    4. Solarspeicher Marstek B2500
      Homoran Global Moderator Administrators @manrum1 last edited by
      @manrum1 sagte in Solarspeicher Marstek B2500:
      Log:
      das ist kein debug-log
      beim nächsten mal bitte als Text in code-tags posten
        manrum1 @Homoran last edited by manrum1
        @homoran Anbei, jetzt richtig?
        mqtt.1
        	2025-08-12 12:31:09.073	debug	Client [hm_360111504d46303734153c4a] send to this client "hame_energy/HMA-1/App/7ce712af614f/ctrl": deleted
        mqtt.1
        	2025-08-12 12:31:07.337	debug	Client [hm_360111504d46303734153c4a] send to this client "hame_energy/HMA-1/App/7ce712af614f/ctrl": deleted
        mqtt.1
        	2025-08-12 12:31:07.337	info	Client [hm_360111504d46303734153c4a] publishOnSubscribe
        mqtt.1
        	2025-08-12 12:31:07.231	debug	stateChange mqtt.1.info.connection: {"val":"hm_360111504d46303734153c4a","ack":true,"ts":1754994667228,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1754994520172}
        mqtt.1
        	2025-08-12 12:31:07.137	info	Client [hm_360111504d46303734153c4a] subscribes on "mqtt.1.hame_energy.HMA-1.App.7ce712af614f.ctrl"
        mqtt.1
        	2025-08-12 12:31:07.137	debug	Client [hm_360111504d46303734153c4a] Handle subscribe: {"topic":"hame_energy/HMA-1/App/7ce712af614f/ctrl","qos":0}
        mqtt.1
        	2025-08-12 12:31:07.136	debug	Client [hm_360111504d46303734153c4a] received subscribe package {"cmd":"subscribe","retain":false,"qos":1,"dup":false,"length":44,"topic":null,"payload":null,"subscriptions":[{"topic":"hame_energy/HMA-1/App/7ce712af614f/ctrl","qos":0}],"messageId":1}
        mqtt.1
        	2025-08-12 12:31:07.126	debug	stateChange mqtt.1.info.clients.hm_360111504d46303734153c4a: {"val":true,"ack":true,"ts":1754994667103,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1754994520119}
        mqtt.1
        	2025-08-12 12:31:07.052	debug	Client [hm_360111504d46303734153c4a] with keepalive 60 set timeout to 90 seconds
        mqtt.1
        	2025-08-12 12:31:07.051	info	Client [hm_360111504d46303734153c4a] reconnected. Old secret 1754994520007_430. New secret 1754994666986_8963
        mqtt.1
        	2025-08-12 12:29:40.580	debug	Client [hm_360111504d46303734153c4a] pingreq
        mqtt.1
        	2025-08-12 12:28:42.116	debug	Client [hm_360111504d46303734153c4a] send to this client "hame_energy/HMA-1/App/7ce712af614f/ctrl": deleted
        mqtt.1
        	2025-08-12 12:28:40.408	debug	Client [hm_360111504d46303734153c4a] send to this client "hame_energy/HMA-1/App/7ce712af614f/ctrl": deleted
        mqtt.1
        	2025-08-12 12:28:40.406	info	Client [hm_360111504d46303734153c4a] publishOnSubscribe
        mqtt.1
        	2025-08-12 12:28:40.206	info	Client [hm_360111504d46303734153c4a] subscribes on "mqtt.1.hame_energy.HMA-1.App.7ce712af614f.ctrl"
        mqtt.1
        	2025-08-12 12:28:40.205	debug	Found object for topic "hame_energy/HMA-1/App/7ce712af614f/ctrl" = mqtt.1.hame_energy.HMA-1.App.7ce712af614f.ctrl
        mqtt.1
        	2025-08-12 12:28:40.203	debug	Check object for topic "hame_energy/HMA-1/App/7ce712af614f/ctrl"
        mqtt.1
        	2025-08-12 12:28:40.203	debug	Client [hm_360111504d46303734153c4a] Handle subscribe: {"topic":"hame_energy/HMA-1/App/7ce712af614f/ctrl","qos":0}
        mqtt.1
        	2025-08-12 12:28:40.202	debug	Client [hm_360111504d46303734153c4a] received subscribe package {"cmd":"subscribe","retain":false,"qos":1,"dup":false,"length":44,"topic":null,"payload":null,"subscriptions":[{"topic":"hame_energy/HMA-1/App/7ce712af614f/ctrl","qos":0}],"messageId":1}
        mqtt.1
        	2025-08-12 12:28:40.175	debug	stateChange mqtt.1.info.connection: {"val":"hm_360111504d46303734153c4a","ack":true,"ts":1754994520172,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1754994520172}
        mqtt.1
        	2025-08-12 12:28:40.123	debug	stateChange mqtt.1.info.clients.hm_360111504d46303734153c4a: {"val":true,"ack":true,"ts":1754994520119,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1754994520119}
        mqtt.1
        	2025-08-12 12:28:40.094	debug	Client [hm_360111504d46303734153c4a] with keepalive 60 set timeout to 90 seconds
        mqtt.1
        	2025-08-12 12:28:40.060	info	Client [hm_360111504d46303734153c4a] connected with secret 1754994520007_430
        mqtt.1
        	2025-08-12 12:28:19.346	debug	stateChange mqtt.1.info.connection: {"val":"","ack":true,"ts":1754994499343,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1754994499343}
        mqtt.1
        	2025-08-12 12:28:19.298	debug	stateChange mqtt.1.info.clients.hm_360111504d46303734153c4a: {"val":false,"ack":true,"ts":1754994499295,"q":0,"from":"system.adapter.mqtt.1","user":"system.user.admin","lc":1754994499295}
        mqtt.1
        	2025-08-12 12:28:19.197	info	Starting MQTT authenticated server on 0.0.0.0:1890
        mqtt.1
        	2025-08-12 12:28:19.027	info	starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.4, js-controller: 7.0.6
        mqtt.1
        	2025-08-12 12:28:18.868	debug	Plugin sentry Do not initialize Plugin (enabled=false)
        mqtt.1
        	2025-08-12 12:28:13.657	info	terminating
        mqtt.1
        	2025-08-12 12:28:13.156	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        mqtt.1
        	2025-08-12 12:28:13.156	info	terminating
        mqtt.1
        	2025-08-12 12:28:13.154	info	Got terminate signal TERMINATE_YOURSELF
        Daten schauen jetzt so aus:
        • Marc Berg
          Marc Berg Most Active @manrum1 last edited by Marc Berg
          Was mache ich falsch?
          Der Speicher sendet nicht von sich aus, wenn ich das richtig lese. Du musst im Topic
          hame_energy/HMA-1/App/<MAC-ID>/ctrl
          cd=01
          reinschreiben. Dann sollten Werte kommen.
          EDIT: Hast du ja schon, ...
          • haselchen
            haselchen Most Active @manrum1 last edited by
            @manrum1
            Hilft Dir das Video evtl. weiter?
            https://www.youtube.com/watch?v=VKYjrlfsUiM
            Habs vor Wochen mal überflogen, weil mich der Speicher auch interessiert hat.
              manrum1 @Marc Berg last edited by manrum1
              @marc-berg said in Solarspeicher Marstek B2500:
              cd=01
              Hallo Marc,
              habs probiert, passieren tut leider nichts. Habe diese 3 Meldungen im Log:
              mqtt.1
              	2025-08-13 11:53:55.159	debug	Client [hm_360111504d46303734153c4a] send to this client "hame_energy/HMA-1/App/7ce712af614f/ctrl": deleted
              mqtt.1
              	2025-08-13 11:53:55.135	info	Client [hm_360111504d46303734153c4a] publishOnSubscribe
              mqtt.1
              	2025-08-13 11:53:54.933	info	Client [hm_360111504d46303734153c4a] subscribes on "mqtt.1.hame_energy.HMA-1.App.7ce712af614f.ctrl"
              Muss ich an den Adapter-Einstellungen noch was ändern? Was bedeutet cd=01?
              Was muss ich wegen der Meldung
              mqtt.1
              	2025-08-13 12:03:15.852	warn	No ioBroker changes will be published to the clients. Set the "publish" option in the adapter settings to subscribe for relevant changes
              einstellen?
              Danke im Voraus!
              haselchen Marc Berg 2 Replies Last reply Reply Quote 0
              • haselchen
                @manrum1
                Video angucken war / ist Dir zu schwierig ?
                  manrum1 @haselchen last edited by
                  @haselchen Ich habe mir das schon angeschaut. Dorts gehts ja nicht um den iobroker sondern nur um die HA-Integration. Am Gerät selbst habe ich alles eingestellt, was auch im Video gezeigt wird. Oder habe ich was übersehen?
                  • haselchen
                    haselchen Most Active @manrum1 last edited by haselchen
                    @manrum1
                    Dann hast Du es anscheinend nicht gesehen bzw. nicht verstanden.
                    Dort wird zwar über die HA Einbindung gesprochen, aber wie MQTT aktiviert wird und wie die GUI dazu dann aussieht etc. wird alles in dem Video erklärt.
                    Edit: Minute 5.03
                      @haselchen Danke für Deine freundlichen Kommentare. Schau mal oben in meine Postings zu meinen Einstellungen, dann reden wir weiter wer hier was nicht verstanden hat.
                      • Marc Berg
                        Hast du den Wert als "unbestätigt" gesendet? Sonst wird nichts passieren.
                          @marc-berg Ja, habe ich schon alles probiert. 😢
                          Marc Berg haselchen 2 Replies Last reply Reply Quote 0
                          • Marc Berg
                            Dann weiß ich es auch nicht, jedenfalls ist es hier so beschrieben:
                            https://eu.hamedata.com/ems/mqtt/index.html
                            • haselchen
                              @manrum1
                              Da wir hier beide anscheinend auf dem Schlauch stehen 😉
                              HA installieren , dann nach Video Anleitung den Marstek integrieren und per HA Adapter in Iobroker holen.
                              Da würde ich gar nicht lange fackeln , wenn’s dafür zig Anleitungen gibt.
                                warum zeigst du nichts?
                                das würde denen, die dir versuchen zu helfen, einiges erleichtern
                                  @homoran Ich wüsste nicht, was ich noch zeigen könnte?
                                    Gonzokalle last edited by
                                    Ich habe jetzt schon so viel über den B2500 und Mqtt gelesen, dass ich jetzt nur Halbwissen habe.
                                    Vielleicht kann mich mal jemand aufklären?
                                    Man kann wohl Mqtt für den B2500 beim Support freischalten lassen?
                                    Noch nicht probiert. Geht das aktuell?
                                    Dann kann man wohl mit einem Laptop und Bluetooth Mqtt freischalten.
                                    Werden die Daten im Mqtt Adapter dargestellt?
                                    Hat bei mir nicht funktioniert. B2500 wird nicht gefunden.
                                    Dann gibt es wohl noch die Möglichkeit mit einem ESP32 und Bluetooth die Daten vom B2500 auszulesen.
                                    Das hört sich am Besten an.
                                    Wie werden die Daten dann im iobroker übertragen?
                                    Hat das schon mal jemand gemacht?
                                    • haselchen
                                      haselchen Most Active @Gonzokalle last edited by
                                      @gonzokalle
                                      Hast dir mal das Video von Simon42 auf YT dazu angesehen?
                                      Hab es auch irgendwo in den vorherigen Posts verlinkt .
                                        Gonzokalle @haselchen last edited by
                                        @haselchen
                                        Ja das Video kennen ich.
                                        So habe ich es mit Laptop und Bluetooth versucht.
                                        • haselchen
                                          @gonzokalle
                                          Und was kam beim Versuch heraus?
                                          Im Video war’s ja kein Problem 😃
                                            @haselchen
                                            Bei mir schon.
                                            Der B2500 wurde nicht gefunden.🤷
                                            1354
