KNX Adapter funktioniert nicht mehr (Reboot Schleife)
seid heute Nacht funktionierte mein KNX-Adapter (2.0.30) nicht mehr richtig. Vor allem waren Objekte betroffen die Werte (z.b. Temperatur) per Direct-Link vom IObroker zum KNX-Bus sendeten. Es kamen auch Fehlermeldungen (siehe Log-Auszug)
2025-08-14 16:29:35.781 - info: host.raspberrypi instance system.adapter.knx.0 in version "2.0.30" started with pid 4699 2025-08-14 16:29:39.470 - info: knx.0 (4699) starting. Version 2.0.30 in /opt/iobroker/node_modules/iobroker.knx, node: v22.18.0, js-controller: 7.0.6 2025-08-14 16:29:43.259 - warn: knx.0 (4699) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses ! 2025-08-14 16:29:43.262 - info: knx.0 (4699) Connecting to knx GW: 192.168.XXX.XXX:3671 with phy. Adr: 1.1.0 2025-08-14 16:29:43.393 - error: knx.0 (4699) uncaught exception: Cannot read properties of null (reading 'val') 2025-08-14 16:29:43.393 - error: knx.0 (4699) TypeError: Cannot read properties of null (reading 'val') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:421175) at processImmediate (node:internal/timers:487:21) 2025-08-14 16:29:43.394 - error: knx.0 (4699) Cannot read properties of null (reading 'val') 2025-08-14 16:29:43.466 - info: knx.0 (4699) terminating 2025-08-14 16:29:43.468 - warn: knx.0 (4699) Terminated (UNCAUGHT_EXCEPTION): Without reason 2025-08-14 16:29:43.520 - error: knx.0 (4699) uncaught exception: Cannot read properties of null (reading 'val') 2025-08-14 16:29:43.521 - error: knx.0 (4699) TypeError: Cannot read properties of null (reading 'val') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:421175) at processImmediate (node:internal/timers:487:21) 2025-08-14 16:29:43.522 - error: knx.0 (4699) Cannot read properties of null (reading 'val') 2025-08-14 16:29:43.955 - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading 'val') 2025-08-14 16:29:43.956 - error: host.raspberrypi Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:421175) 2025-08-14 16:29:43.956 - error: host.raspberrypi Caught by controller[0]: at processImmediate (node:internal/timers:487:21) 2025-08-14 16:29:43.956 - error: host.raspberrypi Caught by controller[1]: Unkown Inputvalue! Please also check Type of Datapoint.true 2025-08-14 16:29:43.956 - error: host.raspberrypi Caught by controller[2]: Unkown Inputvalue! Please also check Type of Datapoint.false 2025-08-14 16:29:43.956 - error: host.raspberrypi Caught by controller[3]: Unkown Inputvalue! Please also check Type of Datapoint.false 2025-08-14 16:29:43.957 - error: host.raspberrypi Caught by controller[4]: TypeError: Cannot read properties of null (reading 'val') 2025-08-14 16:29:43.957 - error: host.raspberrypi Caught by controller[4]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:421175) 2025-08-14 16:29:43.957 - error: host.raspberrypi Caught by controller[4]: at processImmediate (node:internal/timers:487:21) 2025-08-14 16:29:43.958 - error: host.raspberrypi instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2025-08-14 16:29:43.958 - info: host.raspberrypi Restart adapter system.adapter.knx.0 because enabled
Ich habe ca. 200 Gruppenadressen.
Der Adapter startet ständig neu.
Als ich nicht weiter kam habe ich die Instanz und den Adapter gelöscht und neuinstalliert. Danach läuft die KNX-Instanz und ich konnte die Gruppenadressen importieren. Aber im Gruppenadressen-Tool kann ich keine Direct-Links mehr einstellen, sobald ich einen Non-KNX IObroker State verknüpfen möchte, verschwindet das ganze Gruppenadressen-Tool.
Mittlerweile habe ich auch Node.js 22 installiert und KNX-Adapter 2.0.31 , aber das verhalten blieb gleich.Vielleicht kann mir jemand helfen. Vielen Dank und viele Grüße
@satric sagte in KNX Adapter funktioniert nicht mehr:
(siehe Screenshot):
Bitte KEINE Screenshots von Text. Das Log immer als Text in CodeTags eingebettet hier rein.
Wenn es Text wäre könnte ich dir die passende Meldung auch zitieren.
So nur:
Dir fehlt die Lizenz für den Adapter.€dit: Ist nur ein Hinweis, das Limit ist wohl noch nicht erreicht.
@thomas-braun Ich habe den Text als Code hinzugefügt. Vielen Dank
Geht doch...
Und die Kirsche auf der Sahne wäre noch eine chronologisch richtige Abfolge. Kann man entweder dem Log direkt entnehmeniob logs
oder wenn es schon aus der GUI sein muss stellt man die Leserichtung mit dem Pfeil ein.
@thomas-braun Schande über mein Haupt. Jetzt habe ich es hoffentlich.
Ich habe es gefunden. Es war ein alter Direktlink, dessen Sensor nicht mehr aktiv ist. Diesen Link habe ich gelöscht, seitdem scheint es zu laufen. Keine Ahnung warum der Direktlink erst jetzt Probleme gemacht hat, denn den Sensor gibt es schon ein halbes Jahr nicht mehr.
