    4. Frigate Adapter für ioBroker
      BenjaminCz @wendy2702 last edited by
      @wendy2702 Ok das ist der Fehler. Habe nun Richtig eingetragen. Danke!
      Aber kommt leider jetzt ein anderer Fehler:
      IOBroker lauft per HTTPS und Frigate auch per HTTPS (port 8971)
      frigate.0
      	2025-03-17 22:08:23.287	error	"<html>\r\n<head><title>401 Authorization Required</title></head>\r\n<body>\r\n<center><h1>401 Authorization Required</h1></center>\r\n<hr><center>nginx/1.25.3</center>\r\n</body>\r\n</html>\r\n"
      frigate.0
      	2025-03-17 22:08:23.286	error	AxiosError: Request failed with status code 401
      frigate.0
      	2025-03-17 22:08:23.286	warn	createCameraDevices error from http://192.168.178.18:8971/api/config
      frigate.0
      	2025-03-17 22:08:23.280	info	Create Device information and fetch Event History
      frigate.0
      	2025-03-17 22:08:21.008	warn	AxiosError: Request failed with status code 401
      frigate.0
      	2025-03-17 22:08:21.007	warn	fetchEventHistory error from http://192.168.178.18:8971/api/events
      frigate.0
      	2025-03-17 22:08:20.998	info	frigate.0 (12721) MQTT client frigate subscribed to topics: frigate/# from broker 003c41bd-eba6-4370-a138-c6d37204433d
      frigate.0
      	2025-03-17 22:08:20.962	info	Filter for message from client: frigate
      frigate.0
      	2025-03-17 22:08:20.961	info	New client: frigate
      frigate.0
      	2025-03-17 22:08:18.177	info	If you don't see a new client connected, please restart frigate and adapter.
      frigate.0
      	2025-03-17 22:08:18.176	info	Please enter host: 'IOBroker' and port: '1883' in frigate config
      frigate.0
      	2025-03-17 22:08:18.176	info	MQTT server started and listening on port 1883
      frigate.0
      	2025-03-17 22:08:18.090	warn	You are using the UI port 8971. Please use the API port 5000
      frigate.0
      	2025-03-17 22:08:18.077	info	starting. Version 1.3.1 (non-npm: iobroker-community-adapters/ioBroker.frigate#877e22a2d453de02d840835ec3e3db025509d22c) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.19.0, js-controller: 7.0.6
      host.IOBroker
      	2025-03-17 22:08:17.298	info	instance system.adapter.frigate.0 in version "1.3.1" (non-npm: iobroker-community-adapters/ioBroker.frigate#877e22a2d453de02d840835ec3e3db025509d22c) started with pid 12721
      host.IOBroker
      	2025-03-17 22:08:13.985	info	instance system.adapter.frigate.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.IOBroker
      	2025-03-17 22:08:13.499	info	stopInstance system.adapter.frigate.0 send kill signal
      frigate.0
      	2025-03-17 22:08:13.446	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      frigate.0
      	2025-03-17 22:08:13.445	info	terminating
      frigate.0
      	2025-03-17 22:08:13.444	info	Got terminate signal TERMINATE_YOURSELF
      host.IOBroker
      	2025-03-17 22:08:13.442	info	stopInstance system.adapter.frigate.0 (force=false, process=true)
        BenjaminCz @BenjaminCz last edited by
        @benjamincz Ok Adapter geht wohl nicht mit authentifikation sondern nur über port 5000. Ich habe den Port aber deaktiviert muss ich daher wieder aktivieren und Probiere es nocheinmal.
        • wendy2702
          wendy2702 @BenjaminCz last edited by
          @benjamincz warum braucht man im Heimnetzwerk https und Authenticaton ?
            @wendy2702 Ok danke jetzt Funktioniert alles ohne fehler. Da habe ich mir selbst ein bein gestellt. Eine frage hätte ich noch kann ich nun über blockly direkt die Snapshots abgreifen und weiterverarbeiten bzw. per mail oder Gotify senden oder bedarf es einer umkonvertierung des Snapshots ? Kurzum will einfach bei Bewegung das Snapshot z.b per Mail oder Gotify weiter senden.
            • wendy2702
              @benjamincz ich versende direkt per Adapter und Telegramm.
              Noch nicht mit beschäftigt das mit etwas anderem zu versenden
                Hallo Unter events History werden immer die letzten 10 events Angezeigt Richtig es werden nicht mehr ? Dann gibts es unten noch die json datei. Wird hier immer das letzte event hinterlegt oder wozu dient diese datei ? Evtl kann ich von dort das letzte event abgreifen von der letzen Kamera und muss nicht dann die 10 events anlegen.
                Vieleicht hat ja einer ein Blockly wo die events weiterverarbeitet werden. Gotify habe ich soweit fertig es werden auch Bilder angezeigt und der Link mit dem Video wird auch versendet. Es geht also nur um die Zwischenverarbeitung Frigate Adapter>Blockly>Gotify/Email ect.
                Vielen Dank!
                  kuumaur last edited by
                  Moin,
                  ist es möglich die Notification via Blockly zu aktivieren oder zu deaktivieren?
                  Ich benötige nicht immer die Notifications. Eigentlich nur, wenn ich nicht zu hause bin.
                    crunchip Forum Testing Most Active last edited by crunchip
                    @Wal @tombox
                    hab mal ein Anliegen,
                    Adapter v1.3.2
                    genutzt wurde Frigate 0.15.1 und hab gestern auf 0.16.0 aktualisiert. Jedoch ist mir aufgefallen ( auch schon mit der v0.15 ) das zig Unterordner in den History Ordnern angelegt wurden, ergo hatte ich über 32000 Objekte. Hab mal den kompletten Baum gelöscht und bin nun schon wieder bei über 16000.
                    siehe
                    und das gleich nochmal bei jeder cam
                    bei 3 cams
                    • Wal
                      Wal Developer @crunchip last edited by Wal
                      @crunchip ,
                      habe mit dem neuen Adapter nichts mehr zu tun. 👼
                      edit: Du nutzt bestimmt den Mosquitto ?
                      crunchip 1 Reply Last reply Reply Quote 1
                        crunchip Forum Testing Most Active @Wal last edited by
                        @wal das hatte ich dann auch gesehen, aber schon auf absenden gedrückt
                        naja, den frigatte integrierten auf port 1983
                        anderweitig hab ich nen externen mqtt auf port 1883
                        • V
                          virFortis @wendy2702 last edited by virFortis
                          @wendy2702 Hi, hast du das Problem in den Griff bekommen?
                          Ich habe jetzt dem Umstieg von Raspberry auf Windows hinter mir. Iobroker läuft auf einem Windows Tablet und Frigate auf dem Raspberry weiter.
                          Vorher hat mir Frigate dann die Bilder weiter an Telegram geschickt, jetzt mit der neuen Config bekomme ich die Meldung:
                          "Notification sending active but no image available for type person state Event After" - wie bei dir. Unter Objekten ist das Bild aber auch gespeichert und sichtbar.
                          • wendy2702
                            wendy2702 @virFortis last edited by
                            @virfortis Ich nutze Frigate nicht mehr.
                            H V 2 Replies Last reply Reply Quote 0
                              Hansi1234 @wendy2702 last edited by
                              @wendy2702 said in Frigate Adapter für ioBroker:
                              Was benutzt du nun?
                              • V
                                @wendy2702 danke für die Antwort. Ich habe es doch hinbekommen..ich habe den snapshots in der config vom iobroker noch zusätzlich aktiviert und siehe jetzt kommen auch die Bilder an.
                                • wendy2702
                                  wendy2702 @Hansi1234 last edited by
                                  @hansi1234 sagte in Frigate Adapter für ioBroker:
                                  Was benutzt du nun?
                                  Objekt Erkennung der Reolink Kameras Haupt-sächlich weil ich die Anzahl der VMs/CTs reduzieren möchte und mir die Erkennung der Kameras reicht.
                                  367
                                  99088
