    3. Einsteigerfragen
    4. Wie greife ich über Putty auf den Iobroker zu?
      Thomas Braun Most Active @dmode last edited by
      @dmode
      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      funktioniert und liefert was?
        dmode @Thomas Braun last edited by
        @thomas-braun sagte in Wie greife ich über Putty auf den Iobroker zu?:
        Hi Thomas, danke für die schnelle Antwort.
        ..ja angestaubt schon... ich hattes das lange ohne Probleme laufen.
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 13 (trixie)
        Static hostname: ioBroM
              Icon name: computer
                 Kernel: Linux 6.12.34+rpt-rpi-v8
           Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
        18:28:17 up  1:58,  1 user,  load average: 2.42, 1.57, 1.44
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'trixie'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                      Local time: Wed 2025-08-27 18:28:17 CEST
                  Universal time: Wed 2025-08-27 16:28:17 UTC
                        RTC time: n/a
                     NTP service: active
                 RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        SUDO_HOME=/home/pi
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            4.0G        3.4G        252M        5.9M        463M        622M
        Swap:           209M        156M         52M
        Total:          4.2G        3.5G        305M
        Active iob-Instances:   0
                3795 M total memory
                3201 M used memory
                1849 M active memory
                1457 M inactive memory
                 241 M free memory
                  33 M buffer memory
                 409 M swap cache
                 199 M total swap
                 149 M used swap
                  50 M free swap
        top - 18:28:18 up  1:58,  1 user,  load average: 2.42, 1.57, 1.44
        Tasks: 223 total,   3 running, 220 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 42.6 us,  4.3 sy,  0.0 ni, 46.8 id,  0.0 wa,  0.0 hi,  6.4 si,  0.0 st
        MiB Mem :   3795.8 total,    240.7 free,   3202.2 used,    442.6 buff/cache
        MiB Swap:    200.0 total,     50.4 free,    149.6 used.    593.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     760M   11M  750M   2% /run
        /dev/sda2      ext4       29G   12G   16G  43% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G  3.0M  1.9G   1% /tmp
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald        .service
        /dev/sda1      vfat      510M   73M  438M  15% /boot/firmware
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.servi        ce
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@tty        S0.service
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Wed Aug 27 16:29:54 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nv        me.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm        i=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.maca        ddr=DC:A6:32:03:A9:CA vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  con        sole=ttyS0,115200 console=tty1 root=PARTUUID=59a2e77a-02 rootfstype=ext4 fsck.re        pair=yes rootwait
        [Wed Aug 27 16:30:00 2025] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca        -86e6-19da1069914d ro with ordered data mode. Quota mode: none.
        [Wed Aug 27 16:30:03 2025] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19        da1069914d r/w.
        Show mounted filesystems:
        TARGET   SOURCE    FSTYPE OPTIONS
        /        /dev/sda2 ext4   rw,noatime
        `-/boot/firmware
                /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iochars
        /var:
        1.4G    /var/
        788M    /var/log
        784M    /var/log/journal/15cd118df1504fa49dedc3cb078007a5
        201M    /var/lib
        Archived and active journals take up 792.7M in the file system.
        /opt/iobroker/backups:
        299M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.3G    /opt/iobroker/iobroker-data/
        668M    /opt/iobroker/iobroker-data/history
        452M    /opt/iobroker/iobroker-data/files
        119M    /opt/iobroker/iobroker-data/backup-objects
        67M     /opt/iobroker/iobroker-data/files/echarts.admin
        46M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.m        ap
        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41c        ee985.js.map
        24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.j        s.map
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE19647        30-if00
        *** ZigBee Settings ***
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.18.0
        /usr/bin/node           v22.18.0
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        /usr/bin/corepack       0.33.0
        nodejs:
         Installed: 22.18.0-1nodesource1
         Candidate: 22.18.0-1nodesource1
         Version table:
        *** 22.18.0-1nodesource1 1001
               500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
               100 /var/lib/dpkg/status
            22.17.1-1nodesource1 1001
            22.17.0-1nodesource1 1001
            22.16.0-1nodesource1 1001
            22.15.1-1nodesource1 1001
            22.15.0-1nodesource1 1001
            22.14.0-1nodesource1 1001
            22.13.1-1nodesource1 1001
            22.13.0-1nodesource1 1001
            22.12.0-1nodesource1 1001
            22.11.0-1nodesource1 1001
            22.10.0-1nodesource1 1001
            22.9.0-1nodesource1 1001
            22.8.0-1nodesource1 1001
            22.7.0-1nodesource1 1001
            22.6.0-1nodesource1 1001
            22.5.1-1nodesource1 1001
            22.5.0-1nodesource1 1001
            22.4.1-1nodesource1 1001
            22.4.0-1nodesource1 1001
            22.3.0-1nodesource1 1001
            22.2.0-1nodesource1 1001
            22.1.0-1nodesource1 1001
            22.0.0-1nodesource1 1001
            20.19.2+dfsg-1 500
               500 http://deb.debian.org/debian trixie/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        Checking for nodejs vulnerability:
        *** ioBroker-Installation ***
        ioBroker Status
        diag.sh: line 875: iob: command not found
        Hosts:
        diag.sh: line 877: iob: command not found
        Core adapters versions
        diag.sh: line 883: iob: command not found
        js-controller:
        diag.sh: line 884: iob: command not found
        admin:
        diag.sh: line 885: iob: command not found
        javascript:
        nodejs modules from github:     0
        Adapter State
        ioBroker-Repositories
        diag.sh: line 897: iob: command not found
        Installed ioBroker-Adapters
        diag.sh: line 900: iob: command not found
        Objects and States
        Objects:        0
        States:         0
        W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will re        ject signature within a year, see --audit for details
        Hit:1 http://phoscon.de/apt/deconz generic-beta InRelease
        Hit:2 http://phoscon.de/apt/deconz generic InRelease
        Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Hit:5 http://deb.debian.org/debian trixie InRelease
        Hit:6 http://deb.debian.org/debian-security trixie-security InRelease
        Hit:7 http://deb.debian.org/debian trixie-updates InRelease
        Reading package lists... Done
        N: Missing Signed-By in the sources.list(5) entry for 'http://phoscon.de/apt/dec        onz'
        N: Missing Signed-By in the sources.list(5) entry for 'http://archive.raspberryp        i.com/debian'
        Pending Updates: 0
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN        1000       6566       583/deCONZ
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          9955       852/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN        1000       9988       583/deCONZ
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN        1001       6801       809/iobroker.js-con
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN        1001       10050      809/iobroker.js-con
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN        0          7813       1205/exim4
        tcp6       0      0 :::5900                 :::*                    LISTEN        992        8317       846/wayvnc
        tcp6       0      0 :::8081                 :::*                    LISTEN        1001       10139      1213/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN        1001       13480      1528/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN        0          9965       852/sshd: /usr/sbin
        tcp6       0      0 ::1:25                  :::*                    LISTEN        0          7814       1205/exim4
        udp        0      0 0.0.0.0:1900            0.0.0.0:*        1001       11798      1810/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*        1001       8742       1259/io.deconz.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*        1000       9998       583/deCONZ
        udp        0      0 0.0.0.0:49507           0.0.0.0:*        1001       11228      1810/io.upnp.0
        udp        0      0 0.0.0.0:41839           0.0.0.0:*        104        5748       579/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*        104        5746       579/avahi-daemon: r
        udp6       0      0 :::1900                 :::*        1001       8745       1259/io.deconz.0
        udp6       0      0 :::1900                 :::*        1001       8744       1259/io.deconz.0
        udp6       0      0 :::1900                 :::*        1001       8743       1259/io.deconz.0
        udp6       0      0 fe80::aeb3:e9f5:b1d:546 :::*        0          8319       780/NetworkManager
        udp6       0      0 :::42095                :::*        104        5749       579/avahi-daemon: r
        udp6       0      0 :::5353                 :::*        104        5747       579/avahi-daemon: r
        ...ich hoffe, dass da noch was zu retten ist
        Dirk
          Homoran Global Moderator Administrators @dmode last edited by Homoran
          @dmode naja, das Fundament ist gut, nur von ioBroker seh ich gar nichts
          hast du eine größere Updateorgie durchgezogen?
          wenn ja, bitte wie?
            dmode @Homoran last edited by dmode
            soll ich den fixer nochmal drüber laufen lassen ?
            curl -fsL https://iobroker.net/fix.sh | bash -
              @dmode sagte in Wie greife ich über Putty auf den Iobroker zu?:
              schadet sicherlich nicht
              aber was ist da passiert?
                ich war mal ganz mutig und habe nach der Anleitung Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie' umgestellt
                  ja, so sieht es aus.
                  Das sind die allerneuesten Versionen.
                  Wie alt war dein ioBroker?
                  • mcm1957
                    mcm1957 @dmode last edited by
                    @dmode
                    Nur zur Sicherheit:
                    falls du von WINDOWS aus auf den Pi zugreifen wills, brauchst du putty eigentlich nicht mehr. Das geht auch auf der Windows Commandline mittels des Commands ssh:
                    ssh pi@pi
                    (pi durch user und host ersetzen)
                    Homoran D 2 Replies Last reply Reply Quote 0
                      Homoran Global Moderator Administrators @mcm1957 last edited by Homoran
                      @mcm1957 ich glaube die Ursprungsfrage hat sich längst erübrigt!
                      • mcm1957
                        mcm1957 @Homoran last edited by
                        Das schon. Ich wollte dem TO nur mitteilen, dass putty derzeit eigentlich nicht mehr benötigt wird da das bisher noch niemand erwähnt hat. Keine Ahnung ob er das bereits wusste.
                          @homoran sagte in Wie greife ich über Putty auf den Iobroker zu?:
                          mhm... 4 Jahre... läuft...eigentlich stabil...
                            dmode @mcm1957 last edited by
                            @mcm1957 sagte in Wie greife ich über Putty auf den Iobroker zu?:
                            @dmode
                            Nur zur Sicherheit:
                            ssh pi@pi
                            ..wusste ich tatsächlich nicht ! danke
                              Thomas Braun Most Active @dmode last edited by Thomas Braun
                              sources.list
                              In den Dateien stimmt was nicht.
                              Und RaspberryOS 13 'Trixie' ist noch gar nicht offziell draußen.
                              Was liegt da in /etc/apt/ und /etc/apt/sources.list.d/ an Dateien herum?
                              ls -l /etc/apt/
                              ls -l /etc/apt/sources.list.d/
                                @dmode
                                Und zum eigentlichen Problem:
                                ls -la /usr/bin/iob
                                ls -la /opt/iobroker/iobroker
                                sagt?
                                  Hallo Thomas,
                                  danke für deine Hilfe. Ich habe das letzte Backup aufgespielt ..und anschließend den Fixer nochmal laufen lassen. Jetzt funktioniert alles wieder.
                                  @all: Danke für eure Hilfe und eure Geduld!
                                  Dirk
                                    @dmode
                                    Sind deine Quellen denn nun sauber?
                                    1.2k
                                    81.1k
                                    574
