(s): beta
                        Used repository: beta
                        Adapter    "admin"        : 7.7.2    , installed 7.7.2
                        Adapter    "airquality"   : 0.1.5    , installed 0.1.5
                        Adapter    "ankersolix2"  : 2.2.0    , installed 2.2.0
                        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                        Adapter    "denon"        : 1.15.12  , installed 1.15.12
                        Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
                        Adapter    "govee-local"  : 0.2.8    , installed 0.2.8
                        Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                        Adapter    "hue"          : 3.16.2   , installed 3.16.2
                        Adapter    "iot"          : 3.6.0    , installed 3.6.0
                        Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                        Controller "js-controller": 7.0.7    , installed 7.0.7
                        Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                        Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                        Adapter    "myuplink"     : 0.8.4    , installed 0.8.4
                        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                        Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                        Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                        Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                        Adapter    "zigbee"       : 3.0.3    , installed 3.0.3
                        Objects and States
                        Objects:        8338
                        States:         6601
                        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:5 https://repos.influxdata.com/debian stable InRelease
                        Hit:6 https://apt.grafana.com stable InRelease
                        Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Reading package lists... Done
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       66414      60339/io.sonoff.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       68265      61131/io.shelly.1
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       65007      59763/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       65002      59763/iobroker.js-c
                        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        6656       961/pihole-FTL
                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        6655       961/pihole-FTL
                        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        1992       961/pihole-FTL
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6328       853/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:61209         0.0.0.0:*               LISTEN      0          7219       836/python3
                        tcp6       0      0 :::443                  :::*                    LISTEN      999        6658       961/pihole-FTL
                        tcp6       0      0 :::80                   :::*                    LISTEN      999        6657       961/pihole-FTL
                        tcp6       0      0 :::53                   :::*                    LISTEN      999        1994       961/pihole-FTL
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          6330       853/sshd: /usr/sbin
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       69944      61166/io.simple-api
                        tcp6       0      0 :::8086                 :::*                    LISTEN      995        6668       909/influxd
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       63399      59781/io.admin.0
                        tcp6       0      0 :::3000                 :::*                    LISTEN      106        6712       1025/grafana
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1798       706/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       65490      60310/io.shelly.0
                        udp        0      0 0.0.0.0:43039           0.0.0.0:*                           1001       137700     60310/io.shelly.0
                        udp        0      0 0.0.0.0:60398           0.0.0.0:*                           104        1800       706/avahi-daemon: r
                        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        1991       961/pihole-FTL
                        udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        9268       961/pihole-FTL
                        udp6       0      0 :::5353                 :::*                                104        1799       706/avahi-daemon: r
                        udp6       0      0 :::34332                :::*                                104        1801       706/avahi-daemon: r
                        udp6       0      0 :::53                   :::*                                999        1993       961/pihole-FTL
                        udp6       0      0 :::123                  :::*                                999        5936       961/pihole-FTL
                        2025-08-13 11:33:15.110  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                        2025-08-13 11:33:32.234  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
                        2025-08-13 11:33:32.290  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_absolut" has to be type "number" but received type "string"
                        2025-08-13 11:33:32.334  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                        2025-08-13 11:33:35.920  - info: influxdb.0 (59873) Store 23 buffered influxDB history points
                        2025-08-13 11:33:55.130  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Aussentemperatur" has to be type "number" but received type "string"
                        2025-08-13 11:33:55.176  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Gefuehlte_Temperatur" has to be type "number" but received type "string"
                        2025-08-13 11:33:55.232  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind" has to be type "number" but received type "string"
                        2025-08-13 11:33:55.274  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
                        2025-08-13 11:33:55.356  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_absolut" has to be type "number" but received type "string"
                        2025-08-13 11:33:55.403  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                        2025-08-13 11:34:05.921  - info: influxdb.0 (59873) Store 29 buffered influxDB history points
                        2025-08-13 11:34:11.383  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
                        2025-08-13 11:34:12.170  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Aussentemperatur" has to be type "number" but received type "string"
                        2025-08-13 11:34:12.221  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Gefuehlte_Temperatur" has to be type "number" but received type "string"
                        2025-08-13 11:34:12.272  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
                        2025-08-13 11:34:12.316  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_absolut" has to be type "number" but received type "string"
                        2025-08-13 11:34:12.358  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                        2025-08-13 11:34:29.105  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Aussentemperatur" has to be type "number" but received type "string"
                        2025-08-13 11:34:29.161  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Gefuehlte_Temperatur" has to be type "number" but received type "string"
                        2025-08-13 11:34:29.235  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind" has to be type "number" but received type "string"
                        2025-08-13 11:34:29.282  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Wind_max" has to be type "number" but received type "string"
                        2025-08-13 11:34:29.329  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_absolut" has to be type "number" but received type "string"
                        2025-08-13 11:34:29.378  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Druck_relativ" has to be type "number" but received type "string"
                        2025-08-13 11:34:29.433  - info: simple-api.0 (61166) State value to set for "0_userdata.0.Wetterstation.Sonnenstrahlung" has to be type "number" but received type "string"
                        iob diag has finished.
                        mike@Pi5:~ $ ^C
                        mike@Pi5:~ $
                          @bigmike71
                          Da fehlt der Anfang.
                            so nun alles einkopiert
                              @bigmike71
                              iob nodejs-update
                              ist immer noch schweigsam?
                              Dann versuch mal
                              curl -L -o node-update.sh https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/master/node-update.sh && bash node-update.sh
                                prima das script hat geholfen, jedoch gibt immer noch keine ausgaben bei iob diag und co... was das wohl ist
                                  Was spuckt denn der curl-Befehl aus, wenn das nicht direkt in die bash gekippt wird?
                                  Also nur
                                    mike@Pi5:~ $ curl -L -o node-update.sh https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/master/node-update.sh
                                      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                    100 13917  100 13917    0     0  65309      0 --:--:-- --:--:-- --:--:-- 65646
                                    mike@Pi5:~ $
                                      @bigmike71
                                      Nix zu sehen.
                                      Auf meinem System funktioniert aber auch der direkte Aufruf via
                                      iob diag
                                      oder
                                      iob nodesjs-update
                                      Keine Ahnung, was das dann bei dir ist.
                                        Thomas Braun Most Active @Thomas Braun last edited by
                                        @BigMike71
                                        Eins fällt mir noch ein...
                                        Schau mal nach den Rechten an /home/iobroker
                                        ls -la /home
                                          @thomas-braun Es war gar nicht der Adapter, sondern zigbee2mqtt selbst. Sorry.
                                          Sollte jetzt passen 🙂
                                          Script v.2025-08-09
                                          *** BASE SYSTEM ***
                                            Virtualization: lxc
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                           12:08:39 up 1 min,  1 user,  load average: 0.55, 0.61, 0.56
                                          CPU threads: 2
                                                         Local time: Wed 2025-08-13 12:08:39 CEST
                                                     Universal time: Wed 2025-08-13 10:08:39 UTC
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          michael
                                          HOME=/home/michael
                                          iobroker
                                          HOME=/home/iobroker
                                          Display-Manager:
                                          Desktop:
                                          Session: 		tty
                                          *** MEMORY ***
                                          Mem:            8.6G        1.1G        7.1G        1.6M        335M        7.5G
                                          Swap:           536M          0B        536M
                                          Total:          9.1G        1.1G        7.7G
                                                   8192 M total memory
                                                   1080 M used memory
                                                   1230 M active memory
                                                    101 M inactive memory
                                                   6792 M free memory
                                                      0 M buffer memory
                                                    319 M swap cache
                                                    512 M total swap
                                                      0 M used swap
                                                    512 M free swap
                                          top - 12:08:39 up 1 min,  1 user,  load average: 0.55, 0.61, 0.56
                                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   8192.0 total,   6791.5 free,   1081.9 used,    319.9 buff/cache
                                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7110.1 avail Mem
                                          *** FILESYSTEM ***
                                          /dev/mapper/pve-vm--100--disk--1 ext4       25G  4.9G   19G  21% /
                                          tmpfs                            tmpfs      32G  1.4M   32G   1% /tmp
                                          /              /dev/mapper/pve-vm--100--disk--1                       ext4   rw,relatime,stripe=16
                                          /var:
                                          418M	/var/
                                          214M	/var/lib
                                          130M	/var/cache
                                          126M	/var/cache/apt
                                          89M	/var/lib/apt
                                          USB-Devices by-id:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/nodejs 	v22.18.0
                                          /usr/bin/node 		v22.18.0
                                          /usr/bin/npm 		10.9.3
                                          /usr/bin/npx 		10.9.3
                                          /usr/bin/corepack 	0.33.0
                                          nodejs:
                                            Installed: 22.18.0-1nodesource1
                                            Version table:
                                           *** 22.18.0-1nodesource1 600
                                               20.19.2+dfsg-1 500
                                          ioBroker Status
                                          Objects type: redis
                                          States  type: redis
                                          Hosts:
                                          iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 61)
                                          admin: 		7.6.17
                                          javascript: 	8.9.2
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects: 	18944
                                          States: 	7107
                                          Hit:1 http://deb.debian.org/debian trixie InRelease
                                          Hit:2 http://security.debian.org trixie-security InRelease
                                          Pending Updates: 0
                                          tcp        0      0 127.0.0.1:44527         0.0.0.0:*               LISTEN      1000       2961001    535/io.yahka.0
                                          tcp        0      0 127.0.0.1:45247         0.0.0.0:*               LISTEN      1000       2961005    535/io.yahka.0
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        2954068    320/mosquitto
                                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2949013    1/init
                                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2954254    288/master
                                          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        2951043    146/redis-server 12
                                          tcp        0      0 127.0.0.1:40947         0.0.0.0:*               LISTEN      1000       2961009    535/io.yahka.0
                                          tcp6       0      0 ::1:6379                :::*                    LISTEN      105        2951044    146/redis-server 12
                                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2954255    288/master
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2951844    565/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2951332    338/io.admin.0
                                          tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2955216    520/io.lovelace.0
                                          tcp6       0      0 :::35035                :::*                    LISTEN      1000       2951772    535/io.yahka.0
                                          tcp6       0      0 :::1883                 :::*                    LISTEN      107        2954069    320/mosquitto
                                          tcp6       0      0 :::33309                :::*                    LISTEN      1000       2951776    535/io.yahka.0
                                          tcp6       0      0 :::111                  :::*                    LISTEN      0          2949015    1/init
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          2953518    1/init
                                          tcp6       0      0 :::41839                :::*                    LISTEN      1000       2951774    535/io.yahka.0
                                          udp        0      0 0.0.0.0:60413           0.0.0.0:*                           106        2950882    131/avahi-daemon: r
                                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2949014    1/init
                                          udp        0      0 0.0.0.0:34687           0.0.0.0:*                           1000       2955115    475/io.openknx.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        2950880    131/avahi-daemon: r
                                          udp6       0      0 :::111                  :::*                                0          2949016    1/init
                                          udp6       0      0 :::5353                 :::*                                106        2950881    131/avahi-daemon: r
                                          udp6       0      0 :::41093                :::*                                106        2950883    131/avahi-daemon: r
                                            @lessthanmore
                                            Das haste aber jetzt auch nicht per iob nodejs-update gemacht, oder?
                                            Das müsste nämlich dann eigentlich anders aussehen.
                                            202
                                            23837
