    4. Shelly Adapter - genereller Support
    • Samson71
      Samson71 Global Moderator @wotan2005 last edited by
      @wotan2005
      Der Fehler ist bei entsprechender Vergrößerung auch zu lesen, aber aus Bildern kann man nicht zitieren. Daher bitte Protokolle/Logs immer als Text in Code-Tags </> einbetten und nicht als Briefmarkenbildchen.
        2025-08-14 07:09:31.312 - info: mqtt.0 (1516) Client [shellyplus1-ventil-02] connection closed: closed
        2025-08-14 07:09:36.274 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
        2025-08-14 07:09:36.274 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
        2025-08-14 07:09:36.292 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
        2025-08-14 07:09:40.424 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
        2025-08-14 07:09:40.424 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
        2025-08-14 07:09:40.442 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
        2025-08-14 07:09:57.750 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
        2025-08-14 07:09:57.750 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
        2025-08-14 07:09:57.769 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
        2025-08-14 07:10:56.123 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
        2025-08-14 07:10:56.123 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
        2025-08-14 07:10:56.141 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
        2025-08-14 07:11:55.734 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
        2025-08-14 07:11:55.734 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
        2025-08-14 07:11:55.752 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
        2025-08-14 07:12:51.245 - error: shelly.0 (1407) [MQTT] (Shelly?) device unknown, configuration for client with id "shellyplus1-ventil-02" (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) does not exist! Maybe this device is not supported in this adapter version.
        2025-08-14 07:12:51.246 - error: shelly.0 (1407) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
        2025-08-14 07:12:51.264 - info: shelly.0 (1407) [MQTT] Client Close: (shellyplus1-ventil / shellyplus1-ventil-02 / undefined) (false)
        Da habe ich nichts daran geändert, deshalb verstehe ich es ja auch nicht.
        M Samson71 3 Replies Last reply Reply Quote 0
          micklafisch @wotan2005 last edited by
          @wotan2005
          im Shelly Webinterface unter "use custom prefix" bei MQTT auch nichts geändert? Das Ding kommt mit einem anderen Namen, das Log ist ja eindeutig.
          Ansonsten restet das Ding 1x und fang von vorne an. Parallel den Shelly Adapter und wie im Nachbarthread den MQTT Adapter sollte auch nicht gemacht werden.
          • Samson71
            @wotan2005 sagte in Shelly Adapter - genereller Support:
            Dann zeig die Einstellungen vom Shelly.
            Der heißt bestimmt nicht von vornherein so
              @wotan2005
              uns hier die im Log angesprochene Doku (sollte eindeutig sein):
                Die Client-ID ist immer die MAC, richtig? -> "shellplus1-30c9224dxxxx"
                Aber den Part habe ich bei all meinen Shelly's bis jetzt geändert, immer ohne Probleme.
                Samson71 mcm1957 2 Replies Last reply Reply Quote 0
                • Samson71
                  Dann nutzt Du aber nicht den Shelly-Adapter. Lt. Protokoll ist der aber (auch) im Einsatz.
                  Deswegen auch der Hinweis:
                  @micklafisch sagte in Shelly Adapter - genereller Support:
                    Okay, verstanden.
                    Den Fehler habe ich jetzt auch gefixt, da war einfach ein "-" für den Shelly-Adapter zuviel drin, das möchte er nicht.
                    • mcm1957
                      mcm1957 @wotan2005 last edited by
                      @wotan2005 said in Shelly Adapter - genereller Support:
                      In der Doku steht eindeutig dass die CLIENT-ID nicht geändert werden darf.
                      Wenn du das trotzdem tust, dann rechne bitte mit beliebigen Problemen und minimalem bis keinem Support.
                      Der Adapter verwendet die ClientId zur Identifikation des Devicetyps und zur eindeutigen Identifikation des Devices.
                        Na dann werde ich die wohl alle wieder ändern müssen.
                          @wotan2005
                          wenn dir die Bezeichnung der Client-IDs zu kryptisch ist, verwende einfach Aliase. Das macht dann auch den Austausch einfacher wenn mal ein Gerät hopps geht.
                            Wenn ich den jetzt aus der ferne auf Werkseinstellung setzte, muss ich mich wieder an dem Shelly WLan anmelden um den einzustellen, richtig?
                            M mcm1957 2 Replies Last reply Reply Quote 0
                              @wotan2005
                              korrekt
                              • mcm1957
                                @wotan2005
                                Mach das vor Ort - Reset auf Werkseinstellungen löscht ziemlich sicher auch das WLAN. Und damit ist der Shelly aus der Ferne nicht erreichbar ...
                                  @micklafisch & @mcm1957 & @Samson71
                                  Danke euch drei.
                                  • Horst Böttcher
                                    Horst Böttcher @crunchip last edited by
                                    @crunchip ja genau das war der fehler danke jetzt geht wieder alles
                                    • da_Woody
                                      da_Woody @wotan2005 last edited by
                                      @wotan2005 sorry, ich frag mich immer wieder, warum man sich das leben schwer macht.
                                      warum nicht den shelly-adapter und smart-control adapter?
                                      • haselchen
                                        haselchen Most Active @Horst Böttcher last edited by
                                        @crunchip
                                        Das Firmware Update kanns nicht gewesen sein.
                                        Der Shelly startet danach selber automatisch.
                                        Anpingen ging ja anscheinend auch.
                                        Da wird wieder irgendwas im Hintergrund , nebenbei, gemacht worden sein, was nicht wir nicht wissen.
                                          weil über die shelly-App bespielsweise keine Voltmeter vom Shelly Plus Uni angezeigt werden, diese bekommt man leider nur über mqtt.
                                          • haselchen
                                            haselchen Most Active last edited by haselchen
                                            @wotan2005
                                            Welche Version des Shelly Adapters hast Du installiert?
                                            @mcm1957
                                            Auf Github hast Du für dieses Problem ein Isssue eröffnet. Wie ist der Stand heute?
                                            mcm1957 shelly
                                            35
                                            233
                                            15478
