    4. Tuya Adapter V 3.16.0 Instanz bleibt rot
      FS1567 last edited by Samson71
      Mein io-Broker läuft als Docker in einer Synology Nas.
      Der installierte Tuya Adapter zeigt folgendes:
      danach ein Login zum Cloud geht jetzt erstmalig:
      Dbug Log:
      tuya.0
      	2025-08-15 17:47:41.337	info	bf10c708588fe2f665pgtk: Connect locally to device
      tuya.0
      	2025-08-15 17:47:41.294	info	bf8009fd481520527b87z0: Connect locally to device
      tuya.0
      	2025-08-15 17:47:40.384	info	bf609dad6ee86ab803yfhc: Connect locally to device
      tuya.0
      	2025-08-15 17:47:39.965	info	IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
      tuya.0
      	2025-08-15 17:47:39.739	info	Listen for encrypted local Tuya devices on port 6667
      tuya.0
      	2025-08-15 17:47:39.738	info	Listen for local Tuya devices on port 6666
      tuya.0
      	2025-08-15 17:47:39.532	info	Try to sync devices from Cloud using stored cloud credentials
      tuya.0
      	2025-08-15 17:47:39.529	info	Existing devices initialized
      tuya.0
      	2025-08-15 17:47:39.528	info	bf609dad6ee86ab803yfhc: Connect locally to device
      tuya.0
      	2025-08-15 17:47:39.527	info	bf10c708588fe2f665pgtk: Connect locally to device
      tuya.0
      	2025-08-15 17:47:39.487	info	bf8009fd481520527b87z0: Connect locally to device
      tuya.0
      	2025-08-15 17:47:38.552	info	starting. Version 3.16.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v22.18.0, js-controller: 7.0.6
      host.buanet-iobroker
      	2025-08-15 17:47:36.414	info	instance system.adapter.tuya.0 in version "3.16.0" started with pid 11037
      	2025-08-15 17:47:28.621	info	instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      tuya.0
      	2025-08-15 17:47:28.080	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      tuya.0
      	2025-08-15 17:47:28.079	info	terminating
      	2025-08-15 17:47:25.114	info	stopInstance system.adapter.tuya.0 send kill signal
      tuya.0
      	2025-08-15 17:47:25.076	info	Got terminate signal TERMINATE_YOURSELF
      	2025-08-15 17:47:25.073	info	stopInstance system.adapter.tuya.0 (force=false, process=true)
      tuya.0
      	2025-08-15 17:47:25.064	info	Set data for tuya.0 to appDeviceId=hwihbsdshylho8a4qt0dtjhfvi555113rux8psesml61 / sid=eu175033N2830543eq4dzkm3ddf409efd1973b2032d1820836b12d0b. Restart adapter now!
      tuya.0
      	2025-08-15 17:47:25.064	info	Cloud login successful. Adapter restarts in 5s
      tuya.0
      	2025-08-15 17:47:22.142	info	Listen for encrypted local Tuya devices on port 6667
      tuya.0
      	2025-08-15 17:47:22.141	info	Listen for local Tuya devices on port 6666
      tuya.0
      	2025-08-15 17:47:21.942	info	Try to sync devices from Cloud using stored cloud credentials
      tuya.0
      	2025-08-15 17:47:21.939	info	Existing devices initialized
      tuya.0
      	2025-08-15 17:47:21.938	info	bf609dad6ee86ab803yfhc: Connect locally to device
      tuya.0
      	2025-08-15 17:47:21.933	info	bf10c708588fe2f665pgtk: Connect locally to device
      tuya.0
      	2025-08-15 17:47:21.888	info	bf8009fd481520527b87z0: Connect locally to device
      tuya.0
      	2025-08-15 17:47:21.013	info	starting. Version 3.16.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v22.18.0, js-controller: 7.0.6
      die Daten werden im Objekt-bereich angezeigt:
      Frage:
      wie bekomm ich verbunden mit Gerät auf Grün, wenn doch Objekte angezeigt werden und lokal alles Verbunden ist?
      Was mach ich falsch??
      Mod-Edit
      Bitte Code-Tags </> benutzen!
      Thomas Braun C 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @FS1567 last edited by
        @fs1567
        Dürfte damit zusammen hängen:
        tuya.0
          CatShape @FS1567 last edited by CatShape
          @fs1567
          Ich würde Dir empfehlen, das zu machen, was in den Adapter-Instanzeinstellungen steht:
          Ich vermute, dass der Adapter den jeweiligen "localKey" Deiner Geräte nicht kennt, oder einen veralteten/ungültigen gespeichert hat. Um die aktuellen "localKeys" zu erhalten, musst Du eben in den Instanz-Einstellungen die Geräte einmalig mit der Cloud synchronisieren.
          Ich glaube der "localKey" von einem Tuya-Gerät ist nur solange gültig bis Du das Gerät resettest und/oder neu in die Tuya-App einbindest. Beim ausführen einer solchen Aktion bekommt das Gerät einen neuen "localKey". Und deshalb muss sich der Adapter nach einer solchen Aktion diesen neuen "localKey" auch erstmal wieder aus der Cloud besorgen.
            FS1567 @CatShape last edited by
            @catshape
            Danke für die Antwort
            hab ich gemacht, mit Erfolg, aber keine Wirkung auf die Instanz!
              FS1567 @Thomas Braun last edited by
              Hallo Thomas, das ist auch meine Befürchtung, aber
              • wo
              • wie
              kann ich den IOT Coud ITSecret "configurieren"
              Die Smart Live App zeigt mir die Geräte an und ich kann sie damit bedienen
              Die Zugangsdaten hab ich im Tya Adapter eingegeben und er ruft die Daten auch von dort ab.
              Also was ist das?
              Habe gestern nochmals den Adapter deinstalliert und neu installiert, gleicher Fehler wieder.
              Bin für jede Hilfe dankbar
                @fs1567
                Mal in die ReadMe geschaut?
                https://www.iobroker.net/#en/adapters/adapterref/iobroker.tuya/README.md
                  Danke für den Link, hab ich schon 4 mal gelesen.
                  Also ich habe aktuell installiert (zur Probe) bevor ich alles anschließe:
                  1. Wi-Fi IR + FR Remote Controller 1 x
                  2. Tuya Smart Plug WiFi Steckdose 16A mit Power Messung 1 x
                  weitere 6 liegen hier zum Anschließen wenn es denn geht.
                  so hier die Objekt-Daten des smartPlugin Netzsteckers:
                  Local connect flase ist richtig, da ich die Ports im Docker nicht freigegeben habe. --> hilft das?
                  Zeigt er mir dehalb keine IP-Adresse an?
                    @fs1567
                    Zu Docker sag ich nichts...
                    Da sind die Netzwerkeinstellungen ggfls. ganz anders als in 'richtigen' Systemen.
                      Sorry,
                      die Frage war ob ich local Ports wirklich freigeben muss?
                      Bei meinen HomeMatic IP Geräten von der Markise funzt alles und die läuft im gleichen Docker auf der NAS
                      hab nen Neustart gemacht und bei Tuya bleibt alles beim alten:
                        so ich kann euch die Lösung nennen:
                        Für Tyua zusätzlich die Ports 6666 / 6667 TCP/UDP freigeben
                        Achtung : es müssen beide Ports sein und auch UDP
                        Danach logischerweise auch noch die Firewall des Gerätes dafür freischalten
                        Leidr kann ich gerade kein Bild hochladen
                        Danke für die Anregungen
                        • haselchen
                          haselchen Most Active @FS1567 last edited by
                          @fs1567
                          Du hast also eine Bridge Installation …. Gut zu wissen
                            FS1567 @haselchen last edited by
                            @haselchen
                            Gut erkannt,
                            möchte es auf MC-VLAN umstellen, ist aber komplex,
                            der NAS hat 4 Netzanschlüsse als Bond, den Bond stelle ich gerade um auf BOND mit 8 VLAN über die Console; auf dem NAS laufen auch 4 Docker Container, also Netztrennung auf dem NAS
                            also wenn du mir ein gutes Tutorial für MC-VLAN bei der Konstellation hast bin ich dankbar (sind noch 4 Cisco Switche und 3 weiter NAS im Netz)
                            • haselchen
                              haselchen Most Active @FS1567 last edited by haselchen
                              @fs1567 sagte in Tuya Adapter V 3.16.0 Instanz bleibt rot:
                              Bei dem Vorhaben können Dir bestimmt andere eingefleischte Dockerfans helfen.
                              Aber aus reiner Neugier, wenn ich das richtig gelesen habe , hast Du 4 Container und betreibst einen Aufwand , als wenn Du ein Unternehmen führst .
                              Worin liegt der Ansporn?
                              Wenn das alles Bridge Installationen sind, musste Du manuell bei jedem Container die Ports freigeben.
                              Edit: bestes Beispiel dieser Thread hier von Dir
                              337
