    4. Betatest NSPanel-lovelace-ui v0.6.x
      hm_krause @TT-Tom last edited by
      @tt-tom
      Hier wird genau gesagt welches Script du nutzen sollst.
      Es wird vom Adapter angelegt.
      Habe jetzt nochmal Schritt für Schritt alles durchgegangen:
      • Berry Treiber und TFT Firmware vom Adapter aus installiert.
      • Beispiel Konfigscript gestartet
        Fehler noch immer:
      nspanel-lovelace-ui.0
      	2025-08-14 15:43:58.346	error	No compatible config found, paused!
      	2025-08-14 15:43:58.345	warn	No script config found for nspanel_1
      	2025-08-14 15:43:58.253	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
      host.Iobroker
      	2025-08-14 15:43:56.922	info	instance system.adapter.nspanel-lovelace-ui.0 in version "0.2.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) started with pid 112172
      host.Iobroker
      	2025-08-14 15:43:53.473	info	instance system.adapter.nspanel-lovelace-ui.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      	2025-08-14 15:43:53.053	info	stopInstance system.adapter.nspanel-lovelace-ui.0 send kill signal
      	2025-08-14 15:43:52.892	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      	2025-08-14 15:43:52.891	info	terminating
      	2025-08-14 15:43:52.891	info	Got terminate signal TERMINATE_YOURSELF
      host.Iobroker
      	2025-08-14 15:43:52.887	info	stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=true)
      javascript.0
      	2025-08-14 15:43:46.557	info	Stopping script script.js.nspanel-lovelace-ui_0.conf
      javascript.0
      	2025-08-14 15:43:46.444	info	script.js.nspanel-lovelace-ui_0.conf: [ 'Panel for Topic: topic Script version 0.9.1 is correct!', 'No navigation items found! This needs to be fixed!', 'done' ]
      	2025-08-14 15:43:46.424	error	[config-manager] No navigation items found! This needs to be fixed!
      teletapi 1 Reply Last reply Reply Quote 0
      • teletapi
        teletapi @hm_krause last edited by teletapi
        @hm_krause genau das gleiche Problem hatte ich auch. Bis ich durch @TT-Tom und @ticaki darauf aufmeksam gemacht wurde das auch nicht den Schritt für Schritt anleitungen gefolgt bin. Wie war das noch.... Wenn alles da ist das script starten (Das script beendet sich wieder) dann in den Adapter und diesen neu starten. danach kam die Grund oder Basis config erst . dauert paar sekunden
        Hier kannst du lesen wie mein Problem aussah.... https://forum.iobroker.net/topic/80055/betatest-nspanel-lovelace-ui-v0-2-x/174
        Ich hab auch ne ganze Zeit gebraucht um erstmal zu kapieren wie es geht das Script bleibt nicht geöffnet. Das schließt sich nach dem neustart wieder und danach muss der Adapter neu gestartet werden um die Konfig zu laden die er durch das Starten des scriptes bekommen hat.
        Und nach jeder Änderung muss das wieder neu gestart und der Adapter ebenfalls neu gestartet werden.
        @TT-Tom hier könnte die Anleitung in meinen Augen durchaus ausführlicher sein bzw einfacher geschrieben werden. Mir ist das früher bei Anleitungen auch immer mal wieder passiert das (weil man es selbst sehr gut beherscht) vergisst das auf der anderen Seite relativ unbedarfte Menschen sitzen.... (So wie ich) ... 😉
        Und das soll keine Kritik an eurer Arbeit sein die ist hervorragend genauso wie eure Hilfestellung
          hm_krause @teletapi last edited by
          @teletapi
          Was hattest Du denn für ein minimal Script genommen.
          Das Beispiel Konfig Script läuft daurch und beendet sich ja auch.
          Der Adapter will aber nicht starten..:-(
          Ich weiß ja aich das der Fehler "vor" dem Monitor sitzt, aber helfen tut das nicht.
          • teletapi
            @hm_krause ich weiß war bei mir genauso. (Letztendlich hatte ich soviel probiert und getestet das ich zum Schluss als es dann startete nicht mehr sicher war was ich falsch oder richtig gemacht habe.) Hast du nach dem Start des scriptes den Adapter neu gestartet. Vielleicht zeigst du mal deine Adapter seite..?
            teletapi T 2 Replies Last reply Reply Quote 0
            • teletapi
              teletapi @teletapi last edited by teletapi
              @teletapi
              Das minimal script ist im Basisscript enthalten da muss man nix machen. Wenn du im Adapter auf script drückst erstellt der Adapter ein JS Ordner in dem das passende script enthalten ist das einmal starten und danach den Adapter neustarten. Evtl. würde ich nochmal in den Adapter gehen und auf Tabelle aktualisieren gehn und wenn du das Panel da aufrufst muss die tasmota Version drin sein die du nutzt. Die war bei mir vorher auch nicht drin.
                ticaki @teletapi last edited by
                @hm_krause
                Das letzte Mal waren die topics unterschiedlich zwischen dem Skript und der Adapter konfiguration
                  TT-Tom @teletapi last edited by
                  @teletapi
                  Danke für deine Hinweise.
                  @hm_krause
                  Lege bitte mal im Script eine Seite an. uniqename muss main sein.
                  Bin noch unterwegs und kann leider nicht besser helfen von hier.
                    @teletapi
                    Meinst Du mit Basisscript dieses:
                    https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/blob/main/script/example_sendTo_script_iobroker.ts
                    Hier noch:
                    • teletapi
                      @hm_krause Den fehler hatte ich bisher noch nicht der ist mir neu. Aber ja das ist das script was durch den Adsapter erstellt werden soll natürlich unter dem passenden Ordner. hast du mal geschaut ob deine Topics passen
                        @teletapi
                        ..und was hattest Du als Basisscript?
                        • teletapi
                          @hm_krause Das gleiche wie du
                            @teletapi
                            und..
                            und...
                            T T 2 Replies Last reply Reply Quote 0
                              ticaki @hm_krause last edited by
                              @hm_krause
                              Oben steht woran es liegt. Irgendwas wurde umbenannt nach dem initialisieren.
                                hm_krause @ticaki last edited by
                                @ticaki
                                  ticaki @hm_krause last edited by ticaki
                                  @hm_krause
                                  Lösche das Panel und das Skript. Dann initialisiere das Panel und führe das erstellte Skript aus
                                  Bin ebenfalls unterwegs daher eher kurz anbebunden
                                    TT-Tom @hm_krause last edited by
                                    @hm_krause
                                    Der Fehler liegt im Tasmota Topic
                                    Der Adapter legt die Daten in Tasmota an, du brauchst in Tasmota nichts anpassen.
                                    Lösche das Panel auf dem 2.Tab (NSpanel Einstellungen) und das Script im Javascript Adapter.
                                    Dann Instanz neu starten und von vorne anlegen, mqtt einstellungen kannst du lassen.
                                    Schritt für schritt laut wiki
                                      @ticaki
                                      @teletapi
                                      Das ändern des Panelnamens war die Lösung welche nun zum Start des Adapters führte.
                                      Unter dem vorherigen Namen war das Script von dem Projekt
                                      https://forum.iobroker.net/topic/58170/sonoff-nspanel-mit-lovelace-ui
                                      angelegt.
                                      Danke für Eure Hilfe.
                                      Das Panel ist noch offline, dachte aber das hier minimal den Sreensaver angezeigt wird.
                                      Leider nur "waiting for content...
                                      Was muss ich hier noch tun?
                                        @hm_krause
                                        dein Topic stimmt laut Bildern nicht
                                        in tasmota steht übersetzt nspanel_1/nspanel_1/%prefix%
                                        im Adapter steht nspanel_1/%prefix%
                                        lösche in Tasmota -> /%topic%
                                        prüfe aber auch den Topic im Script
                                          TT-Tom @teletapi last edited by TT-Tom
                                          @teletapi
                                          0,1 und 0,01 ergeben beide nur eine Nachkommastelle.
                                          ja, kann den Fehler nachstellen, muss ich mir in Ruhe ansehen.
                                            @hm_krause
                                            Skript ausführen und Adapter neustarten.
                                            Das andere Projekt hat nichts mit diesem hier zu tun. ( außer den selben Betreuern)
                                            Bin in ca 1h zuhause 😊
                                            534
                                            71983
