    4. Kein öffnen von Iobroker oder Grafana möglich
      Thomas Braun Most Active @sral74 last edited by Thomas Braun
      @sral74
      Läuft denn grafana überhaupt?
      systemctl status grafana-server.service
      sagt?
        sral74 @Thomas Braun last edited by Homoran
        ● grafana-server.service - Grafana instance
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; preset: enabled)
             Active: active (running) since Sun 2025-08-17 18:04:45 CEST; 3h 3min ago
               Docs: http://docs.grafana.org
           Main PID: 998 (grafana)
              Tasks: 21 (limit: 753)
                CPU: 35.930s
             CGroup: /system.slice/grafana-server.service
                     └─998 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafa>
        Aug 17 20:20:11 iobroker grafana[998]: logger=infra.usagestats t=2025-08-17T20:20:11.797412361+02:00 level=info msg="Usage stats are ready to report"
        Aug 17 20:29:12 iobroker grafana[998]: logger=cleanup t=2025-08-17T20:29:12.564242264+02:00 level=info msg="Completed cleanup jobs" duration=706.612246ms
        Aug 17 20:29:15 iobroker grafana[998]: logger=plugins.update.checker t=2025-08-17T20:29:15.84882186+02:00 level=info msg="Update check succeeded" duration=881.183031ms
        Aug 17 20:39:11 iobroker grafana[998]: logger=cleanup t=2025-08-17T20:39:11.902157772+02:00 level=info msg="Completed cleanup jobs" duration=80.787217ms
        Aug 17 20:39:14 iobroker grafana[998]: logger=plugins.update.checker t=2025-08-17T20:39:14.979364665+02:00 level=info msg="Update check succeeded" duration=123.296737ms
        Aug 17 20:49:11 iobroker grafana[998]: logger=cleanup t=2025-08-17T20:49:11.855496892+02:00 level=info msg="Completed cleanup jobs" duration=34.253238ms
        Aug 17 20:49:14 iobroker grafana[998]: logger=plugins.update.checker t=2025-08-17T20:49:14.977234378+02:00 level=info msg="Update check succeeded" duration=121.062219ms
        Aug 17 20:50:12 iobroker grafana[998]: logger=infra.usagestats t=2025-08-17T20:50:12.209349966+02:00 level=info msg="Usage stats are ready to report"
        Aug 17 20:59:12 iobroker grafana[998]: logger=cleanup t=2025-08-17T20:59:12.021299646+02:00 level=info msg="Completed cleanup jobs" duration=200.220254ms
        Aug 17 20:59:15 iobroker grafana[998]: logger=plugins.update.checker t=2025-08-17T20:59:15.057203464+02:00 level=info msg="Update check succeeded" duration=201.79754ms
        lines 1-20/20 (END)
          sral74 @Thomas Braun last edited by sral74
          @thomas-braun oh man, bin wieder drin. Aus irgend einen grund hat sich die IP Adresse geändert. Ich dreh durch 🙂
            crunchip Forum Testing Most Active @sral74 last edited by
            @sral74 sagte in Kein öffnen von Iobroker oder Grafana möglich:
            Das versteht wohl keiner, was hat ne geänderte IP damit zu tun? Es ist doch alles auf deinem PI
              sral74 @crunchip last edited by sral74
              @crunchip Grafana wird doch über einen Webbrowser per IP Adresse mit Port :3000 aufgerufen und diese IP war auf einmal geändert. Anscheinend lief das ganze system immer nur ich hatte gedacht es wäre abgestürzt, da nicht mehr erreichbar. Ich versteh es selbst nicht. Hatte nie was geändert
              crunchip Codierknecht 2 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @sral74 last edited by crunchip
                Ja und der iobroker mit der selben IP, Ergo die ssh Verbindung wird ebenfalls mit dieser IP genutzt
                . SSH geht wieder war in der config wieder deaktiviert
                • Codierknecht
                  Codierknecht Developer Most Active @sral74 last edited by
                  Wenn Du das nicht über die IP sondern über den Hostnamen aufrufst, hast Du das Problem nicht.
                  Server sollten 'ne fixe IP erhalten.
                  Zumindest sollte die einmal per DHCP vergebene IP im Router dem Gerät dauerhaft zugewiesen werden.
                    sooo, neuer pi läuft (wow rennt das teil :-D) anbei noch einmal ein aktueller Iob diag Bericht
                    ========== Start marking the full check here ===========
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                     Static hostname: iobroker
                           Icon name: computer
                              Kernel: Linux 6.12.25+rpt-rpi-2712
                        Architecture: arm64
                    OS is similar to:
                    Model           : Raspberry Pi 5 Model B Rev 1.0
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     18:47:36 up  2:34,  2 users,  load average: 0.92, 1.25, 1.32
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'bookworm'!
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** TIME AND TIMEZONES ***
                                   Local time: Wed 2025-08-20 18:47:36 CEST
                               Universal time: Wed 2025-08-20 16:47:36 UTC
                                     RTC time: Wed 2025-08-20 16:47:36
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    lars
                    HOME=/home/lars
                    GROUPS=lars adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         false
                    Unit display-manager.service could not be found.
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:            8.5G        1.4G        5.9G         14M        1.3G        7.1G
                    Swap:           536M          0B        536M
                    Total:          9.0G        1.4G        6.4G
                    Active iob-Instances:   3
                             8063 M total memory
                             1321 M used memory
                             1250 M active memory
                              752 M inactive memory
                             5573 M free memory
                              157 M buffer memory
                             1112 M swap cache
                              511 M total swap
                                0 M used swap
                              511 M free swap
                    top - 18:47:37 up  2:34,  2 users,  load average: 0.92, 1.25, 1.32
                    Tasks: 187 total,   2 running, 185 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 33.3 us,  8.3 sy,  0.0 ni, 41.7 id, 16.7 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   8063.7 total,   5582.9 free,   1312.2 used,   1270.4 buff/cache
                    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6751.5 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    udev           devtmpfs  3.9G     0  3.9G   0% /dev
                    tmpfs          tmpfs     807M   14M  793M   2% /run
                    /dev/sda2      ext4      917G  4.7G  866G   1% /
                    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                    /dev/sda1      vfat      510M   58M  453M  12% /boot/firmware
                    tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
                    [Wed Aug 20 16:13:08 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:78:AA:CD vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=054695f7-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                    [Wed Aug 20 16:13:14 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                    [Wed Aug 20 16:13:18 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
                    Show mounted filesystems:
                    TARGET           SOURCE    FSTYPE OPTIONS
                    /                /dev/sda2 ext4   rw,noatime
                    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    1.2G    /var/
                    409M    /var/cache
                    403M    /var/cache/apt
                    287M    /var/cache/apt/archives
                    238M    /var/lib
                    Archived and active journals take up 8.5M in the file system.
                    /opt/iobroker/backups:
                    1.9M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    123M    /opt/iobroker/iobroker-data/
                    99M     /opt/iobroker/iobroker-data/files
                    47M     /opt/iobroker/iobroker-data/files/admin.admin
                    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
                    8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                    7.0M    /opt/iobroker/iobroker-data/objects.jsonl
                    3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-00V6sJFg.js
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D200ZJFI-if00-port0
                    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D200ZWWZ-if00-port0
                    Zigbee Network Settings on your coordinator/in nvbackup are:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    To unmask the settings run 'iob diag --unmask'
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v22.18.0
                    /usr/bin/node           v22.18.0
                    /usr/bin/npm            10.9.3
                    /usr/bin/npx            10.9.3
                    /usr/bin/corepack       0.33.0
                    nodejs:
                      Installed: 22.18.0-1nodesource1
                      Candidate: 22.18.0-1nodesource1
                      Version table:
                     *** 22.18.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                            100 /var/lib/dpkg/status
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                         18.19.0+dfsg-6~deb12u2 500
                         18.19.0+dfsg-6~deb12u1 500
                    No problems detected
                    Errors in npm tree: 0
                    Checking for nodejs vulnerability:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 16)
                    Core adapters versions
                    js-controller:  7.0.7
                    admin:          7.6.17
                    javascript:     "javascript" not found
                    nodejs modules from github:     0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                      system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                      system.adapter.plenticore-g3.0          : plenticore-g3         : iobroker                                 -  enabled, port: 80
                      system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
                      system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
                      system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
                      system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Upgrade policy: none
                    Installed ioBroker-Adapters
                    Used repository: stable
                    Adapter    "admin"        : 7.6.17   , installed 7.6.17
                    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                    Controller "js-controller": 7.0.7    , installed 7.0.7
                    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                    Adapter    "plenticore-g3": 0.2.0    , installed 0.2.0
                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                    Objects and States
                    Objects:        4489
                    States:         3354
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:5 https://repos.influxdata.com/debian bookworm InRelease
                    Hit:6 https://apt.grafana.com stable InRelease
                    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 86
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       26160      3413/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26165      3413/iobroker.js-co
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6460       721/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      105        6486       704/influxd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          6462       721/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24552      3431/io.admin.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      105        4709       704/influxd
                    tcp6       0      0 :::3000                 :::*                    LISTEN      106        5804       789/grafana
                    udp        0      0 0.0.0.0:56515           0.0.0.0:*                           104        3932       596/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3930       596/avahi-daemon: r
                    udp6       0      0 :::48281                :::*                                104        3933       596/avahi-daemon: r
                    udp6       0      0 fe80::5d9a:7e1c:b64:546 :::*                                0          4969       671/NetworkManager
                    udp6       0      0 fe80::fb2b:3bc4:856:546 :::*                                0          6491       671/NetworkManager
                    udp6       0      0 :::5353                 :::*                                104        3931       596/avahi-daemon: r
                    2025-08-20 18:47:51.447  - info: smartmeter.1 (3821) Received 22 values, 12 updated
                    2025-08-20 18:47:52.081  - info: smartmeter.0 (3644) Received 22 values, 11 updated
                    2025-08-20 18:47:53.061  - info: host.iobroker instance system.adapter.viessmannapi.0 in version "2.3.0" started with pid 3964
                    2025-08-20 18:47:53.448  - info: smartmeter.1 (3821) Received 22 values, 8 updated
                    2025-08-20 18:47:53.811  - info: viessmannapi.0 (3964) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v22.18.0, js-controller: 7.0.7
                    2025-08-20 18:47:54.074  - info: smartmeter.0 (3644) Received 22 values, 9 updated
                    2025-08-20 18:47:55.608  - info: viessmannapi.0 (3964) 1 installations found.
                    2025-08-20 18:47:57.200  - info: host.iobroker instance system.adapter.plenticore-g3.0 in version "0.2.0" started with pid 4007
                    2025-08-20 18:47:58.245  - info: plenticore-g3.0 (4007) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.plenticore-g3, node: v22.18.0, js-controller: 7.0.7
                    2025-08-20 18:47:58.879  - info: plenticore-g3.0 (4007) logged in to plenticore
                    2025-08-20 18:48:00.068  - info: smartmeter.0 (3644) Received 22 values, 10 updated
                    2025-08-20 18:48:00.444  - info: smartmeter.1 (3821) Received 22 values, 9 updated
                    2025-08-20 18:48:01.069  - info: host.iobroker instance system.adapter.plenticore.0 in version "2.2.0" started with pid 4039
                    2025-08-20 18:48:02.031  - info: plenticore.0 (4039) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v22.18.0, js-controller: 7.0.7
                    2025-08-20 18:48:02.041  - info: plenticore.0 (4039) [START] Starting adapter plenticore v2.2.0r237
                    2025-08-20 18:48:02.050  - info: plenticore.0 (4039) Configured Wp of panel(s) is 0
                    2025-08-20 18:48:02.051  - info: plenticore.0 (4039) [INFO] Configured polling interval: 20000
                    2025-08-20 18:48:02.080  - info: smartmeter.0 (3644) Received 22 values, 8 updated
                    2025-08-20 18:48:02.440  - info: smartmeter.1 (3821) Received 22 values, 10 updated
                    2025-08-20 18:48:03.193  - info: plenticore-g3.0 (4007) init completed
                    2025-08-20 18:48:03.531  - info: plenticore.0 (4039) Not enabling forecast data.
                    2025-08-20 18:48:03.532  - info: plenticore.0 (4039) Not enabling MinSoC forecast data.
                    2025-08-20 18:48:03.772  - info: plenticore-g3.0 (4007) check for update
                    2025-08-20 18:48:08.077  - info: smartmeter.0 (3644) Received 22 values, 12 updated
                    2025-08-20 18:48:08.449  - info: smartmeter.1 (3821) Received 22 values, 10 updated
                      Pending Updates: 86
                      Hau die drauf...
                      Und halt das System dann regelmäßig auf dem aktuellen Stand.
                        @thomas-braun habe update drüberlaufen lassen aber immer noch?!
                        Pending Updates: 56
                          @sral74
                          sudo apt update
                          sudo apt full-upgrade
                          sagt?
                          Und auch mal rebooten:
                          sudo reboot
                            @thomas-braun lars@iobroker:~
                            ... ein paar errors tauchen auf (P.s.: wie kann consolen ausgaben/eingaben als seperaten Bereich hier ins forum Posten. also die schwarz hinterlegten Felder)
                            $ sudo apt full-upgrade
                            Reading package lists... Done
                            Building dependency tree... Done
                            Calculating upgrade... Done
                            The following NEW packages will be installed:
                              libdtovl0 libgpiolib0 linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.34+rpt-rpi-2712
                              linux-headers-6.12.34+rpt-rpi-v8 linux-image-6.12.34+rpt-rpi-2712 linux-image-6.12.34+rpt-rpi-v8
                              linux-kbuild-6.12.34+rpt
                            The following packages will be upgraded:
                              busybox debian-archive-keyring distro-info-data influxdb initramfs-tools initramfs-tools-core kms++-utils
                              libabsl20220623 libavif15 libblockdev-crypto2 libblockdev-fs2 libblockdev-loop2 libblockdev-part-err2
                              libblockdev-part2 libblockdev-swap2 libblockdev-utils2 libblockdev2 libc-l10n libcap2 libcap2-bin libgnutls30
                              libgssapi-krb5-2 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libpython3.11 libpython3.11-minimal
                              libpython3.11-stdlib libqt5core5a libssl3 libudisks2-0 libwbclient0 libxml2 linux-headers-rpi-2712
                              linux-headers-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 locales net-tools openssh-client openssh-server
                              openssh-sftp-server openssl pastebinit python3.11 python3.11-minimal python3.11-venv raspberrypi-sys-mods
                              raspi-config raspi-firmware raspi-utils raspi-utils-core raspi-utils-dt raspi-utils-eeprom raspi-utils-otp raspinfo
                              rpi-eeprom ssh sudo udisks2 wireless-regdb
                            62 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 0 B/143 MB of archives.
                            After this operation, 206 MB of additional disk space will be used.
                            Do you want to continue? [Y/n] y
                            Reading changelogs... Done
                            Extracting templates from packages: 100%
                            Preconfiguring packages ...
                            (Reading database ... 82278 files and directories currently installed.)
                            Preparing to unpack .../00-influxdb_1.11.8-2_arm64.deb ...
                            Unpacking influxdb (1.11.8-2) over (1.6.7~rc0-1+b13) ...
                            dpkg: error processing archive /tmp/apt-dpkg-install-6rVuF0/00-influxdb_1.11.8-2_arm64.deb (--unpack):
                             trying to overwrite '/usr/bin/influx', which is also in package influxdb-client 1.6.7~rc0-1+b13
                            dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                            Preparing to unpack .../01-libgssapi-krb5-2_1.20.1-2+deb12u3_arm64.deb ...
                            Unpacking libgssapi-krb5-2:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
                            Preparing to unpack .../02-libkrb5-3_1.20.1-2+deb12u3_arm64.deb ...
                            Unpacking libkrb5-3:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
                            Preparing to unpack .../03-libkrb5support0_1.20.1-2+deb12u3_arm64.deb ...
                            Unpacking libkrb5support0:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
                            Preparing to unpack .../04-libk5crypto3_1.20.1-2+deb12u3_arm64.deb ...
                            Unpacking libk5crypto3:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
                            Preparing to unpack .../05-libssl3_3.0.17-1~deb12u2+rpt1_arm64.deb ...
                            Unpacking libssl3:arm64 (3.0.17-1~deb12u2+rpt1) over (3.0.16-1~deb12u1+rpt1) ...
                            Preparing to unpack .../06-openssh-sftp-server_1%3a9.2p1-2+deb12u7_arm64.deb ...
                            Unpacking openssh-sftp-server (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
                            Preparing to unpack .../07-openssh-server_1%3a9.2p1-2+deb12u7_arm64.deb ...
                            Unpacking openssh-server (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
                            Preparing to unpack .../08-openssh-client_1%3a9.2p1-2+deb12u7_arm64.deb ...
                            Unpacking openssh-client (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
                            Preparing to unpack .../09-python3.11-venv_3.11.2-6+deb12u6_arm64.deb ...
                            Unpacking python3.11-venv (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                            Preparing to unpack .../10-libpython3.11_3.11.2-6+deb12u6_arm64.deb ...
                            Unpacking libpython3.11:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                            Preparing to unpack .../11-python3.11_3.11.2-6+deb12u6_arm64.deb ...
                            Unpacking python3.11 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                            Preparing to unpack .../12-libpython3.11-stdlib_3.11.2-6+deb12u6_arm64.deb ...
                            Unpacking libpython3.11-stdlib:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                            Preparing to unpack .../13-python3.11-minimal_3.11.2-6+deb12u6_arm64.deb ...
                            Unpacking python3.11-minimal (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                            Preparing to unpack .../14-libpython3.11-minimal_3.11.2-6+deb12u6_arm64.deb ...
                            Unpacking libpython3.11-minimal:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
                            Preparing to unpack .../15-raspi-firmware_1%3a1.20250430-4~bookworm_all.deb ...
                            Unpacking raspi-firmware (1:1.20250430-4~bookworm) over (1:1.20250430-1) ...
                            Preparing to unpack .../16-sudo_1.9.13p3-1+deb12u2_arm64.deb ...
                            Unpacking sudo (1.9.13p3-1+deb12u2) over (1.9.13p3-1+deb12u1) ...
                            Preparing to unpack .../17-debian-archive-keyring_2023.3+deb12u2_all.deb ...
                            Unpacking debian-archive-keyring (2023.3+deb12u2) over (2023.3+deb12u1) ...
                            Errors were encountered while processing:
                            E: Sub-process /usr/bin/dpkg returned an error code (1)
                              influxdb-client
                              Der muss weg. Ist nicht kompatibel mit dem influxdb aus deren Repo.
                              sudo apt remove influxdb-client
                              Und die Ausgabe von
                              sudo apt update
                              möchte ich auch sehen.
                                $ sudo apt update
                                Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                45 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                  @sral74
                                  Ja, schmeiß influxdb-client raus.
                                  Siehe oben.
                                    @thomas-braun hatte ich bereits ausgeführt
                                    nochmal?
                                      @sral74
                                      Dann nochmal
                                      sudo apt update
                                        Pending Updates: 0
                                          @sral74
                                          Neugestartet?
                                            @thomas-braun Yepp
                                            grafana
                                            1126
