    4. Betatest Bright Sky v0.3.x
      ticaki Developer last edited by
      @homoran sagte in Betatest Bright Sky v0.1.x:
      2025-08-19 21:13:07.505 error Error fetching weather data: {"message":"Request failed with status code 404","name":"AxiosError","stack":"AxiosError: Request failed with status code 404\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:2090:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3207:11)\n at IncomingMessage.emit (node:events:536:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4317:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async Brightsky.weatherCurrentlyUpdate (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:361:22)\n at async Brightsky.weatherCurrentlyLoop (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:309:5)\n at async Brightsky.onReady (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:86:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, /","User-Agent":"axios/1.11.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"https://api.brightsky.dev/current_weather?lat=...&lon=....&max_dist=10000","allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":404} brightsky.0
      Mit Link meine ich - in dieser Fehlermeldung versteckt sich das:
      jetzt kopiert man den Link in den Browser und die Antwort hilft mir und auch euch weiter. Wenn die Koordinaten nicht unterstützt werden steht da: {"detail":"No sources match your criteria"}
        Homoran Global Moderator Administrators @ticaki last edited by Homoran
        @ticaki DANKE!
        ist wohl schon zu spät, da hätte ich selbst drauf kommen müssen
        ...und ja, das passiert bei dem URL aus dem Log
          ticaki Developer last edited by ticaki
          Kurzzusammengefasst:
          v0.2.0
          • dwd station id kann eingegeben werden
          • wmo station id kann eingegeben werden
          • links auf Listen für beides hinzugefügt
          • current, hourly, daily kann abgewählt werden
          • info text hinzugefügt
          bei den beiden Stations IDs kann eine kommagetrennte liste verwendet werden. 02345,01111 das ist eine prioritäten liste nicht eine anzeige liste 🙂
          Die ID's sind 5 stellig, bei Bedarf mit 0 vorne auffüllen.
          Koordinaten und die Stationen sind ein entweder oder - ist ein station ausgefüllt wird diese verwendet, wenn nicht die Koordinaten.
          EDIT: der DWD Link wurde getauscht, im ersten Link haben ein paar 100/1000 Stationen gefehlt.
            sigi234 Forum Testing Most Active @ticaki last edited by
            @ticaki sagte in Betatest Bright Sky v0.2.x:
            v0.2.0
            Läuft. Info ist da aber nicht Richtig? Current habe ich abgewählt.
            brightsky.0
            	2025-08-20 11:38:26.377	info	Adapter brightsky.0 is now ready. Weather data will be updated every 30 minutes for current weather and every 1 hours for hourly weather. Daily weather data will also be created.
            brightsky.0
            	2025-08-20 11:38:17.641	info	starting. Version 0.2.0 (non-npm: ticaki/ioBroker.brightsky#6547eca25fd5fd367f7a8918c6c91cedb52ff00c) in C:/SmartHome/node_modules/iobroker.brightsky, node: v22.18.0, js-controller: 7.0.7
            brightsky.0
            	2025-08-20 11:36:45.774	info	terminating
            brightsky.0
            	2025-08-20 11:36:45.267	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            brightsky.0
            	2025-08-20 11:36:45.266	info	terminating
            brightsky.0
            	2025-08-20 11:36:45.260	info	Got terminate signal TERMINATE_YOURSELF
              ticaki Developer @sigi234 last edited by
              @sigi234
              Ja info ist noch alt - das mache ich dann noch richtig 🙂
                @sigi234
                Ok, bin ein wenig pingelig. 😀
                Habe noch einige Null Werte:
                  @sigi234
                  2025-08-20 12:00:03.335  - info: brightsky.0 (371389) Adapter started with configuration: Position: ...,..., WMO Station ID: 11035, DWD Station ID: , Currently data disabled - Hourly data enabled. Poll interval: 1 hours - Daily data enabled., Max distance: 50000 meters.
                  2025-08-20 12:00:03.335  - info: brightsky.0 (371389) Using WMO Station ID: 11035
                  so sieht es jetzt aus - ist auf github
                  null werte stehen da weil es keine werte von der api gibt - z.B. humidity wird aktuell nicht in den Vorhersagen mit geliefert - lass ich aber drin, weil es könnte ja sein das sie ab morgen mitgeliefert werden. 🙂
                    @sigi234
                    Perfekt! 👍
                      Bin heute noch zu nix gekommen, schaff ich auch nicht.
                      Einzig etwas ist beim drübersehen aufgefallen
                      sind da die Einheiten bei daily falsch, oder die Werte?
                      Armilar 1 Reply Last reply Reply Quote 1
                      • Armilar
                        Armilar Most Active Forum Testing @Homoran last edited by Armilar
                        ja
                        Die daily.00.solar ist eine Summierung der Stundenleistung eines Tages und müsste ebenfalls kWh/m² sein
                        Die daily.00.solar_max könnte, da sie die maximale Spitze (Summe der Energie einer Stunde) innerhalb eines Tages interpretiert
                        • kWh/m²
                        oder eben, da es ein gemessener Stundenwert ist auch in (teilen wir doch mal durch 1 = 1h)
                        • kW/m² ausgedrückt werden
                          Homoran Global Moderator Administrators @Armilar last edited by Homoran
                          @armilar sagte in Betatest Bright Sky v0.2.x:
                          ist es das?
                          ich würde es als die maximale Sonnenleistung des Tages interpretieren, also reine kW/m²
                          Armilar T 2 Replies Last reply Reply Quote 1
                          • Armilar
                            prognostiziert ist wohl der bessere Begriff für einen Forecast der kommenden Stunden
                            EDIT: würde den auch als reine kW/m² darstellen
                            Tatsächliche Einheit für Stunden ist allerdings wie folgt angegeben:
                            Wäre aber ebenfalls so wie du das bereits interpretierst auch die maximale Sonneleistung eines Tages in kW/m²
                              ticaki Developer @Homoran last edited by ticaki
                              Solar ist ein summenwert und das h ist wegen müdigkeit entfernt worden - ja macht keinen Sinn - ich schreibe bei den summenwerten jetzt noch in common.names das es summenwerte sind.
                              Edit: Ich hab das h jetzt hin gemacht, wenn ihr euch geeinigt habe, mache ich es dann so wie ihr sagt 😄
                              EDIT2:
                              ausserdem sunrise und sunset zu daily hinzugefügt, wird aus den Koordinaten berechnet.
                              Homoran 1 Reply Last reply Reply Quote 2
                                woher nimmst du das?
                                Ich hab leider auch nur mein "Gefühl" und keine Fakten.
                                Hier ein kräftig auf allen Beinen hinkendes Beispiel:
                                Die höchste Sonnenleistung auf meiner Solaranlage waren 4.35 kW / 23m²
                                Bei einem Wirkungsgrad von knapp 25% wären das etwa 0.756kW/m² Sonnenleistung
                                ohne jegliches Summieren
                                passt also hervorragend zu dem Adapterwert
                                  Ich glaube ich hab gerade nen Knoten im Kopf - Ich summiere die Stunden kWh/m2 werte und erhalte dann den geschätzten Tageswert. das sind dann kwh/m2/tag also was der zähler im schrank sich an einem tag bewegt.
                                    @ticaki das ist radiation! die ist in kWh/m²
                                    ich rede von solar Max, die ist IMHO keine Summe, und ein einmaliger Leistungswert in kW/m²
                                      Das ist der höchste Stundenwert der rein kommt. Daily wird aus STundenwerten berechnet und alle mix max werte sind jeweils der kleinste bzw. höchste Stundenwert.
                                        also ein Zeitraum?
                                        Da müssten wir mal bei einen Bier lange drüber sprechen
                                        ich behaupte es ist ein Momentanwert, ggf. wenige Minuten.
                                        Der maximale Wert eben
                                        Armilar T 2 Replies Last reply Reply Quote 0
                                        • Armilar
                                          Denke das trifft es:
                                          EDIT war etwas wenig Überschrift 😉
                                            @armilar ja!
                                            Natürlich liegt der max Wert auch in einer Stunde.
                                            bei optimalem Verlauf hast du einen Parabelverlauf mit einen Maximum.
                                            Wenn du die Parabel in einstündige Timeslices teilst liegt das Maximum in einem Slice, ist aber nach meinem Verständnis nicht die Summe davon
                                            EDIT
                                            demnach doch eine Summe 🤔
                                            EDIT2
                                            aber beim Tag dann doch nicht 😂
                                            2608
