    4. Kein öffnen von Iobroker oder Grafana möglich
      sral74 @crunchip last edited by
      ... alles gestoppt grafana will immer noch nicht
      @crunchip ========== Start marking the full check here ===========
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.12.34+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       20:50:20 up 32 min,  3 users,  load average: 0.98, 0.70, 1.01
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-08-17 20:50:21 CEST
                 Universal time: Sun 2025-08-17 18:50:21 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      lars
      HOME=/home/lars
      GROUPS=lars adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            950M        255M        187M         94K        574M        694M
      Swap:           1.0G        177M        871M
      Total:          2.0G        432M        1.1G
      Active iob-Instances:   1
                906 M total memory
                243 M used memory
                273 M active memory
                336 M inactive memory
                178 M free memory
                 16 M buffer memory
                531 M swap cache
                999 M total swap
                169 M used swap
                830 M free swap
      top - 20:50:21 up 33 min,  3 users,  load average: 0.98, 0.70, 1.01
      Tasks: 174 total,   1 running, 173 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  8.3 us,  8.3 sy,  0.0 ni, 75.0 id,  8.3 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :    906.2 total,    178.9 free,    243.4 used,    548.3 buff/cache
      MiB Swap:   1000.0 total,    830.8 free,    169.2 used.    662.9 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  314M     0  314M   0% /dev
      tmpfs          tmpfs     182M  1.2M  181M   1% /run
      /dev/sda2      ext4      917G   18G  860G   2% /
      tmpfs          tmpfs     454M  8.0K  454M   1% /dev/shm
      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
      /dev/sda1      vfat      510M   78M  433M  16% /boot/firmware
      tmpfs          tmpfs      91M   44K   91M   1% /run/user/1000
      [Sun Aug 17 20:17:21 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0f3ec0cf-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Sun Aug 17 20:17:32 2025] EXT4-fs (sda2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
      [Sun Aug 17 20:17:36 2025] EXT4-fs (sda2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w.
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.3G    /var/
      770M    /var/log
      768M    /var/log/journal
      760M    /var/log/journal/29fe04dc9ad1405bac943853674cdaa0
      398M    /var/lib
      Archived and active journals take up 759.0M in the file system.
      /opt/iobroker/backups:
      8.6G    /opt/iobroker/backups/
      13M     /opt/iobroker/backups/influxDB_2025_05_28-02_40_47_backupiobroker
      4.0K    /opt/iobroker/backups/influxDB_2025_07_24-02_40_46_backupiobroker
      /opt/iobroker/iobroker-data:
      157M    /opt/iobroker/iobroker-data/
      94M     /opt/iobroker/iobroker-data/files
      46M     /opt/iobroker/iobroker-data/backup-objects
      33M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.4
      /usr/bin/node           v20.19.4
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.32.0
      nodejs:
        Installed: 20.19.4-1nodesource1
        Candidate: 20.19.4-1nodesource1
        Version table:
       *** 20.19.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.19.3-1nodesource1 1001
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 328)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
        system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 - disabled
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
        system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
        system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
        system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
        system.adapter.smartmeter.1             : smartmeter            : iobroker                                 - disabled
        system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.1.5  [Updatable]
      Adapter    "backitup"     : 3.3.5    , installed 3.0.25 [Updatable]
      Controller "js-controller": 7.0.7    , installed 7.0.3  [Updatable]
      Adapter    "mielecloudservice": 6.5.10, installed 6.5.7 [Updatable]
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "rpi2"         : 2.4.0    , installed 2.2.1  [Updatable]
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Objects and States
      Objects:        7324
      States:         5571
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6897       657/cupsd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5088       722/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5090       722/sshd: /usr/sbin
      tcp6       0      0 :::5900                 :::*                    LISTEN      992        7128       682/wayvnc
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6896       657/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      112        8428       998/grafana
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4983       532/avahi-daemon: r
      udp        0      0 0.0.0.0:39722           0.0.0.0:*                           104        4985       532/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        4984       532/avahi-daemon: r
      udp6       0      0 fe80::ee01:c2a6:1f2:546 :::*                                0          9422       621/NetworkManager
      udp6       0      0 :::55369                :::*                                104        4986       532/avahi-daemon: r
      2025-08-17 20:23:43.720  - info: host.iobroker stopInstance timeout system.adapter.rpi2.0 killing pid 1768
      2025-08-17 20:23:43.722  - info: host.iobroker stopInstance timeout system.adapter.smartmeter.0 killing pid 1814
      2025-08-17 20:23:43.723  - info: host.iobroker stopInstance timeout system.adapter.smartmeter.1 killing pid 1820
      2025-08-17 20:23:43.724  - info: host.iobroker stopInstance timeout system.adapter.viessmannapi.0 killing pid 1807
      2025-08-17 20:23:44.568  - warn: host.iobroker instance system.adapter.backitup.0 terminated due to SIGKILL
      2025-08-17 20:23:44.569  - info: host.iobroker instance system.adapter.backitup.0 terminated with code null ()
      2025-08-17 20:23:44.570  - warn: host.iobroker instance system.adapter.modbus.0 terminated due to SIGKILL
      2025-08-17 20:23:44.570  - info: host.iobroker instance system.adapter.modbus.0 terminated with code null ()
      2025-08-17 20:23:44.571  - warn: host.iobroker instance system.adapter.modbus.1 terminated due to SIGKILL
      2025-08-17 20:23:44.571  - info: host.iobroker instance system.adapter.modbus.1 terminated with code null ()
      2025-08-17 20:23:44.572  - warn: host.iobroker instance system.adapter.rpi2.0 terminated due to SIGKILL
      2025-08-17 20:23:44.572  - info: host.iobroker instance system.adapter.rpi2.0 terminated with code null ()
      2025-08-17 20:23:44.588  - warn: host.iobroker instance system.adapter.admin.0 terminated due to SIGKILL
      2025-08-17 20:23:44.589  - info: host.iobroker instance system.adapter.admin.0 terminated with code null ()
      2025-08-17 20:23:44.590  - warn: host.iobroker instance system.adapter.viessmannapi.0 terminated due to SIGKILL
      2025-08-17 20:23:44.591  - info: host.iobroker instance system.adapter.viessmannapi.0 terminated with code null ()
      2025-08-17 20:23:44.591  - warn: host.iobroker instance system.adapter.smartmeter.0 terminated due to SIGKILL
      2025-08-17 20:23:44.592  - info: host.iobroker instance system.adapter.smartmeter.0 terminated with code null ()
      2025-08-17 20:23:44.592  - warn: host.iobroker instance system.adapter.smartmeter.1 terminated due to SIGKILL
      2025-08-17 20:23:44.593  - info: host.iobroker instance system.adapter.smartmeter.1 terminated with code null ()
      2025-08-17 20:23:44.597  - info: influxdb.0 (1762) terminating
      2025-08-17 20:23:44.823  - info: influxdb.0 (1762) Terminated (NO_ERROR): Without reason
      2025-08-17 20:23:45.898  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
      2025-08-17 20:23:45.899  - info: host.iobroker All instances are stopped.
      2025-08-17 20:23:46.154  - info: host.iobroker terminated
      iob diag has finished.
        Thomas Braun Most Active @sral74 last edited by Thomas Braun
        @sral74
        Läuft denn grafana überhaupt?
        systemctl status grafana-server.service
        sagt?
          sral74 @Thomas Braun last edited by Homoran
          ● grafana-server.service - Grafana instance
               Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; preset: enabled)
               Active: active (running) since Sun 2025-08-17 18:04:45 CEST; 3h 3min ago
                 Docs: http://docs.grafana.org
             Main PID: 998 (grafana)
                Tasks: 21 (limit: 753)
                  CPU: 35.930s
               CGroup: /system.slice/grafana-server.service
                       └─998 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafa>
          Aug 17 20:20:11 iobroker grafana[998]: logger=infra.usagestats t=2025-08-17T20:20:11.797412361+02:00 level=info msg="Usage stats are ready to report"
          Aug 17 20:29:12 iobroker grafana[998]: logger=cleanup t=2025-08-17T20:29:12.564242264+02:00 level=info msg="Completed cleanup jobs" duration=706.612246ms
          Aug 17 20:29:15 iobroker grafana[998]: logger=plugins.update.checker t=2025-08-17T20:29:15.84882186+02:00 level=info msg="Update check succeeded" duration=881.183031ms
          Aug 17 20:39:11 iobroker grafana[998]: logger=cleanup t=2025-08-17T20:39:11.902157772+02:00 level=info msg="Completed cleanup jobs" duration=80.787217ms
          Aug 17 20:39:14 iobroker grafana[998]: logger=plugins.update.checker t=2025-08-17T20:39:14.979364665+02:00 level=info msg="Update check succeeded" duration=123.296737ms
          Aug 17 20:49:11 iobroker grafana[998]: logger=cleanup t=2025-08-17T20:49:11.855496892+02:00 level=info msg="Completed cleanup jobs" duration=34.253238ms
          Aug 17 20:49:14 iobroker grafana[998]: logger=plugins.update.checker t=2025-08-17T20:49:14.977234378+02:00 level=info msg="Update check succeeded" duration=121.062219ms
          Aug 17 20:50:12 iobroker grafana[998]: logger=infra.usagestats t=2025-08-17T20:50:12.209349966+02:00 level=info msg="Usage stats are ready to report"
          Aug 17 20:59:12 iobroker grafana[998]: logger=cleanup t=2025-08-17T20:59:12.021299646+02:00 level=info msg="Completed cleanup jobs" duration=200.220254ms
          Aug 17 20:59:15 iobroker grafana[998]: logger=plugins.update.checker t=2025-08-17T20:59:15.057203464+02:00 level=info msg="Update check succeeded" duration=201.79754ms
          lines 1-20/20 (END)
            sral74 @Thomas Braun last edited by sral74
            @thomas-braun oh man, bin wieder drin. Aus irgend einen grund hat sich die IP Adresse geändert. Ich dreh durch 🙂
              crunchip Forum Testing Most Active @sral74 last edited by
              @sral74 sagte in Kein öffnen von Iobroker oder Grafana möglich:
              Das versteht wohl keiner, was hat ne geänderte IP damit zu tun? Es ist doch alles auf deinem PI
                sral74 @crunchip last edited by sral74
                @crunchip Grafana wird doch über einen Webbrowser per IP Adresse mit Port :3000 aufgerufen und diese IP war auf einmal geändert. Anscheinend lief das ganze system immer nur ich hatte gedacht es wäre abgestürzt, da nicht mehr erreichbar. Ich versteh es selbst nicht. Hatte nie was geändert
                crunchip Codierknecht 2 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @sral74 last edited by crunchip
                  Ja und der iobroker mit der selben IP, Ergo die ssh Verbindung wird ebenfalls mit dieser IP genutzt
                  . SSH geht wieder war in der config wieder deaktiviert
                  • Codierknecht
                    Codierknecht Developer Most Active @sral74 last edited by
                    Wenn Du das nicht über die IP sondern über den Hostnamen aufrufst, hast Du das Problem nicht.
                    Server sollten 'ne fixe IP erhalten.
                    Zumindest sollte die einmal per DHCP vergebene IP im Router dem Gerät dauerhaft zugewiesen werden.
                      sooo, neuer pi läuft (wow rennt das teil :-D) anbei noch einmal ein aktueller Iob diag Bericht
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                             Icon name: computer
                                Kernel: Linux 6.12.25+rpt-rpi-2712
                          Architecture: arm64
                      OS is similar to:
                      Model           : Raspberry Pi 5 Model B Rev 1.0
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       18:47:36 up  2:34,  2 users,  load average: 0.92, 1.25, 1.32
                      CPU threads: 4
                      Current issues:
                                     Local time: Wed 2025-08-20 18:47:36 CEST
                                 Universal time: Wed 2025-08-20 16:47:36 UTC
                                       RTC time: Wed 2025-08-20 16:47:36
                                    NTP service: active
                                RTC in local TZ: no
                      lars
                      HOME=/home/lars
                      GROUPS=lars adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:            8.5G        1.4G        5.9G         14M        1.3G        7.1G
                      Swap:           536M          0B        536M
                      Total:          9.0G        1.4G        6.4G
                      Active iob-Instances:   3
                               8063 M total memory
                               1321 M used memory
                               1250 M active memory
                                752 M inactive memory
                               5573 M free memory
                                157 M buffer memory
                               1112 M swap cache
                                511 M total swap
                                  0 M used swap
                                511 M free swap
                      top - 18:47:37 up  2:34,  2 users,  load average: 0.92, 1.25, 1.32
                      Tasks: 187 total,   2 running, 185 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 33.3 us,  8.3 sy,  0.0 ni, 41.7 id, 16.7 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   8063.7 total,   5582.9 free,   1312.2 used,   1270.4 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6751.5 avail Mem
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      udev           devtmpfs  3.9G     0  3.9G   0% /dev
                      tmpfs          tmpfs     807M   14M  793M   2% /run
                      /dev/sda2      ext4      917G  4.7G  866G   1% /
                      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                      /dev/sda1      vfat      510M   58M  453M  12% /boot/firmware
                      tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
                      [Wed Aug 20 16:13:08 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:78:AA:CD vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=054695f7-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                      [Wed Aug 20 16:13:14 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                      [Wed Aug 20 16:13:18 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
                      /var:
                      1.2G    /var/
                      409M    /var/cache
                      403M    /var/cache/apt
                      287M    /var/cache/apt/archives
                      238M    /var/lib
                      Archived and active journals take up 8.5M in the file system.
                      1.9M    /opt/iobroker/backups/
                      123M    /opt/iobroker/iobroker-data/
                      99M     /opt/iobroker/iobroker-data/files
                      47M     /opt/iobroker/iobroker-data/files/admin.admin
                      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                      8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                      7.0M    /opt/iobroker/iobroker-data/objects.jsonl
                      3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-00V6sJFg.js
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D200ZJFI-if00-port0
                      /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D200ZWWZ-if00-port0
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/nodejs         v22.18.0
                      /usr/bin/node           v22.18.0
                      /usr/bin/npm            10.9.3
                      /usr/bin/npx            10.9.3
                      /usr/bin/corepack       0.33.0
                      nodejs:
                        Installed: 22.18.0-1nodesource1
                        Candidate: 22.18.0-1nodesource1
                        Version table:
                       *** 22.18.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 16)
                      js-controller:  7.0.7
                      admin:          7.6.17
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                        system.adapter.plenticore-g3.0          : plenticore-g3         : iobroker                                 -  enabled, port: 80
                        system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
                        system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
                        system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
                        system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
                      + instance is alive
                      Adapter    "admin"        : 7.6.17   , installed 7.6.17
                      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                      Controller "js-controller": 7.0.7    , installed 7.0.7
                      Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                      Adapter    "plenticore-g3": 0.2.0    , installed 0.2.0
                      Objects and States
                      Objects:        4489
                      States:         3354
                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:5 https://repos.influxdata.com/debian bookworm InRelease
                      Hit:6 https://apt.grafana.com stable InRelease
                      Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Pending Updates: 86
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       26160      3413/iobroker.js-co
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26165      3413/iobroker.js-co
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6460       721/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      105        6486       704/influxd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          6462       721/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24552      3431/io.admin.0
                      tcp6       0      0 :::8086                 :::*                    LISTEN      105        4709       704/influxd
                      tcp6       0      0 :::3000                 :::*                    LISTEN      106        5804       789/grafana
                      udp        0      0 0.0.0.0:56515           0.0.0.0:*                           104        3932       596/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3930       596/avahi-daemon: r
                      udp6       0      0 :::48281                :::*                                104        3933       596/avahi-daemon: r
                      udp6       0      0 fe80::5d9a:7e1c:b64:546 :::*                                0          4969       671/NetworkManager
                      udp6       0      0 fe80::fb2b:3bc4:856:546 :::*                                0          6491       671/NetworkManager
                      udp6       0      0 :::5353                 :::*                                104        3931       596/avahi-daemon: r
                      2025-08-20 18:47:51.447  - info: smartmeter.1 (3821) Received 22 values, 12 updated
                      2025-08-20 18:47:52.081  - info: smartmeter.0 (3644) Received 22 values, 11 updated
                      2025-08-20 18:47:53.061  - info: host.iobroker instance system.adapter.viessmannapi.0 in version "2.3.0" started with pid 3964
                      2025-08-20 18:47:53.448  - info: smartmeter.1 (3821) Received 22 values, 8 updated
                      2025-08-20 18:47:53.811  - info: viessmannapi.0 (3964) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v22.18.0, js-controller: 7.0.7
                      2025-08-20 18:47:54.074  - info: smartmeter.0 (3644) Received 22 values, 9 updated
                      2025-08-20 18:47:55.608  - info: viessmannapi.0 (3964) 1 installations found.
                      2025-08-20 18:47:57.200  - info: host.iobroker instance system.adapter.plenticore-g3.0 in version "0.2.0" started with pid 4007
                      2025-08-20 18:47:58.245  - info: plenticore-g3.0 (4007) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.plenticore-g3, node: v22.18.0, js-controller: 7.0.7
                      2025-08-20 18:47:58.879  - info: plenticore-g3.0 (4007) logged in to plenticore
                      2025-08-20 18:48:00.068  - info: smartmeter.0 (3644) Received 22 values, 10 updated
                      2025-08-20 18:48:00.444  - info: smartmeter.1 (3821) Received 22 values, 9 updated
                      2025-08-20 18:48:01.069  - info: host.iobroker instance system.adapter.plenticore.0 in version "2.2.0" started with pid 4039
                      2025-08-20 18:48:02.031  - info: plenticore.0 (4039) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v22.18.0, js-controller: 7.0.7
                      2025-08-20 18:48:02.041  - info: plenticore.0 (4039) [START] Starting adapter plenticore v2.2.0r237
                      2025-08-20 18:48:02.050  - info: plenticore.0 (4039) Configured Wp of panel(s) is 0
                      2025-08-20 18:48:02.051  - info: plenticore.0 (4039) [INFO] Configured polling interval: 20000
                      2025-08-20 18:48:02.080  - info: smartmeter.0 (3644) Received 22 values, 8 updated
                      2025-08-20 18:48:02.440  - info: smartmeter.1 (3821) Received 22 values, 10 updated
                      2025-08-20 18:48:03.193  - info: plenticore-g3.0 (4007) init completed
                      2025-08-20 18:48:03.531  - info: plenticore.0 (4039) Not enabling forecast data.
                      2025-08-20 18:48:03.532  - info: plenticore.0 (4039) Not enabling MinSoC forecast data.
                      2025-08-20 18:48:03.772  - info: plenticore-g3.0 (4007) check for update
                      2025-08-20 18:48:08.077  - info: smartmeter.0 (3644) Received 22 values, 12 updated
                      2025-08-20 18:48:08.449  - info: smartmeter.1 (3821) Received 22 values, 10 updated
                        Pending Updates: 86
                        Hau die drauf...
                        Und halt das System dann regelmäßig auf dem aktuellen Stand.
                          @thomas-braun habe update drüberlaufen lassen aber immer noch?!
                          Pending Updates: 56
                            @sral74
                            sudo apt update
                            sudo apt full-upgrade
                            sagt?
                            Und auch mal rebooten:
                            sudo reboot
                              @thomas-braun lars@iobroker:~
                              ... ein paar errors tauchen auf (P.s.: wie kann consolen ausgaben/eingaben als seperaten Bereich hier ins forum Posten. also die schwarz hinterlegten Felder)
                              $ sudo apt full-upgrade
                              Reading package lists... Done
                              Building dependency tree... Done
                              Calculating upgrade... Done
                              The following NEW packages will be installed:
                                libdtovl0 libgpiolib0 linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.34+rpt-rpi-2712
                                linux-headers-6.12.34+rpt-rpi-v8 linux-image-6.12.34+rpt-rpi-2712 linux-image-6.12.34+rpt-rpi-v8
                                linux-kbuild-6.12.34+rpt
                              The following packages will be upgraded:
                                busybox debian-archive-keyring distro-info-data influxdb initramfs-tools initramfs-tools-core kms++-utils
                                libabsl20220623 libavif15 libblockdev-crypto2 libblockdev-fs2 libblockdev-loop2 libblockdev-part-err2
                                libblockdev-part2 libblockdev-swap2 libblockdev-utils2 libblockdev2 libc-l10n libcap2 libcap2-bin libgnutls30
                                libgssapi-krb5-2 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libpython3.11 libpython3.11-minimal
                                libpython3.11-stdlib libqt5core5a libssl3 libudisks2-0 libwbclient0 libxml2 linux-headers-rpi-2712
                                linux-headers-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 locales net-tools openssh-client openssh-server
                                openssh-sftp-server openssl pastebinit python3.11 python3.11-minimal python3.11-venv raspberrypi-sys-mods
                                raspi-config raspi-firmware raspi-utils raspi-utils-core raspi-utils-dt raspi-utils-eeprom raspi-utils-otp raspinfo
                                rpi-eeprom ssh sudo udisks2 wireless-regdb
                              62 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
                              Need to get 0 B/143 MB of archives.
                              After this operation, 206 MB of additional disk space will be used.
                              Do you want to continue? [Y/n] y
                              Reading changelogs... Done
                              Extracting templates from packages: 100%
                              Preconfiguring packages ...
                              (Reading database ... 82278 files and directories currently installed.)
                              Preparing to unpack .../00-influxdb_1.11.8-2_arm64.deb ...
                              Unpacking influxdb (1.11.8-2) over (1.6.7~rc0-1+b13) ...
                              dpkg: error processing archive /tmp/apt-dpkg-install-6rVuF0/00-influxdb_1.11.8-2_arm64.deb (--unpack):
                               trying to overwrite '/usr/bin/influx', which is also in package influxdb-client 1.6.7~rc0-1+b13
                              dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                              Preparing to unpack .../01-libgssapi-krb5-2_1.20.1-2+deb12u3_arm64.deb ...
                              Unpacking libgssapi-krb5-2:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
                              Preparing to unpack .../02-libkrb5-3_1.20.1-2+deb12u3_arm64.deb ...
                              Unpacking libkrb5-3:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
                              Preparing to unpack .../03-libkrb5support0_1.20.1-2+deb12u3_arm64.deb ...
                              Unpacking libkrb5support0:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
                              Preparing to unpack .../04-libk5crypto3_1.20.1-2+deb12u3_arm64.deb ...
                              Unpacking libk5crypto3:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
                              Preparing to unpack .../05-libssl3_3.0.17-1~deb12u2+rpt1_arm64.deb ...
                              Unpacking libssl3:arm64 (3.0.17-1~deb12u2+rpt1) over (3.0.16-1~deb12u1+rpt1) ...
                              Preparing to unpack .../06-openssh-sftp-server_1%3a9.2p1-2+deb12u7_arm64.deb ...
                              Unpacking openssh-sftp-server (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
                              Preparing to unpack .../07-openssh-server_1%3a9.2p1-2+deb12u7_arm64.deb ...
                              Unpacking openssh-server (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
                              Preparing to unpack .../08-openssh-client_1%3a9.2p1-2+deb12u7_arm64.deb ...
                              Unpacking openssh-client (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
                              Preparing to unpack .../09-python3.11-venv_3.11.2-6+deb12u6_arm64.deb ...
                              Unpacking python3.11-venv (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                              Preparing to unpack .../10-libpython3.11_3.11.2-6+deb12u6_arm64.deb ...
                              Unpacking libpython3.11:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                              Preparing to unpack .../11-python3.11_3.11.2-6+deb12u6_arm64.deb ...
                              Unpacking python3.11 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                              Preparing to unpack .../12-libpython3.11-stdlib_3.11.2-6+deb12u6_arm64.deb ...
                              Unpacking libpython3.11-stdlib:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                              Preparing to unpack .../13-python3.11-minimal_3.11.2-6+deb12u6_arm64.deb ...
                              Unpacking python3.11-minimal (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                              Preparing to unpack .../14-libpython3.11-minimal_3.11.2-6+deb12u6_arm64.deb ...
                              Unpacking libpython3.11-minimal:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                              Preparing to unpack .../15-raspi-firmware_1%3a1.20250430-4~bookworm_all.deb ...
                              Unpacking raspi-firmware (1:1.20250430-4~bookworm) over (1:1.20250430-1) ...
                              Preparing to unpack .../16-sudo_1.9.13p3-1+deb12u2_arm64.deb ...
                              Unpacking sudo (1.9.13p3-1+deb12u2) over (1.9.13p3-1+deb12u1) ...
                              Preparing to unpack .../17-debian-archive-keyring_2023.3+deb12u2_all.deb ...
                              Unpacking debian-archive-keyring (2023.3+deb12u2) over (2023.3+deb12u1) ...
                              Errors were encountered while processing:
                              E: Sub-process /usr/bin/dpkg returned an error code (1)
                                influxdb-client
                                Der muss weg. Ist nicht kompatibel mit dem influxdb aus deren Repo.
                                sudo apt remove influxdb-client
                                Und die Ausgabe von
                                sudo apt update
                                möchte ich auch sehen.
                                  $ sudo apt update
                                  Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                  45 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    @sral74
                                    Ja, schmeiß influxdb-client raus.
                                    Siehe oben.
                                      @thomas-braun hatte ich bereits ausgeführt
                                      nochmal?
                                        @sral74
                                        Dann nochmal
                                        sudo apt update
                                          Pending Updates: 0
                                            @sral74
                                            Neugestartet?
                                            grafana
                                            1126
