    4. Betatest NSPanel-lovelace-ui v0.6.x
      hm_krause @TT-Tom last edited by
      bitte um Starthilfe.
      Das Script ist installiert und läuft.
      Desired TFT Firmware: 58 / v4.9.4
      javascript.0	18:52:37.817	info
      Installed TFT Firmware: 58 / v4.9.4
      javascript.0	18:57:09.535	info
      Stopping script script.js.nspanel-lovelace-ui_0.NSPanel_1
      javascript.0	18:58:54.092	info
      Compiling TypeScript source script.js.nspanel-lovelace-ui_0.NSPanel_1
      javascript.0	18:58:54.554	info
      source code did not change, using cached compilation result...
      javascript.0	18:58:54.659	info
      --- start of NsPanelTs: 0_userdata.0.NSPanel. ---
      javascript.0	18:58:54.680	info
      setObjects enabled - create Alias Channels possible
      javascript.0	18:58:54.685	info
      weather alias for openweathermap.0. already exists
      javascript.0	18:58:54.696	info
      registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      javascript.0	18:58:54.701	info
      No Updates for NSPanel available
      javascript.0	18:58:54.861	info
      javascript.0	18:58:54.977	info
      Debug mode disabled
      javascript.0	18:58:56.163	info
      hidden Cards disabled
      javascript.0	18:58:56.253	info
      javascript.0	18:58:57.539	info
      Start MQTT-Port-Check -------------------------------------
      -- admin.0                   - 8081
      -- hm-rpc.0                  - 0
      -- hm-rpc.1                  - 8701
      -- influxdb.0                - 8086
      -- influxdb.1                - 8086
      -- mqtt.0                    - 1883
      -- mqtt.3                    - 1883
      -- mqtt.4                    - 1886
      -- proxmox.0                 - 8006
      -- shelly.0                  - 1883
      -- shelly.1                  - 1882
      javascript.0	18:58:57.540	info
      -- simple-api.0              - 8087
      -- sonoff.0                  - 1885
      -- sun2000.0                 - 502
      -- telegram.0                - 8443
      -- web.0                     - 8082
      -- zigbee.1                  - /dev
      - MQTT-Port-Check OK: Instance of Adapter: mqtt.4 is running on Port:1886
      End MQTT-Port-Check ----------
      Der Apapter startet nicht, Fehler: No compatible config found, paused!
      Hier die Einstellungen:3.jpg 2.jpg 1.jpg
      Log:
      nspanel-lovelace-ui.0
      	2025-08-13 19:15:32.584	debug	{"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.4"},"id":236,"ack":false,"time":1755105332581},"_id":22998830}
      	2025-08-13 19:14:56.356	debug	{"command":"getTimeZones","message":{"ip":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.4"},"id":235,"ack":false,"time":1755105296355},"_id":22998829}
      	2025-08-13 19:14:56.284	debug	{"command":"getTasmotaDevices","message":{"ip":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.4"},"id":234,"ack":false,"time":1755105296281},"_id":22998828}
      	2025-08-13 19:00:28.147	error	No compatible config found, paused!
      	2025-08-13 19:00:28.106	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
      	2025-08-13 19:00:27.873	debug	States connected to redis: 0.0.0.0:9000
      	2025-08-13 19:00:27.771	debug	States create User PubSub Client
      	2025-08-13 19:00:27.771	debug	States create System PubSub Client
      	2025-08-13 19:00:27.741	debug	Redis States: Use Redis connection: 0.0.0.0:9000
      	2025-08-13 19:00:27.683	debug	Objects connected to redis: 0.0.0.0:9001
      	2025-08-13 19:00:27.678	debug	Objects client initialize lua scripts
      	2025-08-13 19:00:27.578	debug	Objects create User PubSub Client
      	2025-08-13 19:00:27.578	debug	Objects create System PubSub Client
      	2025-08-13 19:00:27.577	debug	Objects client ready ... initialize now
      	2025-08-13 19:00:27.534	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
      	2025-08-13 19:00:23.080	info	terminating
      	2025-08-13 19:00:22.579	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      	2025-08-13 19:00:22.579	info	terminating
      	2025-08-13 19:00:22.578	info	Got terminate signal TERMINATE_YOURSELF
      	2025-08-13 18:59:52.362	debug	{"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.4"},"id":232,"ack":false,"time":1755104392359},"_id":22998826}
      Bitte um Hilfe
        TT-Tom @hm_krause last edited by TT-Tom
        @hm_krause
        Hast du dir die Hilfe zur Adapter Installation durchgelesen. Und diese schrittweise abgearbeitet.
        Dann solltest du selber auf den Fehler kommen.
        Du hast ein Schritt vergessen. Bitte lesen, damit du den Ablauf verstehst.
        Wenn es dann immer noch nicht klappt, melde dich einfach noch mal.
        Edit: sehe grade das du auch ein falsches Script genommen hast. Also bitte lesen, der Link ins auf der General Seite oben.
          @tt-tom
          --Hm...??
          Script habe ich dieses von hier: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/DEV/NSPanelTs.ts
          Hilfe zur Adapterinstallation mehrfach gelesen, ich finde den Fehler nicht.
            @hm_krause
            Um ehrlich zu sein hast du so nicht richtig gelesen.
            Das Script ist vom Parallel Projekt und hat mit dem Adapter nichts zu tun.
            Wiki
            Hier wird genau gesagt welches Script du nutzen sollst.
            Es wird vom Adapter angelegt.
            teletapi H 2 Replies Last reply Reply Quote 1
            • teletapi
              teletapi @TT-Tom last edited by
              Nabend, ich hab heute nach der Aufforderung zum testen des neuen Scriptes den Adapter aktualisiert danach stand dann unter Maintain das das neue script zur verfügung steht. Hab dann den Butten gedrückt und ein "OK" bekommen.
              Leider ist der Fehler nach Neustart des scriptes und des Adapters immernoch vorhanden .
              Die neue script Version wird aber geladen
              avascript.0	01:00:10.698	info
              javascript.0	01:00:10.758	info
              javascript.0	01:00:10.762	info
              registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
              javascript.0	01:00:11.123	info
              Stopping script
              javascript.0	01:00:11.529	info
                'Panel for Topic: SmartHome/NSPanel_Weiss Script version 0.9.1 is correct!',
                'done'
              	2025-08-14 00:57:49.999	warn	[StatesDB] Found more as 1 state for role in /^openweathermap\.0./ with .dp: openweathermap.0.forecast.current.windDirection and .regexp: /^openweathermap\.[0-9]+\.forecast\.current\.windDirection/
              	2025-08-14 00:57:49.944	warn	[StatesDB] Found more as 1 state for role in /^openweathermap\.0./ with .dp: openweathermap.0.forecast.current.windDirection and .regexp: /^openweathermap\.[0-9]+\.forecast\.current\.windDirection/
              T T 2 Replies Last reply Reply Quote 0
                TT-Tom @teletapi last edited by TT-Tom
                @teletapi
                zeige mal bitte dein oben Teil Script, also alles was hier vor ist.
                Edit: hat sich erledigt
                  ticaki @teletapi last edited by
                  @teletapi
                  Bitte nochmal aktualisieren. Die Änderung war zwar im Code, aber noch nicht kompiliert.
                  teletapi 1 Reply Last reply Reply Quote 1
                  • teletapi
                    teletapi @ticaki last edited by
                    @ticaki Jawohl das hat wohl funktioniert Fehler taucht nicht mehr auf 👍 👍
                    • teletapi
                      teletapi @teletapi last edited by teletapi
                      @TT-Tom ich glaub ich hab hier in der PagePower einen kleinen Fehler entdeckt. Beim erstellen der Pagepower hier zb. "Leistung 4" einstellen der Dezimalstellen hier geht nur eine kommastelle nicht 2: 0,1 und 0,01 ergeben beide nur eine Nachkommastelle.
                      Bei "Leistung Haus unten" funktioniert es:
                      T T 3 Replies Last reply Reply Quote 0
                        @teletapi
                        Wieviele Kommastellen liefert den der Datenpunkt?
                        kWh ist aber keine aktuelle Leistung.
                        teletapi 1 Reply Last reply Reply Quote 0
                        • teletapi
                          @tt-tom der Datenpunkt liefert 4 Nachkommastellen und der Wert entspricht dem tatsächlichem Hausverbrauch pro Tag
                            @tt-tom
                            Habe jetzt nochmal Schritt für Schritt alles durchgegangen:
                            • Berry Treiber und TFT Firmware vom Adapter aus installiert.
                            • Beispiel Konfigscript gestartet
                              Fehler noch immer:
                            	2025-08-14 15:43:58.346	error	No compatible config found, paused!
                            	2025-08-14 15:43:58.345	warn	No script config found for nspanel_1
                            	2025-08-14 15:43:58.253	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
                            host.Iobroker
                            	2025-08-14 15:43:56.922	info	instance system.adapter.nspanel-lovelace-ui.0 in version "0.2.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) started with pid 112172
                            host.Iobroker
                            	2025-08-14 15:43:53.473	info	instance system.adapter.nspanel-lovelace-ui.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            host.Iobroker
                            	2025-08-14 15:43:53.053	info	stopInstance system.adapter.nspanel-lovelace-ui.0 send kill signal
                            	2025-08-14 15:43:52.892	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            	2025-08-14 15:43:52.891	info	terminating
                            	2025-08-14 15:43:52.891	info	Got terminate signal TERMINATE_YOURSELF
                            host.Iobroker
                            	2025-08-14 15:43:52.887	info	stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=true)
                            javascript.0
                            	2025-08-14 15:43:46.557	info	Stopping script script.js.nspanel-lovelace-ui_0.conf
                            javascript.0
                            	2025-08-14 15:43:46.444	info	script.js.nspanel-lovelace-ui_0.conf: [ 'Panel for Topic: topic Script version 0.9.1 is correct!', 'No navigation items found! This needs to be fixed!', 'done' ]
                            	2025-08-14 15:43:46.424	error	[config-manager] No navigation items found! This needs to be fixed!
                            • teletapi
                              teletapi @hm_krause last edited by teletapi
                              @hm_krause genau das gleiche Problem hatte ich auch. Bis ich durch @TT-Tom und @ticaki darauf aufmeksam gemacht wurde das auch nicht den Schritt für Schritt anleitungen gefolgt bin. Wie war das noch.... Wenn alles da ist das script starten (Das script beendet sich wieder) dann in den Adapter und diesen neu starten. danach kam die Grund oder Basis config erst . dauert paar sekunden
                              Hier kannst du lesen wie mein Problem aussah.... https://forum.iobroker.net/topic/80055/betatest-nspanel-lovelace-ui-v0-2-x/174
                              Ich hab auch ne ganze Zeit gebraucht um erstmal zu kapieren wie es geht das Script bleibt nicht geöffnet. Das schließt sich nach dem neustart wieder und danach muss der Adapter neu gestartet werden um die Konfig zu laden die er durch das Starten des scriptes bekommen hat.
                              Und nach jeder Änderung muss das wieder neu gestart und der Adapter ebenfalls neu gestartet werden.
                              @TT-Tom hier könnte die Anleitung in meinen Augen durchaus ausführlicher sein bzw einfacher geschrieben werden. Mir ist das früher bei Anleitungen auch immer mal wieder passiert das (weil man es selbst sehr gut beherscht) vergisst das auf der anderen Seite relativ unbedarfte Menschen sitzen.... (So wie ich) ... 😉
                              Und das soll keine Kritik an eurer Arbeit sein die ist hervorragend genauso wie eure Hilfestellung
                                hm_krause @teletapi last edited by
                                @teletapi
                                Was hattest Du denn für ein minimal Script genommen.
                                Das Beispiel Konfig Script läuft daurch und beendet sich ja auch.
                                Der Adapter will aber nicht starten..:-(
                                Ich weiß ja aich das der Fehler "vor" dem Monitor sitzt, aber helfen tut das nicht.
                                • teletapi
                                  @hm_krause ich weiß war bei mir genauso. (Letztendlich hatte ich soviel probiert und getestet das ich zum Schluss als es dann startete nicht mehr sicher war was ich falsch oder richtig gemacht habe.) Hast du nach dem Start des scriptes den Adapter neu gestartet. Vielleicht zeigst du mal deine Adapter seite..?
                                  teletapi T 2 Replies Last reply Reply Quote 0
                                  • teletapi
                                    @teletapi
                                    Das minimal script ist im Basisscript enthalten da muss man nix machen. Wenn du im Adapter auf script drückst erstellt der Adapter ein JS Ordner in dem das passende script enthalten ist das einmal starten und danach den Adapter neustarten. Evtl. würde ich nochmal in den Adapter gehen und auf Tabelle aktualisieren gehn und wenn du das Panel da aufrufst muss die tasmota Version drin sein die du nutzt. Die war bei mir vorher auch nicht drin.
                                      @hm_krause
                                      Das letzte Mal waren die topics unterschiedlich zwischen dem Skript und der Adapter konfiguration
                                        @teletapi
                                        Danke für deine Hinweise.
                                        @hm_krause
                                        Lege bitte mal im Script eine Seite an. uniqename muss main sein.
                                        Bin noch unterwegs und kann leider nicht besser helfen von hier.
                                          @teletapi
                                          Meinst Du mit Basisscript dieses:
                                          https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/blob/main/script/example_sendTo_script_iobroker.ts
                                          Hier noch:
                                          • teletapi
                                            @hm_krause Den fehler hatte ich bisher noch nicht der ist mir neu. Aber ja das ist das script was durch den Adsapter erstellt werden soll natürlich unter dem passenden Ordner. hast du mal geschaut ob deine Topics passen
                                            534
                                            71910
