    4. Kein öffnen von Iobroker oder Grafana möglich
      sral74 @Thomas Braun last edited by
      @thomas-braun ========== Start marking the full check here ===========
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.6.60-v8+
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       15:13:49 up 7 min,  4 users,  load average: 7.96, 8.61, 4.27
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-08-17 15:13:50 CEST
                 Universal time: Sun 2025-08-17 13:13:50 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      lars
      HOME=/home/lars
      GROUPS=lars adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         true
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:                tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            951M        675M         52M        786K        283M        275M
      Swap:           1.0G        535M        512M
      Total:          2.0G        1.2G        565M
      Active iob-Instances:   10
                907 M total memory
                643 M used memory
                392 M active memory
                353 M inactive memory
                 50 M free memory
                 15 M buffer memory
                254 M swap cache
                999 M total swap
                511 M used swap
                488 M free swap
      top - 15:14:00 up 7 min,  4 users,  load average: 7.42, 8.46, 4.29
      Tasks: 212 total,   2 running, 210 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 22.6 us,  5.7 sy,  0.0 ni, 24.5 id, 47.2 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :    907.2 total,     50.7 free,    643.5 used,    270.4 buff/cache
      MiB Swap:   1000.0 total,    487.7 free,    512.3 used.    263.8 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  315M     0  315M   0% /dev
      tmpfs          tmpfs      91M  1.3M   90M   2% /run
      /dev/sda2      ext4      917G   18G  860G   2% /
      tmpfs          tmpfs     454M  148K  454M   1% /dev/shm
      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
      /dev/sda1      vfat      510M   76M  435M  15% /boot/firmware
      tmpfs          tmpfs      91M   48K   91M   1% /run/user/1000
      [Sun Aug 17 15:06:30 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0f3ec0cf-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Sun Aug 17 15:06:41 2025] EXT4-fs (sda2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
      [Sun Aug 17 15:06:45 2025] EXT4-fs (sda2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET               SOURCE    FSTYPE      OPTIONS
      /                    /dev/sda2 ext4        rw,noatime
      |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.6G    /var/
      1.1G    /var/log/journal/29fe04dc9ad1405bac943853674cdaa0
      1.1G    /var/log
      383M    /var/lib
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      8.6G    /opt/iobroker/backups/
      13M     /opt/iobroker/backups/influxDB_2025_05_28-02_40_47_backupiobroker
      4.0K    /opt/iobroker/backups/influxDB_2025_07_24-02_40_46_backupiobroker
      /opt/iobroker/iobroker-data:
      177M    /opt/iobroker/iobroker-data/
      94M     /opt/iobroker/iobroker-data/files
      46M     /opt/iobroker/iobroker-data/backup-objects
      33M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      12M     /opt/iobroker/iobroker-data/states.jsonl
      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.19.4-1nodesource1
        Version table:
           20.19.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.19.3-1nodesource1 1001
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
       *** 20.18.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      The current Node.js version (v20.18.0) is vulnerable to the following CVEs:
      CVE-2025-23083(high): With the aid of the diagnostics_channel utility, an event can be hooked into whenever a worker thread is created. This is not limited only to workers but also exposes internal workers, where an instance of them can be fetched, and its constructor can be grabbed and reinstated for malicious usage.
      This vulnerability affects Permission Model users (--permission) on Node.js v20, v22, and v23.
      Patched versions: ^20.18.2 || ^22.13.1 || ^23.6.1
      CVE-2025-23085(medium): A memory leak could occur when a remote peer abruptly closes the socket without sending a GOAWAY notification. Additionally, if an invalid header was detected by nghttp2, causing the connection to be terminated by the peer, the same leak was triggered. This flaw could lead to increased memory consumption and potential denial of service under certain conditions.
      This vulnerability affects HTTP/2 Server users on Node.js v18.x, v20.x, v22.x and v23.x.
      Patched versions: ^18.20.6 || ^20.18.2 || ^22.13.1 || ^23.6.1
      CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
      Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
      CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
      This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
      The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
      Impact:
      * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 447)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
      + system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.1.5  [Updatable]
      Adapter    "backitup"     : 3.3.5    , installed 3.0.25 [Updatable]
      Controller "js-controller": 7.0.7    , installed 7.0.3  [Updatable]
      Adapter    "mielecloudservice": 6.5.10, installed 6.5.7 [Updatable]
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "rpi2"         : 2.4.0    , installed 2.2.1  [Updatable]
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Objects and States
      Objects:        7324
      States:         5652
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 307
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6025       720/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8779       723/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8782       723/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          888        787/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      113        7817       722/influxd
      tcp6       0      0 :::3000                 :::*                    LISTEN      112        11269      1235/grafana
      tcp6       0      0 :::8086                 :::*                    LISTEN      113        8604       722/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11946      2899/io.admin.0
      tcp6       0      0 :::5900                 :::*                    LISTEN      992        10315      747/wayvnc
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6024       720/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          890        787/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7696       580/avahi-daemon: r
      udp        0      0 0.0.0.0:49039           0.0.0.0:*                           104        7698       580/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        7697       580/avahi-daemon: r
      udp6       0      0 :::51123                :::*                                104        7699       580/avahi-daemon: r
      udp6       0      0 fe80::ee01:c2a6:1f2:546 :::*                                0          6640       682/NetworkManager
      2025-08-17 15:14:47.850  - error: modbus.1 (2843) Socket Error
      2025-08-17 15:14:47.862  - error: modbus.1 (2843) Client in error state.
      2025-08-17 15:14:47.863  - warn: modbus.1 (2843) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
      2025-08-17 15:14:48.875  - info: modbus.1 (2843) Disconnected from slave 192.168.2.163
      2025-08-17 15:14:55.891  - info: smartmeter.1 (2924) Error: No or too long answer from Serial Device after last request.
      2025-08-17 15:14:55.913  - warn: smartmeter.1 (2924) No or too long answer from Serial Device after last request.
      2025-08-17 15:14:56.653  - info: smartmeter.0 (2923) Error: No or too long answer from Serial Device after last request.
      2025-08-17 15:14:56.655  - warn: smartmeter.0 (2923) No or too long answer from Serial Device after last request.
      2025-08-17 15:15:26.067  - info: smartmeter.1 (2924) Error: No or too long answer from Serial Device after last request.
      2025-08-17 15:15:26.069  - warn: smartmeter.1 (2924) No or too long answer from Serial Device after last request.
      2025-08-17 15:15:26.663  - info: smartmeter.0 (2923) Error: No or too long answer from Serial Device after last request.
      2025-08-17 15:15:26.665  - warn: smartmeter.0 (2923) No or too long answer from Serial Device after last request.
      2025-08-17 15:15:48.884  - info: modbus.1 (2843) Connected to slave 192.168.2.163
      2025-08-17 15:15:48.937  - error: modbus.1 (2843) Socket Error
      2025-08-17 15:15:48.938  - error: modbus.1 (2843) Client in error state.
      2025-08-17 15:15:48.939  - warn: modbus.1 (2843) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
      2025-08-17 15:15:49.953  - info: modbus.1 (2843) Disconnected from slave 192.168.2.163
      2025-08-17 15:15:56.371  - info: smartmeter.1 (2924) Error: No or too long answer from Serial Device after last request.
      2025-08-17 15:15:56.433  - warn: smartmeter.1 (2924) No or too long answer from Serial Device after last request.
      2025-08-17 15:15:56.863  - info: smartmeter.0 (2923) Error: No or too long answer from Serial Device after last request.
      2025-08-17 15:15:57.047  - warn: smartmeter.0 (2923) No or too long answer from Serial Device after last request.
      2025-08-17 15:16:26.462  - info: smartmeter.1 (2924) Error: No or too long answer from Serial Device after last request.
      2025-08-17 15:16:26.463  - warn: smartmeter.1 (2924) No or too long answer from Serial Device after last request.
      2025-08-17 15:16:27.060  - info: smartmeter.0 (2923) Error: No or too long answer from Serial Device after last request.
      2025-08-17 15:16:27.062  - warn: smartmeter.0 (2923) No or too long answer from Serial Device after last request.
        sral74 @crunchip last edited by
        @crunchip stimmt, das war schonmal thema. was ihr alles findet :-D, Sorry
          Thomas Braun Most Active @sral74 last edited by Thomas Braun
          @sral74 sagte in Kein öffnen von Iobroker oder Grafana möglich:
          Ein laufender Desktop bricht dir auf dem kleinen System ohnehin schon direkt das Genick.
          Schalt den MIST AUS!!!! Hat im Serverbetrieb nix zu suchen.
          Sieht man auch am load:
          System insgesamt alles nicht auf Stand.
          Also Desktop ausknipsen, alles updaten (und zwar ALLES!), davon ein Backup mittels Backitup-Adapter ziehen und mit dem Backup auf ein aktuelles System umziehen.
            sral74 @Thomas Braun last edited by sral74
            @thomas-braun wie "knipse" ich den desktop aus?
            Danke für deine mega schnellen Rückmeldungen auch am Sonntag 🙂
            Hab mir einen 5er bestellt mit 8GB RAM der sollte doch dann ok sein?!
            Thomas Braun haselchen Homoran 4 Replies Last reply Reply Quote 0
              @sral74
              Wird dir u. a. auch bei
              iob stop
              iob fix
              angeboten. Danach dann die Kiste einmal durchstarten.
                Ja, aber auch den hält man schlank. Installier da also die Raspberry OS 'Lite' 64Bit Version auf dem Ding.
                • haselchen
                  haselchen Most Active @sral74 last edited by
                  @sral74
                  Wenn Du nur datteln willst , ist das mehr als okay .
                  Wenn’s Smartphonemäßig mehr werden sollte , würde ich bei Ebay nen Desk PC schiessen für 40-50€ und selber aufrüsten .
                  Bist dann fast beim gleichen Preis wie der Raspi , aber flexibel .
                    sral74 @haselchen last edited by
                    @haselchen ich frage damit eigentlich nur ein paar Heizungsdaten, PV Daten und Stromdaten ab.
                      crunchip Forum Testing Most Active @sral74 last edited by
                      @sral74 sind ja recht übersichtlich deine Beiträge😉 und da war auch letzter Stand, kein Desktop installiert.
                      Somit wurde seit 9.nov (is noch Lang kein ganzes Jahr) zwischenzeitlich ne neue Installation angestoßen
                      • haselchen
                        @sral74
                        Wenn Du dann schon ca. 100€ fürn Raspi mit allem Drum und Dran kaufen willst , würde ich auf die flexible Lösung setzen.
                        S Thomas Braun 2 Replies Last reply Reply Quote 0
                          @haselchen Du würdest dann auf nen z.B. NUC PC gehen?
                            Thomas Braun Most Active @haselchen last edited by
                            @haselchen sagte in Kein öffnen von Iobroker oder Grafana möglich:
                            @sral74
                            Das Thema ist doch schon durch:
                            Und so platt kann man das auch nicht sage, das ein Pi5/8GB 'nur zum daddeln taugt...'.
                            haselchen 1 Reply Last reply Reply Quote 1
                            • haselchen
                              haselchen Most Active @Thomas Braun last edited by haselchen
                              @sral74
                              Wäre auch OT, hast recht.
                              Schließen wir das Kaufthema ab.
                                Homoran Global Moderator Administrators @sral74 last edited by
                                Tut er!
                                nee, ehrlich?
                                der 5er reicht allemal
                                • haselchen
                                  haselchen Most Active @Homoran last edited by
                                  Ok, dann doch nochmal kurz OT 😁
                                  Natürlich reicht der 5er.
                                  Da ich aber die Ziele und Wünsche für die Zukunft des TE nicht kenne , habe ich ein „Bastelsystem“ vorgeschlagen, um flexibel zu bleiben.
                                  Ob er nun 100€ für den Raspi oder den Desk PC ausgibt ……
                                    @thomas-braun soo, hab jetzt Desktop aus. System upgedated. Kann mich allerdings über ssh nicht mehr anmelden?! Wenn ich direkt über den rasp reingehe scheint alles zu laufen (htop) nur wird auch der Befehl iob diag nicht ausgeführt. (Es passiert nichts, auch kein Fehler)
                                    ... SSH geht wieder war in der config wieder deaktiviert
                                      Doch, aber die Fehlermeldungen werden unterdrückt.
                                      ls -l /home/
                                      sagt?
                                        @thomas-braun ich gebe auf, ich warte bis das neue Teil da ist und setze alles neu auf.
                                        Aber danke für die Hilfe
                                          @sral74
                                          Hast du denn nun ein aktuelles Backup?
                                            @thomas-braun habe nur Backup von Influxdb und Iobroker aber nicht vom grafana Dashboard
                                            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                            grafana
                                            1066
