    4. Fehler VIS-2 Widget Inventwo
    • Longbow
      Longbow last edited by Longbow
      Guten Morgen,
      ich würde es gern hinbekommen, aber leider geht das nicht. in dem HtmL Widget kommt kein Auswertung etc., ich muss wohl was noch falsch machen.
      Kann man nicht ein Projekt / Seit expotieren und dann ich die importieren?
      • Longbow
        So es hat endlich geklappt.
        Hier der Text aus dem html, bin gespannt @jkvarel und @OliverIO ob ihr damit was anfangen könnt
        [log] Translate: jqui_widgetTitle
        [log] Translate: jqui_Write state
        [log] Translate: jqui_Close
        [log] Translate: jqui_input
        [log] Translate: jqui_off
        [log] Translate: jqui_on
        [log] Translate: Value
        [log] Ignored bars/tplBarFilter because not used in project
        [log] Ignored bars/tplBarNavigator because not used in project
        [log] Ignored canvas-gauges/tplCGlinearGauge because not used in project
        [log] Ignored canvas-gauges/tplCGradialGauge because not used in project
        [log] Ignored canvas-gauges/tplCGCompas because not used in project
        [log] Ignored canvas-gauges/tplCGflatGauge because not used in project
        [log] Ignored colorpicker/tplRGBSpectrum because not used in project
        [log] Ignored colorpicker/tplSpectrumHomematic because not used in project
        [log] Ignored colorpicker/tplRGBFarbtastic because not used in project
        [log] Ignored colorpicker/tplHUEjscolor because not used in project
        [log] Ignored colorpicker/tplHUEPickerXY because not used in project
        [log] Ignored colorpicker/tplHUEIndicatorXY because not used in project
        [log] Ignored colorpicker/tplHUEPickerCT because not used in project
        [log] Ignored colorpicker/tplHUEIndicatorCT because not used in project
        [log] Ignored colorpicker/tplJscolor because not used in project
        [log] Ignored eventlist/tplEventlist because not used in project
        [log] Ignored eventlist/tplEventlistButton because not used in project
        [log] Ignored history/tplHistoryEventList because not used in project
        [log] Ignored history/tplHistorySparkLIne because not used in project
        [log] Ignored jqplot/tplJqplotGauge because not used in project
        [log] Ignored justgage/tplJustgageJustGage because not used in project
        [log] Ignored justgage/tplJustgageValueColored because not used in project
        [log] Ignored justgage/tplJustgageIndicatorColored because not used in project
        [log] Ignored justgage/tplJustgageValueIndicatorColored because not used in project
        [log] Ignored map/tplOsm because not used in project
        [log] Ignored map/tplGoogleMap because not used in project
        [log] Ignored material/tplMaListDoor because not used in project
        [log] Ignored material/tplMaListWindow because not used in project
        [log] Ignored material/tplMaListShutter because not used in project
        [log] Ignored material/tplMaListTemp because not used in project
        [log] Ignored material/tplMaListHumid because not used in project
        [log] Ignored material/tplMaListLight because not used in project
        [log] Ignored material/tplMaListLightDim because not used in project
        [log] Ignored rgraph/tplRGtermometer because not used in project
        [log] Ignored rgraph/tplRGgauge because not used in project
        [log] Ignored rgraph/tplRLiveChart because not used in project
        [log] Ignored rgraph/tplRBarChart because not used in project
        [log] Ignored swipe/tplCarousel because not used in project
        [log] Ignored trashschedule/tplTrashscheduleHelper because not used in project
        [log] Ignored weather/tplWeatherShowInstance because not used in project
        [log] log test
        [warn] warn test
        [error] error test
        [debug] debug test
        [log] [2025-08-11T14:27:25.073Z] +SUBSCRIBE: 0_userdata.0.Eigene_Datenpunkte.Garage.AutoClose_RemainingSec
        [log] [2025-08-11T14:27:25.076Z] +SUBSCRIBE: 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor
        Das steht jetzt noch dazu
        [error] [2025-08-11T14:53:17.758Z] ws connection error: CLOSE_ABNORMAL
        [log] [2025-08-11T14:53:17.766Z] Start reconnect 0
        [log] [2025-08-11T14:53:17.846Z] Try to connect
        [log] [2025-08-11T15:08:40.280Z] Start reconnect 0
        [log] [2025-08-11T15:08:40.290Z] Try to connect
        [error] [2025-08-11T15:08:40.395Z] ws connection error: CLOSE_ABNORMAL
        [log] [2025-08-11T15:08:40.397Z] Start reconnect 1
        [log] [2025-08-11T15:08:40.400Z] Reconnect is already running 1
        [error] [2025-08-11T15:08:40.400Z] ws connection error: CLOSE_ABNORMAL
        [log] [2025-08-11T15:08:40.402Z] Reconnect is already running 1
        [log] [2025-08-11T15:08:42.295Z] Try to connect
        [log] [2025-08-11T15:40:06.480Z] Start reconnect 0
        [error] [2025-08-11T15:40:06.937Z] ws connection error: CLOSE_ABNORMAL
        [log] [2025-08-11T15:40:06.938Z] Reconnect is already running 0
        [log] [2025-08-11T16:30:25.704Z] Try to connect
        jkvarel 1 Reply Last reply Reply Quote 0
        • jkvarel
          jkvarel Developer @Longbow last edited by
          @longbow hast du in der gleichen View ein inventwo Widget drin?
          Longbow 1 Reply Last reply Reply Quote 0
          • Longbow
            Longbow @jkvarel last edited by
            @jkvarel wie meinst du das ?
            hier die Seite exportiert:
              "name": "test",
              "parentId": null,
              "settings": {
                "style": {},
                "class": "mylog"
              "widgets": {
                "w000406": {
                  "tpl": "tplHtml",
                  "data": {
                    "bindings": [],
                    "name": "mylog",
                    "comment": null,
                    "class": "mylog",
                    "filterkey": null,
                    "multi-views": null,
                    "locked": null,
                    "g_fixed": true,
                    "html": "<script>\r\n    console.log(\"log test\");\r\n    console.warn(\"warn test\");\r\n    console.error(\"error test\");\r\n    console.debug(\"debug test\");\r\n</script>",
                    "refreshInterval": null,
                    "g_common": true
                  "style": {
                    "bindings": [],
                    "left": 48,
                    "top": 64,
                    "width": "711px",
                    "height": "331px"
                  "widgetSet": "basic"
                "w000407": {
                  "tpl": "tplInventwoWidgetUniversal",
                  "data": {
                    "bindings": [],
                    "type": "switch",
                    "g_common": true,
                    "mode": "singleButton",
                    "direction": "row",
                    "oid": "nothing_selected",
                    "httpType": "send",
                    "buttonSize": 110,
                    "btnSpacing": 10,
                    "countStates": 1,
                    "buttonHoldValue": false,
                    "dialogWidth": 500,
                    "g_attr_group_type_view_in_dialog": true,
                    "dialogHeight": 300,
                    "dialogPadding": 10,
                    "dialogBackground": "rgb(18, 18, 18)",
                    "dialogTitleColor": "rgb(255,255,255)",
                    "dialogTitleSize": 20,
                    "dialogCloseButtonBackground": "rgba(255,255,255,0)",
                    "dialogCloseButtonColor": "rgba(255,255,255,1)",
                    "dialogCloseButtonSize": 14,
                    "dialogBorderRadiusTopLeft": 12,
                    "dialogBorderRadiusTopRight": 0,
                    "dialogBorderRadiusBottomRight": 12,
                    "dialogBorderRadiusBottomLeft": 0,
                    "clickThrough": false,
                    "g_attr_group_click_feedback": true,
                    "feedbackDuration": 0,
                    "backgroundFeedback": "rgba(69, 86, 24, 1)",
                    "outerShadowColorFeedback": "rgba(0, 0, 0, 1)",
                    "contentBlinkInterval": 0,
                    "g_attr_group_state_default": true,
                    "outerShadowColor": "rgba(0, 0, 0, 1)",
                    "colorPickerColorModel": "hex",
                    "g_attr_content_color_picker": true,
                    "colorPickerWidth": 200,
                    "colorPickerHandleSize": 8,
                    "colorPickerHandleMargin": 6,
                    "colorPickerComponentsSpace": 12,
                    "colorPickerDirection": "vertical",
                    "colorPickerBorderWidth": 0,
                    "colorPickerShowWheel": true,
                    "colorPickerShowSaturation": true,
                    "colorPickerShowValue": true,
                    "textDecoration": "none",
                    "g_attr_group_css_text": true,
                    "textMarginTop": 0,
                    "textMarginBottom": 0,
                    "textMarginLeft": 0,
                    "textMarginRight": 0,
                    "contentType": "icon",
                    "g_attr_group_css_content": true,
                    "contentMarginTop": 0,
                    "contentMarginBottom": 0,
                    "contentMarginLeft": 0,
                    "contentMarginRight": 0,
                    "contentSize": 40,
                    "contentRotation": 0,
                    "contentMirror": false,
                    "flexDirection": "column",
                    "g_attr_group_css_alignment": true,
                    "alignItems": "space-between",
                    "textAlign": "start",
                    "contentAlign": "center",
                    "backgroundOpacity": 1,
                    "g_attr_group_css_transparency": true,
                    "contentOpacity": 1,
                    "paddingLeft": 10,
                    "g_attr_group_css_spacing": true,
                    "paddingRight": 10,
                    "paddingTop": 10,
                    "paddingBottom": 10,
                    "borderRadiusTopLeft": 12,
                    "g_attr_group_css_border_radius": true,
                    "borderRadiusTopRight": 0,
                    "borderRadiusBottomRight": 12,
                    "borderRadiusBottomLeft": 0,
                    "borderSizeTop": 0,
                    "g_attr_group_css_border": true,
                    "borderSizeBottom": 0,
                    "borderSizeLeft": 0,
                    "borderSizeRight": 0,
                    "borderStyle": "none",
                    "outerShadowX": 2,
                    "g_attr_group_css_outer_shadow": true,
                    "outerShadowY": 2,
                    "outerShadowBlur": 2,
                    "outerShadowSize": 1,
                    "innerShadowX": 0,
                    "g_attr_group_css_inner_shadow": true,
                    "innerShadowY": 0,
                    "innerShadowBlur": 0,
                    "innerShadowSize": 0
                  "style": {
                    "bindings": [],
                    "left": 45,
                    "top": 389,
                    "width": "179px",
                    "height": "199px",
                    "position": "absolute",
                    "overflow": "visible"
                  "widgetSet": "vis-2-widgets-inventwo"
                "w000408": {
                  "tpl": "tplContainerView",
                  "data": {
                    "bindings": [],
                    "contains_view": "Torsteuerung",
                    "g_common": true
                  "style": {
                    "bindings": [],
                    "left": 261,
                    "top": 387,
                    "width": "312px",
                    "height": "270px"
              "activeWidgets": []
            • Longbow
              kann mir jemandes behilflich sein? Bin ich der einzige, der diese Problem hat
              • jkvarel
                jkvarel Developer last edited by
                Nicht wirklich ein Fehler da. Die Websocket Fehler werden damit nichts zu tun haben. @Longbow, hattest du schon den Browser Cache geleert? Wäre ein Versuch wert.
                Ansonsten, @OliverIO hast du noch eine Idee?
                OliverIO 2 Replies Last reply Reply Quote 0
                • OliverIO
                  OliverIO @jkvarel last edited by
                  @jkvarel
                  Ohne Fehlermeldung schwierig.
                  Man könnte unter Windows mal noch Safari installieren. Aber dann wäre es wirklich was Browser spezifischisches, was für mich ein wenig strange wär
                    Filo @OliverIO last edited by
                    @oliverio,
                    sorry,ich hab den ganzen Thread ein bisschen verschlafen, habe auch das gleiche Problem wie Longbow. Wenn ich das Ganze (leere Seite mit dem HTML Widget und Universal Widget) auf Safari im IPad mini öffne, bekomme ich folgende Fehlerausgabe:
                    [log] log test
                    [warn] warn test
                    [error] error test
                    [debug] debug test
                    [error] Cannot load widget system.adapter.vis-2-widgets-inventwo.0: ReferenceError: Cannot access uninitialized variable.
                    [error] Cannot load widget system.adapter.vis-2-widgets-inventwo.0: {}
                    vielleicht kann man daraus etwas sehen.
                    Filo
                    • OliverIO
                      OliverIO @Filo last edited by
                      @filo
                      Das sieht schon besser aus. Evtl gibt das @jkvarel schon genug Hinweise zum suchen.
                      Dürfte aber auch ein Fehler sein, der eigentlich auch auf anderen Plattformen auftaucht.
                      Ich muss mal schauen, ob man die Ausgabe auch noch mit dem callstack erweitern kann.
                      Dann würde man genau sehen, an welcher Stelle der Fehler auftritt.
                      • Longbow
                        Hallo in die Runde,
                        ich habe mir ein neues System auf gesetzt, nur die VIS-2 installiert und Inventwo Widgets.
                        Da läuft alles perfekt, geh ich in die Beta Version auch, nur bei dem Adapter darf ich nicht über 0.2.2 gehen, dann habe ich das Problem wieder.
                        Im System, was ich gebrauche, hat ein Down Option des Adapter leider nicht den Erfolg gebracht. Da bin ich am probieren.
                        Im neuen System geht es, alle Mobile Versionen bei uns probiert und es geht.
                        Update, in dem alten System kann ich die VIS 1 nicht löschen als Adapter. Denke das ich alles umziehen muss in den neuen Iobroker oder ?
                          Filo @Longbow last edited by
                          @longbow
                          die Version 0.2.2 läuft bei mir auch einwandfrei (auch nach Downgrade von 0.3.5). Bei höheren Versionen habe ich das oben beschriebene Problem.
                          Es gibt bei der Version 0.3.5 ein weiteres Problem mit multiplen Zuständen, dazu habe ich bereits ein Issue auf GitHub eröffnet. Link
                          Filo
                          • Longbow
                            Also ich werde nicht drum her rum kommen, alles neu auf zu setzten und dann hoffentlich den Fehler nicht mehr zu haben.
                            Bis jetzt läuft das neue System ohne Fehler bei dem Widget. Bei dem neuen habe ich kein Vis-1 mehr installiert.
                            Ich bin gespannt, was her aus kommt bei dem Fehlercode.
                            • OliverIO
                              @jkvarel
                              Vergiss bitte nicht den Code zeitnah zu deaktivieren, da ansonsten bei allen die die Widgets installiert haben die komplette browser Konsole umgebogen wird.
                              Das könnte die fehlersuche auch für andere Widgets schwierig machen da die Konsole dann einfach leer ist.
                              • jkvarel
                                @longbow bitte mit v0.3.6 versuchen und die Ausgaben schicken. Dort sollte beistehen, woher der Fehler kommt
                                • Longbow
                                  @jkvarel Guten Morgen, du ich habe ein neues System auf gesetzt, kein VIS 1 sachen installiert und es geht nun prima. Da lange keine reaktion kam, habe ich das system gelöscht. Sorry. Ich kann somit leider gerade nichts mehr dazu sagen, aber es scheint ein Problem zu sein.
                                  • Longbow
                                    @jkvarel Gibt es was neues, keine Ahnung warum, aber es wurde heute die Neue Verion installiert, jetzt habe ich die gleichen Fehler wieder auf den iOS Geräten. Auch ein Downgrade macht kein Verbesserung mehr, der Fehler bleibt weiterhin. Hast du hier schon mal was machen können.
                                    @all sind wir die einizgen, die diese Problem haben.
                                    • Longbow
                                      @jkalver Es muss an das Neu laden des VIS 2 Adapter liegen, wenn ich was update wird der neu geladen der Editor, nur dann ist es mal so, das links euere zur Auswahl steht, mal nicht. Wenn es nicht zur Auswahl steht, dann kommen die Fehlermeldung.
                                      Aber habe heute das bemerkt, auch wenn geladen ist, das der Widget Schieberegler und Checkbox auch Fehler in der Vis machen.
                                      An was liegt das bitte? Das kann ja nicht bei 1-2 Leuten sei? Oder?
                                      2523
