    3. Off Topic
    4. Proxmox
    5. Proxmox ioBroker LXC - Login, Nutzer, Rechte Fragen
      Rushmed Most Active @Thomas Braun last edited by
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.14.8-2-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i5-9600T CPU @ 2.30GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       20:55:18 up 23 min,  1 user,  load average: 0.13, 0.13, 0.18
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-08-28 20:55:18 CEST
                 Universal time: Thu 2025-08-28 18:55:18 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      master
      HOME=/home/master
      GROUPS=master adm dialout sudo audio video plugdev users iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/master
      GROUPS=iobroker tty dialout sudo audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             12G        785M         11G        3.0M        768M         11G
      Swap:             0B          0B          0B
      Total:           12G        785M         11G
      Active iob-Instances:   5
              12000 M total memory
                750 M used memory
                861 M active memory
                462 M inactive memory
              10519 M free memory
                  0 M buffer memory
                733 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 20:55:18 up 23 min,  1 user,  load average: 0.13, 0.13, 0.18
      Tasks:  37 total,   1 running,  36 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  12000.0 total,  10518.8 free,    750.9 used,    733.1 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11249.1 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      /dev/loop2     ext4      7.8G  4.1G  3.4G  55% /
      none           tmpfs     492K  4.0K  488K   1% /dev
      udev           devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs          tmpfs      32G     0   32G   0% /dev/shm
      tmpfs          tmpfs      13G  132K   13G   1% /run
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs      32G  2.8M   32G   1% /tmp
      tmpfs          tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
      Show mounted filesystems:
      TARGET SOURCE     FSTYPE OPTIONS
      /      /dev/loop2 ext4   rw,relatime
      /var:
      811M    /var/
      625M    /var/cache
      621M    /var/cache/apt
      531M    /var/cache/apt/archives
      156M    /var/lib
      Archived and active journals take up 27.8M in the file system.
      /opt/iobroker/backups:
      8.8M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      241M    /opt/iobroker/iobroker-data/
      206M    /opt/iobroker/iobroker-data/files
      48M     /opt/iobroker/iobroker-data/files/iot.admin
      47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-_Yus88Xv.js
      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
      8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.18.0
      /usr/bin/node           v22.18.0
      /usr/bin/npm            11.5.2
      /usr/bin/npx            11.5.2
      /usr/bin/corepack       0.33.0
      nodejs:
        Installed: 22.18.0-1nodesource1
        Candidate: 22.18.0-1nodesource1
        Version table:
       *** 22.18.0-1nodesource1 500
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.17.1-1nodesource1 500
           22.17.0-1nodesource1 500
           22.16.0-1nodesource1 500
           22.15.1-1nodesource1 500
           22.15.0-1nodesource1 500
           22.14.0-1nodesource1 500
           22.13.1-1nodesource1 500
           22.13.0-1nodesource1 500
           22.12.0-1nodesource1 500
           22.11.0-1nodesource1 500
           22.10.0-1nodesource1 500
           22.9.0-1nodesource1 500
           22.8.0-1nodesource1 500
           22.7.0-1nodesource1 500
           22.6.0-1nodesource1 500
           22.5.1-1nodesource1 500
           22.5.0-1nodesource1 500
           22.4.1-1nodesource1 500
           22.4.0-1nodesource1 500
           22.3.0-1nodesource1 500
           22.2.0-1nodesource1 500
           22.1.0-1nodesource1 500
           22.0.0-1nodesource1 500
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 856)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     1
      | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
        system.adapter.artnet.0                 : artnet                : ioBroker                                 - disabled, port: 6454
        system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 - disabled
        system.adapter.awtrix-light.1           : awtrix-light          : ioBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        system.adapter.denon.0                  : denon                 : ioBroker                                 - disabled
        system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
        system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 - disabled, port: 8899
        system.adapter.habpanel.0               : habpanel              : ioBroker                                 - disabled
        system.adapter.hass.0                   : hass                  : ioBroker                                 - disabled, port: 8123
        system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
        system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
        system.adapter.iot.0                    : iot                   : ioBroker                                 - disabled
        system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
        system.adapter.kodi.0                   : kodi                  : ioBroker                                 - disabled, port: 9090
        system.adapter.logparser.0              : logparser             : ioBroker                                 - disabled
        system.adapter.matter.0                 : matter                : ioBroker                                 - disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
        system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
        system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.philips-tv.0             : philips-tv            : ioBroker                                 - disabled
        system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
        system.adapter.pixelit.0                : pixelit               : ioBroker                                 - disabled
        system.adapter.pixelit.1                : pixelit               : ioBroker                                 - disabled
        system.adapter.pixelit.2                : pixelit               : ioBroker                                 - disabled
        system.adapter.proxmox.0                : proxmox               : ioBroker                                 - disabled, port: 8006
        system.adapter.reolink.0                : reolink               : ioBroker                                 - disabled
        system.adapter.reolink.1                : reolink               : ioBroker                                 - disabled
        system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
        system.adapter.simple-api.0             : simple-api            : ioBroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 - disabled
        system.adapter.smartmeter.1             : smartmeter            : ioBroker                                 - disabled
        system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1884, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 - disabled
        system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.1               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
        system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.windows-control.0        : windows-control       : ioBroker                                 - disabled
        system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 - disabled, port: 5000
        system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
        system.adapter.zigbee.0                 : zigbee                : ioBroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
      + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.42:6638
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
      Active repo(s): Stable (default)
      Upgrade policy: minor
      Installed ioBroker-Adapters
      Used repository: Stable (default)
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "artnet"       : 1.2.2    , installed 1.2.2
      Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "hue"          : 3.16.2   , installed 3.16.2
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "kodi"         : 3.1.0    , installed 3.1.0
      Adapter    "logparser"    : 2.4.0    , installed 2.4.0
      Adapter    "matter"       : 0.5.1    , installed 0.5.1
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
      Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee"       : 2.0.5    , installed 3.0.1
      Objects and States
      Objects:        18888
      States:         17674
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://security.debian.org trixie-security InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          707396     1/init
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       769395     1387/iobroker.js-co
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       766858     1387/iobroker.js-co
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          710114     296/master
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          710115     296/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          707398     1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          708782     1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       769501     1412/io.admin.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          709765     109/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          707397     1/init
      udp6       0      0 :::111                  :::*                                0          707399     1/init
      2025-08-28 20:41:19.560  - info: zigbee.1 (1500) Zigbee-Herdsman started successfully with Coordinator firmware version: zStack3x0 : 20240710 (2-1.2.7.1)
      2025-08-28 20:41:19.560  - info: zigbee.1 (1500) Unable to disable LED, unsupported function.
      2025-08-28 20:41:19.585  - info: zigbee.1 (1500) 0x00158d0003a4b407 (addr 22720): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      2025-08-28 20:41:19.587  - info: zigbee.1 (1500) 0x00158d00035388c1 (addr 5207): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      2025-08-28 20:41:19.588  - info: zigbee.1 (1500) 0x00158d0002e32c4b (addr 8948): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      2025-08-28 20:41:19.611  - info: zigbee.1 (1500) 0x00178801094009bc (addr 1293): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
      2025-08-28 20:41:19.612  - info: zigbee.1 (1500) 0x00158d000770df1d (addr 45338): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      2025-08-28 20:41:19.675  - info: zigbee.1 (1500) 0xa4c138012453af11 (addr 49346): ZTH05 - Tuya Temperature and humidity sensor (EndDevice)
      2025-08-28 20:41:19.676  - info: zigbee.1 (1500) 0x54ef4410001c5a2f (addr 48527): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
      2025-08-28 20:41:19.677  - info: zigbee.1 (1500) 0x00158d00091b240e (addr 20204): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      2025-08-28 20:41:19.677  - info: zigbee.1 (1500) 0x00158d0008d07e8a (addr 16064): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      2025-08-28 20:41:19.684  - info: zigbee.1 (1500) 0x2c1165fffebea535 (addr 44336): E1812 - IKEA TRADFRI shortcut button (EndDevice)
      2025-08-28 20:41:19.686  - info: zigbee.1 (1500) 0xa4c138e58658a4ab (addr 8334): TS0601_soil - Tuya Soil sensor (EndDevice)
      2025-08-28 20:41:19.695  - info: zigbee.1 (1500) 0xa4c13806a707c4a5 (addr 8651): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
      2025-08-28 20:41:19.696  - info: zigbee.1 (1500) 0xa4c1388a0265f651 (addr 57431): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
      2025-08-28 20:41:19.698  - info: zigbee.1 (1500) 0xa4c1382c8738170e (addr 57453): TS0601_soil - Tuya Soil sensor (EndDevice)
      2025-08-28 20:41:19.700  - info: zigbee.1 (1500) 0xa4c138c7b3e4ec4d (addr 64790): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
      2025-08-28 20:41:19.701  - info: zigbee.1 (1500) 0xa4c13827928b74ce (addr 59985): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
      2025-08-28 20:41:19.703  - info: zigbee.1 (1500) 0xa4c138676454b1db (addr 11729): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
      2025-08-28 20:41:19.704  - info: zigbee.1 (1500) 0xa4c13875cd90235e (addr 37381): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
      2025-08-28 20:41:19.705  - info: zigbee.1 (1500) 0xa4c1382c0fb9ec89 (addr 31931): NAS-AB06B2 - Neo Outdoor solar alarm (EndDevice)
      2025-08-28 20:41:19.706  - info: zigbee.1 (1500) 0x5cc7c1fffe88261d (addr 60589): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
      2025-08-28 20:41:19.706  - info: zigbee.1 (1500) Currently 20 devices are joined:
      2025-08-28 20:41:19.707  - info: zigbee.1 (1500) Zigbee started
      2025-08-28 20:41:20.109  - info: zigbee.1 (1500) debug devices set to []
      iob diag has finished.
        Thomas Braun Most Active @Rushmed last edited by
        @rushmed sagte in Proxmox ioBroker LXC - Login, Nutzer, Rechte Fragen:
        Swap: 0B
        Ich würde immer SWAP einrichten. Auch bei 12 GB RAM.
        {1}
        • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        Steht in der Anleitung
        https://www.iobroker.net/#de/documentation/install/proxmox.md
        drin, wie man das noch beseitigen kann.
        Ansonsten schaut das gut aus.
          Das hat mit:
          sudo systemctl mask run-rpc_pipefs.mount
          sudo systemctl mask var-lib-nfs-rpc_pipefs.mount
          leider nicht geklappt.
            @rushmed
            Auch das wirkt nur bei einem Neustart.
              @thomas-braun Check, hat geklappt.
              Vielen Dank!
                Rushmed Most Active @Rushmed last edited by Rushmed
                Hat noch jemand eine Idee zu:
                Kann ich das Autologind der LXC Konsole in der Proxmox WebUI von "root" auf "master" umstellen?
                Die Ergänzung von:
                # systemctl edit container-getty@.service
                mit
                [Service]
                ExecStart=
                ExecStart=-/sbin/agetty --autologin master --noclear --keep-baud tty%I 115200,38400,9600 $TERM
                hat nicht geklappt.
                Danke vorab!
                  SabineT @Rushmed last edited by
                  @thomas-braun Danke.
                  Jetzt ist der User in der Gruppe aber die Meldung bleibt.
                  root@ioBroker:~# adduser master iobroker
                  warn: The user `master' is already a member of `iobroker'.
                  Ich muss auch immer das PW von master eingeben obwohl ich damit angemeldet bin.
                  Noch ne Idee?
                  Wenn sudo verwendet wird, muss man immer sein PW eingeben, ausser, man passt die /etc/sudoers an, wird aber nicht empfohlen.
                    Rushmed Most Active @SabineT last edited by
                    @sabinet Klar, aber ich habe kein sudo verwendet:
                    https://forum.iobroker.net/post/1291576
                    S Wal 2 Replies Last reply Reply Quote 0
                      @rushmed Du nicht, aber iob verwendet sudo für Befehle, die nur als root funktionieren.
                        Thomas Braun Most Active @SabineT last edited by
                        Genauer:
                        Ein User muss sich gegen sudo authentizifieren, wenn dieser User in die Rolle eines anderen users schlüpft. Das ist meist die root-Rolle, ein paar der iobroker-Skripte wechseln aber auch zum user 'iobroker'.
                        Und damit man das bei mehreren aufeinander folgenden ähnlichen Bedingungen nicht jedes Mal eingeben muss gibt es in der Regel ein Zeitfenster in dem das Passwort nicht erneut abgefragt wird.
                        • Wal
                          Wal Developer @Rushmed last edited by
                          @rushmed ,
                          nutze einen ssh-client(z.B. Bitvise ssh-client) anstatt die Konsole, da funktioniert es auch mit dem PW.
                          Die Web-Konsole nutze ich auch nur im Notfall, da es Einschränkungen gibt.
                            Rushmed Most Active last edited by
                            OK, danke für die Antworten.
                            1.2k
                            81.1k
                            autologin rechte user
                            845
