    4. Wir empfehlen: Node.js 22.x
      Thomas Braun Most Active @BigMike71 last edited by
      @bigmike71
      Nix zu sehen.
      Auf meinem System funktioniert aber auch der direkte Aufruf via
      iob diag
      oder
      iob nodesjs-update
      Keine Ahnung, was das dann bei dir ist.
        Thomas Braun Most Active @Thomas Braun last edited by
        @BigMike71
        Eins fällt mir noch ein...
        Schau mal nach den Rechten an /home/iobroker
        ls -la /home
          lessthanmore @Thomas Braun last edited by
          @thomas-braun Es war gar nicht der Adapter, sondern zigbee2mqtt selbst. Sorry.
          Sollte jetzt passen 🙂
          Script v.2025-08-09
          *** BASE SYSTEM ***
          Operating System: Debian GNU/Linux 13 (trixie)
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.14.8-2-pve
              Architecture: x86-64
          OS is similar to:
          model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           12:08:39 up 1 min,  1 user,  load average: 0.55, 0.61, 0.56
          CPU threads: 2
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'trixie'!
          *** TIME AND TIMEZONES ***
                         Local time: Wed 2025-08-13 12:08:39 CEST
                     Universal time: Wed 2025-08-13 10:08:39 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          michael
          HOME=/home/michael
          GROUPS=michael sudo users iobroker
          iobroker
          HOME=/home/iobroker
          SUDO_HOME=/home/michael
          GROUPS=iobroker tty dialout audio video plugdev redis
          *** DISPLAY-SERVER SETUP ***
          Display-Server: 	false
          Unit display-manager.service could not be found.
          Display-Manager:
          Desktop:
          Session: 		tty
          *** MEMORY ***
          Mem:            8.6G        1.1G        7.1G        1.6M        335M        7.5G
          Swap:           536M          0B        536M
          Total:          9.1G        1.1G        7.7G
          Active iob-Instances: 	13
                   8192 M total memory
                   1080 M used memory
                   1230 M active memory
                    101 M inactive memory
                   6792 M free memory
                      0 M buffer memory
                    319 M swap cache
                    512 M total swap
                      0 M used swap
                    512 M free swap
          top - 12:08:39 up 1 min,  1 user,  load average: 0.55, 0.61, 0.56
          Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8192.0 total,   6791.5 free,   1081.9 used,    319.9 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7110.1 avail Mem
          *** FAILED SERVICES ***
            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                  ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                  SUB    -> The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          dmesg: read kernel buffer failed: Operation not permitted
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--100--disk--1 ext4       25G  4.9G   19G  21% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          /dev/mapper/pve-root             ext4       67G  3.9G   60G   7% /dev/ttyACM0
          udev                             devtmpfs   32G     0   32G   0% /dev/tty
          tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
          tmpfs                            tmpfs      13G  152K   13G   1% /run
          tmpfs                            tmpfs      32G  1.4M   32G   1% /tmp
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
          Show mounted filesystems:
          TARGET         SOURCE                                                 FSTYPE OPTIONS
          /              /dev/mapper/pve-vm--100--disk--1                       ext4   rw,relatime,stripe=16
          `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
          /var:
          418M	/var/
          214M	/var/lib
          130M	/var/cache
          126M	/var/cache/apt
          89M	/var/lib/apt
          Archived and active journals take up 24M in the file system.
          /opt/iobroker/backups:
          1.8M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          92M	/opt/iobroker/iobroker-data/
          56M	/opt/iobroker/iobroker-data/files
          38M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
          6.8M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
          5.3M	/opt/iobroker/iobroker-data/objects.jsonl
          3.9M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
          3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
          3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v22.18.0
          /usr/bin/node 		v22.18.0
          /usr/bin/npm 		10.9.3
          /usr/bin/npx 		10.9.3
          /usr/bin/corepack 	0.33.0
          nodejs:
            Installed: 22.18.0-1nodesource1
            Candidate: 22.18.0-1nodesource1
            Version table:
           *** 22.18.0-1nodesource1 600
                  500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               22.17.1-1nodesource1 600
               22.17.0-1nodesource1 600
               22.16.0-1nodesource1 600
               22.15.1-1nodesource1 600
               22.15.0-1nodesource1 600
               22.14.0-1nodesource1 600
               22.13.1-1nodesource1 600
               22.13.0-1nodesource1 600
               22.12.0-1nodesource1 600
               22.11.0-1nodesource1 600
               22.10.0-1nodesource1 600
               22.9.0-1nodesource1 600
               22.8.0-1nodesource1 600
               22.7.0-1nodesource1 600
               22.6.0-1nodesource1 600
               22.5.1-1nodesource1 600
               22.5.0-1nodesource1 600
               22.4.1-1nodesource1 600
               22.4.0-1nodesource1 600
               22.3.0-1nodesource1 600
               22.2.0-1nodesource1 600
               22.1.0-1nodesource1 600
               22.0.0-1nodesource1 600
               20.19.2+dfsg-1 500
                  500 http://deb.debian.org/debian trixie/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          Checking for nodejs vulnerability:
          *** ioBroker-Installation ***
          ioBroker Status
          At least one iobroker host is running.
          Objects type: redis
          States  type: redis
          Hosts:
          iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 61)
          Core adapters versions
          js-controller: 	7.0.6
          admin: 		7.6.17
          javascript: 	8.9.2
          nodejs modules from github: 	1
          +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#e43328543d35c4555a4a3f3e595dd16417978d85)
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
          + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
          + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
          Adapter    "admin"        : 7.6.17   , installed 7.6.17
          Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
          Adapter    "ical"         : 1.16.2   , installed 1.16.2
          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "lovelace"     : 4.1.15   , installed 4.1.15
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "openknx"      : 0.9.0    , installed 0.9.0
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "socketio"     : 6.7.1    , installed 7.0.8
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "ws"           : 2.6.2    , installed 3.0.19
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
          Objects and States
          Objects: 	18944
          States: 	7107
          W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
          Hit:1 http://deb.debian.org/debian trixie InRelease
          Hit:2 http://security.debian.org trixie-security InRelease
          Hit:3 http://deb.debian.org/debian trixie-updates InRelease
          Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:44527         0.0.0.0:*               LISTEN      1000       2961001    535/io.yahka.0
          tcp        0      0 127.0.0.1:45247         0.0.0.0:*               LISTEN      1000       2961005    535/io.yahka.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        2954068    320/mosquitto
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2949013    1/init
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2954254    288/master
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        2951043    146/redis-server 12
          tcp        0      0 127.0.0.1:40947         0.0.0.0:*               LISTEN      1000       2961009    535/io.yahka.0
          tcp6       0      0 ::1:6379                :::*                    LISTEN      105        2951044    146/redis-server 12
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2954255    288/master
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2951844    565/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2951332    338/io.admin.0
          tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2955216    520/io.lovelace.0
          tcp6       0      0 :::35035                :::*                    LISTEN      1000       2951772    535/io.yahka.0
          tcp6       0      0 :::1883                 :::*                    LISTEN      107        2954069    320/mosquitto
          tcp6       0      0 :::33309                :::*                    LISTEN      1000       2951776    535/io.yahka.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          2949015    1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          2953518    1/init
          tcp6       0      0 :::41839                :::*                    LISTEN      1000       2951774    535/io.yahka.0
          udp        0      0 0.0.0.0:60413           0.0.0.0:*                           106        2950882    131/avahi-daemon: r
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2949014    1/init
          udp        0      0 0.0.0.0:34687           0.0.0.0:*                           1000       2955115    475/io.openknx.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        2950880    131/avahi-daemon: r
          udp6       0      0 :::111                  :::*                                0          2949016    1/init
          udp6       0      0 :::5353                 :::*                                106        2950881    131/avahi-daemon: r
          udp6       0      0 :::41093                :::*                                106        2950883    131/avahi-daemon: r
            Thomas Braun Most Active @lessthanmore last edited by
            @lessthanmore
            Das haste aber jetzt auch nicht per iob nodejs-update gemacht, oder?
            Das müsste nämlich dann eigentlich anders aussehen.
              ag last edited by
              Hallo.
              Habe jetzt mein Multihostsystem auch auf Nodejs22.
              1 Host (RPI5) und 2 Slaves (RPI4/RPI3)
              Der CanBus Adapter wollte erst nicht, Erst nach deinstallation und neubau lief der dann auch.
              Danke an Alle für die Tips und Tricks hier.
              ag
                @thomas-braun Doch, das habe ich.
                Wie müsste es denn aussehen bzw. wie kann ich es korrigieren?
                  @lessthanmore sagte in Wir empfehlen: Node.js 22.x:
                  Kannste so lassen. Ist nicht ganz verkehrt. nodejs-update sollte eigentlich das Paket nodejs mit ganz hoher Priority (1001) führen. Bei dir ist es 'nur' mit 600 eingestellt. Macht aber nix, ist immer noch höhere Prio als der Standard (500).
                  Das könnte allerdings auch der Grund sein, warum das bei dir so komisch reagiert, Prio 1001 knallt diese Versionen ohne Rücksicht auf Verluste auf jedenfall rein, 600 ist nicht ganz so aggressiv.
                    Mutanten @Thomas Braun last edited by
                    Alles klar, dann werde ich das versuchen.
                    Danke und Gruß, Michael
                      BigMike71 @Thomas Braun last edited by
                      @thomas-braun said in Wir empfehlen: Node.js 22.x:
                      ls -la /home
                      mike@Pi5:~ $ ls -la /home
                      total 36
                      drwxr-xr-x  5 root root  4096 Sep  9  2024 .
                      drwxr-xr-x 18 root root  4096 Jul  4  2024 ..
                      drwxr-xr-x  2 root root 20480 Apr 18 17:25 backup
                      drwxr-xr-x  4 mike ****  4096 Jul 15 18:04 iobroker
                      drwx------ 12 mike **** 4096 Aug 13 11:48 mike
                      mike@Pi5:~ $
                      so siehts aus.
                      hast du zufällig auch ein bash script für den iob fix, der macht auch nix mehr, früher gings...
                        Thomas Braun Most Active @BigMike71 last edited by Thomas Braun
                        @bigmike71
                        Haste die **** da selber reingeschrieben oder ist das so?
                        Da sind eh die Rechte verbogen. /home/iobroker muss natürlich auch dem iobroker gehörten und NICHT dem mike.
                          @bigmike71 sagte in Wir empfehlen: Node.js 22.x:
                          früher gings...
                          Bevor du dir die Rechte zerballert hast...
                          sudo chown -R iobroker:iobroker /home/iobroker
                          Das Verzeichnis
                          darf es da auch nicht geben. Oder hast du einen user namens 'backup', der irgendwas tut?
                          Aber dann hätte der die falschen Rechte, der Kram würde dann nicht root gehören. Der hat ein eigenes Home unter /root
                          Also komplett alles irgendwie durcheinandergeschossen.
                            kann ich mir damit was kaputt machen? gibt es einen weg notfalls zurück?
                            keine ahnung warum die rechte so sind, hatte eine normale installation seinerzeit gemacht über ssh
                              Das IST doch schon alles kaputt gefummelt. Mit dem Befehl stellst du das wieder richtig, sodass auch der Befehle wie iob diag und iob nodejs-update wieder funktionieren können. Grund bei dir ist: Die Skripte können nicht heruntergeladen werden, weil der user 'iobroker' in sein eigenes Zuhause nicht reinkommt, weil da jemand an der Tür das Schloss getauscht hat.
                              Und irgendwann danach hast DU die Rechte zerballert. Der user 'iobroker' wird natürlich erstmal mit den richtigen Rechten angelegt.
                              B 1 Reply Last reply Reply Quote 2
                                bean last edited by
                                Das Update des Containers von Buanet auf 11 Latest hat einwandfrei funktioniert - leider kann der eCharts-Adapter keine Bilder mehr versenden und der Eusec Adapter lässt sich nicht starten - entsprechende Issues sind schon eröffnet und warten auf Behandlung.
                                Also wieder zurück auf v10/Node 20, ich muss noch warten...
                                  Pitpilot last edited by Homoran
                                  Der Siemens Simatic S7 Adapter macht leider einen Fehler mit Node.js 22.x und ich musste zurück auf 20 updaten.
                                  Also Vorsicht wenn ihr eine Produktiv System am Laufen habt !!
                                  Kennt das Problem schon jemand?
                                  host.raspberrypi
                                  2025-08-14 12:15:14.244	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.244	error	Caught by controller[0]: Node.js v22.18.0
                                  host.raspberrypi
                                  2025-08-14 12:15:14.244	error	Caught by controller[0]: }
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: ]
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-arm64/node_snap7.node'
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.18.0/linux/arm64/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.242	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.242	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.242	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.242	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
                                  host.raspberrypi
                                  2025-08-14 12:15:14.242	error	Caught by controller[0]: tries: [
                                  host.raspberrypi
                                  2025-08-14 12:15:14.242	error	Caught by controller[0]: at require (node:internal/modules/helpers:135:16) {
                                  host.raspberrypi
                                  2025-08-14 12:15:14.242	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1445:12)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1246:12)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1423:32)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1820:10)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1688:14)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
                                  host.raspberrypi
                                  2025-08-14 12:15:14.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-arm64/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.18.0/linux/arm64/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.239	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.239	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.239	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
                                  host.raspberrypi
                                  2025-08-14 12:15:14.239	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                  host.raspberrypi
                                  2025-08-14 12:15:14.239	error	Caught by controller[0]: ^
                                  host.raspberrypi
                                  2025-08-14 12:15:14.239	error	Caught by controller[0]: throw err;
                                  host.raspberrypi
                                  2025-08-14 12:15:14.238	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
                                  host.raspberrypi
                                  2025-08-14 12:15:12.134	info	instance system.adapter.s7.0 in version "1.4.3" started with pid 6217
                                  host.raspberrypi
                                  2025-08-14 12:15:11.490	info	iobroker npm-rebuild: exit 1
                                  host.raspberrypi
                                  2025-08-14 12:15:10.456	error	iobroker npm-rebuild: Rebuilding native modules failed
                                  vis.0
                                  2025-08-14 12:15:05.035	info	Terminated (NO_ERROR): Without reason
                                  vis.0
                                  2025-08-14 12:15:03.976	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.18.0, js-controller: 7.0.6
                                  host.raspberrypi
                                  2025-08-14 12:14:52.609	info	iobroker npm-rebuild: Rebuilding native modules ...
                                  host.raspberrypi
                                  2025-08-14 12:14:50.956	info	iobroker rebuild
                                  host.raspberrypi
                                  2025-08-14 12:14:50.955	warn	adapter "s7" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                  host.raspberrypi
                                  2025-08-14 12:14:50.955	info	system.adapter.s7.0 will be rebuilt
                                  host.raspberrypi
                                  2025-08-14 12:14:50.955	info	Adapter system.adapter.s7.0 needs rebuild and will be restarted afterwards.
                                  host.raspberrypi
                                  2025-08-14 12:14:50.955	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  host.raspberrypi
                                  2025-08-14 12:14:50.955	error	Caught by controller[0]: Node.js v22.18.0
                                  host.raspberrypi
                                  2025-08-14 12:14:50.955	error	Caught by controller[0]: }
                                  host.raspberrypi
                                  2025-08-14 12:14:50.954	error	Caught by controller[0]: ]
                                  MOD-EDIT:Code in code-tags gesetzt!
                                    Thomas Braun Most Active @Pitpilot last edited by
                                    @pitpilot sagte in Wir empfehlen: Node.js 22.x:
                                    Auch hier muss ein rebuild erfolgen. Da das aber augenscheinlich über den internen Vorgang nicht funktioniert, deinstallier den Adapter mal komplett und installier den dann nochmal frisch von Neu.
                                    mcm1957 P 2 Replies Last reply Reply Quote 0
                                    • mcm1957
                                      mcm1957 @Thomas Braun last edited by
                                      Eine REINSTALLATION sollte m.E. reichen.
                                      Bei einer Deinstallation werden alle ioBroker infos / states etc gelöscht. Bei einer Reinstallation wird nur der Adaptercode (also alles was via npm kommt) deinstalliert und neu installiert. Die Config u States bleiben erhalten.
                                      Bin nur am Handy u kann daher nicht genauer checken. Reinstallation sollte in etwa mit
                                      iob update myadapter@1.2.3
                                      gehen. Sorry wenn sytax fehlerhaft.
                                        ok, vielen dank, nun geht auch wieder diag und co 🙂 👍
                                        • mcm1957
                                          mcm1957 @bean last edited by
                                          @bean said in Wir empfehlen: Node.js 22.x:
                                          Würde mit Erwartungen bei eusec zurüchhaltend sein Brobat hat seit Oktober 2024 keine Aktion mehr auf Github gesetzt ...
                                            @thomas-braun Ich habe 4 Siemens Instanzen installiert. Die Adapter De-und Reinstallation auf meinem Clone System hat zumindest über die GUI auch nichts verändert. Hat mir jemand Konsolen Befehle?
                                            202
                                            23933
