    4. Test Adapter MercedesMe v0.0.x
    • Thomas M. 0
      Thomas M. 0 last edited by
      gerade update von 0.3.8 - Beta.1 auf 0.3.8
      Es funzt wieder! Danke für die neue Version!
        MB11 last edited by
        ja funktioniert wieder mit 0.3.8 gerade eben geupdatet !
          tritor @MB11 last edited by
          bei mir leider immer noch Fehlermeldungen und nach einiger Zeit der Adpater auf Orange:
          mercedesme.0 2025-07-13 20:41:13.604	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          mercedesme.0 2025-07-13 20:41:20.697	info	Error getting GeoFence. Maybe Service is not activated
          mercedesme.0 2025-07-13 20:41:20.550	info	Start Websocket Connection
          mercedesme.0 2025-07-13 20:41:20.544	warn	{"bookedVehicles":[],"companyAddress":{"city":"xx","countryCode":"xx","houseNo":"xxx","street":"xx","zipCode":"xx"},"companyId":"xx","companyName":"xx","companyRoles":["COMPANY_ADMIN"],"fleetId":xx,"fleetName":"xx","fleetRoles" ["DRIVER"]}
          mercedesme.0 2025-07-13 20:41:20.544	warn	No fin or vin found for vehicle
          mercedesme.0 2025-07-13 20:41:20.540	info	Creating vehicle xx with xx
          mercedesme.0 2025-07-13 20:41:20.540	info	Found 2 vehicles
          mercedesme.0 2025-07-13 20:41:18.753	info	Start Login
          ps58 1 Reply Last reply Reply Quote 0
          • ps58
            ps58 @tritor last edited by
            Ich hatte seit einigen Tagen das gleiche Problem. Vehicle not found, server response: 418
            Gestern update auf Beta 3.8 und läuft wieder.
            Ist der Zähler für reconnect neu?
            Steht für Heute inzwischen auf 55
            mercedesme.0 2025-07-17 13:46:04.196 info No Data since 60 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 55
            mercedesme.0 2025-07-17 13:28:02.151 info Reconnect after refresh token. Count: 54
              chiroptera last edited by chiroptera
              Bei mir mit V0.3.8 😢
              mercedesme.0
              2025-07-17 18:59:35.438	error	Login was not successful.
              mercedesme.0
              2025-07-17 18:59:35.436	error	{"errors":[{"key":"errors.login.fail"}],"trackingId":"3935c84cd9b6643c6aec348317f7e145"}
              mercedesme.0
              2025-07-17 18:59:35.436	error	AxiosError: Request failed with status code 401
              mercedesme.0
              2025-07-17 18:59:35.434	error	Not able to get user password page
              mercedesme.0
              2025-07-17 18:59:34.369	info	Start Login
              mercedesme.0
              2025-07-17 18:59:34.005	info	starting. Version 0.3.8 (non-npm: TA2k/ioBroker.mercedesme) in /opt/iobroker/node_modules/iobroker.mercedesme, node: v20.19.1, js-controller: 7.0.6
                schlaubstar @chiroptera last edited by
                @chiroptera Nach dem selben Problem wie bei den anderen läuft es bei mir wieder nach dem ich auf 3.8 von Github aktualisiert habe. Stell doch erstmal sicher, dass Du die Mercedes.ME App läuft, Du den neuen Datenschutzbedingungen dort zugestimmt hast etc. Dann würde ich in der Adapterinstanz mal den Haken Logout setzen > Speichern neu starten > Settings > Haken "Logout" wieder entfernen > speichern und neu starten
                  chiroptera @schlaubstar last edited by
                  @schlaubstar said in Test Adapter MercedesMe v0.0.x:
                  Danke, aber App läuft, Datenschutzbedingungen sind bis auf einen Punkt (Werbung) zugestimmt und das Prozedere mit der Logout Option hat keinen Einfluss. Was mich wundert: Not able to get user password page. Genau hier scheint doch das Problem zu liegen.
                    shadow_cb @chiroptera last edited by shadow_cb
                    Leute, ich brauche Euch mal.
                    Bei mir spielt die remote-Door-lock-Funktion eine besondere Rolle beim Laden zu Hause an der Wallbox.
                    Ein IObroker-Skript prüft, ob z.B. 80% erreicht sind, öffnet dann remote über IObroker das Auto, schaltet die Wallbox dann aus, und schließt das Auto wieder zu. So entseteht beim A250€ kein Ladefehler (wenn man nur die Wallbox remote stoppt, wäre das jedes Mal der Fall).
                    Seit dem 3.8. wird aber der Status im IObroker bei mir nicht mehr richtig angezeigt. Auch wenn ich per App das Auto öffne oder per Autoschlüssel, wird immer nur 0 angezeigt (siehe roter Kreis im Screenshot). Bis zum 3.8. konnte ich sogar direkt im IObroker mit dem Eintragen einer 0 oder 1 das Auto öffnen oder schließen.
                    Bei der Öffnung der Fenster und Vorklimatisierung wird dies noch übertragen. Da steht dann jeweils 1 oder 0. Aber das brauche ich nicht. Es zeigt aber, dass die Remotefunktionen zum Teil noch funktionieren.
                    Leider kann ich nun somit aber nicht mehr vernünftig automatisiert laden 😞 😞 😞
                    Funktioniert dieser Status zur Türöffnung im IObroker bei Euch noch? Könntet Ihr das mal bei Euch testen? Dann erspare ich mir eine komplette Neuinstallation von allem. Oder habt Ihr einen Tipp? Der Neustart von Mercedes-Me im IObroker und das Deaktivieren und Aktivieren der digitalen Services in der Mercedes-App am Handy haben leider keine Lösung gebracht.
                    Selten kommt die Meldung "[{"code":"RIS_INACTIVE_SERVICES","message":"","attributesMap":[],"subErrorsList":[]}]"
                    Vielleicht hat sie damit zu tun, vielleicht auch nicht.
                    EDIT: CHATGPT sagt: "Dass die App das Öffnen/Schließen noch kann, ist ein starkes Indiz, dass der Service an sich aktiv ist – nur dein iobroker-Adapter kommt seit dem 3.8. nicht mehr an den Endpunkt ran (API geändert oder Auth-Token-Problem)."
                    Adapterversion 0.3.8
                      hssk @shadow_cb last edited by
                      @shadow_cb Interessanter workaround 😉 Habe mich an der unregelmäßig vorkommenden Ladefehlermeldung nie gestört, das das weitere Laden trotz der Fehlermeldung immer geklappt hatte. Werde bei Gelegenheit Deine Logik aber mal ausprobieren.
                      Zu Deinem Punkt: Habe es eben mal ausprobiert. Ergebnis: keine Aufschließen. Da der Sicherheit-PIN zum Aufschließen schon mal "vergessen" wurde neu eingegeben: gleiches Ergebnis. Habe dann aber gesehen, es gibt ein zweites Feld weiter unten zur PIN-Eingabe. Habe den PIN hier nochmal eingegeben. Damit hat es dann geklappt.
                      Vielleicht klappt es so ja auch bei Dir wieder.
                        shadow_cb @hssk last edited by
                        @hssk vielen lieben Dank für die Information!
                        Also geht es sogar weiterhin.
                        Freut mich sehr! Finde aber im IOBROKER nicht das Feld zur zweiten PIN-Eingabe. Kannst Du mir die Adresse in der Baumstruktur geben?
                          hssk @shadow_cb last edited by hssk
                          In den Instanz-Einstellungen. Viel Erfolg.
                            @hssk Danke Dir.
                            Leider war da meine PIN schon drin. Irgendwie klappt es doch noch nicht, dass der Türstatus richtig angezeigt wird. Ich probiere mal weiter.
                              @shadow_cb Ja, das ist auch bei mir komisch. Die beiden remote-Datenpunkte DoorOpen und DoorLock sind quasi write only. Angezeigt wird nichts (bzw. nichts korrektes). Eingaben kommen aber beim Auto korrekt an. Um den korrekten Status auszulesen funktioniert bei mir der State-Datenpunkt der einzelnen Türen z.B. doorlockstatusfrontleft. Der vom Begriff her übergreifende Datenpunkt DoorStatusOverall funktioniert hierfür interessanter Weise auch nicht.
                              Da scheint Mercedes einiges angepasst zu haben mit dem der aktuelle Adapter wohl noch nicht richtig umgehen kann.
                              mercedes
                              120
                              935
                              243239
