    4. JavaScript
    5. HowTo: Zusatz-Programme fuer jarvis v3
      MCU @Mabbi last edited by
      @mabbi Sorry von energie, du woltest ja das erstmal nutzen
        Mabbi @MCU last edited by
        @mcu
          "common": {
            "name": "D_Energie copy"
          "native": {
            "url": "",
            "data": {
              "lines": [
                  "name": "Leistung gesamt",
                  "id": "0_userdata.0.Datenpunkte.PV.Leistung_gesamt",
                  "instance": "system.adapter.sql.0",
                  "thickness": "1",
                  "chartType": "auto",
                  "aggregate": "max",
                  "isBoolean": null,
                  "symbolSize": 3,
                  "validTime": "",
                  "unit": "  kW",
                  "color": "#1a98a6",
                  "fill": 0.2,
                  "shadowsize": "",
                  "min": "-14",
                  "max": "20",
                  "ignoreNull": "0",
                  "noFuture": false,
                  "percentile": 50,
                  "integralUnit": 60,
                  "integralInterpolation": "none",
                  "yticks": "-1",
                  "xaxe": "",
                  "xticks": "6",
                  "yOffset": "0",
                  "points": false,
                  "hide": false,
                  "yaxe": "left",
                  "convert": "val / 1000",
                  "afterComma": "3"
                  "name": "EV-Ladestrom",
                  "id": "0_userdata.0.Datenpunkte.EV_Wallbox.EV-Ladestrom",
                  "instance": "system.adapter.history.0",
                  "thickness": "1",
                  "aggregate": "max",
                  "isBoolean": null,
                  "symbolSize": 3,
                  "validTime": "",
                  "fill": 0.2,
                  "min": "-8",
                  "max": "22",
                  "convert": "val / 1000 * -1",
                  "color": "#702ce6",
                  "xticks": "4",
                  "commonYAxis": "0",
                  "ignoreNull": "0"
                  "name": "Eigenverbrauch",
                  "id": "0_userdata.0.Datenpunkte.Strom.Eigenverbrauch",
                  "thickness": "1",
                  "aggregate": "onchange",
                  "isBoolean": null,
                  "symbolSize": 3,
                  "validTime": 35,
                  "fill": 0.2,
                  "min": "-8",
                  "max": "22",
                  "color": "#00687d",
                  "xticks": "4",
                  "commonYAxis": "0",
                  "ignoreNull": "0"
                  "name": "Netzbezug",
                  "id": "0_userdata.0.Datenpunkte.Strom.Netzbezug",
                  "thickness": "1",
                  "isBoolean": null,
                  "symbolSize": 3,
                  "validTime": 35,
                  "fill": 0.3,
                  "min": "-8",
                  "max": "22",
                  "color": "#b82124",
                  "xticks": "4",
                  "commonYAxis": "0",
                  "ignoreNull": "0",
                  "afterComma": ""
                  "name": "Einspeisung",
                  "id": "0_userdata.0.Datenpunkte.Strom.Einspeisung",
                  "thickness": "1",
                  "isBoolean": null,
                  "symbolSize": 3,
                  "validTime": 35,
                  "fill": 0.2,
                  "min": "-8",
                  "max": "22",
                  "color": "#10952f",
                  "xticks": "4",
                  "commonYAxis": "0",
                  "ignoreNull": "0"
                  "name": "Klima Buero OG Betrieb",
                  "id": "0_userdata.0.Datenpunkte.Temperatur-Steuerung.Klima_Buero_OG_Betrieb",
                  "thickness": "1",
                  "chartType": "line",
                  "aggregate": "minmax",
                  "isBoolean": null,
                  "symbolSize": 3,
                  "validTime": "",
                  "fill": 1,
                  "min": "0",
                  "max": "10",
                  "convert": "val * 0.25",
                  "color": "#008b47",
                  "xticks": "4",
                  "commonYAxis": "",
                  "ignoreNull": "false",
                  "yOffset": "0",
                  "percentile": 50,
                  "integralUnit": 60,
                  "name": "Klima Buero Betrieb",
                  "id": "0_userdata.0.Datenpunkte.Temperatur-Steuerung.Klima_Buero_Betrieb",
                  "thickness": "1",
                  "isBoolean": null,
                  "symbolSize": 3,
                  "validTime": "",
                  "fill": 1,
                  "min": "0",
                  "max": "10",
                  "convert": "(val * 0.125)",
                  "color": "#007583",
                  "xticks": "4",
                  "commonYAxis": "",
                  "yOffset": "0"
              "marks": [
                  "color": "#5c1011",
                  "lineId": "0",
                  "upperValueOrId": "-2",
                  "lowerValueOrId": "",
                  "fill": 0,
                  "lineStyle": "dotted",
                  "text": "2 KW ",
                  "textSize": "10",
                  "textColor": "#9b2e2f"
                  "color": "#5c1011",
                  "lineId": "0",
                  "upperValueOrId": "-4",
                  "fill": 0,
                  "text": "4 KW ",
                  "textSize": "10",
                  "color": "#5c1011",
                  "lineId": "0",
                  "upperValueOrId": "-6",
                  "fill": 0,
                  "text": "6 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "2",
                  "fill": 0,
                  "text": "2 KW ",
                  "textSize": "10",
                  "textColor": "#1d6923"
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "4",
                  "fill": 0,
                  "text": "4 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "6",
                  "fill": 0,
                  "text": "6 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "8",
                  "fill": 0,
                  "text": "8 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "10",
                  "fill": 0,
                  "text": "10 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "12",
                  "fill": 0,
                  "text": "12 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "14",
                  "fill": 0,
                  "text": "14 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "16",
                  "fill": 0,
                  "text": "16 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "18",
                  "fill": 0,
                  "text": "18 KW ",
                  "textSize": "10",
                  "color": "#5c1011",
                  "lineId": "0",
                  "upperValueOrId": "-8",
                  "fill": 0,
                  "text": "8 KW ",
                  "textSize": "10",
                  "color": "#5c1011",
                  "lineId": "0",
                  "upperValueOrId": "-10",
                  "fill": 0,
                  "text": "10 KW ",
                  "textSize": "10",
                  "color": "#5c1011",
                  "lineId": "0",
                  "upperValueOrId": "-12",
                  "fill": 0,
                  "text": "12 KW ",
                  "textSize": "10",
                  "color": "#5c1011",
                  "lineId": "0",
                  "upperValueOrId": "-14",
                  "fill": 0,
                  "text": "14 KW ",
                  "textSize": "10",
                  "color": "#1d6923",
                  "lineId": "0",
                  "upperValueOrId": "20",
                  "fill": 0,
                  "text": "20 KW ",
                  "textSize": "10",
              "timeType": "relative",
              "relativeEnd": "now",
              "range": "1440",
              "aggregateType": "step",
              "aggregateSpan": "1",
              "legend": "",
              "hoverDetail": true,
              "zoom": true,
              "animation": 0,
              "live": "300",
              "ticks": "",
              "width": "",
              "height": "",
              "noBorder": "",
              "window_bg": "#000000",
              "bg_custom": "",
              "x_labels_color": "",
              "y_labels_color": "",
              "border_color": "#343434",
              "grid_color": "",
              "grid_hideX": true,
              "grid_hideY": true,
              "border_width": "5",
              "barColor": "",
              "barLabels": "topover",
              "barWidth": "",
              "barFontSize": "",
              "barFontColor": "",
              "title": "",
              "titlePos": "",
              "titleColor": "",
              "titleSize": "",
              "legColumns": "",
              "legBgOpacity": "",
              "legBg": "",
              "timeFormat": "",
              "export": false,
              "legendDirection": "",
              "useComma": false,
              "noBackground": true,
              "legActual": false,
              "legFontSize": "",
              "legendHeight": "",
              "resetZoom": "600",
              "autoGridPadding": false,
              "theme": "default",
              "hoverNoInterpolate": false,
              "hoverNoNulls": false,
              "timeFormatCustom": false,
              "border_style": "ridge",
              "border_padding": "5"
          "type": "chart",
          "_id": "echarts.0.D_Energie_copy",
          "acl": {
            "object": 1636,
            "owner": "system.user.admin",
          "user": "system.user.admin",
          "ts": 1755630349601
          MCU @Mabbi last edited by MCU
          @mabbi ok
          • Jetzt erstmal unter 0_userdata das Verzeichnis 0_userdata.0.echarts löschen.
          • dann Verzeichnis für echartDP im Programm wieder auf Standard zurücksetzen und Programm speichern -> DPs werden wieder angelegt
          let echartDP                = '0_userdata.0.echarts';
          • Im Verzeichnis 0_userdata.0.echarts gibt es nun den DP echartsDP, da kommt nun Dein echarts.0.D_Energie_copyals Wert eingetragen.
          M mickemup 2 Replies Last reply Reply Quote 0
            @mcu Cool, jetzt gehts.
            Mein Fehler war die Änderung des javascripts, dadurch wurden die 0_userdata.0.echarts mehrfach angelegt.
            Hatte mich schon gewundert, warum die 2x vorhanden waren.
            Vielen Dank für Deine Hilfe.
            • mickemup
              mickemup @MCU last edited by
              @mcu
              Salü
              Ich habe versucht mit folgenden Skript zu arbeiten:
              Widgets aus- / einblenden
              Scripts "widgetsDisplay.js" kopieren und in Scripts (jarvis) einfügen.
              was eigentlich auch funktioniert hat.
              Meine Idee ist mittels Selektion (klick auf Objekt im Eflussadapter) links unten dann das entsprechende Widget einzublenden (und die anderen auszublenden).
              Dies kriege ich auch hin, allerdings würde ich die alle gerne am "gleichen" Ort haben und nicht ein Lücke haben dort wo das ausgeblendete ist:
              Ist das irgendwie möglich?
              Alternativ-Elegant wäre natürlich auch, wenn man bei "Assign Widget to Box" die ID "relativ" setzen könnte z.B zu einem eigenen DP, dann bleibt die Position natürlich 🙂 .
              Grüsse
              Jarvis V3.1.8
                MCU @mickemup last edited by
                @mickemup
                Bin noch dabei
                https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/scripts-3.2.x-pro/widgets/widgetshiding
                Die "Alternative" schau ich mir auch mal an.
                mickemup 1 Reply Last reply Reply Quote 1
                • mickemup
                  @mcu
                  Super Danke.
                  Für meinen Fall wäre die Alternative wohl fast einfacher (für mich) dann muss ich nur einen Werte ändern.
                  Ansonsten muss ich immer eins: einschalten und das alte ausschalten.
                  Analog mache ich dies bei mir schon mit StateHTML, wo der jeweilige "Grafana-Iframe" in einem DP steht, welcher dann angepasst wird.
                    @mickemup In Deinem Fall müsste man die Ordernumber von diesem Widget ändern, richtig?.
                    mickemup 1 Reply Last reply Reply Quote 0
                    • mickemup
                      @mcu
                      Genau: das Widget oberhalb ist ausgeblendet und das von dir gezeigte sollte eigentlich dann dort sein.
                      Ich hätte wohl am Ende so um die 10 Widgets, aber will nur immer 1 zeigen am selben Ort.
                        @mickemup Sind diese 10 alle eCharts als iFrame?
                        • mickemup
                          @mcu
                          Also oben links habe ich es so StateHTML gelöst.
                          Diese verweisen auf einen Datenpunkt und dort drin passe ich bei einem Klick z.B auf die Produktionsleistung den DP vom StateHTML an:
                          <iframe src="http://192.168.1.203:3000/d-solo/b3395744-04be-4f4d-83ca-358dd5afe53b/energie-live?orgId=1&refresh=30s&theme=light&panelId=27&__feature.dashboardSceneSolo=false" width="100%"  height="325"  frameborder="0"></iframe>
                          Wenn ich analog die ID in "Assign Widget to Box" Widget ID anpassen könnte, wäre es für mich ideal:
                          Unten links sind alles "State Lists" die ich gerne anzeigen würde:
                          Also Anstatt die beiden (oder eben am Ende ca. 10) soll dort nur ein Widget (State List) dargestellt werden.
                            @mickemup Grafana?
                            • mickemup
                              mickemup @MCU last edited by mickemup
                              @mcu Oben links kann ich meine Grafana-Plots durchswitchen ja.
                              Unten Links würde ich das gleiche gerne mit "StateLists" machen.
                              Ober eben halt nur die ausgewählte/rechts angeklickte anzeigen.
                                @mickemup Also jede "Kurve" hat dazu eine eigene StateList, die dann, direkt darunter, angezeigt werden soll?
                                • mickemup
                                  @mcu
                                  Sry nein das ist unabhängig.
                                  Mit Klicks auf die grün markiertern Leistungswerte Toggle ich oben links durch die Grafiken.
                                  Das funktioniert bereits 1A.
                                  Mit Klicks auf die orange markierten Kreise (werden evtl. noch mehr) würde ich gerne durch StateLists "togglen" welche dann unten Links stehen sollen.
                                  Ich hoff ,ich konnte mich verständlich ausdrücken.
                                    @mickemup
                                    Order number ändern zieht nur auf dem Handy. Wäre schneller, da man nur die Reihenfolge ändern müsste.
                                    Aber für PC und Tablet muss man alle nachfolgenden bzw. darunter liegenden Widgets neu berechnen, in Abhängigkeit von der Anzeige (einige sind ja ausgeblendet) und den Werten vom aktuellen Widget, welches man an die neue Position setzen will.
                                      Also man kann mit dem echarts schon richtig coole Dinge bauen:
                                      Vielen Dank für die Arbeit, die Ihr da reinsteckt.
                                        MCU last edited by
                                        @mabbi Stell bitte die JSON der Modul-Konfiguration hinein, damit man sich daran orientieren kann, wenn man es nachbauen möchte. Danke.
                                          Mabbi @MCU last edited by Mabbi
                                          @mcu
                                          Würde ich grne machen, aber wo finde ich die ?
                                          Ich habe die beiden Anzeigen komplett mit dem Diagramme-Editor gebaut und dann in vis eingfügt.
                                          Finde dort aber keine Möglichkeit, ein json anzuzeigen oder zu exportieren.
                                          In Dateien/echart liegen zwar json Dateien drin, die haben aber imho nichts direkt mit den Diagrammen zu tun ?
                                            @mabbi Aus dem zugehörigen eCharts-Objekt die Daten von native.data als </> code.
                                            81.1k
                                            javascript
                                            33
                                            889
                                            206942
