    3. Off Topic
    4. Proxmox
    5. Proxmox ioBroker LXC - Login, Nutzer, Rechte Fragen
      Thomas Braun Most Active @Rushmed last edited by
      @rushmed sagte in Proxmox ioBroker LXC - Login, Nutzer, Rechte Fragen:
      Jetzt kann ich iob diag ausführen. Danke!
      Zeig mal den Output.
      Vielleicht sehe ich ja noch was.
        Rushmed Most Active @Thomas Braun last edited by
        @thomas-braun Danke
          ========== Start marking the full check here ===========
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
          Operating System: Debian GNU/Linux 13 (trixie)
           Static hostname: ioBroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.14.8-2-pve
              Architecture: x86-64
          OS is similar to:
          model name      : Intel(R) Core(TM) i5-9600T CPU @ 2.30GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           20:55:18 up 23 min,  1 user,  load average: 0.13, 0.13, 0.18
          CPU threads: 2
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'trixie'!
          *** TIME AND TIMEZONES ***
                         Local time: Thu 2025-08-28 20:55:18 CEST
                     Universal time: Thu 2025-08-28 18:55:18 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          master
          HOME=/home/master
          GROUPS=master adm dialout sudo audio video plugdev users iobroker
          iobroker
          HOME=/home/iobroker
          SUDO_HOME=/home/master
          GROUPS=iobroker tty dialout sudo audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server:         false
          Unit display-manager.service could not be found.
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:             12G        785M         11G        3.0M        768M         11G
          Swap:             0B          0B          0B
          Total:           12G        785M         11G
          Active iob-Instances:   5
                  12000 M total memory
                    750 M used memory
                    861 M active memory
                    462 M inactive memory
                  10519 M free memory
                      0 M buffer memory
                    733 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          top - 20:55:18 up 23 min,  1 user,  load average: 0.13, 0.13, 0.18
          Tasks:  37 total,   1 running,  36 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  12000.0 total,  10518.8 free,    750.9 used,    733.1 buff/cache
          MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11249.1 avail Mem
          *** FAILED SERVICES ***
            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                  ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                  SUB    -> The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          dmesg: read kernel buffer failed: Operation not permitted
          No critical errors detected
          *** FILESYSTEM ***
          /dev/loop2     ext4      7.8G  4.1G  3.4G  55% /
          none           tmpfs     492K  4.0K  488K   1% /dev
          udev           devtmpfs   32G     0   32G   0% /dev/tty
          tmpfs          tmpfs      32G     0   32G   0% /dev/shm
          tmpfs          tmpfs      13G  132K   13G   1% /run
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs      32G  2.8M   32G   1% /tmp
          tmpfs          tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
          Show mounted filesystems:
          TARGET SOURCE     FSTYPE OPTIONS
          /      /dev/loop2 ext4   rw,relatime
          /var:
          811M    /var/
          625M    /var/cache
          621M    /var/cache/apt
          531M    /var/cache/apt/archives
          156M    /var/lib
          Archived and active journals take up 27.8M in the file system.
          /opt/iobroker/backups:
          8.8M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          241M    /opt/iobroker/iobroker-data/
          206M    /opt/iobroker/iobroker-data/files
          48M     /opt/iobroker/iobroker-data/files/iot.admin
          47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          31M     /opt/iobroker/iobroker-data/objects.jsonl
          8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-_Yus88Xv.js
          8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
          8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
          USB-Devices by-id:
          No Devices found 'by-id'
          *** ZigBee Settings ***
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
          HINT:
          Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v22.18.0
          /usr/bin/node           v22.18.0
          /usr/bin/npm            11.5.2
          /usr/bin/npx            11.5.2
          /usr/bin/corepack       0.33.0
          nodejs:
            Installed: 22.18.0-1nodesource1
            Candidate: 22.18.0-1nodesource1
            Version table:
           *** 22.18.0-1nodesource1 500
                  500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               22.17.1-1nodesource1 500
               22.17.0-1nodesource1 500
               22.16.0-1nodesource1 500
               22.15.1-1nodesource1 500
               22.15.0-1nodesource1 500
               22.14.0-1nodesource1 500
               22.13.1-1nodesource1 500
               22.13.0-1nodesource1 500
               22.12.0-1nodesource1 500
               22.11.0-1nodesource1 500
               22.10.0-1nodesource1 500
               22.9.0-1nodesource1 500
               22.8.0-1nodesource1 500
               22.7.0-1nodesource1 500
               22.6.0-1nodesource1 500
               22.5.1-1nodesource1 500
               22.5.0-1nodesource1 500
               22.4.1-1nodesource1 500
               22.4.0-1nodesource1 500
               22.3.0-1nodesource1 500
               22.2.0-1nodesource1 500
               22.1.0-1nodesource1 500
               22.0.0-1nodesource1 500
               20.19.2+dfsg-1 500
                  500 http://deb.debian.org/debian trixie/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          Checking for nodejs vulnerability:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 856)
          Core adapters versions
          js-controller:  7.0.7
          admin:          7.6.17
          javascript:     8.9.2
          nodejs modules from github:     1
          | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
            system.adapter.artnet.0                 : artnet                : ioBroker                                 - disabled, port: 6454
            system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 - disabled
            system.adapter.awtrix-light.1           : awtrix-light          : ioBroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
            system.adapter.denon.0                  : denon                 : ioBroker                                 - disabled
            system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
            system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 - disabled, port: 8899
            system.adapter.habpanel.0               : habpanel              : ioBroker                                 - disabled
            system.adapter.hass.0                   : hass                  : ioBroker                                 - disabled, port: 8123
            system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
            system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
          + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
            system.adapter.iot.0                    : iot                   : ioBroker                                 - disabled
            system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
            system.adapter.kodi.0                   : kodi                  : ioBroker                                 - disabled, port: 9090
            system.adapter.logparser.0              : logparser             : ioBroker                                 - disabled
            system.adapter.matter.0                 : matter                : ioBroker                                 - disabled
            system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
            system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
            system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 - disabled, port: 1883, bind: 0.0.0.0
            system.adapter.philips-tv.0             : philips-tv            : ioBroker                                 - disabled
            system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
            system.adapter.pixelit.0                : pixelit               : ioBroker                                 - disabled
            system.adapter.pixelit.1                : pixelit               : ioBroker                                 - disabled
            system.adapter.pixelit.2                : pixelit               : ioBroker                                 - disabled
            system.adapter.proxmox.0                : proxmox               : ioBroker                                 - disabled, port: 8006
            system.adapter.reolink.0                : reolink               : ioBroker                                 - disabled
            system.adapter.reolink.1                : reolink               : ioBroker                                 - disabled
            system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
            system.adapter.simple-api.0             : simple-api            : ioBroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 - disabled
            system.adapter.smartmeter.1             : smartmeter            : ioBroker                                 - disabled
            system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1884, bind: 0.0.0.0
            system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 - disabled
            system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.telegram.1               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
            system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
            system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.windows-control.0        : windows-control       : ioBroker                                 - disabled
            system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 - disabled, port: 5000
            system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
            system.adapter.zigbee.0                 : zigbee                : ioBroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
          + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.42:6638
          + instance is alive
          ioBroker-Repositories
          │ (index) │ name               │ url                                                     │ auto upgrade │
          │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
          │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
          │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
          Active repo(s): Stable (default)
          Upgrade policy: minor
          Installed ioBroker-Adapters
          Used repository: Stable (default)
          Adapter    "admin"        : 7.6.17   , installed 7.6.17
          Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
          Adapter    "artnet"       : 1.2.2    , installed 1.2.2
          Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.3.5    , installed 3.3.5
          Adapter    "denon"        : 1.15.12  , installed 1.15.12
          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
          Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "hass"         : 1.4.0    , installed 1.4.0
          Adapter    "hue"          : 3.16.2   , installed 3.16.2
          Adapter    "ical"         : 1.16.2   , installed 1.16.2
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
          Controller "js-controller": 7.0.7    , installed 7.0.7
          Adapter    "kodi"         : 3.1.0    , installed 3.1.0
          Adapter    "logparser"    : 2.4.0    , installed 2.4.0
          Adapter    "matter"       : 0.5.1    , installed 0.5.1
          Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
          Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
          Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
          Adapter    "reolink"      : 1.2.3    , installed 1.2.3
          Adapter    "shelly"       : 10.1.0   , installed 10.1.0
          Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "socketio"     : 6.7.1    , installed 7.0.8
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "telegram"     : 4.1.0    , installed 4.1.0
          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "windows-control": 0.1.5  , installed 0.1.5
          Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "ws"           : 2.6.2    , installed 3.0.19
          Adapter    "zigbee"       : 2.0.5    , installed 3.0.1
          Objects and States
          Objects:        18888
          States:         17674
          W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
          Hit:1 http://deb.debian.org/debian trixie InRelease
          Hit:2 http://security.debian.org trixie-security InRelease
          Hit:3 http://deb.debian.org/debian trixie-updates InRelease
          Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          707396     1/init
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       769395     1387/iobroker.js-co
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       766858     1387/iobroker.js-co
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          710114     296/master
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          710115     296/master
          tcp6       0      0 :::111                  :::*                    LISTEN      0          707398     1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          708782     1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       769501     1412/io.admin.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          709765     109/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          707397     1/init
          udp6       0      0 :::111                  :::*                                0          707399     1/init
          2025-08-28 20:41:19.560  - info: zigbee.1 (1500) Zigbee-Herdsman started successfully with Coordinator firmware version: zStack3x0 : 20240710 (2-1.2.7.1)
          2025-08-28 20:41:19.560  - info: zigbee.1 (1500) Unable to disable LED, unsupported function.
          2025-08-28 20:41:19.585  - info: zigbee.1 (1500) 0x00158d0003a4b407 (addr 22720): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
          2025-08-28 20:41:19.587  - info: zigbee.1 (1500) 0x00158d00035388c1 (addr 5207): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
          2025-08-28 20:41:19.588  - info: zigbee.1 (1500) 0x00158d0002e32c4b (addr 8948): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
          2025-08-28 20:41:19.611  - info: zigbee.1 (1500) 0x00178801094009bc (addr 1293): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
          2025-08-28 20:41:19.612  - info: zigbee.1 (1500) 0x00158d000770df1d (addr 45338): RTCGQ11LM - Aqara Motion sensor (EndDevice)
          2025-08-28 20:41:19.675  - info: zigbee.1 (1500) 0xa4c138012453af11 (addr 49346): ZTH05 - Tuya Temperature and humidity sensor (EndDevice)
          2025-08-28 20:41:19.676  - info: zigbee.1 (1500) 0x54ef4410001c5a2f (addr 48527): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
          2025-08-28 20:41:19.677  - info: zigbee.1 (1500) 0x00158d00091b240e (addr 20204): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
          2025-08-28 20:41:19.677  - info: zigbee.1 (1500) 0x00158d0008d07e8a (addr 16064): RTCGQ11LM - Aqara Motion sensor (EndDevice)
          2025-08-28 20:41:19.684  - info: zigbee.1 (1500) 0x2c1165fffebea535 (addr 44336): E1812 - IKEA TRADFRI shortcut button (EndDevice)
          2025-08-28 20:41:19.686  - info: zigbee.1 (1500) 0xa4c138e58658a4ab (addr 8334): TS0601_soil - Tuya Soil sensor (EndDevice)
          2025-08-28 20:41:19.695  - info: zigbee.1 (1500) 0xa4c13806a707c4a5 (addr 8651): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
          2025-08-28 20:41:19.696  - info: zigbee.1 (1500) 0xa4c1388a0265f651 (addr 57431): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
          2025-08-28 20:41:19.698  - info: zigbee.1 (1500) 0xa4c1382c8738170e (addr 57453): TS0601_soil - Tuya Soil sensor (EndDevice)
          2025-08-28 20:41:19.700  - info: zigbee.1 (1500) 0xa4c138c7b3e4ec4d (addr 64790): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
          2025-08-28 20:41:19.701  - info: zigbee.1 (1500) 0xa4c13827928b74ce (addr 59985): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
          2025-08-28 20:41:19.703  - info: zigbee.1 (1500) 0xa4c138676454b1db (addr 11729): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
          2025-08-28 20:41:19.704  - info: zigbee.1 (1500) 0xa4c13875cd90235e (addr 37381): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
          2025-08-28 20:41:19.705  - info: zigbee.1 (1500) 0xa4c1382c0fb9ec89 (addr 31931): NAS-AB06B2 - Neo Outdoor solar alarm (EndDevice)
          2025-08-28 20:41:19.706  - info: zigbee.1 (1500) 0x5cc7c1fffe88261d (addr 60589): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
          2025-08-28 20:41:19.706  - info: zigbee.1 (1500) Currently 20 devices are joined:
          2025-08-28 20:41:19.707  - info: zigbee.1 (1500) Zigbee started
          2025-08-28 20:41:20.109  - info: zigbee.1 (1500) debug devices set to []
          iob diag has finished.
            Swap: 0B
            Ich würde immer SWAP einrichten. Auch bei 12 GB RAM.
            {1}
            • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
            Steht in der Anleitung
            https://www.iobroker.net/#de/documentation/install/proxmox.md
            drin, wie man das noch beseitigen kann.
            Ansonsten schaut das gut aus.
              Das hat mit:
              sudo systemctl mask run-rpc_pipefs.mount
              sudo systemctl mask var-lib-nfs-rpc_pipefs.mount
              leider nicht geklappt.
                @rushmed
                Auch das wirkt nur bei einem Neustart.
                  @thomas-braun Check, hat geklappt.
                  Vielen Dank!
                    Rushmed Most Active @Rushmed last edited by Rushmed
                    Hat noch jemand eine Idee zu:
                    Kann ich das Autologind der LXC Konsole in der Proxmox WebUI von "root" auf "master" umstellen?
                    Die Ergänzung von:
                    # systemctl edit container-getty@.service
                    mit
                    [Service]
                    ExecStart=
                    ExecStart=-/sbin/agetty --autologin master --noclear --keep-baud tty%I 115200,38400,9600 $TERM
                    hat nicht geklappt.
                    Danke vorab!
                      SabineT @Rushmed last edited by
                      @thomas-braun Danke.
                      Jetzt ist der User in der Gruppe aber die Meldung bleibt.
                      root@ioBroker:~# adduser master iobroker
                      warn: The user `master' is already a member of `iobroker'.
                      Ich muss auch immer das PW von master eingeben obwohl ich damit angemeldet bin.
                      Noch ne Idee?
                      Wenn sudo verwendet wird, muss man immer sein PW eingeben, ausser, man passt die /etc/sudoers an, wird aber nicht empfohlen.
                        Rushmed Most Active @SabineT last edited by
                        @sabinet Klar, aber ich habe kein sudo verwendet:
                        https://forum.iobroker.net/post/1291576
                        S Wal 2 Replies Last reply Reply Quote 0
                          @rushmed Du nicht, aber iob verwendet sudo für Befehle, die nur als root funktionieren.
                            Thomas Braun Most Active @SabineT last edited by
                            Genauer:
                            Ein User muss sich gegen sudo authentizifieren, wenn dieser User in die Rolle eines anderen users schlüpft. Das ist meist die root-Rolle, ein paar der iobroker-Skripte wechseln aber auch zum user 'iobroker'.
                            Und damit man das bei mehreren aufeinander folgenden ähnlichen Bedingungen nicht jedes Mal eingeben muss gibt es in der Regel ein Zeitfenster in dem das Passwort nicht erneut abgefragt wird.
                            • Wal
                              Wal Developer @Rushmed last edited by
                              @rushmed ,
                              nutze einen ssh-client(z.B. Bitvise ssh-client) anstatt die Konsole, da funktioniert es auch mit dem PW.
                              Die Web-Konsole nutze ich auch nur im Notfall, da es Einschränkungen gibt.
                                Rushmed Most Active last edited by
                                OK, danke für die Antworten.
                                1.2k
                                81.1k
                                autologin rechte user
                                845
