    3. Off Topic
    4. Pflege des Betriebssystems
    5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
      Thomas Braun Most Active @Ritter last edited by Thomas Braun
      @ritter
      Da stimmt doch irgendwas mit deiner sudo-Konfiguration nicht...
      sudo whoami
      sudo -H -u iobroker whoami
      liefert?
        Ritter @Thomas Braun last edited by
        @thomas-braun sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
        sudo whoami
        christian@NUC:~$ sudo whoami
        [sudo] Passwort für christian:
        root
        iobroker
        christian@NUC:~$
          @ritter
          Un jetzt?
          iob diag
            @thomas-braun ```
            ========== Start marking the full check here ===========
            Script v.2025-08-09
            *** BASE SYSTEM ***
            Operating System: Debian GNU/Linux 13 (trixie)
             Static hostname: NUC
                   Icon name: computer-desktop
                     Chassis: desktop 🖥️
                      Kernel: Linux 6.12.41+deb13-amd64
                Architecture: x86-64
             Hardware Vendor: Intel corporation
              Hardware Model: NUC6i3SYB
            Firmware Version: SYSKLi35.86A.0070.2019.0401.1729
               Firmware Date: Mon 2019-04-01
                Firmware Age: 6y 4month 2w 2d
            OS is similar to:
            model name      : Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz
            Docker          : false
            Virtualization  : none
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             17:33:31 up  2:16,  2 users,  load average: 1.39, 1.65, 1.36
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'trixie'!
            *** TIME AND TIMEZONES ***
                           Local time: Sat 2025-08-16 17:33:31 CEST
                       Universal time: Sat 2025-08-16 15:33:31 UTC
                             RTC time: Sat 2025-08-16 15:33:31
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            christian
            HOME=/home/christian
            GROUPS=christian adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
            js-controller is not running
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:             33G        837M         31G        4.3M        2.1G         32G
            Swap:           1.0G          0B        1.0G
            Total:           34G        837M         32G
            Active iob-Instances:   1
                    31993 M total memory
                      798 M used memory
                      290 M active memory
                     1208 M inactive memory
                    29686 M free memory
                      329 M buffer memory
                     1641 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            top - 17:33:31 up  2:16,  2 users,  load average: 1.28, 1.62, 1.35
            Tasks: 184 total,   1 running, 183 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  1.9 us,  3.8 sy,  0.0 ni, 94.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  31993.3 total,  29686.8 free,    798.2 used,   1970.8 buff/cache
            MiB Swap:    975.0 total,    975.0 free,      0.0 used.  31195.1 avail Mem
            *** FAILED SERVICES ***
              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
            * iobroker.service loaded failed failed ioBroker Server
            Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                    ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                    SUB    -> The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs   16G     0   16G   0% /dev
            tmpfs          tmpfs     3.2G  808K  3.2G   1% /run
            /dev/sda1      ext4      468G   62G  382G  14% /
            tmpfs          tmpfs      16G     0   16G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
            tmpfs          tmpfs      16G  3.1M   16G   1% /tmp
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
            tmpfs          tmpfs     3.2G  8.0K  3.2G   1% /run/user/1000
            [Sat Aug 16 15:17:16 2025] EXT4-fs (sda1): mounted filesystem 96448ee6-f182-4f61-a44e-5eb0f63f92f9 ro with ordered data mode. Quota mode: none.
            [Sat Aug 16 15:17:17 2025] EXT4-fs (sda1): re-mounted 96448ee6-f182-4f61-a44e-5eb0f63f92f9 r/w.
            Show mounted filesystems:
            TARGET SOURCE    FSTYPE OPTIONS
            /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
            /var:
            2.2G    /var/
            1.5G    /var/log/journal/08006622a09d4dd5b7dc7c548ff96709
            1.5G    /var/log
            566M    /var/cache
            Archived and active journals take up 1.4G in the file system.
            /opt/iobroker/backups:
            8.2G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.5G    /opt/iobroker/iobroker-data/
            1.2G    /opt/iobroker/iobroker-data/files
            308M    /opt/iobroker/iobroker-data/backup-objects
            287M    /opt/iobroker/iobroker-data/files/vis
            278M    /opt/iobroker/iobroker-data/files/vis/widgets
            49M     /opt/iobroker/iobroker-data/files/0_userdata.0/cam9.mp4
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            40M     /opt/iobroker/iobroker-data/objects.jsonl
            33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            *** ZigBee Settings ***
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v22.18.0
            /usr/bin/node           v22.18.0
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            /usr/bin/corepack       0.33.0
            nodejs:
              Installed: 22.18.0-1nodesource1
              Candidate: 22.18.0-1nodesource1
              Version table:
             *** 22.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 22.17.1-1nodesource1 1001
                 22.17.0-1nodesource1 1001
                 22.16.0-1nodesource1 1001
                 22.15.1-1nodesource1 1001
                 22.15.0-1nodesource1 1001
                 22.14.0-1nodesource1 1001
                 22.13.1-1nodesource1 1001
                 22.13.0-1nodesource1 1001
                 22.12.0-1nodesource1 1001
                 22.11.0-1nodesource1 1001
                 22.10.0-1nodesource1 1001
                 22.9.0-1nodesource1 1001
                 22.8.0-1nodesource1 1001
                 22.7.0-1nodesource1 1001
                 22.6.0-1nodesource1 1001
                 22.5.1-1nodesource1 1001
                 22.5.0-1nodesource1 1001
                 22.4.1-1nodesource1 1001
                 22.4.0-1nodesource1 1001
                 22.3.0-1nodesource1 1001
                 22.2.0-1nodesource1 1001
                 22.1.0-1nodesource1 1001
                 22.0.0-1nodesource1 1001
                 20.19.2+dfsg-1 500
                    500 http://deb.debian.org/debian trixie/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            Checking for nodejs vulnerability:
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            NUC                 NUC (version: 7.0.7, hostname: NUC           , alive, uptime: 8018)
            Core adapters versions
            js-controller:  7.0.7
            admin:          7.7.2
            javascript:     9.0.11
            nodejs modules from github:     8
            +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e98f7443e85ebe29d98d8d725640dd0a8a)
            +-- iobroker.pirate-weather@0.1.4 (git+ssh://git@github.com/ticaki/ioBroker.pirate-weather.git#f70e2e8f1968bfe65afabf792ca73253a19f8321)
            | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
            +-- iobroker.signifylights@1.0.0 (git+ssh://git@github.com/disaster123/ioBroker.signifylights.git#bb475662d63f1e39993c2b4e9fb395c29dcd1adc)
            | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
            +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de3ed1f6e3)
            +-- iobroker.xsense@0.0.12 (git+ssh://git@github.com/arteck/ioBroker.xsense.git#cae2e07ac3d59527f701426739ed0cf14afdd0de)
            +-- iobroker.yr@5.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.yr.git#dec7b7f69b3968a43a390e2b2a60391c2dca6b23)
            Adapter State
              system.adapter.accuweather.0            : accuweather           : NUC                                      -  enabled
              system.adapter.admin.0                  : admin                 : NUC                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alias-manager.0          : alias-manager         : NUC                                      - disabled
              system.adapter.backitup.0               : backitup              : NUC                                      -  enabled
              system.adapter.chromecast.0             : chromecast            : NUC                                      -  enabled
              system.adapter.daswetter.0              : daswetter             : NUC                                      -  enabled
              system.adapter.device-reminder.0        : device-reminder       : NUC                                      -  enabled
              system.adapter.device-watcher.0         : device-watcher        : NUC                                      -  enabled
              system.adapter.devices.0                : devices               : NUC                                      - disabled
              system.adapter.discovery.0              : discovery             : NUC                                      -  enabled
              system.adapter.drops-weather.0          : drops-weather         : NUC                                      - disabled
              system.adapter.dwd.0                    : dwd                   : NUC                                      -  enabled
              system.adapter.echarts.0                : echarts               : NUC                                      -  enabled
              system.adapter.email.0                  : email                 : NUC                                      -  enabled
              system.adapter.email.1                  : email                 : NUC                                      -  enabled
              system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: NUC                                      -  enabled
              system.adapter.enigma2.0                : enigma2               : NUC                                      -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUC                                      -  enabled
              system.adapter.feiertage.0              : feiertage             : NUC                                      -  enabled
              system.adapter.flot.0                   : flot                  : NUC                                      - disabled
              system.adapter.fullcalendar.0           : fullcalendar          : NUC                                      -  enabled
              system.adapter.habpanel.0               : habpanel              : NUC                                      - disabled
              system.adapter.hass.0                   : hass                  : NUC                                      -  enabled, port: 8123
              system.adapter.heizoel.0                : heizoel               : NUC                                      -  enabled
              system.adapter.history.0                : history               : NUC                                      -  enabled
              system.adapter.hm-rega.0                : hm-rega               : NUC                                      -  enabled
              system.adapter.hm-rpc.0                 : hm-rpc                : NUC                                      -  enabled, port: 3000
              system.adapter.hm-rpc.1                 : hm-rpc                : NUC                                      -  enabled, port: 4000
              system.adapter.hm-rpc.2                 : hm-rpc                : NUC                                      -  enabled, port: 5000
              system.adapter.hm-rpc.3                 : hm-rpc                : NUC                                      -  enabled, port: 5500
              system.adapter.homeconnect.0            : homeconnect           : NUC                                      -  enabled
              system.adapter.ical.0                   : ical                  : NUC                                      -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUC                                      - disabled
              system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: NUC                                      -  enabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : NUC                                      - disabled
              system.adapter.icons-freepic.0          : icons-freepic         : NUC                                      -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : NUC                                      - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : NUC                                      - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : NUC                                      - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUC                                      - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUC                                      - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: NUC                                      - disabled
              system.adapter.icons-smarthome.0        : icons-smarthome       : NUC                                      -  enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : NUC                                      - disabled
              system.adapter.iot.0                    : iot                   : NUC                                      -  enabled
              system.adapter.javascript.0             : javascript            : NUC                                      -  enabled
              system.adapter.klipper-moonraker.0      : klipper-moonraker     : NUC                                      - disabled
              system.adapter.linux-control.0          : linux-control         : NUC                                      -  enabled
              system.adapter.material.0               : material              : NUC                                      - disabled
              system.adapter.matter.0                 : matter                : NUC                                      -  enabled
              system.adapter.meross.0                 : meross                : NUC                                      - disabled
              system.adapter.meteoalarm.0             : meteoalarm            : NUC                                      -  enabled
              system.adapter.mobile.0                 : mobile                : NUC                                      - disabled
              system.adapter.mqtt.0                   : mqtt                  : NUC                                      -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.nina.0                   : nina                  : NUC                                      -  enabled
              system.adapter.node-red.0               : node-red              : NUC                                      - disabled, port: 1880, bind: 0.0.0.0
              system.adapter.odl.0                    : odl                   : NUC                                      -  enabled
              system.adapter.onkyo.0                  : onkyo                 : NUC                                      -  enabled
              system.adapter.onvif.0                  : onvif                 : NUC                                      -  enabled, port: 8000
              system.adapter.opendtu.0                : opendtu               : NUC                                      -  enabled
              system.adapter.openweathermap.0         : openweathermap        : NUC                                      -  enabled
              system.adapter.parser.0                 : parser                : NUC                                      -  enabled
              system.adapter.ping.0                   : ping                  : NUC                                      -  enabled
              system.adapter.pirate-weather.0         : pirate-weather        : NUC                                      - disabled
              system.adapter.places.0                 : places                : NUC                                      -  enabled
              system.adapter.pollenflug.0             : pollenflug            : NUC                                      -  enabled
              system.adapter.pushover.0               : pushover              : NUC                                      -  enabled
              system.adapter.reolink.0                : reolink               : NUC                                      -  enabled
              system.adapter.rickshaw.0               : rickshaw              : NUC                                      - disabled
              system.adapter.sainlogic.0              : sainlogic             : NUC                                      -  enabled, port: 45000, bind: 0.0.0.0
              system.adapter.samsung.0                : samsung               : NUC                                      -  enabled
              system.adapter.samsung_tizen.0          : samsung_tizen         : NUC                                      -  enabled, port: 8002
              system.adapter.sayit.0                  : sayit                 : NUC                                      -  enabled
              system.adapter.sayit.7                  : sayit                 : NUC                                      -  enabled
              system.adapter.scenes.0                 : scenes                : NUC                                      -  enabled
              system.adapter.scheduler.0              : scheduler             : NUC                                      -  enabled
              system.adapter.signifylights.0          : signifylights         : NUC                                      -  enabled
              system.adapter.simple-api.0             : simple-api            : NUC                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.socketio.0               : socketio              : NUC                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              system.adapter.sonoff.0                 : sonoff                : NUC                                      -  enabled, port: 1885, bind: 0.0.0.0
              system.adapter.statistics.0             : statistics            : NUC                                      -  enabled
              system.adapter.synology.0               : synology              : NUC                                      -  enabled, port: 5000
              system.adapter.tankerkoenig.0           : tankerkoenig          : NUC                                      -  enabled
              system.adapter.telegram.0               : telegram              : NUC                                      -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.telegram.1               : telegram              : NUC                                      -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : NUC                                      -  enabled
              system.adapter.text2command.1           : text2command          : NUC                                      -  enabled
              system.adapter.time-switch.0            : time-switch           : NUC                                      -  enabled
              system.adapter.tr-064.0                 : tr-064                : NUC                                      -  enabled
              system.adapter.trashschedule.0          : trashschedule         : NUC                                      -  enabled
              system.adapter.tuya.0                   : tuya                  : NUC                                      -  enabled
              system.adapter.vesync.0                 : vesync                : NUC                                      -  enabled
              system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: NUC                                      -  enabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : NUC                                      - disabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : NUC                                      - disabled
              system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: NUC                                      -  enabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: NUC                                      - disabled
              system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: NUC                                      -  enabled
              system.adapter.vis-2.0                  : vis-2                 : NUC                                      -  enabled
              system.adapter.vis-bars.0               : vis-bars              : NUC                                      - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : NUC                                      - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUC                                      - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : NUC                                      - disabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : NUC                                      -  enabled
              system.adapter.vis-history.0            : vis-history           : NUC                                      - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUC                                      - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : NUC                                      - disabled
              system.adapter.vis-inventwo.0           : vis-inventwo          : NUC                                      -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUC                                      - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : NUC                                      - disabled
              system.adapter.vis-keyboard.0           : vis-keyboard          : NUC                                      - disabled
              system.adapter.vis-map.0                : vis-map               : NUC                                      - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : NUC                                      - disabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : NUC                                      - disabled
              system.adapter.vis-material.0           : vis-material          : NUC                                      - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : NUC                                      - disabled
              system.adapter.vis-metro.0              : vis-metro             : NUC                                      - disabled
              system.adapter.vis-players.0            : vis-players           : NUC                                      - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : NUC                                      -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : NUC                                      - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUC                                      - disabled
              system.adapter.vis-weather.0            : vis-weather           : NUC                                      - disabled
              system.adapter.vis.0                    : vis                   : NUC                                      -  enabled
              system.adapter.weather-warnings.0       : weather-warnings      : NUC                                      -  enabled
              system.adapter.web.0                    : web                   : NUC                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.windows-control.0        : windows-control       : NUC                                      -  enabled
              system.adapter.wled.0                   : wled                  : NUC                                      -  enabled
              system.adapter.xsense.0                 : xsense                : NUC                                      -  enabled
              system.adapter.yamaha.0                 : yamaha                : NUC                                      -  enabled
              system.adapter.yr.0                     : yr                    : NUC                                      -  enabled
              system.adapter.zendure-solarflow.0      : zendure-solarflow     : NUC                                      -  enabled
              system.adapter.zigbee.0                 : zigbee                : NUC                                      -  enabled, port: tcp://192.168.1.49:6638
            + instance is alive
            ioBroker-Repositories
            │ (index) │ name          │ url        │ auto upgrade │
            │ 0       │ 'online'      │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
            │ 1       │ 'fast-online' │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
            │ 2       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
            │ 3       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
            Active repo(s): beta
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: beta
            Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
            Adapter    "admin"        : 7.7.2    , installed 7.7.2
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "device-watcher": 2.12.6  , installed 2.12.6
            Adapter    "devices"      : 1.2.8    , installed 1.2.8
            Adapter    "drops-weather": 1.2.7    , installed 1.2.7
            Adapter    "echarts"      : 2.0.6    , installed 2.0.6
            Adapter    "email"        : 2.0.4    , installed 2.0.4
            Adapter    "energiefluss-erweitert": 0.7.8, installed 0.7.8
            Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
            Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "hass"         : 1.4.0    , installed 1.4.0
            Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
            Adapter    "ical"         : 1.16.2   , installed 1.16.2
            Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
            Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
            Adapter    "iot"          : 3.6.0    , installed 3.6.0
            Adapter    "javascript"   : 9.0.11   , installed 9.0.11
            Controller "js-controller": 7.0.7    , installed 7.0.7
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "matter"       : 0.5.2    , installed 0.5.2
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "meteoalarm"   : 4.0.1    , installed 4.0.1
            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
            Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
            Adapter    "nina"         : 0.0.26   , installed 0.0.26
            Adapter    "node-red"     : 6.0.7    , installed 6.0.7
            Adapter    "odl"          : 5.0.0    , installed 5.0.0
            Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
            Adapter    "onvif"        : 1.1.4    , installed 1.1.4
            Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
            Adapter    "openweathermap": 1.4.0   , installed 1.4.0
            Adapter    "parser"       : 2.3.1    , installed 2.3.1
            Adapter    "ping"         : 1.7.9    , installed 1.7.9
            Adapter    "places"       : 1.3.0    , installed 1.3.0
            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "reolink"      : 1.2.3    , installed 1.2.3
            Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
            Adapter    "sainlogic"    : 0.12.1   , installed 0.12.1
            Adapter    "samsung"      : 0.6.1    , installed 0.6.1
            Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
            Adapter    "scenes"       : 4.0.3    , installed 4.0.3
            Adapter    "scheduler"    : 1.5.0    , installed 1.5.0
            Adapter    "signifylights": 1.0.0    , installed 1.0.0
            Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
            Adapter    "socketio"     : 7.0.8    , installed 7.0.8
            Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
            Adapter    "statistics"   : 4.0.0    , installed 4.0.0
            Adapter    "synology"     : 3.1.0    , installed 3.1.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "trashschedule": 4.0.1    , installed 4.0.1
            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
            Adapter    "vesync"       : 0.0.9    , installed 0.0.9
            Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
            Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
            Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
            Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
            Adapter    "vis-2-widgets-inventwo": 0.3.5, installed 0.3.5
            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
            Adapter    "vis-2-widgets-weather-and-heating": 1.1.1, installed 1.1.1
            Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
            Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
            Adapter    "vis-material" : 0.2.0    , installed 0.2.0
            Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
            Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
            Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
            Adapter    "web"          : 7.0.9    , installed 7.0.9
            Adapter    "windows-control": 0.1.5  , installed 0.1.5
            Adapter    "wled"         : 0.7.3    , installed 0.7.3
            Adapter    "ws"           : 3.0.19   , installed 3.0.19
            Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            Adapter    "zendure-solarflow": 2.0.1, installed 2.0.1
            Adapter    "zigbee"       : 3.0.3    , installed 3.0.3
            Objects and States
            Objects:        51148
            States:         38799
            W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
            Hit:1 http://security.debian.org/debian-security trixie-security InRelease
            Hit:2 http://deb.debian.org/debian trixie InRelease
            Hit:3 http://deb.debian.org/debian trixie-updates InRelease
            Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          854        935/exim4
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5832       766/sshd: /usr/sbin
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          855        935/exim4
            tcp6       0      0 :::8555                 :::*                    LISTEN      1000       9071       1751/go2rtc_linux_a
            tcp6       0      0 :::8554                 :::*                    LISTEN      1000       9067       1751/go2rtc_linux_a
            tcp6       0      0 :::22                   :::*                    LISTEN      0          5834       766/sshd: /usr/sbin
            tcp6       0      0 :::1984                 :::*                    LISTEN      1000       10692      1751/go2rtc_linux_a
            udp        0      0 192.168.1.31:8555       0.0.0.0:*                           1000       9075       1751/go2rtc_linux_a
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          816        626/dhclient
            udp6       0      0 2003:c5:8f45:2500::8555 :::*                                1000       9077       1751/go2rtc_linux_a
            udp6       0      0 fd8f:79ab:5076:0:b:8555 :::*                                1000       9076       1751/go2rtc_linux_a
            2025-08-16 17:31:16.378  - warn: host.NUC instance system.adapter.statistics.0 terminated due to SIGKILL
            2025-08-16 17:31:16.378  - info: host.NUC instance system.adapter.statistics.0 terminated with code null ()
            2025-08-16 17:31:16.470  - warn: host.NUC instance system.adapter.tankerkoenig.0 terminated due to SIGKILL
            2025-08-16 17:31:16.470  - info: host.NUC instance system.adapter.tankerkoenig.0 terminated with code null ()
            2025-08-16 17:31:16.471  - warn: host.NUC instance system.adapter.text2command.1 terminated due to SIGKILL
            2025-08-16 17:31:16.471  - info: host.NUC instance system.adapter.text2command.1 terminated with code null ()
            2025-08-16 17:31:16.491  - warn: host.NUC instance system.adapter.time-switch.0 terminated due to SIGKILL
            2025-08-16 17:31:16.491  - info: host.NUC instance system.adapter.time-switch.0 terminated with code null ()
            2025-08-16 17:31:16.511  - warn: host.NUC instance system.adapter.vis-2.0 terminated due to SIGKILL
            2025-08-16 17:31:16.511  - info: host.NUC instance system.adapter.vis-2.0 terminated with code null ()
            2025-08-16 17:31:16.548  - warn: host.NUC instance system.adapter.windows-control.0 terminated due to SIGKILL
            2025-08-16 17:31:16.548  - info: host.NUC instance system.adapter.windows-control.0 terminated with code null ()
            2025-08-16 17:31:16.588  - warn: host.NUC instance system.adapter.energiefluss-erweitert.0 terminated due to SIGKILL
            2025-08-16 17:31:16.588  - info: host.NUC instance system.adapter.energiefluss-erweitert.0 terminated with code null ()
            2025-08-16 17:31:16.588  - warn: host.NUC instance system.adapter.vesync.0 terminated due to SIGKILL
            2025-08-16 17:31:16.603  - info: host.NUC instance system.adapter.vesync.0 terminated with code null ()
            2025-08-16 17:31:17.187  - info: host.NUC instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
            2025-08-16 17:31:17.208  - info: host.NUC instance system.adapter.vis-inventwo.0 terminated while should be started once
            2025-08-16 17:31:17.237  - warn: host.NUC instance system.adapter.tuya.0 terminated due to SIGKILL
            2025-08-16 17:31:17.238  - info: host.NUC instance system.adapter.tuya.0 terminated with code null ()
            2025-08-16 17:31:17.258  - info: host.NUC instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
            2025-08-16 17:31:17.307  - info: host.NUC instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-08-16 17:31:17.307  - info: host.NUC instance system.adapter.matter.0 terminated with code 0 (NO_ERROR)
            2025-08-16 17:31:17.307  - info: host.NUC All instances are stopped.
            2025-08-16 17:31:17.375  - info: host.NUC terminated
            iob diag has finished.
            christian@NUC:~$
              @ritter
              Funktioniert also wieder.
                @thomas-braun Ja, es funktioniert jetzt. Vielen herzlichen Dank für deine Hilfe und Geduld und die super Anleitung für das upgrade.
                • Codierknecht
                  Codierknecht Developer Most Active last edited by Codierknecht
                  Prinzipiell hat das Upgrade dank @Thomas-Braun's detaillierter Anleitung problemlos funktioniert.
                  Zuerst vor dem offiziellen Release auf der Testkiste und dann - nachdem das einwandfrei geklappt hat - gestern auf dem Produktivsystem.
                  Allerdings lief heute Morgen das MySQL-Backup nicht mehr durch:
                  2025-08-16 02:40:25.969 - error: backitup.0 (483) [iobroker/mysql] Error: Command failed: mysqldump -u ioBroker -p**** ioBroker -h 192.168.178.51 -P 3306 > /opt/iobroker/backups/mysql_2025_08_16-02_40_25_backupiobroker.sql
                  2025-08-16 02:40:25.970 - error: backitup.0 (483) [iobroker/mysql] mysqldump: Got error: 2026: "TLS/SSL error: SSL is required, but the server does not support it" when trying to connect
                  2025-08-16 02:40:25.970 - error: backitup.0 (483) [iobroker] Error: Command failed: mysqldump -u ioBroker -p**** ioBroker -h 192.168.178.51 -P 3306 > /opt/iobroker/backups/mysql_2025_08_16-02_40_25_backupiobroker.sql
                  Der DB-Server läuft - genau wie der ioBroker - als LXC unter Proxmox. Das wurde gleichzeitig mit dem Upgrade des ioBroker auf PVE 9.0.5 gehoben.
                  An den LXC's selbst wurde nix weiter geändert.
                  Die Historisierung über den SQL-Adapter funktioniert ja auch weiterhin problemlos.
                  @simatec Was muss ich jetzt hier unternehmen? SSL brauche ich innerhalb meines lokalen Netzes nicht. Kann man dem Backup beibringen, die Option --skip-ssl zu verwenden?
                  • OliverIO
                    OliverIO @Codierknecht last edited by
                    @codierknecht
                    Die Frage ist, warum MySQL bei dir überhaupt SSL verlangt.
                    Normalerweise muss man das für den Server oder für den User Extra konfigurieren.
                    Schau mal in der Konfiguration einmal hier.
                    [mysqld]
                    require_secure_transport = ON
                    Oder in der Datenbank selbst
                    SELECT user, host, ssl_type
                    FROM mysql.user;
                    • Eduard77
                      Eduard77 @Dr. Bakterius last edited by
                      @dr-bakterius sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                      sudo apt-get install iputils-ping --reinstall
                      Tut mir leid, dass ich erst jetzt antworte.
                      Ich habe jetzt versucht nochmals mit deinem Code zu machen.
                      Hat wieder nichts gebracht.
                      edi77@DebianIO:~$ sudo apt-get install iputils-ping --reinstall
                      [sudo] password for edi77:
                      Reading package lists... Done
                      Building dependency tree... Done
                      The following packages were automatically installed and are no longer required:
                        g++-12 libassuan0 libavcodec59 libavdevice59 libavfilter8 libavformat59 libavutil57 libc-ares2 libcares2 libcodec2-1.0 libdav1d6 libdrm-nouveau2
                        libdrm-radeon1 libepoxy0 libflac12 libgirepository-1.0-1 libglapi-mesa libjsoncpp25 libjxl0.7 libllvm15 libmbedcrypto7 libmfx1 libnl-3-200
                        libnl-genl-3-200 libnsl-dev libplacebo208 libpostproc56 libpthread-stubs0-dev librav1e0 librhash0 libssh-gcrypt-4 libstdc++-12-dev libsvtav1enc1
                        libswresample4 libswscale6 libtheora0 libtirpc-dev libvpx7 libx265-199 libxcb-dri2-0 node-busboy node-cjs-module-lexer node-undici node-xtend
                        x11proto-core-dev
                      Use 'sudo apt autoremove' to remove them.
                      0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                      Need to get 51.2 kB of archives.
                      After this operation, 0 B of additional disk space will be used.
                      Get:1 http://deb.debian.org/debian trixie/main amd64 iputils-ping amd64 3:20240905-3 [51.2 kB]
                      Fetched 51.2 kB in 0s (612 kB/s)
                      (Reading database ... 48784 files and directories currently installed.)
                      Preparing to unpack .../iputils-ping_3%3a20240905-3_amd64.deb ...
                      Unpacking iputils-ping (3:20240905-3) over (3:20240905-3) ...
                      Setting up iputils-ping (3:20240905-3) ...
                      Processing triggers for man-db (2.13.1-1) ...
                      edi77@DebianIO:~$
                      • Codierknecht
                        Codierknecht Developer Most Active @OliverIO last edited by Codierknecht
                        @oliverio sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                        Falsche Richtung. Nicht der "Server" verlangt SSL, sondern das Backup und mysqldump.
                        Der Server bietet gar kein SSL an - daran stört sich mysqldump und damit das Backup. Aber erst seit dem Update.
                        Edit
                        Die mysqldump.cnf sieht wie folgt aus:
                        [mysqldump]
                        quick
                        quote-names
                        max_allowed_packet      = 16M
                        • Codierknecht
                          Codierknecht Developer Most Active @Codierknecht last edited by Codierknecht
                          @codierknecht sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                          Ich hab's hinbekommen 😄
                          Die config muss (auf der ioBroker-Seite) so aussehen:
                          [mysqldump]
                          quick
                          quote-names
                          ssl = 0
                          Siggi0904 1 Reply Last reply Reply Quote 2
                            cbrocker last edited by
                            Ähnliches macht man mit veralteten und lokal erzeugten Pakten nach Möglichkeit.
                            apt list '~o'
                            sudo apt purge '~o'
                            sudo apt --purge autoremove
                            sudo apt autoclean
                            Hallo, das Upgrade auf Trixie lief astrein durch.
                            Wenn ich das apt list '~o' eingebe, kommt bei mir u.a.:
                            grafana-enterprise/now 12.1.1 amd64  [Installiert,lokal]
                            Das möchte ich natürlich behalten.
                            Kann ich das aus --purge autoremove ausschließen oder
                            die o.g. Befehle einfach überspringen?
                            Ist ja nichts, was man unbedingt machen müsste?
                            Christoph
                              Thomas Braun Most Active @cbrocker last edited by Thomas Braun
                              @cbrocker sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                              Nein, du möchtest eher auf das Paket grafana umsteigen
                              Und du möchtest schauen, warum das als lokal installiert angezeigt wird.
                              grafana-Repository nicht aktiv?
                                cbrocker @Thomas Braun last edited by
                                Grafana aktualisiere ich immer manuell mit
                                wget https://dl.grafana.com/grafana-enterprise/release/12.1.1/grafana-enterprise_12.1.1_16903967602_linux_amd64.deb
                                sudo dpkg -i grafana-enterprise_12.1.1_16903967602_linux_amd64.deb
                                habe das nicht in der Repository.
                                Was ist der Unterschied zwischen grafana und grafana-enterprise?
                                  Solltest du aber machen und die Finger von manuellen Installationen lassen.
                                  Das löst dir nämlich auch Abhängigkeiten auf und du wirst auch über neue Releases informiert.
                                  grafana-enterprise ist das kommerzielle Angebot für Unternehmen:
                                  Grafana Enterprise:
                                  Commercial offering: Requires a paid license after the trial period.
                                  C D 2 Replies Last reply Reply Quote 1
                                    klar, über Repo ist es auch bequemer.
                                    Ich nutze die Enterprise schon seit 2-3 Jahren,
                                    die eingeschränkte Version ist free:
                                    The Enterprise Edition is the default and recommended edition. It includes all the features of the OSS Edition, can be used for free and can be upgraded to the full Enterprise feature set, including support for Enterprise plugins.
                                    ok, danke für die Hinweise.
                                    Werde ich in die Repo einbauen.
                                      Dieter_P @Thomas Braun last edited by
                                      Danke hat für ein debian 12.11 auf einem Firebat T8 Pro ohne jeglichen Hürden so funktioniert und läuft.
                                      • Matzebhv
                                        Matzebhv last edited by
                                        Hier auch erledigt.
                                        root@iOBroker:/home/iobroker# lsb_release -a
                                        No LSB modules are available.
                                        Distributor ID: Debian
                                        Description: Debian GNU/Linux 13 (trixie)
                                        Release: 13
                                        Codename: trixie
                                          lessthanmore @Matzebhv last edited by
                                          @matzebhv said in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                          root@
                                          Na lass das mal nicht @Thomas-Braun sehen 😄
                                          Thomas Braun 1 Reply Last reply Reply Quote 2
                                            Thomas Braun Most Active @lessthanmore last edited by
                                            @lessthanmore sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                            Hab ich schon heute Vormittag gesehen...
                                            teletapi 1 Reply Last reply Reply Quote 0
                                            1.0k
                                            81.1k
                                            192
                                            26259
