    4. Tester Zigbee Adapter 3.x gesucht
    • mickemup
      mickemup @Asgothian last edited by
      @asgothian
      Hoffe das ist das richtige...
      2025-08-29 20:52:45.525	warn	ELEVATED:NOVAL (ce53) No value published for device 04e3e5fffe73f464
      2025-08-29 20:52:45.525	warn	ELEVATED:I01 (ce53) message received '{}' from device 04e3e5fffe73f464 type 'E2001/E2002'
      2025-08-29 20:52:45.525	warn	ELEVATED:I02 (ce53) value generated '236' from device 04e3e5fffe73f464 for 'Link quality'
      2025-08-29 20:52:45.525	warn	ELEVATED:I01 (ce53) message received '{"linkquality":236}' from device 04e3e5fffe73f464 type 'E2001/E2002'
      2025-08-29 20:52:45.524	warn	ELEVATED:O06 (cb26) Convert does not return a result result for read with {"cluster":"genPowerCfg","attributes":["batteryPercentageRemaining"]} on device 0x04e3e5fffe73f464.
      2025-08-29 20:52:45.524	warn	ELEVATED:SUCCESS (cb26) convert result undefined for device 0x04e3e5fffe73f464
      2025-08-29 20:52:45.523	warn	ELEVATED:I01 (ce53) Zigbee Event of Type readResponse from device 0x04e3e5fffe73f464, incoming event: {"type":"readResponse","data":{"batteryPercentageRemaining":255},"linkquality":236,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":218,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      • Asgothian
        Asgothian Developer @mickemup last edited by
        @mickemup sagte in Tester Zigbee Adapter 3.x gesucht:
        Da hast du Dein Problem - der Konverter liefert leere Daten. Warum weiss ich nicht.
        Das Ergebnis sieht bei mir so aus:
        2025-08-29 21:17:34.106 - warn: zigbee.0 (61503) ELEVATED:O01 (851a) User state change of state zigbee.0.842e14fffe68d6fd.send_payload with value { "read": { "cluster": "genPowerCfg", "attributes": ["batteryPercentageRemaining"] }} (ack: false) from system.adapter.admin.0
        2025-08-29 21:17:34.107 - warn: zigbee.0 (61503) ELEVATED:O02 (851a) Change state 'send_payload' at device 0x842e14fffe68d6fd type 'E2001/E2002'
        2025-08-29 21:17:34.107 - warn: zigbee.0 (61503) ELEVATED:O03 (851a) Publishing to 0x842e14fffe68d6fd of model E2001/E2002 with send_payload
        2025-08-29 21:17:34.108 - warn: zigbee.0 (61503) ELEVATED:O03 (851c) Publishing to 0x842e14fffe68d6fd of model E2001/E2002 with read
        2025-08-29 21:17:34.109 - warn: zigbee.0 (61503) ELEVATED:O04 (851c) convert read, {"cluster":"genPowerCfg","attributes":["batteryPercentageRemaining"]}, {} for device 0x842e14fffe68d6fd with Endpoint read
        2025-08-29 21:17:34.310 - warn: zigbee.0 (61503) ELEVATED:I01 (85e6) Zigbee Event of Type readResponse from device 0x842e14fffe68d6fd, incoming event: {"type":"readResponse","data":{"batteryPercentageRemaining":100},"linkquality":117,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":5,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        2025-08-29 21:17:34.311 - warn: zigbee.0 (61503) ELEVATED:SUCCESS (851c) convert result undefined for device 0x842e14fffe68d6fd
        2025-08-29 21:17:34.311 - warn: zigbee.0 (61503) ELEVATED:O06 (851c) Convert does not return a result result for read with {"cluster":"genPowerCfg","attributes":["batteryPercentageRemaining"]} on device 0x842e14fffe68d6fd.
        2025-08-29 21:17:34.312 - warn: zigbee.0 (61503) ELEVATED:I01 (85e6) message received '{"linkquality":117}' from device 842e14fffe68d6fd type 'E2001/E2002'
        2025-08-29 21:17:34.312 - warn: zigbee.0 (61503) ELEVATED:I02 (85e6) value generated '117' from device 842e14fffe68d6fd for 'Link quality'
        2025-08-29 21:17:34.313 - warn: zigbee.0 (61503) ELEVATED:I01 (85e6) message received '{"battery":100}' from device 842e14fffe68d6fd type 'E2001/E2002'
        2025-08-29 21:17:34.313 - warn: zigbee.0 (61503) ELEVATED:I02 (85e6) value generated '100' from device 842e14fffe68d6fd for 'Battery percent'
        Was hat denn dein Gerät für eine Firmware ?
        A
        mickemup 1 Reply Last reply Reply Quote 0
        • mickemup
          @asgothian
          description: STYRBAR remote control
          build: 2.4.17
          • Asgothian
            Asgothian Developer @mickemup last edited by Asgothian
            @mickemup Ich fürchte da wirst du bei Z2M mal nachhaken müssen - ich erinnere mich dumpf an Wechselwirkungen zwischen der Styrbar Firmware, der Controller Firmware und dem benutzten Herdsman.
            Der Adapter ist da jedenfalls aussen vor - er bekommt keinen Wert, und kann deswegen auch nichts setzen.
            A.
            • mickemup
              @asgothian
              Danke für den Support.
              Habe jetzt nochmals Batterien rein und raus...und plötzlich ging es:
              22:18:22.752	warn	ELEVATED:I02 (319e) value generated '85' from device 04e3e5fffe73f464 for 'Battery percent'
              22:18:22.751	warn	ELEVATED:I01 (319e) message received '{"battery":85}' from device 04e3e5fffe73f464 type 'E2001/E2002'
              22:18:22.751	warn	ELEVATED:I02 (319e) value generated '236' from device 04e3e5fffe73f464 for 'Link quality'
              22:18:22.751	warn	ELEVATED:I01 (319e) message received '{"linkquality":236}' from device 04e3e5fffe73f464 type 'E2001/E2002'
              22:18:22.750	warn	ELEVATED:O06 (2dec) Convert does not return a result result for read with {"cluster":"genPowerCfg","attributes":["batteryPercentageRemaining"]} on device 0x04e3e5fffe73f464.
              22:18:22.750	warn	ELEVATED:SUCCESS (2dec) convert result undefined for device 0x04e3e5fffe73f464
              22:18:22.750	warn	ELEVATED:I01 (319e) Zigbee Event of Type readResponse from device 0x04e3e5fffe73f464, incoming event: {"type":"readResponse","data":{"batteryPercentageRemaining":170},"linkquality":236,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":187,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
              22:18:22.162	warn	ELEVATED:O04 (2f52) convert read, {"cluster":"genPowerCfg","attributes":["batteryPercentageRemaining"]}, {} for device 0x04e3e5fffe73f464 with Endpoint read
              22:18:22.162	warn	ELEVATED:O03 (2f52) Publishing to 0x04e3e5fffe73f464 of model E2001/E2002 with read
              22:18:22.162	warn	ELEVATED:O03 (2f29) Publishing to 0x04e3e5fffe73f464 of model E2001/E2002 with send_payload
              22:18:22.162	warn	ELEVATED:O02 (2f29) Change state 'send_payload' at device 0x04e3e5fffe73f464 type E2001/E2002'
              22:18:22.121	warn	ELEVATED:O01 (2f29) User state change of state zigbee.0.04e3e5fffe73f464.send_payload with value { "read": { "cluster": "genPowerCfg", "attributes": ["batteryPercentageRemaining"] }} (ack: false) from system.adapter.javascript.0
                Wie kann man eigentlich Änderungen an den Werten ("Kalibrierung") durchführen?
                Ich habe mir letztens noch ein paar IKEA Inspelning Steckdosen geholt, als diese wieder verfügbar waren.
                Die letzten liefen so toll, dass ich gar nicht auf "Probleme" eingestellt war.
                Habe jetzt 2 Stück davon installiert und beide zeigen anscheinend ohne Last eine Leistung um die 1W an.
                Laut Z2M
                power_calibration: Calibrates the power value (percentual offset), takes into effect on next report of device. The value must be a number.
                Abgesehen davon, dass ich nicht weiss wo und wie man den Befehl absetzt, frage ich mich wie ein prozentualer offset von 0 aussehen soll.
                Für Hilfe wäre ich sehr dankbar
                • Asgothian
                  Asgothian Developer @Homoran last edited by
                  @homoran sagte in Tester Zigbee Adapter 3.x gesucht:
                  Laut Z2M
                  100% sicher bin ich nicht. Es kann sein das die Kalibrierung erst gehen wird wenn ich mit dem Adapter 3.1 fertig bin.
                  Was du probieren kannst:
                  Option A:
                  • Datenpunkt sendPayload den payload {"power_calibration":10} eintragen
                  • Im log schauen ob es Meldungen gibt
                  • Schauen ob sich der Leistungswert ändert.
                  Option B:
                  • Kachel Umdrehen.
                  • Stift icon nutzen (wie beim Umbenennen / Gruppenzuordnung)
                  • unten das kleine + nutzen um eine 'option' zu bekommen
                  • Als Optionsname power_calibration und als Wert 10 eintragen
                  • Mit save abspeichern (kann sein das da speichern steht - weiss ich gerade nicht
                  • Gerät neu konfigurieren (reconfigure auf der Kachel)
                  • Gerät einmal vom ioBroker aus schalten
                  Ob eines davon funktioniert ist nicht klar - es hängt davon ab wie die Kalibration im Konverter umgesetzt ist. Probieren kann ich das selber aktuell nicht.
                  A.
                    Homoran Global Moderator Administrators @Asgothian last edited by Homoran
                    @asgothian Danke!
                    @asgothian sagte in Tester Zigbee Adapter 3.x gesucht:
                    Dann mach ich das doch!
                    Aber:
                    Methode B wäre mir lieber
                    doch
                    da ist (noch) kein +
                    habe noch v3.0.0
                    EDIT:
                    Update auf 3.0.5 via latest bringt das +, aber leider keine Änderungen.
                    Zumindest nicht mit 10 und -10
                    EDIT2:
                    über den Datenpunkt hab ich's auch versucht.
                    Danach zeigte es gar nichts mehr an, immer nur 0W.
                    Nach Rücksetzen auf Werkseinstellung läuft's erst mal wieder.
                    ich geh da mal systematisch ran, wenn ich mehr Zeit habe
                    • Asgothian
                      @asgothian Danke!
                      [...snip]
                      EDIT2:
                      Das kann eigentlich nicht sein - die Werte werden nicht akzeptiert. Du solltest im Log die folgenden Einträge finden, wenn du die Kalibration versuchst einzustellen. Eher denk ich das da was anderes noch passiert.
                      zigbee.0 2025-09-01 13:39:26.321	info	No converter available for 'E2206' with key 'voltage_calibration'
                      zigbee.0 2025-09-01 13:39:26.321	info	No converter available for 'E2206' with key 'current_calibration'
                      zigbee.0 2025-09-01 13:39:26.321	info	No converter available for 'E2206' with key 'power_calibration'
                      zigbee.0 2025-09-01 13:39:26.321	info	No converter available for 'E2206' with key 'energy_calibration'
                      Warte mal bis morgen ab - ich hab eine Steckdose hier und kann die (allerdings mit der 3.1.0RC1) durch den debugger jagen um zu sehen wie wir die Werte da rein bekommen.
                      Wollte ich sowieso 🙂
                      A
                        da war gar nichts, nada!
                        • Asgothian
                          auch nicht wenn du über den Datenpunkt gegangen bist ? Das wäre komisch.
                          A.
                            @asgothian
                            mea culpa!!!
                            Ich hab wohl irgendwann der Instanz das plappern abgewöhnen wollen 😞
                            Die Logstufe steht auf warn.
                            Kein Wunder dass da nichts kommt.
                            • Asgothian
                              Asgothian Developer @Homoran last edited by Asgothian
                              @homoran So.. nun bin ich mit der Analyse erst einmal durch - das ganze funktioniert so erst einmal nicht. Es ist nicht in den Konvertern hinterlegt (ZHC) oder im Herdsman (ZH) sondern eine Funktion die ausschliesslich bei Z2M implementiert ist.
                              Ob / Wie ich diese im Zigbee Adapter implementieren kann / will ist fraglich.
                              Dann habe ich wieder Adapter-eigenen Code der ggf. durch Code im ZHC übersteuert wird.
                              Nebenbei bin ich auf mehrere Bugs gestossen, die fuer die 3.1 behoben werden. Insbesondere im Umfeld des device_query
                              A.
                                @asgothian
                                Danke!
                                davon geht die Welt nicht unter
                                dann ist das eben ein Feature für Z2M only!
                                • Asgothian
                                  @asgothian
                                  Das kann am Ende heraus kommen. Allerdings will ich mir anschauen was da gemacht wurde - ggf. kann ich da durchaus etwas mit machen. Aber nicht mehr heute 🙂
                                  Was auch immer ich da mache muss aber 'allgemeingültig' sein, sprich nicht an der Ikea Steckdose oder an Steckdosen allgemein hängen, sonst müsste ich die erst noch erkennen.
                                  A.
                                  Nachtrag - Es geht. Zumindest bei dem Gerät wo ich es getestet hab. Und bei meiner 3.1.0RC1. Läuft wie gedacht über 'Option 2', allerdings ohne dass neu konfiguriert oder vom ioBroker aus geschaltet werden muss.
                                  Es wird einfach so aktiv.
                                  Ich geb Dir gerne einen Link wenn du es testen willst. (soviel zu 'nicht mehr Heute' 🙂 )
                                    Springreiter @haselchen last edited by
                                    @haselchen Ich hatte auch 2 an die Seite gelegt weil sie einfach nicht wollten- und nun
                                    funktionieren sie einwandfrei (Version 3.0.5)
                                    zigbee zigbee adapter
                                    27
                                    259
                                    35823
