    3. Entwicklung
    4. Adapter Worx Landroid v3.x.x
      Homoran Global Moderator Administrators @hg6806 last edited by
      @hg6806 sagte in Adapter Worx Landroid v3.x.x:
      Hatte aber alle Scripte die
      Hatte oder hast du....?
      und sind es wirklich alle?
      sonst hast du nichts was auf worx.0 zugreift?
      alexa, cloud oder irgendwas anderes?
      • hg6806
        hg6806 Most Active last edited by hg6806
        Moin!
        Habe es gefunden. Und zwar war es wieder der "Mouse-Over" Effekt bei hqwidgets on/off.
        Das Widget is wie folgt definiert:
        Wenn ich mit der Mouse nur drüberfahre kommt folgendes:
        2025-08-14 07:39:39.785  - info: web.0 (3122) State value to set for "worx.0.20203019930100197363.mower.sendCommand" has to be type "number" but received type "boolean"
        2025-08-14 07:39:39.789  - info: worx.0 (1019813) Request Counter: 2
        2025-08-14 07:39:40.943  - info: web.0 (3122) State value to set for "worx.0.20203019930100197363.mower.sendCommand" has to be type "number" but received type "boolean"
        2025-08-14 07:39:41.222  - info: worx.0 (1019813) Request Counter: 3
        2025-08-14 07:39:42.268  - info: web.0 (3122) State value to set for "worx.0.20203019930100197363.mower.sendCommand" has to be type "number" but received type "boolean"
        2025-08-14 07:39:42.308  - info: worx.0 (1019813) Request Counter: 4
        2025-08-14 07:39:43.237  - info: web.0 (3122) State value to set for "worx.0.20203019930100197363.mower.sendCommand" has to be type "number" but received type "boolean"
        2025-08-14 07:39:43.245  - info: worx.0 (1019813) Min Time between requests is 1000ms. The time between commands was 938 ms. Request worx.0.20203019930100197363.mower.sendCommand with value false was not sended
        2025-08-14 07:39:43.568  - info: web.0 (3122) State value to set for "worx.0.20203019930100197363.mower.sendCommand" has to be type "number" but received type "boolean"
        2025-08-14 07:39:43.578  - info: worx.0 (1019813) Request Counter: 5
        2025-08-14 07:39:44.483  - info: smartmeter.0 (2880) Received 10 values, 3 updated
        2025-08-14 07:39:44.497  - info: mqtt.2 (2752) send2Server mqtt.2.openWB.set.counter.11.get.power[openWB/set/counter/11/get/power]
        2025-08-14 07:39:44.499  - info: mqtt.2 (2752) send2Server mqtt.2.openWB.set.counter.11.get.exported[openWB/set/counter/11/get/exported]
        2025-08-14 07:39:44.555  - info: web.0 (3122) State value to set for "worx.0.20203019930100197363.mower.sendCommand" has to be type "number" but received type "boolean"
        2025-08-14 07:39:44.567  - info: worx.0 (1019813) Min Time between requests is 1000ms. The time between commands was 990 ms. Request worx.0.20203019930100197363.mower.sendCommand with value false was not sended
        2025-08-14 07:39:45.120  - info: web.0 (3122) State value to set for "worx.0.20203019930100197363.mower.sendCommand" has to be type "number" but received type "boolean"
        2025-08-14 07:39:45.125  - info: worx.0 (1019813) Request Counter: 6
        2025-08-14 07:39:46.120  - info: web.0 (3122) State value to set for "worx.0.20203019930100197363.mower.sendCommand" has to be type "number" but received type "boolean"
        2025-08-14 07:39:46.124  - info: worx.0 (1019813) Min Time between requests is 1000ms. The time between commands was 999 ms. Request worx.0.20203019930100197363.mower.sendCommand with value false was not sended
        Das hqwidget on/off ist wohl eigentlich nur für boolean gedacht, übergibt aber trotzdem eine Zahl beim Auslösen, denn generell funktioniert es.
          Homoran Global Moderator Administrators @hg6806 last edited by Homoran
          im Sinne von 0=false / 1=true!
          Das ist keine Zahl!
          steht auch genauso im log
          Der Datenpunkt ist vom typ Zahl, bekommt eine Wert Bool:
          • hg6806
            hg6806 Most Active @Homoran last edited by
            Genau - aber wie schon geschrieben, wird bei Tastendruck trotzdem eine Zahl übergeben, denn es funktioniert ja, bis auf dieses Mouseover und eben der Fehler im Log.
            Jetzt die Frage - auch wenn es off-topic ist - welchen Button nimmt man um eine Zahl zu übergeben?
              NEIN!
              es wird ein Bool übergeben, der noch akzeptiert und als Zahl interpretiert wird.
              • hg6806
                Mag ja sein, trotzdem brauche ich eine andere Lösung mit einem Tasten-Widget was eine Zahl übergibt.
                • Dr. Bakterius
                  Dr. Bakterius Most Active @hg6806 last edited by
                  @hg6806 Beschreibe doch mal was du genau vor hast. Welche Zahl soll wofür übergeben werden?
                  • hg6806
                    hg6806 Most Active @Dr. Bakterius last edited by
                    @dr-bakterius
                    Ich möchte bei Datenpunkt
                    eine Zahl eintragen.
                    Das geht zwar notfalls auch über ein Script, einfacher wäre es wenn ich es direkt über einen Tastendruck eintrage.
                    haselchen Dr. Bakterius 2 Replies Last reply Reply Quote 0
                    • haselchen
                      haselchen Most Active @hg6806 last edited by
                      @Homoran
                      Magst Du das Thema mal in einen separaten Thread abtrennen ?
                      Hat ja eher mit VIS zu tun und nur gaaaaaanz entfernt mit dem Adapter .
                        Homoran Global Moderator Administrators @haselchen last edited by
                        @haselchen sagte in Adapter Worx Landroid v3.x.x:
                        im Prinzip schon, aber ich kann den ersten Post nicht rübernehmen, der hier zu diesrm Thread gehört und mittlerweile leiderversandet ist.
                        @hg6806
                        wann und wie genau kommt es zu dieser Meldung im worx.0?
                        Zum Thema vis bitte einen eigenen Thread unter Visualisierung aufmachen, ich lösche dann hier die entsprechenden posts
                        • Dr. Bakterius
                          Hm. Ich habe da schon lange nichts gemacht, aber in meinem doch recht umfangreichen Skript zur Steuerung des Mähers habe ich diesen Datenpunkt niemals verändert. Braucht es den überhaupt?
                          • hg6806
                            @haselchen
                            @Homoran
                            Jetzt sind wir wieder beim Thema 😀
                            @Dr-Bakterius
                            Mit dem Datenpunkt
                            worx.0.xxxxxxxxxxxx.mower.sendCommand
                            Sendet man eben Befehle an den Mähroboter wie Mähstart, Stop, Heimfahrt etc.
                            https://github.com/iobroker-community-adapters/ioBroker.worx/blob/master/docs/en/README.md#mower-wire-and-vision
                            Überschrift SendCommands
                            • Dr. Bakterius
                              Das ist mir schon klar. Aber ich verwende diesen Datenpunkt nicht um meinen Mäher zu steuern. Bei mir wird das alles über die Mähzeiten gemacht. Aber vielleicht hilft dir das Widget 'basic - ValueList HTML'.
                              • haselchen
                                haselchen Most Active last edited by
                                Halleluja 🙌
                                Mit der neue App GUI hat Worx ja den Vogel abgeschossen .
                                Vermutlich rührten daher die ganzen App und Verbindungsprobleme 🤣
                                ilovegym BananaJoe 2 Replies Last reply Reply Quote 1
                                • ilovegym
                                  ilovegym @haselchen last edited by
                                  @haselchen
                                  Vermutung an:
                                  eijo, da wird wohl fleissig getestet worden sein, und "wir" Smarthome-Nutzer waren dann dran schuld..
                                  Wahrscheinlich hat man das einem externen gegeben, und der hat dann mit nem Fehler in der neuen App fuer das Chaos gesorgt..
                                  Vermutung off.
                                  Ich finde es etwas übersichtlicher, alles auf einer Seite, auf dem Tablet bestimmt schön, am Handy bin ich nur am scrollen, was schon wieder so n 2000er-Stil in mir aufruft.. 🙂
                                  Dürfte aber Geschmackssache sein..
                                  hsteinme 1 Reply Last reply Reply Quote 0
                                  • BananaJoe
                                    BananaJoe Most Active @haselchen last edited by
                                    Halleluja 🙌
                                    Öhm? App sieht aus wie immer?
                                    • haselchen
                                      haselchen Most Active @BananaJoe last edited by
                                      @bananajoe
                                      Nöhööööö 🙂
                                      App Update auf dem Iphone heute gemacht
                                      BananaJoe 1 Reply Last reply Reply Quote 1
                                      • BananaJoe
                                        @haselchen ok, Android sieht aus wie immer und es gibt auch kein Update
                                        • Armilar
                                          Armilar Most Active Forum Testing @BananaJoe last edited by Armilar
                                          @bananajoe
                                          Aber für iOS schon... Habe es eben auch gesehen und installiert
                                          EDIT: kurzer Blick auf die neue GUI
                                          • hsteinme
                                            hsteinme @ilovegym last edited by
                                            @ilovegym sagte in Adapter Worx Landroid v3.x.x:
                                            Klar, und deshalb wurde gerade Dein Account und Deine IP-Adresse gesperrt.
                                            788
                                            122142
