    4. Proxmox-Updater (Host/LXC/VM) auch ioBroker,piHole,etc
    • Bass-T
      Bass-T last edited by Bass-T
      v4.1 released
      !! Because of name and directory changing, you need an restart of the node, after update !!
      Extras:
      • name changing ("Proxmox Updater" is now "The Ultimate Updater for Proxmox VE")
      • disable/enable Snapshots and Backups in config file
      • set, how many snapshots will be keep, in config file
      • delete old (Update_) snapshots
      • move program to correct folder system
      • edit config file, for better usage
      • update-check can now be better set (in config file)
      • support Docker Compose v1 and v2
      Fixed:
      • bug fixing
      • Bass-T
        v4.2 released
        Extras:
        • rebuild waiting for VM start (could now be set in config file)
        Fixed:
        • VM Template error
        • Unifi-Controller Container
        • FreeBSD VM error
        • docker compose
        • node hopping without welcome screen installed
        • Bass-T
          v4.3 released
          https://github.com/BassT23/Proxmox
          • add freebsd VM (QEMU and SSH Connection)
          • add non root user update in VMs
          • add autoclean for debian based systems
          • add filesystem trim for ext4 systems
          • add curl for internet check
          • add env settings for arch in config file
          • add kernel kleaning (disabled by default in config file)
          • fix run for only one LXC/VM with update <ID>
          • fix ioBroker Upgrade
          • fix arch upgrade
          • fix START/STOP/WAITING for stopped VMs
          • fix compatibility with "old" ssh connection
          • fix IP output by nodes
          • fix fedora autoremove
          • fix missing kernel infos
          • fix template detection
          • fix internet check
          • modify config file - checker settings now on the buttom
          • modify version check - check now all branches
          • code cleaning
            A Former User @Bass-T last edited by
            @bass-t sagte in Proxmox-Updater (Host/LXC/VM) auch ioBroker,piHole,etc:
            @da_woody wir hatten es ja nur von der Proxmox Umgebung 😜
            Das hier wäre dann mein gesamtes Netz:
            und über 30 Zigbee Geräte 🤔
            Mit welcher Software hast du diese Grafik gemacht?
            Bass-T 1 Reply Last reply Reply Quote 0
            • Bass-T
              Bass-T @Guest last edited by Bass-T
              @neuschwansteini zabbix
              Hilft mir bei der Visualisierung und host Überwachung.
              EDIT:
              läuft in einer extra "monitoring" LXC.
              Ich war es leid fehlerhafte Rechner zu "suchen".
              Zabbix ist gratis und sendet per (ua.) telegram bot Nachrichten, falls Probleme auflaufen.
              • Bass-T
                Extras:
                • add symbolic
                • add user scripts folder
                • add "error hopping option" in config file
                • add LXC start delay option in config file
                • add "update" command for "Proxmox VE Helper-Scripts" in extra section
                • FreeBSD is disabled by default in config file
                • modify "update <ID>" - disable skip output
                • code cleaning
                Fixed:
                • fix docker-compose v2 skipping
                • fix YUM Update - used now only for centos
                • fix VM shutdown errors
                Master67 1 Reply Last reply Reply Quote 0
                • Master67
                  Master67 @Bass-T last edited by Master67
                  @bass-t Danke für deine Arbeit, das Script nimmt mir wirklich was an Arbeit ab 🙂
                  Bass-T 1 Reply Last reply Reply Quote 1
                  • Bass-T
                    Bass-T @Master67 last edited by
                    @master67 sehr gerne.
                    Mit dem neuen Update ist jetzt auch ein "Error-Hopping" drin.
                    Das Script bricht nun bei error nicht mehr ab, sondern bricht nur die LXC/VM ab und macht beim nächsten weiter.
                    Am Ende bekommst du ein log mit Fehlern.
                    Diese fehlerhaften dann am besten mit "update <ID>" nochmal separat updaten. Immer nur einen. Somit kommen auch interactive abfragen 😉
                    Viel spass beim Updaten 🙂
                    • Bass-T
                      💪 👍 !!! Vielen Dank für 10k downloads !!! 👍💪
                      • Bass-T
                        Hi @ll
                        ich habe ein neues update für alle (beta stage)
                        Bitte Testen und feedback da lassen 😉
                        update beta -up
                        Es gibt massig grafische Upgrades und coole Features 🙂
                        • "only" or "exclude" LXC/VM by ID/TAG/range #thx to @AdamSutch
                        • add debug mode (can be enabled in config file)
                        • add check-updates command update -check
                        • add email notification after update
                        • add better email notification for update-check
                        • add more symbolic
                        • add LXC template detection
                        • check "paused" VMs during update-check and bring them back in pause
                        • fix #203 Error on apt clean
                        • fix unsupported neofetch under trixie - change to screenfetch
                        • fix #201 (abbort after template detection)
                        • fix VM ID in error-log-file
                        • fix shell check
                        • fix typo
                        • code cleaning
                        T 1 Reply Last reply Reply Quote 3
                          TT-Tom @Bass-T last edited by
                          @bass-t
                          hallo, kann ich irgendwo das format der Email beeinflussen, aktuell sieht es bei mir so aus. Ich nutze hier Apple (iMac)
                          Host : proxmox1
                          S: 2 / N: 2
                          LXC 103 : mosquitto
                          N: 2
                          LXC 104 : nodered
                          N: 2
                          Host : proxmox2
                          S: 2 / N: 2
                          • Bass-T
                            Bass-T @TT-Tom last edited by
                            @tt-tom ja, mit v4.5 ist das geändert 😉
                            • Bass-T
                              v4.5 released
                              NEU:
                              • add LXC debian trixie upgrade (update -dist-upgrade)
                              • add more symbolic
                              FIX:
                              • fix shell check
                              • fix typo
                              • code cleaning
                              da_Woody 1 Reply Last reply Reply Quote 2
                              • da_Woody
                                da_Woody @Bass-T last edited by
                                @bass-t ich weis nicht, ob ich zu dumm bin. ich bekomm jetzt 2x täglich (07:01 und 19:01) eine mail mit "No updates found during search"
                                früher kam nur ne mail, wenn updates zur verfügung standen.
                                wenn keine updates anstehn nervt das.
                                • Bass-T
                                  Bass-T @da_Woody last edited by Bass-T
                                  @da_woody früher kam die meldung auch immer, aber mit doofen text. Auslöser ist/war cron.
                                  Cron ist nun still gelegt, und die Nachricht wird jetzt bereinigt und geschickt.
                                  Wenn jetzt mit der letzten beta und dem neuen 4.5 von heute keine updates gefunden werden sollte:
                                  per email kommen.
                                  Ich könnte das mit einer Variablen in der config file ändern. Soll ich 😉
                                  Alternativ passe die cron zeiten in /etc/crontab an, dann machst du den check vielleicht nur noch 1x am Tag /Woche 😉
                                  Zeile ist hier:
                                  00 07,19 * * *  root    update -check >/dev/null 2>&1
                                  EDIT:
                                  send email if no updates available
                                  EMAIL_NO_UPDATES="true"
                                  ist im neusten develop jetzt drin - wird mit dem nächsten release kommen 😉
                                  • Bass-T
                                    v4.5.2 released
                                    • add Backup when Snapshot is not available #204
                                    • fix fs-trim
                                    • fix "error code 1" on start
                                    • fix #188 error during helper-script update
                                    • fix ssh connection during check
                                    • code cleaning
                                    vowill 1 Reply Last reply Reply Quote 1
                                    • vowill
                                      vowill @Bass-T last edited by vowill
                                      @bass-t Danke für das Script - echt eine super Sache.
                                      Bei mir lief das Programm wenige Minuten durch und blieb dann "stehen" mit den Zeilen:
                                      Setting up openssh-server (1:9.2p1-2+deb12u7) ...
                                      locale: Cannot set LC_CTYPE to default locale: No such file or directory
                                      locale: Cannot set LC_MESSAGES to default locale: No such file or directory
                                      locale: Cannot set LC_ALL to default locale: No such file or directory
                                      rescue-ssh.target is a disabled or a static unit not running, not starting it.
                                      Danach für ca. 2min kein Prompt mehr und auch sonst keine Aktion. Das macht doch etwas nervös ... Aber dann lief es durch bis zum Ende.
                                      ✅ Finished, all updates done.
                                      🎉 All fine, have a nice day```
                                      • Bass-T
                                        Bass-T @vowill last edited by
                                        @vowill sagte in Proxmox-Updater (Host/LXC/VM) auch ioBroker,piHole,etc:
                                        Hi @vowill, leider kann ich aus deinem code nicht viel raus lesen. Was ich sehe ist, ein "normaler" Fehlercode, wenn locale nicht gesetzt wurde - was ziemlich oft der Fall ist - ist auch kein Problem, mehr ein Hinweis.
                                        rescue-ssh.target hat dann wohl etwas länger gedauert zu installieren, ... auch nichts auffälliges, ...
                                        Am Ende hast du ein Finish - ohne Fehler bekommen, was bedeutet, dass an keiner stelle des Skript etwas "schief" gelaufen ist - es gab keinen ExitCode - nur 0 - so soll es sein.
                                        Alles in allem würde ich behaupten alles safe 😉
                                        • da_Woody
                                          @bass-t sorry, hatte die letzten tage anderes chaos. 🙄
                                          wie gesagt, warum mail, wenn kein update ist. was ja auch witzig ist, teilweise kommen die mails als spam an, teilweise nicht...
                                          • Bass-T
                                            @da_woody kein ding 🙂
                                            Habe deinen Wunsch in die v4.5.2 übernommen
                                            update.conf - line 34 😉
                                            die Spam Geschichte ist mit neu. Bin jetzt kein System Admin, aber für mein Verständniss (bzgl Mailserver - mein eigener funktioniert bis heute nicht richtig 😄 ) kommt der Spam tag vom mail Server. Da kann ich wohl nichts ändern.
                                            Zudem benutze ich für mail keine extra tools, sondern den in PVE eingebauten mail client 😉
                                            Meine code Zeile hierfür:
                                            mail -s "Ultimate Updater summary" "$EMAIL_USER" < "$LOCAL_FILES"/mail-output
                                            echo "No updates found during search" | mail -s "Ultimate Updater" root
                                            $EMAIL_USER ist standardt "root" - kann auch in config geändert werden.
                                            Gerade entdeckt, dass im 2. code der USER nicht korrekt ist, ... lol - gerade gefixed in develop version.
                                            55
                                            8418
