    4. Neuer Adapter für Roborock-Staubsauger
    • System 9
      System 9 @ticaki last edited by
      guten morgen.
      ich bekomme fehler, da einige Datenpunkte nicht angelegt werden.
      State "roborock.0.Devices.6vZ1zawxmrZgMTxgOPtwJn.deviceStatus.carpet_clean_mode" has no existing object, this might lead to an error in future versions
      State "roborock.0.Devices.6vZ1zawxmrZgMTxgOPtwJn.deviceStatus.carpet_mode" has no existing object, this might lead to an error in future versions
      was kann ich hier machen ?
        TimoWald @System 9 last edited by
        Hallo, wieso bekomme ich meinen Adapter nicht mehr auf grün?
        Dieser Feher kommt nach dem starten.
        Was kann ich tun?
        2025-08-20 06:57:36.146 - info: host.iobroker instance system.adapter.roborock.0 in version "0.6.19" (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) started with pid 2735931
        2025-08-20 06:57:40.150 - info: roborock.0 (2735931) starting. Version 0.6.19 (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 7.0.7
        2025-08-20 06:57:40.171 - info: roborock.0 (2735931) Starting adapter. This might take a few minutes depending on your setup. Please wait.
        2025-08-20 06:57:40.187 - info: roborock.0 (2735931) Loaded existing clientID: ee6783f4-5d0a-4d48-b00e-7cafd23b31d9
        2025-08-20 06:57:40.472 - error: roborock.0 (2735931) Failed to process undefined on robot undefined (unknown device model): TypeError: Cannot read properties of null (reading 'rrHomeId')
        at http_api.getHomeID (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:111:31)
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
        at http_api.updateHomeData (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:123:19)
        at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:33:3)
        at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
        2025-08-20 06:57:40.762 - info: roborock.0 (2735931) MQTT initialized
        2025-08-20 06:57:40.763 - error: roborock.0 (2735931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2025-08-20 06:57:40.764 - error: roborock.0 (2735931) unhandled promise rejection: this.homeData is not initialized. Initialize via getHomeData() first
        2025-08-20 06:57:40.764 - error: roborock.0 (2735931) Error: this.homeData is not initialized. Initialize via getHomeData() first
        at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
        at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
        2025-08-20 06:57:40.765 - error: roborock.0 (2735931) this.homeData is not initialized. Initialize via getHomeData() first
        2025-08-20 06:57:40.779 - info: roborock.0 (2735931) terminating
        2025-08-20 06:57:40.781 - warn: roborock.0 (2735931) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2025-08-20 06:57:40.843 - info: roborock.0 (2735931) MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
        2025-08-20 06:57:41.282 - info: roborock.0 (2735931) terminating
        2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[1]: Error: this.homeData is not initialized. Initialize via getHomeData() first
        2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[1]: at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
        2025-08-20 06:57:41.438 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
        2025-08-20 06:57:41.438 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2025-08-20 06:57:41.438 - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
        2025-08-20 06:57:52.160 - info: host.iobroker "system.adapter.roborock.0" disabled
        2025-08-20 06:58:14.994 - error: roborock.0 (2735952) adapter disabled
        2025-08-20 06:58:15.040 - warn: roborock.0 (2735952) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        2025-08-20 06:58:15.723 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        2025-08-20 06:58:15.723 - info: host.iobroker Do not restart adapter system.adapter.roborock.0 because disabled or deleted
        • N
          nu_81 @Anderl 0 last edited by nu_81
          @anderl-0
          hab nun auf einmal die selben Fehler.
          Hast du das Problem schon gelöst?
            Thomas Braun Most Active @nu_81 last edited by
            @nu_81
            Versionsnummern der üblichen Verdächtigen? Alternativ die Ausgabe von
            iob diag
            posten.
            • N
              nu_81 @Thomas Braun last edited by
              @thomas-braun said in Fehler Roborock - Adapter:
              @nu_81
              Welche Verdächtigen meinst du? Kann dir leider nicht folgen.
                @nu_81
                Versionen von nodejs, js-controller usw.
                Poste einfach die Ausgabe von
                iob diag
                da steht erstmal alles drin.
                • N
                  Hier der Log.
                  Danke schonmal!
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.12.34+rpt-rpi-v8
                      Architecture: arm64
                  OS is similar to:
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   18:42:51 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Operating System is the current Debian stable version codenamed 'bookworm'!
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  ~ Under-voltage has occurred
                  ~ Arm frequency capping has occurred
                  ~ Throttling has occurred
                  ~ Soft temperature limit has occurred
                  *** TIME AND TIMEZONES ***
                                 Local time: Sat 2025-08-23 18:42:51 CEST
                             Universal time: Sat 2025-08-23 16:42:51 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pihome
                  HOME=/home/pihome
                  GROUPS=pihome adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker uosserver
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server:         false
                  Unit display-manager.service could not be found.
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:            4.0G        3.1G        281M         29M        696M        839M
                  Swap:           209M        209M        704K
                  Total:          4.2G        3.4G        282M
                  Active iob-Instances:   29
                           3796 M total memory
                           2995 M used memory
                           2252 M active memory
                           1046 M inactive memory
                            268 M free memory
                             38 M buffer memory
                            625 M swap cache
                            199 M total swap
                            199 M used swap
                              0 M free swap
                  top - 18:42:52 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
                  Tasks: 252 total,   1 running, 251 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 44.4 us, 22.2 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   3796.9 total,    268.2 free,   2996.0 used,    664.5 buff/cache
                  MiB Swap:    200.0 total,      0.7 free,    199.3 used.    800.9 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     760M  1.2M  759M   1% /run
                  /dev/mmcblk0p2 ext4       29G   17G   11G  63% /
                  tmpfs          tmpfs     1.9G  9.2M  1.9G   1% /dev/shm
                  /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                  tmpfs          tmpfs     380M   84K  380M   1% /run/user/1002
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [Sat Aug 23 13:17:08 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Sat Aug 23 13:17:11 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                  [Sat Aug 23 13:17:12 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                  Show mounted filesystems:
                  TARGET           SOURCE         FSTYPE OPTIONS
                  /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.2G    /var/
                  486M    /var/log
                  380M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
                  348M    /var/cache
                  Archived and active journals take up 379.5M in the file system.
                  /opt/iobroker/backups:
                  54M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  358M    /opt/iobroker/iobroker-data/
                  269M    /opt/iobroker/iobroker-data/files
                  68M     /opt/iobroker/iobroker-data/backup-objects
                  48M     /opt/iobroker/iobroker-data/files/iot.admin
                  47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                  24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                  15M     /opt/iobroker/iobroker-data/objects.jsonl
                  8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                  8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                  *** ZigBee Settings ***
                  Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                  Zigbee Network Settings on your coordinator/in nvbackup are:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  To unmask the settings run 'iob diag --unmask'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.19.4
                  /usr/bin/node           v20.19.4
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.32.0
                  nodejs:
                    Installed: 20.19.4-1nodesource1
                    Candidate: 20.19.4-1nodesource1
                    Version table:
                   *** 20.19.4-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                          100 /var/lib/dpkg/status
                       20.19.3-1nodesource1 1001
                       20.19.2-1nodesource1 1001
                       20.19.1-1nodesource1 1001
                       20.19.0-1nodesource1 1001
                       20.18.3-1nodesource1 1001
                       20.18.2-1nodesource1 1001
                       20.18.1-1nodesource1 1001
                       20.18.0-1nodesource1 1001
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                       18.19.0+dfsg-6~deb12u1 500
                  No problems detected
                  Errors in npm tree: 0
                  Checking for nodejs vulnerability:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 3139)
                  Core adapters versions
                  admin:          7.6.17
                  javascript:     8.9.2
                  nodejs modules from github:     1
                  +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                    system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                  + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                  + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                  + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                  + system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                  + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
                  + system.adapter.ph803w.0                 : ph803w                : raspberrypi                              -  enabled
                    system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
                  + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                    system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                  + system.adapter.tapo.0                   : tapo                  : raspberrypi                              -  enabled
                  + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                    system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                  + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Adapters
                  Used repository: stable
                  Adapter    "admin"        : 7.6.17   , installed 7.6.17
                  Adapter    "alarm"        : 3.7.0    , installed 3.7.0
                  Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                  Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                  Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                  Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                  Adapter    "denon"        : 1.15.12  , installed 1.15.12
                  Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
                  Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
                  Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                  Adapter    "ical"         : 1.16.2   , installed 1.16.1 [Updatable]
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                  Controller "js-controller": 7.0.7    , installed 7.0.7
                  Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                  Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                  Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                  Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
                  Adapter    "roborock"     : 0.6.18   , installed 0.6.18
                  Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                  Adapter    "schoolfree"   : 1.1.10   , installed 1.1.9  [Updatable]
                  Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                  Adapter    "shuttercontrol": 2.0.3   , installed 2.0.1  [Updatable]
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                  Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                  Objects and States
                  Objects:        8590
                  States:         6628
                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       448519     33748/iobroker.js-c
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       446004     33748/iobroker.js-c
                  tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6488       914/slirp4netns
                  tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6494       914/slirp4netns
                  tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6496       914/slirp4netns
                  tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6498       914/slirp4netns
                  tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       6361       730/discovery
                  tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6492       914/slirp4netns
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6107       732/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8720       856/pihole-FTL
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        8055       856/pihole-FTL
                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        8056       856/pihole-FTL
                  tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6490       914/slirp4netns
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       453005     34618/io.shelly.1
                  tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6500       914/slirp4netns
                  tcp6       0      0 :::3000                 :::*                    LISTEN      1001       448417     34233/io.fullybrows
                  tcp6       0      0 :::51989                :::*                    LISTEN      1001       449536     34424/io.nuki-exten
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          6109       732/sshd: /usr/sbin
                  tcp6       0      0 :::53                   :::*                    LISTEN      999        8722       856/pihole-FTL
                  tcp6       0      0 :::80                   :::*                    LISTEN      999        8057       856/pihole-FTL
                  tcp6       0      0 :::443                  :::*                    LISTEN      999        8058       856/pihole-FTL
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       446157     33776/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       452363     34755/io.web.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        484        553/avahi-daemon: r
                  udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6504       914/slirp4netns
                  udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6502       914/slirp4netns
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       452785     34516/io.shelly.0
                  udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       555009     730/discovery
                  udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6506       914/slirp4netns
                  udp        0      0 0.0.0.0:36782           0.0.0.0:*                           1002       552483     914/slirp4netns
                  udp        0      0 0.0.0.0:55259           0.0.0.0:*                           1001       451740     34458/io.ph803w.0
                  udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8719       856/pihole-FTL
                  udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        9782       856/pihole-FTL
                  udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       451251     34397/io.mihome-vac
                  udp        0      0 0.0.0.0:33046           0.0.0.0:*                           104        486        553/avahi-daemon: r
                  udp        0      0 192.168.2.109:33514     0.0.0.0:*                           1002       552649     730/discovery
                  udp6       0      0 :::5353                 :::*                                104        485        553/avahi-daemon: r
                  udp6       0      0 :::53                   :::*                                999        8721       856/pihole-FTL
                  udp6       0      0 :::123                  :::*                                999        9783       856/pihole-FTL
                  udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          7193       638/NetworkManager
                  udp6       0      0 :::33351                :::*                                104        487        553/avahi-daemon: r
                      at Socket.emit (node:events:524:28)
                      at Socket.emit (node:domain:489:12)
                      at UDP.onMessage (node:dgram:951:8)
                  2025-08-23 18:43:58.144  - error: roborock.0 (42090) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                  2025-08-23 18:43:58.191  - info: roborock.0 (42090) terminating
                  2025-08-23 18:43:58.193  - warn: roborock.0 (42090) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2025-08-23 18:43:58.851  - info: roborock.0 (42090) terminating
                  2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                  2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:193:29)
                  2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                  2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                  2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:524:28)
                  2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                  2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:951:8) {
                  2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
                  2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
                  2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                  2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]: }
                  2025-08-23 18:43:59.249  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2025-08-23 18:43:59.249  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                  2025-08-23 18:44:02.499  - info: tapo.0 (34846) Get camera Status failed
                  2025-08-23 18:44:02.500  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                  2025-08-23 18:44:06.991  - info: tr-064.0 (34564) forEachConfiguredDevice: in GetSpecificHostEntry 1(Gioia/B8:94:E7:E7:C5:98) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                  2025-08-23 18:44:12.515  - info: tapo.0 (34846) Get camera Status failed
                  2025-08-23 18:44:12.516  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                    Thomas Braun Most Active @nu_81 last edited by Thomas Braun
                    @nu_81 sagte in Neuer Adapter für Roborock-Staubsauger:
                    Ich habe den Verdacht, das könnte mit nodejs zusammenhängen.
                    Bring die drei Adapter auf Stand und dann ein
                    iob nodejs-update
                    B N 2 Replies Last reply Reply Quote 0
                      breaksrmine @Thomas Braun last edited by
                      Beim Adapter 0.6.18 kommt beim Roborock QV 35A folgende Fehler.
                      Steuern geht aber ohne Probleme
                      roborock.0
                      2025-08-23 19:17:02.540 warn Unsupported attribute: seq_type of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.539 warn Unsupported attribute: exit_dock of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.538 warn Unsupported attribute: cleaning_info of get_status with value [object Object]. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.458 warn Unsupported attribute: last_clean_t of get_status with value 1755969220. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.457 warn Unsupported attribute: switch_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.416 warn Unsupported attribute: kct of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.336 warn Unsupported attribute: common_status of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.335 warn Unsupported attribute: dss of get_status with value 169. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.335 warn Unsupported attribute: rss of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.334 warn Unsupported attribute: extra_time of get_status with value 1860. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.333 warn Unsupported attribute: clean_percent of get_status with value 45. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:02.172 warn Unsupported attribute: charge_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      roborock.0
                      2025-08-23 19:17:01.851 warn Unsupported attribute: in_warmup of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:01.650 warn Unsupported attribute: water_shortage_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:01.530 warn Unsupported attribute: mop_forbidden_enable of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:01.529 warn Unsupported attribute: water_box_carriage_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:01.488 warn Unsupported attribute: water_box_mode of get_status with value 207. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      roborock.0
                      2025-08-23 19:17:01.287 warn Unsupported attribute: water_box_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                      • N
                        Hallo, habe das Update durchgeführt.
                        Der Fehler bleibt jedoch leider.
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
                        CPU threads: 4
                        Current issues:
                                       Local time: Mon 2025-08-25 11:31:58 CEST
                                   Universal time: Mon 2025-08-25 09:31:58 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pihome
                        HOME=/home/pihome
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:            4.0G        3.4G         59M         25M        599M        542M
                        Swap:           2.1G        452M        1.7G
                        Total:          6.1G        3.9G        1.8G
                        Active iob-Instances:   24
                                 3796 M total memory
                                 3280 M used memory
                                 2278 M active memory
                                 1257 M inactive memory
                                   55 M free memory
                                   35 M buffer memory
                                  535 M swap cache
                                 2047 M total swap
                                  432 M used swap
                                 1615 M free swap
                        top - 11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
                        Tasks: 237 total,   1 running, 236 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3796.9 total,     52.2 free,   3283.9 used,    571.4 buff/cache
                        MiB Swap:   2048.0 total,   1616.0 free,    432.0 used.    513.0 avail Mem
                        *** FILESYSTEM ***
                        /dev/mmcblk0p2 ext4       29G   19G  8.9G  68% /
                        tmpfs          tmpfs     1.9G  6.3M  1.9G   1% /dev/shm
                        [Mon Aug 25 00:31:18 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Mon Aug 25 00:31:21 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                        [Mon Aug 25 00:31:23 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                        /var:
                        2.8G    /var/
                        476M    /var/log
                        412M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
                        172M    /var/lib
                        Archived and active journals take up 411.5M in the file system.
                        15M     /opt/iobroker/backups/
                        16M     /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/nodejs         v22.18.0
                        /usr/bin/node           v22.18.0
                        /usr/bin/npm            10.9.3
                        /usr/bin/npx            10.9.3
                        /usr/bin/corepack       0.33.0
                        nodejs:
                          Installed: 22.18.0-1nodesource1
                          Candidate: 22.18.0-1nodesource1
                          Version table:
                         *** 22.18.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                             22.17.1-1nodesource1 1001
                             22.17.0-1nodesource1 1001
                             22.16.0-1nodesource1 1001
                             22.15.1-1nodesource1 1001
                             22.15.0-1nodesource1 1001
                             22.14.0-1nodesource1 1001
                             22.13.1-1nodesource1 1001
                             22.13.0-1nodesource1 1001
                             22.12.0-1nodesource1 1001
                             22.11.0-1nodesource1 1001
                             22.10.0-1nodesource1 1001
                             22.9.0-1nodesource1 1001
                             22.8.0-1nodesource1 1001
                             22.7.0-1nodesource1 1001
                             22.6.0-1nodesource1 1001
                             22.5.1-1nodesource1 1001
                             22.5.0-1nodesource1 1001
                             22.4.1-1nodesource1 1001
                             22.4.0-1nodesource1 1001
                             22.3.0-1nodesource1 1001
                             22.2.0-1nodesource1 1001
                             22.1.0-1nodesource1 1001
                             22.0.0-1nodesource1 1001
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 39639)
                        admin:          7.6.17
                        javascript:     8.9.2
                        Adapter State
                          system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                          system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              - disabled, port: 8899
                          system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                          system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                          system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                        + instance is alive
                        Adapter    "ical"         : 1.16.2   , installed 1.16.2
                        Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
                        Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
                        Objects and States
                        Objects:        8782
                        States:         6752
                        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6662       920/slirp4netns
                        tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6672       920/slirp4netns
                        tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6670       920/slirp4netns
                        tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6668       920/slirp4netns
                        tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6666       920/slirp4netns
                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        9512       863/pihole-FTL
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6540       739/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        924        863/pihole-FTL
                        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        9513       863/pihole-FTL
                        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6664       920/slirp4netns
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15151      2682/io.shelly.1
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       930        716/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5702       716/iobroker.js-con
                        tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6674       920/slirp4netns
                        tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       5094       737/discovery
                        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       14447      2186/io.fullybrowse
                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       11994      2364/io.nuki-extend
                        tcp6       0      0 :::80                   :::*                    LISTEN      999        9514       863/pihole-FTL
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          6542       739/sshd: /usr/sbin
                        tcp6       0      0 :::53                   :::*                    LISTEN      999        926        863/pihole-FTL
                        tcp6       0      0 :::443                  :::*                    LISTEN      999        9515       863/pihole-FTL
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15445      2584/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7048       907/io.admin.0
                        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        923        863/pihole-FTL
                        udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        24743      863/pihole-FTL
                        udp        0      0 0.0.0.0:60493           0.0.0.0:*                           1001       11997      2376/io.ph803w.0
                        udp        0      0 0.0.0.0:58631           0.0.0.0:*                           1002       675873     920/slirp4netns
                        udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6678       920/slirp4netns
                        udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6676       920/slirp4netns
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14856      2439/io.shelly.0
                        udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       868410     737/discovery
                        udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6680       920/slirp4netns
                        udp        0      0 192.168.2.109:38760     0.0.0.0:*                           1002       868411     737/discovery
                        udp6       0      0 :::53                   :::*                                999        925        863/pihole-FTL
                        udp6       0      0 :::123                  :::*                                999        23343      863/pihole-FTL
                        udp6       0      0 :::59687                :::*                                1002       675872     920/slirp4netns
                        udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          849        644/NetworkManager
                        udp6       0      0 :::54266                :::*                                1002       675860     920/slirp4netns
                            at Socket.emit (node:events:518:28)
                            at UDP.onMessage (node:dgram:988:8)
                        2025-08-25 11:33:11.924  - error: roborock.0 (49238) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                        2025-08-25 11:33:11.957  - info: roborock.0 (49238) terminating
                        2025-08-25 11:33:11.959  - warn: roborock.0 (49238) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2025-08-25 11:33:12.555  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                        2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:184:29)
                        2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                        2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                        2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:518:28)
                        2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                        2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:988:8) {
                        2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
                        2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
                        2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                        2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]: }
                        2025-08-25 11:33:12.557  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2025-08-25 11:33:12.558  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                        2025-08-25 11:33:18.253  - info: tapo.0 (2625) Get camera Status failed
                        2025-08-25 11:33:18.254  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                        2025-08-25 11:33:28.273  - info: tapo.0 (2625) Get camera Status failed
                        2025-08-25 11:33:28.274  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                        N Ro75 2 Replies Last reply Reply Quote 0
                        • N
                          nu_81 @nu_81 last edited by
                          @nu_81 Hallo, hat jemand hierzu noch eine Idee?
                          Danke euch schonmal
                          • Ro75
                            Ro75 @nu_81 last edited by
                            Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred
                            Originalnetzteil verwenden - kein Ladegerät! Sorge für gute Kühlung.
                            Ro75.
                            N 1 Reply Last reply Reply Quote 1
                            • D3ltoroxp
                              D3ltoroxp last edited by
                              ich kann leider vom Adapter keine DP abgreifen, der mit den Status der Station anzeigt. Tank voll, leer usw. Hab den roborock Qrevo Edge S5A + Station.
                              • N
                                nu_81 @Ro75 last edited by
                                @ro75
                                Danke, ich benutze das Originalnetzteil.
                                Das mit der Kühlung hatte ich schon gesehen und kümmere mich nun um ein anderes Gehäuse, bzw. um einen Lüfter.
                                Das Problem mit der Kühlung verursacht aber doch nicht das Problem am Adapter, oder?!
                                • D3ltoroxp
                                  Ich sehe auch grad, er connected gar nicht mehr mit dem Sauger. Das ist neu, es ging mal.
                                  roborock.0
                                  2025-09-01 18:08:41.980	info	terminating
                                  roborock.0
                                  2025-09-01 18:08:41.657	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                                  roborock.0
                                  2025-09-01 18:08:41.478	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  roborock.0
                                  2025-09-01 18:08:41.477	info	terminating
                                  roborock.0
                                  2025-09-01 18:08:41.468	error	this.homeData is not initialized. Initialize via updateHomeData() first
                                  roborock.0
                                  2025-09-01 18:08:41.467	error	Error: this.homeData is not initialized. Initialize via updateHomeData() first at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:192:10) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:112:39)
                                  roborock.0
                                  2025-09-01 18:08:41.464	error	unhandled promise rejection: this.homeData is not initialized. Initialize via updateHomeData() first
                                  roborock.0
                                  2025-09-01 18:08:41.463	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  roborock.0
                                  2025-09-01 18:08:41.462	info	MQTT initialized
                                  roborock.0
                                  2025-09-01 18:08:41.418	error	No homeId found
                                  roborock.0
                                  2025-09-01 18:08:41.417	error	failed to get getHomeDetail: invalid token
                                  • N
                                    nu_81 @D3ltoroxp last edited by
                                    Habe den Adapter komplett entfernt und neu installiert.
                                    Der Fehler bleibt leider.
                                    Jemand noch eine Idee?
                                    host.raspberrypi
                                    2025-09-01 20:11:10.015	info	Restart adapter system.adapter.roborock.0 because enabled
                                    host.raspberrypi
                                    2025-09-01 20:11:10.015	error	instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.raspberrypi
                                    2025-09-01 20:11:10.015	error	Caught by controller[0]: }
                                    host.raspberrypi
                                    2025-09-01 20:11:10.015	error	Caught by controller[0]: code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                                    host.raspberrypi
                                    2025-09-01 20:11:10.015	error	Caught by controller[0]: reason: 'wrong final block length',
                                    host.raspberrypi
                                    2025-09-01 20:11:10.015	error	Caught by controller[0]: library: 'Provider routines',
                                    host.raspberrypi
                                    2025-09-01 20:11:10.015	error	Caught by controller[0]: at UDP.onMessage (node:dgram:988:8) {
                                    host.raspberrypi
                                    2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                                    host.raspberrypi
                                    2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:events:518:28)
                                    host.raspberrypi
                                    2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                                    host.raspberrypi
                                    2025-09-01 20:11:10.014	error	Caught by controller[0]: at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                                    host.raspberrypi
                                    2025-09-01 20:11:10.014	error	Caught by controller[0]: at Decipheriv.final (node:internal/crypto/cipher:184:29)
                                    host.raspberrypi
                                    2025-09-01 20:11:10.014	error	Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                                    roborock.0
                                    2025-09-01 20:11:09.673	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    roborock.0
                                    2025-09-01 20:11:09.671	info	terminating
                                    roborock.0
                                    2025-09-01 20:11:09.641	error	Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                                    roborock.0
                                    2025-09-01 20:11:09.641	error	Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:518:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
                                    roborock.0
                                    2025-09-01 20:11:09.640	error	uncaught exception: error:1C80006B:Provider routines::wrong final block length
                                    roborock.0
                                    2025-09-01 20:11:07.212	info	MQTT initialized
                                    roborock.0
                                    2025-09-01 20:11:05.656	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                    roborock.0
                                    2025-09-01 20:11:05.626	info	starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.18.0, js-controller: 7.0.7
                                    • N
                                      @nu_81 said in Neuer Adapter für Roborock-Staubsauger:
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      host.raspberrypi
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      Hab es durch iÍnstallation des dev_ts gelöst.
                                      • N
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        host.raspberrypi
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        Hab es durch Installation des dev_ts gelöst.
                                        • N
                                          Nachtfuchs last edited by
                                          Hallo Gemeinde,
                                          wir sind seit gestern Besitzer des QRevo Slim und nun soll dieser natürlich auch mit dem ioBroker sprechen. Adapter aus Adapterliste ausgewählt, aber er wirft diese Fehlermeldungen aus - kennt das jemand?
                                          Dank euch
                                          Thomas Braun B 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @Nachtfuchs last edited by Thomas Braun
                                            @nachtfuchs
                                            iob stop
                                            iob fix
                                            iob start
                                            Und bring deine nodejs-Installation in Ordnung. Keine aktuelle Version verwendet npm 10.7.0.
                                            81.1k
                                            916
                                            307271
