    4. Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"}
      apollon77 last edited by
      Lol, das auch
      • Bluefox
        Bluefox last edited by
        Das ist definitiv kein Adapter. Ich dachte, dass er eigenen schreiben will.
        • h3adbang3r
          h3adbang3r last edited by
          Ja ich dachte… weil...
           npm install https://github.com/arteck/ioBroker.hs100/tarball/master/
          iobroker@1.0.0 /opt/iobroker
          └── iobroker.hs100@0.1.3
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
          host.ioBroker-Pi	2018-02-02 15:30:34.634	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
          Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
          Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
          Caught	2018-02-02 15:30:34.632	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
          Caught	2018-02-02 15:30:34.632	error	by controller[0]: at Adapter.emit (events.js:185:7)
          Caught	2018-02-02 15:30:34.632	error	by controller[0]: at emitNone (events.js:86:13)
          Caught	2018-02-02 15:30:34.632	error	by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.js:27:5)
          Caught	2018-02-02 15:30:34.632	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:482:32)
          Caught	2018-02-02 15:30:34.631	error	by controller[0]: TypeError: Cannot read property 'length' of undefined
          hs100.0	2018-02-02 15:30:34.608	info	terminating
          hs100.0	2018-02-02 15:30:34.098	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
          hs100.0	2018-02-02 15:30:34.098	error	at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          hs100.0	2018-02-02 15:30:34.098	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          hs100.0	2018-02-02 15:30:34.098	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          hs100.0	2018-02-02 15:30:34.098	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
          hs100.0	2018-02-02 15:30:34.098	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
          hs100.0	2018-02-02 15:30:34.098	error	at Adapter.emit (events.js:185:7)
          hs100.0	2018-02-02 15:30:34.098	error	at emitNone (events.js:86:13)
          hs100.0	2018-02-02 15:30:34.098	error	at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.js:27:5)
          hs100.0	2018-02-02 15:30:34.098	error	at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:482:32)
          hs100.0	2018-02-02 15:30:34.098	error	TypeError: Cannot read property 'length' of undefined
          hs100.0	2018-02-02 15:30:34.095	error	uncaught exception: Cannot read property 'length' of undefined
          hs100.0	2018-02-02 15:30:34.050	info	starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v6.12.3
          iobroker	2018-02-02 15:30:31.707	info	exit 0
          iobroker	2018-02-02 15:30:31.697	info	host.ioBroker-Pi object system.adapter.hs100.0 created
          host.ioBroker-Pi	2018-02-02 15:30:31.673	info	instance system.adapter.hs100.0 started with pid 23970
          host.ioBroker-Pi	2018-02-02 15:30:31.640	info	object change system.adapter.hs100.0
          iobroker	2018-02-02 15:30:31.593	info	host.ioBroker-Pi object system.adapter.hs100.0.alive created
          iobroker	2018-02-02 15:30:31.550	info	host.ioBroker-Pi object system.adapter.hs100.0.connected created
          iobroker	2018-02-02 15:30:31.513	info	host.ioBroker-Pi object system.adapter.hs100.0.memHeapUsed created
          iobroker	2018-02-02 15:30:31.470	info	host.ioBroker-Pi object system.adapter.hs100.0.memHeapTotal created
          iobroker	2018-02-02 15:30:31.417	info	host.ioBroker-Pi object system.adapter.hs100.0.memRss created
          iobroker	2018-02-02 15:30:31.369	info	host.ioBroker-Pi object system.adapter.hs100.0.uptime created
          iobroker	2018-02-02 15:30:31.330	info	host.ioBroker-Pi object system.adapter.hs100.0.inputCount created
          iobroker	2018-02-02 15:30:31.291	info	host.ioBroker-Pi object system.adapter.hs100.0.outputCount created
          iobroker	2018-02-02 15:30:31.269	info	host.ioBroker-Pi create instance hs100
          admin.0	2018-02-02 15:30:31.193	error	change ID is empty: {"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.host.ioBroker-Pi.cli","ts":1517585431181}
          iobroker	2018-02-02 15:30:31.211	info	host.ioBroker-Pi object undefined created
          javascript.0	2018-02-02 15:30:31.203	error	change ID is empty: {"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.host.ioBroker-Pi.cli","ts":1517585431181}
          history.0	2018-02-02 15:30:31.198	error	change ID is empty: {"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.host.ioBroker-Pi.cli","ts":1517585431181}
          iobroker	2018-02-02 15:30:31.177	info	host.ioBroker-Pi object system.adapter.hs100 created
          iobroker	2018-02-02 15:30:31.009	info	upload [0] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/hs100.png hs100.png image/png
          iobroker	2018-02-02 15:30:30.894	info	upload [1] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index.html index.html text/html
          iobroker	2018-02-02 15:30:30.785	info	upload [2] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/words.js words.js application/javascript
          iobroker	2018-02-02 15:30:30.747	info	got /opt/iobroker/node_modules/iobroker.hs100/admin
          iobroker	2018-02-02 15:30:27.278	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.hs100"
          iobroker	2018-02-02 15:30:27.274	info	host.ioBroker-Pi install adapter hs100
          iobroker	2018-02-02 15:30:25.438	info	add hs100
          host.ioBroker-Pi	2018-02-02 15:30:17.022	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
          iobroker	2018-02-02 15:30:16.558	info	exit 0
          iobroker	2018-02-02 15:30:16.420	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          iobroker	2018-02-02 15:30:16.420	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
          iobroker	2018-02-02 15:30:16.420	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupport
          iobroker	2018-02-02 15:30:16.417	info	npm
          iobroker	2018-02-02 15:29:05.614	info	npm install https://github.com/arteck/ioBroker.hs100/tarball/master --production --prefix "/opt/iobroker" (System call)
          iobroker	2018-02-02 15:29:05.206	info	install https://github.com/arteck/ioBroker.hs100/tarball/master
          iobroker	2018-02-02 15:29:03.972	info	url "https://github.com/arteck/ioBroker.hs100.git"
          Wenn ich dann ein Gerät hinzufüge, überschlagen sich die Fehlermeldung, das ioBroker mit dem Anzeigen nicht mehr folgen kann.
          Alles beginnt mit einem
          *** "Dose nicht erreichbar: 172.26.63.111
          das scrollt im hunderstel Sekundentakt durch bis es in einem
          host.ioBroker-Pi	2018-02-02 15:36:52.969	info	instance system.adapter.hs100.0 terminated with code 0 (OK)
          Caught	2018-02-02 15:36:52.969	error	by controller[1849]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3409): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.969	error	by controller[1849]: [PC Junior] device.send() Error: TCP Timeout
          Caught	2018-02-02 15:36:52.969	error	by controller[1849]: TCP Timeout
          Caught	2018-02-02 15:36:52.969	error	by controller[1849]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3408): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.969	error	by controller[1848]: [PC Junior] device.send() Error: TCP Timeout
          Caught	2018-02-02 15:36:52.968	error	by controller[1848]: TCP Timeout
          Caught	2018-02-02 15:36:52.968	error	by controller[1848]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3407): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.968	error	by controller[1848]: [PC Junior] device.send() Error: TCP Timeout
          Caught	2018-02-02 15:36:52.968	error	by controller[1847]: TCP Timeout
          Caught	2018-02-02 15:36:52.968	error	by controller[1846]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3406): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.968	error	by controller[1846]: TCP Timeout
          Caught	2018-02-02 15:36:52.968	error	by controller[1846]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3405): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.967	error	by controller[1846]: TCP Timeout
          Caught	2018-02-02 15:36:52.967	error	by controller[1846]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3404): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.967	error	by controller[1846]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3403): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.967	error	by controller[1845]: TCP Timeout
          Caught	2018-02-02 15:36:52.967	error	by controller[1845]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3402): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.966	error	by controller[1845]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3401): Error: TCP Timeout
          Caught	2018-02-02 15:36:52.966	error	by controller[1845]: [PC Junior] device.send() Error: TCP Timeout
          Caught	2018-02-02 15:36:52.966	error	by controller[1845]: TCP Timeout
          Caught	2018-02-02 15:36:52.966	error	by controller[1845]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3400): Error: TCP Timeout
          und dem pausieren des Adapter endet. Dieses Theater habe ich, seit ich auf das Image gewechselt habe. Vorher liefen die 3 TP-Link problemlos.
            Du hast irgendein npm-package, das überhaupt nichts mit ioBroker zu tun hat versucht mit in ioBroker einzubinden.
            Dass das nicht gut geht ist doch klar.
            Rainer
            • h3adbang3r
              @Homoran:
              Rainer ` Diese Fehlermeldung habe ich seit dem allererstem Start. Das hat mit meinem Fehler nichts zutun, wenn er mich auch mächtig ärgert.
              • h3adbang3r
                Das hatte ich am 30.01.2018, gleich nach dem erstem Start von ioBroker als ich Discovery updaten wollte.
                https://www.facebook.com/groups/4404991 … 475053193/
                https://www.facebook.com/groups/4404991 … 698343504/
                Es hat also rein garnichts mit meinem Fehler zu tun. Dieser entstand deshalb weil ich hier gesucht habe um meine Steckdosen wieder verwenden zu können und ich zu dumm war alle 10 Seiten des Beitrages zur tplink-smarthome-api zu lesen. So habe ich nur die ersten 2 - 3 Seiten überflogen und dann versucht zu installieren. Von Erfolg gekrönt war das, wie man oben sieht zwar nicht, aber es ist auf keinen Fall die Ursache meines Problemes.
                  Mit den Facebook-Links kann ich nichts anfangen 😞
                  Gib mir bitte die Versionen von:
                  • js-controller
                  • admin
                  • nodejs
                  • npm
                  Rainer
                  • h3adbang3r
                    huhu
                    @Homoran:
                    • js-controller ` root@ioBroker-Pi:/home/pi# iobroker -v
                    1.2.3
                    @Homoran:
                    • admin ` ioBroker admin
                    2.0.9
                    @Homoran:
                    • nodejs ` root@ioBroker-Pi:/home/pi# node -v
                    v6.12.3
                    @Homoran:
                    • npm ` root@ioBroker-Pi:/home/pi# npm -v
                    3.10.10
                    @Homoran:
                    Rainer ` Ich danke 😉
                    Gruß Sven
                      Die Versionen passen.
                      Irgendwas übersehe ich. 😞
                      Wanted arch = any und trotzdem sagt er not supported bei arch = arm
                      Aber egal; es handelt sich nur um Optional Dependencies, also nichts notwendiges.
                      Rainer
                      • h3adbang3r
                        Es scheint als gebe es weitere mit einem Problem mit dem HS-100 Adapter.
                        https://www.facebook.com/groups/4404991 … 081562299/
                        • h3adbang3r
                          Ich habe mein Problem erstmal damit gelöst den Wert "Abfrage Intervall[ms]" auf "20000" zu setzen. Damit kommt es nicht mehr zu den TCP Fehlern. Möglicherweise wollen die Steckdosen nicht so häufig antworten oder sind dafür auch nicht ausgelegt.
                          2039
