    4. Betatest NSPanel-lovelace-ui v0.6.x
      hm_krause @TT-Tom last edited by
      @tt-tom
      Wurde schon selbstständig geändert
      warum auch immer
      @ticaki
      ..kein Stress..
        TT-Tom @hm_krause last edited by
        @hm_krause
        prüfe im script, was hier hinter panelTopic steht, da muss nspanel_1 stehen
            const config: ScriptConfig.Config = {
                panelTopic: 'SmartHome/NSPanel_1',
                weatherEntity: 'openweathermap.0.',
                defaultOffColor: Off,
                defaultOnColor: On,
                defaultBackgroundColor: HMIDark,
                weatherAddDefaultItems: false,
        der Name vom Script, muss gleich dem Namen vom Panel sein.
        Script starten, danach adapter neu starten.
        bitte auch mal das Log zeigen vom Scriptstart und Adapterstart.
          @tt-tom
          ...vom Script
          javascript.0	19:50:26.202	info
          Compiling TypeScript source script.js.nspanel-lovelace-ui_0.Panel_1
          javascript.0	19:50:26.309	info
          source code did not change, using cached compilation result...
          javascript.0	19:50:26.321	info
          registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0	19:50:26.522	info
            'Panel for Topic: nspanel_1 Script version 0.9.1 is correct!',
            'No navigation items found! This needs to be fixed!',
            'done'
          javascript.0	19:50:26.588	info
          Stopping script script.js.nspanel-lovelace-ui_0.Panel_1
          ...Adapter
          nspanel-lovelace-ui.0
          	2025-08-14 19:52:02.321	info	[Panel_1] Panel startup finished!
          	2025-08-14 19:52:02.320	debug	[Panel_1] Set screeensaver timeout to 2s.
          	2025-08-14 19:52:02.220	debug	[Panel_1] Set screeensaver timeout to 15s.
          	2025-08-14 19:52:01.867	debug	[///Adapter-Info] Switch page to visible!
          	2025-08-14 19:52:00.070	debug	[controller] Panel E4_65_B8_48_80_70 created
          	2025-08-14 19:51:59.867	warn	[Panel_1-navigation] Dont find navigation main page for main
          	2025-08-14 19:51:59.867	warn	[Panel_1-navigation] Dont find a navigation node with name main
          	2025-08-14 19:51:59.866	warn	[Panel_1-navigation] Dont find a navigation node with name main
          	2025-08-14 19:51:57.927	warn	[Panel_1] is offline!
          	2025-08-14 19:51:57.919	info	[Panel_1] is online!
          	2025-08-14 19:51:57.754	debug	[system-notifications] Received notifications from "system.host.iob-huawei": {"system":{"categories":{},"description":{"en":"These notifications are collected by the ioBroker system and point to issues you should check and fix.","de":"Diese Benachrichtigungen werden vom ioBroker-System erfasst und weisen auf Probleme hin, die überprüft und behoben werden sollten.","ru":"Эти уведомления собираются системой ioBroker и указывают на проблемы, которые вы должны проверить и исправить.","pt":"Essas notificações são coletadas pelo sistema ioBroker e apontam para problemas que você deve verificar e corrigir.","nl":"Deze meldingen worden verzameld door het ioBroker-systeem en wijzen op problemen die u moet controleren en oplossen.","fr":"Ces notifications sont collectées par le système ioBroker et indiquent des problèmes que vous devez vérifier et résoudre.","it":"Queste notifiche vengono raccolte dal sistema ioBroker e indicano problemi che dovresti controllare e correggere.","es":"Estas notificaciones son recopiladas por el sistema ioBroker y señalan problemas que debe verificar y solucionar.","pl":"Te powiadomienia są zbierane przez system ioBroker i wskazują problemy, które należy sprawdzić i naprawić.","uk":"Ці сповіщення збираються системою ioBroker і вказують на проблеми, які ви повинні перевірити та виправити.","zh-cn":"这些通知由ioBroker系统收集,并指出您应检查并修复的问题"},"name":{"en":"System Notifications","de":"System-Benachrichtigungen","ru":"Системные уведомления","pt":"Notificações do sistema","nl":"Systeemmeldingen","fr":"Notifications système","it":"Notifiche di sistema","es":"Notificaciones del sistema","pl":"Powiadomienia systemowe","uk":"Системні сповіщення","zh-cn":"系统通知"}}}
          	2025-08-14 19:51:57.748	debug	[system-notifications] Request notifications from "system.host.iob-huawei"
          	2025-08-14 19:51:57.748	debug	[system-notifications] Received notifications from "system.host.Iobroker": {}
          	2025-08-14 19:51:57.725	debug	[system-notifications] Request notifications from "system.host.Iobroker"
          	2025-08-14 19:51:57.713	debug	[mqttClient] subscripe to: nspanel_1/stat/#
          	2025-08-14 19:51:57.711	debug	[mqttClient] subscripe to: nspanel_1/tele/#
          	2025-08-14 19:51:57.711	debug	[Panel_1] Panel E4_65_B8_48_80_70 is initialised!
          	2025-08-14 19:51:57.671	debug	[controller] Set current Date with time: Thu Aug 14 2025 19:51:57 GMT+0200 (Central European Summer Time)
          	2025-08-14 19:51:57.606	debug	[mqttClient] subscripe to: nspanel_1/stat/RESULT
          	2025-08-14 19:51:57.559	debug	[controller] controller created
          	2025-08-14 19:51:57.557	debug	42818.65625k
          	2025-08-14 19:51:57.556	info	[mqttClient] Connection is active.
          	2025-08-14 19:51:57.502	debug	Check configuration!
          	2025-08-14 19:51:55.469	info	Force an MQTT reconnect from the Nspanel with the ip 192.168.178.56 in 10 seconds!
          	2025-08-14 19:51:55.391	debug	[library] Load language de
          	2025-08-14 19:51:55.390	info	Raw script config found for nspanel_1
          	2025-08-14 19:51:55.388	error	[config-manager] No navigation items found! This needs to be fixed!
          	2025-08-14 19:51:55.387	debug	[config-manager] Screensaver pageItems count: 17
          	2025-08-14 19:51:55.384	warn	Invalid color value: "0_userdata.0.Abfallkalender.1.color"
          	2025-08-14 19:51:55.291	info	[config-manager] Start converting configuration for nspanel_1
          	2025-08-14 19:51:55.238	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
          	2025-08-14 19:51:50.324	info	terminating
          	2025-08-14 19:51:49.837	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          	2025-08-14 19:51:49.836	info	terminating
          	2025-08-14 19:51:49.835	info	[mqttClient] Connection is closed.
          	2025-08-14 19:51:49.833	debug	[///Adapter-Info] Switch page to invisible!
          	2025-08-14 19:51:49.822	info	Got terminate signal TERMINATE_YOURSELF
            ticaki @hm_krause last edited by
            Zeig mal den kompletten oberen Teil vom Skript.
              ticaki last edited by ticaki
              Hab in der aktuellen Github version mal etwas mehr Log eingebaut damit das mit Topics besser zu sehen ist einmal beim startup:
              ... Configured panels: name#topic -> [ns_panel4#nspanel/ns_panel4], [nspanel6#nspanel/ns_panel6]
              ... Found 2 script configs for topics: nspanel/ns_panel4, nspanel/ns_panel6
              Beim übertragen des Skripts gibts noch zusätzlich:
              Im log steht dann:
              2025-08-14 21:06:18.038  - error: nspanel-lovelace-ui.0 (99753) [config-manager] Panel for Topic: nspanel/ns_panel67 not found in adapter config!
                hm_krause @ticaki last edited by
                @ticaki
                hier bitte
                async function configuration(): Promise<void> {
                    const overrideConfig: Partial<ScriptConfig.Config> = {
                        // hier kann man die Werte von unten überschreiben bzw nicht ewig im Skript suchen wo nochmal die Farbe steht :)
                        // pages und subpages geht hier nicht, weil die Seiten ja erst später angelegt werden. Bei const gehts nach Reihenfolge.
                        // panelTopic: 'nspanel/ns_panel4',
                        weatherEntity: 'pirate-weather.0.',
                        defaultOnColor: On,
                         ** https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/wiki/Adapter-Installation **
                         **                       Page Configuration                          **
                    // Diese Konfiguration für den Fahrplan ist ein Beispiel was die interne Adapterkonfiguration benutzt, diese
                    // ist recht komplex und wird nicht weiter erläutert. Da gibts später fertige Templates die man hier verwenden kann.
                    // wie am Fahrplan Beispiel zu sehen ist.
                    /* const fahrplan: any = {
                        heading: 'Fahrplan Script',
                        native: {
                            card: 'cardEntities',
                            dpInit: 'fahrplan.0.0',
                            uniqueID: 'fahrplanrouten',
                            template: 'entities.fahrplan.routes',
                    // Konfiguration findet im Admin statt, uniqueName muß gleich dem namen in der Adminkonfiguration sein.
                    /* const qrCode: ScriptConfig.PageQR = {
                        type: 'cardQR',
                        uniqueName: 'qrCode'
                    /* const chartHeizung: ScriptConfig.PageChart = {
                        type: 'cardChart',
                        uniqueName: 'temperatur'
                    // Ein Beispiel für eine Gridseite mit verschiedenen Farbskalen
                    /* const irgendeinName: ScriptConfig.PageGrid = {
                        type: 'cardGrid',
                        uniqueName: 'main',
                        heading: 'Wohnzimmer',
                        useColor: true,
                        items: [
                            {id: 'alias.0.Temperatur', name: 'standard', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40}},
                            {id: 'alias.0.Temperatur', name: 'hue', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'hue'}},
                            {id: 'alias.0.Temperatur', name: 'cie', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'cie'}},
                            {id: 'alias.0.Temperatur', name: 'standard log min', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, log10: 'min'}},
                            {id: 'alias.0.Temperatur', name: 'hue log min', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'hue', log10: 'min'}},
                            {id: 'alias.0.Temperatur', name: 'cie log min', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'cie', log10: 'min'}},
                            {id: 'alias.0.Temperatur', name: 'standard log max', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, log10: 'max'}},
                            {id: 'alias.0.Temperatur', name: 'hue log max', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'hue', log10: 'max'}},
                            {id: 'alias.0.Temperatur', name: 'cie log max', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'cie', log10: 'max'}},
                    /* const grid1: ScriptConfig.PageGrid = {
                        uniqueName: 'grid1', // keine Navigation, am besten uniqueName von config.ts übernehmen
                        heading: 'Grid 1',
                        items: [
                            {id: 'alias.0.Licht.lights.Gerät_1'},
                            {id: 'alias.0.Licht.lights.Gerät_2'},
                            {id: '0_userdata.0.Einzelne_Geräte.dimmer'},
                            {id: 'alias.0.NSPanel.allgemein.hue', },
                            {navigate: true, targetPage: 'fahrplanrouten'},
                            {id: 'alias.0.NSPanel.allgemein.shutter'}
                        type: 'cardGrid',
                        useColor: true
                        panelTopic: 'nspanel_1',
                        weatherEntity: 'pirate-weather.0',
                        defaultOnColor: On,
                        // Als Gedankenstütze, die Hauptseite muß main heißen!
                        //panelName: 'NSPanel', //unique name for the panel
                        // Seiteneinteilung / Page division
                        // Hauptseiten / Mainpages
                        pages: [
                            //irgendeinName,
                            //grid1,
                            //qrCode,
                            //chartHeizung,
                        // Unterseiten / Subpages
                        subPages: [
                            //fahrplan
                         **                    Screensaver Configuration                      **
                        favoritScreensaverEntity: [
                                type: 'template',
                                template: 'text.openweathermap.favorit',
                                dpInit: `/^openweathermap\\.0.+/`,
                                modeScr: 'favorit',
                        alternateScreensaverEntity: [
                            // only used with alternate Screensaver
                        indicatorScreensaverEntity: [
                            // indicatorScreensaverEntity 1 (only Advanced Screensaver)
                                type: 'script',
                                ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_offene_Fenster.ACTUAL',
                                ScreensaverEntityFactor: 1,
                                ScreensaverEntityDecimalPlaces: 0,
                                ScreensaverEntityIconOn: 'window-open-variant',
                                ScreensaverEntityIconOff: 'window-closed-variant',
                                ScreensaverEntityText: 'Fenster',
                                ScreensaverEntityUnitText: '%',
                                ScreensaverEntityIconColor: {val_min: 0, val_max: 1},
                            // indicatorScreensaverEntity 2 (only Advanced Screensaver)
                                type: 'script',
                                ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_offene_Tuer.ACTUAL',
                                ScreensaverEntityIconOn: 'door-open',
                                ScreensaverEntityIconOff: 'door-closed',
                                ScreensaverEntityText: 'Tür',
                                ScreensaverEntityUnitText: '',
                            // indicatorScreensaverEntity 3 (only Advanced Screensaver)
                                type: 'script',
                                ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_Licht_An.ACTUAL',
                                ScreensaverEntityIconOn: 'lightbulb',
                                ScreensaverEntityIconOff: null,
                                ScreensaverEntityText: 'Licht',
                            // indicatorScreensaverEntity 4 (only Advanced Screensaver)
                                type: 'script',
                                ScreensaverEntity: 'alias.0.Türschloss.ACTUAL',
                                ScreensaverEntityIconOn: 'lock',
                                ScreensaverEntityIconOff: 'lock-open',
                                ScreensaverEntityText: 'Türschloss',
                                ScreensaverEntityIconColor: {val_min: 0, val_max: 1, val_best: 1},
                            // indicatorScreensaverEntity 5 (only Advanced Screensaver)
                                type: 'script',
                                ScreensaverEntity: 'alias.0.NSPanel.allgemein.Auto.Safety.ACTUAL',
                                ScreensaverEntityIconOn: 'car-key',
                                ScreensaverEntityText: 'Auto',
                        bottomScreensaverEntity: [
                            // bottomScreensaverEntity 1
                                type: 'template',
                                template: 'text.openweathermap.sunriseset',
                                dpInit: `/^openweathermap\\.0\\.forecast\\.current.+/`,
                                modeScr: 'bottom',
                            // bottomScreensaverEntity 2
                                type: 'template',
                                template: 'text.hmip.windcombo',
                                dpInit: 'hmip.0.devices.3014F711A000185F2999676C',
                                modeScr: 'bottom',
                                //readOptions: {directionOfPanel: 81}
                                type: 'script',
                                ScreensaverEntity: 'openweathermap.0.forecast.current.windSpeed',
                                ScreensaverEntityDecimalPlaces: 1,
                                ScreensaverEntityIconOn: 'weather-windy',
                                ScreensaverEntityText: "Wind",
                                ScreensaverEntityUnitText: 'm/s',
                                ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120}
                            // bottomScreensaverEntity 3
                                type: 'script',
                                ScreensaverEntity: 'openweathermap.0.forecast.current.windGust',
                                ScreensaverEntityIconOn: 'weather-tornado',
                                ScreensaverEntityText: 'Böen',
                            // bottomScreensaverEntity 4
                                type: 'template',
                                template: 'text.openweathermap.winddirection',
                                dpInit: `/^openweathermap\\.0./`,
                                modeScr: 'bottom',
                            // bottomScreensaverEntity 5 (Advanced Screensaver)
                                type: 'script',
                                ScreensaverEntity: 'openweathermap.0.forecast.current.humidity',
                                ScreensaverEntityIconOn: 'water-percent',
                                ScreensaverEntityText: 'Feuchte',
                                ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 60}
                            // bottomScreensaverEntity 6 (for Advanced Screensaver)
                            // the 6th day from dasWetter
                                type: 'native',
                                native: dasWetterBottomScreensaverEntity6
                            // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400
                            // Some templates for the screensaver uncomment the lines to use them
                            // If u use an other instance for the weather data, change the instance in the following lines
                            // If you want to have them all, set weatherAddDefaultItems=true in the config and leave the following lines as they are!
                H T 2 Replies Last reply Reply Quote 0
                  hm_krause @hm_krause last edited by
                  und
                  javascript.0	21:19:50.614	info
                  javascript.0	21:19:50.697	info
                  javascript.0	21:19:50.709	info
                  javascript.0	21:19:50.767	info
                    'done'
                  javascript.0	21:19:50.992	info
                    ticaki @hm_krause last edited by ticaki
                    @hm_krause
                    Du hast alles auskommentiert - kein Wunder das da nix läuft.
                    Wenn keine Seite mit dem uniqueName: 'main' vorhanden ist, ist das Verhalten des Adapter undefiniert. Kommentiere "irgendeinName" wieder ein entferne alle pageItems und kommentiere es auch in pages wieder ein - dann sollte zumindest was angezeigt werden... wobei hab noch net ausprobiert ob cardGrid mit 0 items geht.
                    EDIT: zu dem undefinierten Verhalten - ich muß vor dem Screensaver irgendwas anzeigen und das Skript funktioniert, auch wenn du die Datenpunkte nicht hast - ich dachte dann passen die User das an.
                      @ticaki
                      Danke erstmal,
                      werde das morgen nochmal in Ruhe angehen.
                      Ich habe von Scripte leider überhaupt keine Ahnung.
                      Bisher lief das mit anderen Sachen per Copy/Paste
                      Melde mich dann wieder...
                        @hm_krause
                        Sry ich sehe gerade das TT-Tom das auskommentiert hat nicht du. Ich muß das jetzt mal selbst durch probieren. Ich teste halt sehr selten das neuerstellen - glaube ist schon 2 Monate her
                        Ok, bis auf die Fehlermeldungen gehts doch... ist echt zu warm heute 😄
                        Egal machen wir morgen weiter - im Bespielskript sollte aber ne funktionierende Hauptseite sein - mal gucken wo ich states finde die jeder hat 🙂
                          @hm_krause
                          Füge im Skript unterhalb von
                          das hier
                              const Hauptseite: ScriptConfig.PageGrid = {
                                  type: 'cardGrid',
                                  uniqueName: 'main',
                                  heading: 'Die Leere',
                                  items: []
                          ein und und füge in pages Hauptseite ein damit das so aussieht:
                                  pages: [
                                      Hauptseite
                                      //irgendeinName,
                                      //grid1,
                                      //qrCode,
                                      //chartHeizung,
                            Mal ein paar Vorlagen mit Erklärung dazu wo sie benutzt werden können und wie. (Das nächste glaube ich)Screensaver Vorlagen funktionieren nicht für cardGrid/cardEntites und umgedreht (muß das mal testen 🙂 ).
                            modeScr ist immer variable - obs Sinn macht ist was anderes -> ein Bottomicon für wind im indicator anzuzeigen macht keinen Sinn.
                            Allgemeines
                            dpInit: 'sainlogic.0', bezeichnet immer den Datenpfad unter dem man die dazu gehörigen Datenpunkte finden kann. Das muß zu eindeutigen Ergenissen führen. Wenn es also sainlogic.0 und sainlogic.1 mal gibt muß dort sainlogic.0 oder sainlogic.1stehen
                            Screensaver: Windrichtung/-geschwindigkeit für sainlogic
                                            type: 'template',
                                            template: 'text.sainlogic.windarrow',
                                            modeScr: 'bottom',
                                            readOptions: {directionOfPanel: 0} //0-360
                            readOptions ist optional und die darin enthaltende Eigenschaft directionOfPanel bestimmt in welche Richtung die Person schaut, wenn sie auf das Panel sieht. Wenn dort nichts oder 0 steht ist der Pfeil genordet - also oben ist norden. Wenn man es anpasst wie beschrieben ist oben die Richtung relativ zur Person die drauf guckt zu sehen.
                            Aussehen:
                            Screensaver: Windrichtung/-geschwindigkeit generisch
                                            type: 'template',
                                            template: 'text.generic.windarrow',
                                            dpInit: 'Bitte anpassen',
                                            modeScr: 'bottom',
                            dpinit muß hier angepasst werden und auf einen Order zeigen in dem 2 Datenpunkte mit folgenden Rolen und Typen zu finden sind.
                            // Datenpunkt 1 für Richtung
                            type: 'number',
                            role: 'value.direction.wind',
                            // Datenpunkt 2 für Geschwindigkeit
                            type: 'number',
                            role: 'value.speed.wind',
                            unit:'km/h', // oder m/s oder was auch immer
                            Screensaver: Batterieanzeige für bydhvs
                            Zeigt Ladestand in 10er Schritten an, ändert die Farbe wenn sie leer wird. Laden und entladen sind unterschiedliche Icons - werden ca. 20 verschiedene Icons verwendet.
                                            type: 'template',
                                            template: 'text.battery.bydhvs',
                                            dpInit: 'bydhvs.0',
                                            modeScr: 'bottom',
                            sieht so aus:
                            Screensaver: Wetterdaten anzeigen für Pirate-Weather oder Openweathermap
                            Dazu findet man viel Beispiele für Wetterdaten im Konfigskript - Da der Adapter aber nichts im Nutzercode ändert, muß man für aktuelle Beispiele auf Github schauen: https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/blob/main/script/example_sendTo_script_iobroker.ts - ich kopiere die mal hier mit dazu:
                            OPENWEATHERMAP
                                        //OPENWEATHERMAP
                                        // Bottom 1 - sunrise/set
                                            type: 'template',
                                            modeScr: 'favorit',
                                        // Bottom 2 -  Forecast Day 1
                                            type: 'template',
                                            template: 'text.openweathermap.bot2values',
                                            dpInit: `/^openweathermap\\.0.+?day0/`,
                                            modeScr: 'bottom',
                                        // Bottom 3 - Forecast Day 2
                                            type: 'template',
                                            dpInit: `/^openweathermap\\.0.+?day1/`,
                                            modeScr: 'bottom',
                                        // Bottom 4 - Forecast Day 3
                                            type: 'template',
                                            dpInit: `/^openweathermap\\.0.+?day2/`,
                                            modeScr: 'bottom',
                                        // Bottom 5 - Forecast Day 4
                                            type: 'template',
                                            dpInit: `/^openweathermap\\.0.+?day3/`,
                                            modeScr: 'bottom',
                                        // Bottom 6 - Forecast Day 5
                                            type: 'template',
                                            dpInit: `/^openweathermap\\.0.+?day4/`,
                                            modeScr: 'bottom',
                                        // Bottom 7 -  Forecast Day 6
                                            type: 'template',
                                            dpInit: `/^openweathermap\\.0.+?day5/`,
                                            modeScr: 'bottom',
                                        // Bottom 8 - Windgeschwindigkeit
                                            type: 'template',
                                            template: 'text.openweathermap.windspeed',
                                            modeScr: 'bottom',
                                        // Bottom 9 - Böen
                                            type: 'template',
                                            template: 'text.openweathermap.windgust',
                                            modeScr: 'bottom',
                                        // Bottom 10 - Windrichtung
                                            type: 'template',
                                            modeScr: 'bottom',
                            PIRATE-WEATHER
                                        // PIRATE-WEATHER
                                            type: 'template',
                                            template: 'text.pirate-weather.sunriseset',
                                            dpInit: `/^pirate-weather\\.0\\.weather\\.daily\\.00.+/`,
                                            modeScr: 'bottom',
                                            type: 'template',
                                            template: 'text.pirate-weather.bot2values',
                                            dpInit: `/^pirate-weather\\.0.+?\\.daily\\.01/`,
                                            modeScr: 'bottom',
                                            type: 'template',
                                            dpInit: `/^pirate-weather\\.0.+?\\.daily\\.02/`,
                                            modeScr: 'bottom',
                                            type: 'template',
                                            dpInit: `/^pirate-weather\\.0.+?\\.daily\\.03/`,
                                            modeScr: 'bottom',
                                            type: 'template',
                                            dpInit: `/^pirate-weather\\.0.+?\\.daily\\.04/`,
                                            modeScr: 'bottom',
                                            type: 'template',
                                            dpInit: `/^pirate-weather\\.0.+?\\.daily\\.05/`,
                                            modeScr: 'bottom',
                                            type: 'template',
                                            dpInit: `/^pirate-weather\\.0.+?\\.daily\\.06/`,
                                            modeScr: 'bottom',
                                            type: 'template',
                                            template: 'text.pirate-weather.windspeed',
                                            dpInit: `/^pirate-weather\\.0\\.weather\\.currently./`,
                                            modeScr: 'bottom',
                                        // Bottom 9 - Böen
                                            type: 'template',
                                            template: 'text.pirate-weather.windgust',
                                            modeScr: 'bottom',
                                            type: 'template',
                                            template: 'text.pirate-weather.winddirection',
                                            modeScr: 'bottom',
                                        // Bottom 11 - UV-Index
                                            type: 'template',
                                            template: 'text.pirate-weather.uvindex',
                                            modeScr: 'bottom',
                            // hier mit kann man dann eine Stundenübersicht erzeugen durch anpassen der 02 bzw. 04
                                            type: 'template',
                                            template: 'text.pirate-weather.hourlyweather',
                                            dpInit: `/^pirate-weather\\.0.+?\\.hourly\\.02/`,
                                            modeScr: 'bottom',
                                            type: 'template',
                                            dpInit: `/^pirate-weather\\.0.+?\\.hourly\\.04/`,
                                            modeScr: 'bottom',
                            Da kann man sich einzelne Rauspicken und die dort anzeigen wo man möchte - also bottom geht als favorit und left als bottom usw. wie man möchte.
                              Pirate-Weather
                              Ist in der aktuellen Githubversion implementiert
                              H 1 Reply Last reply Reply Quote 2
                                @ticaki
                                leider immer noch der gleiche, nicht funktionende Stand.
                                Script:
                                        defaultOnColor: On,
                                    // Beispiel Hauptseite / Mainpage
                                    // Diese Seite ist die Hauptseite, sie wird immer als erstes angezeigt und hat den uniqueName 'main'.
                                    // uniqueName 'main' muß mindestens einmal vorkommen, damit die Navigation funktioniert.
                                        type: 'cardGrid',
                                        uniqueName: 'main',
                                        items: []
                                        native: {
                                        type: 'cardQR',
                                        type: 'cardChart',
                                        type: 'cardGrid',
                                        uniqueName: 'main',
                                        items: [
                                        heading: 'Grid 1',
                                        items: [
                                        type: 'cardGrid',
                                        panelTopic: 'topic',
                                        defaultOnColor: On,
                                        pages: [
                                            Hauptseite
                                            //irgendeinName,
                                            //grid1,
                                            //qrCode,
                                            //chartHeizung,
                                        subPages: [
                                            //fahrplan
                                Script Log:
                                javascript.0	13:54:46.322	info
                                javascript.0	13:54:46.399	info
                                javascript.0	13:54:46.420	info
                                javascript.0	13:54:46.538	info
                                [ 'Panel for Topic: topic Script version 0.9.1 is correct!', 'done' ]
                                javascript.0	13:54:46.673	info
                                Adapter:
                                	2025-08-15 13:55:54.566	info	[Panel_1] Panel startup finished!
                                	2025-08-15 13:55:54.566	debug	[Panel_1] Set screeensaver timeout to 2s.
                                	2025-08-15 13:55:54.465	debug	[Panel_1] Set screeensaver timeout to 15s.
                                	2025-08-15 13:55:54.455	debug	[main] Switch page to visible!
                                	2025-08-15 13:55:54.024	debug	[controller] Panel E4_65_B8_48_80_70 created
                                	2025-08-15 13:55:51.715	warn	[Panel_1] is offline!
                                	2025-08-15 13:55:51.707	info	[Panel_1] is online!
                                	2025-08-15 13:55:51.549	debug	[system-notifications] Received notifications from "system.host.iob-huawei": {"system":{"categories":{},"description":{"en":"These notifications are collected by the ioBroker system and point to issues you should check and fix.","de":"Diese Benachrichtigungen werden vom ioBroker-System erfasst und weisen auf Probleme hin, die überprüft und behoben werden sollten.","ru":"Эти уведомления собираются системой ioBroker и указывают на проблемы, которые вы должны проверить и исправить.","pt":"Essas notificações são coletadas pelo sistema ioBroker e apontam para problemas que você deve verificar e corrigir.","nl":"Deze meldingen worden verzameld door het ioBroker-systeem en wijzen op problemen die u moet controleren en oplossen.","fr":"Ces notifications sont collectées par le système ioBroker et indiquent des problèmes que vous devez vérifier et résoudre.","it":"Queste notifiche vengono raccolte dal sistema ioBroker e indicano problemi che dovresti controllare e correggere.","es":"Estas notificaciones son recopiladas por el sistema ioBroker y señalan problemas que debe verificar y solucionar.","pl":"Te powiadomienia są zbierane przez system ioBroker i wskazują problemy, które należy sprawdzić i naprawić.","uk":"Ці сповіщення збираються системою ioBroker і вказують на проблеми, які ви повинні перевірити та виправити.","zh-cn":"这些通知由ioBroker系统收集,并指出您应检查并修复的问题"},"name":{"en":"System Notifications","de":"System-Benachrichtigungen","ru":"Системные уведомления","pt":"Notificações do sistema","nl":"Systeemmeldingen","fr":"Notifications système","it":"Notifiche di sistema","es":"Notificaciones del sistema","pl":"Powiadomienia systemowe","uk":"Системні сповіщення","zh-cn":"系统通知"}}}
                                	2025-08-15 13:55:51.539	debug	[system-notifications] Request notifications from "system.host.iob-huawei"
                                	2025-08-15 13:55:51.538	debug	[system-notifications] Received notifications from "system.host.Iobroker": {}
                                	2025-08-15 13:55:51.534	debug	[system-notifications] Request notifications from "system.host.Iobroker"
                                	2025-08-15 13:55:51.503	debug	[mqttClient] subscripe to: nspanel_1/stat/#
                                	2025-08-15 13:55:51.501	debug	[mqttClient] subscripe to: nspanel_1/tele/#
                                	2025-08-15 13:55:51.501	debug	[Panel_1] Panel E4_65_B8_48_80_70 is initialised!
                                	2025-08-15 13:55:51.451	debug	[controller] Set current Date with time: Fri Aug 15 2025 13:55:51 GMT+0200 (Central European Summer Time)
                                	2025-08-15 13:55:51.395	debug	[mqttClient] subscripe to: nspanel_1/stat/RESULT
                                	2025-08-15 13:55:51.343	debug	[controller] controller created
                                	2025-08-15 13:55:51.342	debug	46401.5234375k
                                	2025-08-15 13:55:51.340	info	[mqttClient] Connection is active.
                                	2025-08-15 13:55:51.295	debug	Check configuration!
                                	2025-08-15 13:55:49.263	info	Force an MQTT reconnect from the Nspanel with the ip 192.168.178.56 in 10 seconds!
                                	2025-08-15 13:55:49.166	debug	[library] Load language de
                                	2025-08-15 13:55:49.165	info	Raw script config found for nspanel_1
                                	2025-08-15 13:55:49.161	debug	[config-manager] Screensaver pageItems count: 17
                                	2025-08-15 13:55:49.158	warn	Invalid color value: "0_userdata.0.Abfallkalender.1.color"
                                	2025-08-15 13:55:49.088	info	[config-manager] Start converting configuration for nspanel_1
                                	2025-08-15 13:55:49.035	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
                                host.Iobroker
                                	2025-08-15 13:55:47.616	info	instance system.adapter.nspanel-lovelace-ui.0 in version "0.2.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) started with pid 45081
                                host.Iobroker
                                	2025-08-15 13:55:44.162	info	instance system.adapter.nspanel-lovelace-ui.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                	2025-08-15 13:55:44.054	info	terminating
                                host.Iobroker
                                	2025-08-15 13:55:43.614	info	stopInstance system.adapter.nspanel-lovelace-ui.0 send kill signal
                                	2025-08-15 13:55:43.569	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                	2025-08-15 13:55:43.568	info	terminating
                                	2025-08-15 13:55:43.567	info	[mqttClient] Connection is closed.
                                	2025-08-15 13:55:43.564	debug	[main] Switch page to invisible!
                                	2025-08-15 13:55:43.553	info	Got terminate signal TERMINATE_YOURSELF
                                host.Iobroker
                                	2025-08-15 13:55:43.550	info	stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=true)
                                  @hm_krause
                                  Definiere bitte "nicht funktionende Stand." was genau funktioniert nicht? Bin zuhause - und klimatisiert - heißt ich hab zeit und bin nicht kurz vorm ausflippen wegen hitze 😄
                                    @ticaki
                                    Panel sagt:
                                    waiting for content.....
                                      @hm_krause
                                      Ist das alles an log was kommt für den adapter?
                                      H teletapi 2 Replies Last reply Reply Quote 0
                                        @ticaki
                                        nochmal:
                                        	2025-08-15 14:06:32.642	info	[Panel_1] Panel startup finished!
                                        	2025-08-15 14:06:32.641	debug	[Panel_1] Set screeensaver timeout to 2s.
                                        	2025-08-15 14:06:32.541	debug	[Panel_1] Set screeensaver timeout to 15s.
                                        	2025-08-15 14:06:32.474	debug	[main] Switch page to visible!
                                        	2025-08-15 14:06:31.942	debug	[controller] Panel E4_65_B8_48_80_70 created
                                        	2025-08-15 14:06:29.324	warn	[Panel_1] is offline!
                                        	2025-08-15 14:06:29.315	info	[Panel_1] is online!
                                        	2025-08-15 14:06:29.134	debug	[system-notifications] Received notifications from "system.host.iob-huawei": {"system":{"categories":{},"description":{"en":"These notifications are collected by the ioBroker system and point to issues you should check and fix.","de":"Diese Benachrichtigungen werden vom ioBroker-System erfasst und weisen auf Probleme hin, die überprüft und behoben werden sollten.","ru":"Эти уведомления собираются системой ioBroker и указывают на проблемы, которые вы должны проверить и исправить.","pt":"Essas notificações são coletadas pelo sistema ioBroker e apontam para problemas que você deve verificar e corrigir.","nl":"Deze meldingen worden verzameld door het ioBroker-systeem en wijzen op problemen die u moet controleren en oplossen.","fr":"Ces notifications sont collectées par le système ioBroker et indiquent des problèmes que vous devez vérifier et résoudre.","it":"Queste notifiche vengono raccolte dal sistema ioBroker e indicano problemi che dovresti controllare e correggere.","es":"Estas notificaciones son recopiladas por el sistema ioBroker y señalan problemas que debe verificar y solucionar.","pl":"Te powiadomienia są zbierane przez system ioBroker i wskazują problemy, które należy sprawdzić i naprawić.","uk":"Ці сповіщення збираються системою ioBroker і вказують на проблеми, які ви повинні перевірити та виправити.","zh-cn":"这些通知由ioBroker系统收集,并指出您应检查并修复的问题"},"name":{"en":"System Notifications","de":"System-Benachrichtigungen","ru":"Системные уведомления","pt":"Notificações do sistema","nl":"Systeemmeldingen","fr":"Notifications système","it":"Notifiche di sistema","es":"Notificaciones del sistema","pl":"Powiadomienia systemowe","uk":"Системні сповіщення","zh-cn":"系统通知"}}}
                                        	2025-08-15 14:06:29.122	debug	[system-notifications] Request notifications from "system.host.iob-huawei"
                                        	2025-08-15 14:06:29.121	debug	[system-notifications] Received notifications from "system.host.Iobroker": {}
                                        	2025-08-15 14:06:29.117	debug	[system-notifications] Request notifications from "system.host.Iobroker"
                                        	2025-08-15 14:06:29.112	debug	[mqttClient] subscripe to: nspanel_1/stat/#
                                        	2025-08-15 14:06:29.110	debug	[mqttClient] subscripe to: nspanel_1/tele/#
                                        	2025-08-15 14:06:29.109	debug	[Panel_1] Panel E4_65_B8_48_80_70 is initialised!
                                        	2025-08-15 14:06:29.065	debug	[controller] Set current Date with time: Fri Aug 15 2025 14:06:29 GMT+0200 (Central European Summer Time)
                                        	2025-08-15 14:06:29.003	debug	[mqttClient] subscripe to: nspanel_1/stat/RESULT
                                        	2025-08-15 14:06:28.955	debug	[controller] controller created
                                        	2025-08-15 14:06:28.954	debug	42802.5078125k
                                        	2025-08-15 14:06:28.952	info	[mqttClient] Connection is active.
                                        	2025-08-15 14:06:28.901	debug	Check configuration!
                                        	2025-08-15 14:06:26.865	info	Force an MQTT reconnect from the Nspanel with the ip 192.168.178.56 in 10 seconds!
                                        	2025-08-15 14:06:26.774	debug	[library] Load language de
                                        	2025-08-15 14:06:26.774	info	Raw script config found for nspanel_1
                                        	2025-08-15 14:06:26.769	debug	[config-manager] Screensaver pageItems count: 17
                                        	2025-08-15 14:06:26.765	warn	Invalid color value: "0_userdata.0.Abfallkalender.1.color"
                                        	2025-08-15 14:06:26.686	info	[config-manager] Start converting configuration for nspanel_1
                                        	2025-08-15 14:06:26.623	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
                                        	2025-08-15 14:06:21.536	info	terminating
                                        	2025-08-15 14:06:21.250	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        	2025-08-15 14:06:21.249	info	terminating
                                        	2025-08-15 14:06:21.249	info	[mqttClient] Connection is closed.
                                        	2025-08-15 14:06:21.245	debug	[main] Switch page to invisible!
                                        	2025-08-15 14:06:21.035	info	Got terminate signal TERMINATE_YOURSELF
                                        	2025-08-15 14:06:09.678	debug	[config-manager] Screensaver pageItems count: 17
                                        	2025-08-15 14:06:09.669	warn	Invalid color value: "0_userdata.0.Abfallkalender.1.color"
                                        	2025-08-15 14:06:09.498	info	[config-manager] Start converting configuration for topic
                                        	2025-08-15 14:06:09.497	debug	{"command":"ScriptConfig","message":{"panelTopic":"topic","weatherEntity":"openweathermap.0.","defaultOffColor":{"red":253,"green":128,"blue":0},"defaultOnColor":{"red":253,"green":216,"blue":53},"defaultBackgroundColor":{"red":29,"green":29,"blue":29},"weatherAddDefaultItems":false,"pages":[{"type":"cardGrid","uniqueName":"main","heading":"Die Leere","items":[]}],"subPages":[],"favoritScreensaverEntity":[{"type":"template","template":"text.openweathermap.favorit","dpInit":"/^openweathermap\\.0.+/","modeScr":"favorit"}],"alternateScreensaverEntity":[],"indicatorScreensaverEntity":[{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Status_offene_Fenster.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"window-open-variant","ScreensaverEntityIconOff":"window-closed-variant","ScreensaverEntityText":"Fenster","ScreensaverEntityUnitText":"%","ScreensaverEntityIconColor":{"val_min":0,"val_max":1}},{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Status_offene_Tuer.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"door-open","ScreensaverEntityIconOff":"door-closed","ScreensaverEntityText":"Tür","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":{"val_min":0,"val_max":1}},{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Status_Licht_An.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"lightbulb","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Licht","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":{"val_min":0,"val_max":1}},{"type":"script","ScreensaverEntity":"alias.0.Türschloss.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"lock","ScreensaverEntityIconOff":"lock-open","ScreensaverEntityText":"Türschloss","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":{"val_min":0,"val_max":1,"val_best":1}},{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Auto.Safety.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"car-key","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Auto","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":{"val_min":0,"val_max":1,"val_best":1}}],"bottomScreensaverEntity":[{"type":"template","template":"text.openweathermap.sunriseset","dpInit":"/^openweathermap\\.0\\.forecast\\.current.+/","modeScr":"bottom"},{"type":"script","ScreensaverEntity":"openweathermap.0.forecast.current.windSpeed","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":1,"ScreensaverEntityIconOn":"weather-windy","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Wind","ScreensaverEntityUnitText":"m/s","ScreensaverEntityIconColor":{"val_min":0,"val_max":120}},{"type":"script","ScreensaverEntity":"openweathermap.0.forecast.current.windGust","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":1,"ScreensaverEntityIconOn":"weather-tornado","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Böen","ScreensaverEntityUnitText":"m/s","ScreensaverEntityIconColor":{"val_min":0,"val_max":120}},{"type":"template","template":"text.openweathermap.winddirection","dpInit":"/^openweathermap\\.0./","modeScr":"bottom"},{"type":"script","ScreensaverEntity":"openweathermap.0.forecast.current.humidity","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"water-percent","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Feuchte","ScreensaverEntityUnitText":"%","ScreensaverEntityIconColor":{"val_min":0,"val_max":100,"val_best":60}},{"type":"native","native":{"type":"native","native":{"role":"2values","dpInit":"","type":"text","modeScr":"bottom","data":{"entity1":{"value":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Minimale_Temperatur_value"},"decimal":{"type":"const","constVal":0},"unit":{"type":"const","constVal":"° "}},"entity2":{"value":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Maximale_Temperatur_value"},"decimal":{"type":"const","constVal":0},"unit":{"type":"const","constVal":"°"}},"icon":{"true":{"value":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_id","read":"{\n switch (val) {\n case 1: // Sonnig\n return 'weather-sunny'; // sunny\n\n case 2: // Teils bewölkt\n case 3: // Bewölkt\n return 'weather-partly-cloudy'; // partlycloudy\n \n case 4: // Bedeckt\n return 'weather-cloudy'; // cloudy\n \n case 5: // Teils bewölkt mit leichtem Regen\n case 6: // Bewölkt mit leichtem Regen\n case 8: // Teils bewölkt mit mäßigem Regen\n case 9: // Bewölkt mit mäßigem Regen\n return 'weather-partly-rainy'; // partly-rainy\n \n case 7: // Bedeckt mit leichtem Regen\n return 'weather-rainy'; // rainy\n \n case 10: // Bedeckt mit mäßigem Regen\n return 'weather-pouring'; // pouring\n \n case 11: // Teils bewölkt mit starken Regenschauern\n case 12: // Bewölkt mit stürmischen Regenschauern\n return 'weather-partly-lightning'; // partlylightning\n \n case 13: // Bedeckt mit stürmischen Regenschauern\n return 'weather-lightning'; // lightning\n \n case 14: // Teils bewölkt mit stürmischen Regenschauern und Hagel\n case 15: // Bewölkt mit stürmischen Regenschauern und Hagel\n case 16: // Bedeckt mit stürmischen Regenschauern und Hagel\n return 'weather-hail'; // Hail\n\n case 17: // Teils bewölkt mit Schnee\n case 18: // Bewölkt mit Schnee\n return 'weather-partly-snowy'; // partlysnowy\n\n case 19: // Bedeckt mit Schneeschauern\n return 'weather-snowy'; // snowy\n\n case 20: // Teils bewölkt mit Schneeregen\n case 21: // Bewölkt mit Schneeregen\n return 'weather-partly-snowy-rainy';\n\n case 22: // Bedeckt mit Schneeregen\n return 'weather-snowy-rainy'; // snowy-rainy\n\n default:\n return 'alert-circle-outline';\n }\n }"},"color":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_id","read":"{\n switch (val) {\n case 1: // Sonnig\n return Color.swSunny;\n\n case 2: // Teils bewölkt\n case 3: // Bewölkt\n return Color.swPartlycloudy;\n\n case 4: // Bedeckt\n return Color.swCloudy;\n\n case 5: // Teils bewölkt mit leichtem Regen\n case 6: // Bewölkt mit leichtem Regen\n case 8: // Teils bewölkt mit mäßigem Regen\n case 9: // Bewölkt mit mäßigem Regen\n return Color.swRainy;\n\n case 7: // Bedeckt mit leichtem Regen\n return Color.swRainy;\n\n case 10: // Bedeckt mit mäßigem Regen\n return Color.swPouring;\n\n case 11: // Teils bewölkt mit starken Regenschauern\n case 12: // Bewölkt mit stürmischen Regenschauern\n return Color.swLightningRainy;\n\n case 13: // Bedeckt mit stürmischen Regenschauern\n return Color.swLightning;\n\n case 14: // Teils bewölkt mit stürmischen Regenschauern und Hagel\n case 15: // Bewölkt mit stürmischen Regenschauern und Hagel\n case 16: // Bedeckt mit stürmischen Regenschauern und Hagel\n return Color.swHail;\n\n case 17: // Teils bewölkt mit Schnee\n case 18: // Bewölkt mit Schnee\n return Color.swSnowy;\n\n case 19: // Bedeckt mit Schneeschauern\n return Color.swSnowy;\n\n case 20: // Teils bewölkt mit Schneeregen\n case 21: // Bewölkt mit Schneeregen\n return Color.swSnowyRainy; // snowy-rainy\n\n case 22: // Bedeckt mit Schneeregen\n return Color.swSnowyRainy;\n\n default:\n return Color.White;\n }\n }"}},"false":{}},"text":{"true":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Tag_value","read":"{\n return (val).substring(0,2);\n }"}}}}}}],"leftScreensaverEntity":[{"type":"script","ScreensaverEntity":"alias.0.NSPanel.Flur.Sensor.ANALOG.Temperature.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":1,"ScreensaverEntityIconOn":"thermometer","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Temperatur","ScreensaverEntityUnitText":"°C","ScreensaverEntityIconColor":{"val_min":0,"val_max":35,"val_best":22}},{"type":"script","ScreensaverEntity":"alias.0.Heizung.WärmeTagesVerbrauch.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":1,"ScreensaverEntityIconOn":"counter","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Wärme","ScreensaverEntityUnitText":" kWh","ScreensaverEntityIconColor":{"red":255,"green":235,"blue":156}},{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Abfall.event1.INFO","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityDateFormat":{"year":"numeric","month":"2-digit","day":"2-digit"},"ScreensaverEntityIconOn":"trash-can","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Abfall","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":"0_userdata.0.Abfallkalender.1.color"}],"mrIcon1ScreensaverEntity":{"type":"script","ScreensaverEntity":"Relay.1","ScreensaverEntityIconOn":"lightbulb","ScreensaverEntityIconOff":null,"ScreensaverEntityValue":null,"ScreensaverEntityValueDecimalPlace":0,"ScreensaverEntityValueUnit":null,"ScreensaverEntityOnColor":{"red":253,"green":216,"blue":53},"ScreensaverEntityOffColor":{"red":68,"green":115,"blue":158}},"mrIcon2ScreensaverEntity":{"type":"script","ScreensaverEntity":"Relay.2","ScreensaverEntityIconOn":"lightbulb","ScreensaverEntityIconOff":null,"ScreensaverEntityValue":null,"ScreensaverEntityValueDecimalPlace":0,"ScreensaverEntityValueUnit":null,"ScreensaverEntityOnColor":{"red":253,"green":216,"blue":53},"ScreensaverEntityOffColor":{"red":68,"green":115,"blue":158}},"buttonLeft":{"mode":"page","page":"main"},"buttonRight":null,"version":"0.9.1"},"from":"system.adapter.javascript.0","callback":{"message":{"panelTopic":"topic","weatherEntity":"openweathermap.0.","defaultOffColor":{"red":253,"green":128,"blue":0},"defaultOnColor":{"red":253,"green":216,"blue":53},"defaultBackgroundColor":{"red":29,"green":29,"blue":29},"weatherAddDefaultItems":false,"pages":[{"type":"cardGrid","uniqueName":"main","heading":"Die Leere","items":[]}],"subPages":[],"favoritScreensaverEntity":[{"type":"template","template":"text.openweathermap.favorit","dpInit":"/^openweathermap\\.0.+/","modeScr":"favorit"}],"alternateScreensaverEntity":[],"indicatorScreensaverEntity":[{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Status_offene_Fenster.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"window-open-variant","ScreensaverEntityIconOff":"window-closed-variant","ScreensaverEntityText":"Fenster","ScreensaverEntityUnitText":"%","ScreensaverEntityIconColor":{"val_min":0,"val_max":1}},{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Status_offene_Tuer.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"door-open","ScreensaverEntityIconOff":"door-closed","ScreensaverEntityText":"Tür","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":{"val_min":0,"val_max":1}},{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Status_Licht_An.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"lightbulb","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Licht","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":{"val_min":0,"val_max":1}},{"type":"script","ScreensaverEntity":"alias.0.Türschloss.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"lock","ScreensaverEntityIconOff":"lock-open","ScreensaverEntityText":"Türschloss","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":{"val_min":0,"val_max":1,"val_best":1}},{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Auto.Safety.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"car-key","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Auto","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":{"val_min":0,"val_max":1,"val_best":1}}],"bottomScreensaverEntity":[{"type":"template","template":"text.openweathermap.sunriseset","dpInit":"/^openweathermap\\.0\\.forecast\\.current.+/","modeScr":"bottom"},{"type":"script","ScreensaverEntity":"openweathermap.0.forecast.current.windSpeed","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":1,"ScreensaverEntityIconOn":"weather-windy","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Wind","ScreensaverEntityUnitText":"m/s","ScreensaverEntityIconColor":{"val_min":0,"val_max":120}},{"type":"script","ScreensaverEntity":"openweathermap.0.forecast.current.windGust","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":1,"ScreensaverEntityIconOn":"weather-tornado","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Böen","ScreensaverEntityUnitText":"m/s","ScreensaverEntityIconColor":{"val_min":0,"val_max":120}},{"type":"template","template":"text.openweathermap.winddirection","dpInit":"/^openweathermap\\.0./","modeScr":"bottom"},{"type":"script","ScreensaverEntity":"openweathermap.0.forecast.current.humidity","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityIconOn":"water-percent","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Feuchte","ScreensaverEntityUnitText":"%","ScreensaverEntityIconColor":{"val_min":0,"val_max":100,"val_best":60}},{"type":"native","native":{"type":"native","native":{"role":"2values","dpInit":"","type":"text","modeScr":"bottom","data":{"entity1":{"value":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Minimale_Temperatur_value"},"decimal":{"type":"const","constVal":0},"unit":{"type":"const","constVal":"° "}},"entity2":{"value":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Maximale_Temperatur_value"},"decimal":{"type":"const","constVal":0},"unit":{"type":"const","constVal":"°"}},"icon":{"true":{"value":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_id","read":"{\n switch (val) {\n case 1: // Sonnig\n return 'weather-sunny'; // sunny\n\n case 2: // Teils bewölkt\n case 3: // Bewölkt\n return 'weather-partly-cloudy'; // partlycloudy\n \n case 4: // Bedeckt\n return 'weather-cloudy'; // cloudy\n \n case 5: // Teils bewölkt mit leichtem Regen\n case 6: // Bewölkt mit leichtem Regen\n case 8: // Teils bewölkt mit mäßigem Regen\n case 9: // Bewölkt mit mäßigem Regen\n return 'weather-partly-rainy'; // partly-rainy\n \n case 7: // Bedeckt mit leichtem Regen\n return 'weather-rainy'; // rainy\n \n case 10: // Bedeckt mit mäßigem Regen\n return 'weather-pouring'; // pouring\n \n case 11: // Teils bewölkt mit starken Regenschauern\n case 12: // Bewölkt mit stürmischen Regenschauern\n return 'weather-partly-lightning'; // partlylightning\n \n case 13: // Bedeckt mit stürmischen Regenschauern\n return 'weather-lightning'; // lightning\n \n case 14: // Teils bewölkt mit stürmischen Regenschauern und Hagel\n case 15: // Bewölkt mit stürmischen Regenschauern und Hagel\n case 16: // Bedeckt mit stürmischen Regenschauern und Hagel\n return 'weather-hail'; // Hail\n\n case 17: // Teils bewölkt mit Schnee\n case 18: // Bewölkt mit Schnee\n return 'weather-partly-snowy'; // partlysnowy\n\n case 19: // Bedeckt mit Schneeschauern\n return 'weather-snowy'; // snowy\n\n case 20: // Teils bewölkt mit Schneeregen\n case 21: // Bewölkt mit Schneeregen\n return 'weather-partly-snowy-rainy';\n\n case 22: // Bedeckt mit Schneeregen\n return 'weather-snowy-rainy'; // snowy-rainy\n\n default:\n return 'alert-circle-outline';\n }\n }"},"color":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_id","read":"{\n switch (val) {\n case 1: // Sonnig\n return Color.swSunny;\n\n case 2: // Teils bewölkt\n case 3: // Bewölkt\n return Color.swPartlycloudy;\n\n case 4: // Bedeckt\n return Color.swCloudy;\n\n case 5: // Teils bewölkt mit leichtem Regen\n case 6: // Bewölkt mit leichtem Regen\n case 8: // Teils bewölkt mit mäßigem Regen\n case 9: // Bewölkt mit mäßigem Regen\n return Color.swRainy;\n\n case 7: // Bedeckt mit leichtem Regen\n return Color.swRainy;\n\n case 10: // Bedeckt mit mäßigem Regen\n return Color.swPouring;\n\n case 11: // Teils bewölkt mit starken Regenschauern\n case 12: // Bewölkt mit stürmischen Regenschauern\n return Color.swLightningRainy;\n\n case 13: // Bedeckt mit stürmischen Regenschauern\n return Color.swLightning;\n\n case 14: // Teils bewölkt mit stürmischen Regenschauern und Hagel\n case 15: // Bewölkt mit stürmischen Regenschauern und Hagel\n case 16: // Bedeckt mit stürmischen Regenschauern und Hagel\n return Color.swHail;\n\n case 17: // Teils bewölkt mit Schnee\n case 18: // Bewölkt mit Schnee\n return Color.swSnowy;\n\n case 19: // Bedeckt mit Schneeschauern\n return Color.swSnowy;\n\n case 20: // Teils bewölkt mit Schneeregen\n case 21: // Bewölkt mit Schneeregen\n return Color.swSnowyRainy; // snowy-rainy\n\n case 22: // Bedeckt mit Schneeregen\n return Color.swSnowyRainy;\n\n default:\n return Color.White;\n }\n }"}},"false":{}},"text":{"true":{"type":"triggered","dp":"daswetter.0.NextDays.Location_1.Day_6.Tag_value","read":"{\n return (val).substring(0,2);\n }"}}}}}}],"leftScreensaverEntity":[{"type":"script","ScreensaverEntity":"alias.0.NSPanel.Flur.Sensor.ANALOG.Temperature.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":1,"ScreensaverEntityIconOn":"thermometer","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Temperatur","ScreensaverEntityUnitText":"°C","ScreensaverEntityIconColor":{"val_min":0,"val_max":35,"val_best":22}},{"type":"script","ScreensaverEntity":"alias.0.Heizung.WärmeTagesVerbrauch.ACTUAL","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":1,"ScreensaverEntityIconOn":"counter","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Wärme","ScreensaverEntityUnitText":" kWh","ScreensaverEntityIconColor":{"red":255,"green":235,"blue":156}},{"type":"script","ScreensaverEntity":"alias.0.NSPanel.allgemein.Abfall.event1.INFO","ScreensaverEntityFactor":1,"ScreensaverEntityDecimalPlaces":0,"ScreensaverEntityDateFormat":{"year":"numeric","month":"2-digit","day":"2-digit"},"ScreensaverEntityIconOn":"trash-can","ScreensaverEntityIconOff":null,"ScreensaverEntityText":"Abfall","ScreensaverEntityUnitText":"","ScreensaverEntityIconColor":"0_userdata.0.Abfallkalender.1.color"}],"mrIcon1ScreensaverEntity":{"type":"script","ScreensaverEntity":"Relay.1","ScreensaverEntityIconOn":"lightbulb","ScreensaverEntityIconOff":null,"ScreensaverEntityValue":null,"ScreensaverEntityValueDecimalPlace":0,"ScreensaverEntityValueUnit":null,"ScreensaverEntityOnColor":{"red":253,"green":216,"blue":53},"ScreensaverEntityOffColor":{"red":68,"green":115,"blue":158}},"mrIcon2ScreensaverEntity":{"type":"script","ScreensaverEntity":"Relay.2","ScreensaverEntityIconOn":"lightbulb","ScreensaverEntityIconOff":null,"ScreensaverEntityValue":null,"ScreensaverEntityValueDecimalPlace":0,"ScreensaverEntityValueUnit":null,"ScreensaverEntityOnColor":{"red":253,"green":216,"blue":53},"ScreensaverEntityOffColor":{"red":68,"green":115,"blue":158}},"buttonLeft":{"mode":"page","page":"main"},"buttonRight":null,"version":"0.9.1"},"id":15,"ack":false,"time":1755259569487},"_id":94552161}
                                          @hm_krause
                                          Das hier gibt jetzt ein ziemlich großes log 🙂
                                          gehe auf die Adminkonfiguration für den Adapter - schalte den expert mode anBildschirmfoto 2025-08-15 um 14.11.25.png das grüne da
                                          Dann gehe auf den Tab developer und aktiviere debugLogMqtt.
                                          Dann anschließend das log bitte über log herunterladen anzeigen lassen und von dort hier in code tags posten - die sind dann schöner formatiert - bei der menge ist das nötig.
                                          Danke.
                                          • teletapi
                                            teletapi @ticaki last edited by teletapi
                                            @ticaki
                                            Morjen, ich hab da mal wieder ein kleines Problem ich hab heute mal das neue NSPanel US ausgepackt und fertig gemacht zunächst war für mich das größte problem überhaupt mal eine TFT drauf zu flashen entweder kam der Balken zum flashen und machte nix oder No Match. Bis ich irgendwann die Berry treiber 9 händisch und die Firmware für 9.9.4 US_L geflasht habe
                                            ( FlashNextionAdv0 http://nspanel.de/nspanel-us-l-v4.9.5.tft geändert auf 4.9.4) (die 4.95 lies sich nur bis 99% flashen)
                                            mit dem script vom ersten EU Model (Meine daten eingefügt in das script was man per Button laden kann).
                                            Jetzt läuft das US Teil,
                                            aber zum einen wird mir im Adapter jetzt angezeigt das das erste EU modell ein Update der TFT braucht auf die 4.9.4, auf dem EU Model ist aber bereits die 4.9.4 drauf .
                                            Auf dem US Model wird mir die 4.9.3 im System angezeigt im Adapter jdeoch wird die 4.9.3 angezeigt aber kein Update zur 4.9.4 und im Panel System wird mir ein EU Model angezeigt und kein US. Und das obwohl ich ja die 4.9.4 als US_l geflasht habe. (http://nspanel.de/nspanel-us-l-v4.9.4.tft)
                                            Armilar T 2 Replies Last reply Reply Quote 0
                                            546
                                            72804
