    4. js Controler auf 7.07 geht nicht Fehlermeldung iOb
      Thomas Braun Most Active @marcel-drzal last edited by Thomas Braun
      @marcel-drzal
      Und wie immer: NIE, NIE, NIE als root herumkaspern.
      marcel-drzal 1 Reply Last reply Reply Quote 1
      • marcel-drzal
        marcel-drzal @Thomas Braun last edited by marcel-drzal
        auch als user geht es nicht
        apt-listchanges: News
        openssh (1:10.0p1-1) unstable; urgency=medium
          OpenSSH 10.0p1 includes a number of changes that may affect existing
          configurations:
           * This release removes support for the weak DSA signature algorithm,
             completing the deprecation process that began in 2015 (when DSA was
             disabled by default) and repeatedly warned over the last 12 months.
           * scp(1), sftp(1): pass "ControlMaster no" to ssh when invoked by scp &
             sftp. This disables implicit session creation by these tools when
             ControlMaster was set to yes/auto by configuration, which some users
             found surprising. This change will not prevent scp/sftp from using an
             existing multiplexing session if one had already been created.
           * sshd(8): this release disables finite field (a.k.a modp) Diffie-Hellman
             key exchange in sshd by default. Specifically, this removes the
             "diffie-hellman-group*" and "diffie-hellman-group-exchange-*" methods
             from the default KEXAlgorithms list. The client is unchanged and
             continues to support these methods by default.
        hängt an der Stelle, was muss ich hier machen?
          @marcel-drzal sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
          Mit q aus der Nachricht raus...
          marcel-drzal 1 Reply Last reply Reply Quote 0
          • marcel-drzal
            @thomas-braun said in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
            470 upgraded, 165 newly installed, 34 to remove and 0 not upgraded.
            Need to get 0 B/341 MB of archives.
            After this operation, 743 MB of additional disk space will be used.
            Do you want to continue? [Y/n] Y
            Reading changelogs... Done
            apt-listchanges: Mailing root: apt-listchanges: news for iobroker
            Extracting templates from packages: 100%
            Preconfiguring packages ...
            (Reading database ... 43860 files and directories currently installed.)
            Preparing to unpack .../base-files_13.8_amd64.deb ...
            * The base-files package cannot be installed because
            * /bin is a directory, but should be a symbolic link.
            * Please install the usrmerge package to convert this system to merged-/usr.
            * For more information please read https://wiki.debian.org/UsrMerge.
            dpkg: error processing archive /var/cache/apt/archives/base-files_13.8_amd64.deb (--unpack):
             new base-files package pre-installation script subprocess returned error exit status 1
            Errors were encountered while processing:
            E: Sub-process /usr/bin/dpkg returned an error code (1)
            marcel@iobroker:~$
            was ist das noch für ein error?
            Jetzt hat sich auch der js-controler auf 7.0.7 geändert Danke dir das hat schon mal geklappt 👏
            Installieren von Adapter myuplink gibt unten noch Fehlermeldungen, kannst du mir da helfen. Danke dir
            $ iobroker add myuplink auto --host iobroker --debug
            NPM version: 10.9.3
            Installing iobroker.myuplink@0.8.4... (System call)
            added 1 package in 4s
            408 packages are looking for funding run `npm fund` for details
            host.iobroker install adapter myuplink
            upload [12] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [11] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [10] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [9] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [8] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [6] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [5] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [4] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [3] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [2] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [1] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/jsonConfig.json jsonConfig.json application/json
            upload [0] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/myuplink.png myuplink.png image/png
            host.iobroker object system.adapter.myuplink created/updatedUpdating objects from io-package.json for adapter "myuplink" with version "0.8.4"
            host.iobroker object system.adapter.myuplink.0.compactMode created
            host.iobroker object system.adapter.myuplink.0.cpu created
            host.iobroker object system.adapter.myuplink.0.cputime created
            host.iobroker object system.adapter.myuplink.0.memHeapUsed created
            host.iobroker object system.adapter.myuplink.0.memHeapTotal created
            host.iobroker object system.adapter.myuplink.0.memRss created
            host.iobroker object system.adapter.myuplink.0.uptime created
            host.iobroker object system.adapter.myuplink.0.inputCount created
            host.iobroker object system.adapter.myuplink.0.outputCount created
            host.iobroker object system.adapter.myuplink.0.eventLoopLag created
            host.iobroker object system.adapter.myuplink.0.sigKill created
            host.iobroker object system.adapter.myuplink.0.logLevel created
            host.iobroker object myuplink.0.info created
            host.iobroker object myuplink.0.info.connection created
            host.iobroker object myuplink.0.info.currentError created
            host.iobroker object myuplink.0.info.updateTime created
            host.iobroker object myuplink.0.info.lastError created
            host.iobroker Set default value of myuplink.0.info.currentError:
            host.iobroker Set default value of myuplink.0.info.updateTime:
            host.iobroker Set default value of myuplink.0.info.lastErrorTime:
            host.iobroker object system.adapter.myuplink.0 created
            Process exited with code 0
            haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
            • haselchen
              haselchen Most Active @marcel-drzal last edited by
              @marcel-drzal
              Zeig nochmal bitte nen aktuelles
              iob diag
                ZUERST musst du die windschiefe Basis in Ordnung bringen. Auf das wackelige Fundament setzt man doch keinen Dienst drauf.
                • mcm1957
                  mcm1957 last edited by
                  @marcel-drzal
                  Die deinem Problem zugrunde liegende Fehlermeldung ist folgende:
                  error: host.iobroker iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.18.0"}npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-22T13_13_53_260Z-debug-0.log
                  2025-08-22 15:13:55.721 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.myuplink@0.8.4: 1
                  2025-08-22 15:13:56.732 - info: host.iobroker iobroker exit 25
                  2025-08-22 15:14:49.833 - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T14:14:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                  2025-08-22 15:14:50.069 - info: host.iobroker Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                  2025-08-22 15:14:58.547 - info: host.iobroker iobroker upgrade yahka@1.1.5 --debug
                  2025-08-22 15:14:59.206 - info: host.iobroker iobroker Update yahka from @1.0.3 to @1.1.5
                  2025-08-22 15:14:59.275 - info: host.iobroker iobroker NPM version: 10.9.3
                  2025-08-22 15:14:59.275 - info: host.iobroker iobroker Installing iobroker.yahka@1.1.5... (System call)
                  2025-08-22 15:15:05.132 - info: host.iobroker iobroker added 1 package, removed 1 package, and changed 19 packages in 6s408 packages are looking for funding run `npm fund` for details
                  2025-08-22 15:15:06.399 - error: host.iobroker iobroker Cannot install "pam-devel": WARNING: apt does not have a stable CLI interface. Use with caution in scripts.E: Unable to locate package pam-devel
                  2025-08-22 15:15:06.399 - error: host.iobroker iobroker The following apt packages could not be installed: pam-devel. Please install them manually.
                  Oder extrahiert:
                  Diese wird (oder wurde?) durch YAHKA in einer Version älter als 1.1.5 ausgelöst. Da du anscheinend zwischenzeitlich yahka auf 1.1.5 gebracht hast sollte sich das primäre Problem behoben haben.
                  Was sonst noch zu sanieren wäre hat die @Thomas-Braun schon geschieben,
                  • marcel-drzal
                    @marcel-drzal
                    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
                    Und dann sind da 125 Updates in der Pipeline...
                    Und deine Paketquellen sind 'Kraut-und-Rüben'.
                    Setz da einen frischen, konsistenten Container neu auf.
                    wie kann ich die Packetquellen sauber ziehen
                    Linux iobroker 6.8.12-13-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-13 (2025-07-22T10                                             :00Z) x86_64
                    The programs included with the Debian GNU/Linux system are free software;
                    the exact distribution terms for each program are described in the
                    individual files in /usr/share/doc/*/copyright.
                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                    permitted by applicable law.
                    Last login: Fri Aug 22 15:54:52 2025 from 10.10.10.166
                    marcel@iobroker:~$   iobroker repo show
                    │ (index) │ name               │ url        │ auto upgrade │
                    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json                                             '        │ false        │
                    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-late                                             st.json' │ false        │
                    Active repo(s): Stable (default)
                    Upgrade policy: none
                    marcel@iobroker:~$
                    • marcel-drzal
                      marcel-drzal @haselchen last edited by marcel-drzal
                      @haselchen
                      ich hoffe ihr könnt mir helfen. Versuche es nun erst einmal Sauber zu ziehen und dann Updaten.
                      ========== Start marking the full check here ===========
                      ```bash
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                      Operating System: Debian GNU/Linux 11 (bullseye)
                         Static hostname: iobroker
                               Icon name: computer-container
                                 Chassis: container
                          Virtualization: lxc
                                  Kernel: Linux 6.8.12-13-pve
                            Architecture: x86-64
                      OS is similar to:
                      model name      : Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       11:54:07 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
                      CPU threads: 2
                      *** LIFE CYCLE STATUS ***
                      *** TIME AND TIMEZONES ***
                                     Local time: Sun 2025-08-24 11:54:07 CEST
                                 Universal time: Sun 2025-08-24 09:54:07 UTC
                                       RTC time: n/a
                                    NTP service: n/a
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      marcel
                      HOME=/home/marcel
                      GROUPS=marcel sudo iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server:         false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:            6.1G        1.9G        3.6G        0.0K        633M        4.3G
                      Swap:           512M          0B        512M
                      Total:          6.7G        1.9G        4.1G
                      Active iob-Instances:   23
                               6144 M total memory
                               1892 M used memory
                               1886 M active memory
                                493 M inactive memory
                               3618 M free memory
                                  0 M buffer memory
                                633 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      top - 11:54:08 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
                      Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  6.2 us,  0.0 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   6144.0 total,   3617.9 free,   1892.3 used,    633.8 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   4251.6 avail Mem
                      *** FAILED SERVICES ***
                        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
                      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
                      * influxdb.service              loaded failed failed InfluxDB is an open-source, distributed, time series database
                      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
                      LOAD   = Reflects whether the unit definition was properly loaded.
                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                      SUB    = The low-level unit activation state, values depend on unit type.
                      4 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      dmesg: read kernel buffer failed: Operation not permitted
                      No critical errors detected
                      *** FILESYSTEM ***
                      Filesystem                       Type      Size  Used Avail Use% Mounted on
                      /dev/mapper/pve-vm--160--disk--0 ext4       30G   11G   17G  39% /
                      none                             tmpfs     492K  4.0K  488K   1% /dev
                      udev                             devtmpfs   32G     0   32G   0% /dev/tty
                      tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
                      tmpfs                            tmpfs      13G  108K   13G   1% /run
                      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
                      Show mounted filesystems:
                      TARGET SOURCE                           FSTYPE OPTIONS
                      /      /dev/mapper/pve-vm--160--disk--0 ext4   rw,relatime,stripe=16
                      /var:
                      1.7G    /var/
                      709M    /var/cache
                      704M    /var/cache/apt
                      669M    /var/log
                      665M    /var/log/journal/fe2dcc346dde445a9e95482e37c85663
                      Archived and active journals take up 33.3M in the file system.
                      /opt/iobroker/backups:
                      2.2G    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      670M    /opt/iobroker/iobroker-data/
                      377M    /opt/iobroker/iobroker-data/files
                      176M    /opt/iobroker/iobroker-data/backup-objects
                      49M     /opt/iobroker/iobroker-data/files/vis.0
                      48M     /opt/iobroker/iobroker-data/files/iot.admin
                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                      26M     /opt/iobroker/iobroker-data/objects.jsonl
                      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
                      19M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      Zigbee Network Settings on your coordinator/in nvbackup are:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      To unmask the settings run 'iob diag --unmask'
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v22.18.0
                      /usr/bin/node           v22.18.0
                      /usr/bin/npm            10.9.3
                      /usr/bin/npx            10.9.3
                      /usr/bin/corepack       0.33.0
                      nodejs:
                        Installed: 22.18.0-1nodesource1
                        Candidate: 22.18.0-1nodesource1
                        Version table:
                       *** 22.18.0-1nodesource1 600
                              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                              100 /var/lib/dpkg/status
                           22.17.1-1nodesource1 600
                           22.17.0-1nodesource1 600
                           22.16.0-1nodesource1 600
                           22.15.1-1nodesource1 600
                           22.15.0-1nodesource1 600
                           22.14.0-1nodesource1 600
                           22.13.1-1nodesource1 600
                           22.13.0-1nodesource1 600
                           22.12.0-1nodesource1 600
                           22.11.0-1nodesource1 600
                           22.10.0-1nodesource1 600
                           22.9.0-1nodesource1 600
                           22.8.0-1nodesource1 600
                           22.7.0-1nodesource1 600
                           22.6.0-1nodesource1 600
                           22.5.1-1nodesource1 600
                           22.5.0-1nodesource1 600
                           22.4.1-1nodesource1 600
                           22.4.0-1nodesource1 600
                           22.3.0-1nodesource1 600
                           22.2.0-1nodesource1 600
                           22.1.0-1nodesource1 600
                           22.0.0-1nodesource1 600
                           20.19.2+dfsg-1 500
                              500 http://deb.debian.org/debian trixie/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      Checking for nodejs vulnerability:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 58433)
                      Core adapters versions
                      js-controller:  7.0.7
                      admin:          7.6.17
                      javascript:     8.9.2
                      nodejs modules from github:     1
                      +-- iobroker.luxtronik2@0.3.0 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e3a8b912a68cdb84c808a91c6a2250ae4f7ec1b9)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                        system.adapter.denon.0                  : denon                 : iobroker                                 - disabled
                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                      + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.judoisoft.0              : judoisoft             : iobroker                                 -  enabled
                      + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 10.10.50.16
                        system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 - disabled, port: 8214
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.16
                      + system.adapter.myuplink.0               : myuplink              : iobroker                                 -  enabled
                      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                      Installed ioBroker-Adapters
                      Used repository: Stable (default)
                      Adapter    "admin"        : 7.6.17   , installed 7.6.17
                      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                      Adapter    "denon"        : 1.15.12  , installed 1.15.12
                      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
                      Adapter    "homekit-controller": 0.5.11, installed 0.5.11
                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                      Controller "js-controller": 7.0.7    , installed 7.0.7
                      Adapter    "judoisoft"    : 1.1.2    , installed 1.1.2
                      Adapter    "klf200"       : 1.3.5    , installed 1.3.5
                      Adapter    "knx"          : 2.0.30   , installed 2.0.30
                      Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
                      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                      Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
                      Adapter    "myuplink"     : 0.8.4    , installed 0.8.4
                      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                      Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
                      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Adapter    "wled"         : 0.7.2    , installed 0.7.2
                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                      Objects and States
                      Objects:        8765
                      States:         6459
                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                      W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused)
                      W: Some index files failed to download. They have been ignored, or old ones used instead.
                      Hit:1 http://security.debian.org/debian-security trixie-security InRelease
                      Hit:2 http://deb.debian.org/debian trixie InRelease
                      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                      Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
                      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Err:6 https://dl.yarnpkg.co m/debian InRelease
                        Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
                      Err:4 https://repos.influxdata.com/debian buster InRelease
                      Fetched 12.9 kB in 0s (46.8 kB/s)
                      Reading package lists...
                      W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
                      Pending Updates: 125
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       22058      140/iobroker.js-con
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       17359      140/iobroker.js-con
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11038      1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21672      193/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          21795      320/master
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       32747      712/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22163      342/io.admin.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       27465      667/io.simple-api.0
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          21796      320/master
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          11040      1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          21674      193/sshd: /usr/sbin
                      udp        0      0 10.10.50.16:50137       0.0.0.0:*                           1000       435218     547/io.knx.0
                      udp        0      0 10.10.50.16:55244       0.0.0.0:*                           1000       1650387    547/io.knx.0
                      udp        0      0 10.10.50.16:57540       0.0.0.0:*                           1000       56405      547/io.knx.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16336      75/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11039      1/init
                      udp        0      0 10.10.50.16:123         0.0.0.0:*                           0          21644      172/ntpd
                      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          21642      172/ntpd
                      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          21638      172/ntpd
                      udp        0      0 10.10.50.16:33034       0.0.0.0:*                           1000       766879     547/io.knx.0
                      udp        0      0 10.10.50.16:33292       0.0.0.0:*                           1000       42281      547/io.knx.0
                      udp        0      0 10.10.50.16:33516       0.0.0.0:*                           1000       796516     547/io.knx.0
                      udp        0      0 10.10.50.16:35890       0.0.0.0:*                           1000       2015188    547/io.knx.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       34914      742/io.wled.0
                      udp        0      0 10.10.50.16:38368       0.0.0.0:*                           1000       27253      547/io.knx.0
                      udp        0      0 10.10.50.16:42227       0.0.0.0:*                           1000       144075     547/io.knx.0
                      udp        0    960 10.10.50.16:43259       0.0.0.0:*                           1000       2062242    547/io.knx.0
                      udp        0      0 10.10.50.16:43538       0.0.0.0:*                           1000       2015226    547/io.knx.0
                      udp        0      0 10.10.50.16:47107       0.0.0.0:*                           1000       1431661    547/io.knx.0
                      udp6       0      0 :::111                  :::*                                0          11041      1/init
                      udp6       0      0 fe80::7435:b2ff:fe7:123 :::*                                109        22015      172/ntpd
                      udp6       0      0 fd48:3919:e463:2897:123 :::*                                109        22013      172/ntpd
                      udp6       0      0 ::1:123                 :::*                                0          21646      172/ntpd
                      udp6       0      0 :::123                  :::*                                0          21635      172/ntpd
                      2025-08-24 11:42:49.822  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:42:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:42:56.387  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                      2025-08-24 11:42:56.430  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                      2025-08-24 11:42:56.518  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                      2025-08-24 11:43:49.845  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:43:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:44:49.836  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:44:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:45:10.007  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3952
                      2025-08-24 11:45:10.613  - info: dwd.0 (3952) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.18.0, js-controller: 7.0.7
                      2025-08-24 11:45:10.805  - info: dwd.0 (3952) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2025-08-24 11:45:11.314  - info: host.iobroker instance system.adapter.dwd.0 having pid 3952 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-08-24 11:45:49.834  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:45:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:46:49.854  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:46:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:47:49.843  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:47:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:47:56.999  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                      2025-08-24 11:47:57.042  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                      2025-08-24 11:47:57.134  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                      2025-08-24 11:48:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:48:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:49:49.839  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:49:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:50:49.820  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:50:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:51:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:51:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:52:49.858  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:52:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      2025-08-24 11:52:57.648  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                      2025-08-24 11:52:57.690  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                      2025-08-24 11:52:57.782  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                      2025-08-24 11:53:49.823  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:53:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                      iob diag has finished.
                      • marcel-drzal
                        marcel-drzal @mcm1957 last edited by
                        @mcm1957
                        Danke für deine Hilfe.
                        Yahkara nutze ich nicht mehr. hatte ich eigendlich gelöscht
                        • mcm1957
                          mcm1957 @marcel-drzal last edited by mcm1957
                          @marcel-drzal
                          Zum Zeitpunkt der Fehlermeldung war yahka aber installiert.Bist du sicher, dass du den ADAPTER und nicht nur die INSTANZ gelöscht hast?
                          EDIT:
                          Lt iob diag in commentar https://forum.iobroker.net/topic/81995/js-controler-auf-7-07-geht-nicht-fehlermeldung-iob/12 hast du jetzt yahka 1.1.5 installiert - allerdings ohne aktive instanz.
                          Du hast also offensichtlich nur die Instanz gelöscht 🙂
                          @Thomas-Braun
                          Anregung für iob diag: Warnung bei Adaptern die installiert sind aber keine Instanz besitzen wär zu überlegen.
                          marcel-drzal Thomas Braun 3 Replies Last reply Reply Quote 0
                          • marcel-drzal
                            @mcm1957
                            • mcm1957
                              @marcel-drzal
                              Yep ist installiert. Wenn du ihn nicht mehr benutzt solltest du ihn deinstallieren.
                                Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                                @mcm1957 sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                                Schwierig zu checken. Können ja auch Adapter ohne Instanz sein oder die Nummerierung ist instanz.3 oder so.
                                • mcm1957
                                  mcm1957 @Thomas Braun last edited by
                                  Also zu checken of die Instanz .0 oder .99 ist wär sicher trivial machbar.
                                  Hast du Beispiele für Adapter ohne Instanz? Da gibts sicher ein Kriterium dazu.
                                  • marcel-drzal
                                    marcel-drzal @mcm1957 last edited by marcel-drzal
                                    @mcm1957 Adapter habe ich gelöscht
                                    habe nun einen error:
                                    dpkg: error
                                     new base-files package pre-installation script subprocess returned error exit s              tatus 1
                                      @marcel-drzal
                                      dpkg ist aber das Paketmanagement auf OS-Ebene. Da ist also eine Etage tiefer schon was schief.
                                      sudo apt update
                                      sagt?
                                      • marcel-drzal
                                        direcktes uptadt aus iobroker:
                                        marcel@10.10.50.16's password:
                                        Linux iobroker 6.14.8-2-pve #1 SMP PREEMPT_DYNAMIC PMX 6.14.8-2 (2025-07-22T10:0                                                       4Z) x86_64
                                        Last login: Tue Aug 26 18:40:15 2025 from 10.10.10.166
                                        marcel@iobroker:~$ sudo apt update
                                        [sudo] password for marcel:
                                        Hit:1 http://deb.debian.org/debian trixie InRelease
                                        Get:2 http://security.debian.org/debian-security trixie-security InRelease [43.4                                                        kB]
                                        Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.1 kB]
                                        Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
                                        Get:6 http://security.debian.org/debian-security trixie-security/main amd64 Pack                                                       ages [33.1 kB]
                                        Get:7 http://security.debian.org/debian-security trixie-security/main Translatio                                                       n-en [22.0 kB]
                                          The following signatures couldn't be verified because the public key is not av                                                       ailable: NO_PUBKEY D8FF8E1F7DF8B07E
                                        Get:8 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [7803 B]
                                        Err:9 https://dl.yarnpkg.co m/debian InRelease
                                          Could not connect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connec                                                       tion refused) Could not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect                                                        (111: Connection refused)
                                        Fetched 178 kB in 1s (325 kB/s)
                                        Reading package lists... Done
                                        Building dependency tree... Done
                                        471 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                        W: An error occurred during the signature verification. The repository is not up                                                       dated and the previous index files will be used. GPG error: https://repos.influx                                                       data.com/debian buster InRelease: The following signatures couldn't be verified                                                        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  T                                                       he following signatures couldn't be verified because the public key is not avail                                                       able: NO_PUBKEY D8FF8E1F7DF8B07E
                                        W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not con                                                       nect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connection refused) C                                                       ould not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect (111: Connecti                                                       on refused)
                                        PlatformBetriebssystem:linux
                                        Architektur:x64
                                        CPUs:2
                                        Geschwindigkeit:4043 MHz
                                        Modell:unknown
                                        RAM:6 GB
                                        System-Betriebszeit:2 T. 00:15:05
                                        Node.js:v22.18.0
                                        Zeit:1756964837826
                                        Zeitversatz:-120
                                        NPM:10.9.3
                                        Adapter-Anzahl:574
                                        Datenträgergröße:29.4 GB
                                        Freier Festplattenspeicher:18.5 GB
                                        Aktive Instanzen:21
                                        Pfad:/opt/iobroker/
                                        Betriebszeit:2 T. 00:15:01
                                        aktiv:true
                                        _nodeCurrent:22.18.0
                                        _nodeNewest:22.19.0
                                        _nodeNewestNext:22.19.0
                                        _npmCurrent:10.9.3
                                        _npmNewest:10.9.3
                                        _npmNewestNext:10.9.3
                                          @marcel-drzal
                                          Hau die 471 Updates rein, verdammt.
                                          Die influxdb-Quelle ist veraltet. Leg die neu an.
                                          Geht so:
                                          https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                          Und dann schau, aus welcher Datei dieses yarn-Dingsi kommt.
                                          cd /etc/apt/
                                          grep -r yarn .
                                          Die Zeile mit dem Eintrag zu yarn würde ich löschen.
                                          • marcel-drzal
                                            habe ich bekomme hier die Meldung:
                                            Fetched 38.5 MB in 3s (11.3 MB/s)
                                            marcel@iobroker:~$
                                            1983
