      Kami last edited by
      Ich schaffe es irgendwie nicht einen Wert vom submenu an SetValue zu übergeben.
      Das sollte doch mit ! gehen oder?
      Versuchsweise habe ich es mit {value} auch probiert, aber das hat leider auch nicht geklappt.
      Kann da mal wer schauen der sich auskennt?
      Was dann passiert ist ich bekomme den text ! oder {value} in mein objekt geschrieben.
      Das Log dazu ist:
      telegram-menu.0
      2025-08-21 15:45:05.369	debug	Telegram response : "["{\"1309636133\":2972}"]"
      telegram-menu.0
      2025-08-21 15:45:05.241	debug	Groups with searched User: ["Hauptmenu"]
      telegram-menu.0
      2025-08-21 15:45:05.241	debug	Menu found
      telegram-menu.0
      2025-08-21 15:45:05.240	debug	Submenu : {"text":"Rolladen aktuell: 99% (0%=zu, 100%=offen)","keyboard":{"inline_keyboard":[[{"text":"100%","callback_data":"submenu:percent10,100:RolloPct"},{"text":"90%","callback_data":"submenu:percent10,90:RolloPct"},{"text":"80%","callback_data":"submenu:percent10,80:RolloPct"},{"text":"70%","callback_data":"submenu:percent10,70:RolloPct"},{"text":"60%","callback_data":"submenu:percent10,60:RolloPct"},{"text":"50%","callback_data":"submenu:percent10,50:RolloPct"},{"text":"40%","callback_data":"submenu:percent10,40:RolloPct"},{"text":"30%","callback_data":"submenu:percent10,30:RolloPct"}],[{"text":"20%","callback_data":"submenu:percent10,20:RolloPct"},{"text":"10%","callback_data":"submenu:percent10,10:RolloPct"},{"text":"0%","callback_data":"submenu:percent10,0:RolloPct"}]]},"device":"RolloPct"}
      telegram-menu.0
      2025-08-21 15:45:05.240	debug	Return text was modified from "Rolladen aktuell: {status:'alias.0.Rollo_oben.targetValue':true}% (0%=zu, 100%=offen)" to "Rolladen aktuell: 99% (0%=zu, 100%=offen)"
      telegram-menu.0
      2025-08-21 15:45:05.195	debug	Menu : [["menu:percent10:RolloPct:"],[""]]
      telegram-menu.0
      2025-08-21 15:45:05.195	debug	Submenu: [["menu:percent10:RolloPct:"],[""]]
      telegram-menu.0
      2025-08-21 15:45:05.195	debug	Menu to Send: [["menu:percent10:RolloPct:"],[""]]
      telegram-menu.0
      2025-08-21 15:45:05.194	debug	Nav : {"Übersicht":{"nav":[["Test","Rollo %","Rollo ⬆️","Rollo ⬇️","Stop 🛑"],["Beschwalbung Aus","Beschwalbung An"],["Heizung Diagramm","Full Diagramm"]],"text":"Wähle eine Aktion","parse_mode":false},"Rollo %":{"nav":[["menu:percent10:RolloPct:"],[""]],"text":"Rolladen aktuell: {status:'alias.0.Rollo_oben.targetValue':true}% (0%=zu, 100%=offen)","parse_mode":false},"Beschwalbung An":{"switch":[{"id":"0_userdata.0.Beschwalbung","value":"true","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"Beschwalbung Aus":{"switch":[{"id":"0_userdata.0.Beschwalbung","value":"false","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"Rollo ⬆️":{"switch":[{"id":"alias.0.Rollo_oben.Up","value":"true","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"Rollo ⬇️":{"switch":[{"id":"alias.0.Rollo_oben.Down","value":"true","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"Stop 🛑":{"switch":[{"id":"alias.0.Rollo_oben.Down","value":"false","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false},{"id":"alias.0.Rollo_oben.Up","value":"false","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"RolloPct":{"switch":[{"id":"0_userdata.0.doorbell_video","value":"!","toggle":false,"confirm":"false","returnText":"Rollo gestellt auf &&%","ack":false,"parse_mode":false}]},"Heizung Diagramm":{"echarts":[{"preset":"echarts.0.Kesseltemp","background":"#FFFFFF","theme":"light","filename":"echarts-temp-photo.jpg"}]},"Full Diagramm":{"echarts":[{"preset":"echarts.0.Kesseltemp_full","background":"#FFFFFF","theme":"light","filename":"echarts-temp-full-photo.jpg"}]}}
      telegram-menu.0
      2025-08-21 15:45:05.194	debug	Menu : Hauptmenu
      telegram-menu.0
      2025-08-21 15:45:10.770	debug	Groups with searched User: ["Hauptmenu"]
      telegram-menu.0
      2025-08-21 15:45:10.770	debug	Menu found
      telegram-menu.0
      2025-08-21 15:45:10.770	debug	Submenu : undefined
      telegram-menu.0
      2025-08-21 15:45:10.725	debug	Value to Set: "!"
      telegram-menu.0
      2025-08-21 15:45:10.681	debug	Value to Set: "!"
      telegram-menu.0
      2025-08-21 15:45:10.678	debug	Menu : submenu:percent10,90:RolloPct
      telegram-menu.0
      2025-08-21 15:45:10.678	debug	Call Submenu
        fritzke316 @Kami last edited by fritzke316
        @kami
        Ich hatte auch mal so einen ähnliches Problem, bei mir hat es funktioniert wenn ich das "!" gelöscht und Wert leer gelassen habe.
        Ich glaube bei früheren Versionen war es notwendig das "!" zu setzen, jetzt aber nicht mehr.
          Kami @fritzke316 last edited by Kami
          @fritzke316 said in Test Adapter telegram-menu v.1.6.x:
          @kami
          Danke für den Tipp, wenn ich das Versuche kommt bei einem String Objekt der Wert NaN und bei einem Number Objekt der Wert (null)
          Es schaut schon besser aus, in Log steht Value to Set: "70", aber direkt danach kommt dann noch ein Value to Set: "NaN", Der dann mein Wert überschreibt.
          Der Log schaut dann so aus:
          2025-08-21 18:31:17.395 - silly: telegram-menu.0 (2071774) States user redis pmessage telegram.0.communicate.requestMessageId/telegram.0.communicate.requestMessageId:{"val":2990,"ack":true,"ts":1755793877395,"q":0,"from":"system.adapter.telegram.0","user":"system.user.admin","lc":1755793798187}
          2025-08-21 18:31:17.437 - silly: telegram-menu.0 (2071774) States user redis pmessage telegram.0.communicate.requestChatId/telegram.0.communicate.requestChatId:{"val":1309636133,"ack":true,"ts":1755793877436,"q":0,"from":"system.adapter.telegram.0","user":"system.user.admin","lc":1755629207570}
          2025-08-21 18:31:17.437 - silly: telegram-menu.0 (2071774) States user redis pmessage telegram.0.communicate.request/telegram.0.communicate.request:{"val":"[Kami]submenu:percent10,70:RolloPct","ack":true,"ts":1755793877436,"q":0,"from":"system.adapter.telegram.0","user":"system.user.admin","lc":1755793877436}
          2025-08-21 18:31:17.481 - debug: telegram-menu.0 (2071774) Menu : Hauptmenu
          2025-08-21 18:31:17.481 - debug: telegram-menu.0 (2071774) Nav : {"Übersicht":{"nav":[["Test","Rollo %","Rollo ⬆️","Rollo ⬇️","Stop 🛑"],["Beschwalbung Aus","Beschwalbung An"],["Heizung Diagramm","Full Diagramm"]],"text":"Wähle eine Aktion","parse_mode":false},"Rollo %":{"nav":[["menu:percent10:RolloPct:"],[""]],"text":"Rolladen aktuell: {status:'alias.0.Rollo_oben.targetValue':true}% (0%=zu, 100%=offen)","parse_mode":false},"Beschwalbung An":{"switch":[{"id":"0_userdata.0.Beschwalbung","value":"true","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"Beschwalbung Aus":{"switch":[{"id":"0_userdata.0.Beschwalbung","value":"false","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"Rollo ⬆️":{"switch":[{"id":"alias.0.Rollo_oben.Up","value":"true","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"Rollo ⬇️":{"switch":[{"id":"alias.0.Rollo_oben.Down","value":"true","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"Stop 🛑":{"switch":[{"id":"alias.0.Rollo_oben.Down","value":"false","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false},{"id":"alias.0.Rollo_oben.Up","value":"false","toggle":false,"confirm":"false","returnText":"-","ack":false,"parse_mode":false}]},"RolloPct":{"switch":[{"id":"0_userdata.0.example_state","value":"","toggle":false,"confirm":"false","returnText":"Rollo gestellt auf &&%","ack":false,"parse_mode":false}]},"Heizung Diagramm":{"echarts":[{"preset":"echarts.0.Kesseltemp","background":"#FFFFFF","theme":"light","filename":"echarts-temp-photo.jpg"}]},"Full Diagramm":{"echarts":[{"preset":"echarts.0.Kesseltemp_full","background":"#FFFFFF","theme":"light","filename":"echarts-temp-full-photo.jpg"}]}}
          2025-08-21 18:31:17.482 - debug: telegram-menu.0 (2071774) Call Submenu
          2025-08-21 18:31:17.482 - debug: telegram-menu.0 (2071774) Menu : submenu:percent10,70:RolloPct
          2025-08-21 18:31:17.483 - debug: telegram-menu.0 (2071774) Value to Set: "70"
          2025-08-21 18:31:17.525 - silly: telegram-menu.0 (2071774) States user redis pmessage 0_userdata.0.example_state/0_userdata.0.example_state:{"val":"70","ack":false,"ts":1755793877525,"q":0,"from":"system.adapter.telegram-menu.0","user":"system.user.admin","lc":1755793877525}
          2025-08-21 18:31:17.527 - debug: telegram-menu.0 (2071774) Value to Set: "NaN"
          2025-08-21 18:31:17.569 - silly: telegram-menu.0 (2071774) States user redis pmessage 0_userdata.0.example_state/0_userdata.0.example_state:{"val":"NaN","ack":false,"ts":1755793877568,"q":0,"from":"system.adapter.telegram-menu.0","user":"system.user.admin","lc":1755793877568}
          2025-08-21 18:31:17.570 - debug: telegram-menu.0 (2071774) Submenu : undefined
          2025-08-21 18:31:17.570 - debug: telegram-menu.0 (2071774) Menu found
          2025-08-21 18:31:17.570 - debug: telegram-menu.0 (2071774) Groups with searched User: ["Hauptmenu"]
          • TbsJah
            TbsJah @Michael Roling last edited by
            @michael-roling said in Test Adapter telegram-menu v.1.6.x:
            @tbsjah Ich verstehe die Frage nicht. Sorry
            Ich möchte den Wert eines Datenpunktes aus einer Kombination von statischen Text und dem Wert aus der dynSwitch Eingabe befüllen.
            Beispiel
            Statischer Text: {"state" : "ON", "ontime" :
            Wert dynSwitch: 60
            Statischer Text: }
            • Michael Roling
              Michael Roling Developer @TbsJah last edited by
              @tbsjah mach das doch mit blockly oder javascript
              TbsJah 1 Reply Last reply Reply Quote 0
              • Michael Roling
                Michael Roling Developer @Kami last edited by Michael Roling
                @kami 2e70492e-4267-4ead-bf27-46ff52821c3b-image.png Da muss schon mal das ! raus bei Value
                Ich sehe das da ein Bug drin ist, werde ich mir direkt mal anschauen
                • TbsJah
                  Mache ich bereits 👍
                  Wäre so aber eleganter
                  • Michael Roling
                    @kami Bitte einmal von Github installieren
                    TbsJah K 2 Replies Last reply Reply Quote 0
                    • TbsJah
                      @michael-roling Wie wäre der richtige Befehl?
                        Kami @Michael Roling last edited by
                        Ja super, jetzt klappt's!
                        Vielen Dank 🙏
                          deta Most Active last edited by
                          habe gerade festgestellt, das die Ausgabe mit einmal nicht mehr funktioniert.
                          Er zeigt nicht mehr an ob die Pumpe nun an oder aus ist.
                          Es kommt nur:
                          Es hat perfekt schon funktioniert.
                          • Michael Roling
                            Michael Roling Developer @deta last edited by
                            @deta mach bitte ein Issue auf mit allen Informationen usw. Dann schaue ich mir das an
                              deta Most Active @Michael Roling last edited by
                              @michael-roling sagte in Test Adapter telegram-menu v.1.6.x:
                              aufgemacht
                                BobBruni last edited by BobBruni
                                Telegram-Menu Version: 3.1.2
                                Bei mir funktioniert die Textausgabe ebenfalls nicht mehr richtig.
                                Meine Einstellungen:
                                Ausgabe früher:
                                Ausgabe aktuell:
                                Sprich, es wird nur noch der Zeitstempel angezeigt...
                                • Michael Roling
                                  Michael Roling Developer @BobBruni last edited by
                                  @bobbruni bitte Issue erstellen, mit allen Informationen.
                                    BobBruni @Michael Roling last edited by
                                    @michael-roling
                                    Danke, das läuft wieder!
                                    Allerdings habe ich gerade bemerkt, dass Events nicht mehr ausgelöst werden...
                                    Muss ich hier ebenfalls was ändern?
                                    Danke, Gruß
                                    • Michael Roling
                                      @bobbruni erstelle auch da mal ein Issue, dann schaue ich mir das auch mal an
                                      1795
                                      790079
