    3. Off Topic
    4. Pflege des Betriebssystems
    5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
      Thomas Braun Most Active @Ritter last edited by
      @ritter
      sudo -u iobroker curl -L https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh
        Ritter @Thomas Braun last edited by
        @thomas-braun soll ich den kompletten text posten oder nur bestimmtes?
          @ritter Das läuft also?
          Poste das mal komplett.
            @thomas-braun Ja
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
            Operating System: Debian GNU/Linux 13 (trixie)
             Static hostname: NUC
                   Icon name: computer-desktop
                     Chassis: desktop 🖥️
                      Kernel: Linux 6.12.41+deb13-amd64
                Architecture: x86-64
             Hardware Vendor: Intel corporation
              Hardware Model: NUC6i3SYB
            Firmware Version: SYSKLi35.86A.0070.2019.0401.1729
               Firmware Date: Mon 2019-04-01
                Firmware Age: 6y 4month 2w 2d
            OS is similar to:
            model name      : Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz
            Docker          : false
            Virtualization  : none
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             14:03:16 up  1:07,  2 users,  load average: 1.00, 1.06, 1.03
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'trixie'!
            *** TIME AND TIMEZONES ***
                           Local time: Sat 2025-08-16 14:03:16 CEST
                       Universal time: Sat 2025-08-16 12:03:16 UTC
                             RTC time: Sat 2025-08-16 12:03:16
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            christian
            HOME=/home/christian
            GROUPS=christian cdrom floppy sudo audio dip video plugdev users netdev iobroker
            iobroker
            HOME=/home/iobroker
            SUDO_HOME=/home/christian
            GROUPS=iobroker tty dialout audio video plugdev
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:             33G        5.8G         26G        1.8M        1.4G         27G
            Swap:           1.0G          0B        1.0G
            Total:           34G        5.8G         27G
            Active iob-Instances:   72
                    31993 M total memory
                     5495 M used memory
                     5050 M active memory
                      940 M inactive memory
                    25572 M free memory
                      154 M buffer memory
                     1175 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            top - 14:03:16 up  1:07,  2 users,  load average: 1.00, 1.06, 1.03
            Tasks: 198 total,   3 running, 195 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 16.1 us,  5.4 sy,  0.0 ni, 76.8 id,  1.8 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  31993.3 total,  25571.1 free,   5496.2 used,   1330.7 buff/cache
            MiB Swap:    975.0 total,    975.0 free,      0.0 used.  26497.2 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs   16G     0   16G   0% /dev
            tmpfs          tmpfs     3.2G  808K  3.2G   1% /run
            /dev/sda1      ext4      468G   63G  382G  14% /
            tmpfs          tmpfs      16G     0   16G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
            tmpfs          tmpfs      16G  668K   16G   1% /tmp
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
            tmpfs          tmpfs     3.2G  8.0K  3.2G   1% /run/user/1000
            [Sat Aug 16 12:55:40 2025] EXT4-fs (sda1): mounted filesystem 96448ee6-f182-4f61-a44e-5eb0f63f92f9 ro with ordered data mode. Quota mode: none.
            [Sat Aug 16 12:55:41 2025] EXT4-fs (sda1): re-mounted 96448ee6-f182-4f61-a44e-5eb0f63f92f9 r/w.
            Show mounted filesystems:
            TARGET SOURCE    FSTYPE OPTIONS
            /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
            /var:
            2.2G    /var/
            1.5G    /var/log/journal/08006622a09d4dd5b7dc7c548ff96709
            1.5G    /var/log
            566M    /var/cache
            Archived and active journals take up 86M in the file system.
            /opt/iobroker/backups:
            8.2G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.6G    /opt/iobroker/iobroker-data/
            1.2G    /opt/iobroker/iobroker-data/files
            308M    /opt/iobroker/iobroker-data/backup-objects
            287M    /opt/iobroker/iobroker-data/files/vis
            278M    /opt/iobroker/iobroker-data/files/vis/widgets
            63M     /opt/iobroker/iobroker-data/states.jsonl
            63M     /opt/iobroker/iobroker-data/objects.jsonl
            49M     /opt/iobroker/iobroker-data/files/0_userdata.0/cam9.mp4
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
            USB-Devices by-id:
            No Devices found 'by-id'
            *** ZigBee Settings ***
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v22.18.0
            /usr/bin/node           v22.18.0
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            /usr/bin/corepack       0.33.0
            nodejs:
              Installed: 22.18.0-1nodesource1
              Candidate: 22.18.0-1nodesource1
              Version table:
             *** 22.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 22.17.1-1nodesource1 1001
                 22.17.0-1nodesource1 1001
                 22.16.0-1nodesource1 1001
                 22.15.1-1nodesource1 1001
                 22.15.0-1nodesource1 1001
                 22.14.0-1nodesource1 1001
                 22.13.1-1nodesource1 1001
                 22.13.0-1nodesource1 1001
                 22.12.0-1nodesource1 1001
                 22.11.0-1nodesource1 1001
                 22.10.0-1nodesource1 1001
                 22.9.0-1nodesource1 1001
                 22.8.0-1nodesource1 1001
                 22.7.0-1nodesource1 1001
                 22.6.0-1nodesource1 1001
                 22.5.1-1nodesource1 1001
                 22.5.0-1nodesource1 1001
                 22.4.1-1nodesource1 1001
                 22.4.0-1nodesource1 1001
                 22.3.0-1nodesource1 1001
                 22.2.0-1nodesource1 1001
                 22.1.0-1nodesource1 1001
                 22.0.0-1nodesource1 1001
                 20.19.2+dfsg-1 500
                    500 http://deb.debian.org/debian trixie/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            Checking for nodejs vulnerability:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            NUC                 NUC (version: 7.0.7, hostname: NUC           , alive, uptime: 4058)
            Core adapters versions
            js-controller:  7.0.7
            admin:          7.7.2
            javascript:     9.0.11
            nodejs modules from github:     8
            +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e        98f7443e85ebe29d98d8d725640dd0a8a)
            +-- iobroker.pirate-weather@0.1.4 (git+ssh://git@github.com/ticaki/ioBroker.pirate-weather.git#f70e2e8f1968bfe6        5afabf792ca73253a19f8321)
            | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8        635550)
            +-- iobroker.signifylights@1.0.0 (git+ssh://git@github.com/disaster123/ioBroker.signifylights.git#bb475662d63f1        e39993c2b4e9fb395c29dcd1adc)
            | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
            +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de        3ed1f6e3)
            +-- iobroker.xsense@0.0.12 (git+ssh://git@github.com/arteck/ioBroker.xsense.git#cae2e07ac3d59527f701426739ed0cf        14afdd0de)
            +-- iobroker.yr@5.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.yr.git#dec7b7f69b3968a43a390e2b2a60391c2dca6b        23)
            Adapter State
            + system.adapter.accuweather.0            : accuweather           : NUC                                      -        enabled
            + system.adapter.admin.0                  : admin                 : NUC                                      -        enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alias-manager.0          : alias-manager         : NUC                                      -        disabled
            + system.adapter.backitup.0               : backitup              : NUC                                      -        enabled
            + system.adapter.chromecast.0             : chromecast            : NUC                                      -        enabled
              system.adapter.daswetter.0              : daswetter             : NUC                                      -        enabled
            + system.adapter.device-reminder.0        : device-reminder       : NUC                                      -        enabled
            + system.adapter.device-watcher.0         : device-watcher        : NUC                                      -        enabled
              system.adapter.devices.0                : devices               : NUC                                      -        disabled
            + system.adapter.discovery.0              : discovery             : NUC                                      -        enabled
              system.adapter.drops-weather.0          : drops-weather         : NUC                                      -        disabled
              system.adapter.dwd.0                    : dwd                   : NUC                                      -        enabled
            + system.adapter.echarts.0                : echarts               : NUC                                      -        enabled
            + system.adapter.email.0                  : email                 : NUC                                      -        enabled
            + system.adapter.email.1                  : email                 : NUC                                      -        enabled
            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: NUC                                      -        enabled
            + system.adapter.enigma2.0                : enigma2               : NUC                                      -        enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUC                                      -        enabled
              system.adapter.feiertage.0              : feiertage             : NUC                                      -        enabled
              system.adapter.flot.0                   : flot                  : NUC                                      -        disabled
            + system.adapter.fullcalendar.0           : fullcalendar          : NUC                                      -        enabled
              system.adapter.habpanel.0               : habpanel              : NUC                                      -        disabled
            + system.adapter.hass.0                   : hass                  : NUC                                      -        enabled, port: 8123
            + system.adapter.heizoel.0                : heizoel               : NUC                                      -        enabled
            + system.adapter.history.0                : history               : NUC                                      -        enabled
            + system.adapter.hm-rega.0                : hm-rega               : NUC                                      -        enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : NUC                                      -        enabled, port: 3000
            + system.adapter.hm-rpc.1                 : hm-rpc                : NUC                                      -        enabled, port: 4000
            + system.adapter.hm-rpc.2                 : hm-rpc                : NUC                                      -        enabled, port: 5000
            + system.adapter.hm-rpc.3                 : hm-rpc                : NUC                                      -        enabled, port: 5500
            + system.adapter.homeconnect.0            : homeconnect           : NUC                                      -        enabled
              system.adapter.ical.0                   : ical                  : NUC                                      -        enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUC        - disabled
              system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: NUC        -  enabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : NUC                                      -        disabled
              system.adapter.icons-freepic.0          : icons-freepic         : NUC                                      -        enabled
              system.adapter.icons-icons8.0           : icons-icons8          : NUC                                      -        disabled
              system.adapter.icons-material-png.0     : icons-material-png    : NUC                                      -        disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : NUC                                      -        disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUC                                      -        disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUC                                      -        disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: NUC        - disabled
              system.adapter.icons-smarthome.0        : icons-smarthome       : NUC                                      -        enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : NUC                                      -        disabled
            + system.adapter.iot.0                    : iot                   : NUC                                      -        enabled
            + system.adapter.javascript.0             : javascript            : NUC                                      -        enabled
              system.adapter.klipper-moonraker.0      : klipper-moonraker     : NUC                                      -        disabled
            + system.adapter.linux-control.0          : linux-control         : NUC                                      -        enabled
              system.adapter.material.0               : material              : NUC                                      -        disabled
            + system.adapter.matter.0                 : matter                : NUC                                      -        enabled
              system.adapter.meross.0                 : meross                : NUC                                      -        disabled
              system.adapter.meteoalarm.0             : meteoalarm            : NUC                                      -        enabled
              system.adapter.mobile.0                 : mobile                : NUC                                      -        disabled
            + system.adapter.mqtt.0                   : mqtt                  : NUC                                      -        enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.nina.0                   : nina                  : NUC                                      -        enabled
              system.adapter.node-red.0               : node-red              : NUC                                      -        disabled, port: 1880, bind: 0.0.0.0
              system.adapter.odl.0                    : odl                   : NUC                                      -        enabled
            + system.adapter.onkyo.0                  : onkyo                 : NUC                                      -        enabled
            + system.adapter.onvif.0                  : onvif                 : NUC                                      -        enabled, port: 8000
            + system.adapter.opendtu.0                : opendtu               : NUC                                      -        enabled
              system.adapter.openweathermap.0         : openweathermap        : NUC                                      -        enabled
            + system.adapter.parser.0                 : parser                : NUC                                      -        enabled
            + system.adapter.ping.0                   : ping                  : NUC                                      -        enabled
              system.adapter.pirate-weather.0         : pirate-weather        : NUC                                      -        disabled
            + system.adapter.places.0                 : places                : NUC                                      -        enabled
            + system.adapter.pollenflug.0             : pollenflug            : NUC                                      -        enabled
            + system.adapter.pushover.0               : pushover              : NUC                                      -        enabled
            + system.adapter.reolink.0                : reolink               : NUC                                      -        enabled
              system.adapter.rickshaw.0               : rickshaw              : NUC                                      -        disabled
            + system.adapter.sainlogic.0              : sainlogic             : NUC                                      -        enabled, port: 45000, bind: 0.0.0.0
            + system.adapter.samsung.0                : samsung               : NUC                                      -        enabled
            + system.adapter.samsung_tizen.0          : samsung_tizen         : NUC                                      -        enabled, port: 8002
            + system.adapter.sayit.0                  : sayit                 : NUC                                      -        enabled
            + system.adapter.sayit.7                  : sayit                 : NUC                                      -        enabled
            + system.adapter.scenes.0                 : scenes                : NUC                                      -        enabled
            + system.adapter.scheduler.0              : scheduler             : NUC                                      -        enabled
            + system.adapter.signifylights.0          : signifylights         : NUC                                      -        enabled
            + system.adapter.simple-api.0             : simple-api            : NUC                                      -        enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.socketio.0               : socketio              : NUC                                      -        enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : NUC                                      -        enabled, port: 1885, bind: 0.0.0.0
            + system.adapter.statistics.0             : statistics            : NUC                                      -        enabled
            + system.adapter.synology.0               : synology              : NUC                                      -        enabled, port: 5000
            + system.adapter.tankerkoenig.0           : tankerkoenig          : NUC                                      -        enabled
            + system.adapter.telegram.0               : telegram              : NUC                                      -        enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.1               : telegram              : NUC                                      -        enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : NUC                                      -        enabled
            + system.adapter.text2command.1           : text2command          : NUC                                      -        enabled
            + system.adapter.time-switch.0            : time-switch           : NUC                                      -        enabled
            + system.adapter.tr-064.0                 : tr-064                : NUC                                      -        enabled
            + system.adapter.trashschedule.0          : trashschedule         : NUC                                      -        enabled
            + system.adapter.tuya.0                   : tuya                  : NUC                                      -        enabled
            + system.adapter.vesync.0                 : vesync                : NUC                                      -        enabled
              system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: NUC        -  enabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : NUC                                      -        disabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : NUC                                      -        disabled
              system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: NUC                                      -        enabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: NUC                                      -        disabled
              system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: NUC        -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : NUC                                      -        enabled
              system.adapter.vis-bars.0               : vis-bars              : NUC                                      -        disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : NUC                                      -        disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUC                                      -        disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : NUC                                      -        disabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : NUC                                      -        enabled
              system.adapter.vis-history.0            : vis-history           : NUC                                      -        disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUC                                      -        disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : NUC                                      -        disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : NUC                                      -        enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUC                                      -        disabled
              system.adapter.vis-justgage.0           : vis-justgage          : NUC                                      -        disabled
              system.adapter.vis-keyboard.0           : vis-keyboard          : NUC                                      -        disabled
              system.adapter.vis-map.0                : vis-map               : NUC                                      -        disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : NUC                                      -        disabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : NUC                                      -        disabled
              system.adapter.vis-material.0           : vis-material          : NUC                                      -        disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : NUC                                      -        disabled
              system.adapter.vis-metro.0              : vis-metro             : NUC                                      -        disabled
              system.adapter.vis-players.0            : vis-players           : NUC                                      -        disabled
              system.adapter.vis-plumb.0              : vis-plumb             : NUC                                      -        enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : NUC                                      -        disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUC                                      -        disabled
              system.adapter.vis-weather.0            : vis-weather           : NUC                                      -        disabled
              system.adapter.vis.0                    : vis                   : NUC                                      -        enabled
            + system.adapter.weather-warnings.0       : weather-warnings      : NUC                                      -        enabled
            + system.adapter.web.0                    : web                   : NUC                                      -        enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.windows-control.0        : windows-control       : NUC                                      -        enabled
            + system.adapter.wled.0                   : wled                  : NUC                                      -        enabled
            + system.adapter.xsense.0                 : xsense                : NUC                                      -        enabled
            + system.adapter.yamaha.0                 : yamaha                : NUC                                      -        enabled
              system.adapter.yr.0                     : yr                    : NUC                                      -        enabled
            + system.adapter.zendure-solarflow.0      : zendure-solarflow     : NUC                                      -        enabled
            + system.adapter.zigbee.0                 : zigbee                : NUC                                      -        enabled, port: tcp://192.168.1.49:6638
            + instance is alive
            ioBroker-Repositories
            │ (index) │ name          │ url        │ auto upgrade │
            │ 0       │ 'online'      │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-di        st.json' │ false        │
            │ 1       │ 'fast-online' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 2       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 3       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json'        │ false        │
            Active repo(s): beta
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: beta
            Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
            Adapter    "admin"        : 7.7.2    , installed 7.7.2
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "device-watcher": 2.12.6  , installed 2.12.6
            Adapter    "devices"      : 1.2.8    , installed 1.2.8
            Adapter    "drops-weather": 1.2.7    , installed 1.2.7
            Adapter    "echarts"      : 2.0.6    , installed 2.0.6
            Adapter    "email"        : 2.0.4    , installed 2.0.4
            Adapter    "energiefluss-erweitert": 0.7.8, installed 0.7.8
            Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
            Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "hass"         : 1.4.0    , installed 1.4.0
            Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
            Adapter    "ical"         : 1.16.2   , installed 1.16.2
            Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
            Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
            Adapter    "iot"          : 3.6.0    , installed 3.6.0
            Adapter    "javascript"   : 9.0.11   , installed 9.0.11
            Controller "js-controller": 7.0.7    , installed 7.0.7
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "matter"       : 0.5.2    , installed 0.5.2
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "meteoalarm"   : 4.0.1    , installed 4.0.1
            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
            Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
            Adapter    "nina"         : 0.0.26   , installed 0.0.26
            Adapter    "node-red"     : 6.0.7    , installed 6.0.7
            Adapter    "odl"          : 5.0.0    , installed 5.0.0
            Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
            Adapter    "onvif"        : 1.1.4    , installed 1.1.4
            Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
            Adapter    "openweathermap": 1.4.0   , installed 1.4.0
            Adapter    "parser"       : 2.3.1    , installed 2.3.1
            Adapter    "ping"         : 1.7.9    , installed 1.7.9
            Adapter    "places"       : 1.3.0    , installed 1.3.0
            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "reolink"      : 1.2.3    , installed 1.2.3
            Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
            Adapter    "sainlogic"    : 0.12.1   , installed 0.12.1
            Adapter    "samsung"      : 0.6.1    , installed 0.6.1
            Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
            Adapter    "scenes"       : 4.0.3    , installed 4.0.3
            Adapter    "scheduler"    : 1.5.0    , installed 1.5.0
            Adapter    "signifylights": 1.0.0    , installed 1.0.0
            Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
            Adapter    "socketio"     : 7.0.8    , installed 7.0.8
            Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
            Adapter    "statistics"   : 4.0.0    , installed 4.0.0
            Adapter    "synology"     : 3.1.0    , installed 3.1.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "trashschedule": 4.0.1    , installed 4.0.1
            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
            Adapter    "vesync"       : 0.0.9    , installed 0.0.9
            Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
            Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
            Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
            Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
            Adapter    "vis-2-widgets-inventwo": 0.3.5, installed 0.3.5
            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
            Adapter    "vis-2-widgets-weather-and-heating": 1.1.1, installed 1.1.1
            Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
            Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
            Adapter    "vis-material" : 0.2.0    , installed 0.2.0
            Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
            Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
            Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
            Adapter    "web"          : 7.0.9    , installed 7.0.9
            Adapter    "windows-control": 0.1.5  , installed 0.1.5
            Adapter    "wled"         : 0.7.3    , installed 0.7.3
            Adapter    "ws"           : 3.0.19   , installed 3.0.19
            Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            Adapter    "zendure-solarflow": 2.0.1, installed 2.0.1
            Adapter    "zigbee"       : 3.0.3    , installed 3.0.3
            Objects and States
            Objects:        51207
            States:         39525
            W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, s        ee --audit for details
            Hit:1 http://deb.debian.org/debian trixie InRelease
            Hit:2 http://security.debian.org/debian-security trixie-security InRelease
            Hit:3 http://deb.debian.org/debian trixie-updates InRelease
            Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
            Reading package lists... Done
            Pending Updates: 0
            *** Listening Ports ***
            Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Progr        am name
            tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       16865      3291/io.s        ainlogic.0
            tcp        0      0 192.168.1.31:5500       0.0.0.0:*               LISTEN      1001       9642       1375/io.h        m-rpc.3
            tcp        0      0 192.168.1.31:5000       0.0.0.0:*               LISTEN      1001       11682      1364/io.h        m-rpc.2
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5905       949/exim4
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       6957       679/iobro        ker.js-con
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       6962       679/iobro        ker.js-con
            tcp        0      0 192.168.1.31:4000       0.0.0.0:*               LISTEN      1001       9638       1347/io.h        m-rpc.1
            tcp        0      0 192.168.1.31:3000       0.0.0.0:*               LISTEN      1001       11657      1332/io.h        m-rpc.0
            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       11839      1521/io.s        onoff.0
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       11740      1416/io.m        qtt.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11739      1416/io.m        qtt.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7488       784/sshd:        /usr/sbin
            tcp6       0      0 :::8555                 :::*                    LISTEN      1000       9156       1785/go2r        tc_linux_a
            tcp6       0      0 :::8554                 :::*                    LISTEN      1000       9153       1785/go2r        tc_linux_a
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5906       949/exim4
            tcp6       0      0 :::1984                 :::*                    LISTEN      1000       11954      1785/go2r        tc_linux_a
            tcp6       0      0 :::22                   :::*                    LISTEN      0          7490       784/sshd:        /usr/sbin
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       15126      2919/io.s        imple-api.
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16540      2930/io.s        ocketio.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14524      1848/io.w        eb.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5101       965/io.ad        min.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          5867       638/dhcli        ent
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17773      3255/io.m        atter.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17768      3255/io.m        atter.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15306      3223/io.w        led.0
            udp        0      0 192.168.1.31:5353       0.0.0.0:*                           1001       9042       1543/io.t        r-064.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11611      1272/io.c        hromecast.
            udp        0 213120 0.0.0.0:38899           0.0.0.0:*                           1001       15070      2900/io.s        ignifyligh
            udp        0      0 0.0.0.0:38900           0.0.0.0:*                           1001       15071      2900/io.s        ignifyligh
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       14547      1797/io.t        uya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       14548      1797/io.t        uya.0
            udp        0      0 192.168.1.31:8555       0.0.0.0:*                           1000       9160       1785/go2r        tc_linux_a
            udp        0      0 0.0.0.0:57856           0.0.0.0:*                           1001       17779      3255/io.m        atter.0
            udp6       0      0 :::5353                 :::*                                1001       17774      3255/io.m        atter.0
            udp6       0      0 :::5353                 :::*                                1001       17769      3255/io.m        atter.0
            udp6       0      0 2003:c5:8f45:2500::8555 :::*                                1000       9162       1785/go2r        tc_linux_a
            udp6       0      0 fd8f:79ab:5076:0:b:8555 :::*                                1000       9161       1785/go2r        tc_linux_a
            udp6       0      0 :::57856                :::*                                1001       17778      3255/io.m        atter.0
            2025-08-16 14:00:52.800  - info: yr.0 (13131) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-08-16 14:00:53.318  - info: host.NUC instance system.adapter.yr.0 having pid 13131 terminated with code 11        (ADAPTER_REQUESTED_TERMINATION)
            2025-08-16 14:00:56.543  - info: openweathermap.0 (13149) Terminated (NO_ERROR): Without reason
            2025-08-16 14:00:57.060  - info: host.NUC instance system.adapter.openweathermap.0 having pid 13149 terminated        with code 0 (NO_ERROR)
            2025-08-16 14:01:48.011  - info: host.NUC instance system.adapter.dwd.0 in version "2.8.5" started with pid 133        10
            2025-08-16 14:01:49.369  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.adapter.d        wd.0.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"        }}
            2025-08-16 14:01:49.484  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":tr        ue,"write":true,"role":"value"},"native":{},"_id":"system.adapter.dwd.0.plugins.sentry.enabled","acl":{"object"        :1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
            2025-08-16 14:01:49.830  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.alive:{"_id":"system.adapter.dwd.0.alive","type":"state","common":{"name":"dwd.0 alive","type":"boole        an","role":"indicator.state","custom":{"lovelace.0":{"enabled":true,"entity":"","name":""}},"read":true,"write"        :true},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.adm        inistrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":1755345709828}
            2025-08-16 14:01:49.965  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.connected:{"_id":"system.adapter.dwd.0.connected","type":"state","common":{"name":"dwd.0 is connected        ","type":"boolean","role":"indicator.state","custom":{"lovelace.0":{"enabled":true,"entity":"","name":""}},"rea        d":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"        system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":175534570        9963}
            2025-08-16 14:01:50.056  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.compactMode:{"_id":"system.adapter.dwd.0.compactMode","type":"state","common":{"name":"dwd.0.compactM        ode","type":"boolean","read":true,"write":false,"role":"indicator.state"},"native":{},"acl":{"object":1636,"sta        te":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.0","        user":"system.user.admin","ts":1755345709970}
            2025-08-16 14:01:50.319  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.cpu:{"_id":"system.adapter.dwd.0.cpu","type":"state","common":{"name":"dwd.0.cpu","type":"number","re        ad":true,"write":false,"role":"indicator.state","unit":"% of one core"},"native":{},"acl":{"object":1636,"state        ":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.0","us        er":"system.user.admin","ts":1755345710296}
            2025-08-16 14:01:50.473  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.cputime:{"_id":"system.adapter.dwd.0.cputime","type":"state","common":{"name":"dwd.0.cputime","type":        "number","read":true,"write":false,"role":"indicator.state","unit":"seconds"},"native":{},"acl":{"object":1636,        "state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.        0","user":"system.user.admin","ts":1755345710450}
            2025-08-16 14:01:50.613  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.memHeapUsed:{"_id":"system.adapter.dwd.0.memHeapUsed","type":"state","common":{"name":"dwd.0 heap act        ually Used","type":"number","role":"indicator.state","unit":"MB","custom":{"lovelace.0":{"enabled":true,"entity        ":"","name":""}},"read":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.        admin","ownerGroup":"system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system.user.        admin","ts":1755345710610}
            2025-08-16 14:01:50.746  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.memHeapTotal:{"_id":"system.adapter.dwd.0.memHeapTotal","type":"state","common":{"name":"dwd.0 total        Size of the Heap","type":"number","role":"indicator.state","unit":"MB","custom":{"lovelace.0":{"enabled":true,"        entity":"","name":""}},"read":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owner":"system        .user.admin","ownerGroup":"system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system        .user.admin","ts":1755345710744}
            2025-08-16 14:01:50.874  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.memRss:{"_id":"system.adapter.dwd.0.memRss","type":"state","common":{"name":"dwd.0 resident Set Size"        ,"desc":"Resident set size","type":"number","role":"indicator.state","unit":"MB","custom":{"lovelace.0":{"enabl        ed":true,"entity":"","name":""}},"read":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owne        r":"system.user.admin","ownerGroup":"system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","use        r":"system.user.admin","ts":1755345710867}
            2025-08-16 14:01:51.060  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.uptime:{"_id":"system.adapter.dwd.0.uptime","type":"state","common":{"name":"dwd.0 uptime","type":"nu        mber","role":"indicator.state","unit":"seconds","custom":{"lovelace.0":{"enabled":true,"entity":"","name":""}},        "read":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGrou        p":"system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":17553        45711008}
            2025-08-16 14:01:51.199  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.inputCount:{"_id":"system.adapter.dwd.0.inputCount","type":"state","common":{"name":"dwd.0 events inp        ut counter","desc":"State's inputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","uni        t":"events/15 seconds"},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":        "system.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":1755345711140}
            2025-08-16 14:01:51.356  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.outputCount:{"_id":"system.adapter.dwd.0.outputCount","type":"state","common":{"name":"dwd.0 events o        utput counter","desc":"State's outputs in 15 seconds","type":"number","read":true,"write":false,"role":"state",        "unit":"events/15 seconds"},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGro        up":"system.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":1755345711293}
            2025-08-16 14:01:51.435  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.eventLoopLag:{"_id":"system.adapter.dwd.0.eventLoopLag","type":"state","common":{"name":"dwd.0 Node.j        s event loop lag","desc":"Node.js event loop lag in ms averaged over 15 seconds","type":"number","read":true,"w        rite":false,"role":"state","unit":"ms"},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admi        n","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":175        5345711427}
            2025-08-16 14:01:51.599  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.sigKill:{"_id":"system.adapter.dwd.0.sigKill","type":"state","common":{"name":"dwd.0 kill signal","ty        pe":"number","read":true,"write":false,"desc":"Process id that must survive. All other IDs must terminate itsel        f","role":"state"},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"syst        em.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":1755345711575}
            2025-08-16 14:01:51.767  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.logLevel:{"_id":"system.adapter.dwd.0.logLevel","type":"state","common":{"name":"dwd.0 loglevel","typ        e":"string","read":true,"write":true,"desc":"Loglevel of the adapter. Will be set on start with defined value b        ut can be overridden during runtime","role":"state"},"native":{},"acl":{"object":1636,"state":1636,"owner":"sys        tem.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.ad        min","ts":1755345711743}
            2025-08-16 14:01:52.050  - info: dwd.0 (13310) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.d        wd, node: v22.18.0, js-controller: 7.0.7
            2025-08-16 14:01:53.179  - info: dwd.0 (13310) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-08-16 14:01:53.739  - info: host.NUC instance system.adapter.dwd.0 having pid 13310 terminated with code 1        1 (ADAPTER_REQUESTED_TERMINATION)
            2025-08-16 14:02:17.123  - error: weather-warnings.0 (3185) [json] No template for key: NewJson!
            iob diag has finished.
              @ritter
              Setz den user die Gruppe adm rein.
              Uns stell das LogLevel für vis-2.0.0 auf info oder sowas, aber nicht auf silly.
              Lösch das log mal:
              sudo -u iobroker rm /home/iobroker/iob_diag.log
                @thomas-braun LogLevel umgestellt, log gelöscht,
                mit "Setz den user die Gruppe adm rein." weis nicht genau was ich tun soll.
                christian@NUC:~$ sudo -u iobroker rm /home/iobroker/iob_diag.log
                [sudo] Passwort für christian:
                christian@NUC:~$ iob diag
                /usr/bin/iob: Zeile 21: /home/iobroker/iob_diag.log: Keine Berechtigung
                christian@NUC:~$
                  @ritter
                  sudo usermod -a -G adm christian
                  Dann die Kiste einmal sauber neustarten.
                  Die Meldung
                  macht eigentlich keinen Sinn. Die Zeile 21 schaut so aus:
                  sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh "$2" | sudo -u iobroker tee /home/iobroker/iob_diag.log
                  Das muss eigentlich mit den Rechten funktionieren.
                    @thomas-braun Bei dem zweiten Befehl kommt jede Menge Text ungefär wie vorhin. Wenn ich jetzt iob diag eingebe bleibt es so stehen seit einigen Minuten.
                      @ritter
                      Da muss du das Passwort des christian eingeben.
                      Das erfolgt blind, keine Rückmeldung in der Konsole.
                        @thomas-braun Das habe ich schon, danach bleibt der grüne curser Punkt darunter stehen
                          Thomas Braun Most Active @Ritter last edited by Thomas Braun
                          @ritter
                          Da stimmt doch irgendwas mit deiner sudo-Konfiguration nicht...
                          sudo whoami
                          sudo -H -u iobroker whoami
                          liefert?
                            @thomas-braun sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                            sudo whoami
                            christian@NUC:~$ sudo whoami
                            root
                            iobroker
                            christian@NUC:~$
                              @ritter
                              Un jetzt?
                              iob diag
                                @thomas-braun ```
                                Script v.2025-08-09
                                *** BASE SYSTEM ***
                                         Chassis: desktop 🖥️
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 17:33:31 up  2:16,  2 users,  load average: 1.39, 1.65, 1.36
                                CPU threads: 4
                                               Local time: Sat 2025-08-16 17:33:31 CEST
                                           Universal time: Sat 2025-08-16 15:33:31 UTC
                                                 RTC time: Sat 2025-08-16 15:33:31
                                              NTP service: active
                                          RTC in local TZ: no
                                christian
                                GROUPS=christian adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
                                js-controller is not running
                                Display-Manager:
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Mem:             33G        837M         31G        4.3M        2.1G         32G
                                Swap:           1.0G          0B        1.0G
                                Total:           34G        837M         32G
                                Active iob-Instances:   1
                                          798 M used memory
                                          290 M active memory
                                         1208 M inactive memory
                                        29686 M free memory
                                          329 M buffer memory
                                         1641 M swap cache
                                          974 M total swap
                                            0 M used swap
                                          974 M free swap
                                top - 17:33:31 up  2:16,  2 users,  load average: 1.28, 1.62, 1.35
                                Tasks: 184 total,   1 running, 183 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  1.9 us,  3.8 sy,  0.0 ni, 94.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :  31993.3 total,  29686.8 free,    798.2 used,   1970.8 buff/cache
                                MiB Swap:    975.0 total,    975.0 free,      0.0 used.  31195.1 avail Mem
                                  UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                * iobroker.service loaded failed failed ioBroker Server
                                Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                        ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                        SUB    -> The low-level unit activation state, values depend on unit type.
                                1 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/sda1      ext4      468G   62G  382G  14% /
                                tmpfs          tmpfs      16G  3.1M   16G   1% /tmp
                                [Sat Aug 16 15:17:16 2025] EXT4-fs (sda1): mounted filesystem 96448ee6-f182-4f61-a44e-5eb0f63f92f9 ro with ordered data mode. Quota mode: none.
                                [Sat Aug 16 15:17:17 2025] EXT4-fs (sda1): re-mounted 96448ee6-f182-4f61-a44e-5eb0f63f92f9 r/w.
                                /var:
                                2.2G    /var/
                                1.5G    /var/log
                                566M    /var/cache
                                Archived and active journals take up 1.4G in the file system.
                                1.5G    /opt/iobroker/iobroker-data/
                                40M     /opt/iobroker/iobroker-data/objects.jsonl
                                27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                USB-Devices by-id:
                                HINT:
                                tcp
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.9.3
                                /usr/bin/npx            10.9.3
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                ioBroker Status
                                iobroker is not running on this host.
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                NUC                 NUC (version: 7.0.7, hostname: NUC           , alive, uptime: 8018)
                                admin:          7.7.2
                                javascript:     9.0.11
                                +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e98f7443e85ebe29d98d8d725640dd0a8a)
                                +-- iobroker.pirate-weather@0.1.4 (git+ssh://git@github.com/ticaki/ioBroker.pirate-weather.git#f70e2e8f1968bfe65afabf792ca73253a19f8321)
                                | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                +-- iobroker.signifylights@1.0.0 (git+ssh://git@github.com/disaster123/ioBroker.signifylights.git#bb475662d63f1e39993c2b4e9fb395c29dcd1adc)
                                +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de3ed1f6e3)
                                +-- iobroker.xsense@0.0.12 (git+ssh://git@github.com/arteck/ioBroker.xsense.git#cae2e07ac3d59527f701426739ed0cf14afdd0de)
                                +-- iobroker.yr@5.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.yr.git#dec7b7f69b3968a43a390e2b2a60391c2dca6b23)
                                Adapter State
                                + instance is alive
                                │ 0       │ 'online'      │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
                                Objects and States
                                Objects:        51148
                                States:         38799
                                W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                Hit:1 http://security.debian.org/debian-security trixie-security InRelease
                                Hit:2 http://deb.debian.org/debian trixie InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          854        935/exim4
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5832       766/sshd: /usr/sbin
                                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          855        935/exim4
                                tcp6       0      0 :::8555                 :::*                    LISTEN      1000       9071       1751/go2rtc_linux_a
                                tcp6       0      0 :::8554                 :::*                    LISTEN      1000       9067       1751/go2rtc_linux_a
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          5834       766/sshd: /usr/sbin
                                tcp6       0      0 :::1984                 :::*                    LISTEN      1000       10692      1751/go2rtc_linux_a
                                udp        0      0 192.168.1.31:8555       0.0.0.0:*                           1000       9075       1751/go2rtc_linux_a
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          816        626/dhclient
                                udp6       0      0 2003:c5:8f45:2500::8555 :::*                                1000       9077       1751/go2rtc_linux_a
                                udp6       0      0 fd8f:79ab:5076:0:b:8555 :::*                                1000       9076       1751/go2rtc_linux_a
                                2025-08-16 17:31:16.378  - warn: host.NUC instance system.adapter.statistics.0 terminated due to SIGKILL
                                2025-08-16 17:31:16.378  - info: host.NUC instance system.adapter.statistics.0 terminated with code null ()
                                2025-08-16 17:31:16.470  - warn: host.NUC instance system.adapter.tankerkoenig.0 terminated due to SIGKILL
                                2025-08-16 17:31:16.470  - info: host.NUC instance system.adapter.tankerkoenig.0 terminated with code null ()
                                2025-08-16 17:31:16.471  - warn: host.NUC instance system.adapter.text2command.1 terminated due to SIGKILL
                                2025-08-16 17:31:16.471  - info: host.NUC instance system.adapter.text2command.1 terminated with code null ()
                                2025-08-16 17:31:16.491  - warn: host.NUC instance system.adapter.time-switch.0 terminated due to SIGKILL
                                2025-08-16 17:31:16.491  - info: host.NUC instance system.adapter.time-switch.0 terminated with code null ()
                                2025-08-16 17:31:16.511  - warn: host.NUC instance system.adapter.vis-2.0 terminated due to SIGKILL
                                2025-08-16 17:31:16.511  - info: host.NUC instance system.adapter.vis-2.0 terminated with code null ()
                                2025-08-16 17:31:16.548  - warn: host.NUC instance system.adapter.windows-control.0 terminated due to SIGKILL
                                2025-08-16 17:31:16.548  - info: host.NUC instance system.adapter.windows-control.0 terminated with code null ()
                                2025-08-16 17:31:16.588  - warn: host.NUC instance system.adapter.energiefluss-erweitert.0 terminated due to SIGKILL
                                2025-08-16 17:31:16.588  - info: host.NUC instance system.adapter.energiefluss-erweitert.0 terminated with code null ()
                                2025-08-16 17:31:16.588  - warn: host.NUC instance system.adapter.vesync.0 terminated due to SIGKILL
                                2025-08-16 17:31:16.603  - info: host.NUC instance system.adapter.vesync.0 terminated with code null ()
                                2025-08-16 17:31:17.187  - info: host.NUC instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
                                2025-08-16 17:31:17.208  - info: host.NUC instance system.adapter.vis-inventwo.0 terminated while should be started once
                                2025-08-16 17:31:17.237  - warn: host.NUC instance system.adapter.tuya.0 terminated due to SIGKILL
                                2025-08-16 17:31:17.238  - info: host.NUC instance system.adapter.tuya.0 terminated with code null ()
                                2025-08-16 17:31:17.258  - info: host.NUC instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                                2025-08-16 17:31:17.307  - info: host.NUC instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2025-08-16 17:31:17.307  - info: host.NUC instance system.adapter.matter.0 terminated with code 0 (NO_ERROR)
                                2025-08-16 17:31:17.307  - info: host.NUC All instances are stopped.
                                2025-08-16 17:31:17.375  - info: host.NUC terminated
                                christian@NUC:~$
                                  @ritter
                                  Funktioniert also wieder.
                                    @thomas-braun Ja, es funktioniert jetzt. Vielen herzlichen Dank für deine Hilfe und Geduld und die super Anleitung für das upgrade.
                                    • Codierknecht
                                      Codierknecht Developer Most Active last edited by Codierknecht
                                      Prinzipiell hat das Upgrade dank @Thomas-Braun's detaillierter Anleitung problemlos funktioniert.
                                      Zuerst vor dem offiziellen Release auf der Testkiste und dann - nachdem das einwandfrei geklappt hat - gestern auf dem Produktivsystem.
                                      Allerdings lief heute Morgen das MySQL-Backup nicht mehr durch:
                                      2025-08-16 02:40:25.969 - error: backitup.0 (483) [iobroker/mysql] Error: Command failed: mysqldump -u ioBroker -p**** ioBroker -h 192.168.178.51 -P 3306 > /opt/iobroker/backups/mysql_2025_08_16-02_40_25_backupiobroker.sql
                                      2025-08-16 02:40:25.970 - error: backitup.0 (483) [iobroker/mysql] mysqldump: Got error: 2026: "TLS/SSL error: SSL is required, but the server does not support it" when trying to connect
                                      2025-08-16 02:40:25.970 - error: backitup.0 (483) [iobroker] Error: Command failed: mysqldump -u ioBroker -p**** ioBroker -h 192.168.178.51 -P 3306 > /opt/iobroker/backups/mysql_2025_08_16-02_40_25_backupiobroker.sql
                                      Der DB-Server läuft - genau wie der ioBroker - als LXC unter Proxmox. Das wurde gleichzeitig mit dem Upgrade des ioBroker auf PVE 9.0.5 gehoben.
                                      An den LXC's selbst wurde nix weiter geändert.
                                      Die Historisierung über den SQL-Adapter funktioniert ja auch weiterhin problemlos.
                                      @simatec Was muss ich jetzt hier unternehmen? SSL brauche ich innerhalb meines lokalen Netzes nicht. Kann man dem Backup beibringen, die Option --skip-ssl zu verwenden?
                                      • OliverIO
                                        OliverIO @Codierknecht last edited by
                                        @codierknecht
                                        Die Frage ist, warum MySQL bei dir überhaupt SSL verlangt.
                                        Normalerweise muss man das für den Server oder für den User Extra konfigurieren.
                                        Schau mal in der Konfiguration einmal hier.
                                        [mysqld]
                                        require_secure_transport = ON
                                        Oder in der Datenbank selbst
                                        SELECT user, host, ssl_type
                                        FROM mysql.user;
                                        • Eduard77
                                          Eduard77 @Dr. Bakterius last edited by
                                          @dr-bakterius sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                          sudo apt-get install iputils-ping --reinstall
                                          Tut mir leid, dass ich erst jetzt antworte.
                                          Ich habe jetzt versucht nochmals mit deinem Code zu machen.
                                          Hat wieder nichts gebracht.
                                          edi77@DebianIO:~$ sudo apt-get install iputils-ping --reinstall
                                          [sudo] password for edi77:
                                          Building dependency tree... Done
                                          The following packages were automatically installed and are no longer required:
                                            g++-12 libassuan0 libavcodec59 libavdevice59 libavfilter8 libavformat59 libavutil57 libc-ares2 libcares2 libcodec2-1.0 libdav1d6 libdrm-nouveau2
                                            libdrm-radeon1 libepoxy0 libflac12 libgirepository-1.0-1 libglapi-mesa libjsoncpp25 libjxl0.7 libllvm15 libmbedcrypto7 libmfx1 libnl-3-200
                                            libnl-genl-3-200 libnsl-dev libplacebo208 libpostproc56 libpthread-stubs0-dev librav1e0 librhash0 libssh-gcrypt-4 libstdc++-12-dev libsvtav1enc1
                                            libswresample4 libswscale6 libtheora0 libtirpc-dev libvpx7 libx265-199 libxcb-dri2-0 node-busboy node-cjs-module-lexer node-undici node-xtend
                                            x11proto-core-dev
                                          Use 'sudo apt autoremove' to remove them.
                                          0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                                          Need to get 51.2 kB of archives.
                                          After this operation, 0 B of additional disk space will be used.
                                          Get:1 http://deb.debian.org/debian trixie/main amd64 iputils-ping amd64 3:20240905-3 [51.2 kB]
                                          Fetched 51.2 kB in 0s (612 kB/s)
                                          (Reading database ... 48784 files and directories currently installed.)
                                          Preparing to unpack .../iputils-ping_3%3a20240905-3_amd64.deb ...
                                          Unpacking iputils-ping (3:20240905-3) over (3:20240905-3) ...
                                          Setting up iputils-ping (3:20240905-3) ...
                                          Processing triggers for man-db (2.13.1-1) ...
                                          edi77@DebianIO:~$
                                          • Codierknecht
                                            Codierknecht Developer Most Active @OliverIO last edited by Codierknecht
                                            @oliverio sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                            Falsche Richtung. Nicht der "Server" verlangt SSL, sondern das Backup und mysqldump.
                                            Der Server bietet gar kein SSL an - daran stört sich mysqldump und damit das Backup. Aber erst seit dem Update.
                                            Edit
                                            Die mysqldump.cnf sieht wie folgt aus:
                                            [mysqldump]
                                            quick
                                            quote-names
                                            max_allowed_packet      = 16M
                                            1.2k
                                            81.1k
                                            192
                                            26318
