    4. Betatest NSPanel-lovelace-ui v0.6.x
      hm_krause @ticaki last edited by
      @ticaki
      Hier schon mal was neues: panel online
      Aber noch immer .
      waitung for content...
        ticaki @hm_krause last edited by
        @hm_krause
        Bitte nochmal ein aktuelles log mit dem mqtt debug
          @ticaki
          Fehler
          Payload Too Large
            ticaki @hm_krause last edited by ticaki
            @hm_krause
            hier im Forum?
            kopiere es in eine .txt datei und zieh die ins Antwort feld
              @ticaki
              hier:
              log.txt
                @hm_krause
                Da ist kein Berry Treiber installiert - oder die datei ist leer - kannst du das von hand machen - nimm den teil hier aus der nspanel-script wiki - https://github.com/joBr99/nspanel-lovelace-ui/wiki/iobroker---Basisinstallation#3-berry-treiber-installieren
                  @ticaki
                  erledigt,
                  script:
                  javascript.0	15:12:57.711	info
                  Compiling TypeScript source script.js.nspanel-lovelace-ui_0.Panel_1
                  javascript.0	15:12:57.784	info
                  source code did not change, using cached compilation result...
                  javascript.0	15:12:57.789	info
                  registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  javascript.0	15:12:57.804	info
                    'Abort: Topic: topic not found in Adapter configuration! Maybe wrong topic?!'
                  javascript.0	15:12:58.038	info
                  Stopping script script.js.nspanel-lovelace-ui_0.Panel_1
                  Adapter
                  2025-08-15 15:13:50.259 - info: host.Iobroker stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=true)
                  2025-08-15 15:13:50.262 - info: nspanel-lovelace-ui.0 (48612) Got terminate signal TERMINATE_YOURSELF
                  2025-08-15 15:13:50.416 - info: host.Iobroker stopInstance system.adapter.nspanel-lovelace-ui.0 send kill signal
                  2025-08-15 15:13:50.414 - debug: nspanel-lovelace-ui.0 (48612) [main] Switch page to invisible!
                  2025-08-15 15:13:50.428 - info: nspanel-lovelace-ui.0 (48612) [mqttClient] Connection is closed.
                  2025-08-15 15:13:50.430 - info: nspanel-lovelace-ui.0 (48612) terminating
                  2025-08-15 15:13:50.431 - info: nspanel-lovelace-ui.0 (48612) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-08-15 15:13:50.763 - info: nspanel-lovelace-ui.0 (48612) terminating
                  2025-08-15 15:13:51.026 - info: host.Iobroker instance system.adapter.nspanel-lovelace-ui.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-08-15 15:13:54.484 - info: host.Iobroker instance system.adapter.nspanel-lovelace-ui.0 in version "0.2.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#67197b8eec1476f6f5b81ea7b88bc9c728365c86) started with pid 48647
                  2025-08-15 15:13:55.408 - debug: nspanel-lovelace-ui.0 (48647) Redis Objects: Use Redis connection: 0.0.0.0:9001
                  2025-08-15 15:13:55.458 - debug: nspanel-lovelace-ui.0 (48647) Objects client ready ... initialize now
                  2025-08-15 15:13:55.459 - debug: nspanel-lovelace-ui.0 (48647) Objects create System PubSub Client
                  2025-08-15 15:13:55.460 - debug: nspanel-lovelace-ui.0 (48647) Objects create User PubSub Client
                  2025-08-15 15:13:55.572 - debug: nspanel-lovelace-ui.0 (48647) Objects client initialize lua scripts
                  2025-08-15 15:13:55.577 - debug: nspanel-lovelace-ui.0 (48647) Objects connected to redis: 0.0.0.0:9001
                  2025-08-15 15:13:55.636 - debug: nspanel-lovelace-ui.0 (48647) Redis States: Use Redis connection: 0.0.0.0:9000
                  2025-08-15 15:13:55.717 - debug: nspanel-lovelace-ui.0 (48647) States create System PubSub Client
                  2025-08-15 15:13:55.718 - debug: nspanel-lovelace-ui.0 (48647) States create User PubSub Client
                  2025-08-15 15:13:55.832 - debug: nspanel-lovelace-ui.0 (48647) States connected to redis: 0.0.0.0:9000
                  2025-08-15 15:13:55.998 - info: nspanel-lovelace-ui.0 (48647) starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#67197b8eec1476f6f5b81ea7b88bc9c728365c86) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
                  2025-08-15 15:13:56.050 - info: nspanel-lovelace-ui.0 (48647) Configured panels: name#topic -> [Panel_1#nspanel_1]
                  2025-08-15 15:13:56.050 - info: nspanel-lovelace-ui.0 (48647) Found 2 script configs for topics: nspanel_1, topic
                  2025-08-15 15:13:56.053 - info: nspanel-lovelace-ui.0 (48647) [config-manager] Start converting configuration for nspanel_1
                  2025-08-15 15:13:56.200 - warn: nspanel-lovelace-ui.0 (48647) Invalid color value: "0_userdata.0.Abfallkalender.1.color"
                  2025-08-15 15:13:56.203 - debug: nspanel-lovelace-ui.0 (48647) [config-manager] Screensaver pageItems count: 17
                  2025-08-15 15:13:56.207 - info: nspanel-lovelace-ui.0 (48647) Raw script config found for nspanel_1
                  2025-08-15 15:13:56.207 - debug: nspanel-lovelace-ui.0 (48647) [library] Load language de
                  2025-08-15 15:13:56.297 - info: nspanel-lovelace-ui.0 (48647) Force an MQTT reconnect from the Nspanel with the ip 192.168.178.56 in 10 seconds!
                  2025-08-15 15:13:58.332 - debug: nspanel-lovelace-ui.0 (48647) Check configuration!
                  2025-08-15 15:13:58.384 - info: nspanel-lovelace-ui.0 (48647) [mqttClient] Connection is active.
                  2025-08-15 15:13:58.386 - debug: nspanel-lovelace-ui.0 (48647) 42896.4921875k
                  2025-08-15 15:13:58.388 - debug: nspanel-lovelace-ui.0 (48647) [controller] controller created
                  2025-08-15 15:13:58.438 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] subscripe to: nspanel_1/stat/RESULT
                  2025-08-15 15:13:58.502 - debug: nspanel-lovelace-ui.0 (48647) [controller] Set current Date with time: Fri Aug 15 2025 15:13:58 GMT+0200 (Central European Summer Time)
                  2025-08-15 15:13:58.543 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Panel E4_65_B8_48_80_70 is initialised!
                  2025-08-15 15:13:58.544 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] subscripe to: nspanel_1/tele/#
                  2025-08-15 15:13:58.545 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] subscripe to: nspanel_1/stat/#
                  2025-08-15 15:13:58.552 - debug: nspanel-lovelace-ui.0 (48647) [system-notifications] Request notifications from "system.host.Iobroker"
                  2025-08-15 15:13:58.556 - debug: nspanel-lovelace-ui.0 (48647) [system-notifications] Received notifications from "system.host.Iobroker": {}
                  2025-08-15 15:13:58.556 - debug: nspanel-lovelace-ui.0 (48647) [system-notifications] Request notifications from "system.host.iob-huawei"
                  2025-08-15 15:13:58.567 - debug: nspanel-lovelace-ui.0 (48647) [system-notifications] Received notifications from "system.host.iob-huawei": {"system":{"categories":{},"description":{"en":"These notifications are collected by the ioBroker system and point to issues you should check and fix.","de":"Diese Benachrichtigungen werden vom ioBroker-System erfasst und weisen auf Probleme hin, die überprüft und behoben werden sollten.","ru":"Эти уведомления собираются системой ioBroker и указывают на проблемы, которые вы должны проверить и исправить.","pt":"Essas notificações são coletadas pelo sistema ioBroker e apontam para problemas que você deve verificar e corrigir.","nl":"Deze meldingen worden verzameld door het ioBroker-systeem en wijzen op problemen die u moet controleren en oplossen.","fr":"Ces notifications sont collectées par le système ioBroker et indiquent des problèmes que vous devez vérifier et résoudre.","it":"Queste notifiche vengono raccolte dal sistema ioBroker e indicano problemi che dovresti controllare e correggere.","es":"Estas notificaciones son recopiladas por el sistema ioBroker y señalan problemas que debe verificar y solucionar.","pl":"Te powiadomienia są zbierane przez system ioBroker i wskazują problemy, które należy sprawdzić i naprawić.","uk":"Ці сповіщення збираються системою ioBroker і вказують на проблеми, які ви повинні перевірити та виправити.","zh-cn":"这些通知由ioBroker系统收集,并指出您应检查并修复的问题"},"name":{"en":"System Notifications","de":"System-Benachrichtigungen","ru":"Системные уведомления","pt":"Notificações do sistema","nl":"Systeemmeldingen","fr":"Notifications système","it":"Notifiche di sistema","es":"Notificaciones del sistema","pl":"Powiadomienia systemowe","uk":"Системні сповіщення","zh-cn":"系统通知"}}}
                  2025-08-15 15:13:58.645 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 2 subproceses. topic: nspanel_1/stat/RESULT message: {"POWER1":"OFF"}
                  2025-08-15 15:13:58.646 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] Receive command nspanel_1/stat/RESULT with {"POWER1":"OFF"}
                  2025-08-15 15:13:58.647 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/RESULT with {"POWER1":"OFF"}
                  2025-08-15 15:13:58.746 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 2 subproceses. topic: nspanel_1/stat/RESULT message: {"POWER1":"OFF"}
                  2025-08-15 15:13:58.747 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] Receive command nspanel_1/stat/RESULT with {"POWER1":"OFF"}
                  2025-08-15 15:13:58.747 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/LWT message: Offline
                  2025-08-15 15:13:58.748 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO1 message: {"Info1":{"Module":"Panel_1","Version":"15.0.1(release-nspanel)","FallbackTopic":"cmnd/Panel_1-488070_fb/","GroupTopic":"nspanel_1/cmnd/"}}
                  2025-08-15 15:13:58.748 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO2 message: {"Info2":{"WebServerMode":"Admin","Hostname":"Panel-1","IPAddress":"192.168.178.56","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1"}}
                  2025-08-15 15:13:58.749 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/INFO2 with {"Info2":{"WebServerMode":"Admin","Hostname":"Panel-1","IPAddress":"192.168.178.56","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1"}}
                  2025-08-15 15:13:58.749 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO3 message: {"Info3":{"RestartReason":"Software reset CPU","BootCount":99}}
                  2025-08-15 15:13:58.749 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/INFO3 with {"Info3":{"RestartReason":"Software reset CPU","BootCount":99}}
                  2025-08-15 15:13:58.750 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/POWER1 message: OFF
                  2025-08-15 15:13:58.750 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/POWER2 message: OFF
                  2025-08-15 15:13:58.751 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/RESULT message: {"nlui_driver_version":"9"}
                  2025-08-15 15:13:58.751 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/STATE message: {"Time":"2025-08-15T15:12:57","Uptime":"0T00:00:10","UptimeSec":10,"Heap":168,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":503,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  2025-08-15 15:13:58.752 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/STATE with {"Time":"2025-08-15T15:12:57","Uptime":"0T00:00:10","UptimeSec":10,"Heap":168,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":503,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  2025-08-15 15:13:58.752 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/SENSOR message: {"Time":"2025-08-15T15:12:57","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
                  2025-08-15 15:13:58.752 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/SENSOR with {"Time":"2025-08-15T15:12:57","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
                  2025-08-15 15:13:58.752 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS0 message: {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["Panel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:01:08","StartupUTC":"2025-08-15T13:12:47","Sleep":0,"CfgHolder":4617,"BootCount":99,"BCResetTime":"2025-08-11T14:17:51","SaveCount":180},"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"442/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":165,"StackLowMark":3,"PsrMax":2048,"PsrFree":2018,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"Panel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0},"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"Panel_1-488070","MqttClient":"Panel_1-488070","MqttUser":"iobroker","MqttCount":2,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2025-08-15T13:13:55Z","Local":"2025-08-15T15:13:55","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:43","Sunset":"21:05"},"StatusSNS":{"Time":"2025-08-15T15:13:55","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"},"StatusSTS":{"Time":"2025-08-15T15:13:55","Uptime":"0T00:01:08","UptimeSec":68,"Heap":165,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":597,"MqttCount":2,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:13:58.753 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS5 message: {"StatusNET":{"Hostname":"NSPanel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0}}
                  2025-08-15 15:13:58.754 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS5 with {"StatusNET":{"Hostname":"NSPanel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0}}
                  2025-08-15 15:13:58.754 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS message: {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["NSPanel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
                  2025-08-15 15:13:58.754 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS with {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["NSPanel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
                  2025-08-15 15:13:58.754 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS1 message: {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:03:09","StartupUTC":"2025-08-14T16:01:05","Sleep":0,"CfgHolder":4617,"BootCount":50,"BCResetTime":"2025-08-11T14:17:51","SaveCount":127}}
                  2025-08-15 15:13:58.755 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS1 with {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:03:09","StartupUTC":"2025-08-14T16:01:05","Sleep":0,"CfgHolder":4617,"BootCount":50,"BCResetTime":"2025-08-11T14:17:51","SaveCount":127}}
                  2025-08-15 15:13:58.755 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS2 message: {"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"450/699"}}
                  2025-08-15 15:13:58.755 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS2 with {"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"450/699"}}
                  2025-08-15 15:13:58.755 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS3 message: {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]}}
                  2025-08-15 15:13:58.755 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS3 with {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]}}
                  2025-08-15 15:13:58.756 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS4 message: {"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":164,"StackLowMark":3,"PsrMax":2048,"PsrFree":2013,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"}}
                  2025-08-15 15:13:58.756 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS4 with {"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":164,"StackLowMark":3,"PsrMax":2048,"PsrFree":2013,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"}}
                  2025-08-15 15:13:58.756 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS6 message: {"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"NSPanel_1-488070","MqttClient":"NSPanel_1-488070","MqttUser":"iobroker","MqttCount":1,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
                  2025-08-15 15:13:58.756 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS6 with {"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"NSPanel_1-488070","MqttClient":"NSPanel_1-488070","MqttUser":"iobroker","MqttCount":1,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
                  2025-08-15 15:13:58.756 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS7 message: {"StatusTIM":{"UTC":"2025-08-14T16:04:15Z","Local":"2025-08-14T18:04:15","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:42","Sunset":"21:07"}}
                  2025-08-15 15:13:58.757 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS7 with {"StatusTIM":{"UTC":"2025-08-14T16:04:15Z","Local":"2025-08-14T18:04:15","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:42","Sunset":"21:07"}}
                  2025-08-15 15:13:58.757 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS10 message: {"StatusSNS":{"Time":"2025-08-14T18:04:15","ANALOG":{"Temperature1":3.5},"ESP32":{"Temperature":53.3},"TempUnit":"C"}}
                  2025-08-15 15:13:58.757 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS10 with {"StatusSNS":{"Time":"2025-08-14T18:04:15","ANALOG":{"Temperature1":3.5},"ESP32":{"Temperature":53.3},"TempUnit":"C"}}
                  2025-08-15 15:13:58.757 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS11 message: {"StatusSTS":{"Time":"2025-08-14T18:04:15","Uptime":"0T00:03:10","UptimeSec":190,"Heap":161,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":692,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:13:58.757 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS11 with {"StatusSTS":{"Time":"2025-08-14T18:04:15","Uptime":"0T00:03:10","UptimeSec":190,"Heap":161,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":692,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:13:58.758 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/RESULT with {"POWER1":"OFF"}
                  2025-08-15 15:13:58.768 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 2 subproceses. topic: nspanel_1/stat/RESULT message: {"POWER1":"OFF"}
                  2025-08-15 15:13:58.768 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] Receive command nspanel_1/stat/RESULT with {"POWER1":"OFF"}
                  2025-08-15 15:13:58.768 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/LWT message: Offline
                  2025-08-15 15:13:58.769 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO1 message: {"Info1":{"Module":"Panel_1","Version":"15.0.1(release-nspanel)","FallbackTopic":"cmnd/Panel_1-488070_fb/","GroupTopic":"nspanel_1/cmnd/"}}
                  2025-08-15 15:13:58.769 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO2 message: {"Info2":{"WebServerMode":"Admin","Hostname":"Panel-1","IPAddress":"192.168.178.56","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1"}}
                  2025-08-15 15:13:58.769 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/INFO2 with {"Info2":{"WebServerMode":"Admin","Hostname":"Panel-1","IPAddress":"192.168.178.56","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1"}}
                  2025-08-15 15:13:58.770 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO3 message: {"Info3":{"RestartReason":"Software reset CPU","BootCount":99}}
                  2025-08-15 15:13:58.770 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/INFO3 with {"Info3":{"RestartReason":"Software reset CPU","BootCount":99}}
                  2025-08-15 15:13:58.770 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/POWER1 message: OFF
                  2025-08-15 15:13:58.771 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/POWER2 message: OFF
                  2025-08-15 15:13:58.771 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/RESULT message: {"nlui_driver_version":"9"}
                  2025-08-15 15:13:58.771 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/STATE message: {"Time":"2025-08-15T15:12:57","Uptime":"0T00:00:10","UptimeSec":10,"Heap":168,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":503,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  2025-08-15 15:13:58.771 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/STATE with {"Time":"2025-08-15T15:12:57","Uptime":"0T00:00:10","UptimeSec":10,"Heap":168,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":503,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  2025-08-15 15:13:58.772 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/SENSOR message: {"Time":"2025-08-15T15:12:57","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
                  2025-08-15 15:13:58.772 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/SENSOR with {"Time":"2025-08-15T15:12:57","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
                  2025-08-15 15:13:58.772 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS0 message: {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["Panel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:01:08","StartupUTC":"2025-08-15T13:12:47","Sleep":0,"CfgHolder":4617,"BootCount":99,"BCResetTime":"2025-08-11T14:17:51","SaveCount":180},"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"442/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":165,"StackLowMark":3,"PsrMax":2048,"PsrFree":2018,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"Panel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0},"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"Panel_1-488070","MqttClient":"Panel_1-488070","MqttUser":"iobroker","MqttCount":2,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2025-08-15T13:13:55Z","Local":"2025-08-15T15:13:55","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:43","Sunset":"21:05"},"StatusSNS":{"Time":"2025-08-15T15:13:55","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"},"StatusSTS":{"Time":"2025-08-15T15:13:55","Uptime":"0T00:01:08","UptimeSec":68,"Heap":165,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":597,"MqttCount":2,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:13:58.772 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS5 message: {"StatusNET":{"Hostname":"NSPanel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0}}
                  2025-08-15 15:13:58.773 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS5 with {"StatusNET":{"Hostname":"NSPanel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0}}
                  2025-08-15 15:13:58.774 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS message: {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["NSPanel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
                  2025-08-15 15:13:58.774 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS with {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["NSPanel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
                  2025-08-15 15:13:58.775 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS1 message: {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:03:09","StartupUTC":"2025-08-14T16:01:05","Sleep":0,"CfgHolder":4617,"BootCount":50,"BCResetTime":"2025-08-11T14:17:51","SaveCount":127}}
                  2025-08-15 15:13:58.775 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS1 with {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:03:09","StartupUTC":"2025-08-14T16:01:05","Sleep":0,"CfgHolder":4617,"BootCount":50,"BCResetTime":"2025-08-11T14:17:51","SaveCount":127}}
                  2025-08-15 15:13:58.775 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS2 message: {"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"450/699"}}
                  2025-08-15 15:13:58.775 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS2 with {"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"450/699"}}
                  2025-08-15 15:13:58.775 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS3 message: {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]}}
                  2025-08-15 15:13:58.775 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS3 with {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]}}
                  2025-08-15 15:13:58.776 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS4 message: {"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":164,"StackLowMark":3,"PsrMax":2048,"PsrFree":2013,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"}}
                  2025-08-15 15:13:58.776 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS4 with {"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":164,"StackLowMark":3,"PsrMax":2048,"PsrFree":2013,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"}}
                  2025-08-15 15:13:58.776 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS6 message: {"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"NSPanel_1-488070","MqttClient":"NSPanel_1-488070","MqttUser":"iobroker","MqttCount":1,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
                  2025-08-15 15:13:58.777 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS6 with {"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"NSPanel_1-488070","MqttClient":"NSPanel_1-488070","MqttUser":"iobroker","MqttCount":1,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
                  2025-08-15 15:13:58.777 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS7 message: {"StatusTIM":{"UTC":"2025-08-14T16:04:15Z","Local":"2025-08-14T18:04:15","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:42","Sunset":"21:07"}}
                  2025-08-15 15:13:58.777 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS7 with {"StatusTIM":{"UTC":"2025-08-14T16:04:15Z","Local":"2025-08-14T18:04:15","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:42","Sunset":"21:07"}}
                  2025-08-15 15:13:58.777 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS10 message: {"StatusSNS":{"Time":"2025-08-14T18:04:15","ANALOG":{"Temperature1":3.5},"ESP32":{"Temperature":53.3},"TempUnit":"C"}}
                  2025-08-15 15:13:58.777 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS10 with {"StatusSNS":{"Time":"2025-08-14T18:04:15","ANALOG":{"Temperature1":3.5},"ESP32":{"Temperature":53.3},"TempUnit":"C"}}
                  2025-08-15 15:13:58.778 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS11 message: {"StatusSTS":{"Time":"2025-08-14T18:04:15","Uptime":"0T00:03:10","UptimeSec":190,"Heap":161,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":692,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:13:58.778 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS11 with {"StatusSTS":{"Time":"2025-08-14T18:04:15","Uptime":"0T00:03:10","UptimeSec":190,"Heap":161,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":692,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:13:58.780 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/RESULT with {"POWER1":"OFF"}
                  2025-08-15 15:13:58.870 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] send payload: {"topic":"nspanel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel.
                  2025-08-15 15:13:58.870 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Publish topic: nspanel_1/cmnd/CustomSend with message: pageType~pageStartup.
                  2025-08-15 15:13:58.936 - info: nspanel-lovelace-ui.0 (48647) [Panel_1] Automatic update of the berry driver version from 9 to 10 on tasmota with IP 192.168.178.56 and Panel-1.
                  2025-08-15 15:13:58.941 - info: nspanel-lovelace-ui.0 (48647) [Panel_1] Automatic update of the berry driver version from 9 to 10 on tasmota with IP 192.168.178.56 and Panel-1.
                  2025-08-15 15:14:00.659 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 2 subproceses. topic: nspanel_1/stat/RESULT message: {"POWER1":"OFF"}
                  2025-08-15 15:14:00.660 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] Receive command nspanel_1/stat/RESULT with {"POWER1":"OFF"}
                  2025-08-15 15:14:00.661 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/RESULT with {"POWER1":"OFF"}
                  2025-08-15 15:14:00.681 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/LWT message: Offline
                  2025-08-15 15:14:00.701 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO1 message: {"Info1":{"Module":"Panel_1","Version":"15.0.1(release-nspanel)","FallbackTopic":"cmnd/Panel_1-488070_fb/","GroupTopic":"nspanel_1/cmnd/"}}
                  2025-08-15 15:14:00.711 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO2 message: {"Info2":{"WebServerMode":"Admin","Hostname":"Panel-1","IPAddress":"192.168.178.56","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1"}}
                  2025-08-15 15:14:00.712 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/INFO2 with {"Info2":{"WebServerMode":"Admin","Hostname":"Panel-1","IPAddress":"192.168.178.56","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1"}}
                  2025-08-15 15:14:00.721 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/INFO3 message: {"Info3":{"RestartReason":"Software reset CPU","BootCount":99}}
                  2025-08-15 15:14:00.721 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/INFO3 with {"Info3":{"RestartReason":"Software reset CPU","BootCount":99}}
                  2025-08-15 15:14:00.731 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/POWER1 message: OFF
                  2025-08-15 15:14:00.746 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/POWER2 message: OFF
                  2025-08-15 15:14:00.762 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/RESULT message: {"nlui_driver_version":"9"}
                  2025-08-15 15:14:00.772 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/STATE message: {"Time":"2025-08-15T15:12:57","Uptime":"0T00:00:10","UptimeSec":10,"Heap":168,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":503,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  2025-08-15 15:14:00.773 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/STATE with {"Time":"2025-08-15T15:12:57","Uptime":"0T00:00:10","UptimeSec":10,"Heap":168,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":503,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  2025-08-15 15:14:00.782 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/tele/SENSOR message: {"Time":"2025-08-15T15:12:57","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
                  2025-08-15 15:14:00.782 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/tele/SENSOR with {"Time":"2025-08-15T15:12:57","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
                  2025-08-15 15:14:00.795 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS0 message: {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["Panel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:01:08","StartupUTC":"2025-08-15T13:12:47","Sleep":0,"CfgHolder":4617,"BootCount":99,"BCResetTime":"2025-08-11T14:17:51","SaveCount":180},"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"442/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":165,"StackLowMark":3,"PsrMax":2048,"PsrFree":2018,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"Panel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0},"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"Panel_1-488070","MqttClient":"Panel_1-488070","MqttUser":"iobroker","MqttCount":2,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2025-08-15T13:13:55Z","Local":"2025-08-15T15:13:55","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:43","Sunset":"21:05"},"StatusSNS":{"Time":"2025-08-15T15:13:55","ANALOG":{"Temperature1":5.3},"ESP32":{"Temperature":53.9},"TempUnit":"C"},"StatusSTS":{"Time":"2025-08-15T15:13:55","Uptime":"0T00:01:08","UptimeSec":68,"Heap":165,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":597,"MqttCount":2,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:14:00.803 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS5 message: {"StatusNET":{"Hostname":"NSPanel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0}}
                  2025-08-15 15:14:00.803 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS5 with {"StatusNET":{"Hostname":"NSPanel-1","IPAddress":"192.168.178.56","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"E4:65:B8:48:80:70","IP6Global":"","IP6Local":"fe80::e665:b8ff:fe48:8070%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.2","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0}}
                  2025-08-15 15:14:00.811 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS message: {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["NSPanel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
                  2025-08-15 15:14:00.812 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS with {"Status":{"Module":0,"DeviceName":"NSPanel_1","FriendlyName":["NSPanel_1",""],"Topic":"nspanel_1","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
                  2025-08-15 15:14:00.822 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS1 message: {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:03:09","StartupUTC":"2025-08-14T16:01:05","Sleep":0,"CfgHolder":4617,"BootCount":50,"BCResetTime":"2025-08-11T14:17:51","SaveCount":127}}
                  2025-08-15 15:14:00.822 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS1 with {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:03:09","StartupUTC":"2025-08-14T16:01:05","Sleep":0,"CfgHolder":4617,"BootCount":50,"BCResetTime":"2025-08-11T14:17:51","SaveCount":127}}
                  2025-08-15 15:14:00.832 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS2 message: {"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"450/699"}}
                  2025-08-15 15:14:00.833 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS2 with {"StatusFWR":{"Version":"15.0.1(release-nspanel)","BuildDateTime":"2025-06-14T10:37:18","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"450/699"}}
                  2025-08-15 15:14:00.843 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS3 message: {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]}}
                  2025-08-15 15:14:00.843 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS3 with {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 7490",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]}}
                  2025-08-15 15:14:00.853 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS4 message: {"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":164,"StackLowMark":3,"PsrMax":2048,"PsrFree":2013,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"}}
                  2025-08-15 15:14:00.853 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS4 with {"StatusMEM":{"ProgramSize":2041,"Free":838,"Heap":164,"StackLowMark":3,"PsrMax":2048,"PsrFree":2013,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"}}
                  2025-08-15 15:14:00.863 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS6 message: {"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"NSPanel_1-488070","MqttClient":"NSPanel_1-488070","MqttUser":"iobroker","MqttCount":1,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
                  2025-08-15 15:14:00.863 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS6 with {"StatusMQT":{"MqttHost":"192.168.178.4","MqttPort":1886,"MqttClientMask":"NSPanel_1-488070","MqttClient":"NSPanel_1-488070","MqttUser":"iobroker","MqttCount":1,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
                  2025-08-15 15:14:00.869 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] send payload: {"topic":"nspanel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel.
                  2025-08-15 15:14:00.870 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Publish topic: nspanel_1/cmnd/CustomSend with message: pageType~pageStartup.
                  2025-08-15 15:14:00.873 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS7 message: {"StatusTIM":{"UTC":"2025-08-14T16:04:15Z","Local":"2025-08-14T18:04:15","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:42","Sunset":"21:07"}}
                  2025-08-15 15:14:00.873 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS7 with {"StatusTIM":{"UTC":"2025-08-14T16:04:15Z","Local":"2025-08-14T18:04:15","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":99,"Sunrise":"06:42","Sunset":"21:07"}}
                  2025-08-15 15:14:00.882 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS10 message: {"StatusSNS":{"Time":"2025-08-14T18:04:15","ANALOG":{"Temperature1":3.5},"ESP32":{"Temperature":53.3},"TempUnit":"C"}}
                  2025-08-15 15:14:00.883 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS10 with {"StatusSNS":{"Time":"2025-08-14T18:04:15","ANALOG":{"Temperature1":3.5},"ESP32":{"Temperature":53.3},"TempUnit":"C"}}
                  2025-08-15 15:14:00.892 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Incoming message for 1 subproceses. topic: nspanel_1/stat/STATUS11 message: {"StatusSTS":{"Time":"2025-08-14T18:04:15","Uptime":"0T00:03:10","UptimeSec":190,"Heap":161,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":692,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:14:00.893 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1] Receive other message nspanel_1/stat/STATUS11 with {"StatusSTS":{"Time":"2025-08-14T18:04:15","Uptime":"0T00:03:10","UptimeSec":190,"Heap":161,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":692,"MqttCount":1,"Berry":{"HeapUsed":15,"Objects":209},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"50:E6:36:C2:50:B1","Channel":11,"Mode":"HE20","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                  2025-08-15 15:14:01.069 - info: nspanel-lovelace-ui.0 (48647) [Panel_1] Automatic update of the berry driver version from 9 to 10 on tasmota with IP 192.168.178.56 and Panel-1.
                  2025-08-15 15:14:01.492 - debug: nspanel-lovelace-ui.0 (48647) [controller] Panel E4_65_B8_48_80_70 created
                  2025-08-15 15:14:03.870 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] send payload: {"topic":"nspanel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel.
                  2025-08-15 15:14:03.870 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Publish topic: nspanel_1/cmnd/CustomSend with message: pageType~pageStartup.
                  2025-08-15 15:14:07.870 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] send payload: {"topic":"nspanel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel.
                  2025-08-15 15:14:07.870 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Publish topic: nspanel_1/cmnd/CustomSend with message: pageType~pageStartup.
                  2025-08-15 15:14:12.870 - debug: nspanel-lovelace-ui.0 (48647) [Panel_1-SendClass] send payload: {"topic":"nspanel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel.
                  2025-08-15 15:14:12.870 - debug: nspanel-lovelace-ui.0 (48647) [mqttClient] Publish topic: nspanel_1/cmnd/CustomSend with message: pageType~pageStartup.
                    ticaki @hm_krause last edited by
                    @hm_krause
                    Du hast glaube ich deutlich mehr gemacht als ich gesagt habe.
                    Update adapter heißt über benutzerdefinierte Installation den adapter neu installieren - sonst nix.
                    Kannst debugMqtt wieder ausschalten. Jetzt müsste ich die ersten 10-20 Zeilen beim Adapter start sehen.
                    Sagen kann ich schon mal das im Skript kein Topic angegeben ist.
                    • teletapi
                      teletapi @Armilar last edited by teletapi
                      @armilar Ich habe jetzt beide Panele auf Berry 10 und TFT 4.95 updaten können. und beide laufen und der Adapter zeigt auch alles richtig an bis auf die Tatsache das im US_Panel unter "Device" immer noch ein "EU" Panel als Version steht. Danke
                        ticaki @teletapi last edited by
                        @teletapi
                        falsche anzeigen im admin ist TT-Tom oder mein Problem - Armilar macht tft und berry 🙂
                          hm_krause @ticaki last edited by
                          @ticaki
                          Sorry,
                          	2025-08-15 15:29:46.539	info	[Panel_1] Panel startup finished!
                          	2025-08-15 15:29:46.537	debug	[Panel_1] Set screeensaver timeout to 2s.
                          	2025-08-15 15:29:46.436	debug	[Panel_1] Set screeensaver timeout to 15s.
                          	2025-08-15 15:29:46.417	debug	[main] Switch page to visible!
                          	2025-08-15 15:29:45.908	debug	[controller] Panel E4_65_B8_48_80_70 created
                          	2025-08-15 15:29:43.589	info	[Panel_1] is online!
                          	2025-08-15 15:29:43.422	debug	[system-notifications] Received notifications from "system.host.iob-huawei": {"system":{"categories":{},"description":{"en":"These notifications are collected by the ioBroker system and point to issues you should check and fix.","de":"Diese Benachrichtigungen werden vom ioBroker-System erfasst und weisen auf Probleme hin, die überprüft und behoben werden sollten.","ru":"Эти уведомления собираются системой ioBroker и указывают на проблемы, которые вы должны проверить и исправить.","pt":"Essas notificações são coletadas pelo sistema ioBroker e apontam para problemas que você deve verificar e corrigir.","nl":"Deze meldingen worden verzameld door het ioBroker-systeem en wijzen op problemen die u moet controleren en oplossen.","fr":"Ces notifications sont collectées par le système ioBroker et indiquent des problèmes que vous devez vérifier et résoudre.","it":"Queste notifiche vengono raccolte dal sistema ioBroker e indicano problemi che dovresti controllare e correggere.","es":"Estas notificaciones son recopiladas por el sistema ioBroker y señalan problemas que debe verificar y solucionar.","pl":"Te powiadomienia są zbierane przez system ioBroker i wskazują problemy, które należy sprawdzić i naprawić.","uk":"Ці сповіщення збираються системою ioBroker і вказують на проблеми, які ви повинні перевірити та виправити.","zh-cn":"这些通知由ioBroker系统收集,并指出您应检查并修复的问题"},"name":{"en":"System Notifications","de":"System-Benachrichtigungen","ru":"Системные уведомления","pt":"Notificações do sistema","nl":"Systeemmeldingen","fr":"Notifications système","it":"Notifiche di sistema","es":"Notificaciones del sistema","pl":"Powiadomienia systemowe","uk":"Системні сповіщення","zh-cn":"系统通知"}}}
                          	2025-08-15 15:29:43.416	debug	[system-notifications] Request notifications from "system.host.iob-huawei"
                          	2025-08-15 15:29:43.416	debug	[system-notifications] Received notifications from "system.host.Iobroker": {}
                          	2025-08-15 15:29:43.401	debug	[system-notifications] Request notifications from "system.host.Iobroker"
                          	2025-08-15 15:29:43.385	debug	[mqttClient] subscripe to: nspanel_1/stat/#
                          	2025-08-15 15:29:43.383	debug	[mqttClient] subscripe to: nspanel_1/tele/#
                          	2025-08-15 15:29:43.383	debug	[Panel_1] Panel E4_65_B8_48_80_70 is initialised!
                          	2025-08-15 15:29:43.347	debug	[controller] Set current Date with time: Fri Aug 15 2025 15:29:43 GMT+0200 (Central European Summer Time)
                          	2025-08-15 15:29:43.276	debug	[mqttClient] subscripe to: nspanel_1/stat/RESULT
                          	2025-08-15 15:29:43.222	debug	[controller] controller created
                          	2025-08-15 15:29:43.220	debug	43053.9765625k
                          	2025-08-15 15:29:43.217	info	[mqttClient] Connection is active.
                          	2025-08-15 15:29:43.153	debug	Check configuration!
                          	2025-08-15 15:29:41.116	info	Force an MQTT reconnect from the Nspanel with the ip 192.168.178.56 in 10 seconds!
                          	2025-08-15 15:29:41.039	debug	[library] Load language de
                          	2025-08-15 15:29:41.039	info	Raw script config found for nspanel_1
                          	2025-08-15 15:29:41.035	debug	[config-manager] Screensaver pageItems count: 17
                          	2025-08-15 15:29:41.032	warn	Invalid color value: "0_userdata.0.Abfallkalender.1.color"
                          	2025-08-15 15:29:40.959	info	[config-manager] Start converting configuration for nspanel_1
                          	2025-08-15 15:29:40.957	info	Found 2 script configs for topics: nspanel_1, topic
                          	2025-08-15 15:29:40.957	info	Configured panels: name#topic -> [Panel_1#nspanel_1]
                          	2025-08-15 15:29:40.904	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#67197b8eec1476f6f5b81ea7b88bc9c728365c86) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
                            ticaki @hm_krause last edited by ticaki
                            @hm_krause
                            Problem besteht weiter hin? Schaue bitte nach ob die autoexec.be noch so ist wie sie sein soll - also da und nicht leer
                            kannst auch mal die hier einfügen - das sollte zwar automatisch passieren - aber keine ahnung was da nicht will https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/blob/main/tasmota/berry/10/autoexec.be
                              @ticaki
                              Datei ist da und auch mit Inhalt.
                              Problem besteht noch.
                                @hm_krause
                                dann brauche ich doch noch mal das mqttlog - sry
                                  @ticaki
                                  bitteschön, aber leider wider nur txt
                                  log neu.txt
                                  teletapi T 2 Replies Last reply Reply Quote 0
                                  • teletapi
                                    teletapi @hm_krause last edited by teletapi
                                    @hm_krause Wie wäre es denn wenn mal jemand per Anydesk drauf schaut. Das wäre ja auch ne Möglichkeit. Hab ich zur Zeit bei Auto Diagnosen immer gemacht wenn der Gegenpart einverstanden war und die Gerätschaften für die Diagnose hatte. Hat eigentlich immer ganz gut funktioniert
                                      hm_krause @teletapi last edited by
                                      @teletapi
                                      können wir machen
                                      teletapi 1 Reply Last reply Reply Quote 0
                                      • teletapi
                                        @hm_krause du hast ne PM
                                          @hm_krause
                                          Also - ich werde da nicht schlau draus - überhaupt nicht. Aus Adaptersicht gibt es kein Berry Script auf dem tasmota. Der Tasmota reagiert auf nichts das der Adapter ans tft schickt. Bitte zeige mir mal Bildschirmfoto 2025-08-15 um 15.51.30.png
                                          Bin jetzt nur noch wild am rumraten 🙂
                                            @ticaki
                                            546
                                            73163
