    • Ciwa
      Ciwa @Armilar last edited by Ciwa
      @armilar
      Also jetzt bin ich wieder auf die JS 9.0.11. Dann Berry update, danach war die autoexec.be leer. Die habe ich wieder eingespielt. Dann tft Update das startet jetzt auch, bleibt aber hängen.
      22:35:57.216 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
      ganz komisch.
      Hier der Weblog 3 Output
      22:01:34.975 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v4.9.5.tft
      22:01:34.991 MQT: SmartHome/NS_Panel/stat/RESULT = {"FlashNextionAdv":"Done"}
      22:01:35.042 FLH: host: nspanel.de, port: 80, get: /nspanel-v4.9.5.tft
      22:01:36.282 FLH: Send (High Speed) flash start
      22:01:36.671 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
      22:01:43.018 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:01:43.087 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:01:43.202 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:01:59.933 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:00.060 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:00.121 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:00.222 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:27.904 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:27.984 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:28.079 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:28.223 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:28.298 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:28.404 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:43.013 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:43.077 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:43.191 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:02:59.934 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:03:00.060 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:03:00.125 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:03:00.224 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:03:43.066 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:03:43.142 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:03:43.235 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:46:59.142 CMD: Grp 0, Cmd 'FLASHNEXTION', Idx 1, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v4.9.5.tft'
      22:46:59.151 MQT: SmartHome/NS_Panel/stat/RESULT = {"FlashNextion":"Done"}
      22:46:59.209 SRC: MQTT
      22:46:59.211 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 24, Pld -99, Data 'dimmode~1~100~6371~65535'
      22:46:59.231 NXP: skipped command becuase still flashing
      22:46:59.239 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:46:59.251 FLH: host: nspanel.de, port: 80, get: /nspanel-v4.9.5.tft
      22:46:59.253 WIF: DNS failed for nspanel.de after 1 ms
      22:46:59.254 FLH: Connected:false
      22:46:59.356 FLH: Retry 2
      22:46:59.557 FLH: Retry 3
      22:46:59.858 FLH: Retry 4
      22:47:00.259 FLH: Retry 5
      22:47:00.259 FLH: Nothing available to read!
      22:47:00.263 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
      22:47:00.266 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
      22:47:00.268 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
      22:47:00.272 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
      22:47:00.311 SRC: MQTT
      22:47:00.312 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~23:46'
      22:47:00.335 NXP: skipped command becuase still flashing
      22:47:00.345 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:47:00.367 SRC: MQTT
      22:47:00.368 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 30, Pld -99, Data 'date~Dienstag, 26. August 2025'
      22:47:00.390 NXP: skipped command becuase still flashing
      22:47:00.397 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:47:00.429 SRC: MQTT
      22:47:00.430 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 20, Pld -99, Data 'pageType~pageStartup'
      22:47:00.454 NXP: skipped command becuase still flashing
      22:47:00.466 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:47:00.484 HTP: Command
      22:47:00.491 SRC: WebCommand from 192.168.7.75
      22:47:00.493 CMD: Grp 0, Cmd 'GETDRIVERVERSION', Idx 1, Len 0, Pld -99, Data ''
      22:47:00.505 MQT: SmartHome/NS_Panel/tele/RESULT = {"nlui_driver_version":"9"}
      22:47:00.562 SRC: MQTT
      22:47:00.563 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~23:47'
      22:47:00.578 NXP: skipped command becuase still flashing
      22:47:00.586 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:47:59.814 SRC: MQTT
      22:47:59.815 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~23:48'
      22:47:59.829 NXP: skipped command becuase still flashing
      22:47:59.836 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      22:48:59.812 SRC: MQTT
      22:48:59.813 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~23:49'
      22:48:59.836 NXP: skipped command becuase still flashing
      22:48:59.845 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
      Edit:
      Hat jetzt abgebrochen Panel zeigt:
      • Armilar
        Armilar Most Active Forum Testing @Ciwa last edited by Armilar
        @ciwa
        Jo das sieht sehr gut aus...
        Kommunikation startet zur TFT URL und dann kommt sowas 😉
        Okay - Du hast eine statische IP vergeben und/oder ein besonderes Binding für das Panel im Router gesetzt.
        Das mag Tasmota nicht...
        https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Tasmota-FAQ#32-fehler-bei-flashnextion---type-error-unsupported-operand-types
        backlog savedata 1; ipaddress1 0.0.0.0; savedata 0; restart 1
        damit bekommt das Panel eine IP vom DHCP
        und dann neue IP suchen und:
        Wenn's dann immer noch die Meldung gibt, dann im Router nach Bindings suchen...
        Seit der Einführung von ipv6 im Tasmota passiert das mit dem Fehler... danach sollte sich das aber ohne diesen Fehler flashen lassen...
        EDIT: Den weißen Screen mit "Model does not match" kannst du getrost ignorieren... Kann ja nicht passen, weil nichts gesendet wurde... 😊
        EDIT2: Sollte das Flash irgendwo zwischen 0 und 100% abbrechen, dann Panel restart und neu flashen...
        Ciwa 1 Reply Last reply Reply Quote 1
        • Ciwa
          @armilar
          Vielen Dank für die Zeit die du hier investierst.
          Ich mag halt feste IPs für den ganzen Iot Kram 🙂
          Jetzt ist erst mal Feierabend 🙂
          Ciwa
          Armilar T 2 Replies Last reply Reply Quote 1
          • Armilar
            @ciwa
            Solang es hilft, gerne
            Ich auch... Macht die Verwaltung so einfach... Man kann anschließend wieder eine statische IP vergeben... Man muss sich nur das nächste Mal an diese Prozedere erinnern (passiert sonst wieder)
            Ich flashe ja so häufig, dass die statischen NSPanel IP's bei mir keinen Sinn mehr machen.
              TT-Tom @Ciwa last edited by
              @ciwa
              Du kannst im Router festlegen, das er der Mac-Adresse (Panel) immer diese IP zuweisen soll. In Tasmota lässt du alles auf DHCP. Sso funktioniert es bei mir schon seit Monden.
                ticaki Developer @TT-Tom last edited by
                @ciwa
                @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
                @ciwa
                So wurde mir das auch von einem Netzwerktechniker empfohlen, besser zu administrieren.
                  ticaki Developer last edited by ticaki
                  Für Berry update bitte diesen Befehlt benutzen:
                  Backlog UfsDelete autoexec.old; UfsRename autoexec.be,autoexec.old; UrlFetch https://raw.githubusercontent.com/ticaki/ioBroker.nspanel-lovelace-ui/refs/heads/main/tasmota/berry/10/autoexec.be; Restart 1
                  Der benennt die autoexec.be in autoexec.old um - vorher wird die alte .old gelöscht und läd dann die neue Version. Damit sollte es nicht eine existierende aber leere autoexec.be geben.
                  • Ciwa
                    Ciwa @ticaki last edited by Ciwa
                    das Spiel geht in eine neue Runde.
                    • Berry Update ok
                    • TFT Update ok (Schöner Startbildschirm)
                    • Ip Adresse wieder zurück statisch
                    • JS 9.0.11
                    • Script adaptiert und läuft fehlerfrei
                    NS Panel abgeschmiert....Webinterface erreichbar, TFT zeigt Fehler:
                    Ciwa
                    • Armilar
                      @ciwa
                      Da scheint sich aber auch ein Flash nochmal versucht zu haben... ist bislang nur beim Adapter passiert. Und auch nur wenn der Haken im mqtt.x bei:
                      gesetzt war.
                      Ist es nach einem Reboot wieder okay? Ansonsten nochmal flashen...
                      • Ciwa
                        @armilar
                        Das wars, Teilerfolg super! Haken raus & Neuflashen war die Lösung. Das Eine Panel läuft wieder perfekt, alle Funktionen drauf. Danke dafür.
                        Mein zweites Funktioniert leider jetzt gar nicht mehr. Ich habe es vom Sockel abgezogen um es Stromlos zu machen (Dummheit ole).
                        • TFT dunkel
                        • IP nicht erreichbar
                        • manuell bestromen geht auch nicht (Stromaufnahme jedoch messbar)
                        • Versorgungsspannung Sockel ok
                        Ciwa
                        Armilar 1 Reply Last reply Reply Quote 1
                        • Armilar
                          @ciwa
                          okay - hmm - das ist jetzt Neuland... IP nicht erreichbar ist aktuell unser Problem, es sei denn das Panel befindet sich im Tasmota AP Modus und möchte ins WLAN...
                          Hört sich ja irgendwie nach einem kompletten Reset an...
                          Ciwa 1 Reply Last reply Reply Quote 0
                          • Ciwa
                            @armilar
                            eher nach Hardwaredefekt 😕 Tasmota Accesspoint ist auf jeden Fall keiner Sichtbar.
                            Stromaufnahme ist da und schwankt. Mehr nicht..... Aber Egal....werde erst mal eins auf Ersatz anschaffen. Bei den Basteleien hier, sicher nicht die schlechteste Idee 🙂
                            Was anderes noch....Der JS Adapter haut jetzt Warnmeldungen raus:
                            javascript.0
                            	2025-08-27 21:38:59.670	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                            das würde ich gerne noch abstellen.
                            Ciwa
                              ticaki Developer @Ciwa last edited by
                              @ciwa
                              mach mal den tasmota tasten reset mußte mal nach suche, ich weiß gerade nicht auswendig wie der ging.
                              • Armilar
                                Armilar Most Active Forum Testing @ticaki last edited by
                                @ticaki
                                Falls Tasmota noch existiert, dann das Gerät sechs mal kurz einschalten (<10s). Beim siebten Einschalten erfolgt der Factory-Reset.
                                Gab auch irgendwas mit einer von den beiden Tasten... Weiß ich aber auch nicht mehr...
                                Ansonsten wie ein neues Panel behandeln und komplett ab Tasmota Flashen anfangen... Die Dinger sind eigentlich schon sehr robust... Das Display geht erst wieder an, wenn es die Einstellungen hat und weiß, dass es als Panel arbeiten soll:
                                • Armilar
                                  Armilar Most Active Forum Testing last edited by Armilar
                                  @ciwa sagte in SONOFF NSPanel mit Lovelace UI:
                                  javascript.0 2025-08-27 21:38:59.670 warn State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                  Sieht ja irgendwie danach aus, als wäre der Datenpunkt:
                                  bei dir nicht vorhanden...
                                  Wäre dann wohl eher ein Bug im Javascript-Adapter
                                  Ich habe da aber einen Datenpunkt und keine Warnung...
                                  • Ciwa
                                    Ciwa last edited by
                                    @armilar
                                    So beide Themen gelöst....Danke.
                                    NSPanel einmal komplett neu.....läuft.
                                    JS Adapter auf Last Stable 8.9.2 da ist dann auch der Datenpunkt wieder da.
                                    @ticaki @TT-Tom auch noch mal explizit Danke an euch.
                                    Ich bin zwar nur einfacher User, aber ab und zu etwas debugging macht auch nicht dümmer.
                                    Bis bald mal....Proxmox 9, und Serverumzug in den Keller steht an 🙂
                                    Ciwa
                                    lovelace ui nspanel sonoff
                                    267
                                    7522
                                    5591314
