    4. js Controler auf 7.07 geht nicht Fehlermeldung iOb
    • mcm1957
      mcm1957 last edited by
      @marcel-drzal
      Die deinem Problem zugrunde liegende Fehlermeldung ist folgende:
      error: host.iobroker iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.18.0"}npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-22T13_13_53_260Z-debug-0.log
      2025-08-22 15:13:55.721 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.myuplink@0.8.4: 1
      2025-08-22 15:13:56.732 - info: host.iobroker iobroker exit 25
      2025-08-22 15:14:49.833 - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T14:14:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-22 15:14:50.069 - info: host.iobroker Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
      2025-08-22 15:14:58.547 - info: host.iobroker iobroker upgrade yahka@1.1.5 --debug
      2025-08-22 15:14:59.206 - info: host.iobroker iobroker Update yahka from @1.0.3 to @1.1.5
      2025-08-22 15:14:59.275 - info: host.iobroker iobroker NPM version: 10.9.3
      2025-08-22 15:14:59.275 - info: host.iobroker iobroker Installing iobroker.yahka@1.1.5... (System call)
      2025-08-22 15:15:05.132 - info: host.iobroker iobroker added 1 package, removed 1 package, and changed 19 packages in 6s408 packages are looking for funding run `npm fund` for details
      2025-08-22 15:15:06.399 - error: host.iobroker iobroker Cannot install "pam-devel": WARNING: apt does not have a stable CLI interface. Use with caution in scripts.E: Unable to locate package pam-devel
      2025-08-22 15:15:06.399 - error: host.iobroker iobroker The following apt packages could not be installed: pam-devel. Please install them manually.
      Oder extrahiert:
      Diese wird (oder wurde?) durch YAHKA in einer Version älter als 1.1.5 ausgelöst. Da du anscheinend zwischenzeitlich yahka auf 1.1.5 gebracht hast sollte sich das primäre Problem behoben haben.
      Was sonst noch zu sanieren wäre hat die @Thomas-Braun schon geschieben,
      marcel-drzal 1 Reply Last reply Reply Quote 0
      • marcel-drzal
        marcel-drzal @Thomas Braun last edited by
        @thomas-braun said in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
        @marcel-drzal
        Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
        Und dann sind da 125 Updates in der Pipeline...
        Und deine Paketquellen sind 'Kraut-und-Rüben'.
        Setz da einen frischen, konsistenten Container neu auf.
        wie kann ich die Packetquellen sauber ziehen
        Linux iobroker 6.8.12-13-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-13 (2025-07-22T10                                             :00Z) x86_64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Fri Aug 22 15:54:52 2025 from 10.10.10.166
        marcel@iobroker:~$   iobroker repo show
        │ (index) │ name               │ url        │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json                                             '        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-late                                             st.json' │ false        │
        Active repo(s): Stable (default)
        Upgrade policy: none
        marcel@iobroker:~$
        • marcel-drzal
          marcel-drzal @haselchen last edited by marcel-drzal
          @haselchen
          ich hoffe ihr könnt mir helfen. Versuche es nun erst einmal Sauber zu ziehen und dann Updaten.
          ========== Start marking the full check here ===========
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
          Operating System: Debian GNU/Linux 11 (bullseye)
             Static hostname: iobroker
                   Icon name: computer-container
                     Chassis: container
              Virtualization: lxc
                      Kernel: Linux 6.8.12-13-pve
                Architecture: x86-64
          OS is similar to:
          model name      : Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           11:54:07 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
          CPU threads: 2
          *** LIFE CYCLE STATUS ***
          *** TIME AND TIMEZONES ***
                         Local time: Sun 2025-08-24 11:54:07 CEST
                     Universal time: Sun 2025-08-24 09:54:07 UTC
                           RTC time: n/a
                        NTP service: n/a
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          marcel
          HOME=/home/marcel
          GROUPS=marcel sudo iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server:         false
          Unit display-manager.service could not be found.
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:            6.1G        1.9G        3.6G        0.0K        633M        4.3G
          Swap:           512M          0B        512M
          Total:          6.7G        1.9G        4.1G
          Active iob-Instances:   23
                   6144 M total memory
                   1892 M used memory
                   1886 M active memory
                    493 M inactive memory
                   3618 M free memory
                      0 M buffer memory
                    633 M swap cache
                    512 M total swap
                      0 M used swap
                    512 M free swap
          top - 11:54:08 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
          Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  6.2 us,  0.0 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   6144.0 total,   3617.9 free,   1892.3 used,    633.8 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   4251.6 avail Mem
          *** FAILED SERVICES ***
            UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
          * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
          * influxdb.service              loaded failed failed InfluxDB is an open-source, distributed, time series database
          * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          4 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          dmesg: read kernel buffer failed: Operation not permitted
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--160--disk--0 ext4       30G   11G   17G  39% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs   32G     0   32G   0% /dev/tty
          tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
          tmpfs                            tmpfs      13G  108K   13G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
          Show mounted filesystems:
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--160--disk--0 ext4   rw,relatime,stripe=16
          /var:
          1.7G    /var/
          709M    /var/cache
          704M    /var/cache/apt
          669M    /var/log
          665M    /var/log/journal/fe2dcc346dde445a9e95482e37c85663
          Archived and active journals take up 33.3M in the file system.
          /opt/iobroker/backups:
          2.2G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          670M    /opt/iobroker/iobroker-data/
          377M    /opt/iobroker/iobroker-data/files
          176M    /opt/iobroker/iobroker-data/backup-objects
          49M     /opt/iobroker/iobroker-data/files/vis.0
          48M     /opt/iobroker/iobroker-data/files/iot.admin
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
          26M     /opt/iobroker/iobroker-data/objects.jsonl
          20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
          19M     /opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          No Devices found 'by-id'
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v22.18.0
          /usr/bin/node           v22.18.0
          /usr/bin/npm            10.9.3
          /usr/bin/npx            10.9.3
          /usr/bin/corepack       0.33.0
          nodejs:
            Installed: 22.18.0-1nodesource1
            Candidate: 22.18.0-1nodesource1
            Version table:
           *** 22.18.0-1nodesource1 600
                  500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               22.17.1-1nodesource1 600
               22.17.0-1nodesource1 600
               22.16.0-1nodesource1 600
               22.15.1-1nodesource1 600
               22.15.0-1nodesource1 600
               22.14.0-1nodesource1 600
               22.13.1-1nodesource1 600
               22.13.0-1nodesource1 600
               22.12.0-1nodesource1 600
               22.11.0-1nodesource1 600
               22.10.0-1nodesource1 600
               22.9.0-1nodesource1 600
               22.8.0-1nodesource1 600
               22.7.0-1nodesource1 600
               22.6.0-1nodesource1 600
               22.5.1-1nodesource1 600
               22.5.0-1nodesource1 600
               22.4.1-1nodesource1 600
               22.4.0-1nodesource1 600
               22.3.0-1nodesource1 600
               22.2.0-1nodesource1 600
               22.1.0-1nodesource1 600
               22.0.0-1nodesource1 600
               20.19.2+dfsg-1 500
                  500 http://deb.debian.org/debian trixie/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          Checking for nodejs vulnerability:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 58433)
          Core adapters versions
          js-controller:  7.0.7
          admin:          7.6.17
          javascript:     8.9.2
          nodejs modules from github:     1
          +-- iobroker.luxtronik2@0.3.0 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e3a8b912a68cdb84c808a91c6a2250ae4f7ec1b9)
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            system.adapter.denon.0                  : denon                 : iobroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.judoisoft.0              : judoisoft             : iobroker                                 -  enabled
          + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 10.10.50.16
            system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 - disabled, port: 8214
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.16
          + system.adapter.myuplink.0               : myuplink              : iobroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
          │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
          Installed ioBroker-Adapters
          Used repository: Stable (default)
          Adapter    "admin"        : 7.6.17   , installed 7.6.17
          Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
          Adapter    "denon"        : 1.15.12  , installed 1.15.12
          Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
          Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
          Adapter    "homekit-controller": 0.5.11, installed 0.5.11
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
          Controller "js-controller": 7.0.7    , installed 7.0.7
          Adapter    "judoisoft"    : 1.1.2    , installed 1.1.2
          Adapter    "klf200"       : 1.3.5    , installed 1.3.5
          Adapter    "knx"          : 2.0.30   , installed 2.0.30
          Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
          Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
          Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
          Adapter    "myuplink"     : 0.8.4    , installed 0.8.4
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "shelly"       : 10.1.0   , installed 10.1.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "telegram"     : 4.1.0    , installed 4.1.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
          Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
          Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        8765
          States:         6459
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused)
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          Hit:1 http://security.debian.org/debian-security trixie-security InRelease
          Hit:2 http://deb.debian.org/debian trixie InRelease
          Hit:3 http://deb.debian.org/debian trixie-updates InRelease
          Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
          Err:6 https://dl.yarnpkg.co m/debian InRelease
            Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
          Err:4 https://repos.influxdata.com/debian buster InRelease
          Fetched 12.9 kB in 0s (46.8 kB/s)
          Reading package lists...
          W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
          Pending Updates: 125
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       22058      140/iobroker.js-con
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       17359      140/iobroker.js-con
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11038      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21672      193/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          21795      320/master
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       32747      712/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22163      342/io.admin.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       27465      667/io.simple-api.0
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          21796      320/master
          tcp6       0      0 :::111                  :::*                    LISTEN      0          11040      1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          21674      193/sshd: /usr/sbin
          udp        0      0 10.10.50.16:50137       0.0.0.0:*                           1000       435218     547/io.knx.0
          udp        0      0 10.10.50.16:55244       0.0.0.0:*                           1000       1650387    547/io.knx.0
          udp        0      0 10.10.50.16:57540       0.0.0.0:*                           1000       56405      547/io.knx.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16336      75/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11039      1/init
          udp        0      0 10.10.50.16:123         0.0.0.0:*                           0          21644      172/ntpd
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          21642      172/ntpd
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          21638      172/ntpd
          udp        0      0 10.10.50.16:33034       0.0.0.0:*                           1000       766879     547/io.knx.0
          udp        0      0 10.10.50.16:33292       0.0.0.0:*                           1000       42281      547/io.knx.0
          udp        0      0 10.10.50.16:33516       0.0.0.0:*                           1000       796516     547/io.knx.0
          udp        0      0 10.10.50.16:35890       0.0.0.0:*                           1000       2015188    547/io.knx.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       34914      742/io.wled.0
          udp        0      0 10.10.50.16:38368       0.0.0.0:*                           1000       27253      547/io.knx.0
          udp        0      0 10.10.50.16:42227       0.0.0.0:*                           1000       144075     547/io.knx.0
          udp        0    960 10.10.50.16:43259       0.0.0.0:*                           1000       2062242    547/io.knx.0
          udp        0      0 10.10.50.16:43538       0.0.0.0:*                           1000       2015226    547/io.knx.0
          udp        0      0 10.10.50.16:47107       0.0.0.0:*                           1000       1431661    547/io.knx.0
          udp6       0      0 :::111                  :::*                                0          11041      1/init
          udp6       0      0 fe80::7435:b2ff:fe7:123 :::*                                109        22015      172/ntpd
          udp6       0      0 fd48:3919:e463:2897:123 :::*                                109        22013      172/ntpd
          udp6       0      0 ::1:123                 :::*                                0          21646      172/ntpd
          udp6       0      0 :::123                  :::*                                0          21635      172/ntpd
          2025-08-24 11:42:49.822  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:42:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:42:56.387  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
          2025-08-24 11:42:56.430  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
          2025-08-24 11:42:56.518  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
          2025-08-24 11:43:49.845  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:43:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:44:49.836  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:44:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:45:10.007  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3952
          2025-08-24 11:45:10.613  - info: dwd.0 (3952) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.18.0, js-controller: 7.0.7
          2025-08-24 11:45:10.805  - info: dwd.0 (3952) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-08-24 11:45:11.314  - info: host.iobroker instance system.adapter.dwd.0 having pid 3952 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-08-24 11:45:49.834  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:45:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:46:49.854  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:46:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:47:49.843  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:47:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:47:56.999  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
          2025-08-24 11:47:57.042  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
          2025-08-24 11:47:57.134  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
          2025-08-24 11:48:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:48:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:49:49.839  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:49:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:50:49.820  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:50:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:51:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:51:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:52:49.858  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:52:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          2025-08-24 11:52:57.648  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
          2025-08-24 11:52:57.690  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
          2025-08-24 11:52:57.782  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
          2025-08-24 11:53:49.823  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:53:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
          iob diag has finished.
          • marcel-drzal
            marcel-drzal @mcm1957 last edited by
            @mcm1957
            Danke für deine Hilfe.
            Yahkara nutze ich nicht mehr. hatte ich eigendlich gelöscht
            • mcm1957
              mcm1957 @marcel-drzal last edited by mcm1957
              @marcel-drzal
              Zum Zeitpunkt der Fehlermeldung war yahka aber installiert.Bist du sicher, dass du den ADAPTER und nicht nur die INSTANZ gelöscht hast?
              EDIT:
              Lt iob diag in commentar https://forum.iobroker.net/topic/81995/js-controler-auf-7-07-geht-nicht-fehlermeldung-iob/12 hast du jetzt yahka 1.1.5 installiert - allerdings ohne aktive instanz.
              Du hast also offensichtlich nur die Instanz gelöscht 🙂
              @Thomas-Braun
              Anregung für iob diag: Warnung bei Adaptern die installiert sind aber keine Instanz besitzen wär zu überlegen.
              marcel-drzal Thomas Braun 3 Replies Last reply Reply Quote 0
              • marcel-drzal
                @mcm1957
                • mcm1957
                  @marcel-drzal
                  Yep ist installiert. Wenn du ihn nicht mehr benutzt solltest du ihn deinstallieren.
                    Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                    @mcm1957 sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                    Schwierig zu checken. Können ja auch Adapter ohne Instanz sein oder die Nummerierung ist instanz.3 oder so.
                    • mcm1957
                      mcm1957 @Thomas Braun last edited by
                      Also zu checken of die Instanz .0 oder .99 ist wär sicher trivial machbar.
                      Hast du Beispiele für Adapter ohne Instanz? Da gibts sicher ein Kriterium dazu.
                      • marcel-drzal
                        marcel-drzal @mcm1957 last edited by marcel-drzal
                        @mcm1957 Adapter habe ich gelöscht
                        habe nun einen error:
                        dpkg: error
                        470 upgraded, 165 newly installed, 34 to remove and 0 not upgraded.
                        Need to get 0 B/341 MB of archives.
                        After this operation, 743 MB of additional disk space will be used.
                        Do you want to continue? [Y/n] Y
                        Reading changelogs... Done
                        Extracting templates from packages: 100%
                        Preconfiguring packages ...
                        (Reading database ... 43860 files and directories currently installed.)
                        Preparing to unpack .../base-files_13.8_amd64.deb ...
                        * The base-files package cannot be installed because
                        * /bin is a directory, but should be a symbolic link.
                        * Please install the usrmerge package to convert this system to merged-/usr.
                        * For more information please read https://wiki.debian.org/UsrMerge.
                        dpkg: error processing archive /var/cache/apt/archives/base-files_13.8_amd64.deb               (--unpack):
                         new base-files package pre-installation script subprocess returned error exit s              tatus 1
                        Errors were encountered while processing:
                        E: Sub-process /usr/bin/dpkg returned an error code (1)
                          Thomas Braun Most Active @marcel-drzal last edited by
                          @marcel-drzal
                          dpkg ist aber das Paketmanagement auf OS-Ebene. Da ist also eine Etage tiefer schon was schief.
                          sudo apt update
                          sagt?
                          • marcel-drzal
                            marcel-drzal @Thomas Braun last edited by marcel-drzal
                            direcktes uptadt aus iobroker:
                            marcel@10.10.50.16's password:
                            Linux iobroker 6.14.8-2-pve #1 SMP PREEMPT_DYNAMIC PMX 6.14.8-2 (2025-07-22T10:0                                                       4Z) x86_64
                            Last login: Tue Aug 26 18:40:15 2025 from 10.10.10.166
                            marcel@iobroker:~$ sudo apt update
                            [sudo] password for marcel:
                            Hit:1 http://deb.debian.org/debian trixie InRelease
                            Get:2 http://security.debian.org/debian-security trixie-security InRelease [43.4                                                        kB]
                            Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.1 kB]
                            Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
                            Get:6 http://security.debian.org/debian-security trixie-security/main amd64 Pack                                                       ages [33.1 kB]
                            Get:7 http://security.debian.org/debian-security trixie-security/main Translatio                                                       n-en [22.0 kB]
                              The following signatures couldn't be verified because the public key is not av                                                       ailable: NO_PUBKEY D8FF8E1F7DF8B07E
                            Get:8 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [7803 B]
                            Err:9 https://dl.yarnpkg.co m/debian InRelease
                              Could not connect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connec                                                       tion refused) Could not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect                                                        (111: Connection refused)
                            Fetched 178 kB in 1s (325 kB/s)
                            Reading package lists... Done
                            Building dependency tree... Done
                            471 packages can be upgraded. Run 'apt list --upgradable' to see them.
                            W: An error occurred during the signature verification. The repository is not up                                                       dated and the previous index files will be used. GPG error: https://repos.influx                                                       data.com/debian buster InRelease: The following signatures couldn't be verified                                                        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  T                                                       he following signatures couldn't be verified because the public key is not avail                                                       able: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not con                                                       nect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connection refused) C                                                       ould not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect (111: Connecti                                                       on refused)
                            PlatformBetriebssystem:linux
                            Architektur:x64
                            CPUs:2
                            Geschwindigkeit:4043 MHz
                            Modell:unknown
                            RAM:6 GB
                            System-Betriebszeit:2 T. 00:15:05
                            Node.js:v22.18.0
                            Zeit:1756964837826
                            Zeitversatz:-120
                            NPM:10.9.3
                            Adapter-Anzahl:574
                            Datenträgergröße:29.4 GB
                            Freier Festplattenspeicher:18.5 GB
                            Aktive Instanzen:21
                            Pfad:/opt/iobroker/
                            Betriebszeit:2 T. 00:15:01
                            aktiv:true
                            _nodeCurrent:22.18.0
                            _nodeNewest:22.19.0
                            _nodeNewestNext:22.19.0
                            _npmCurrent:10.9.3
                            _npmNewest:10.9.3
                            _npmNewestNext:10.9.3
                              Thomas Braun Most Active @marcel-drzal last edited by Thomas Braun
                              @marcel-drzal
                              Hau die 471 Updates rein, verdammt.
                              Die influxdb-Quelle ist veraltet. Leg die neu an.
                              Geht so:
                              https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                              Und dann schau, aus welcher Datei dieses yarn-Dingsi kommt.
                              cd /etc/apt/
                              grep -r yarn .
                              Die Zeile mit dem Eintrag zu yarn würde ich löschen.
                              • marcel-drzal
                                habe ich bekomme hier die Meldung:
                                Fetched 38.5 MB in 3s (11.3 MB/s)
                                 new base-files package pre-installation script subprocess returned error exit status 1
                                marcel@iobroker:~$
                                  @marcel-drzal
                                  Hast du das ganze Ding über Jahre von Release zu Release geschliffen?
                                  Oder von Buster direkt auf Trixie gesprungen?
                                  Da scheint mir einiges schiefgelaufen zu sein.
                                  Installier es von Grund auf neu.
                                  • marcel-drzal
                                    @thomas-braun nein denke habe es immer auf den neusten Stand gehalten.
                                    Neu? Gibt es einen anderen Weg. Wie kann ich da am besten vor gehen?
                                      @marcel-drzal sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                                      Von wo aus? Also doch über Generationen rübergetragen?
                                      Ich würde es neuinstallieren. Da fehlt mindestens der usrmerge auf der Kiste und wer weiß was sonst noch alles.
                                      Edit:
                                      Und dein Herumgehampel als root trägt auch nicht dazu bei da ein stabiles, sauberes System zu haben.
                                      • marcel-drzal
                                        ok, ich mach alles neu.
                                        kannst du mir dabei helfen?
                                        würde erst mal ein neues sauberes System auf setzen in Proxmox.
                                        also es erst mal parallel laufen lassen und nach und nach alles rüber ziehen.
                                        oder geht das nich ?
                                        ich denke wenn ich ein Backup ziehe in iobroker habe ich die gelichen Probleme dann wieder oder?
                                        da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                                        • da_Woody
                                          da_Woody @marcel-drzal last edited by
                                          @marcel-drzal bin jetzt auch kein profi, aber sauber aufsetzen (beschreibungen gibts genug), backup mit dem backitup adapter machen, dann sollten keine schweinereien mehr sein nach rückspielen.
                                            Nein, das darunterliegende System ist krumm und schief, der ioBroker dürfte da nicht direkt von betroffen sein.
                                            Zur Installation auf Proxmox:
                                            https://www.iobroker.net/#de/documentation/install/proxmox.md
                                            da_Woody 1 Reply Last reply Reply Quote 1
                                            1983
